1 | ;---------------------------------------------------------------------------
2 | ; Title : Programmbeispiel für myAVR-Board mit LCD Add-On
3 | ;---------------------------------------------------------------------------
4 | ; Funktion : gibt Zeichenketten auf dem myAVR LCD Modul, 2 Zeilen
5 | ; Schaltung : PORT D2 = RS, PORT D3 = E, PORT D4-7 = D4-7
6 | ;---------------------------------------------------------------------------
7 | ; Prozessor : ATmega8
8 | ; Takt : 3,6864 MHz
9 | ; Sprache : Assembler
10 | ; Datum : 03.02.2005
11 | ; Version : 1.6
12 | ; Autor : Dipl. Ing. Päd. Alexander Huwaldt
13 | ;---------------------------------------------------------------------------
14 | .equ F_CPU, 3686400
15 | .include "AVR.H"
16 | ;---------------------------------------------------------------------------
17 | ; Reset- und Interruptvektoren ; VNr. Beschreibung
18 | rjmp main ; 1 POWER ON RESET
19 | reti ; 2 Int0-Interrupt
20 | reti ; 3 Int1-Interrupt
21 | reti ; 4 TC2 Compare Match
22 | reti ; 5 TC2 Overflow
23 | reti ; 6 TC1 Capture
24 | reti ; 7 TC1 Compare Match A
25 | reti ; 8 TC1 Compare Match B
26 | reti ; 9 TC1 Overflow
27 | reti ; 10 TC0 Overflow
28 | reti ; 11 SPI, STC Serial Transfer Complete
29 | reti ; 12 UART Rx Complete
30 | reti ; 13 UART Data Register Empty
31 | reti ; 14 UART Tx complete
32 | reti ; 15 ADC Conversion Complete
33 | reti ; 16 EEPROM Ready
34 | reti ; 17 Analog Comperator
35 | reti ; 18 TWI (I²C) Serial Interface
36 | reti ; 19 Store Program Memory Ready
37 | ;---------------------------------------------------------------------------
38 | ; Start, Power ON, Reset
39 | main: ldi r16,lo8(RAMEND)
40 | out SPL,r16 ; Init Stackpointer LO
41 | ldi r16,hi8(RAMEND)
42 | out SPH,r16 ; Init Stackpointer HI
43 | rcall LCD_init
44 | rcall LCD_clear
45 | ;---------------------------------------------------------------------------
46 | mainloop: rcall wait
47 | ldi r16,'H'
48 | rcall LCD_data
49 | ldi r16,'a'
50 | rcall LCD_data
51 | ldi r16,'l'
52 | rcall LCD_data
53 | ldi r16,'l'
54 | rcall LCD_data
55 | ldi r16,'o'
56 | rcall LCD_data
57 | ldi r16,' '
58 | rcall LCD_data
59 |
60 | rcall LCD_line2
61 |
62 | ldi r16,'S'
63 | rcall LCD_data
64 | ldi r16,'i'
65 | rcall LCD_data
66 | ldi r16,'S'
67 | rcall LCD_data
68 | ldi r16,'y'
69 | rcall LCD_data
70 | ldi r16,' '
71 | rcall LCD_data
72 |
73 | rcall LCD_home
74 |
75 | rjmp mainloop
76 | ;===========================================================================
77 | ; hier Unterprogramme und Interruptroutinen zufügen
78 | ;---------------------------------------------------------------------------
79 | wait: push r24
80 | ldi r24,0x13 ; hier delay einstellen 13 = ca. 20yS
81 | w1: subi r24,0x01
82 | rcall wait20ms
83 | brcc w1
84 | pop r24
85 | ret
86 | ;---------------------------------------------------------------------------
87 | wait5ms: ldi r16,255
88 | ldi r17,26
89 | w5ms: dec r16
90 | brne w5ms
91 | dec r17
92 | brne w5ms
93 | ret
94 | ;---------------------------------------------------------------------------
95 | wait20ms: ldi r16,255
96 | ldi r17,104
97 | w20ms: dec r16
98 | brne w20ms
99 | dec r17
100 | brne w20ms
101 | ret
102 | ;---------------------------------------------------------------------------
103 | LCD_init: sbi DDRD,2 ; LCD RS = OUT
104 | sbi DDRD,3 ; LCD E = OUT
105 | sbi DDRD,4 ; LCD D4 = OUT
106 | sbi DDRD,5 ; LCD D5 = OUT
107 | sbi DDRD,6 ; LCD D6 = OUT
108 | sbi DDRD,7 ; LCD D7 = OUT
109 | cbi PORTD,2 ; LDC RS = Low
110 |
111 | ; warte bis PowerUp
112 | ldi r18,20
113 | powerup: rcall wait5ms
114 | dec r18
115 | brne powerup ; Power-Up Wartezyklus min 30 ms
116 |
117 | ; sende Resetsequenz kompatibel zu HD44780 Industriestandard
118 | ldi r16,0b00110000 ; Reset-Sequenz Teil 1
119 | out PORTD,r16
120 | rcall LCD_enable ; Enable-Impuls
121 | rcall wait5ms
122 | ldi r16,0b00110000 ; Reset-Sequenz Teil 2
123 | out PORTD,r16
124 | rcall LCD_enable ; Enable-Impuls
125 | rcall wait5ms
126 | ldi r18,100 ; Wartezyklus bei RESET LCD min 100 µs
127 | resetLCD:
128 | nop
129 | nop
130 | nop
131 | dec r18
132 | brne resetLCD
133 | ldi r16,0b00110000 ; Reset-Sequenz Teil 3
134 | out PORTD,r16
135 | rcall LCD_enable ; Enable-Impuls
136 | rcall wait5ms
137 |
138 | ; sende init 1
139 | ldi r16,0b00100000 ; 4 Bit Modus aktivieren
140 | out PORTD,r16
141 | rcall LCD_enable ; Enable-Impuls
142 | rcall wait5ms
143 | ldi r16,0b00101000
144 | rcall LCD_cmd ; Function Set 4 Bit, 2 Zeilen, 5x7
145 | rcall LCD_off
146 | rcall LCD_clear
147 | ldi r16,0x06
148 | rcall LCD_cmd ; Entry Mode Set, increase+shifted
149 | rcall LCD_on
150 | ret
151 | ;---------------------------------------------------------------------------
152 | LCD_data: ldi r18,0b0000100 ; RS = hi
153 | rjmp LCD_out
154 | ;---------------------------------------------------------------------------
155 | LCD_cmd: ldi r18,0b0000000 ; RS = lo
156 | LCD_out: mov r17,r16
157 | swap r17
158 | andi r16,0b11110000
159 | or r16,r18
160 | andi r17,0b11110000
161 | or r17,r18
162 | out PORTD,r16
163 | rcall LCD_enable
164 | out PORTD,r17
165 | rcall LCD_enable
166 | rcall wait5ms
167 | ret
168 | ;---------------------------------------------------------------------------
169 | LCD_enable: sbi PORTD,3 ; Enable high
170 | nop ; kurz warten
171 | nop
172 | nop
173 | cbi PORTD,3 ; Enable wieder low
174 | ret
175 | ;---------------------------------------------------------------------------
176 | LCD_clear: ldi r16,0b00000001 ; Display löschen
177 | rcall LCD_cmd
178 | rcall wait5ms
179 | ret
180 | ;---------------------------------------------------------------------------
181 | LCD_off: ldi r16,0b00001000
182 | rcall LCD_cmd
183 | rcall wait5ms
184 | ret
185 | ;---------------------------------------------------------------------------
186 | LCD_on: ldi r16,0x0E
187 | rcall LCD_cmd
188 | rcall wait5ms
189 | ret
190 | ;---------------------------------------------------------------------------
191 | LCD_home: ldi r16,0b00000010 ; Display Cursor HOME
192 | rcall LCD_cmd
193 | rcall wait5ms
194 | ret
195 | ;---------------------------------------------------------------------------
196 | LCD_line1: ldi r16,0b10000000 ; DRAM auf Adresse 0x00
197 | rcall LCD_cmd
198 | rcall wait5ms
199 | ret
200 | ;---------------------------------------------------------------------------
201 | LCD_line2: ldi r16,0b11000000 ; DRAM auf Adresse 0x40
202 | rcall LCD_cmd
203 | rcall wait5ms
204 | ret
205 | ;---------------------------------------------------------------------------
206 | ; Goto r16 = Adresse (Zeile 1 = 0x00..0x0F, Zeile 2 = 0x40..0x4F)
207 | LCD_goto: ori r16,0b10000000 ; Goto DRAM auf Adresse r16
208 | rcall LCD_cmd
209 | rcall wait5ms
210 | ret
211 | ;---------------------------------------------------------------------------
