	<id>https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=172.26.24.184</id>
	<link rel="self" type="application/atom+xml" href="https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=172.26.24.184"/>
	<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/articles/Spezial:Beitr%C3%A4ge/172.26.24.184"/>
	<updated>2026-04-11T03:16:21Z</updated>
		<id>https://www.mikrocontroller.net/index.php?title=Diskussion:AVR_Transistortester&amp;diff=105270</id>
		<title>Diskussion:AVR Transistortester</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Diskussion:AVR_Transistortester&amp;diff=105270"/>
		<updated>2022-06-25T16:23:48Z</updated>
		<summary type="html">&lt;p&gt;172.26.24.184: &lt;/p&gt;
&lt;div&gt;=== M644 chip display SSD1306 fonts, 7x12 &#039;6x8, can not compile the program. ===&lt;br /&gt;
I don&#039;t know how to contact you, these words are also translation software to do.&lt;br /&gt;
This transistor tester is quite interesting, and I made a OLED SSD1306 display version. Address: http://bbs.yleee.com.cn/thread-41093-1-1.html. If you can contact me through the forum that would be the best。&lt;br /&gt;
There has A lot of unsolved problems found in the 2015.9.18 test.&lt;br /&gt;
1:Battery_check.c, M644 chip automatically shut down a problem,&lt;br /&gt;
 Problem PORTD = 0; power off //switch&lt;br /&gt;
 Solved  ON_PORT &amp;amp;= ~ (1&amp;lt;&amp;lt;ON_PIN); //switch power off&lt;br /&gt;
2:function_menu.c, cap_corr problem, the encoder is defined the same and too complicated.&lt;br /&gt;
 WITH_ROTARY_SWITCH #ifdef&lt;br /&gt;
 If (rotary.incre &amp;gt; FAST_ROTATION) break fast rotation ends setting of Korr&lt;br /&gt;
 Problem //if (rotary.count &amp;gt; = 0) {&lt;br /&gt;
 Solved  korr - = rotary.count; / / increase the Korr by rotary.count&lt;br /&gt;
 Problem //} {else&lt;br /&gt;
 Problem //korr = rotary.count; / / decrease the Korr by rotary.count&lt;br /&gt;
 Problem //}&lt;br /&gt;
3：The voltage test mode is not ideal, and the measurement is larger than 2.5V.&lt;br /&gt;
4:DisplayValue.c, the proposed - voltage takes two decimal places&lt;br /&gt;
 Display_mV&lt;br /&gt;
 void (XX uint16_t, ll uint8_t) {&lt;br /&gt;
 If (ll = = 2)&lt;br /&gt;
 DisplayValue ((long) XX, -3, ll+1,&#039;V&#039;);&lt;br /&gt;
 Else&lt;br /&gt;
 DisplayValue ((long) XX, -3, ll,&#039;V&#039;);&lt;br /&gt;
5: can you start the Chinese language module.&lt;br /&gt;
Thanks for providing such a good tool for free.&lt;br /&gt;
[[Spezial:Beiträge/60.163.3.192|60.163.3.192]] ([[Benutzer Diskussion:60.163.3.192|Diskussion]]) und [[Spezial:Beiträge/125.123.186.128 |125.123.186.128 ]] ([[Benutzer Diskussion:60.163.3.192|Diskussion]]) am 19. September 2015&lt;br /&gt;
== Struktur ==&lt;br /&gt;
Sollte man dem Artikel etwas Struktur geben? Verzeichnis z.B.?&lt;/div&gt;</summary>
		<author><name>172.26.24.184</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Diskussion:Elektronikversender&amp;diff=105268</id>
		<title>Diskussion:Elektronikversender</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Diskussion:Elektronikversender&amp;diff=105268"/>
		<updated>2022-06-25T16:17:34Z</updated>
&lt;div&gt;Da sind einige Leichen drin. Sollte man vlt mal rausnehmen?&lt;/div&gt;</summary>
