Hallo Habe ein kleines Problem beim Simulieren! Es kommt immer folgende Fehler Meldung: # ** Error: (vsim-3601) Iteration limit reached at time 0 ps. Ich weis auch was es heißt aber ich sehe den Fehler im Code nicht! Vielleicht sieht ihn ja jemand von euch! Danke im vorhinein! MFG Fresh entity transmit_unit is port ( clk : in std_logic; reset : in std_logic; data_in : in transmit_data; enable_out : out std_logic := '1'; data_out : out std_logic); end transmit_unit; architecture twoproc of transmit_unit is signal r, rin : transmit_reg_type; signal tmp_data_in : std_logic := '1'; begin -- twoproc -- purpose: combinatorial process of the two-process design -- type : combinational -- inputs : data_in, r -- outputs: data_out, rin comb: process(data_in.transmit_en, r) variable tmp : transmit_reg_type; variable databit : std_logic := '0'; variable prebit : std_logic := '0'; begin -- process comb tmp := r; if data_in.transmit_en = '1' then if (tmp.precount = precount_value) then databit := data_in.data; --look if bit Stuffing is enable if (data_in.bit_stuff_en = '1') then --send the data or the stuffing bit if(tmp.bitnumber = conv_std_logic_vector(6,3)) then databit := not prebit; enable_out <= '1'; tmp.bitnumber := (others => '0'); else prebit := databit; end if; --compare if the the prebit and the databit are the same if (databit = prebit) then tmp.bitnumber := tmp.bitnumber + 1; else tmp.bitnumber := (others => '0'); end if; --control the bitnumber if it reached the value 5 if (tmp.bitnumber = bitstuffing_value) then enable_out <= '0'; tmp.bitnumber := conv_std_logic_vector(6,3); end if; end if; tmp_data_in <= databit; tmp.precount := (others => '0'); else tmp.precount := tmp.precount + 1; end if; else tmp.precount := precount_value; end if; rin <= tmp; end process comb; data_out <= tmp_data_in; -- purpose: sequential process or the two-process design -- type : sequential -- inputs : clk, reset, rin -- outputs: r seq: process (clk, reset) begin -- process seq if reset = '0' then -- asynchronous reset (active low) r.bitnumber <= (others => '0'); r.precount <= precount_value; elsif clk'event and clk = '1' then -- rising clock edge r <= rin; end if; end process seq; end twoproc;
@ fresh (Gast) >Habe ein kleines Problem beim Simulieren! Es kommt immer folgende Fehler >Meldung: ># ** Error: (vsim-3601) Iteration limit reached at time 0 ps. Uhhh, das sieht komisch aus. Diese tmp.irgendwas Scheibweise kenn ich gar nicht. Du kommst aus der prgrammierer-Ecke, nicht wahr? Ich sag mal, für das Problem brauch man keine Variablen. Machs mal ohne. Und lass diese komsichen tmp.irgendwas Dinger weg. Normale Signale tuns locker. MFG Falk
@ Falk Brunner > Uhhh, das sieht komisch aus. Diese tmp.irgendwas Scheibweise kenn ich > gar nicht. Du kommst aus der prgrammierer-Ecke, nicht wahr? und was du nicht kennst ist schlecht? > Und lass diese komsichen tmp.irgendwas Dinger weg. Normale Signale tuns > locker. tmp wird wohl ein record sein. ideal um Signale zu gliedern => code wird uebersichtlicher und weniger schreibaufwand. Cheers, Roger
@ Roger Steiner (edge) >> Uhhh, das sieht komisch aus. Diese tmp.irgendwas Scheibweise kenn ich >> gar nicht. Du kommst aus der prgrammierer-Ecke, nicht wahr? >und was du nicht kennst ist schlecht? Was der Bauer nicht kennt, frisst er nciht. ;-) >tmp wird wohl ein record sein. ideal um Signale zu gliedern => code wird >uebersichtlicher und weniger schreibaufwand. Schon klar, hab ich aber bei VHDL noch nie gesehen und auch nie was drüber gelesen. Modelsim scheint es auch nicht zu bekommen, obwohl es das kennt. Wahrscheinlich kommte es in eine endlose Rekursion beim Durchhangeln der Records. Und übersichtlich die DER Code weiss Gott nicht. MFg Falk
Hallo @fresh: Da hat mal einer schön die Zwei Prozess Methode benutzt! Du hast Dir aber ne ganz Hand voll Latche gebaut. Z.B.: tmp_data_in wird nur in einem der if-else Zweige gesetzt. Entweder Du weißt überall zu oder du setzt einen Default-Wert. Dein Problem ist aber wahrscheinlich ein anderes. Poste doch mal die Testbench, vieleicht gibt es dort ein Zweig in einem der Prozesse, der kein wait oder wait until oder ähnliches enthält. Da kann es dann schnell mal zu einem Loop kommen. Gruß DaMicha.
Hallo Ich habe in der Testbench mal nur den ClockProcess drinnen aber auch dann kommt der Fehler! Nehme nicht an das an diesen Prozess hängt oder? clk: process begin -- process clk clk_i <= '0'; wait for 25ns; clk_i <= '1'; wait for 25ns; end process clk;
Hallo Beim Process für den Takt hat bei den wait for Anweisungen der Abstand zwischen 25 und ns gefehlt! Aber der hat leider mein ursprüngliches Problem nicht gelöst! Habe nun den ausdruck enable_out <= '1'; aus der if schleife genommen damit ein latch weniger entsteht! Sollte man zum latcher vermeiden solche konstrukte: if (test = '1') then tmp := '1'; else tmp := tmp; end if; verwenden oder kann man den ausdruck im else zweig weglassen? comb: process(data_in.transmit_en, r) variable tmp : transmit_reg_type; variable databit : std_logic := '0'; variable prebit : std_logic := '0'; begin -- process comb tmp := r; if data_in.transmit_en = '1' then if (tmp.precount = precount_value) then databit := data_in.data; --look if bit Stuffing is enable if (data_in.bit_stuff_en = '1') then enable_out <= '1'; --send the data or the stuffing bit if(tmp.bitnumber = conv_std_logic_vector(6,3)) then databit := not prebit; tmp.bitnumber := (others => '0'); else tmp.bitnumber := tmp.bitnumber; prebit := databit; end if; --compare if the the prebit and the databit are the same if (databit = prebit) then tmp.bitnumber := tmp.bitnumber + 1; else tmp.bitnumber := (others => '0'); end if; --control the bitnumber if it reached the value 5 if (tmp.bitnumber = bitstuffing_value) then enable_out <= '0'; tmp.bitnumber := conv_std_logic_vector(6,3); end if; end if; tmp_data_in <= databit; tmp.precount := (others => '0'); else tmp.precount := tmp.precount + 1; end if; else tmp.precount := precount_value; end if; rin <= tmp;
@ fresh (Gast) >Hallo Beim Process für den Takt hat bei den wait for Anweisungen der >Abstand zwischen 25 und ns gefehlt! Da meckert Modelsim aber vorher drüber. >ursprüngliches Problem nicht gelöst! Habe nun den ausdruck enable_out <= >'1'; aus der if schleife genommen damit ein latch weniger entsteht! Es dürfen KEINE Latches entstehen, sonst schiesst du dir ins Knie. >Sollte man zum latcher vermeiden solche konstrukte: >if (test = '1') then > tmp := '1'; >else > tmp := tmp; >end if; Kann man machen. >verwenden oder kann man den ausdruck im else zweig weglassen? Wenn man, was ich für sinnvoll halte, das alles gleich in einen getakteten Prozess schreibt. Ist genauso übersichtlich, und Latches entstehen auf keinen Fall. Hat auch keine negativen Auswirkungen auf die Geschwindigkeit, die Diskussionen darüber in der Vergangenheit halte ich für eine Legende. MFG Falk
Hallo ich bins gleich nochmal! Habe jetzt folgendes getestet und bekomme da auch diesen fehler mit den iteration limit! comb: process(data_in.transmit_en, r) variable tmp : transmit_reg_type; variable databit : std_logic := '0'; variable prebit : std_logic := '0'; begin -- process comb tmp := r; rin <= tmp; end process comb; data_out <= tmp_data_in; seq: process (clk, reset) begin -- process seq if reset = '0' then -- asynchronous reset (active low) r.bitnumber <= (others => '0'); r.precount <= precount_value; elsif clk'event and clk = '1' then -- rising clock edge r <= rin; end if; end process seq; und in der testbench: clk: process begin -- process clk clk_i <= '0'; wait for 25 ns; clk_i <= '1'; wait for 25 ns; end process clk; reset_i <= '1'; wo kann da noch der Fehler aufretten?
@ fresh (Gast) >Habe jetzt folgendes getestet und bekomme da auch diesen fehler mit den >iteration limit! Dein Stil ist und bleibt komisch. Warum nciht ganz einfach so?
1 | comb: process(clk) |
2 | variable tmp : transmit_reg_type; |
3 | variable databit : std_logic := '0'; |
4 | variable prebit : std_logic := '0'; |
5 | begin -- process comb |
6 | elsif clk'event and clk = '1' then -- rising clock edge |
7 | |
8 | tmp := r; |
9 | |
10 | -- Berechnung hier rein
11 | |
12 | r <= tmp; |
13 | |
14 | data_out <= tmp_data_in; |
15 | |
16 | |
17 | end if; |
18 | end process; |
19 | |
20 | und in der testbench: |
21 | |
22 | clk: process |
23 | begin -- process clk |
24 | clk_i <= '0'; |
25 | wait for 25 ns; |
26 | clk_i <= '1'; |
27 | wait for 25 ns; |
28 | end process clk; |
29 | |
30 | reset_i <= '1'; |
MFG Falk
Ja das wäre eine einfachere Lösung aber ich habe als Vorgabe das das ganze im 2 Prozess Design zu implementieren ist. aber das darf doch im großen und ganzen keinen wirklichen unterschied machen! MFG Harald
fresh wrote: > if (test = '1') then > tmp := '1'; > else > tmp := tmp; > end if; > > verwenden oder kann man den ausdruck im else zweig weglassen? Der else-Zweig hat keine Auswirkung. Latches kannst du nur vermeiden indem du den Prozess entweder taktest oder so schreibst dass überhaupt keine speichernden Elemente benötigt werden.
@ fresh (Gast) >Ja das wäre eine einfachere Lösung aber ich habe als Vorgabe das das >ganze im 2 Prozess Design zu implementieren ist. Von wem? Prof? Akademiker . . . >aber das darf doch im >großen und ganzen keinen wirklichen unterschied machen! Nein. Wenn du im kombinatorischen Prozess in JEDEM Zweig eine Zuweisung an JEDE Ausgangsvariable machst. Aber ich bleibe dabei. Schreibs mal einfach ohne diese Records und so weit wie möglich ohne Variablen hin. MFG Falk
Bringt modelsim den fehler bei jedem Code? Vielleicht ist ja das iteration limit zu niedrig (0 bis 10), üblich sind ein paar tausend. du kannst ja mal mit einem Beispiel von modelsim testen. und vielleicht etwas spitzfindig. wo wird clk_i aus deiner TB verwendet ? clk: als label und signalname ist vielleicht unglücklich
