	<id>https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=79.83.80.121</id>
	<link rel="self" type="application/atom+xml" href="https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=79.83.80.121"/>
	<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/articles/Spezial:Beitr%C3%A4ge/79.83.80.121"/>
	<updated>2026-04-10T12:54:13Z</updated>
		<id>https://www.mikrocontroller.net/index.php?title=Logic_Analyzer&amp;diff=68287</id>
		<title>Logic Analyzer</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Logic_Analyzer&amp;diff=68287"/>
		<updated>2012-09-05T16:49:07Z</updated>
		<summary type="html">&lt;p&gt;79.83.80.121: /* µLab LA */ entfernt. Seite ist tot und archive.org sagt &amp;quot;Page cannot be crawled or displayed due to robots.txt.&amp;quot;&lt;/p&gt;
&lt;div&gt;Diese Seite enthält eine Übersicht über verschiedene Logic Analyzer &#039;&#039;&#039;Selbstbau-Projekte&#039;&#039;&#039;.&lt;br /&gt;
== AVR-basiert ==&lt;br /&gt;
=== LoLA ===&lt;br /&gt;
* ASM&lt;br /&gt;
LoLA is a 8-Bit Logicanalyzer. Internal sampletimes from 2µs to 16ms. Triggerword with don&#039;t cares. External clock or trigger on rising or falling edge. Timing and state with I2C-analysis. 2k memory, very low cost.&lt;br /&gt;
* 2006 B. Sauter&lt;br /&gt;
* 8-Bit&lt;br /&gt;
* USB&lt;br /&gt;
* 8-channel&lt;br /&gt;
* 32kB SRAM&lt;br /&gt;
* RS232&lt;br /&gt;
* 2 MHz&lt;br /&gt;
&#039;&#039;&#039;Version 1&#039;&#039;&#039;&lt;br /&gt;
* bis 4 Kanäle&lt;br /&gt;
* Basis: Atmega16 und NAND-Gate&lt;br /&gt;
* http://www.ikalogic.com/scanalogic_home.php&lt;br /&gt;
&#039;&#039;&#039;Version 2 Pro&#039;&#039;&#039;&lt;br /&gt;
* bis 20 Million Samples per second&lt;br /&gt;
* Maximum sampling buffer 256K&lt;br /&gt;
* Generator/Playback Modus&lt;br /&gt;
* USB HID mode&lt;br /&gt;
* Firmware upgrade feature&lt;br /&gt;
* Basis: Atmel AVR&lt;br /&gt;
* Aufgebaut und getestet&lt;br /&gt;
* http://www.ikalogic.com/scanalogic2/&lt;br /&gt;
=== MiniLog ===&lt;br /&gt;
Zur Zeit gibt es zwei Versionen, die sich hauptsächlich in der Samplerate und in der Speichergröße unterscheiden:&lt;br /&gt;
&#039;&#039;&#039;50 MSa/s Version&#039;&#039;&#039;&lt;br /&gt;
* 8 Kanäle&lt;br /&gt;
* 50 MSa/s&lt;br /&gt;
* 4k Samplespeicher&lt;br /&gt;
* Trigger auf beliebige Pegelkombinationen &lt;br /&gt;
* Basis ATMega644&lt;br /&gt;
* FT232 USB 115200 Baud&lt;br /&gt;
&#039;&#039;&#039;80 MSa/s Version&#039;&#039;&#039;&lt;br /&gt;
* 16k Samplespeicher (32k bei neuer Software)&lt;br /&gt;
* Basis ATMega88 / ATMega48&lt;br /&gt;
* FT232 USB 500000 Baud&lt;br /&gt;
Weitere Infos und Diskussion:&lt;br /&gt;
* http://www.avr.roehres-home.de/logikanalyzer/index.html&lt;br /&gt;
* http://www.mikrocontroller.net/topic/141602&lt;br /&gt;
== FPGA / CLPD ==&lt;br /&gt;
&amp;lt;!-- &lt;br /&gt;
Deditec LAs sind keine Selbstbauprojekte, daher hier entfernt. Ggf. neuen Artikel aufmachen oder anderen, passenderen ergänzen. Danke.&lt;br /&gt;
* 36 Kanäle&lt;br /&gt;
* 2 Trigger Ebene&lt;br /&gt;
=== SUMP Logic Analyzer ===&lt;br /&gt;
* Java Software&lt;br /&gt;
Der SUMP Logic Analyzer hat wahlweise einen einfachen Trigger (Rising/Falling mit Maskierung) oder einen komplexen 4stufigen Trigger, sowie einen einfachen zuschaltbaren Noise Filter, der Pulse kürzer als 1/100 MHz filtert um Crosstalk-Effekte in den Anschlussleitungen zu kompensieren. Der Speicher wird im Wartezustand als &amp;quot;Ringstack&amp;quot; kontinuierlich beschrieben. Dadurch können auch Daten von vor der Trigger-Auslösung ausgelesen werden.&lt;br /&gt;
* [http://www.sump.org/projects/analyzer/ Projektseite bei sump.org]&lt;br /&gt;
* [http://logicanalyzer.sourceforge.net/ LogicAnalyzer] is a framework as well as an application to operate a PC based logic analyzer. It&#039;s built using the Eclipse RCP and designed with extensibiliy in mind. Integrating devices, providing tools or creating completely new functionality is easy. The most prominent OpenSource logic analyzer hardware (namely the SUMP Logic Analyzer - and derivates such as the [[Logic_Analyzer#OpenBench_Logic_Sniffer|Open Workbench Logic Sniffer]]) work out of the box. It also serves as an example how easy it is to integrate new devices. (GPL)&lt;br /&gt;
=== BitHound Logic Analyzer ===&lt;br /&gt;
Hier handelt es sich um eine Erweiterung des SUMP auf einen Spartan-6. &lt;br /&gt;
Es gibt zwei Versionen; eine für das Xilinx-SP601 Development Board und eine für das Digilent ATLYS-Spartan-6 Board. &lt;br /&gt;
Der Analyzer-Core ist (noch) derselbe wie beim SUMP, der Speicher ist nun jedoch 128MB gross und die Datenübertragung erfolgt per Ethernet zum ebenfalls leicht verbesserten JAVA-Client. &lt;br /&gt;
* [http://www.bastli.ethz.ch/index.php?page=BitHoundEn Projektseite von www.bastli.ethz.ch]&lt;br /&gt;
* 32 Kanäle&lt;br /&gt;
=== miniLA ===&lt;br /&gt;
Der LA basiert auf einem Xilinx CPLD&lt;br /&gt;
* Ankopplung über USB oder LPT (neuere Version von mockup: nur USB)&lt;br /&gt;
neuere Version von mockup: &lt;br /&gt;
* 512 kSamples bzw. 1MSamples&lt;br /&gt;
* Ankoppelung über USB&lt;br /&gt;
* [http://minila.sourceforge.net Projektseite]&lt;br /&gt;
* [[MiniLA]] Artikel auf www.mikrocontroller.net&lt;br /&gt;
* http://www.mikrocontroller.net/topic/174860 Forum&lt;br /&gt;
* http://www.mikrocontroller.net/articles/Minila_Version_MockUp Artikel&lt;br /&gt;
=== coolLA ===&lt;br /&gt;
coolLA ist eine erweiterte Version des miniLA. Die wesentlichen Änderungen sind:&lt;br /&gt;
* USB Stromversorgung mit galvanischer Trennung&lt;br /&gt;
* Einsatz einer Coolrunner II CPLD&lt;br /&gt;
* Time- und Stateanalyse umschaltbar zusammen im System mit angepasster Software&lt;br /&gt;
* 512k Samples Speicher 32 Bit&lt;br /&gt;
* integrierte Datenempfänger&lt;br /&gt;
* 40-poliger IDE Stecker Intronix LogicPort kompatibel&lt;br /&gt;
* passt in Elpac Gehäuse&lt;br /&gt;
* [http://coolla.freeunix.net Projektseite mit Bilder und Download]&lt;br /&gt;
* [http://www.mikrocontroller.net/topic/175219#1682430 Forumbeitrag] von Wolfgang R. (portside)&lt;br /&gt;
* 24 Kanäle&lt;br /&gt;
* 32 channels&lt;br /&gt;
Die Software hat Interpreter für RS232, SPI, I2C, 1-Wire und einen A/D-Wandler.&lt;br /&gt;
Eine fertige Platine gibts von www.Seeedstudio.com für 50$ oder in Deutschland bei http://www.watterott.com/de/Open-Logic-Sniffer für 45,22€ exkl. Versand (2.90 € UPS Standard).&lt;br /&gt;
== PIC-basiert ==&lt;br /&gt;
=== PIC Logicx ===&lt;br /&gt;
[http://martin.hinner.info/electronics/piclogix/ PIC Logix] (GPL, optional Standalone VGA Ausgabe, PIC24 or dsPIC33)&lt;br /&gt;
=== Logic Analyzer III (USB) ===&lt;br /&gt;
[http://technology.niagarac.on.ca/people/mcsele/LogicAnalyzer.html Logic Analyzer III (USB)] uses a multithreaded Win-32 front-end and a native USB interface. It features a 20MS/s sample rate and a 4K sample depth. Zentrale Bauteile sind ein PIC18F4550 Mikrocontroller und ein AM7204 FIFO IC z.B. von AMD.&lt;br /&gt;
=== pk2-la ===&lt;br /&gt;
* Hardware: PICkit 2 Programmer Logic Tool Analyzer&lt;br /&gt;
** 3 Kanal bis 500 kHz&lt;br /&gt;
** http://www.microchip.com/pickit2&lt;br /&gt;
* Software: &lt;br /&gt;
** [http://pk2-la.sourceforge.net/ pk2-la]. The Microchip PICkit 2 has the ability to act as a logic analyzer and I/O probe. This project provides a reverse engineered libusb user space device driver and GUI to provide this functionality for users of unsupported operating systems. (Python, Lizenz: GPL)&lt;br /&gt;
== Parallelport LA ==&lt;br /&gt;
Bitte beachten: Derartige Parallelport LAs sind z.B. bei der Samplerate durch die PC-Hardware und das PC OS im Vergleich zu höherwertigen LAs eingeschränkt.&lt;br /&gt;
* [http://tfla-01.berlios.de/ The Fabulous Logic Analyzer] (GPL, multiplatform, Simple [[I2C]] analyzer)&lt;br /&gt;
* [http://akikorhonen.org/projects.php?action=view&amp;amp;id=59 Parallel port logic analyzer]&lt;br /&gt;
* [http://uvasux.googlepages.com/simplelogicanalyser Simple Logic Analyser]&lt;br /&gt;
* [http://www.xs4all.nl/~jwasys/old/diy2.html A logic analyzer using the PC&#039;s parallel port] (Win32)&lt;br /&gt;
* [http://www.codeproject.com/KB/system/17ChannelLogicAnalyzer.aspx 17 Channel Logic Analyzer] By Elmue auf www.codeproject.com (Windows)&lt;br /&gt;
&#039;&#039;[http://logicanalyzer.sourceforge.net/ LogicAnalyzer] is a framework as well as an application to operate a PC based logic analyzer. It&#039;s built using the Eclipse RCP and designed with extensibiliy in mind. Integrating devices, providing tools or creating completely new functionality is easy.&lt;br /&gt;
LogicAnalyzer main features:&lt;br /&gt;
* Platform independent ( LogicAnalyzer is built using Eclipse RCP, thus it&#039;s mostly platform independent. It also features a native and clean UI.)&lt;br /&gt;
* Rich set of tools ( Several tools come out of the box, such as frequency measurement, distance measurement and serial byte interpreter. LA also comes with an I2C protocol analyzer (SPI, as well as UART analyzer will follow).)&lt;br /&gt;
* SUMP integration ( The most prominent OpenSource logic analyzer hardware (namely the SUMP Logic Analyzer - and derivates such as the Open Workbench Logic Sniffer) work out of the box. It also serves as an example how easy it is to integrate new devices.)&lt;br /&gt;
== Sonstiges ==&lt;br /&gt;
* [http://sigrok.org/wiki/Logic_Analyzer_Comparison sigrok: Logic Analyzer Comparison] (TODO: evtl. dort sowie hier Einträge synchronisieren)&lt;br /&gt;
		<author><name>79.83.80.121</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Konstantstromquelle&amp;diff=67158</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Konstantstromquelle&amp;diff=67158"/>
		<updated>2012-07-02T08:30:36Z</updated>
		<summary type="html">&lt;p&gt;79.83.80.121: typo&lt;/p&gt;
&lt;div&gt;Eine &#039;&#039;&#039;Konstantstromquelle&#039;&#039;&#039; ist eine Schaltung, deren Zweck es ist, den Strom durch eine Last (z.&amp;amp;nbsp;B. eine [[LED]]) möglichst konstant zu halten, das heißt Änderungen des Stroms durch Variationen der Betriebsspannung und/oder des Lastwiderstands entgegen zu wirken.&lt;br /&gt;
Es gibt viele verschiedene Schaltungen, die zu diesem Zweck eingesetzt werden. Sie unterscheiden sich in ihrer Präzision, der minimalen und maximalen Betriebsspannung, und dem Bauteilaufwand. Es sollen hier nur einige besonders einfache Schaltungen vorgestellt werden.&lt;br /&gt;
&amp;lt;div class=&amp;quot;toclimit-2&amp;quot;&amp;gt;&lt;br /&gt;
__TOC__&lt;br /&gt;
Eine sehr einfache Konstantstromquelle lässt sich mit einem [[FET|JFET]] realisieren. Der resultierende Strom ist durch den verwendeten FET bestimmt, dabei wird die Eigenschaft genutzt, dass der JFET selbstleitend ist, also bei einer Gate-Source-Spannung von 0V seinen maximal möglichen Strom leitet und bei ansteigender negativer Gate-Source-Spannung U_GS den Drain-Source-Kanal zunehmend abschnürt. Es werden Bauteile angeboten, bei denen die Verbindung zwischen Gate und Source des FET schon intern vorgenommen wurde (Konstantstromdiode, engl. current regulator diode). Diese werden mit engeren Toleranzen gefertigt und erlauben daher eine genauere Definition des Stroms. Außerdem benötigen diese keinen Widerstand in der Sourceleitung und brauchen damit weniger Spannungsabfall zum Betrieb.&lt;br /&gt;
=== Vorteile ===&lt;br /&gt;
* geringe Sättigungsspannung über dem FET, typ. 0,5V&lt;br /&gt;
* weitestgehend temperaturunabhängig&lt;br /&gt;
=== Nachteile ===&lt;br /&gt;
* Beeinflussung durch Toleranzen der Fertigungsparameter des FET, typ +/- 10%&lt;br /&gt;
* Selbstleitende FETs für Ströme größer als 30mA sind selten und entsprechend teuer&amp;lt;ref&amp;gt;Es gibt aber einige Depletion-Mode Mosfets mit sehr hohen Sperrspannungen und z.T. auch grösseren Strömen.&amp;lt;/ref&amp;gt;&lt;br /&gt;
=== Schaltung ===&lt;br /&gt;
=== Weblinks ===&lt;br /&gt;
* [http://home.arcor.de/slotracingtechnik/homepage/bd256b.htm Konstantstromquelle für Leuchtdioden mit dem BF256B]&lt;br /&gt;
* [[Mosfet-Übersicht#N-Kanal J-FET | Liste von J-FETs]]&lt;br /&gt;
* [http://search.datasheetcatalog.net/key/LM334 LM334] betagter, aber guter IC, programmierbare Konstantstromquelle mit 1µA-10mA, 0,8-1V Spannungsabfall&lt;br /&gt;
== Konstantstromquelle mit bipolaren Transistoren ==&lt;br /&gt;
[[Datei:Ksq.png|thumb|right|231px|U&amp;lt;sub&amp;gt;BE&amp;lt;/sub&amp;gt;-Konstantstromquelle]]&lt;br /&gt;
Die auch als U&amp;lt;sub&amp;gt;BE&amp;lt;/sub&amp;gt;-Konstantstromquelle bekannte Stromquelle funktioniert folgendermassen:&lt;br /&gt;
Wenn die Spannung über R1 die Basis-Emitter-Flussspannung (verwendeter BC546: 0,6V) von T2 überschreitet, schaltet T2 durch. Dadurch wird die Basis von T1 geräumt und damit gesperrt. Der Strom durch T1 und damit die Spannung über R1 sinkt, wodurch T2 wieder zu sperren beginnt, was T1 wieder leiten lässt. So pendelt diese Schaltung auf die konstante BE-Spannung von ca. 0,6..0,7V – je nach verwendetem Transistor – über R1 ein. Weil R1 konstant ist hat dies einen  konstanten Strom durch T2 zur Folge.&lt;br /&gt;
R1 berechnet sich daher wie folgt:&lt;br /&gt;
\begin{align}&lt;br /&gt;
R &amp;amp; = \frac{U}{I}\\&lt;br /&gt;
R1 &amp;amp; = \frac{U_{BE,T2}}{I_{\text{soll}}} = \frac{0.6\text{V}}{I_{\text{soll}}}&lt;br /&gt;
\end{align}&lt;br /&gt;
R2 wird so ausgelegt, dass T1 grundsätzlich sättigen kann. Siehe dazu [[Basiswiderstand]]. Ein guter Richtwert bei 5V Vcc ist 4,7kΩ.&lt;br /&gt;
Anstatt &#039;&#039;&#039;T2&#039;&#039;&#039; kann auch eine Leuchtdiode verwendet werden, dazu den Basisanschluss weglassen. Die LED leuchtet auf, wenn die Stromquelle regelt, und verlischt bei Leerlauf. So lassen sich einfache Konstantstrom-Ladegeräte mit Kontrollanzeige aufbauen.&lt;br /&gt;
Eine temperaturstabile Präzisions-Stromquelle entsteht durch Ersetzen von &#039;&#039;&#039;T2&#039;&#039;&#039; durch einen TL431[http://www.mikrocontroller.net/part/TL431].&lt;br /&gt;
* gut bei niedriger Betriebsspannung, da Schaltung bereits mit kleiner Restspannung von&lt;br /&gt;
:: &amp;lt;math&amp;gt;U_{BE,T2}+U_{CE,T1} \approx 0{,}65\,\text{V}+0{,}15\,\text{V}&amp;lt;/math&amp;gt;&lt;br /&gt;
: am Transistor läuft und die Regelung auch dann erfolgt, wenn nur noch wenige hundert mV zwischen Kollektor und Emitter des Transistors T1 anliegen.&lt;br /&gt;
* Ausschließlich &amp;quot;Allerweltsteile&amp;quot;, d.h. kann aus Resten aus der Bastelkiste aufgebaut werden&lt;br /&gt;
* nicht temperaturkompensiert. Strom schwankt um &lt;br /&gt;
:: &amp;lt;math&amp;gt;\frac{\Delta U_{BE}}{R1} \quad\text{ mit }\quad \Delta U_{BE} \left(\Delta\vartheta\right) \approx -1{,}7 \,\frac{\text{mV}}{\text{K}} \cdot \Delta\vartheta&amp;lt;/math&amp;gt;&lt;br /&gt;
: Das sind etwa 2,6% pro 10°C&lt;br /&gt;
[[Datei:Ksq_2T_sim.svg|thumb|right|300px|Analyse bei steigender Versorgungsspannung]]&lt;br /&gt;
== Konstantstromquelle mit Operationsverstärker und Bipolartransistor ==&lt;br /&gt;
[[Datei:Ksq_opv.png|thumb|right|231px|Konstantstromquelle mit OPV und Bipolartransistor]]&lt;br /&gt;
Der Strom der, welcher konstant gehalten werden soll, wird durch R2 gemessen (Shunt). Der OPV arbeitet quasi als Spannungsfolger und versucht, die Spannung am - Eingang so groß wie am + Eingang zu halten. Ist z.B. die Spanunng am - Eingang etwas kleiner als am + Eingang (Bruchteile von mV!), dann steigt die Ausgangsspannung des OPV um einige mV und erhöht damit die Basis-Emitter-Spannung von T1 und damit den Basisstrom. Dadurch fließt ein höherer Kollerktorstom, welcher wiederum einen höheren Spannungsabfall über R2 verursacht, bis die Spannungen am - und + Eingang des OPV wieder absolut gleich sind (die Offsetspannung wird hier zunächst vernachlässigt). Die Beispielschaltung hier ist bei ausreichender [[Kühlkörper|Kühlung]] für T1 für ca. 1A brauchbar. Der Strom wird mit 0-100mV eingestellt.&lt;br /&gt;
Nachteilig ist, dass der Basisstrom von T1 nicht durch die Last fließt, aber durch R2 und somit die Konstantstromregelung verfälscht. Als Gegenmaßnahme nutzt man einen Darlingtontransistor mit sehr hoher Stromverstärkung von 1000 und mehr, was bedeutet, dass der verfälschende Basisstrom nur noch 1 Promille Fehler verursacht. Oder noch besser einen MOSFET. Letzterer hat Gateströme (Leckströme) im Bereich von unter einem Mikroampere. Dieser Fehler fällt bei 99,9% der Anwendungen nicht ins Gewicht. Prüfen sollte man dabei, dass der MOSFET für [[FET#Linearbetrieb_von_MOSFETs | Linearbetrieb]] geeignet ist, denn das sind viele Hochleistungs-MOSFETs nicht! Hier wird noch ein zusätzlicher Widerstand vor dem Gate des MOSFETs geschaltet, um die hohe Kapazität des Gates vom OPV-Ausgang zu entkoppeln, welche viele OPVs wieder instabil machen würde.&lt;br /&gt;
[[Datei:Ksq_opv_mosfet.png|thumb|right|231px|Konstantstromquelle mit OPV und MOSFET]]&lt;br /&gt;
Wichtig sind R1 und C1. In vielen Schaltungen im Internet fehlen sie, die Spannung über R2 geht direkt an den - Eingang des OPV. Das ist aber falsch und funktioniert oft nur durch Zufall. Denn R1 und C1 sind wichtig zu Frequenzgangkompensation des OPV. Die Schaltung ist ein Regelkreis und diese sind notorisch für Instabilitäten bekannt, d.h. sie schwingen. Durch Rechnung oder Probieren muss der richtige Wert für R1 und C1 gefunden werden, bei der die Stromquelle ausreichend schnell regiert ohne zu schwingen. Testen kann man das u.a. dadurch, dass man einen Sprung auf den Eingang gibt, z.B. mit einem Funktionsgenerator oder einfach einem NE555 als Taktgeber. Dabei beobachtet man die Spannung über R2 mit dem Oszilloskop, ggf. auch am Ausgang des OPV. Hier sieht man wie schnell die die Stromquelle reagiert und ob sie schwingt.&lt;br /&gt;
* Größe Ströme können sehr genau und schnell geregelt werden, nur durch T1 und dessen Kühlung begrenzt.&lt;br /&gt;
* bei sehr hohen Stömen muss man eine Vierdrahtmessung an R2 vornehmen&lt;br /&gt;
* einfacher Aufbau mit Standardkomponenten&lt;br /&gt;
* wird oft als Stromregler in elektronischen Lasten benutzt.&lt;br /&gt;
*Analog by Design Show - Hosted by Bob Pease&lt;br /&gt;
** [http://www.youtube.com/watch?v=411f0DvXu18 Konstantstromquellen]&lt;br /&gt;
** [http://www.youtube.com/watch?v=2N6cjGS7lUE Präzise 1A Konstantstromquelle ]&lt;br /&gt;
== Stromspiegel als Konstantstromquelle ==&lt;br /&gt;
[[Datei:Stromspiegel als Konstantstromquelle.svg|miniatur|Stromspiegel mit Widerstand]]&lt;br /&gt;
Bei stabiler Versorgungsspannung eignet sich ein Stromspiegel mit Widerstand als Spannungs-Stromwandler und findet sich beispielsweise in älteren Operationsverstärkern wie dem LM741. Das Konzept des Stromspiegels wird an dieser Stelle nicht weiter erläutert.&lt;br /&gt;
Die Widerstände R2 und R3 reduzieren die Auswirkungen von Bauteiltoleranzen und der Temperaturdrift. Als grober Richtwert sollte deren Spannungsabfall 0,2 V oder mehr betragen. T1 und T2 sind identische Transistortypen (z.B. BC557B), die idealerweise von einer Bauteilrolle stammen.&lt;br /&gt;
Bei geeigneter Wahl von R2 und R3 oder Parallelschaltung von Transistoren wird aus dem Stromspiegel ein Stromvervielfacher. Bei gleichen Transistoren und gleichen Widerständen entsteht ein 1:1 Stromspiegel.&lt;br /&gt;
Berechnung:&lt;br /&gt;
U&amp;lt;sub&amp;gt;B&amp;lt;/sub&amp;gt; und der gewünschte Strom I sind bekannt&lt;br /&gt;
:&amp;lt;math&amp;gt;I_{ref} = \frac{U_B - 0{,}65 V}{R1+R2}&amp;lt;/math&amp;gt; (Ausgangsformel)&lt;br /&gt;
:&amp;lt;math&amp;gt;R3 = R2&amp;lt;/math&amp;gt; (1:1 Stromspiegel)&lt;br /&gt;
:&amp;lt;math&amp;gt;I = I_{ref}&amp;lt;/math&amp;gt;&lt;br /&gt;
:&amp;lt;math&amp;gt;R1 + R2 = R_g = \frac{U_B - 0{,}65 V}{I}&amp;lt;/math&amp;gt;&lt;br /&gt;
:&amp;lt;math&amp;gt;U_{R2} \approx 0{,}2 V&amp;lt;/math&amp;gt;&lt;br /&gt;
:&amp;lt;math&amp;gt;R2 = \frac{U_{R2}}{I}=\frac{0{,}2 V}{I}&amp;lt;/math&amp;gt;&lt;br /&gt;
:&amp;lt;math&amp;gt;R1 = R_g - R2&amp;lt;/math&amp;gt;&lt;br /&gt;
* wenige, günstige Bauteile&lt;br /&gt;
* sehr einfache Konstruktion&lt;br /&gt;
* mäßiger Spannungsabfall (ca. 1V)&lt;br /&gt;
* schnell da keine ausgeprägte Rückkopplung vorhanden&lt;br /&gt;
* zur Stromsenke umformbar (Überkopf stellen und npn-Typen verwenden)&lt;br /&gt;
* geringer Wirkungsgrad, doppelt wegen Referenzstrom&lt;br /&gt;
* mäßig hoher Quellenwiderstand (einfacher Stromspiegel)&lt;br /&gt;
== PTAT-Konstantstromquelle ==&lt;br /&gt;
:→ siehe  [[PTAT-Stromquelle]]&lt;br /&gt;
=== Grundschaltung mit LM317 ===&lt;br /&gt;
[[Bild:LM317_constant_current.png|thumb|right|280px|Konstantstromquelle mit LM317]]&lt;br /&gt;
Eine sehr einfache, günstige und doch genaue Konstantstromquelle kann mittels LM317 aufgebaut werden. Für einen LED Strom von 20mA ist ein R1 von 62,5 Ω erforderlich, praktisch wird man 68Ω wählen. Dabei ist zu beachten, daß die Eingangsspannung &#039;&#039;V&#039;&#039;&amp;lt;sub&amp;gt;in&amp;lt;/sub&amp;gt; mindestens 3,5V + &#039;&#039;U&#039;&#039;&amp;lt;sub&amp;gt;f,LED&amp;lt;/sub&amp;gt; (Flußspannung der LED) betragen muss.&lt;br /&gt;
* Hohe Spannungsabfall über der Schaltung von mind. 3,5V&lt;br /&gt;
* Verlustleistung&lt;br /&gt;
:: &amp;lt;math&amp;gt;PV_\text{LM317} = I_\text{out}\cdot (V_\text{in}- U_\text{f,LED} -1,25\,\mathrm V)&amp;lt;/math&amp;gt;&lt;br /&gt;
* Abhängig vom Gehäuse ist bei höheren Eingangsspannungen ein Kühlkörper am LM317 nötig:&lt;br /&gt;
** TO220: 1W&lt;br /&gt;
** TO92: 500mW&lt;br /&gt;
** SO-8: 600mW&lt;br /&gt;
* Bei niedrigen Strömen unter 3.5 mA ungenau (min. Load Current 3.5 mA laut Datenblatt)&lt;br /&gt;
==== Schrittweise einstellbare Variante ====&lt;br /&gt;
Eine schrittweise voreinstellbare Variante der Grundschaltung wurde 2008 von einem Mitarbeiter von National Semiconductor (Hersteller des LM317) im EDN-Magazin vorgestellt: [http://www.edn.com/contents/images/6566536.pdf Programmable current source requires no power supply]. Dabei ist hier mit &#039;&#039;programmable&#039;&#039; manuell voreinstellbar gemeint, nicht Mikrocontroller-gesteuert. Auch der Teil des Titles &#039;&#039;requires no power supply&#039;&#039; ist irreführend. Die Konstantstromquelle benötigt sehr wohl eine externe Stromversorgung. Die Schaltung benötigt lediglich keine zusätzlichen Hilfsspannungen, entspricht sie doch der oben genannten Grundschaltung.&lt;br /&gt;
Mittels dreier 0−9 BCD-Schalter werden geschickt gewählte Widerstände zwischen ADJ und OUT parallel geschaltet. Die Widerstände sind so gewählt, dass der erste Schalter mit seinen zehn Stellungen und Widerständen zwischen 0 mA und 9 mA in 1 mA Schritten zum Gesamtstrom beiträgt, der zweite 0 mA bis 90 mA in 10 mA Schritten und der dritte 0 mA bis 900 mA in 100 mA Schritten. &lt;br /&gt;
In dieser Kombination ergibt das eine einstellbare Konstantstromquelle bis 999 mA in 1mA-Schritten bei rund 2% Genauigkeit.&lt;br /&gt;
Insgesamt werden &lt;br /&gt;
* 45 Widerstände, alle 1%, 1/4 W&lt;br /&gt;
** 15 × 1,24 kΩ&lt;br /&gt;
** 15 × 124 Ω&lt;br /&gt;
** 15 × 12,4 Ω&lt;br /&gt;
* ein LM317&lt;br /&gt;
* drei 0−9 BCD-Schaltern und&lt;br /&gt;
* Gehäusematerial (Gehäuse, Kühlkörper für den LM317, Polklemmen, ...)&lt;br /&gt;
benötigt.&lt;br /&gt;
Der LM317 wird bei dieser einstellbaren Stromquelle gerade noch innerhalb seiner Spezifikation betrieben - wenn man den Spannungsabfall über ihn gering hält. Im Stromquellen-Beispiel im Datenblatt wird ein maximaler Widerstand von 120 Ω genannt, wohingegen die einstellbare Stromquelle bis zu 1,24 kΩ (nominell 1 mA Ausgangsstrom) und ∞ Ω (offen, nominell 0 mA Ausgangsstrom) verwendet. Mit etwas Geduld kann man aus dem Datenblatt herauslesen, dass 1,24 kΩ gerade noch ausreichen, damit die Regelung des LM317 nicht aussetzt. Dies findet man im Datenblatt in der Graphik &#039;&#039;Minimum Operating Current&#039;&#039; und im Beispiel &#039;&#039;1.2V-20V Regulator with Minimum Program Current&#039;&#039;. Mit ∞ Ω ist man definitiv außerhalb des Arbeitsbereiches.&lt;br /&gt;
Der Strom bei der Einstellung 000 mA (Widerstand → ∞ Ω, d.h. offen) entspricht nicht 0,0 mA, sondern dem Strom aus dem ADJ-Anschluss für den nicht spezifizierten Fall, dass der LM317 außerhalb seines Arbeitsbereiches betrieben wird. Die im Datenblatt angegebenen 50 µA (typ.), 100 µA (max.) für den Arbeitsbereich können dabei je nach Exemplar überschnitten werden und sind nicht konstant. &lt;br /&gt;
Die Messung an neueren Chargen (gefertigt nach 2006) des LM317 diverser Hersteller zeigt, dass auch 1mA nicht sicher erreichbar sind. Es ist vielmehr so, das diese KSQ erst korrekt ab 003 mA bis hoch zu den 999 mA funktioniert. Das heißt konkret, die Einstellungen 000 mA, 001 mA und 002 mA sind nicht mehr stromstabilsiert. Das sollte man beachten, sofern man unbedingt den LM317 bei sehr kleinen Strömen einsetzen möchte.&lt;br /&gt;
In der Praxis lohnt es sich besonders bei kleinen Strömen ein Strommessgerät in Reihe zu schalten. Dabei ist Vorsicht bei billigen Multimetern geboten&amp;lt;ref&amp;gt;Bei billigen Multimetern ist auch aus anderen Gründen immer Vorsicht geboten. Siehe [http://gps.sozialnetz.de/global/show_document.asp?id=aaaaaaaaaaaajxn Schwerpunktaktion „Handmultimeter“ der hessischen Marktüberwachung ...]&amp;lt;/ref&amp;gt;. Deren niedrige Strommessbereichen sind häufig mit einer 200 mA oder 250 mA Schmelzsicherung abgesichert. Schaltet man die Stromquelle versehentlich über 200 mA, beziehungsweise 250 mA, ist ein Sicherungswechsel fällig.&lt;br /&gt;
==== Weblinks ====&lt;br /&gt;
* National Semiconductor Datenblatt [http://www.national.com/ds/LM/LM117.pdf LM117/LM317A/LM317 3-Terminal Adjustable Regulator]&lt;br /&gt;
* [http://www.umnicom.de/Elektronik/Schaltungssammlung/Strom/Quelle/Stromquelle.html Konstantstromquelle bis 3A mit LM2576]&lt;br /&gt;
*[http://www.edn.com/contents/images/6566536.pdf Programmable current source requires no power supply]&lt;br /&gt;
==== Preise ====&lt;br /&gt;
; LM317:&lt;br /&gt;
* TO3: 1,90 €&lt;br /&gt;
* TO-220: &amp;lt; 0,25 €&lt;br /&gt;
* TO-92: &amp;lt; 0,15 €&lt;br /&gt;
* SO-8: &amp;lt; 0,20 €&lt;br /&gt;
=== Andere Linearregler ===&lt;br /&gt;
Der zuvor beschriebene LM317 eignet sich besonders gut als Stromquelle, da er seine Regelspannung auf der &#039;high-side&#039; erwartet (1,25 V zwischen Vout und ADJ) und man den Regelpfad als Konstantstrompfad missbrauchen kann (ADJ als Ausgang nach GND, wobei der Strom über den Widerstand und nicht von ADJ geliefert wird)).&lt;br /&gt;
==== Mittels Shunt und Messverstärker ====&lt;br /&gt;
Die meisten anderen Linearregler messen ihre Regelspannung im Bezug auf GND. Um einen solchen Regler als Konstantstromquelle zu benutzen, kann man einen Stromsensor und einen Messverstärker verwenden. Letzterer steuert dann die Regelung des Linearreglers. Maxim hat in [http://www.maxim-ic.com/app-notes/index.mvp/id/921] ein Beispiel veröffentlicht, das so oder so ähnlich auch mit anderen Linearreglern funktioniert. Maxim misst den Strom auf der Eingangsseite. Vorteil: der Innenwiderstand des Ausgangs des Linearreglers wird durch den Messwiderstand nicht erhöht. Nachteil: Der Eigenverbrauch des Linearreglers wird mitgemessen.&lt;br /&gt;
Man kann den Strom auch auf der Ausgangsseite messen.&lt;br /&gt;
Das gleiche Prinzip funktioniert für Schaltregler, siehe zum Beispiel [[#LM2576_Step_Down| LM2576 Step Down]] auf dieser Seite.&lt;br /&gt;
==== Im Regelpfad - High-Side ====&lt;br /&gt;
              .-----------.&lt;br /&gt;
 VCC       IN |           | OUT&lt;br /&gt;
  ------------o           o------&amp;gt;----.&lt;br /&gt;
              |           |      I    |                 |&lt;br /&gt;
              |           |           |                 |&lt;br /&gt;
              |           |          .-.                |&lt;br /&gt;
              |           |          | |                |&lt;br /&gt;
              |           |          | |  Rload, R1     |&lt;br /&gt;
              |           |          &#039;-&#039;                |&lt;br /&gt;
              |           |           |                 |&lt;br /&gt;
              |           | FB        |                 |&lt;br /&gt;
              |           o------&amp;lt;----o                 |Vout&lt;br /&gt;
              |           |    Iref   |        |        |&lt;br /&gt;
              |           |           |        |        |&lt;br /&gt;
              |           |          .-.       |        |&lt;br /&gt;
              |           |          | |       | Vref   |&lt;br /&gt;
              |           |          | |  R2   |        |&lt;br /&gt;
              &#039;-----o-----&#039;          &#039;-&#039;       |        |&lt;br /&gt;
                    | GND             |        |        |&lt;br /&gt;
                    |                 |        |        |&lt;br /&gt;
                   ===               ===       v        v&lt;br /&gt;
                   GND               GND&lt;br /&gt;
                             Iref &amp;lt;&amp;lt; I&lt;br /&gt;
Die meisten einstellbaren Linearregeler werden durch einen Spannungsteiler (R&amp;lt;sub&amp;gt;1&amp;lt;/sub&amp;gt;, R&amp;lt;sub&amp;gt;2&amp;lt;/sub&amp;gt;) zwischen Ausgangsspannung (V&amp;lt;sub&amp;gt;out&amp;lt;/sub&amp;gt;) und Masse (GND) eingestellt. Der Spannungsteiler wird dabei so dimensioniert, dass eine vorgegebene Spannung V&amp;lt;sub&amp;gt;ref&amp;lt;/sub&amp;gt; (meist 1,25 V) gegen GND an der Anzapfung des Spannungsteilers abfällt, die dann zum Regeleingang des Linearreglers geführt wird. Dabei wird üblicherweise angenommen, dass der Strom I&amp;lt;sub&amp;gt;ref&amp;lt;/sub&amp;gt; in den Regler hinein vernachlässigbar ist.&lt;br /&gt;
Dann gilt für den Strom I im Spannungsteiler:&lt;br /&gt;
:&amp;lt;math&amp;gt;I = I_{R_1} = I_{R_2} = \frac{V_\text{out}}{R_1 + R_2}&amp;lt;/math&amp;gt;&lt;br /&gt;
und &lt;br /&gt;
:&amp;lt;math&amp;gt;I_{R_2} = \frac{V_\text{ref}}{R_2}&amp;lt;/math&amp;gt;&lt;br /&gt;
Der Strom I im Spannungsteiler ist somit alleine durch Wahl von R&amp;lt;sub&amp;gt;2&amp;lt;/sub&amp;gt; bestimmt und unabhängig von R&amp;lt;sub&amp;gt;1&amp;lt;/sub&amp;gt; bei vorgegebenem R&amp;lt;sub&amp;gt;2&amp;lt;/sub&amp;gt;.&lt;br /&gt;
Ersetzt man daher R&amp;lt;sub&amp;gt;1&amp;lt;/sub&amp;gt; durch die Last, so erzeugt der Linearregler durch Steuerung von V&amp;lt;sub&amp;gt;out&amp;lt;/sub&amp;gt; einen konstanten Strom&lt;br /&gt;
:{|cellpadding=&amp;quot;2&amp;quot; style=&amp;quot;border:2px solid #ccccff&amp;quot;&lt;br /&gt;
|&amp;lt;math&amp;gt;I = \frac{V_\text{ref}}{R_2}&amp;lt;/math&amp;gt;&lt;br /&gt;
durch die Last.&lt;br /&gt;
Dabei muss man die Grenzen des Linearreglers beachten:&lt;br /&gt;
Der maximale Strom &#039;&#039;I&#039;&#039;&amp;lt;sub&amp;gt;max&amp;lt;/sub&amp;gt; des Reglers darf nicht überschritten werden. Damit die Annahme gilt, dass der Reglerstrom &#039;&#039;I&#039;&#039;&amp;lt;sub&amp;gt;ref&amp;lt;/sub&amp;gt; gegenüber dem Strom &#039;&#039;I&#039;&#039; im Spannungsteiler vernachlässigbar ist muss R&amp;lt;sub&amp;gt;2&amp;lt;/sub&amp;gt; klein gegenüber dem Innenwiderstand des Regeleingangs sein. Dass bedeutet, dass R&amp;lt;sub&amp;gt;2&amp;lt;/sub&amp;gt; so zu wählen ist, dass immer gilt:&lt;br /&gt;
|&amp;lt;math&amp;gt;\frac{V_\text{ref}}{I_\text{max}} \leqq R_2 \ll R_\text{in,ref} = \frac{V_\text{ref}}{I_\text{ref}}&amp;lt;/math&amp;gt;&lt;br /&gt;
Es muss ein Minimalstrom &#039;&#039;I&#039;&#039;&amp;lt;sub&amp;gt;min&amp;lt;/sub&amp;gt; durch den Spannungsteiler fließen, damit die Regelung nicht aussetzt. Für diesen Strom gilt gegenüber dem Regelstrom &#039;&#039;I&#039;&#039;&amp;lt;sub&amp;gt;ref&amp;lt;/sub&amp;gt;:&lt;br /&gt;
:&amp;lt;math&amp;gt;I_\text{min} = \frac{V_\text{out,min}}{R_1 + R_2} \gg I_\text{ref}&amp;lt;/math&amp;gt;&lt;br /&gt;
Mit &lt;br /&gt;
:&amp;lt;math&amp;gt;V_\text{out,min} = V_\text{ref}\,&amp;lt;/math&amp;gt;&lt;br /&gt;
folgt&lt;br /&gt;
:&amp;lt;math&amp;gt;R_1 \ll \frac{V_\text{ref}}{I_\text{ref}} - R_2 = R_\text{in,ref} - R_2&amp;lt;/math&amp;gt;&lt;br /&gt;
Angenähert:&lt;br /&gt;
|&amp;lt;math&amp;gt;R_\text{load} \approx R_1 \ll \frac{V_\text{ref}}{I_\text{ref}}&amp;lt;/math&amp;gt;&lt;br /&gt;
Neben diesen Einschränkungen ist auch zu beachten, dass Die Last R&amp;lt;sub&amp;gt;1&amp;lt;/sub&amp;gt; auf der High-Side hängt und nicht gegen GND.&lt;br /&gt;
Der Ausgangsstrom beträgt 1,25V/Rx. Die Stromquelle ist &#039;&#039;&#039;nicht&#039;&#039;&#039; kurzschlussfest. Der Widerstand Rsc dient der Strombegrenzung der einzelnen Strompulse (Schaltregler), was u.a. einen gewissen Überlastschutz für den MC34063 darstellt. Rsc = 0.3/I_max, wobei I_max der maximale Pulsstrom ist und dieser kleiner 1.5A sein muss, weil der IC nicht mehr hergibt. In den meisten Anwendung nimmt man hier 0,22Ω oder mehr. &lt;br /&gt;
Das Ganze kann man z.&amp;amp;nbsp;B. für mehrere LEDs in Reihe verwenden um diese mit&lt;br /&gt;
5V oder mit 4x 1,5V Batterien zu betreiben. Weiterhin ist zu beachten,&lt;br /&gt;
dass die Schaltung nicht leerlauffest ist: Im Leerlauf läuft die&lt;br /&gt;
Spannung auf &amp;gt;40V, und dann geht der MC34063 kaputt. Daher sollte man&lt;br /&gt;
zur Sicherheit eine Z-Diode parallel zum Ausgang legen, deren Z-Spannung 2..3V über der maximal zu erwartenden Ausgangsspannung liegt, wenn es&lt;br /&gt;
passieren kann, dass die Last abgeklemmt wird.&lt;br /&gt;
Aufgrund des Elkos am Ausgang ist die Stromquelle recht träge. R1 dient dazu den MC34063 vor dem Stromstoß zu schützen, wenn sich der Elko in eine zu kleine Last entlädt und der Strom kurzzeitig höher als der eingestellte Wert wird.&lt;br /&gt;
Die Bauteilwerte sind alle relativ unkritisch. Je nach Betriebsspannung sind die Bauteilwerte etwas anzupassen um den optimalen Wirkungsgrad und die beste Performance zu erzielen. Die eingezeichneten Bauteilwerte sind für geringe Ströme (&amp;lt;100mA) und Eingangsspannungen zwischen 5 und 15V ausgelegt. R2 sollte bei hohen Spannungen vergrößert werden. Wie man die Werte genau berechnet, steht in der Application Note AN920/D.&lt;br /&gt;
Stromquellen sollten grundsätzlich &#039;&#039;keinen&#039;&#039; Ausgangselko aufweisen! Wie die Schaltregler-Schaltung dann stabil arbeitet muss gesondert herausgefunden werden.&lt;br /&gt;
[[Bild:mc34063_constant_current.gif]]&lt;br /&gt;
* ohne Z-Diode D2 nicht leerlauffest&lt;br /&gt;
Die Step-Down Version funktioniert im Prinzip genauso wie die normale, lineare Konstantstromquelle, nur dass die ungenutzte Spannung nicht sinnlos verheizt wird. Die Eingangsspannung muss mindestens 2V größer sein als die Ausgangsspannung.&lt;br /&gt;
Diese Version ist auch ohne die Z-Diode leerlauffest. Kurzschlussfest wird sie durch Rsc. Allerdings entlädt sich der Elko erstmal in die Last, wenn man diese im Betrieb anklemmt. Dadurch kann die Last und der MC34063 beschädigt werden, der Widerstand R1 verhindert aber letzteres.&lt;br /&gt;
Bei der Step-Down Version kann man die Elkos etwas kleiner machen, als bei der Step-Up Version, da der Stromfluss durch die Spule in die Last nahezu konstant ist. Wenn man die Spule vergrößert, wird der Strom gleichmäßiger und man kann die Elkos verkleinern. Allerdings wird der Wirkungsgrad aufgrund des höheren Gleichstromwiderstands der Spule schlechter und die Schaltung reagiert langsamer auf Laständerungen. Wie immer ist es also ein Kompromiss zwischen Wirkungsgrad, Kosten und Bauteilgröße.&lt;br /&gt;
Konstantstromregler sollten grundsätzlich &#039;&#039;keinen&#039;&#039; Ausgangskondensator haben, weil dieser den gewünschten Regeleffekt zunichte macht. Wie die Rückführung zum Regelverstärker im Schaltregler regelschwingungsfrei gemacht wird muss dann gesondert herausgefunden werden.&lt;br /&gt;
[[Bild:mc34063_constant_current_2.gif]]&lt;br /&gt;
* leerlauf &lt;br /&gt;
* kurzschlussfest&lt;br /&gt;
Besser ist hier eine [[Konstantstromquelle fuer Power LED]].&lt;br /&gt;
In einem Thread im Forum (http://www.mikrocontroller.net/topic/97838#new) wird folgende Schaltung genannt: http://www.mikrocontroller.net/attachment/34179/current_source.pdf &lt;br /&gt;
Vollständiger Artikel: http://www.ednasia.com/article-621-switchingregularformsconstantcurrentsource-Asia.html&lt;br /&gt;
== Konstantstromquelle mit Komparatoren ==&lt;br /&gt;
=== Einfache Abwärtswandlung (Vout &amp;lt; Vin)===&lt;br /&gt;
Diese Schaltung wurde eigentlich für 1W LEDs entworfen, kann aber sicherlich auch anderweitig verwenden werden. Sie ähnelt sehr der eines vollintegrierten Schaltreglers wie MC34063 oder LM2576, ohne jedoch einen solchen zu verwenden.&lt;br /&gt;
Der Komparator vergleicht den Spannungsabfall über einem Shunt mit dem einer Referenzspannungsquelle. Ist die Spannung über dem Shunt zu groß, so schaltet er ab und der P-Kanal MOSFET sperrt. Umgekehrt, ist die Spannung über dem Shunt kleiner als die Referenzspannung, leitet der P-FET. Q4 arbeitet als [[Konstantstromquelle]] und sorgt dafür, dass die Gateansteuerung auch bei unterschiedlichen Versorgungsspannungen immer gleich bleibt. Die Referenzspannung von 100mV wird hier einfach durch eine Z-Diode und einen Spannungsteiler eingestellt. Für D4 muss eine schnelle Diode eingesetzt werden, entweder eine Schottkydiode oder schnelle Siliziumdiode! Q2 und Q3 dienen als sehr einfacher [[FET|MOSFET]]-[[Treiber]]. D3 ist nur aus Sicherheitsgründen vorhanden, um die Gate-Source Spannung des MOSFETs zu begrenzen, sie kann ggf. auch weggelassen werden. Über den Anschluß PWM kann ein invertiertes [[PWM]]-Signal zur Dimmung eingespeist werden. Hierbei muss das PWM-Signal im HIGH-Zustand größer als ca. 1V sein, ein einfaches 3,3V oder 5V Logiksignal ist also voll OK.&lt;br /&gt;
Der Ausgangsstrom kann durch Veränderung von R1 eingestellt werden. Der Wert kann einfach über die Formel&lt;br /&gt;
&amp;lt;math&amp;gt;I_{aus}=\frac{V_{Ref}}{R1} = \frac{100mV}{R1}&amp;lt;/math&amp;gt;&lt;br /&gt;
bestimmt werden.&lt;br /&gt;
Platinendatei im Eagle-Format gibt es [http://www.mikrocontroller.net/wikifiles/3/38/LED_Stromregler.sch hier].&lt;br /&gt;
[[Bild:LED_Stromregler.png|thumb|left|600px| Einfacher Stromregler aus Standardbauteilen]]&lt;br /&gt;
[[Bild:LED_Stromregler_brd.png|thumb|left|600px| Beispiel eines Platinenlayouts]]&lt;br /&gt;
{{clear}}&lt;br /&gt;
* Kurzschlussfest&lt;br /&gt;
* guter Wirkungsgrad bei hohen Eingangsspannungen, Energie wird nicht wie bei einem Linearregler in Wärme umgesetzt&lt;br /&gt;
* einfachste Komponenten&lt;br /&gt;
* sehr preiswert, max. 2 EUR &lt;br /&gt;
* Dimmung per [[PWM]] möglich&lt;br /&gt;
* Eingangsspannungsbereich sehr groß, ca. 6-30V&lt;br /&gt;
* sehr einfach auch auf anderen Strom einstellbar&lt;br /&gt;
* [http://www.christiankoch.de/archiv/led-ksq/ Diskrete LED-Konstantstromquelle auf Schaltregler-Basis]&lt;br /&gt;
* [http://www.national.com/an/AN/AN-1515.pdf &amp;quot;A Comprehensive Study of the Howland Current Pump&amp;quot;, Application Note von National Semiconductior, engl.]&lt;br /&gt;
* [http://www.nomad.ee/micros/mc34063a/index.shtml MC34063A Design Tool (engl.)]&lt;br /&gt;
* [http://www.onsemi.com/pub_link/Collateral/MC34063A-D.PDF Datenblatt des MC34063 bei ON Semi]&lt;br /&gt;
* [http://www.stromflo.de/dokuwiki/doku.php?id=led_tutorial LED_Tutorial]&lt;br /&gt;
* [http://www.joretronik.de/Web_NT_Buch/Kap3/Kapitel3_2.html weitere Beispiele von Konstantstromquellen]&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Linksammlung&amp;diff=55771</id>
		<title>Linksammlung</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Linksammlung&amp;diff=55771"/>
		<updated>2011-03-11T14:45:43Z</updated>
		<summary type="html">&lt;p&gt;79.83.80.121: Änderung 55747 von Jimmy j (Diskussion) wurde rückgängig gemacht. Spam&lt;/p&gt;
&lt;div&gt;Auf dieser Seite werden Links zu anderen interessanten Mikrocontroller- und Elektronikseiten gesammelt.&lt;br /&gt;
Die alte Linkseite findet man [http://www.mikrocontroller.net/en/links hier].&lt;br /&gt;
* [http://www.alldatasheet.com/ alldatasheet] - Datasheet Search&lt;br /&gt;
* [http://www.datasheetarchive.com/ datasheetarchive] - Datasheet Search&lt;br /&gt;
* [http://www.datasheetcatalog.com/ datasheetcatalog] - Datasheet Search&lt;br /&gt;
* [http://www.msarnoff.org/chipdb/ ChipDB] - Pinouts von gängigen µCs.&lt;br /&gt;
&amp;lt;!-- SPAM&lt;br /&gt;
* [http://www.TechTour.net] - Angebote und Technische Beratung von mehreren Anbietern gleichzeitig einholen. Von der Elektronik Entwicklung über Leiterplatten Bestückung, von Leiterplatten über Folientastaturen, Gehäusen bis zur Kabelkonfektion.&lt;br /&gt;
== [[AVR]] ==&lt;br /&gt;
* [http://www.halbleiter-scout.de/ Halbleiter Scout] - Halbleiter Hersteller&lt;br /&gt;
* [http://www.atmel.com/dyn/general/updates.asp Atmel.com updates] Liste der letzten Änderungen in Datenblättern und Beispielcode auf ATMEL.com (nicht nur für AVRs)&lt;br /&gt;
* [http://www.msc-ge.com/de/produkte/elekom/mc/atmel/avr_start.html AVR Produktinfos] AVR Infos vom Atmel Distributor MSC Vertriebs GmbH&lt;br /&gt;
* [http://www.filmetrics.com  Filmetrics Inc.] (Filmetrics manufactures affordable thin-film measurement instruments capable of measuring thin films from 3nm to 0.5mm in thickness.)&lt;br /&gt;
&amp;lt;!-- offline 4/2010&lt;br /&gt;
* [http://www.microschematic.com/ AVR Microcontroller inside] (nett gemacht, Engl. Seite am 07-09-2008 nicht erreichbar)&lt;br /&gt;
* [http://popularmicrocontrollers.com/ AVR Microcontrollers] - A web site about AVR microcontrollers&lt;br /&gt;
&amp;lt;!-- Dieser Unterabschnitt ist für AVR. Für PIC gibt es einen eigenen Unterabschnitt weiter unten. --&amp;gt;&lt;br /&gt;
==== C ====&lt;br /&gt;
* [http://www.imagecraft.com/devtools_AVR.html Imagecraft] Der ICCAVR C Compiler fuer AVR von Imagecraft.&lt;br /&gt;
* [http://john.ccac.rwth-aachen.de:8000/as/ Macro Assembler AS] - AS is a portable macro cross assembler for a variety of microprocessors and -controllers&lt;br /&gt;
==== Disassembler ====&lt;br /&gt;
* [http://www.datarescue.com/idabase/ IDA-Pro] -Disassembler und Debugger für fast alle bekannten Prozessoren. Evaluation Version verfügbar. Tagline: &#039;&#039;The most advanced tool for Hostile Code Analysis, Vulnerability and Software Reverse Engineering&#039;&#039;&lt;br /&gt;
* [http://avr.jassenbaum.de/ja-tools ReAVR] - Disassembler und ACXutility Binary Tool&lt;br /&gt;
* [http://dev.frozeneskimo.com/software_projects/vavrdisasm vAVRdisasm] - Free AVR Disassembler&lt;br /&gt;
* [http://www.johannes-bauer.com/mcus/avrdisas/ avrdisas] - AVR Mikrocontroller Disassembler für Linux (und Win32)&lt;br /&gt;
&amp;lt;!-- * [http://biew.sourceforge.net/en/biew.html BVIEW] is multiplatform portable viewer of binary files with built-in editor in binary, hexadecimal and disassembler modes. It includes &#039;&#039;&#039;AVR&#039;&#039;&#039;/Java/i86-i386-AMD64/ARM-XScale/PPC64 disassemblers, russian codepages convertor, full preview of formats - MZ, NE, PE, NLM, coff32, elf partial - a.out, LE, LX, PharLap; code navigator and more over. (GPL) - 404, 6.9.2010 --&amp;gt;&lt;br /&gt;
==== BASIC ====&lt;br /&gt;
* [http://www.DieProjektseite.de Beetle-Basic] Leistungsfähiges Basic-Betriebssystem im AVR.&lt;br /&gt;
* [http://www.mikrocontroller.net/articles/AVR_BASIC AVR_BASIC] Open Source Freeware: Minimalistischer Basic-Interpreter  im AVR.&lt;br /&gt;
* [http://gcbasic.sourceforge.net/ Great Cow BASIC] &amp;quot;Open Source BASIC programming tools for Microchip PIC and Atmel AVR microcontrollers&amp;quot;&lt;br /&gt;
==== Pascal ====&lt;br /&gt;
==== Forth ====&lt;br /&gt;
* [http://www.robo-forth.de www.robo-forth.de] - AVR Forth Compiler mit umfangreicher Funktionslibrary für Servos, Motore und Sensoren&lt;br /&gt;
==== Java ====&lt;br /&gt;
* [http://www.harbaum.org/till/nanovm NanoVM] - Java VM für AVR-Mikrocontroller ([[NanoVM|deutsches Wiki]])&lt;br /&gt;
* [http://www.fam-frenz.de/stefan/compiler.html SJC] - Java-Compiler (erzeugt AVR-Maschinencode) für AVR-Mikrocontroller ([[SJC]])&lt;br /&gt;
==== Ada ====&lt;br /&gt;
* [http://avr-ada.sourceforge.net/ AVR-Ada] - Ada Compiler innerhalb von GCC (GNAT) für AVR.  Enthält eine kleine Laufzeitbibliothek ohne Tasking und ohne Exceptions. [http://www.mikrocontroller.net/topic/168823#1614208]&lt;br /&gt;
==== Virgil ====&lt;br /&gt;
==== LabVIEW ====&lt;br /&gt;
* http://www.ni.com/embedded/ Informationen zu LabVIEW, der graphischen Entwicklungsumgebung von National Instruments&lt;br /&gt;
* http://www.labviewforum.de/ Deutsches Labview-Forum&lt;br /&gt;
* [http://web.me.com/iklln6/automation/LabVIEW.html Communicating Arduino--&amp;gt;LabVIEW]&lt;br /&gt;
==== Python ====&lt;br /&gt;
* [http://code.google.com/p/python-on-a-chip/ python-on-a-chip] (pymite). There are two sample projects in the source tree.  One for an 8-bit Atmel ATmega103 (but any AVR/ATmega with 4 KB RAM or more will do) and one for the 32-bit Atmel AT91SAM7S64 running on the AT91SAM7S-EK evaluation board. (GPL Lizenz)&lt;br /&gt;
==== Openeye ====&lt;br /&gt;
* OpenEye ist eine Kombination aus PC-Programm (Windows, Delphi) und einer Monitor-Routine im AVR. Die Daten aus dem AVR werden mit RS232 übertragen und können fürs Debuggen der laufenden Anwendung benutzt werden. OpenEye wurde vom User Martin Vogel (oldmax) geschrieben [http://www.mikrocontroller.net/topic/143144#1326244].&lt;br /&gt;
==== Modkit ====&lt;br /&gt;
[http://blog.modk.it/ Modkit] is a new kind of graphical programming environment that makes programming things in the physical world as easy as dragging and dropping little virtual code blocks in a web browser.. Heavily inspired by the Scratch programming environment (from MIT Media Lab&#039;s Lifelong Kindergarten Group), Modkit enables anyone including kids, artists and inventors to build with electronic kits and components including motors, sensors, lights, sound and the popular Arduino and Arduino compatible development boards... (Text vom Makezine)&lt;br /&gt;
* [http://et-tutorials.de/632/kostenloser-mikrocontroller-kurs/ Mikrocontroller Video Tutorial] Video-Tutorial für Einsteiger (C-Kurs + Einführung 8051)&lt;br /&gt;
* [http://www.meinemullemaus.de/elektronik/avr_workshop/index.html AVR Mikrocontroller] Einfühung in AVR Mikrocontroller mit Nachbau des Spiels &amp;quot;Senso&amp;quot;.&lt;br /&gt;
* [http://electrons.psychogenic.com/avr/ electrons.psychgenic.com] AVR Microcontroller Section - Einführung und Tutorial (E)&lt;br /&gt;
&amp;lt;!-- Bachblütentherapie... 4/2010&lt;br /&gt;
* [http://digitaltechnik.mschoeffler.de digitaltechnik.mschoeffler.de] Einführung in die Grundlagen der Digitaltechnik&lt;br /&gt;
* [http://www.schaltungsforum.de Das Schaltungsforum] ist eine Seite für Anfänger und Profis welche ständig mit Tutorials erweitert wird. Stellt Eure Projekte online. Die Seite befindet noch im Aufbau und Eure Mithilfe ist erwünscht.&lt;br /&gt;
* [http://www.mikrocontrollerspielwiese.de mikrocontrollerspielwiese.de] ist eine Seite, die an Anfänger gerichtet ist und Experimente und fertige Projekte komplett mit Code und Eagle-Dokumenten zur Verfügung stellt.&lt;br /&gt;
* [http://www.elo-web.de/elo/mikrocontroller-und-programmierung/avr-anwendungen ELO-AVR-Anwendungen] bietet eine wachsende Sammlung kleinerer AVR-Projekte, überwiegend für die ATTiny-Serie.&lt;br /&gt;
* [http://www.schramm-software.de/tipps/ AVR-Tipps] Programmier-Tipps und AVR-Experimente.&lt;br /&gt;
* [http://www.uwe-kerwien.de/pll/pll-synthesizer.htm PLL-Synthesizer Tutorial] kleines praxisorientiertes PLL-Tutorial zur Funktion, Reparatur und Steuerung einer PLL-Schaltung mit AVR ATtiny2313 über 3-Leiter-Bus&lt;br /&gt;
* Arduino&lt;br /&gt;
** [http://tronixstuff.wordpress.com/tutorials/ t r o n i x s t u f f] - Arduino Tutorials (engl.)&lt;br /&gt;
** [http://www.earthshinedesign.co.uk/ASKManual/Site/ASKManual.html The Complete Beginners Guide to the Arduino]&lt;br /&gt;
** [http://www.codeproject.com/KB/system/ArduinoVB.aspx Arduino with Visual Basic] by Carl Morey auf codeproject.com&lt;br /&gt;
* [http://www.piconomic.co.za/avr.html Piconomic Design Atmel AVR Course] is for the engineer who wants to switch to the 8-bit Atmel AVR microcontroller and learns by example. C language and compiler experience is a prerequisite. (Beim Nachbau des AVR-Boards &#039;&#039;&#039;Copyright notice&#039;&#039;&#039; beachten!)&lt;br /&gt;
* [http://metku.net/index.html?path=articles/microcontroller-part-1/index_eng metku.net] - How to get started with microcontrollers (ATtiny45, Steckbrett)&lt;br /&gt;
* [http://www.stromflo.de/dokuwiki/doku.php?id=xmega-c-tutorial XMEGA-C-Tutorial] - Tutorial über Atxmega&lt;br /&gt;
* [http://www.itee.uq.edu.au/~cse/_atmel/AVR_Studio_Tutorial/ Einstieg in AVRStudio 4] (viele Abbildungen, Engl.)&lt;br /&gt;
* [[AVR-Studio]]&lt;br /&gt;
==== Bascom ====&lt;br /&gt;
* [http://sourceforge.net/apps/mediawiki/avr-ada/index.php?title=Tutorial AVR-Ada Tutorial]&lt;br /&gt;
* [http://www.fox4you.cc Austria] Development Tools for ATMEL ATmega Microcontrollers Connections via USB and LAN&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php Embedded-IT] USB Module auf AVR Basis sowie Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem&lt;br /&gt;
&amp;lt;!-- falsche Einordnung: kein Atmel spezifisches Angebot 4/2010&lt;br /&gt;
* [http://www.glyn.de GLYN High-Tech Distribution] Mikrocontroller Applikationen, TFT-Displays, LCD-Anzeigen, Memory Cards&lt;br /&gt;
* [http://avrboards.com/ AVR Boards] - Some information about AVR microcontrollers and development boards&lt;br /&gt;
* [http://six.media.mit.edu:8080/6 number six] - Open Source Design, Atmega32. Alle Pins sind auf eine 2x20 Pol Wannenstiftleiste herausgeführt.&lt;br /&gt;
* http://www.maares.de/tools USB Memory Stick am AVR Butterfly. AVR Butterfly Trägerplatine zum Anschluß von VDRIVE, VMUSIC, RFM12.&lt;br /&gt;
* [http://www.wiring.org.co/ Wiring] is an open source programming environment and electronics i/o board for exploring the electronic arts, tangible media, teaching and learning computer programming and prototyping with electronics.&lt;br /&gt;
* [http://binaryideas.blogspot.com/2008/08/project-quick-avr-part-3_26.html QuickAVR] - DIY Prototypenboard zum Aufstecken auf ein Breadboard (ATmega168, 16 MHz, no SMD)&lt;br /&gt;
* [http://www.chip45.com/ chip45] Atmel AVR Module und Boards mit USB, RS232/485, CAN, Ethernet, Funkmodule, sowie ISP Programmieradapter.&lt;br /&gt;
* [http://www.rakers.de/catalog Dr. Rakers] &amp;lt;b&amp;gt;AVR Boards und Experimentierplatinen&amp;lt;/b&amp;gt; mit USB, Ethernet, RS232, CAN, LCD etc. in hochwertiger Qualität zu günstigen Preisen.&lt;br /&gt;
* [http://nibo.nicai-systems.de Roboterbausatz Nibo] - autonomer &amp;lt;b&amp;gt;Roboter&amp;lt;/b&amp;gt; mit einem ATmega128 und einem ATmega88&lt;br /&gt;
* [http://www.comsys.ch/Tern-Embedded-Systeme.151.0.html Tern Embedded Systeme] - C++ programmierbare Kontroller mit 586, i386EX, Am188ES und V25 Prozessoren, Entwicklungstools.&lt;br /&gt;
* [http://www.schramm-software.de/bausatz/ Schramm-Software] - AVR Mikrocontroller-Bausätze&lt;br /&gt;
* [http://www.alvidi.de/ Alvidi] - Headerboards mit AVR &amp;amp; AVR32 Controllern&lt;br /&gt;
* [http://www.steitec.net/ Steinert Technologies] - Thailändischer Anbieter von Mikrocontroller Boards (AVR, ARM7, ARM9, PIC, dsPIC, PSoC, uvm.)&lt;br /&gt;
* [http://www.kabelscheune.de/ Elektromaterial] - Onlineshop für Elektromaterial&lt;br /&gt;
* [http://www.ledmeile.de/ LED Lampen] - Onlineshop für LEDs&lt;br /&gt;
** [http://www.arduino.cc/ Arduino] Homepage&lt;br /&gt;
** [http://www.freeduino.org/ Freeduino.org] - Riesige Linksammlung zu dem &#039;&#039;&#039;Ardunio&#039;&#039;&#039;(R) AVR-Board (Kit) und dessen Clones und Mutanten (DIY oder Kit)&lt;br /&gt;
** [http://www.freeduino.de/ freeduino.de] - Anleitungen und Tutorials, Arduino Wiki, Blog, Tools in Deutsch&lt;br /&gt;
** [http://shieldlist.org/ Arduino Shield List]&lt;br /&gt;
* [http://www.fritzing.org Fritzing] nützliches Programm für viele Betriebsysteme zur Unterstützung eines Brettboard-Aufbaus(ungetestet).&lt;br /&gt;
* [http://www.specialprint.eu Specialprint] InkjetDruck für den digitalen Direktdruck von Ätzmasken, Lötstoppmasken, Frontplatten, Kennzeichnungen&lt;br /&gt;
* [http://www.obdev.at/products/avrusb/avrdoper.html AVR-Doper] Einfach nachzubauender, STK500-kompatibler Programmer mit USB-Anschluss. Beherrscht auch HVSP, nicht jedoch HVPP. Open Source.&lt;br /&gt;
* [http://home.arcor.de/bernhard.michelis Amadeus-USB] - Highspeed-Programmer für PIC18, PIC24, dsPIC30, PIC32, dsPIC33 und AVR. Bietet auch Möglichkeiten zur Fehlersuche.&lt;br /&gt;
* [http://www.piketec.com/products/tpt.php Time Partition Testing (TPT)] - Test-, und Testauswertewerkzeug für eingebettete Systeme&lt;br /&gt;
* [http://shop.myavr.de/Programmer.htm?sp=artlist_kat.sp.php&amp;amp;katID=16 mySmartUSB] - USB Programmer (ab 15€) kombiniert auch mit USB-UART-Bridge, STK500v2/AVR910/AVR911 kompatibel, ISP HV-seriell, HV-parallel&lt;br /&gt;
* [http://www.myavr.de/download.php?suchwort=ProgTool myAVR ProgTool] nette Programmieroberfläche (free)&lt;br /&gt;
* [http://b9.com/elect/avr/kavrcalc/ KAVRCalc] is a free calculator to assist in programming AVR microcontrollers (Baudrate, Watchdog, Timer, ...)&lt;br /&gt;
* [http://www.chip45.com/CrispAVR-USB CrispAVR-USB] STK500 V2 kompatibler ISP Adapter mit USB Schnittstelle für Atmel AVR Mikrocontroller (1,8V-5,5V).&lt;br /&gt;
* [http://ucom-ir.nicai-systems.de UCOM-IR] - Programmieradapter mit USB Schnittstelle (AT90USB162) und IR-Sender/Empfänger, STK500 V2 kompatibel&lt;br /&gt;
* [http://www.anagate.de/products/programmers.htm AnaGate Programmer] Serielle Programmer mit LAN-Anschluss für I2C und SPI inkl. Programmier-API für Windows/Linux (Shop)&lt;br /&gt;
* [http://www.tinyos.net/ TinyOS] - Komponentenbasiertes Betriebssystem für Sensorknoten. Bringt eigene C-ähnliche Hochsprache nesC mit.&lt;br /&gt;
* [http://www.femtoos.org/ Femto OS] von  Ruud Vlaming ist ein preemptives Betriebssystem für die kleinsten Mikrocontroller aus der AVR Serie bis ca. 16 KB ROM und 1 KB RAM. Spezielle Targets sind: ATtiny861/461/261. Geschrieben in C. Freie Software, GPLv3. Artikel in Elektor Februar 2010 &lt;br /&gt;
* [http://www.projects-lab.com/?p=344 kaOS] is a real-time, multithreaded, preemptive operating system for the ATmega32 microcontroller, which loads and executes programs from a Secure Digital or MMC card. Authors Nicholas Clark &amp;amp; Adam Liechty. (Circuit Cellar AVR Wettbewerb 2006)&lt;br /&gt;
* [http://helium.sourceforge.net/ Helium] is a minimalistic real-time kernel for the HC(S)08 core by Freescale and Atmel AVR.&lt;br /&gt;
* [http://dev.bertos.org/ BeRTOS] is a completely free, open source, real time operating system (RTOS) suitable for embedded platforms. Runs on many microprocessors and microcontrollers, ranging from 8 bits to 32 bits CPUs and even PCs.&lt;br /&gt;
* [http://funkos.sourceforge.net/ funkos] Targets: AVR, XMEGA, MSP430, Cortex M3, Open Source&lt;br /&gt;
* Vergleich zwischen [http://antipastohw.blogspot.com/2009/11/4-operating-systems-for-arduino.html 4 Operating Systems for the Arduino] auf [http://antipastohw.blogspot.com Liquidware Antipasto]&lt;br /&gt;
** &#039;&#039;&#039;DuinOS&#039;&#039;&#039; by RobotGroup (FreeRTOS Portierung)&lt;br /&gt;
** [http://www.skewworks.com/pyxis/ Pyxis OS] by ArduinoWill&lt;br /&gt;
** &#039;&#039;&#039;ArduinoMacOS&#039;&#039;&#039; by Mark&lt;br /&gt;
** &#039;&#039;&#039;TaOS&#039;&#039;&#039; by Ziplock&lt;br /&gt;
* [http://atomthreads.com/ Atomthreads] is a free, lightweight, portable, real-time scheduler for embedded systems. (BSD Lizenz)&lt;br /&gt;
* [http://www.shift-right.com/xmk/ XMK] (eXtreme Minimal Kernel) ist ein freies Echtzeitbetriebssystem für Mikrocontroller (AVR, H8, R8C, M16C).&lt;br /&gt;
* [http://irtos.sourceforge.net/index.html.en iRTOS] is an free Real Time Operating System. The iRTOS kernel is free to download and use under the terms of LGPL. It can be used in commercial applications. iRTOS is designed for tiny 8 bit microconroller chips with little RAM usage. OS can be installed also in 16 and 32 bit processor units.&lt;br /&gt;
* [http://sites.google.com/site/cocoosorg/avr-projects/home cocoOS] is a cooperative task scheduler, based on coroutines and it is written in C. (STK500, Atmega16)&lt;br /&gt;
* [http://www.DieProjektseite.de BasicBeetle] Basic-Betriebssystem im AVR&lt;br /&gt;
* Shells für Arduino:&lt;br /&gt;
** [http://biot.com/arsh/ ARSH]&lt;br /&gt;
** [http://www.battledroids.net/downloads/avrsh.html AVRSH]&lt;br /&gt;
** [http://bitlash.net/wiki/start BITLASH]&lt;br /&gt;
** [http://sourceforge.net/projects/fruitshell/ FRUITSHELL]&lt;br /&gt;
** [http://www.gisvold.co.uk/~gisvold/drupal/node/1484 BREAKFAST]&lt;br /&gt;
* [http://nootropicdesign.com/toolduino/ toolduino] is a simple software tool that lets you easily interact with your Arduino hardware so you can test the circuits you create. Toolduino is written in the [http://processing.org/ Processing] languange and is available for Windows, Mac OS X, and Linux. Toolduino uses the the [http://www.arduino.cc/playground/Interfacing/Processing Arduino library for Processing] to communicate with an Arduino board so you can manipulate output pins and read inputs. The Arduino must be running the [http://firmata.org/wiki/Main_Page Firmata] firmware that comes with the Arduino IDE. (LGPL)&lt;br /&gt;
* [http://www.mueller-torres.de/avr.php MOPS] - A small C and Assembly based operating system for the ATMEL AVR® 8-Bit RISC controller family.&lt;br /&gt;
* [http://www.DieProjektseite.de Die Elektronik-Projektseite und Heimat des BasicBeetle] Hauptthema ist der BasicBeetle. Ein modularer, leistungsfähiger, in Basic programmierbarer Mikrorechner speziell für Steuerungen. Mit vielen Programmen, Tiipps und Tricks, Informationen...&lt;br /&gt;
* [http://www.Happy-Micro.de Happy-Micro.de] Die Internetsite für Hobbyelektroniker, Mikrocontroller-Anwender, Programmierer und alle, die Spaß an Computern und Elektronik haben. Bei Happy-Micro.de steht der Spaß am Entwickeln von Programmen und Schaltungen im Vordergrund. Jeder Benutzer hat die Möglichkeit auch als Autor mitzumachen und seine Schaltungen oder Programme zu veröffentlichen. Freier Bilderdownload für die eigene Homepage. &#039;&#039;(Seite wurde geschlossen!)&#039;&#039;&lt;br /&gt;
* [http://iwenzo.de Elektronik und Informationen] Wissenswertes aus der Unterhaltungselektronik..&lt;br /&gt;
* [http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/ Cornell University ECE 476 Microcontroller Design Final Projects] &lt;br /&gt;
* [http://home.planet.nl/~meurs274/ AVRmicrocontrollerprojects] u.a. Text-LCD, Schrittmotor, Thermometer &#039;&#039;(Seite existiert nicht mehr/ Error 404)&#039;&#039;&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects  M. Thomas&#039; AVR Projekte] untern Anderem AVR Butterfly avr-gcc-port, DB101 gcc-port, BC100 gcc-port, Bootloader, Programmier- und Debughardware, Software-UART, DS1820-Lib., experimentelle avrdude-Versionen, AVR und CAN mit MCP2515 &amp;lt;!-- Vorsicht &amp;quot;Eigenwerbung&amp;quot; --&amp;gt;&lt;br /&gt;
* [http://www.avr-projekte.de AVR-Projekte.de] Belichtungstimer, FT232RL Schaltungen,LED-Fading über Fernbedienung, HD44780-LCD über USB und Seriell, AVR910-USB Programmer, Basteleien: Ätzmaschine,Kompressor.&lt;br /&gt;
* [http://openeeg.sourceforge.net/ openeeg.sourceforge.net] Das OpenEEG Projekt befasst sich mit der Entwicklung eines preiswerten Elektro-Enzephalographie (EEG) Geräts und dessen freier Steuersoftware zur Messung elektrischer Gehirnströme. Sein µPC-Herz ist ein AT90S4433 bzw. ein ATmega8. Ziel sind auch verschiedene EEG Anwendungen z.&amp;amp;nbsp;B. im Bereich mentaler Trainingsmethoden (Neurofeedback).&lt;br /&gt;
* [http://www.loetstelle.net www.loetstelle.net] Verschiedene kleinere AVR-Projekte rund um LEDs, z.&amp;amp;nbsp;B. RGB Dimmer, Moodlight. Diverse Elektronikprojekte und Grundlagen&lt;br /&gt;
* [http://www.avrguide.com/ AVR Projektsammlung] bei www.avrguide.com&lt;br /&gt;
* [http://freenet-homepage.de/wedis-bastelecke/ Wedis-Bastelecke] - Modellbahn DCC-Servo-Zubehördecoder DCC Servo Decoder mit ATmega8 / Servo Differenzierbaugruppe für Modellbau&lt;br /&gt;
* http://www.electronicspit.com - Verschiedene Elektronikprojekte (LED-Matrix, PAL-Video)&lt;br /&gt;
* http://web.archive.org/web/20050415222337/http://www.hebel23.de/ RDS RADIO: ATMega32, TEA5757, T6963C, TDA7330B in C&lt;br /&gt;
* [http://www.gasenzer.dk Analog/Digital and MPU Eletronic Projects] PAL/VGA Terminal, CallerID, Ethernet, Wireless Bridge, LPC2214, AT91RM9200, Sony Unilink Controlled Wireless MP3 Player.&lt;br /&gt;
* [http://www.circuitcellar.com/avr2006/ Circuit Cellar AVR Design Contest 2006] mit Projektbeschreibungen&lt;br /&gt;
* [http://www.heesch.net/microcontroller.aspx/ Homepage von Stefan Heesch] - AVR Mikrokontroller Projekte, z.B. WLAN und AVR, netzwerkgesteuertes RGB Licht, IDE-Interface, DS1821 Thermometer, Morse-Dekoder u.a.&lt;br /&gt;
* [http://avrprojekte.de/] Viele Projekte mit LEDs(LED-Matrixen) und AVRs&lt;br /&gt;
* [http://arduino.milkcrate.com.au/ little-scale&#039;s arduino page]&lt;br /&gt;
* [http://www.sebastianweidmann.de www.sebastianweidmann.de] Grundlagen zum Thema Platinen ätzen, Bohren, Durchkontaktierungen und Projekte Tipps/Tricks mit Atmel AVR Microcontrollern&lt;br /&gt;
*[http://www.jtronics.de/elektronik-avr.html Junghans Electronic Page] u.a Nokia 3310 LCD Ansteuerung in &amp;quot;C&amp;quot;(aktualisiert 2010), TWI/USI, Quadcopter&lt;br /&gt;
* [http://www.familie-finke.com/ http://www.familie-finke.com/] Die Website von Thomas Finke mit diversen Elektronikprojekten, wie z.B. STK-LAN (AVR im Netzwerk mit HTTPD, SNMP,...), UV-LED-Belichter, HPGL-Plotter.&lt;br /&gt;
*[http://www.funktermin.de Funkuhr FT1] Funkuhr mit programmierbaren Terminkalender, Kalenderwochenanzeige und optischen Stundenschlag (Anzeige der empfangenen Daten vom Zeitzeichensender DCF77)&lt;br /&gt;
* [http://phil-zone.de/ Philips Projektsammlung] Elektronik Projekte (µC,CMOS,Analog,...), Tutorials und nützliche Online-Tools&lt;br /&gt;
==== Schnittstellen ====&lt;br /&gt;
===== TCP/IP =====&lt;br /&gt;
* Kostengünstige und schnelle WLAN Anbindung an Mikrocontroller mit Wiz610wi. Bezugsquelle inkl. praktischer Adapterplatine bei: [http://www.shop.display3000.com/elektronikmodule/ethernet-wlan/index.html Display3000]&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/eNet-sam7X.php eNet-sam7X] Embedded Ethernet Modul im DIL64 Format mit kompletten OpenSource Board Support Packake auf Ethernut / Nut/OS Basis. Industrie geeignet&lt;br /&gt;
* [http://www.ethersex.de/index.php/Feature_Liste Ethersex] - Trotz des bescheuerten Namens sehr empfehlenswert. Viele flexibel einbindbare Module für diverse Hardware.&lt;br /&gt;
* [http://wiki.neo-guerillaz.de OpenMCP] Bekanntes Board auf Basis des ATmega2561 und ENC28j60. Läuft auch auf dem AVR-NETIO und dem myAVR.&lt;br /&gt;
* http://www.circuitcellar.com/AVR2006/winners/DE/AT2581.htm MEGA128(CAN) PCMCIA&lt;br /&gt;
* [https://berlin.ccc.de/wiki/AVR-Board_mit_Ethernet AVR-Board mit Ethernet mit dem ENC28J60 von Microchip]&lt;br /&gt;
* [http://www.roland-riegel.de/mega-eth/ AVR-Ethernet-Board mit extra SRAM, SD/MMC, USB und zugehöriger Software]&lt;br /&gt;
===== CAN =====&lt;br /&gt;
* [http://www.edevices.lt/  www.edevices.lt ] - USB2CAN inexpensive USB to CAN bus converter&lt;br /&gt;
===== USB =====&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php eUSB-162 und eUSB-LCD] - At90USB162 basiertes universelles USB Prototypen / Mikrocontroller Modul und USB Terminal Interface für HD44780 kompatible LCDs auf Basis der Lufa Library&lt;br /&gt;
* [http://www.obdev.at/products/vusb/index-de.html V-USB] &amp;amp;#8211; USB-Implementation in C nach gleichem Prinzip wie Igor-Plug, aber einfacher zu verwenden, GPL-ähnliche Lizenz (Nutzung des Projekts &#039;&#039;erfordert&#039;&#039; Veröffentlichung), englisch kommentierter Code&lt;br /&gt;
* [http://www.eltima.com/products/usb-over-ethernet/ USB to Ehternet Connector] - Share your USB devices via LAN/Internet&lt;br /&gt;
* [http://www.rahand.eu Mega8D12] - Schritt für Schritt zum virtuellen COM-Port. Ein Einsteiger-Tutorial zur CDC-Klasse mit Schaltung und Firmware (ATmega8 und PDIUSBD12).&lt;br /&gt;
* http://www.maares.de/tools USB_ISO: Isolierter Schnittstellenwandler USB auf RS232 (TTL) mit FT232RL und ADUM1402. Galvanische Trennung für das Zielsystem.&lt;br /&gt;
* [http://www.embedded24.net USB HID Host Treiber] - USB HID Treiber Bibliothek für Windows (Demo Projekt für Visual Studio C++).&lt;br /&gt;
* [http://Dworkin-DMX.de Konverter RS232 zum DMX512] Steuerung DMX-fähigen Geräten mit einem PC. Es gibt Low cost Variante zum selber basteln.&lt;br /&gt;
* [http://www.hoelscher-hi.de/hendrik/light/profile.htm Hennes Sites] Bauanleitungen für DMX-Dimmerpacks, DMX-Switchpacks, PWM-Controller, ... Tutorial für Senden und Empfangen von DMX-Daten mit AVRs.&lt;br /&gt;
* [http://digital-enlightenment.de Digital Enlightenment ]Verschiedene DMX-Selbstbauprojekte&lt;br /&gt;
===== PS2 =====&lt;br /&gt;
===== LANC =====&lt;br /&gt;
* [http://dsc.ijs.si/3dlancmaster/ 3D LANC Master from Damir Vrancic] is a device which keeps in synchronisation some of Sony camcorders by using LANC (CONTROL-L, ACC) protocol. (Open Hardware + Open Source, Atmega8).&lt;br /&gt;
* [http://jochendony.homeip.net/content/view/22/26/ LANC Lib] for AVRGCC. Read and write LANC commands.&lt;br /&gt;
* [http://blog.makezine.com/archive/2008/12/controlling_sony_camcorders_with_th.html Controlling Sony camcorders with the Arduino]&lt;br /&gt;
* http://arm.hsz-t.ch MMC, SD, SDHC Kartentreiber für ARM7 Mikrocontroller&lt;br /&gt;
* [http://www.mikrocontroller.net/articles/FAT32 Wiki und FAT16/32 Bibliothek für atmega]&lt;br /&gt;
===== Text (character-mode) HD44870 =====&lt;br /&gt;
* Bray&lt;br /&gt;
* [http://www.simon-brenner.ch/projekte/lcd-display 4x40 LCD Projekt, Microchip]&lt;br /&gt;
* [http://www.tklinux.de/sed1330.html SED1330 an ATMega]. Library für SED 1330 controller an ATmega&lt;br /&gt;
===== Siemens S55/C60 =====&lt;br /&gt;
* [http://www.module.ro/siemens_lcd.html S55-Display Pinbelegung]&lt;br /&gt;
* [http://www.mikrocontroller.net/topic/22643 Forumbeitrag]&lt;br /&gt;
* [http://www.jtronics.de/elektronik-avr/lcd-display-nokia3310 Bibliothek für Nokia 3310 Lcd Ansteuerung in &amp;quot;C&amp;quot; von http://www.jtronics.de - sehr gut (aktualisiert 2010)]&lt;br /&gt;
* [http://www.myplace.nu/mp3/download/download.php Yampp 7 Software Download Seite]: Archiv &amp;quot;yampp-7 with colour LCD firmware&amp;quot; enthält avr-gcc/avr-as Routinen für 6100-LCDs mit Philips- oder Epson-Controller (nicht direkt eine &amp;quot;Library&amp;quot;)&lt;br /&gt;
* avrfreaks UP&lt;br /&gt;
* [http://pic-projekte.de/index.php/ks01078.html PIC-Projekte.de] Ansteuern eines KS0107/8 Controllers in ASM mit PIC&lt;br /&gt;
====GPS====&lt;br /&gt;
* [http://mcu8051ide.sourceforge.net/ MCU 8051 IDE] - MCU 8051 IDE is a new modern graphical IDE for microcontrollers based on 8051. MCU 8051 IDE is noncommercial open-source software for Linux.&lt;br /&gt;
* [http://www.rakers.de/catalog Dr. Rakers] Entwicklungssystem mit C-Compiler, BASIC-Compiler und Makroassembler für alle 8051-Mikrocontroller (80C552, 80C515(C), 80C537). Auch für Hobbyisten bezahlbar.&lt;br /&gt;
* [http://www.maxim.ph.tc Selbstbau-Programmer] für 2051er&lt;br /&gt;
* [http://home.t-online.de/home/s.holst/sh51/index.html Mikrokontroller sh51] Schaltplan für 80C535-Board&lt;br /&gt;
* [http://turbo51.com Turbo51 - Free Pascal compiler for 8051]&lt;br /&gt;
* [http://self8051.de/ self8051.de] - Dein Nachschlagewerk - Befehlsreferenz, Eigenschaften, Derivate&lt;br /&gt;
* [http://cmon51.sourceforge.net/ CMON51] - freier Onboard Monitor und Debugger, anpassbar an unterschiedliche 8051 kompatible Mikrocontroller&lt;br /&gt;
== MSP430 ==&lt;br /&gt;
* [http://www.mikekohn.net/micro/naken430asm_msp430_assembler.php naken430msp] -   MSP430 Assembler von Michael Kohn (GPL)&lt;br /&gt;
* TI Design-Wettbewerb: http://www.designmsp430.com/View.aspx (Dateien liegen evtl. in /projects/) [2011-01-24: redirect zum TI Wiki, Projekte nicht mehr vorhanden]&lt;br /&gt;
* [http://www.sics.se/project/mspsim MSPsim] - a Java-based simulator of MSP430 sensor network platforms (BSD License (revised))&lt;br /&gt;
* [http://develissimo.net/de/msp430entwicklung MSPGCC + Eclipse + msp430-gdbproxy / Linux / Debian / Ubuntu] - Anleitung / Tutorial zur Installation der MSPGCC Toolchain + Eclipse + msp430-gdbproxy für Linux / Debian / Ubuntu Lang=Deutsch und Englisch&lt;br /&gt;
* [http://travisgoodspeed.blogspot.com/ Travis Goodspeed&#039;s Blog] - Home of the [http://goodfet.sourceforge.net/ GoodFET] Programmer&lt;br /&gt;
* [http://www.43oh.com/ Four-Three-Oh!]&lt;br /&gt;
=== MSP430 Launchpad ===&lt;br /&gt;
* [http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_(MSP-EXP430G2)?DCMP=launchpad&amp;amp;HQS=Other+OT+launchpadwiki MSP430 LaunchPad Wiki] bei TI&lt;br /&gt;
* [http://hackaday.com/2010/08/11/how-to-launchpad-programming-with-linux/ How-to: Launchpad programming with Linux] auf hackaday.com&lt;br /&gt;
* [http://springuin.nl/en/articles/launchpadwindows TI Launchpad programming and debugging with Open Source tools on Windows] (Eclipse, MSPGCC4, Insight, msp430-gdbproxy)&lt;br /&gt;
=== EZ430 Chronos ===&lt;br /&gt;
* [http://processors.wiki.ti.com/index.php/EZ430-Chronos?DCMP=Chronos&amp;amp;HQS=Other+OT+chronoswiki EZ Chronos Wiki] bei TI&lt;br /&gt;
== ARM ==&lt;br /&gt;
* [http://www.energymicro.com/ Energy Micro] EFM32 mit Cortex M3 Kern&lt;br /&gt;
* [http://www.intel.com/design/intelxscale/ Intel XSCALE Startseite], siehe auch [http://www.marvell.com/ Marvell]&lt;br /&gt;
* [http://www.luminarymicro.com/ Luminiary Micro (TI)] Controller mit Cortex M3 core&lt;br /&gt;
* [http://www.standardics.nxp.com/microcontrollers/ NXP (ehemals Philips) Microcontroller Startseite] für sämtliche Mikrocontroller (ARM7, ARM9, Cortex-M0, -M3, MCS51 etc.), neben LPC2000, LPC3000 auch die LH7xxxx BlueStreak-Serie (ehemals Sharp Microelectronics)&lt;br /&gt;
* [http://www.lpc2000.com lpc2000.com] Infoseite für NXP (ex. Philips) LPC1700 Cortex-M3 basierende Typen, LPC2000, ARM7 basierende Typen und LPC3000, ARM9 basierende Typen. Auch andere Cortex-M3 Bausteine sind erfasst&lt;br /&gt;
* [http://mcu.st.com/mcu/ STMicroelectronics (ST) Microcontroller Startseite] u.a. STR7, STR9, STM32 Support-Forum&lt;br /&gt;
* [http://www.toshiba.com/taec/ Toshiba] Controller mit ARM9 und Cortex-M3 core&lt;br /&gt;
* [http://arm.hsz-t.ch arm.hsz-t.ch] Einfühung in ARM7 Mikrocontroller und uClinux.&lt;br /&gt;
* [http://tech.groups.yahoo.com/group/ADuC7000/ ADuC7000 Yahoo-Group]&lt;br /&gt;
* [http://www.codesourcery.com/archives/arm-gnu/maillist.html Sourcery G++ Lite Edition User Forum/Mailing-List]&lt;br /&gt;
* [http://www.keil.com/forum/ Keil/ARM Forum]&lt;br /&gt;
* [http://www.mcu-related.com MCU related] Neuigkeiten zu MCUs, überwiegend ARM / Cortex-M3 basierend mit Vergleichen von RTOS und anderen Entwicklungstools&lt;br /&gt;
* [http://forum.sparkfun.com/ Sparkfun Foren]&lt;br /&gt;
* [http://www.stm32circle.com/ Forum for STM32 moderated by Raisonance] Sehr viele Beispielprogramme in Source fuer STM32 und den Primer2 von Raisonance&lt;br /&gt;
* [http://www.st-angliamicro.com/software.asp Anglia Idealist IDE und Anglia Toolchain] GNU toolchain für Win32-hosts inkl. Beispielen für STR7, STR9 und STM32. IDE kostenlost aber registrierungspflichtig&lt;br /&gt;
* [http://atollic.com/ attolic] TrueSTUDIO&lt;br /&gt;
* [http://www.codesourcery.com/gnu_toolchains/ Codesourcery] GNU Toolchains für ARM (Hosts: Linux, MS Windows, Solaris; Targets: arm-elf, arm-linux, SybianOS)&lt;br /&gt;
* [http://devkitpro.org/ devkitPro/devkitARM] GNU-Toolchain für MS-Windows &amp;quot;Hosts&amp;quot;. Vor allem auf GBA abgestimmt aber auch für andere ARM-Controller geeignet (arm-elf)&lt;br /&gt;
* [http://www.hitex.de Hitex] IDE für diverse Compiler, Debugger&lt;br /&gt;
* [http://www.keil.com Keil/ARM RVDK/uVision] kommerzielle IDE/Compiler, unterstützt zwei Compiler (ARM RealView, GNU/gcc), codegrößenbeschränkte Evaluierungsversion verfügbar (IDE/Compiler unbeschränkt für GNU), guter Debugger, guter Simulator (teilw. mit Hardwaresimulation) Simulator und Debugger in der Evaluierungsversion auch bei Nutzung der GNU-Toolchain auf 16kB beschränkt&lt;br /&gt;
* [http://mct.de/download.html#free MCT Demoversion C-Compiler für ARM und 68k] ARM C-Compiler basiert auf GCC laut Herstellerinformation jedoch mit Codegrößenbeschränkung &amp;lt;!-- etwas ungewöhnlich: Codegrößenbeschränkung bei GNU-Toolchain --&amp;gt;&lt;br /&gt;
* [http://www.raisonance.com/ Raisonance] Ride, RKit-ARM&lt;br /&gt;
* [http://www.yagarto.de Yagarto] GNU arm-elf-Toolchain, Eclipse, OpenOCD für Win32 inkl. Setup&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index.html#winarm WinARM] eine an WinAVR angelehnte Sammlung von Entwicklungswerkzeugen (binutils, arm-elf-gcc, newlib, &#039;&#039;newlib-lpc&#039;&#039;, Programmers Notepad, &#039;&#039;Beispiel-Makefiles und Beispielcode&#039;&#039;) für alle ARM-Controller. Beispiele für Philips LPC2000 und Atmel AT91SAM7S (ARM7TDMI) u.a.&lt;br /&gt;
* [http://rtlab.tekproj.bth.se/wiki/index.php/Dissy#Architecture_support Dissy] is a disassembler for Linux and UNIX which supports multiple architectures and allows easy navigation through the code. Dissy is implemented in Python and uses objdump for disassembling files.&lt;br /&gt;
* [http://www.sinelabore.com sinelaboreRT] - generiert leicht lesbaren C-Code aus einer Zustandsmaschine. Die Generierung berücksichtig speziell die Bedürfnisse eingebetteter Echtzeitsysteme.&lt;br /&gt;
* http://arm.hsz-t.ch Entwicklungsumgebung für ARM7 Mikrocontroller basierend auf der Knoppix CD. Keine Harddisk installation nötig für uClinux.&lt;br /&gt;
* [http://openocd.berlios.de/web/ OpenOCD] Open On-Chip Debugger: Schnittstelle (&amp;quot;gdb-Server&amp;quot;) zwischen Wiggler-komaptiblem JTAG-Interface und GNU-debugger (gdb/Insight-gdb), ebenfalls Unterstützung für JTAG-Hardware auf FTDI2232-Basis, Flash-Programmierfunktion für LPC2k, AT91SAM7S u.a.&lt;br /&gt;
* [http://www.hjtag.com H-JTAG] RDI-Interface für Wiggler, Flash-Funktionen für diverse interne und externe Speicher&lt;br /&gt;
*[http://www.abatron.ch Abatron] BDI1000 &amp;amp; BDI2000, On-Chip Debuggers für ARM, 68k, Coldfire uvm.&lt;br /&gt;
* [http://www.amontec.com Amontec] JTAGkey, JTAGkey2(P): JTAG-Adapter auf Basis des FTDI2232(H) &lt;br /&gt;
* [http://www.hjtag.com/product_intro.html H-JTAG USB Emulator]&lt;br /&gt;
* [http://www.keil.com Keil/ARM ULINK/ULINK2/ULINK-ME] JTAG-Adapter, USB-Anschluss, wird von Keil uVision unterstützt, ULINK2 teilw. auch von Codesourcery G++ (lt. Hestellerangaben)&lt;br /&gt;
* [http://www.ronetix.at/peedi.html Ronetix Peedi]&lt;br /&gt;
* [http://www.segger.de Segger J-Link] JTAG-Adapter, USB-Anschluss, unterstützt z.&amp;amp;nbsp;B. von IAR, Keil uVision (via RDI) (OEM: IAR J-Link, SAM-ICE)&lt;br /&gt;
* [http://www.signalyzer.com/ Signalyzer] Signalyzer Tool, u.a. JTAG-Adapter auf Basis des FTDI2232&lt;br /&gt;
* [http://www.simonqian.com/en/Versaloon/index.html Simon Qians Versaloon]&lt;br /&gt;
* [http://patater.com/gbaguy/gbaasm.htm GBA ASM Tutorial] - ARM7 Assembler Tutorial mit arm-elf-as (&amp;quot;gcc&amp;quot;) (Allgemein und GBA)&lt;br /&gt;
* [http://www.sparkfun.com/datasheets/DevTools/SAM7/at91sam7%20serial%20communications.pdf AT91SAM7 Serial Communications] von James P. Lynch (PDF, www.sparkfun.com)&lt;br /&gt;
* [http://www.kaczurba.pl/aduc ADuC7000 Tutorial] von Witold Kaczurba (www.kaczurba.pl)&lt;br /&gt;
* [http://www.stromflo.de/dokuwiki/doku.php?id=xmega-c-tutorial XMEGA-C-Tutorial]&lt;br /&gt;
* [http://hubbard.engr.scu.edu/embedded/arm/armlib/ Procyon ARMlib-LPC2100] - Treiber, Beispiele (Lizenz: GPL, kaum weiterentwickelt)&lt;br /&gt;
* [http://www.standardics.nxp.com/support/documents/?type=software NXP BlueStreak] Code für LH7xxxx (ehemals Sharp)&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index.html M. Thomas&#039; ARM Projekte] &amp;quot;Projectvorlagen&amp;quot; für AT91SAM7 und LPC2000 mit GNU-Toolchain Einsteiger-Projekte für AT91SAM7, LPC2000, ADuC7000 u.a. (u.a. Blinky, UART, Interrupt, C++, GLCD mit KS0108, DS18x20, DCF77, Anpassungen von FAT16/32-Libraries) &amp;lt;!-- noch mehr &amp;quot;Eigenwerbung&amp;quot; --&amp;gt;&lt;br /&gt;
* [http://mcu.st.com/ STMicro] Treiber und Beispiel für STR7, STR9 und STM32&lt;br /&gt;
* [http://www.luminarymicro.com/ Luminary Micro Driverlib] für Stellaris Cortex-M3&lt;br /&gt;
* [http://r2d2.stefanm.com/gps-tracker.html GPS-Tracker] mit Navigation auf LPC2103-Basis (Complier: GCC)&lt;br /&gt;
* [http://elua.berlios.de elua] Lua für ARM-controller&lt;br /&gt;
* [http://freemodbus.berlios.de/ FreeMODBUS] &amp;quot;A Modbus ASCII/RTU and TCP implementation&amp;quot; (für STR71x, AT91SAM7, LPC214x, auch: AVR, MSP430 u.a.)&lt;br /&gt;
* [http://bettyhacks.com BettyHacks] Freie Firmware für die &amp;quot;interaktive TV-Fernbedienung&amp;quot; betty-tv (ARM7tdmi, 2MB Flash, 160 x 128 Pixel 2 bit LCD, CC1100, IR, Lautsprecher,..)&lt;br /&gt;
* [http://www.bertos.org/ BeRTOS] is a completely free, open source, real time operating system (RTOS) suitable for embedded platforms. Runs on many microprocessors and microcontrollers, ranging from 8 bits to 32 bits CPUs and even PCs. &lt;br /&gt;
* [http://chibios.sourceforge.net/ ChibiOS/RT]&lt;br /&gt;
* [http://www.stm32circle.com/resources/upgrade.php Circle-OS for STM32] Kostenloses OS, sehr klein mit Basisfunktionen fuer STM32&lt;br /&gt;
* [http://coocox.org/ CoOS]&lt;br /&gt;
* [http://www.freertos.org/ FreeRTOS (.org!)] - &amp;quot;Real-Time-Kernel&amp;quot; unter anderem für ARM7 (LPC2xxx) auch AVR, MSP430, &#039;51er&lt;br /&gt;
* [http://sourceforge.net/projects/funkos/ FunkOS]&lt;br /&gt;
* [http://www.toradex.com/colibri_downloads/Linux/readme.txt Linux 2.4.29 für Toradex Colibri] basierend auf Intel XScale PXA270&lt;br /&gt;
* [http://www.linux4sam.org Linux4SAM] Informationen, Anleitungen und Code zur Anwendung von Linux auf AT91SAM9xxx&lt;br /&gt;
* [http://www.freertos.com/ NicheTask] (URL ist www.freertos.com aber hat nichts mit FreeRTOS(.org) zu tun)&lt;br /&gt;
* [http://www.ethernut.de/en/software/index.html Nut/OS] Echtzeitbetriebssystem für Mikrocontroller (ARM, AVR, AVR32, Cortex M3 u.A). Multitasking und vollständiger TCP/IP Stack inklusive. Leicht zu erlernen und viele Beispiele&lt;br /&gt;
* [http://nuttx.sourceforge.net/ NuttX RTOS] (ARM7TDMI port for TI TMS320C5471 also called a C5471 or TMS320DM180).&lt;br /&gt;
* [http://code.google.com/p/rt-thread/ rt-thread]&lt;br /&gt;
* [http://sourceforge.net/projects/scmrtos/ scmRTOS]&lt;br /&gt;
* [http://www.tnkernel.com/downloads.html TNKernel] - &amp;quot;Real-Time-Kernel&amp;quot; TNKernel ist ein kompakter und sehr schneller Echtzeitkernel unter anderem für ARM7 (Philips LPC2106/LPC21XX/LPC22xx, Samsung S3C44B0X, Atmel AT91SAM7S128, STMicroelectronics STR711FR2)&lt;br /&gt;
* [http://www.knif-elektronik.de/index.php/cPath/27/category/industrie-module-/-bausaetze.html/ KNIF-elektronik] Preisgünstige Industriemodule und Bausätze z.B GPS, W-Lan, Kamera,Bluetooth uvm. --&amp;gt;&lt;br /&gt;
&amp;lt;!-- Ist KEIN ARM-Board, falsche Rubrik! * [http://www.chip45.com/ chip45] Atmel AVR Module und Boards mit USB, RS232/485, CAN, Ethernet, Funkmodule, sowie ISP Programmieradapter --&amp;gt;&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php Embedded-IT] eNet-sam7X: Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem sowie USB Module auf AVR Basis&lt;br /&gt;
* [http://www.mcu-raisonance.com/~primer-starter-kits__microcontrollers__tool~tool__T018:4enfvamuxbtp.html Primer2 from Raisonance] Focus auf STM32 mit sehr grossem Forum im STM32circle&lt;br /&gt;
* [http://www.skpang.co.uk/catalog/index.php SKPang electronics] Entwicklungsboards für diverse ARM7/9 (UK)&lt;br /&gt;
* [http://www.taskit.de taskit] [https://www.ledato.de/shop_content.php?coID=10 Development- und Header-Boards für AT91SAM7S/X], AT91RM9200, AT91SAM9&lt;br /&gt;
* [http://www.toradex.com/e/products.html Toradex] Colibri: Intel XScale PXA270 DevKit (Schweiz)&lt;br /&gt;
== [[PIC]] ==&lt;br /&gt;
* [http://www.powercontact.de Elektronikentwicklung von Systemtechnik LEBER] Offizieller Microchip Design Partner für professionelles Microcontroller Design und Hersteller von Leistungsstellern, Thyristorstellern und Halbleiterelais...&lt;br /&gt;
* [http://www.osterer.co.at www.osterer.co.at] Entwicklungs-Board mit integrierten Programmer/Debugger für PIC18F4550.&lt;br /&gt;
* [http://www.martins-elektronikwelt.tk www.martins-elektronikwelt.tk] ICD1-Debugger-Nachbau im Kleinstformat u. SMD Technik (so groß wie eine halbe Scheckkarte).&lt;br /&gt;
* [http://pic-projekte.de/ PIC-Projekte.de] Sehr gut geschriebene Tutorials und Projekte mit erklärten Codesnipseln. Besonders geeignet für Anfänger!&lt;br /&gt;
* [http://www.fernando-heitor.de PIC: Programmierung in CCS (www.fernando-heitor.de)] Dies ist eine weitere Seite die dem Anfänger, der sich mit PICs beschäftigt, auf die Beine hilft. Sie befasst sich hauptsächlich mit dem CCS-Compiler und hat dazu ein sehr gutes Tutorial. Ausserdem bietet die Seite ein Forum speziell für PIC Mikrocontroller.&lt;br /&gt;
* [http://www.cc5x.de CC5X] Programmierkurs für PIC-Mikrocontroller in C (CC5X Compiler)] Programmierkurs mit Beispielen und Schaltplänen, fertige Hardware- und Softwarelösungen. In diesem Kurs sind auch einige Unterprogramme detailliert erklärt.&lt;br /&gt;
* [http://members.aon.at/electronics/pic/picpgm/index.html PICPgm - A free and simple PIC Development Programmer Software for Windows and Linux] Einfacher PIC Programmer für Windows und Linux. Unterstützt eine Vielzahl von PIC-Chips und wird ständig erweitert. Derzeit können PIC10F, PIC12F, PIC16F, PIC18F, PIC24H  sowie dsPIC30F und dsPIC33F programmiert werden.&lt;br /&gt;
* [http://usbpicprog.org/ usbpicprog], an open source Microchip PIC programmer for the USB port. A wxWidgets based (cross platform) application to communicate with the usbpicprog hardware / firmware. This application is known to function well on Linux, Windows (XP or later) and Macosx.&lt;br /&gt;
* [http://www.uchobby.com/index.php/2008/04/19/pic-development-linux-style/ How to setup for PIC microcontroller development on Linux] von Steven Moughan&lt;br /&gt;
* [http://www.dattalo.com/gnupic/gpsim.html#docs gpsim] is a full-featured software simulator for Microchip PIC microcontrollers distributed under the GNU General Public License.&lt;br /&gt;
* [http://www.mtoussaint.de/yapide.html YaPIDE] aims to be a fully featured Microchip PIC simulator for Linux (and probably other UNIXes). YaPIDE is a GUI only application. If you need a commandline based PIC simulator there is the excellent &#039;&#039;&#039;gpsim&#039;&#039;&#039;. The simulator kernel currently supports the PIC 16F628.&lt;br /&gt;
* [http://piklab.sourceforge.net/ Piklab] is an integrated development environment for applications based on Microchip PIC and dsPIC microcontrollers similar to the MPLAB environment. It integrates with several compiler and assembler toolchains (like gputils, sdcc, c18) and with the simulator &#039;&#039;&#039;gpsim&#039;&#039;&#039;. It supports the most common programmers (serial, parallel, ICD2, Pickit2, PicStart+) and debuggers (ICD2).&lt;br /&gt;
* [http://dev.frozeneskimo.com/software_projects:vpicdisasm vPICdisasm] is a Microchip PIC Mid-Range family firmware disassembler. This single-pass disassembler can read Intel HEX and Motorola S-Record formatted files containing valid PIC firmware. (GPL)&lt;br /&gt;
* [http://pikdev.free.fr/ PiKdev] is a simple graphic IDE for the development of PIC-based applications. It currently supports assembly language. C language is also supported for PIC 18 devices. PiKdev is developed in C++ under Linux and is based on the KDE environment.&lt;br /&gt;
* [http://www.yenka.com/en/Yenka_PICs/ Yenka PICs] lets you write routines using simple flowcharts, and test them on-screen, before using them to program real PIC or PICAXE chips. To help spread the news about Yenka, we&#039;re offering free copies of Yenka PICs for use at home or school.&lt;br /&gt;
* [http://pic-projekte.de/phpBB3/ Das deutsche PIC Forum] Diskutieren Sie mit anderen über PIC und stellen Sie Fragen zu Ihren Problemen. Das deutschsprachige PIC-Forum&lt;br /&gt;
* [http://gcbasic.sourceforge.net/ Great Cow BASIC] &amp;quot;Open Source BASIC programming tools for Microchip PIC and Atmel AVR microcontrollers&amp;quot;&lt;br /&gt;
* [http://www.martins-elektronikwelt.tk www.martins-elektronikwelt.tk] Viele Projekte mit den PIC Mikrocontrollern, u.a. SMS-Schaltzentrale, SD/MMC-FAT32-MP3-Player, Lichtschranken, Funk-Wetterempfänger, PS/2 am PIC usw.&lt;br /&gt;
* [http://www.Firmware-On-Demand.com Firmware-On-Demand] Umfangreiche Firmware-Bibliothek. &lt;br /&gt;
* [http://www.circuitcellar.com/microchip2007/ Microchip 16-Bit Embedded Control 2007 Design Contest] bei [http://www.circuitcellar.com/ Circuit cellar]&lt;br /&gt;
* [http://mondo-technology.com/ Mondo Technologiy] Grosse Ansammlung von PIC-Projekten, u.a. SuperProbe: Logic Probe,(Auf der linken Seite ganz oben) Logic pulser, Frequency Counter, Event Counter, Voltmeter, Diode Junction Voltage, Capacitance Measurement, Inductance Measurement, Signal Generator, Video Patern, Serial Ascii, Midi Note, R/C Servo, Square Wave, Pseudo Random Number, ir38, PWM in einem... (PIC16F870)&lt;br /&gt;
* [http://micrognurtos.sourceforge.net uGNU/RTOS] is a microcontroller-targeted serial real time operating system. It has been ported to USART capable Microchip PIC16 devices. It supports I/O operations and some internal registry operations. The user can interact with the chip through the RS-232 serial cable and a shell. The user can type a small list of commands and see the results on the chip&#039;s outputs. (LGPL)&lt;br /&gt;
* [http://pic-projekte.de www.PIC-Projekte.de] Hier finden sich einige interessante Projekte mit PIC Mikrocontrollern (z.B. Anleitung zum Ansteuern eines HD44780 komp. LCD von eA, KS0107/8 ansteuern in ASM) sowie Erklärungen zu den dazugehörigen Programmabschnitten. Außerdem gibt es eine Anleitung zum Herrstellen von Platinen. Besuchen Sie das [http://pic-projekte.de/phpBB3/index.php PIC-Forum] und diskutieren Sie mit bei spannenden Themen. Wenn Sie Fragen zu PIC µC der Firma Micochip haben, dann sind Sie hier richtig aufgehoben!&lt;br /&gt;
* [http://pic16f628a.blogspot.com/ Experiments with PIC16F628A] - PIC Programming in C&lt;br /&gt;
&amp;lt;!-- * [http://www.picguide.org PIC Guide] Eine große Sammlung von PIC-Projekten für den Anfänger 6.9.2010: nur cPanel Standard Seite --&amp;gt;&lt;br /&gt;
*Stevy&#039;s Homepage http://stevy.bplaced.com Pic Projekte die in C geschriebn wurden z.B 3D Engine, Grafik Display Ansteuerungen, Oszilloskip usw&lt;br /&gt;
* [http://www.simon-brenner.ch/projekte/rgb-led-stripe RGB Stripe mit 16bit Bus, realisiert mit PIC12F629]&lt;br /&gt;
* [http://scifi.pages.at/drakesoft/aulem_mypong/ Spiel PONG] auf einer 16x16 LED Matrix mit Ton, realisiert auf einem AVR.&lt;br /&gt;
== [[Z8]] ==&lt;br /&gt;
* [[Zilog Encore Experimentierplatine]] (Z8F6421 Familie mit DIP-40 Gehäuse)&lt;br /&gt;
*[http://www.thpeter.net Zilog Projekte] (Ein Z8Encore und ZNEO Projekt und viele Tips zum Programmieren und Debuggen)&lt;br /&gt;
&amp;lt;!-- * [http://www.z8micro.com/forum/ Z8 Encore! Microcontroller Discussion Forum - Dedicated to the ZiLOG Z8 Encore! Microcontroller] Ein der Z8 Encore!-Mikrocontrollerfamilie gewidmetes Diskussionsforum (in Englisch). - Link tot 6.9.2010 --&amp;gt;&lt;br /&gt;
* [http://www.cmosexod.com/ CMOSExod], Designs unter &#039;Free IP&#039;&lt;br /&gt;
* [http://www.fpga-forum.com/wbb Forum mit allgemeinen Diskussionen zum Thema FPGA und FAQ&#039;s speziell zu den Cesys FPGA Karten]&lt;br /&gt;
* [http://www.cesys.biz Online Shop für Cesys FPGA Karten]&lt;br /&gt;
== DSP ==&lt;br /&gt;
== Wettbewerbe (Contests) == &lt;br /&gt;
Verschiedene Hersteller veranstalten zur Promotion ihrer Produkte Designwettbewerbe, aus denen teilweise komplette Projektunterlagen hervorgehen (Schaltung, Source).&lt;br /&gt;
&#039;&#039;&#039;2011&#039;&#039;&#039;&lt;br /&gt;
*[http://www.555contest.com 555 Contest]&lt;br /&gt;
*[http://www.circuitcellar.com/nxpmbeddesignchallenge/ NXP and ARM/mbed challenge]&lt;br /&gt;
*[http://www.ebv.com/en/products/stm32-design-contest.html STM32 Design Contest] von EBV Elektronik und STMicroelectronics&lt;br /&gt;
* [http://www.renesasrulz.com/community/rx-contest The RX MCU Design Contest]&lt;br /&gt;
* [http://www.cypress.com/?id=3298 ARM Cortex-M3 PSoC® 5 Design Challenge]&lt;br /&gt;
* [http://www.instructables.com/contest/micro/ SparkFun Microcontroller Contest] bis 13.02.2011&lt;br /&gt;
* [http://www.elektroniknet.de/bauelemente/news/article/27963/0/Wer_entwickelt_die_beste_Anwendung_mit_dem_EFM32/ EFM32 Design-Wettbewerb] von Elektronik, Avnet-Memec und Energy Micro&lt;br /&gt;
&#039;&#039;&#039;2010&#039;&#039;&#039;&lt;br /&gt;
* [http://www.schmartboard.com/index.asp?page=mcu_2010 SchmartBoard 2010 MCU Challenge]&lt;br /&gt;
* [http://www.digilentinc.com/showcase/contests/designcontest.cfm?ContestID=6 Digilent Design Contest 2010]&lt;br /&gt;
* [http://www.parallax.com/go/holidaychallenge Parallax &amp;amp; iGen Student LED Holiday Challenge]&lt;br /&gt;
* [http://www.embeddedspark.com/upcomingchallenge/ The embeddedSPARK 2010 SUMMER Challenge]&lt;br /&gt;
* [http://www.libelium.com/tienda/catalog/contest.php?language=en Libelium Arduino Open Hardware Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/designstellaris2010/index.html Texas Instruments DesignStellaris 2010]&lt;br /&gt;
* [http://www.wizwiki.net/main/ iMCU Design Contest] (WIZnet)&lt;br /&gt;
* [http://www.elo-web.de/elo/entwicklung-und-projekte/ping-pong/elo-programmierwettbewerb-2010 ELO-Programmierwettbewerb 2010] (Atmega8, PingPong-Platine, 31.3.10)&lt;br /&gt;
* [http://www.lpc1100challenge.com/ NXP LPC1100 Design Challenge] (Cortex-M0 based LPC1100)&lt;br /&gt;
&#039;&#039;&#039;2009&#039;&#039;&#039;&lt;br /&gt;
* [http://arduinofun.com/blog/2009/11/01/fun-with-arduino-contest/ Fun with Arduino Contest]&lt;br /&gt;
* [https://www.xmos.com/challenge/ XMOS Challenge]&lt;br /&gt;
* [http://www.designmsp430.com/ Design MSP430 Ultra-Low Power Challenge]&lt;br /&gt;
* [http://makezine.com/halloweencontest/ Make: Halloween Contest 2009], sponsored by Microchip Technology!&lt;br /&gt;
* [http://www.bricogeek.com/contest/let-arduino-play/resultados.php Let Arduino Play Contest]&lt;br /&gt;
* [http://www.dlpdesign.com/designcontest/ DLP Design DLP-232PC Design Contest]&lt;br /&gt;
* [http://www.libelium.com/tienda/catalog/contest.php Arduino contest by Libelium]&lt;br /&gt;
* [http://www.expli.de/wettbewerb/coole-avr-microcontroller-elektronik-ideen/ EXPLI Elektronik Wettbewerb]: Die coolsten Elektronik Projekte &amp;amp; AVR Microcontroller Anleitungen&lt;br /&gt;
* [http://www.stm32circle.com/projects/contest.php STM32 Primer2 Design Competition 2009]&lt;br /&gt;
* [http://www.parallax.com/Resources/ApplicationsContests/Contests/200910PropellerContest/tabid/846/Default.aspx 2009/2010 Propeller Design Contest]&lt;br /&gt;
&#039;&#039;&#039;2008&#039;&#039;&#039;&lt;br /&gt;
* [http://www.parallax.com/tabid/720/Default.aspx Propeller Design Contest]&lt;br /&gt;
* [http://www.psocidcindia.com/index.php PSoC Innovator Design Challenge India 2008]&lt;br /&gt;
* [http://www.mypic32.com Microchip PIC32 Design Challenge]&lt;br /&gt;
* [http://contest.renesasinteractive.com/ HEW Target Server Design Contest 2008]&lt;br /&gt;
* [http://www.stm32circle.com/projects/result_contest_2008.php STM32 Primer Design Competition 2008]&lt;br /&gt;
&#039;&#039;&#039;2007&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/wiznet/index.html WIZnet iEthernet Design Contest 2007] &lt;br /&gt;
* [http://www.circuitcellar.com/microchip2007/ Microchip 16-Bit Embedded Control 2007 Design Contest]&lt;br /&gt;
&#039;&#039;&#039;2006&#039;&#039;&#039;&lt;br /&gt;
* [http://www.designmsp430.com/View.aspx 2006 MSP430 eZ Design Contest] &lt;br /&gt;
* [http://www.circellar.com/msp430/ MSP430 Design Contest]&lt;br /&gt;
* [http://www.luminarymicro.com/DesignStellaris2006 Luminary Micro DesignStellaris2006]&lt;br /&gt;
* [http://www.circuitcellar.com/avr2006/ Atmel AVR Design Contest 2006] &lt;br /&gt;
&#039;&#039;&#039;2005&#039;&#039;&#039;&lt;br /&gt;
* [http://www.jandspromotions.com/philips2005/index.htm Philips ARM Design Contest 2005] (LPC213x)&lt;br /&gt;
* [http://www.circuitcellar.com/renesas2005m16c/index.htm Renesas M16C Design Contest 2005]&lt;br /&gt;
* [http://www.edn.com/article/CA516007.html Cornelius van Drebbel&#039;s Mad Design Contest] (NEC)&lt;br /&gt;
&#039;&#039;&#039;2004&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/avr2004/ Atmel AVR 2004 Design Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/psoc2004/ PSoC High Integration Challenge 2004]&lt;br /&gt;
* [http://www.jandspromotions.com/zilog2004/ Zilog 2004 Flash Nets Cash Design Contest] (eZ80Acclaim!)&lt;br /&gt;
* [http://www.jandspromotions.com/wirelesschallenge/index.html 2004 Freescale Wireless Design Challenge] (MC13191/92/93 RF Transceivers, [[Meshnetics Zigbee|ZigBee]])&lt;br /&gt;
&#039;&#039;&#039;2003&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/fi2003/ MOTOROLA FLASH INNOVATION 2003 DESIGN CONTEST] (Motorola HC08)&lt;br /&gt;
* [http://www.circuitcellar.com/renesas/ Renesas H8 Design 2003 Contest]&lt;br /&gt;
* [http://www.jandspromotions.com/zilog2003/ ZiLOG Flash for Cash Z8 Encore®! International Design Contest]&lt;br /&gt;
* [http://www.jandspromotions.com/efield203/index.htm 2003 Motorola E-Field Sensor Contest] (MC33794)&lt;br /&gt;
&#039;&#039;&#039;2002&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/flash2002/ Mad Dash for Flash Cash] (Microchip, PIC)&lt;br /&gt;
&#039;&#039;&#039;2001&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/dl2001/ Atmel &#039;Design Logic 2001&#039; Design Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/msp430/ MSP430 Design Contest]&lt;br /&gt;
Siehe auch [[Linksammlung#Schnittstellen]]&lt;br /&gt;
=== Infrarot (IR) ===&lt;br /&gt;
* [http://www.sbprojects.com/knowledge/ir/ir.htm Übersicht IR-Protokolle] von San Bergmans (engl.): ITT, JVC, NEC, Nokia NRC17, Sharp, Sony SIRC, Philips RC-5, RC-6, RC-MM, RECS80, RCA, X-Sat&lt;br /&gt;
* [http://www.vishay.com/docs/80071/dataform.pdf Data formats for IR controls (PDF)] von Vishay.&lt;br /&gt;
* [http://www.projects-lab.com/?p=1139 ECPMON] - ECP Parallel Port Monitor ([[M16C]]/62P) &lt;br /&gt;
=== iPod ===&lt;br /&gt;
* [http://ipodlinux.org/IPod_to_T%26A_remotecontrol_adapter IPod to T&amp;amp;A remotecontrol adapter] ([[PIC]]-Projekt)(Link defect)&lt;br /&gt;
* http://jasongarr.wordpress.com/project-pages/ipod-clickwheel-hack/&lt;br /&gt;
=== [[RFID]] ===&lt;br /&gt;
* [http://www.alexanderguthmann.de/RFIDemulator.html RFIDemulator] - Beschreibung eines RFIDemulators zum klonen von Tags&lt;br /&gt;
http://www.message_bocracco.com/&lt;br /&gt;
* [http://dworkin-dmx.de/ USB DMX Interface] Bausatz /Fertiggerät USB DMX Interface  &lt;br /&gt;
* [http://www.marjorie.de/ps2/ps2_protocol.htm Das PS/2 Maus und PS/2- oder AT-Tastatur-Protokoll] (Original auf [http://www.computer-engineering.org/])&lt;br /&gt;
* [http://www.hth.com/snap/ S.N.A.P - Scaleable Node Address Protocol]. S.N.A.P is an free and open network protocol. The protocol was primary developed for PLM-24 based home automation and control systems but it is a generic protocol and not limited to this. S.N.A.P can be used in any type of applications where an easy to learn and light weighted network protocol is needed.&lt;br /&gt;
* [http://www.ulrichradig.de/home/index.php/avr/avr_-_rc PPM / PWM Encoder/Decoder für R/C Funkfernsteuerungen] von Ulrich Radig (AVR, C)&lt;br /&gt;
* [http://www.national.com/analog/interface/lvds_owners_manual LVDS Owner&#039;s Manual - 4th Edition] von National Semiconductor&lt;br /&gt;
* [http://www.mictronics.de/?page=becker Becker Unilink]&lt;br /&gt;
* [http://users.ntplx.net/~andrew/sony/unilink/ Sony UniLink]&lt;br /&gt;
* [http://www.vending.org/technology/MDB_Version_4.pdf Multi-Drop Bus / Internal Communication Protocol (MDB / ICP)]&lt;br /&gt;
siehe [[Platinenhersteller|Platinenhersteller]]&lt;br /&gt;
* [http://webcast.berkeley.edu/course_details.php?seriesid=1906978507 EE 42/EE 100 Introduction to Digital Electronics] - Webcast, Spring 2008 (englisch)&lt;br /&gt;
* [http://freevideolectures.com freevideolectures.com] - Webcasts zu  naturwissenschaftlichen Theman (englisch)&lt;br /&gt;
* [http://www.circuitsage.com/ Circuit Sage], a complete source of information to help you design circuits fast. (Linksammlung zu Software, Artikeln Büchern und Websites)&lt;br /&gt;
* [http://www.DieElektronikerseite.de Die Elektronikerseite] Umfangreiche Sammlung von kleinen Lehrgängen und Schaltungen. Ideal für Anfänger aber auch für Fortgeschrittene&lt;br /&gt;
* [http://homepages.internet.lu/absolute3/tronic/ 3D Virtual Development] - Sammlung von vielen Grundschaltungen im Bereich Oszillator, Operationsverstärker, Empfangstechnik. Vereinzelt in Englisch.&lt;br /&gt;
* [http://cws.gtc.edu/programs/objects/electronics.htm Learning Objects for Electronics] des Engineering Tech Wing of Gateway Technical College (Flash erforderlich)&lt;br /&gt;
* [http://ecee.colorado.edu/~bart/book/book/title.htm Principles of Semiconductor Devices] von Bart Van Zeghbroeck&lt;br /&gt;
* [http://itp.nyu.edu/physcomp/Intro/HomePage Introduction to Physical Computing] ([[AVR]], Arduino)&lt;br /&gt;
== Skripte ==&lt;br /&gt;
* [http://www.janson-soft.de/skripte/index.html Linksammlung von Volker Lange-Janson]&lt;br /&gt;
* [http://openbookproject.net//electricCircuits/index.htm Lessons in Electric Circuits I-VI] von Tony R. Kuphaldt&lt;br /&gt;
* [http://www.filmetrics.com  Filmetrics Inc.] (Filmetrics manufactures affordable thin-film measurement instruments capable of measuring thin films from 3nm to 0.5mm in thickness.)&lt;br /&gt;
* [http://www.pce-instruments.com  PCE Instruments] (Entwicklung und Produktion für Prüfgeräte und Waagen.)&lt;br /&gt;
* [http://www.pctestinstruments.com Intronix LogicPort], Günstiger, aber sehr leistungsfähiger Logikanalysator mit USB-Anschluß an PC (34Ch, 500MHz Timing, 34 x 2kSa mit Kompression, ca. 295 Euro [http://www.shop.display3000.com/elektronik/messgeraete/index.html hier])&lt;br /&gt;
* Zeroplus LAP-Cxxxx (Familie von LA&#039;s mit unterschiedlichen Daten, 32kBit...2MBit, 16ch oder 32ch, 100MHz..200MHz, Preise von 90,-...1100,- Euro, zu kaufen [http://www.tigal.com/products_category.asp?cid=96 hier])&lt;br /&gt;
* [http://www.hacker-messtechnik.de/13722/59001.html TravelLogic TL2x36], Logikanalysator zum Anschluß an PC über USB, (36ch, 4GHz timing, 200MHz state, Speicher bis 72MBit, Preis ab ca. 500,- netto)&lt;br /&gt;
* [http://www.saleae.com/logic/ logic] - Logik-Analyzer mit 8 Kanälen, mit Software zur Analyse von SPI, I2C, UART, etc... (ca 150$ + Versand/Zoll)&lt;br /&gt;
* [http://www.deditec.de/de/logikanalysatoren/prod/usb-logi-500.html DEDITEC USB-LOGI-500], kostengünstiges Einsteigermodell mit USB-Anschluß und dazugehöriger Software Logi+ (36Ch, Abtastrate 500MHz, 4096 Samples Speichertiefe/Kanal,  ca. 236 Euro)&lt;br /&gt;
* Eine Übersicht über verschiedene Selbstbauprojekte: [[Logic_Analyzer]]&lt;br /&gt;
* [http://www.timing-diagrams.com TimingAnalyzer] can be used to easily draw timing diagrams and perform timing analysis to find faults in digital logic systems. Written in Java, it runs on any platform that supports the Java Run-time Environment, JRE1.6.0 or Java Development Kit JDK1.6.0 or newer.&lt;br /&gt;
=== Foren ===&lt;br /&gt;
* [http://forum.sparkfun.com/ Spark Fun Electronics] MicroController Ideas and Support (Englisch) ([[AVR]], [[PIC]], [[MSP]], [[ARM]], OpenOCD)&lt;br /&gt;
* [http://formu.iwenzo.de Elektronik Reparatur Forum] Informationselektroniker Reparatur Forum&lt;br /&gt;
* [http://www.elektrikforum.de Elektrik-Forum] Forum zum Thema Elektroinstallationen&lt;br /&gt;
=== Videocasts und Podcasts ===&lt;br /&gt;
* [http://www.eevblog.com/ EEVblog] Electronics Engineering Video Blog von David L. Jones (englisch). &#039;&#039;Anm.: David ist Australier und das hört man. An die Sprechweise kann man sich aber gewöhnen. Und nicht erschrecken, wenn öfter mal ein drastisches Fourletterword auftaucht!&#039;&#039;&lt;br /&gt;
* [http://www.theamphour.com/ The Amp Hour] Podcast mit Chris Gammell und David Jones (englisch)&lt;br /&gt;
&amp;lt;!-- offline 4/2010&lt;br /&gt;
* [http://www.next.gr/ Next] Electronic Circuit Database&lt;br /&gt;
* [http://www.schaltplaene-online.de/ www.schaltplaene-online.de] Umfangreiche Linksammlung zu Schaltplänen aller Art&lt;br /&gt;
* [http://www.open-innovation-projects.org Open Innovation Projects] - Sammlung von offenen Projekten zu physischen Produkten, darunter etliche Mikrocontroller-Projekte. Man kann selber Projekte hinzufügen.&lt;br /&gt;
* [http://www.cs.net/lucid/intel.htm Intel-Hex-Format]&lt;br /&gt;
* [http://www.rev-ed.co.uk/docs/picaxe_manual3.pdf Microcontroller Interfacing Circuits] - Revolution Education Ltd.&lt;br /&gt;
* [http://www.digchip.com/application-notes/ Datenbank für &#039;&#039;Application Notes&#039;&#039;] bei www.digchip.com&lt;br /&gt;
* [http://www.nrbook.com/a/bookcpdf.php Numerical Recipes in C, Second Edition (1992)]&lt;br /&gt;
* [http://www.specamotor.de/freebook.php Electrical drives for precision engineering designs]  Prof.dr.ir. Compter&lt;br /&gt;
* [http://www.joretronik.de/Web_NT_Buch/Vorwort/Vorwort.html Das neue InterNetzteil- und Konverter-Handbuch] Dipl.-Ing. Jörg Rehrmann&lt;br /&gt;
** [http://www.makezine.com/ Makezine]&lt;br /&gt;
** [http://www.hacknmod.com/ Hack N&#039; Mod]&lt;br /&gt;
** [http://zedomax.com/blog/category/diy/ Zedomax DIY]&lt;br /&gt;
** [http://digital-diy.com Digital-DIY]&lt;br /&gt;
* Foren&lt;br /&gt;
domain expired&lt;br /&gt;
** Final Projects der Kurse [http://people.ece.cornell.edu/land/courses/ece4760/FinalProjects/ ECE4760] (Designing with Microcontrollers) und [http://people.ece.cornell.edu/land/courses/ece5760/FinalProjects/ ECE5760] (Advanced Microcontrollers) an der Cornell University &lt;br /&gt;
** [http://www.coolcircuit.com/gadgets/ Cool Circuit]&lt;br /&gt;
** [http://www.electronics-lab.com/blog/ Electronics-Lab.com Blog]&lt;br /&gt;
* DIY-Anleitungen&lt;br /&gt;
* Mix&lt;br /&gt;
** [http://www.ikalogic.com/index.php ikalogic.com]&lt;br /&gt;
** [http://elettrolinux.com elettrolinux] - Elektronik und Linux (engl.)&lt;br /&gt;
** [http://electronicfox.at.tf/ electronicfox] - Verschiedene Projekte mit [[AVR]], Fernbedienungen und deren Aufbau sowie Decoder und alten ICs aus dem Recyclinghof&lt;br /&gt;
** [http://www.techfocusmedia.net/archives/fresh-bytes/ Fresh Bytes von Techfocusmedia]&lt;br /&gt;
* [http://www.eue24.net/ E&amp;amp;E Faszination Elektronik] - Magazin für Elektronik-Entwickler und Elektronik-Interessierte&lt;br /&gt;
* [http://www.edn.com/ EDN] (etwas schwer zu finden, aber lesenswert: die [http://www.edn.com/channel/Design_Ideas.php Design Ideas] und das [http://www.edn.com/archive/ Archiv der Druckausgaben])&lt;br /&gt;
* [http://www.franzis.de/elo-das-magazin ELO - Das Magazin] für Elektronik-Einsteiger&lt;br /&gt;
* [http://techonline.com/ TechOnline]&lt;br /&gt;
* [http://www.elektor.de/ Elektor] &lt;br /&gt;
* [http://www.techbriefs.com/tech-briefs/electronics-techbriefs NASA Tech Briefs] - Electronics &amp;amp; Computers&lt;br /&gt;
* [http://et.nmsu.edu/~etti/ Technology Interface Journal]&lt;br /&gt;
* [http://dev.emcelettronica.com/ Your Electronics Open Source]&lt;br /&gt;
* [http://www.element-14.com element14.com] is an information portal and community specifically built for electronic design engineers.&lt;br /&gt;
* [http://www.itwissen.info ITWissen.info] (gutes Lexikon)&lt;br /&gt;
* [http://www.nutsvolts.com Nuts&#039;n&#039;Volts] Amerikanisches Elektronikmagazin mit Online Blog&lt;br /&gt;
* [http://de.rs-online.com/web/generalDisplay.html?id=eTech eTech] von RS Online&lt;/div&gt;</summary>
		<author><name>79.83.80.121</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Linksammlung&amp;diff=55746</id>
		<title>Linksammlung</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Linksammlung&amp;diff=55746"/>
		<updated>2011-03-11T14:01:37Z</updated>
		<summary type="html">&lt;p&gt;79.83.80.121: Änderung 55741 von Jimmy j (Diskussion) wurde rückgängig gemacht. Spam&lt;/p&gt;
&lt;div&gt;Auf dieser Seite werden Links zu anderen interessanten Mikrocontroller- und Elektronikseiten gesammelt.&lt;br /&gt;
Die alte Linkseite findet man [http://www.mikrocontroller.net/en/links hier].&lt;br /&gt;
* [http://www.alldatasheet.com/ alldatasheet] - Datasheet Search&lt;br /&gt;
* [http://www.datasheetarchive.com/ datasheetarchive] - Datasheet Search&lt;br /&gt;
* [http://www.datasheetcatalog.com/ datasheetcatalog] - Datasheet Search&lt;br /&gt;
* [http://www.msarnoff.org/chipdb/ ChipDB] - Pinouts von gängigen µCs.&lt;br /&gt;
&amp;lt;!-- SPAM&lt;br /&gt;
* [http://www.TechTour.net] - Angebote und Technische Beratung von mehreren Anbietern gleichzeitig einholen. Von der Elektronik Entwicklung über Leiterplatten Bestückung, von Leiterplatten über Folientastaturen, Gehäusen bis zur Kabelkonfektion.&lt;br /&gt;
== [[AVR]] ==&lt;br /&gt;
* [http://www.halbleiter-scout.de/ Halbleiter Scout] - Halbleiter Hersteller&lt;br /&gt;
* [http://www.atmel.com/dyn/general/updates.asp Atmel.com updates] Liste der letzten Änderungen in Datenblättern und Beispielcode auf ATMEL.com (nicht nur für AVRs)&lt;br /&gt;
* [http://www.msc-ge.com/de/produkte/elekom/mc/atmel/avr_start.html AVR Produktinfos] AVR Infos vom Atmel Distributor MSC Vertriebs GmbH&lt;br /&gt;
* [http://www.microschematic.com/ AVR Microcontroller inside] (nett gemacht, Engl. Seite am 07-09-2008 nicht erreichbar)&lt;br /&gt;
* [http://popularmicrocontrollers.com/ AVR Microcontrollers] - A web site about AVR microcontrollers&lt;br /&gt;
&amp;lt;!-- Dieser Unterabschnitt ist für AVR. Für PIC gibt es einen eigenen Unterabschnitt weiter unten. --&amp;gt;&lt;br /&gt;
==== C ====&lt;br /&gt;
* [http://www.imagecraft.com/devtools_AVR.html Imagecraft] Der ICCAVR C Compiler fuer AVR von Imagecraft.&lt;br /&gt;
* [http://john.ccac.rwth-aachen.de:8000/as/ Macro Assembler AS] - AS is a portable macro cross assembler for a variety of microprocessors and -controllers&lt;br /&gt;
==== Disassembler ====&lt;br /&gt;
* [http://www.datarescue.com/idabase/ IDA-Pro] -Disassembler und Debugger für fast alle bekannten Prozessoren. Evaluation Version verfügbar. Tagline: &#039;&#039;The most advanced tool for Hostile Code Analysis, Vulnerability and Software Reverse Engineering&#039;&#039;&lt;br /&gt;
* [http://avr.jassenbaum.de/ja-tools ReAVR] - Disassembler und ACXutility Binary Tool&lt;br /&gt;
* [http://dev.frozeneskimo.com/software_projects/vavrdisasm vAVRdisasm] - Free AVR Disassembler&lt;br /&gt;
* [http://www.johannes-bauer.com/mcus/avrdisas/ avrdisas] - AVR Mikrocontroller Disassembler für Linux (und Win32)&lt;br /&gt;
&amp;lt;!-- * [http://biew.sourceforge.net/en/biew.html BVIEW] is multiplatform portable viewer of binary files with built-in editor in binary, hexadecimal and disassembler modes. It includes &#039;&#039;&#039;AVR&#039;&#039;&#039;/Java/i86-i386-AMD64/ARM-XScale/PPC64 disassemblers, russian codepages convertor, full preview of formats - MZ, NE, PE, NLM, coff32, elf partial - a.out, LE, LX, PharLap; code navigator and more over. (GPL) - 404, 6.9.2010 --&amp;gt;&lt;br /&gt;
==== BASIC ====&lt;br /&gt;
* [http://www.DieProjektseite.de Beetle-Basic] Leistungsfähiges Basic-Betriebssystem im AVR.&lt;br /&gt;
* [http://www.mikrocontroller.net/articles/AVR_BASIC AVR_BASIC] Open Source Freeware: Minimalistischer Basic-Interpreter  im AVR.&lt;br /&gt;
==== Pascal ====&lt;br /&gt;
==== Forth ====&lt;br /&gt;
* [http://www.robo-forth.de www.robo-forth.de] - AVR Forth Compiler mit umfangreicher Funktionslibrary für Servos, Motore und Sensoren&lt;br /&gt;
==== Java ====&lt;br /&gt;
* [http://www.harbaum.org/till/nanovm NanoVM] - Java VM für AVR-Mikrocontroller ([[NanoVM|deutsches Wiki]])&lt;br /&gt;
* [http://www.fam-frenz.de/stefan/compiler.html SJC] - Java-Compiler (erzeugt AVR-Maschinencode) für AVR-Mikrocontroller ([[SJC]])&lt;br /&gt;
==== Ada ====&lt;br /&gt;
* [http://avr-ada.sourceforge.net/ AVR-Ada] - Ada Compiler innerhalb von GCC (GNAT) für AVR.  Enthält eine kleine Laufzeitbibliothek ohne Tasking und ohne Exceptions. [http://www.mikrocontroller.net/topic/168823#1614208]&lt;br /&gt;
==== Virgil ====&lt;br /&gt;
==== LabVIEW ====&lt;br /&gt;
* http://www.ni.com/embedded/ Informationen zu LabVIEW, der graphischen Entwicklungsumgebung von National Instruments&lt;br /&gt;
* http://www.labviewforum.de/ Deutsches Labview-Forum&lt;br /&gt;
* [http://web.me.com/iklln6/automation/LabVIEW.html Communicating Arduino--&amp;gt;LabVIEW]&lt;br /&gt;
==== Python ====&lt;br /&gt;
* [http://code.google.com/p/python-on-a-chip/ python-on-a-chip] (pymite). There are two sample projects in the source tree.  One for an 8-bit Atmel ATmega103 (but any AVR/ATmega with 4 KB RAM or more will do) and one for the 32-bit Atmel AT91SAM7S64 running on the AT91SAM7S-EK evaluation board. (GPL Lizenz)&lt;br /&gt;
==== Openeye ====&lt;br /&gt;
* OpenEye ist eine Kombination aus PC-Programm (Windows, Delphi) und einer Monitor-Routine im AVR. Die Daten aus dem AVR werden mit RS232 übertragen und können fürs Debuggen der laufenden Anwendung benutzt werden. OpenEye wurde vom User Martin Vogel (oldmax) geschrieben [http://www.mikrocontroller.net/topic/143144#1326244].&lt;br /&gt;
==== Modkit ====&lt;br /&gt;
[http://blog.modk.it/ Modkit] is a new kind of graphical programming environment that makes programming things in the physical world as easy as dragging and dropping little virtual code blocks in a web browser.. Heavily inspired by the Scratch programming environment (from MIT Media Lab&#039;s Lifelong Kindergarten Group), Modkit enables anyone including kids, artists and inventors to build with electronic kits and components including motors, sensors, lights, sound and the popular Arduino and Arduino compatible development boards... (Text vom Makezine)&lt;br /&gt;
* [http://et-tutorials.de/632/kostenloser-mikrocontroller-kurs/ Mikrocontroller Video Tutorial] Video-Tutorial für Einsteiger (C-Kurs + Einführung 8051)&lt;br /&gt;
* [http://www.meinemullemaus.de/elektronik/avr_workshop/index.html AVR Mikrocontroller] Einfühung in AVR Mikrocontroller mit Nachbau des Spiels &amp;quot;Senso&amp;quot;.&lt;br /&gt;
* [http://electrons.psychogenic.com/avr/ electrons.psychgenic.com] AVR Microcontroller Section - Einführung und Tutorial (E)&lt;br /&gt;
&amp;lt;!-- Bachblütentherapie... 4/2010&lt;br /&gt;
* [http://digitaltechnik.mschoeffler.de digitaltechnik.mschoeffler.de] Einführung in die Grundlagen der Digitaltechnik&lt;br /&gt;
* [http://www.schaltungsforum.de Das Schaltungsforum] ist eine Seite für Anfänger und Profis welche ständig mit Tutorials erweitert wird. Stellt Eure Projekte online. Die Seite befindet noch im Aufbau und Eure Mithilfe ist erwünscht.&lt;br /&gt;
* [http://www.mikrocontrollerspielwiese.de mikrocontrollerspielwiese.de] ist eine Seite, die an Anfänger gerichtet ist und Experimente und fertige Projekte komplett mit Code und Eagle-Dokumenten zur Verfügung stellt.&lt;br /&gt;
* [http://www.elo-web.de/elo/mikrocontroller-und-programmierung/avr-anwendungen ELO-AVR-Anwendungen] bietet eine wachsende Sammlung kleinerer AVR-Projekte, überwiegend für die ATTiny-Serie.&lt;br /&gt;
* [http://www.schramm-software.de/tipps/ AVR-Tipps] Programmier-Tipps und AVR-Experimente.&lt;br /&gt;
* [http://www.uwe-kerwien.de/pll/pll-synthesizer.htm PLL-Synthesizer Tutorial] kleines praxisorientiertes PLL-Tutorial zur Funktion, Reparatur und Steuerung einer PLL-Schaltung mit AVR ATtiny2313 über 3-Leiter-Bus&lt;br /&gt;
* Arduino&lt;br /&gt;
** [http://tronixstuff.wordpress.com/tutorials/ t r o n i x s t u f f] - Arduino Tutorials (engl.)&lt;br /&gt;
** [http://www.earthshinedesign.co.uk/ASKManual/Site/ASKManual.html The Complete Beginners Guide to the Arduino]&lt;br /&gt;
** [http://www.codeproject.com/KB/system/ArduinoVB.aspx Arduino with Visual Basic] by Carl Morey auf codeproject.com&lt;br /&gt;
* [http://www.piconomic.co.za/avr.html Piconomic Design Atmel AVR Course] is for the engineer who wants to switch to the 8-bit Atmel AVR microcontroller and learns by example. C language and compiler experience is a prerequisite. (Beim Nachbau des AVR-Boards &#039;&#039;&#039;Copyright notice&#039;&#039;&#039; beachten!)&lt;br /&gt;
* [http://metku.net/index.html?path=articles/microcontroller-part-1/index_eng metku.net] - How to get started with microcontrollers (ATtiny45, Steckbrett)&lt;br /&gt;
* [http://www.stromflo.de/dokuwiki/doku.php?id=xmega-c-tutorial XMEGA-C-Tutorial] - Tutorial über Atxmega&lt;br /&gt;
* [http://www.itee.uq.edu.au/~cse/_atmel/AVR_Studio_Tutorial/ Einstieg in AVRStudio 4] (viele Abbildungen, Engl.)&lt;br /&gt;
* [[AVR-Studio]]&lt;br /&gt;
==== Bascom ====&lt;br /&gt;
* [http://sourceforge.net/apps/mediawiki/avr-ada/index.php?title=Tutorial AVR-Ada Tutorial]&lt;br /&gt;
* [http://www.fox4you.cc Austria] Development Tools for ATMEL ATmega Microcontrollers Connections via USB and LAN&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php Embedded-IT] USB Module auf AVR Basis sowie Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem&lt;br /&gt;
&amp;lt;!-- falsche Einordnung: kein Atmel spezifisches Angebot 4/2010&lt;br /&gt;
* [http://www.glyn.de GLYN High-Tech Distribution] Mikrocontroller Applikationen, TFT-Displays, LCD-Anzeigen, Memory Cards&lt;br /&gt;
* [http://avrboards.com/ AVR Boards] - Some information about AVR microcontrollers and development boards&lt;br /&gt;
* [http://six.media.mit.edu:8080/6 number six] - Open Source Design, Atmega32. Alle Pins sind auf eine 2x20 Pol Wannenstiftleiste herausgeführt.&lt;br /&gt;
* http://www.maares.de/tools USB Memory Stick am AVR Butterfly. AVR Butterfly Trägerplatine zum Anschluß von VDRIVE, VMUSIC, RFM12.&lt;br /&gt;
* [http://www.wiring.org.co/ Wiring] is an open source programming environment and electronics i/o board for exploring the electronic arts, tangible media, teaching and learning computer programming and prototyping with electronics.&lt;br /&gt;
* [http://binaryideas.blogspot.com/2008/08/project-quick-avr-part-3_26.html QuickAVR] - DIY Prototypenboard zum Aufstecken auf ein Breadboard (ATmega168, 16 MHz, no SMD)&lt;br /&gt;
* [http://www.chip45.com/ chip45] Atmel AVR Module und Boards mit USB, RS232/485, CAN, Ethernet, Funkmodule, sowie ISP Programmieradapter.&lt;br /&gt;
* [http://www.rakers.de/catalog Dr. Rakers] &amp;lt;b&amp;gt;AVR Boards und Experimentierplatinen&amp;lt;/b&amp;gt; mit USB, Ethernet, RS232, CAN, LCD etc. in hochwertiger Qualität zu günstigen Preisen.&lt;br /&gt;
* [http://nibo.nicai-systems.de Roboterbausatz Nibo] - autonomer &amp;lt;b&amp;gt;Roboter&amp;lt;/b&amp;gt; mit einem ATmega128 und einem ATmega88&lt;br /&gt;
* [http://www.comsys.ch/Tern-Embedded-Systeme.151.0.html Tern Embedded Systeme] - C++ programmierbare Kontroller mit 586, i386EX, Am188ES und V25 Prozessoren, Entwicklungstools.&lt;br /&gt;
* [http://www.schramm-software.de/bausatz/ Schramm-Software] - AVR Mikrocontroller-Bausätze&lt;br /&gt;
* [http://www.alvidi.de/ Alvidi] - Headerboards mit AVR &amp;amp; AVR32 Controllern&lt;br /&gt;
* [http://www.steitec.net/ Steinert Technologies] - Thailändischer Anbieter von Mikrocontroller Boards (AVR, ARM7, ARM9, PIC, dsPIC, PSoC, uvm.)&lt;br /&gt;
* [http://www.kabelscheune.de/ Elektromaterial] - Onlineshop für Elektromaterial&lt;br /&gt;
* [http://www.ledmeile.de/ LED Lampen] - Onlineshop für LEDs&lt;br /&gt;
** [http://www.arduino.cc/ Arduino] Homepage&lt;br /&gt;
** [http://www.freeduino.org/ Freeduino.org] - Riesige Linksammlung zu dem &#039;&#039;&#039;Ardunio&#039;&#039;&#039;(R) AVR-Board (Kit) und dessen Clones und Mutanten (DIY oder Kit)&lt;br /&gt;
** [http://www.freeduino.de/ freeduino.de] - Anleitungen und Tutorials, Arduino Wiki, Blog, Tools in Deutsch&lt;br /&gt;
** [http://shieldlist.org/ Arduino Shield List]&lt;br /&gt;
* [http://www.fritzing.org Fritzing] nützliches Programm für viele Betriebsysteme zur Unterstützung eines Brettboard-Aufbaus(ungetestet).&lt;br /&gt;
* [http://www.specialprint.eu Specialprint] InkjetDruck für den digitalen Direktdruck von Ätzmasken, Lötstoppmasken, Frontplatten, Kennzeichnungen&lt;br /&gt;
* [http://www.obdev.at/products/avrusb/avrdoper.html AVR-Doper] Einfach nachzubauender, STK500-kompatibler Programmer mit USB-Anschluss. Beherrscht auch HVSP, nicht jedoch HVPP. Open Source.&lt;br /&gt;
* [http://home.arcor.de/bernhard.michelis Amadeus-USB] - Highspeed-Programmer für PIC18, PIC24, dsPIC30, PIC32, dsPIC33 und AVR. Bietet auch Möglichkeiten zur Fehlersuche.&lt;br /&gt;
* [http://www.piketec.com/products/tpt.php Time Partition Testing (TPT)] - Test-, und Testauswertewerkzeug für eingebettete Systeme&lt;br /&gt;
* [http://shop.myavr.de/Programmer.htm?sp=artlist_kat.sp.php&amp;amp;katID=16 mySmartUSB] - USB Programmer (ab 15€) kombiniert auch mit USB-UART-Bridge, STK500v2/AVR910/AVR911 kompatibel, ISP HV-seriell, HV-parallel&lt;br /&gt;
* [http://www.myavr.de/download.php?suchwort=ProgTool myAVR ProgTool] nette Programmieroberfläche (free)&lt;br /&gt;
* [http://b9.com/elect/avr/kavrcalc/ KAVRCalc] is a free calculator to assist in programming AVR microcontrollers (Baudrate, Watchdog, Timer, ...)&lt;br /&gt;
* [http://www.chip45.com/CrispAVR-USB CrispAVR-USB] STK500 V2 kompatibler ISP Adapter mit USB Schnittstelle für Atmel AVR Mikrocontroller (1,8V-5,5V).&lt;br /&gt;
* [http://ucom-ir.nicai-systems.de UCOM-IR] - Programmieradapter mit USB Schnittstelle (AT90USB162) und IR-Sender/Empfänger, STK500 V2 kompatibel&lt;br /&gt;
* [http://www.anagate.de/products/programmers.htm AnaGate Programmer] Serielle Programmer mit LAN-Anschluss für I2C und SPI inkl. Programmier-API für Windows/Linux (Shop)&lt;br /&gt;
* [http://www.tinyos.net/ TinyOS] - Komponentenbasiertes Betriebssystem für Sensorknoten. Bringt eigene C-ähnliche Hochsprache nesC mit.&lt;br /&gt;
* [http://www.femtoos.org/ Femto OS] von  Ruud Vlaming ist ein preemptives Betriebssystem für die kleinsten Mikrocontroller aus der AVR Serie bis ca. 16 KB ROM und 1 KB RAM. Spezielle Targets sind: ATtiny861/461/261. Geschrieben in C. Freie Software, GPLv3. Artikel in Elektor Februar 2010 &lt;br /&gt;
* [http://www.projects-lab.com/?p=344 kaOS] is a real-time, multithreaded, preemptive operating system for the ATmega32 microcontroller, which loads and executes programs from a Secure Digital or MMC card. Authors Nicholas Clark &amp;amp; Adam Liechty. (Circuit Cellar AVR Wettbewerb 2006)&lt;br /&gt;
* [http://helium.sourceforge.net/ Helium] is a minimalistic real-time kernel for the HC(S)08 core by Freescale and Atmel AVR.&lt;br /&gt;
* [http://dev.bertos.org/ BeRTOS] is a completely free, open source, real time operating system (RTOS) suitable for embedded platforms. Runs on many microprocessors and microcontrollers, ranging from 8 bits to 32 bits CPUs and even PCs.&lt;br /&gt;
* [http://funkos.sourceforge.net/ funkos] Targets: AVR, XMEGA, MSP430, Cortex M3, Open Source&lt;br /&gt;
* Vergleich zwischen [http://antipastohw.blogspot.com/2009/11/4-operating-systems-for-arduino.html 4 Operating Systems for the Arduino] auf [http://antipastohw.blogspot.com Liquidware Antipasto]&lt;br /&gt;
** &#039;&#039;&#039;DuinOS&#039;&#039;&#039; by RobotGroup (FreeRTOS Portierung)&lt;br /&gt;
** [http://www.skewworks.com/pyxis/ Pyxis OS] by ArduinoWill&lt;br /&gt;
** &#039;&#039;&#039;ArduinoMacOS&#039;&#039;&#039; by Mark&lt;br /&gt;
** &#039;&#039;&#039;TaOS&#039;&#039;&#039; by Ziplock&lt;br /&gt;
* [http://atomthreads.com/ Atomthreads] is a free, lightweight, portable, real-time scheduler for embedded systems. (BSD Lizenz)&lt;br /&gt;
* [http://www.shift-right.com/xmk/ XMK] (eXtreme Minimal Kernel) ist ein freies Echtzeitbetriebssystem für Mikrocontroller (AVR, H8, R8C, M16C).&lt;br /&gt;
* [http://irtos.sourceforge.net/index.html.en iRTOS] is an free Real Time Operating System. The iRTOS kernel is free to download and use under the terms of LGPL. It can be used in commercial applications. iRTOS is designed for tiny 8 bit microconroller chips with little RAM usage. OS can be installed also in 16 and 32 bit processor units.&lt;br /&gt;
* [http://sites.google.com/site/cocoosorg/avr-projects/home cocoOS] is a cooperative task scheduler, based on coroutines and it is written in C. (STK500, Atmega16)&lt;br /&gt;
* [http://www.DieProjektseite.de BasicBeetle] Basic-Betriebssystem im AVR&lt;br /&gt;
* Shells für Arduino:&lt;br /&gt;
** [http://biot.com/arsh/ ARSH]&lt;br /&gt;
** [http://www.battledroids.net/downloads/avrsh.html AVRSH]&lt;br /&gt;
** [http://bitlash.net/wiki/start BITLASH]&lt;br /&gt;
** [http://sourceforge.net/projects/fruitshell/ FRUITSHELL]&lt;br /&gt;
** [http://www.gisvold.co.uk/~gisvold/drupal/node/1484 BREAKFAST]&lt;br /&gt;
* [http://nootropicdesign.com/toolduino/ toolduino] is a simple software tool that lets you easily interact with your Arduino hardware so you can test the circuits you create. Toolduino is written in the [http://processing.org/ Processing] languange and is available for Windows, Mac OS X, and Linux. Toolduino uses the the [http://www.arduino.cc/playground/Interfacing/Processing Arduino library for Processing] to communicate with an Arduino board so you can manipulate output pins and read inputs. The Arduino must be running the [http://firmata.org/wiki/Main_Page Firmata] firmware that comes with the Arduino IDE. (LGPL)&lt;br /&gt;
* [http://www.mueller-torres.de/avr.php MOPS] - A small C and Assembly based operating system for the ATMEL AVR® 8-Bit RISC controller family.&lt;br /&gt;
* [http://www.DieProjektseite.de Die Elektronik-Projektseite und Heimat des BasicBeetle] Hauptthema ist der BasicBeetle. Ein modularer, leistungsfähiger, in Basic programmierbarer Mikrorechner speziell für Steuerungen. Mit vielen Programmen, Tiipps und Tricks, Informationen...&lt;br /&gt;
* [http://www.Happy-Micro.de Happy-Micro.de] Die Internetsite für Hobbyelektroniker, Mikrocontroller-Anwender, Programmierer und alle, die Spaß an Computern und Elektronik haben. Bei Happy-Micro.de steht der Spaß am Entwickeln von Programmen und Schaltungen im Vordergrund. Jeder Benutzer hat die Möglichkeit auch als Autor mitzumachen und seine Schaltungen oder Programme zu veröffentlichen. Freier Bilderdownload für die eigene Homepage. &#039;&#039;(Seite wurde geschlossen!)&#039;&#039;&lt;br /&gt;
* [http://iwenzo.de Elektronik und Informationen] Wissenswertes aus der Unterhaltungselektronik..&lt;br /&gt;
* [http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/ Cornell University ECE 476 Microcontroller Design Final Projects] &lt;br /&gt;
* [http://home.planet.nl/~meurs274/ AVRmicrocontrollerprojects] u.a. Text-LCD, Schrittmotor, Thermometer &#039;&#039;(Seite existiert nicht mehr/ Error 404)&#039;&#039;&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects  M. Thomas&#039; AVR Projekte] untern Anderem AVR Butterfly avr-gcc-port, DB101 gcc-port, BC100 gcc-port, Bootloader, Programmier- und Debughardware, Software-UART, DS1820-Lib., experimentelle avrdude-Versionen, AVR und CAN mit MCP2515 &amp;lt;!-- Vorsicht &amp;quot;Eigenwerbung&amp;quot; --&amp;gt;&lt;br /&gt;
* [http://www.avr-projekte.de AVR-Projekte.de] Belichtungstimer, FT232RL Schaltungen,LED-Fading über Fernbedienung, HD44780-LCD über USB und Seriell, AVR910-USB Programmer, Basteleien: Ätzmaschine,Kompressor.&lt;br /&gt;
* [http://openeeg.sourceforge.net/ openeeg.sourceforge.net] Das OpenEEG Projekt befasst sich mit der Entwicklung eines preiswerten Elektro-Enzephalographie (EEG) Geräts und dessen freier Steuersoftware zur Messung elektrischer Gehirnströme. Sein µPC-Herz ist ein AT90S4433 bzw. ein ATmega8. Ziel sind auch verschiedene EEG Anwendungen z.&amp;amp;nbsp;B. im Bereich mentaler Trainingsmethoden (Neurofeedback).&lt;br /&gt;
* [http://www.loetstelle.net www.loetstelle.net] Verschiedene kleinere AVR-Projekte rund um LEDs, z.&amp;amp;nbsp;B. RGB Dimmer, Moodlight. Diverse Elektronikprojekte und Grundlagen&lt;br /&gt;
* [http://www.avrguide.com/ AVR Projektsammlung] bei www.avrguide.com&lt;br /&gt;
* [http://freenet-homepage.de/wedis-bastelecke/ Wedis-Bastelecke] - Modellbahn DCC-Servo-Zubehördecoder DCC Servo Decoder mit ATmega8 / Servo Differenzierbaugruppe für Modellbau&lt;br /&gt;
* http://www.electronicspit.com - Verschiedene Elektronikprojekte (LED-Matrix, PAL-Video)&lt;br /&gt;
* http://web.archive.org/web/20050415222337/http://www.hebel23.de/ RDS RADIO: ATMega32, TEA5757, T6963C, TDA7330B in C&lt;br /&gt;
* [http://www.gasenzer.dk Analog/Digital and MPU Eletronic Projects] PAL/VGA Terminal, CallerID, Ethernet, Wireless Bridge, LPC2214, AT91RM9200, Sony Unilink Controlled Wireless MP3 Player.&lt;br /&gt;
* [http://www.circuitcellar.com/avr2006/ Circuit Cellar AVR Design Contest 2006] mit Projektbeschreibungen&lt;br /&gt;
* [http://www.heesch.net/microcontroller.aspx/ Homepage von Stefan Heesch] - AVR Mikrokontroller Projekte, z.B. WLAN und AVR, netzwerkgesteuertes RGB Licht, IDE-Interface, DS1821 Thermometer, Morse-Dekoder u.a.&lt;br /&gt;
* [http://avrprojekte.de/] Viele Projekte mit LEDs(LED-Matrixen) und AVRs&lt;br /&gt;
* [http://arduino.milkcrate.com.au/ little-scale&#039;s arduino page]&lt;br /&gt;
* [http://www.sebastianweidmann.de www.sebastianweidmann.de] Grundlagen zum Thema Platinen ätzen, Bohren, Durchkontaktierungen und Projekte Tipps/Tricks mit Atmel AVR Microcontrollern&lt;br /&gt;
*[http://www.jtronics.de/elektronik-avr.html Junghans Electronic Page] u.a Nokia 3310 LCD Ansteuerung in &amp;quot;C&amp;quot;(aktualisiert 2010), TWI/USI, Quadcopter&lt;br /&gt;
* [http://www.familie-finke.com/ http://www.familie-finke.com/] Die Website von Thomas Finke mit diversen Elektronikprojekten, wie z.B. STK-LAN (AVR im Netzwerk mit HTTPD, SNMP,...), UV-LED-Belichter, HPGL-Plotter.&lt;br /&gt;
*[http://www.funktermin.de Funkuhr FT1] Funkuhr mit programmierbaren Terminkalender, Kalenderwochenanzeige und optischen Stundenschlag (Anzeige der empfangenen Daten vom Zeitzeichensender DCF77)&lt;br /&gt;
* [http://phil-zone.de/ Philips Projektsammlung] Elektronik Projekte (µC,CMOS,Analog,...), Tutorials und nützliche Online-Tools&lt;br /&gt;
==== Schnittstellen ====&lt;br /&gt;
===== TCP/IP =====&lt;br /&gt;
* Kostengünstige und schnelle WLAN Anbindung an Mikrocontroller mit Wiz610wi. Bezugsquelle inkl. praktischer Adapterplatine bei: [http://www.shop.display3000.com/elektronikmodule/ethernet-wlan/index.html Display3000]&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/eNet-sam7X.php eNet-sam7X] Embedded Ethernet Modul im DIL64 Format mit kompletten OpenSource Board Support Packake auf Ethernut / Nut/OS Basis. Industrie geeignet&lt;br /&gt;
* [http://www.ethersex.de/index.php/Feature_Liste Ethersex] - Trotz des bescheuerten Namens sehr empfehlenswert. Viele flexibel einbindbare Module für diverse Hardware.&lt;br /&gt;
* [http://wiki.neo-guerillaz.de OpenMCP] Bekanntes Board auf Basis des ATmega2561 und ENC28j60. Läuft auch auf dem AVR-NETIO und dem myAVR.&lt;br /&gt;
* http://www.circuitcellar.com/AVR2006/winners/DE/AT2581.htm MEGA128(CAN) PCMCIA&lt;br /&gt;
* [https://berlin.ccc.de/wiki/AVR-Board_mit_Ethernet AVR-Board mit Ethernet mit dem ENC28J60 von Microchip]&lt;br /&gt;
* [http://www.roland-riegel.de/mega-eth/ AVR-Ethernet-Board mit extra SRAM, SD/MMC, USB und zugehöriger Software]&lt;br /&gt;
===== CAN =====&lt;br /&gt;
* [http://www.edevices.lt/  www.edevices.lt ] - USB2CAN inexpensive USB to CAN bus converter&lt;br /&gt;
===== USB =====&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php eUSB-162 und eUSB-LCD] - At90USB162 basiertes universelles USB Prototypen / Mikrocontroller Modul und USB Terminal Interface für HD44780 kompatible LCDs auf Basis der Lufa Library&lt;br /&gt;
* [http://www.obdev.at/products/vusb/index-de.html V-USB] &amp;amp;#8211; USB-Implementation in C nach gleichem Prinzip wie Igor-Plug, aber einfacher zu verwenden, GPL-ähnliche Lizenz (Nutzung des Projekts &#039;&#039;erfordert&#039;&#039; Veröffentlichung), englisch kommentierter Code&lt;br /&gt;
* [http://www.eltima.com/products/usb-over-ethernet/ USB to Ehternet Connector] - Share your USB devices via LAN/Internet&lt;br /&gt;
* [http://www.rahand.eu Mega8D12] - Schritt für Schritt zum virtuellen COM-Port. Ein Einsteiger-Tutorial zur CDC-Klasse mit Schaltung und Firmware (ATmega8 und PDIUSBD12).&lt;br /&gt;
* http://www.maares.de/tools USB_ISO: Isolierter Schnittstellenwandler USB auf RS232 (TTL) mit FT232RL und ADUM1402. Galvanische Trennung für das Zielsystem.&lt;br /&gt;
* [http://www.embedded24.net USB HID Host Treiber] - USB HID Treiber Bibliothek für Windows (Demo Projekt für Visual Studio C++).&lt;br /&gt;
* [http://Dworkin-DMX.de Konverter RS232 zum DMX512] Steuerung DMX-fähigen Geräten mit einem PC. Es gibt Low cost Variante zum selber basteln.&lt;br /&gt;
* [http://www.hoelscher-hi.de/hendrik/light/profile.htm Hennes Sites] Bauanleitungen für DMX-Dimmerpacks, DMX-Switchpacks, PWM-Controller, ... Tutorial für Senden und Empfangen von DMX-Daten mit AVRs.&lt;br /&gt;
* [http://digital-enlightenment.de Digital Enlightenment ]Verschiedene DMX-Selbstbauprojekte&lt;br /&gt;
===== PS2 =====&lt;br /&gt;
===== LANC =====&lt;br /&gt;
* [http://dsc.ijs.si/3dlancmaster/ 3D LANC Master from Damir Vrancic] is a device which keeps in synchronisation some of Sony camcorders by using LANC (CONTROL-L, ACC) protocol. (Open Hardware + Open Source, Atmega8).&lt;br /&gt;
* [http://jochendony.homeip.net/content/view/22/26/ LANC Lib] for AVRGCC. Read and write LANC commands.&lt;br /&gt;
* [http://blog.makezine.com/archive/2008/12/controlling_sony_camcorders_with_th.html Controlling Sony camcorders with the Arduino]&lt;br /&gt;
* http://arm.hsz-t.ch MMC, SD, SDHC Kartentreiber für ARM7 Mikrocontroller&lt;br /&gt;
* [http://www.mikrocontroller.net/articles/FAT32 Wiki und FAT16/32 Bibliothek für atmega]&lt;br /&gt;
===== Text (character-mode) HD44870 =====&lt;br /&gt;
* Bray&lt;br /&gt;
* [http://www.simon-brenner.ch/projekte/lcd-display 4x40 LCD Projekt, Microchip]&lt;br /&gt;
* [http://www.tklinux.de/sed1330.html SED1330 an ATMega]. Library für SED 1330 controller an ATmega&lt;br /&gt;
===== Siemens S55/C60 =====&lt;br /&gt;
* [http://www.module.ro/siemens_lcd.html S55-Display Pinbelegung]&lt;br /&gt;
* [http://www.mikrocontroller.net/topic/22643 Forumbeitrag]&lt;br /&gt;
* [http://www.jtronics.de/elektronik-avr/lcd-display-nokia3310 Bibliothek für Nokia 3310 Lcd Ansteuerung in &amp;quot;C&amp;quot; von http://www.jtronics.de - sehr gut (aktualisiert 2010)]&lt;br /&gt;
* [http://www.myplace.nu/mp3/download/download.php Yampp 7 Software Download Seite]: Archiv &amp;quot;yampp-7 with colour LCD firmware&amp;quot; enthält avr-gcc/avr-as Routinen für 6100-LCDs mit Philips- oder Epson-Controller (nicht direkt eine &amp;quot;Library&amp;quot;)&lt;br /&gt;
* avrfreaks UP&lt;br /&gt;
* [http://pic-projekte.de/index.php/ks01078.html PIC-Projekte.de] Ansteuern eines KS0107/8 Controllers in ASM mit PIC&lt;br /&gt;
====GPS====&lt;br /&gt;
* [http://mcu8051ide.sourceforge.net/ MCU 8051 IDE] - MCU 8051 IDE is a new modern graphical IDE for microcontrollers based on 8051. MCU 8051 IDE is noncommercial open-source software for Linux.&lt;br /&gt;
* [http://www.rakers.de/catalog Dr. Rakers] Entwicklungssystem mit C-Compiler, BASIC-Compiler und Makroassembler für alle 8051-Mikrocontroller (80C552, 80C515(C), 80C537). Auch für Hobbyisten bezahlbar.&lt;br /&gt;
* [http://www.maxim.ph.tc Selbstbau-Programmer] für 2051er&lt;br /&gt;
* [http://home.t-online.de/home/s.holst/sh51/index.html Mikrokontroller sh51] Schaltplan für 80C535-Board&lt;br /&gt;
* [http://turbo51.com Turbo51 - Free Pascal compiler for 8051]&lt;br /&gt;
* [http://self8051.de/ self8051.de] - Dein Nachschlagewerk - Befehlsreferenz, Eigenschaften, Derivate&lt;br /&gt;
* [http://cmon51.sourceforge.net/ CMON51] - freier Onboard Monitor und Debugger, anpassbar an unterschiedliche 8051 kompatible Mikrocontroller&lt;br /&gt;
== MSP430 ==&lt;br /&gt;
* [http://www.mikekohn.net/micro/naken430asm_msp430_assembler.php naken430msp] -   MSP430 Assembler von Michael Kohn (GPL)&lt;br /&gt;
* TI Design-Wettbewerb: http://www.designmsp430.com/View.aspx (Dateien liegen evtl. in /projects/) [2011-01-24: redirect zum TI Wiki, Projekte nicht mehr vorhanden]&lt;br /&gt;
* [http://www.sics.se/project/mspsim MSPsim] - a Java-based simulator of MSP430 sensor network platforms (BSD License (revised))&lt;br /&gt;
* [http://develissimo.net/de/msp430entwicklung MSPGCC + Eclipse + msp430-gdbproxy / Linux / Debian / Ubuntu] - Anleitung / Tutorial zur Installation der MSPGCC Toolchain + Eclipse + msp430-gdbproxy für Linux / Debian / Ubuntu Lang=Deutsch und Englisch&lt;br /&gt;
* [http://travisgoodspeed.blogspot.com/ Travis Goodspeed&#039;s Blog] - Home of the [http://goodfet.sourceforge.net/ GoodFET] Programmer&lt;br /&gt;
* [http://www.43oh.com/ Four-Three-Oh!]&lt;br /&gt;
=== MSP430 Launchpad ===&lt;br /&gt;
* [http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_(MSP-EXP430G2)?DCMP=launchpad&amp;amp;HQS=Other+OT+launchpadwiki MSP430 LaunchPad Wiki] bei TI&lt;br /&gt;
* [http://hackaday.com/2010/08/11/how-to-launchpad-programming-with-linux/ How-to: Launchpad programming with Linux] auf hackaday.com&lt;br /&gt;
* [http://springuin.nl/en/articles/launchpadwindows TI Launchpad programming and debugging with Open Source tools on Windows] (Eclipse, MSPGCC4, Insight, msp430-gdbproxy)&lt;br /&gt;
=== EZ430 Chronos ===&lt;br /&gt;
* [http://processors.wiki.ti.com/index.php/EZ430-Chronos?DCMP=Chronos&amp;amp;HQS=Other+OT+chronoswiki EZ Chronos Wiki] bei TI&lt;br /&gt;
== ARM ==&lt;br /&gt;
* [http://www.energymicro.com/ Energy Micro] EFM32 mit Cortex M3 Kern&lt;br /&gt;
* [http://www.intel.com/design/intelxscale/ Intel XSCALE Startseite], siehe auch [http://www.marvell.com/ Marvell]&lt;br /&gt;
* [http://www.luminarymicro.com/ Luminiary Micro (TI)] Controller mit Cortex M3 core&lt;br /&gt;
* [http://www.standardics.nxp.com/microcontrollers/ NXP (ehemals Philips) Microcontroller Startseite] für sämtliche Mikrocontroller (ARM7, ARM9, Cortex-M0, -M3, MCS51 etc.), neben LPC2000, LPC3000 auch die LH7xxxx BlueStreak-Serie (ehemals Sharp Microelectronics)&lt;br /&gt;
* [http://www.lpc2000.com lpc2000.com] Infoseite für NXP (ex. Philips) LPC1700 Cortex-M3 basierende Typen, LPC2000, ARM7 basierende Typen und LPC3000, ARM9 basierende Typen. Auch andere Cortex-M3 Bausteine sind erfasst&lt;br /&gt;
* [http://mcu.st.com/mcu/ STMicroelectronics (ST) Microcontroller Startseite] u.a. STR7, STR9, STM32 Support-Forum&lt;br /&gt;
* [http://www.toshiba.com/taec/ Toshiba] Controller mit ARM9 und Cortex-M3 core&lt;br /&gt;
* [http://arm.hsz-t.ch arm.hsz-t.ch] Einfühung in ARM7 Mikrocontroller und uClinux.&lt;br /&gt;
* [http://tech.groups.yahoo.com/group/ADuC7000/ ADuC7000 Yahoo-Group]&lt;br /&gt;
* [http://www.codesourcery.com/archives/arm-gnu/maillist.html Sourcery G++ Lite Edition User Forum/Mailing-List]&lt;br /&gt;
* [http://www.keil.com/forum/ Keil/ARM Forum]&lt;br /&gt;
* [http://www.mcu-related.com MCU related] Neuigkeiten zu MCUs, überwiegend ARM / Cortex-M3 basierend mit Vergleichen von RTOS und anderen Entwicklungstools&lt;br /&gt;
* [http://forum.sparkfun.com/ Sparkfun Foren]&lt;br /&gt;
* [http://www.stm32circle.com/ Forum for STM32 moderated by Raisonance] Sehr viele Beispielprogramme in Source fuer STM32 und den Primer2 von Raisonance&lt;br /&gt;
* [http://www.st-angliamicro.com/software.asp Anglia Idealist IDE und Anglia Toolchain] GNU toolchain für Win32-hosts inkl. Beispielen für STR7, STR9 und STM32. IDE kostenlost aber registrierungspflichtig&lt;br /&gt;
* [http://atollic.com/ attolic] TrueSTUDIO&lt;br /&gt;
* [http://www.codesourcery.com/gnu_toolchains/ Codesourcery] GNU Toolchains für ARM (Hosts: Linux, MS Windows, Solaris; Targets: arm-elf, arm-linux, SybianOS)&lt;br /&gt;
* [http://devkitpro.org/ devkitPro/devkitARM] GNU-Toolchain für MS-Windows &amp;quot;Hosts&amp;quot;. Vor allem auf GBA abgestimmt aber auch für andere ARM-Controller geeignet (arm-elf)&lt;br /&gt;
* [http://www.hitex.de Hitex] IDE für diverse Compiler, Debugger&lt;br /&gt;
* [http://www.keil.com Keil/ARM RVDK/uVision] kommerzielle IDE/Compiler, unterstützt zwei Compiler (ARM RealView, GNU/gcc), codegrößenbeschränkte Evaluierungsversion verfügbar (IDE/Compiler unbeschränkt für GNU), guter Debugger, guter Simulator (teilw. mit Hardwaresimulation) Simulator und Debugger in der Evaluierungsversion auch bei Nutzung der GNU-Toolchain auf 16kB beschränkt&lt;br /&gt;
* [http://mct.de/download.html#free MCT Demoversion C-Compiler für ARM und 68k] ARM C-Compiler basiert auf GCC laut Herstellerinformation jedoch mit Codegrößenbeschränkung &amp;lt;!-- etwas ungewöhnlich: Codegrößenbeschränkung bei GNU-Toolchain --&amp;gt;&lt;br /&gt;
* [http://www.raisonance.com/ Raisonance] Ride, RKit-ARM&lt;br /&gt;
* [http://www.yagarto.de Yagarto] GNU arm-elf-Toolchain, Eclipse, OpenOCD für Win32 inkl. Setup&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index.html#winarm WinARM] eine an WinAVR angelehnte Sammlung von Entwicklungswerkzeugen (binutils, arm-elf-gcc, newlib, &#039;&#039;newlib-lpc&#039;&#039;, Programmers Notepad, &#039;&#039;Beispiel-Makefiles und Beispielcode&#039;&#039;) für alle ARM-Controller. Beispiele für Philips LPC2000 und Atmel AT91SAM7S (ARM7TDMI) u.a.&lt;br /&gt;
* [http://rtlab.tekproj.bth.se/wiki/index.php/Dissy#Architecture_support Dissy] is a disassembler for Linux and UNIX which supports multiple architectures and allows easy navigation through the code. Dissy is implemented in Python and uses objdump for disassembling files.&lt;br /&gt;
* [http://www.sinelabore.com sinelaboreRT] - generiert leicht lesbaren C-Code aus einer Zustandsmaschine. Die Generierung berücksichtig speziell die Bedürfnisse eingebetteter Echtzeitsysteme.&lt;br /&gt;
* http://arm.hsz-t.ch Entwicklungsumgebung für ARM7 Mikrocontroller basierend auf der Knoppix CD. Keine Harddisk installation nötig für uClinux.&lt;br /&gt;
* [http://openocd.berlios.de/web/ OpenOCD] Open On-Chip Debugger: Schnittstelle (&amp;quot;gdb-Server&amp;quot;) zwischen Wiggler-komaptiblem JTAG-Interface und GNU-debugger (gdb/Insight-gdb), ebenfalls Unterstützung für JTAG-Hardware auf FTDI2232-Basis, Flash-Programmierfunktion für LPC2k, AT91SAM7S u.a.&lt;br /&gt;
* [http://www.hjtag.com H-JTAG] RDI-Interface für Wiggler, Flash-Funktionen für diverse interne und externe Speicher&lt;br /&gt;
*[http://www.abatron.ch Abatron] BDI1000 &amp;amp; BDI2000, On-Chip Debuggers für ARM, 68k, Coldfire uvm.&lt;br /&gt;
* [http://www.amontec.com Amontec] JTAGkey, JTAGkey2(P): JTAG-Adapter auf Basis des FTDI2232(H) &lt;br /&gt;
* [http://www.hjtag.com/product_intro.html H-JTAG USB Emulator]&lt;br /&gt;
* [http://www.keil.com Keil/ARM ULINK/ULINK2/ULINK-ME] JTAG-Adapter, USB-Anschluss, wird von Keil uVision unterstützt, ULINK2 teilw. auch von Codesourcery G++ (lt. Hestellerangaben)&lt;br /&gt;
* [http://www.ronetix.at/peedi.html Ronetix Peedi]&lt;br /&gt;
* [http://www.segger.de Segger J-Link] JTAG-Adapter, USB-Anschluss, unterstützt z.&amp;amp;nbsp;B. von IAR, Keil uVision (via RDI) (OEM: IAR J-Link, SAM-ICE)&lt;br /&gt;
* [http://www.signalyzer.com/ Signalyzer] Signalyzer Tool, u.a. JTAG-Adapter auf Basis des FTDI2232&lt;br /&gt;
* [http://www.simonqian.com/en/Versaloon/index.html Simon Qians Versaloon]&lt;br /&gt;
* [http://patater.com/gbaguy/gbaasm.htm GBA ASM Tutorial] - ARM7 Assembler Tutorial mit arm-elf-as (&amp;quot;gcc&amp;quot;) (Allgemein und GBA)&lt;br /&gt;
* [http://www.sparkfun.com/datasheets/DevTools/SAM7/at91sam7%20serial%20communications.pdf AT91SAM7 Serial Communications] von James P. Lynch (PDF, www.sparkfun.com)&lt;br /&gt;
* [http://www.kaczurba.pl/aduc ADuC7000 Tutorial] von Witold Kaczurba (www.kaczurba.pl)&lt;br /&gt;
* [http://www.stromflo.de/dokuwiki/doku.php?id=xmega-c-tutorial XMEGA-C-Tutorial]&lt;br /&gt;
* [http://hubbard.engr.scu.edu/embedded/arm/armlib/ Procyon ARMlib-LPC2100] - Treiber, Beispiele (Lizenz: GPL, kaum weiterentwickelt)&lt;br /&gt;
* [http://www.standardics.nxp.com/support/documents/?type=software NXP BlueStreak] Code für LH7xxxx (ehemals Sharp)&lt;br /&gt;
* [http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index.html M. Thomas&#039; ARM Projekte] &amp;quot;Projectvorlagen&amp;quot; für AT91SAM7 und LPC2000 mit GNU-Toolchain Einsteiger-Projekte für AT91SAM7, LPC2000, ADuC7000 u.a. (u.a. Blinky, UART, Interrupt, C++, GLCD mit KS0108, DS18x20, DCF77, Anpassungen von FAT16/32-Libraries) &amp;lt;!-- noch mehr &amp;quot;Eigenwerbung&amp;quot; --&amp;gt;&lt;br /&gt;
* [http://mcu.st.com/ STMicro] Treiber und Beispiel für STR7, STR9 und STM32&lt;br /&gt;
* [http://www.luminarymicro.com/ Luminary Micro Driverlib] für Stellaris Cortex-M3&lt;br /&gt;
* [http://r2d2.stefanm.com/gps-tracker.html GPS-Tracker] mit Navigation auf LPC2103-Basis (Complier: GCC)&lt;br /&gt;
* [http://elua.berlios.de elua] Lua für ARM-controller&lt;br /&gt;
* [http://freemodbus.berlios.de/ FreeMODBUS] &amp;quot;A Modbus ASCII/RTU and TCP implementation&amp;quot; (für STR71x, AT91SAM7, LPC214x, auch: AVR, MSP430 u.a.)&lt;br /&gt;
* [http://bettyhacks.com BettyHacks] Freie Firmware für die &amp;quot;interaktive TV-Fernbedienung&amp;quot; betty-tv (ARM7tdmi, 2MB Flash, 160 x 128 Pixel 2 bit LCD, CC1100, IR, Lautsprecher,..)&lt;br /&gt;
* [http://www.bertos.org/ BeRTOS] is a completely free, open source, real time operating system (RTOS) suitable for embedded platforms. Runs on many microprocessors and microcontrollers, ranging from 8 bits to 32 bits CPUs and even PCs. &lt;br /&gt;
* [http://chibios.sourceforge.net/ ChibiOS/RT]&lt;br /&gt;
* [http://www.stm32circle.com/resources/upgrade.php Circle-OS for STM32] Kostenloses OS, sehr klein mit Basisfunktionen fuer STM32&lt;br /&gt;
* [http://coocox.org/ CoOS]&lt;br /&gt;
* [http://www.freertos.org/ FreeRTOS (.org!)] - &amp;quot;Real-Time-Kernel&amp;quot; unter anderem für ARM7 (LPC2xxx) auch AVR, MSP430, &#039;51er&lt;br /&gt;
* [http://sourceforge.net/projects/funkos/ FunkOS]&lt;br /&gt;
* [http://www.toradex.com/colibri_downloads/Linux/readme.txt Linux 2.4.29 für Toradex Colibri] basierend auf Intel XScale PXA270&lt;br /&gt;
* [http://www.linux4sam.org Linux4SAM] Informationen, Anleitungen und Code zur Anwendung von Linux auf AT91SAM9xxx&lt;br /&gt;
* [http://www.freertos.com/ NicheTask] (URL ist www.freertos.com aber hat nichts mit FreeRTOS(.org) zu tun)&lt;br /&gt;
* [http://www.ethernut.de/en/software/index.html Nut/OS] Echtzeitbetriebssystem für Mikrocontroller (ARM, AVR, AVR32, Cortex M3 u.A). Multitasking und vollständiger TCP/IP Stack inklusive. Leicht zu erlernen und viele Beispiele&lt;br /&gt;
* [http://nuttx.sourceforge.net/ NuttX RTOS] (ARM7TDMI port for TI TMS320C5471 also called a C5471 or TMS320DM180).&lt;br /&gt;
* [http://code.google.com/p/rt-thread/ rt-thread]&lt;br /&gt;
* [http://sourceforge.net/projects/scmrtos/ scmRTOS]&lt;br /&gt;
* [http://www.tnkernel.com/downloads.html TNKernel] - &amp;quot;Real-Time-Kernel&amp;quot; TNKernel ist ein kompakter und sehr schneller Echtzeitkernel unter anderem für ARM7 (Philips LPC2106/LPC21XX/LPC22xx, Samsung S3C44B0X, Atmel AT91SAM7S128, STMicroelectronics STR711FR2)&lt;br /&gt;
* [http://www.knif-elektronik.de/index.php/cPath/27/category/industrie-module-/-bausaetze.html/ KNIF-elektronik] Preisgünstige Industriemodule und Bausätze z.B GPS, W-Lan, Kamera,Bluetooth uvm. --&amp;gt;&lt;br /&gt;
&amp;lt;!-- Ist KEIN ARM-Board, falsche Rubrik! * [http://www.chip45.com/ chip45] Atmel AVR Module und Boards mit USB, RS232/485, CAN, Ethernet, Funkmodule, sowie ISP Programmieradapter --&amp;gt;&lt;br /&gt;
* [http://www.embedded-it.de/microcontroller/microcontroller-module.php Embedded-IT] eNet-sam7X: Ethernut kompatible Embedded Ethernet Mikrocontroller Boards für Industrie und Hobby auf ARM mit Nut/OS Betriebssystem sowie USB Module auf AVR Basis&lt;br /&gt;
* [http://www.mcu-raisonance.com/~primer-starter-kits__microcontrollers__tool~tool__T018:4enfvamuxbtp.html Primer2 from Raisonance] Focus auf STM32 mit sehr grossem Forum im STM32circle&lt;br /&gt;
* [http://www.skpang.co.uk/catalog/index.php SKPang electronics] Entwicklungsboards für diverse ARM7/9 (UK)&lt;br /&gt;
* [http://www.taskit.de taskit] [https://www.ledato.de/shop_content.php?coID=10 Development- und Header-Boards für AT91SAM7S/X], AT91RM9200, AT91SAM9&lt;br /&gt;
* [http://www.toradex.com/e/products.html Toradex] Colibri: Intel XScale PXA270 DevKit (Schweiz)&lt;br /&gt;
== [[PIC]] ==&lt;br /&gt;
* [http://www.powercontact.de Elektronikentwicklung von Systemtechnik LEBER] Offizieller Microchip Design Partner für professionelles Microcontroller Design und Hersteller von Leistungsstellern, Thyristorstellern und Halbleiterelais...&lt;br /&gt;
* [http://www.osterer.co.at www.osterer.co.at] Entwicklungs-Board mit integrierten Programmer/Debugger für PIC18F4550.&lt;br /&gt;
* [http://www.martins-elektronikwelt.tk www.martins-elektronikwelt.tk] ICD1-Debugger-Nachbau im Kleinstformat u. SMD Technik (so groß wie eine halbe Scheckkarte).&lt;br /&gt;
* [http://pic-projekte.de/ PIC-Projekte.de] Sehr gut geschriebene Tutorials und Projekte mit erklärten Codesnipseln. Besonders geeignet für Anfänger!&lt;br /&gt;
* [http://www.fernando-heitor.de PIC: Programmierung in CCS (www.fernando-heitor.de)] Dies ist eine weitere Seite die dem Anfänger, der sich mit PICs beschäftigt, auf die Beine hilft. Sie befasst sich hauptsächlich mit dem CCS-Compiler und hat dazu ein sehr gutes Tutorial. Ausserdem bietet die Seite ein Forum speziell für PIC Mikrocontroller.&lt;br /&gt;
* [http://www.cc5x.de CC5X] Programmierkurs für PIC-Mikrocontroller in C (CC5X Compiler)] Programmierkurs mit Beispielen und Schaltplänen, fertige Hardware- und Softwarelösungen. In diesem Kurs sind auch einige Unterprogramme detailliert erklärt.&lt;br /&gt;
* [http://members.aon.at/electronics/pic/picpgm/index.html PICPgm - A free and simple PIC Development Programmer Software for Windows and Linux] Einfacher PIC Programmer für Windows und Linux. Unterstützt eine Vielzahl von PIC-Chips und wird ständig erweitert. Derzeit können PIC10F, PIC12F, PIC16F, PIC18F, PIC24H  sowie dsPIC30F und dsPIC33F programmiert werden.&lt;br /&gt;
* [http://usbpicprog.org/ usbpicprog], an open source Microchip PIC programmer for the USB port. A wxWidgets based (cross platform) application to communicate with the usbpicprog hardware / firmware. This application is known to function well on Linux, Windows (XP or later) and Macosx.&lt;br /&gt;
* [http://www.uchobby.com/index.php/2008/04/19/pic-development-linux-style/ How to setup for PIC microcontroller development on Linux] von Steven Moughan&lt;br /&gt;
* [http://www.dattalo.com/gnupic/gpsim.html#docs gpsim] is a full-featured software simulator for Microchip PIC microcontrollers distributed under the GNU General Public License.&lt;br /&gt;
* [http://www.mtoussaint.de/yapide.html YaPIDE] aims to be a fully featured Microchip PIC simulator for Linux (and probably other UNIXes). YaPIDE is a GUI only application. If you need a commandline based PIC simulator there is the excellent &#039;&#039;&#039;gpsim&#039;&#039;&#039;. The simulator kernel currently supports the PIC 16F628.&lt;br /&gt;
* [http://piklab.sourceforge.net/ Piklab] is an integrated development environment for applications based on Microchip PIC and dsPIC microcontrollers similar to the MPLAB environment. It integrates with several compiler and assembler toolchains (like gputils, sdcc, c18) and with the simulator &#039;&#039;&#039;gpsim&#039;&#039;&#039;. It supports the most common programmers (serial, parallel, ICD2, Pickit2, PicStart+) and debuggers (ICD2).&lt;br /&gt;
* [http://dev.frozeneskimo.com/software_projects:vpicdisasm vPICdisasm] is a Microchip PIC Mid-Range family firmware disassembler. This single-pass disassembler can read Intel HEX and Motorola S-Record formatted files containing valid PIC firmware. (GPL)&lt;br /&gt;
* [http://pikdev.free.fr/ PiKdev] is a simple graphic IDE for the development of PIC-based applications. It currently supports assembly language. C language is also supported for PIC 18 devices. PiKdev is developed in C++ under Linux and is based on the KDE environment.&lt;br /&gt;
* [http://www.yenka.com/en/Yenka_PICs/ Yenka PICs] lets you write routines using simple flowcharts, and test them on-screen, before using them to program real PIC or PICAXE chips. To help spread the news about Yenka, we&#039;re offering free copies of Yenka PICs for use at home or school.&lt;br /&gt;
* [http://pic-projekte.de/phpBB3/ Das deutsche PIC Forum] Diskutieren Sie mit anderen über PIC und stellen Sie Fragen zu Ihren Problemen. Das deutschsprachige PIC-Forum&lt;br /&gt;
* [http://gcbasic.sourceforge.net/ Great Cow BASIC] &amp;quot;Open Source BASIC programming tools for Microchip PIC and Atmel AVR microcontrollers&amp;quot;&lt;br /&gt;
* [http://www.martins-elektronikwelt.tk www.martins-elektronikwelt.tk] Viele Projekte mit den PIC Mikrocontrollern, u.a. SMS-Schaltzentrale, SD/MMC-FAT32-MP3-Player, Lichtschranken, Funk-Wetterempfänger, PS/2 am PIC usw.&lt;br /&gt;
* [http://www.Firmware-On-Demand.com Firmware-On-Demand] Umfangreiche Firmware-Bibliothek. &lt;br /&gt;
* [http://www.circuitcellar.com/microchip2007/ Microchip 16-Bit Embedded Control 2007 Design Contest] bei [http://www.circuitcellar.com/ Circuit cellar]&lt;br /&gt;
* [http://mondo-technology.com/ Mondo Technologiy] Grosse Ansammlung von PIC-Projekten, u.a. SuperProbe: Logic Probe,(Auf der linken Seite ganz oben) Logic pulser, Frequency Counter, Event Counter, Voltmeter, Diode Junction Voltage, Capacitance Measurement, Inductance Measurement, Signal Generator, Video Patern, Serial Ascii, Midi Note, R/C Servo, Square Wave, Pseudo Random Number, ir38, PWM in einem... (PIC16F870)&lt;br /&gt;
* [http://micrognurtos.sourceforge.net uGNU/RTOS] is a microcontroller-targeted serial real time operating system. It has been ported to USART capable Microchip PIC16 devices. It supports I/O operations and some internal registry operations. The user can interact with the chip through the RS-232 serial cable and a shell. The user can type a small list of commands and see the results on the chip&#039;s outputs. (LGPL)&lt;br /&gt;
* [http://pic-projekte.de www.PIC-Projekte.de] Hier finden sich einige interessante Projekte mit PIC Mikrocontrollern (z.B. Anleitung zum Ansteuern eines HD44780 komp. LCD von eA, KS0107/8 ansteuern in ASM) sowie Erklärungen zu den dazugehörigen Programmabschnitten. Außerdem gibt es eine Anleitung zum Herrstellen von Platinen. Besuchen Sie das [http://pic-projekte.de/phpBB3/index.php PIC-Forum] und diskutieren Sie mit bei spannenden Themen. Wenn Sie Fragen zu PIC µC der Firma Micochip haben, dann sind Sie hier richtig aufgehoben!&lt;br /&gt;
* [http://pic16f628a.blogspot.com/ Experiments with PIC16F628A] - PIC Programming in C&lt;br /&gt;
&amp;lt;!-- * [http://www.picguide.org PIC Guide] Eine große Sammlung von PIC-Projekten für den Anfänger 6.9.2010: nur cPanel Standard Seite --&amp;gt;&lt;br /&gt;
*Stevy&#039;s Homepage http://stevy.bplaced.com Pic Projekte die in C geschriebn wurden z.B 3D Engine, Grafik Display Ansteuerungen, Oszilloskip usw&lt;br /&gt;
* [http://www.simon-brenner.ch/projekte/rgb-led-stripe RGB Stripe mit 16bit Bus, realisiert mit PIC12F629]&lt;br /&gt;
* [http://scifi.pages.at/drakesoft/aulem_mypong/ Spiel PONG] auf einer 16x16 LED Matrix mit Ton, realisiert auf einem AVR.&lt;br /&gt;
== [[Z8]] ==&lt;br /&gt;
* [[Zilog Encore Experimentierplatine]] (Z8F6421 Familie mit DIP-40 Gehäuse)&lt;br /&gt;
*[http://www.thpeter.net Zilog Projekte] (Ein Z8Encore und ZNEO Projekt und viele Tips zum Programmieren und Debuggen)&lt;br /&gt;
&amp;lt;!-- * [http://www.z8micro.com/forum/ Z8 Encore! Microcontroller Discussion Forum - Dedicated to the ZiLOG Z8 Encore! Microcontroller] Ein der Z8 Encore!-Mikrocontrollerfamilie gewidmetes Diskussionsforum (in Englisch). - Link tot 6.9.2010 --&amp;gt;&lt;br /&gt;
* [http://www.cmosexod.com/ CMOSExod], Designs unter &#039;Free IP&#039;&lt;br /&gt;
* [http://www.fpga-forum.com/wbb Forum mit allgemeinen Diskussionen zum Thema FPGA und FAQ&#039;s speziell zu den Cesys FPGA Karten]&lt;br /&gt;
* [http://www.cesys.biz Online Shop für Cesys FPGA Karten]&lt;br /&gt;
== DSP ==&lt;br /&gt;
== Wettbewerbe (Contests) == &lt;br /&gt;
Verschiedene Hersteller veranstalten zur Promotion ihrer Produkte Designwettbewerbe, aus denen teilweise komplette Projektunterlagen hervorgehen (Schaltung, Source).&lt;br /&gt;
&#039;&#039;&#039;2011&#039;&#039;&#039;&lt;br /&gt;
*[http://www.555contest.com 555 Contest]&lt;br /&gt;
*[http://www.circuitcellar.com/nxpmbeddesignchallenge/ NXP and ARM/mbed challenge]&lt;br /&gt;
*[http://www.ebv.com/en/products/stm32-design-contest.html STM32 Design Contest] von EBV Elektronik und STMicroelectronics&lt;br /&gt;
* [http://www.renesasrulz.com/community/rx-contest The RX MCU Design Contest]&lt;br /&gt;
* [http://www.cypress.com/?id=3298 ARM Cortex-M3 PSoC® 5 Design Challenge]&lt;br /&gt;
* [http://www.instructables.com/contest/micro/ SparkFun Microcontroller Contest] bis 13.02.2011&lt;br /&gt;
* [http://www.elektroniknet.de/bauelemente/news/article/27963/0/Wer_entwickelt_die_beste_Anwendung_mit_dem_EFM32/ EFM32 Design-Wettbewerb] von Elektronik, Avnet-Memec und Energy Micro&lt;br /&gt;
&#039;&#039;&#039;2010&#039;&#039;&#039;&lt;br /&gt;
* [http://www.schmartboard.com/index.asp?page=mcu_2010 SchmartBoard 2010 MCU Challenge]&lt;br /&gt;
* [http://www.digilentinc.com/showcase/contests/designcontest.cfm?ContestID=6 Digilent Design Contest 2010]&lt;br /&gt;
* [http://www.parallax.com/go/holidaychallenge Parallax &amp;amp; iGen Student LED Holiday Challenge]&lt;br /&gt;
* [http://www.embeddedspark.com/upcomingchallenge/ The embeddedSPARK 2010 SUMMER Challenge]&lt;br /&gt;
* [http://www.libelium.com/tienda/catalog/contest.php?language=en Libelium Arduino Open Hardware Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/designstellaris2010/index.html Texas Instruments DesignStellaris 2010]&lt;br /&gt;
* [http://www.wizwiki.net/main/ iMCU Design Contest] (WIZnet)&lt;br /&gt;
* [http://www.elo-web.de/elo/entwicklung-und-projekte/ping-pong/elo-programmierwettbewerb-2010 ELO-Programmierwettbewerb 2010] (Atmega8, PingPong-Platine, 31.3.10)&lt;br /&gt;
* [http://www.lpc1100challenge.com/ NXP LPC1100 Design Challenge] (Cortex-M0 based LPC1100)&lt;br /&gt;
&#039;&#039;&#039;2009&#039;&#039;&#039;&lt;br /&gt;
* [http://arduinofun.com/blog/2009/11/01/fun-with-arduino-contest/ Fun with Arduino Contest]&lt;br /&gt;
* [https://www.xmos.com/challenge/ XMOS Challenge]&lt;br /&gt;
* [http://www.designmsp430.com/ Design MSP430 Ultra-Low Power Challenge]&lt;br /&gt;
* [http://makezine.com/halloweencontest/ Make: Halloween Contest 2009], sponsored by Microchip Technology!&lt;br /&gt;
* [http://www.bricogeek.com/contest/let-arduino-play/resultados.php Let Arduino Play Contest]&lt;br /&gt;
* [http://www.dlpdesign.com/designcontest/ DLP Design DLP-232PC Design Contest]&lt;br /&gt;
* [http://www.libelium.com/tienda/catalog/contest.php Arduino contest by Libelium]&lt;br /&gt;
* [http://www.expli.de/wettbewerb/coole-avr-microcontroller-elektronik-ideen/ EXPLI Elektronik Wettbewerb]: Die coolsten Elektronik Projekte &amp;amp; AVR Microcontroller Anleitungen&lt;br /&gt;
* [http://www.stm32circle.com/projects/contest.php STM32 Primer2 Design Competition 2009]&lt;br /&gt;
* [http://www.parallax.com/Resources/ApplicationsContests/Contests/200910PropellerContest/tabid/846/Default.aspx 2009/2010 Propeller Design Contest]&lt;br /&gt;
&#039;&#039;&#039;2008&#039;&#039;&#039;&lt;br /&gt;
* [http://www.parallax.com/tabid/720/Default.aspx Propeller Design Contest]&lt;br /&gt;
* [http://www.psocidcindia.com/index.php PSoC Innovator Design Challenge India 2008]&lt;br /&gt;
* [http://www.mypic32.com Microchip PIC32 Design Challenge]&lt;br /&gt;
* [http://contest.renesasinteractive.com/ HEW Target Server Design Contest 2008]&lt;br /&gt;
* [http://www.stm32circle.com/projects/result_contest_2008.php STM32 Primer Design Competition 2008]&lt;br /&gt;
&#039;&#039;&#039;2007&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/wiznet/index.html WIZnet iEthernet Design Contest 2007] &lt;br /&gt;
* [http://www.circuitcellar.com/microchip2007/ Microchip 16-Bit Embedded Control 2007 Design Contest]&lt;br /&gt;
&#039;&#039;&#039;2006&#039;&#039;&#039;&lt;br /&gt;
* [http://www.designmsp430.com/View.aspx 2006 MSP430 eZ Design Contest] &lt;br /&gt;
* [http://www.circellar.com/msp430/ MSP430 Design Contest]&lt;br /&gt;
* [http://www.luminarymicro.com/DesignStellaris2006 Luminary Micro DesignStellaris2006]&lt;br /&gt;
* [http://www.circuitcellar.com/avr2006/ Atmel AVR Design Contest 2006] &lt;br /&gt;
&#039;&#039;&#039;2005&#039;&#039;&#039;&lt;br /&gt;
* [http://www.jandspromotions.com/philips2005/index.htm Philips ARM Design Contest 2005] (LPC213x)&lt;br /&gt;
* [http://www.circuitcellar.com/renesas2005m16c/index.htm Renesas M16C Design Contest 2005]&lt;br /&gt;
* [http://www.edn.com/article/CA516007.html Cornelius van Drebbel&#039;s Mad Design Contest] (NEC)&lt;br /&gt;
&#039;&#039;&#039;2004&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/avr2004/ Atmel AVR 2004 Design Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/psoc2004/ PSoC High Integration Challenge 2004]&lt;br /&gt;
* [http://www.jandspromotions.com/zilog2004/ Zilog 2004 Flash Nets Cash Design Contest] (eZ80Acclaim!)&lt;br /&gt;
* [http://www.jandspromotions.com/wirelesschallenge/index.html 2004 Freescale Wireless Design Challenge] (MC13191/92/93 RF Transceivers, [[Meshnetics Zigbee|ZigBee]])&lt;br /&gt;
&#039;&#039;&#039;2003&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/fi2003/ MOTOROLA FLASH INNOVATION 2003 DESIGN CONTEST] (Motorola HC08)&lt;br /&gt;
* [http://www.circuitcellar.com/renesas/ Renesas H8 Design 2003 Contest]&lt;br /&gt;
* [http://www.jandspromotions.com/zilog2003/ ZiLOG Flash for Cash Z8 Encore®! International Design Contest]&lt;br /&gt;
* [http://www.jandspromotions.com/efield203/index.htm 2003 Motorola E-Field Sensor Contest] (MC33794)&lt;br /&gt;
&#039;&#039;&#039;2002&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/flash2002/ Mad Dash for Flash Cash] (Microchip, PIC)&lt;br /&gt;
&#039;&#039;&#039;2001&#039;&#039;&#039;&lt;br /&gt;
* [http://www.circuitcellar.com/dl2001/ Atmel &#039;Design Logic 2001&#039; Design Contest]&lt;br /&gt;
* [http://www.circuitcellar.com/msp430/ MSP430 Design Contest]&lt;br /&gt;
Siehe auch [[Linksammlung#Schnittstellen]]&lt;br /&gt;
=== Infrarot (IR) ===&lt;br /&gt;
* [http://www.sbprojects.com/knowledge/ir/ir.htm Übersicht IR-Protokolle] von San Bergmans (engl.): ITT, JVC, NEC, Nokia NRC17, Sharp, Sony SIRC, Philips RC-5, RC-6, RC-MM, RECS80, RCA, X-Sat&lt;br /&gt;
* [http://www.vishay.com/docs/80071/dataform.pdf Data formats for IR controls (PDF)] von Vishay.&lt;br /&gt;
* [http://www.projects-lab.com/?p=1139 ECPMON] - ECP Parallel Port Monitor ([[M16C]]/62P) &lt;br /&gt;
=== iPod ===&lt;br /&gt;
* [http://ipodlinux.org/IPod_to_T%26A_remotecontrol_adapter IPod to T&amp;amp;A remotecontrol adapter] ([[PIC]]-Projekt)(Link defect)&lt;br /&gt;
* http://jasongarr.wordpress.com/project-pages/ipod-clickwheel-hack/&lt;br /&gt;
=== [[RFID]] ===&lt;br /&gt;
* [http://www.alexanderguthmann.de/RFIDemulator.html RFIDemulator] - Beschreibung eines RFIDemulators zum klonen von Tags&lt;br /&gt;
http://www.message_bocracco.com/&lt;br /&gt;
* [http://dworkin-dmx.de/ USB DMX Interface] Bausatz /Fertiggerät USB DMX Interface  &lt;br /&gt;
* [http://www.marjorie.de/ps2/ps2_protocol.htm Das PS/2 Maus und PS/2- oder AT-Tastatur-Protokoll] (Original auf [http://www.computer-engineering.org/])&lt;br /&gt;
* [http://www.hth.com/snap/ S.N.A.P - Scaleable Node Address Protocol]. S.N.A.P is an free and open network protocol. The protocol was primary developed for PLM-24 based home automation and control systems but it is a generic protocol and not limited to this. S.N.A.P can be used in any type of applications where an easy to learn and light weighted network protocol is needed.&lt;br /&gt;
* [http://www.ulrichradig.de/home/index.php/avr/avr_-_rc PPM / PWM Encoder/Decoder für R/C Funkfernsteuerungen] von Ulrich Radig (AVR, C)&lt;br /&gt;
* [http://www.national.com/analog/interface/lvds_owners_manual LVDS Owner&#039;s Manual - 4th Edition] von National Semiconductor&lt;br /&gt;
* [http://www.mictronics.de/?page=becker Becker Unilink]&lt;br /&gt;
* [http://users.ntplx.net/~andrew/sony/unilink/ Sony UniLink]&lt;br /&gt;
* [http://www.vending.org/technology/MDB_Version_4.pdf Multi-Drop Bus / Internal Communication Protocol (MDB / ICP)]&lt;br /&gt;
siehe [[Platinenhersteller|Platinenhersteller]]&lt;br /&gt;
* [http://webcast.berkeley.edu/course_details.php?seriesid=1906978507 EE 42/EE 100 Introduction to Digital Electronics] - Webcast, Spring 2008 (englisch)&lt;br /&gt;
* [http://freevideolectures.com freevideolectures.com] - Webcasts zu  naturwissenschaftlichen Theman (englisch)&lt;br /&gt;
* [http://www.circuitsage.com/ Circuit Sage], a complete source of information to help you design circuits fast. (Linksammlung zu Software, Artikeln Büchern und Websites)&lt;br /&gt;
* [http://www.DieElektronikerseite.de Die Elektronikerseite] Umfangreiche Sammlung von kleinen Lehrgängen und Schaltungen. Ideal für Anfänger aber auch für Fortgeschrittene&lt;br /&gt;
* [http://homepages.internet.lu/absolute3/tronic/ 3D Virtual Development] - Sammlung von vielen Grundschaltungen im Bereich Oszillator, Operationsverstärker, Empfangstechnik. Vereinzelt in Englisch.&lt;br /&gt;
* [http://cws.gtc.edu/programs/objects/electronics.htm Learning Objects for Electronics] des Engineering Tech Wing of Gateway Technical College (Flash erforderlich)&lt;br /&gt;
* [http://ecee.colorado.edu/~bart/book/book/title.htm Principles of Semiconductor Devices] von Bart Van Zeghbroeck&lt;br /&gt;
* [http://itp.nyu.edu/physcomp/Intro/HomePage Introduction to Physical Computing] ([[AVR]], Arduino)&lt;br /&gt;
== Skripte ==&lt;br /&gt;
* [http://www.janson-soft.de/skripte/index.html Linksammlung von Volker Lange-Janson]&lt;br /&gt;
* [http://openbookproject.net//electricCircuits/index.htm Lessons in Electric Circuits I-VI] von Tony R. Kuphaldt&lt;br /&gt;
* [http://www.filmetrics.com  Filmetrics Inc.] (Filmetrics manufactures affordable thin-film measurement instruments capable of measuring thin films from 3nm to 0.5mm in thickness.)&lt;br /&gt;
* [http://www.pce-instruments.com  PCE Instruments] (Entwicklung und Produktion für Prüfgeräte und Waagen.)&lt;br /&gt;
* [http://www.pctestinstruments.com Intronix LogicPort], Günstiger, aber sehr leistungsfähiger Logikanalysator mit USB-Anschluß an PC (34Ch, 500MHz Timing, 34 x 2kSa mit Kompression, ca. 295 Euro [http://www.shop.display3000.com/elektronik/messgeraete/index.html hier])&lt;br /&gt;
* Zeroplus LAP-Cxxxx (Familie von LA&#039;s mit unterschiedlichen Daten, 32kBit...2MBit, 16ch oder 32ch, 100MHz..200MHz, Preise von 90,-...1100,- Euro, zu kaufen [http://www.tigal.com/products_category.asp?cid=96 hier])&lt;br /&gt;
* [http://www.hacker-messtechnik.de/13722/59001.html TravelLogic TL2x36], Logikanalysator zum Anschluß an PC über USB, (36ch, 4GHz timing, 200MHz state, Speicher bis 72MBit, Preis ab ca. 500,- netto)&lt;br /&gt;
* [http://www.saleae.com/logic/ logic] - Logik-Analyzer mit 8 Kanälen, mit Software zur Analyse von SPI, I2C, UART, etc... (ca 150$ + Versand/Zoll)&lt;br /&gt;
* [http://www.deditec.de/de/logikanalysatoren/prod/usb-logi-500.html DEDITEC USB-LOGI-500], kostengünstiges Einsteigermodell mit USB-Anschluß und dazugehöriger Software Logi+ (36Ch, Abtastrate 500MHz, 4096 Samples Speichertiefe/Kanal,  ca. 236 Euro)&lt;br /&gt;
* Eine Übersicht über verschiedene Selbstbauprojekte: [[Logic_Analyzer]]&lt;br /&gt;
* [http://www.timing-diagrams.com TimingAnalyzer] can be used to easily draw timing diagrams and perform timing analysis to find faults in digital logic systems. Written in Java, it runs on any platform that supports the Java Run-time Environment, JRE1.6.0 or Java Development Kit JDK1.6.0 or newer.&lt;br /&gt;
=== Foren ===&lt;br /&gt;
* [http://forum.sparkfun.com/ Spark Fun Electronics] MicroController Ideas and Support (Englisch) ([[AVR]], [[PIC]], [[MSP]], [[ARM]], OpenOCD)&lt;br /&gt;
* [http://formu.iwenzo.de Elektronik Reparatur Forum] Informationselektroniker Reparatur Forum&lt;br /&gt;
* [http://www.elektrikforum.de Elektrik-Forum] Forum zum Thema Elektroinstallationen&lt;br /&gt;
=== Videocasts und Podcasts ===&lt;br /&gt;
* [http://www.eevblog.com/ EEVblog] Electronics Engineering Video Blog von David L. Jones (englisch). &#039;&#039;Anm.: David ist Australier und das hört man. An die Sprechweise kann man sich aber gewöhnen. Und nicht erschrecken, wenn öfter mal ein drastisches Fourletterword auftaucht!&#039;&#039;&lt;br /&gt;
* [http://www.theamphour.com/ The Amp Hour] Podcast mit Chris Gammell und David Jones (englisch)&lt;br /&gt;
&amp;lt;!-- offline 4/2010&lt;br /&gt;
* [http://www.next.gr/ Next] Electronic Circuit Database&lt;br /&gt;
* [http://www.schaltplaene-online.de/ www.schaltplaene-online.de] Umfangreiche Linksammlung zu Schaltplänen aller Art&lt;br /&gt;
* [http://www.open-innovation-projects.org Open Innovation Projects] - Sammlung von offenen Projekten zu physischen Produkten, darunter etliche Mikrocontroller-Projekte. Man kann selber Projekte hinzufügen.&lt;br /&gt;
* [http://www.cs.net/lucid/intel.htm Intel-Hex-Format]&lt;br /&gt;
* [http://www.rev-ed.co.uk/docs/picaxe_manual3.pdf Microcontroller Interfacing Circuits] - Revolution Education Ltd.&lt;br /&gt;
* [http://www.digchip.com/application-notes/ Datenbank für &#039;&#039;Application Notes&#039;&#039;] bei www.digchip.com&lt;br /&gt;
* [http://www.nrbook.com/a/bookcpdf.php Numerical Recipes in C, Second Edition (1992)]&lt;br /&gt;
* [http://www.specamotor.de/freebook.php Electrical drives for precision engineering designs]  Prof.dr.ir. Compter&lt;br /&gt;
* [http://www.joretronik.de/Web_NT_Buch/Vorwort/Vorwort.html Das neue InterNetzteil- und Konverter-Handbuch] Dipl.-Ing. Jörg Rehrmann&lt;br /&gt;
** [http://www.makezine.com/ Makezine]&lt;br /&gt;
** [http://www.hacknmod.com/ Hack N&#039; Mod]&lt;br /&gt;
** [http://zedomax.com/blog/category/diy/ Zedomax DIY]&lt;br /&gt;
** [http://digital-diy.com Digital-DIY]&lt;br /&gt;
* Foren&lt;br /&gt;
domain expired&lt;br /&gt;
** Final Projects der Kurse [http://people.ece.cornell.edu/land/courses/ece4760/FinalProjects/ ECE4760] (Designing with Microcontrollers) und [http://people.ece.cornell.edu/land/courses/ece5760/FinalProjects/ ECE5760] (Advanced Microcontrollers) an der Cornell University &lt;br /&gt;
** [http://www.coolcircuit.com/gadgets/ Cool Circuit]&lt;br /&gt;
** [http://www.electronics-lab.com/blog/ Electronics-Lab.com Blog]&lt;br /&gt;
* DIY-Anleitungen&lt;br /&gt;
* Mix&lt;br /&gt;
** [http://www.ikalogic.com/index.php ikalogic.com]&lt;br /&gt;
** [http://elettrolinux.com elettrolinux] - Elektronik und Linux (engl.)&lt;br /&gt;
** [http://electronicfox.at.tf/ electronicfox] - Verschiedene Projekte mit [[AVR]], Fernbedienungen und deren Aufbau sowie Decoder und alten ICs aus dem Recyclinghof&lt;br /&gt;
** [http://www.techfocusmedia.net/archives/fresh-bytes/ Fresh Bytes von Techfocusmedia]&lt;br /&gt;
* [http://www.eue24.net/ E&amp;amp;E Faszination Elektronik] - Magazin für Elektronik-Entwickler und Elektronik-Interessierte&lt;br /&gt;
* [http://www.edn.com/ EDN] (etwas schwer zu finden, aber lesenswert: die [http://www.edn.com/channel/Design_Ideas.php Design Ideas] und das [http://www.edn.com/archive/ Archiv der Druckausgaben])&lt;br /&gt;
* [http://www.franzis.de/elo-das-magazin ELO - Das Magazin] für Elektronik-Einsteiger&lt;br /&gt;
* [http://techonline.com/ TechOnline]&lt;br /&gt;
* [http://www.elektor.de/ Elektor] &lt;br /&gt;
* [http://www.techbriefs.com/tech-briefs/electronics-techbriefs NASA Tech Briefs] - Electronics &amp;amp; Computers&lt;br /&gt;
* [http://et.nmsu.edu/~etti/ Technology Interface Journal]&lt;br /&gt;
* [http://dev.emcelettronica.com/ Your Electronics Open Source]&lt;br /&gt;
* [http://www.element-14.com element14.com] is an information portal and community specifically built for electronic design engineers.&lt;br /&gt;
* [http://www.itwissen.info ITWissen.info] (gutes Lexikon)&lt;br /&gt;
* [http://www.nutsvolts.com Nuts&#039;n&#039;Volts] Amerikanisches Elektronikmagazin mit Online Blog&lt;br /&gt;
* [http://de.rs-online.com/web/generalDisplay.html?id=eTech eTech] von RS Online&lt;/div&gt;</summary>
		<author><name>79.83.80.121</name></author>
