1 | import java.awt.*;
2 | import java.awt.event.*;
3 | import javax.swing.*;
4 | import java.*;
5 | import java.io.*;
6 | import javax.comm.*;
7 |
8 |
9 | public class schieberegler extends Frame
10 | {
11 |
12 | static JTextField tf;
13 | static JScrollBar sb;
14 | static JButton aendern;
15 | static JTextField binär;
16 | static JButton senden;
17 | static JTextArea ausgabe;
18 | static JLabel label1;
19 | static JLabel label2;
20 | static JLabel label3;
21 | static JLabel label4;
22 | static JLabel label5;
23 | static JLabel label6;
24 | static CommPortIdentifier portID;
25 | InputStream ins;
26 | OutputStream out;
27 | static SerialPort serss;
28 |
29 |
30 |
31 | public static void main( String args[] )
32 | {
33 | try{portID = CommPortIdentifier.getPortIdentifier("CNCA0");
34 | serss = (SerialPort) portID.open("mein_programm",2000);
35 |
36 | }
37 | catch(Exception exc){System.out.println("Fehler :"+exc);}
38 | JFrame f = new JFrame();
39 | f.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
40 | f.setTitle("RS232 Ansteuerung von ");
41 | f.pack();
42 | f.setSize(250,130);
43 | f.setVisible( true );
44 | Container c = f.getContentPane();
45 |
46 | c.setLayout( new GridLayout(6,2) );
47 |
48 | c.add (label1 = new JLabel("Aktueller SR Wert:"));
49 | c.add ( tf = new JTextField( 20 ) );
50 | c.add (label2 = new JLabel("Schieberegler:"));
51 | c.add ( sb = new JScrollBar( JScrollBar.HORIZONTAL, 0, 10, 0, 255+10 ) );
52 | c.add (label3 = new JLabel("Wert ändern:"));
53 | c.add(aendern = new JButton("ändern"));
54 | c.add (label4 = new JLabel("Binärer Wert:"));
55 | c.add(binär = new JTextField(20));
56 | c.add (label5 = new JLabel("Gäenderten Wert senden:"));
57 | c.add(senden = new JButton("Wert senden"));
58 | c.add(label6 = new JLabel("Satus:"));
59 | c.add(ausgabe = new JTextArea("Port COM geöffnet\n",7,40));
60 |
61 | aendern.addActionListener(new ActionListener() {
62 | public void actionPerformed(ActionEvent e) {
63 |
64 | String b = null;
65 | int Wert;
66 | Wert = sb.getValue();
67 |
68 | b = (new Integer(Wert)).toBinaryString(Wert);
69 | binär.setText(""+b);
70 | }
71 | } );
72 |
73 | tf.addActionListener( new ActionListener() {
74 | public void actionPerformed( ActionEvent e ) {
75 | sb.setValue( Integer.parseInt(tf.getText()) );
76 | }
77 | } );
78 |
79 | sb.addAdjustmentListener( new AdjustmentListener() {
80 | public void adjustmentValueChanged( AdjustmentEvent e ) {
81 | tf.setText( "" + sb.getValue() );
82 | }
83 | } );
84 | }
85 |
86 | public schieberegler() {
87 |
88 |
89 |
90 |
91 |
92 |
93 |
94 |
95 |
96 |
97 |
98 | binär.addActionListener(new sendeListener());
99 | senden.addActionListener(new sendeListener());
100 |
101 | try {ins = serss.getInputStream();
102 | out = serss.getOutputStream();
103 | serss.addEventListener(new commListener());
104 | }
105 | catch (Exception e) { System.out.println("Fehler: "+e);}
106 | serss.notifyOnDataAvailable(true);
107 | try {serss.setSerialPortParams(2400,
108 | SerialPort.DATABITS_8,
109 | SerialPort.STOPBITS_1 ,
110 | SerialPort.PARITY_NONE);}
111 | catch (UnsupportedCommOperationException e) {}
112 | }
113 |
114 | public class sendeListener implements ActionListener{
115 | public void actionPerformed(ActionEvent e){
116 | PrintWriter aus = new PrintWriter(out);
117 | aus.println(binär.getText());
118 | aus.flush();
119 | aus.close();
120 | }
121 | }
122 |
123 | public class commListener implements SerialPortEventListener{
124 | public void serialEvent(SerialPortEvent event) {
125 | if(event.getEventType()==SerialPortEvent.DATA_AVAILABLE){
126 | byte[] readBuffer = new byte[20];
127 | try {
128 | while (ins.available() > 0) {int numBytes = ins.read(readBuffer);}
129 | String nachricht = new String(readBuffer);
130 | ausgabe.append(nachricht);
131 |
132 | }
133 | catch (IOException e) {System.out.println("Fehler: "+e);}
134 |
135 | }
136 | }
137 | }
138 | }
