1 | # Hey Emacs, this is a -*- makefile -*-
2 | #
3 | # WinAVR makefile written by Eric B. Weddington, Jörg Wunsch, et al.
4 | # Released to the Public Domain
5 | # Please read the make user manual!
6 | #
7 | # Additional material for this makefile was submitted by:
8 | # Tim Henigan
9 | # Peter Fleury
10 | # Reiner Patommel
11 | # Sander Pool
12 | # Frederik Rouleau
13 | # Markus Pfaff
14 | #
15 | # On command line:
16 | #
17 | # make all = Make software.
18 | #
19 | # make clean = Clean out built project files.
20 | #
21 | # make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
22 | #
23 | # make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
24 | # 4.07 or greater).
25 | #
26 | # make program = Download the hex file to the device, using avrdude. Please
27 | # customize the avrdude settings below first!
28 | #
29 | # make filename.s = Just compile filename.c into the assembler code only
30 | #
31 | # To rebuild project do "make clean" then "make all".
32 | #
33 |
34 | # mth 2004/09
35 | # Differences from WinAVR 20040720 sample:
36 | # - DEPFLAGS according to Eric Weddingtion's fix (avrfreaks/gcc-forum)
37 | # - F_OSC Define in CFLAGS and AFLAGS
38 |
39 |
40 | # MCU name
41 | MCU = atmega32
42 |
43 | # Main Oscillator Frequency
44 | # This is only used to define F_OSC in all assembler and c-sources.
45 | F_OSC = 16000000
46 |
47 | # Output format. (can be srec, ihex, binary)
48 | FORMAT = ihex
49 |
50 | # Target file name (without extension).
51 | TARGET = main
52 |
53 |
54 | # List C source files here. (C dependencies are automatically generated.)
55 | SRC = $(TARGET).c spi.c mcp2515.c avr_can.c boot.c parser.c
56 |
57 |
58 | # List Assembler source files here.
59 | # Make them always end in a capital .S. Files ending in a lowercase .s
60 | # will not be considered source files but generated files (assembler
61 | # output from the compiler), and will be deleted upon "make clean"!
62 | # Even though the DOS/Win* filesystem matches both .s and .S the same,
63 | # it will preserve the spelling of the filenames, and gcc itself does
64 | # care about how the name is spelled on its command-line.
65 | ASRC =
66 |
67 |
68 |
69 | # Optimization level, can be [0, 1, 2, 3, s].
70 | # 0 = turn off optimization. s = optimize for size.
71 | # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
72 | OPT = s
73 |
74 | # Debugging format.
75 | # Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
76 | # AVR (extended) COFF requires stabs, plus an avr-objcopy run.
77 | #DEBUG = stabs
78 | #DEBUG = dwarf-2
79 |
80 | # List any extra directories to look for include files here.
81 | # Each directory must be seperated by a space.
82 | EXTRAINCDIRS =
83 |
84 |
85 | # Compiler flag to set the C Standard level.
86 | # c89 - "ANSI" C
87 | # gnu89 - c89 plus GCC extensions
88 | # c99 - ISO C99 standard (not yet fully implemented)
89 | # gnu99 - c99 plus GCC extensions
90 | CSTANDARD = -std=gnu99
91 |
92 | # Place -D or -U options here
93 | CDEFS =
94 |
95 | # Place -I options here
96 | CINCS =
97 |
98 |
99 | # Compiler flags.
100 | # -g*: generate debugging information
101 | # -O*: optimization level
102 | # -f...: tuning, see GCC manual and avr-libc documentation
103 | # -Wall...: warning level
104 | # -Wa,...: tell GCC to pass this to the assembler.
105 | # -adhlns...: create assembler listing
106 | CFLAGS = -g$(DEBUG)
107 | CFLAGS += $(CDEFS) $(CINCS)
108 | CFLAGS += -O$(OPT)
109 | CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
110 | CFLAGS += -Wall -Wstrict-prototypes
111 | #CFLAGS += -Wall
112 | CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
113 | CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
114 | CFLAGS += $(CSTANDARD)
115 | CFLAGS += -DF_OSC=$(F_OSC)
116 |
117 |
118 |
119 | # Assembler flags.
120 | # -Wa,...: tell GCC to pass this to the assembler.
121 | # -ahlms: create listing
122 | # -gstabs: have the assembler create line number information; note that
123 | # for use in COFF files, additional information about filenames
124 | # and function names needs to be present in the assembler source
125 | # files -- see avr-libc docs [FIXME: not yet described there]
126 | ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
127 | ASFLAGS += -DF_OSC=$(F_OSC)
128 |
129 |
130 | #Additional libraries.
131 |
132 | # Minimalistic printf version
133 | PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
134 |
135 | # Floating point printf version (requires MATH_LIB = -lm below)
136 | PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
137 |
138 | PRINTF_LIB =
139 |
140 | # Minimalistic scanf version
141 | SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
142 |
143 | # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
144 | SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
145 |
146 | SCANF_LIB =
147 |
148 | MATH_LIB = -lm
149 |
150 | # External memory options
151 |
152 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
153 | # used for variables (.data/.bss) and heap (malloc()).
154 | #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
155 |
156 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
157 | # only used for heap (malloc()).
158 | #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
159 |
160 | EXTMEMOPTS =
161 |
162 | # Linker flags.
163 | # -Wl,...: tell GCC to pass this to linker.
164 | # -Map: create map file
165 | # --cref: add cross reference to map file
166 | LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
167 | LDFLAGS += $(EXTMEMOPTS)
168 | LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
169 |
170 |
171 |
172 |
173 | # Programming support using avrdude. Settings and variables.
174 |
175 | # Programming hardware: alf avr910 avrisp bascom bsd
176 | # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
177 | #
178 | # Type: avrdude -c ?
179 | # to get a full listing.
180 | #
181 | AVRDUDE_PROGRAMMER = stk500
182 |
183 | # com1 = serial port. Use lpt1 to connect to parallel port.
184 | AVRDUDE_PORT = com2 # programmer connected to serial device
185 |
186 | AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
187 | #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
188 |
189 |
190 | # Uncomment the following if you want avrdude's erase cycle counter.
191 | # Note that this counter needs to be initialized first using -Yn,
192 | # see avrdude manual.
193 | #AVRDUDE_ERASE_COUNTER = -y
194 |
195 | # Uncomment the following if you do /not/ wish a verification to be
196 | # performed after programming the device.
197 | #AVRDUDE_NO_VERIFY = -V
198 |
199 | # Increase verbosity level. Please use this when submitting bug
200 | # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
201 | # to submit bug reports.
202 | #AVRDUDE_VERBOSE = -v -v
203 |
204 | AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
205 | AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
206 | AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
207 | AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
208 |
209 |
210 |
211 | # ---------------------------------------------------------------------------
212 |
213 | # Define directories, if needed.
214 | DIRAVR = c:/winavr
215 | DIRAVRBIN = $(DIRAVR)/bin
216 | DIRAVRUTILS = $(DIRAVR)/utils/bin
217 | DIRINC = .
218 | DIRLIB = $(DIRAVR)/avr/lib
219 |
220 |
221 | # Define programs and commands.
222 | SHELL = sh
223 | CC = avr-gcc
224 | OBJCOPY = avr-objcopy
225 | OBJDUMP = avr-objdump
226 | SIZE = avr-size
227 | NM = avr-nm
228 | AVRDUDE = avrdude
229 | REMOVE = rm -f
230 | COPY = cp
231 |
232 |
233 |
234 |
235 | # Define Messages
236 | # English
237 | MSG_ERRORS_NONE = Errors: none
238 | MSG_BEGIN = -------- begin --------
239 | MSG_END = -------- end --------
240 | MSG_SIZE_BEFORE = Size before:
241 | MSG_SIZE_AFTER = Size after:
242 | MSG_COFF = Converting to AVR COFF:
243 | MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
244 | MSG_FLASH = Creating load file for Flash:
245 | MSG_EEPROM = Creating load file for EEPROM:
246 | MSG_EXTENDED_LISTING = Creating Extended Listing:
247 | MSG_SYMBOL_TABLE = Creating Symbol Table:
248 | MSG_LINKING = Linking:
249 | MSG_COMPILING = Compiling:
250 | MSG_ASSEMBLING = Assembling:
251 | MSG_CLEANING = Cleaning project:
252 |
253 |
254 |
255 |
256 | # Define all object files.
257 | OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
258 |
259 | # Define all listing files.
260 | LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
261 |
262 |
263 | # Compiler flags to generate dependency files.
264 | ### GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
265 | GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
266 |
267 | # Combine all necessary flags and optional flags.
268 | # Add target processor to flags.
269 | ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
270 | ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
271 |
272 |
273 |
274 |
275 |
276 | # Default target.
277 | all: begin gccversion sizebefore build sizeafter finished end
278 |
279 | build: elf hex eep lss sym
280 |
281 | elf: $(TARGET).elf
282 | hex: $(TARGET).hex
283 | eep: $(TARGET).eep
284 | lss: $(TARGET).lss
285 | sym: $(TARGET).sym
286 |
287 |
288 |
289 | # Eye candy.
290 | # AVR Studio 3.x does not check make's exit code but relies on
291 | # the following magic strings to be generated by the compile job.
292 | begin:
293 | @echo
294 | @echo $(MSG_BEGIN)
295 |
296 | finished:
297 | @echo $(MSG_ERRORS_NONE)
298 |
299 | end:
300 | @echo $(MSG_END)
301 | @echo
302 |
303 |
304 | # Display size of file.
305 | HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
306 | ELFSIZE = $(SIZE) $(TARGET).elf
307 | sizebefore:
308 | @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
309 |
310 | sizeafter:
311 | @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
312 |
313 |
314 |
315 | # Display compiler version information.
316 | gccversion :
317 | @$(CC) --version
318 |
319 |
320 |
321 | # Program the device.
322 | program: $(TARGET).hex $(TARGET).eep
323 | $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
324 |
325 |
326 |
327 |
328 | # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
329 | COFFCONVERT=$(OBJCOPY) --debugging \
330 | --change-section-address .data-0x800000 \
331 | --change-section-address .bss-0x800000 \
332 | --change-section-address .noinit-0x800000 \
333 | --change-section-address .eeprom-0x810000
334 |
335 |
336 | coff: $(TARGET).elf
337 | @echo
338 | @echo $(MSG_COFF) $(TARGET).cof
339 | $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
340 |
341 |
342 | extcoff: $(TARGET).elf
343 | @echo
344 | @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
345 | $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
346 |
347 |
348 |
349 | # Create final output files (.hex, .eep) from ELF output file.
350 | %.hex: %.elf
351 | @echo
352 | @echo $(MSG_FLASH) $@
353 | $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
354 | # mv main.hex main.bin
355 |
356 | %.eep: %.elf
357 | @echo
358 | @echo $(MSG_EEPROM) $@
359 | -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
360 | --change-section-lma .eeprom=0 -O $(FORMAT) $< $@
361 |
362 | # Create extended listing file from ELF output file.
363 | %.lss: %.elf
364 | @echo
365 | @echo $(MSG_EXTENDED_LISTING) $@
366 | $(OBJDUMP) -h -S $< > $@
367 |
368 | # Create a symbol table from ELF output file.
369 | %.sym: %.elf
370 | @echo
371 | @echo $(MSG_SYMBOL_TABLE) $@
372 | $(NM) -n $< > $@
373 |
374 |
375 |
376 | # Link: create ELF output file from object files.
377 | .SECONDARY : $(TARGET).elf
378 | .PRECIOUS : $(OBJ)
379 | %.elf: $(OBJ)
380 | @echo
381 | @echo $(MSG_LINKING) $@
382 | $(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
383 |
384 |
385 | # Compile: create object files from C source files.
386 | %.o : %.c
387 | @echo
388 | @echo $(MSG_COMPILING) $<
389 | $(CC) -c $(ALL_CFLAGS) $< -o $@
390 |
391 |
392 | # Compile: create assembler files from C source files.
393 | %.s : %.c
394 | $(CC) -S $(ALL_CFLAGS) $< -o $@
395 |
396 |
397 | # Assemble: create object files from assembler source files.
398 | %.o : %.S
399 | @echo
400 | @echo $(MSG_ASSEMBLING) $<
401 | $(CC) -c $(ALL_ASFLAGS) $< -o $@
402 |
403 |
404 |
405 | # Target: clean project.
406 | clean: begin clean_list finished end
407 | rm main.bin
408 |
409 | clean_list :
410 | @echo
411 | @echo $(MSG_CLEANING)
412 | $(REMOVE) $(TARGET).hex
413 | $(REMOVE) $(TARGET).eep
414 | $(REMOVE) $(TARGET).obj
415 | $(REMOVE) $(TARGET).cof
416 | $(REMOVE) $(TARGET).elf
417 | $(REMOVE) $(TARGET).map
418 | $(REMOVE) $(TARGET).obj
419 | $(REMOVE) $(TARGET).a90
420 | $(REMOVE) $(TARGET).sym
421 | $(REMOVE) $(TARGET).lnk
422 | $(REMOVE) $(TARGET).lss
423 | $(REMOVE) $(OBJ)
424 | $(REMOVE) $(LST)
425 | $(REMOVE) $(SRC:.c=.s)
426 | $(REMOVE) $(SRC:.c=.d)
427 | $(REMOVE) .dep/*
428 |
429 |
430 |
431 | # Include the dependency files.
432 | -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
433 |
434 |
435 | # Listing of phony targets.
436 | .PHONY : all begin finish end sizebefore sizeafter gccversion \
437 | build elf hex eep lss sym coff extcoff \
438 | clean clean_list program
