Bei meinem ARM9 Samsung S3C2410 erfolgt die Vergabe der Startadresse des Framebuffers mit Hilfe des LCDSADR1 Registers: LCDBANK [29:21] These bits indicate A[30:22] of the bank location for the video buffer in the system memory. LCDBANK value cannot be changed even when moving the view port. LCD frame buffer should be within aligned 4MB region, which ensures that LCDBANK value will not be changed when moving the view port. So, care should be taken to use the malloc() function. LCDBASEU [20:0] These bits indicate A[21:1] of the start address of the LCD frame buffer. Das Register LCDSADR2 Register legt das Ende des Framebuffers fest: LCDBASEL [20:0] These bits indicate A[21:1] of the end address of the LCD frame buffer. LCDBASEL = ((the fame end address) >>1) + 1 = LCDBASEU + (PAGEWIDTH+OFFSIZE)x(LINEVAL+1) Weiterhin werden fuer die Konfiguration das LCDSADR3 benoetigt: OFFSIZE [21:11] Virtual screen offset size (the number of half words). This value defines the difference between the address of the last half word displayed on the previous LCD line and the address of the first half word to be displayed in the new LCD line. PAGEWIDTH [10:0] Virtual screen page width (the number of half words). This value defines the width of the view port in the frame. Nun verstehe ich nicht wie die Register vor allem LCDBASEU und LCDBASEU belegt werden sollen. Das von Samsung angegebene Beispiel bringt mich leider auch nichtr weiter: Example 1. LCD panel = 320*240, 16gray, single scan Frame start address = 0x0c500000 Offset dot number = 2048 dots ( 512 half words ) LINEVAL = 240-1 = 0xef PAGEWIDTH = 320*4/16 = 0x50 OFFSIZE = 512 = 0x200 LCDBANK = 0x0c500000 >> 22 = 0x31 LCDBASEU = 0x100000 >> 1 = 0x80000 LCDBASEL = 0x80000 + ( 0x50 + 0x200 ) * ( 0xef + 1 ) = 0xa2b00 Besten Dank fuer jede Hilfe.
