	<id>https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=91.115.132.241</id>
	<link rel="self" type="application/atom+xml" href="https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=91.115.132.241"/>
	<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/articles/Spezial:Beitr%C3%A4ge/91.115.132.241"/>
	<updated>2026-04-10T14:54:43Z</updated>
		<id>https://www.mikrocontroller.net/index.php?title=Logic_Analyzer&amp;diff=60897</id>
		<title>Logic Analyzer</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Logic_Analyzer&amp;diff=60897"/>
		<updated>2011-10-03T15:11:45Z</updated>
		<summary type="html">&lt;p&gt;91.115.132.241: /* BitHound Logic Anlyzer */&lt;/p&gt;
&lt;div&gt;Diese Seite enthält eine Übersicht über verschiedene Logic Analyzer &#039;&#039;&#039;Selbstbau-Projekte&#039;&#039;&#039;.&lt;br /&gt;
== AVR-basiert ==&lt;br /&gt;
=== LoLA ===&lt;br /&gt;
* ASM&lt;br /&gt;
LoLA is a 8-Bit Logicanalyzer. Internal sampletimes from 2us to 16ms. Triggerword with don&#039;t cares. External clock or trigger on rising or falling edge. Timing and state with I2C-analysis. 2k memory, very low cost.&lt;br /&gt;
* 2006 B. Sauter&lt;br /&gt;
* 8-Bit&lt;br /&gt;
* USB&lt;br /&gt;
=== µLab LA ===&lt;br /&gt;
* 2007 µLabs&lt;br /&gt;
* Mega 8&lt;br /&gt;
* 8-Bit, 24Mhz&lt;br /&gt;
* Ram zur Aufzeichnung&lt;br /&gt;
* LCD&lt;br /&gt;
* USB&lt;br /&gt;
* Software: Linux, zur Ausgabe von VCD&lt;br /&gt;
http://www.microlaboratories.com/?page_id=77&lt;br /&gt;
&#039;(Site down!)&#039;&lt;br /&gt;
* 8-channel&lt;br /&gt;
* 32kB SRAM&lt;br /&gt;
* RS232&lt;br /&gt;
* 2 MHz&lt;br /&gt;
&#039;&#039;&#039;Version 1&#039;&#039;&#039;&lt;br /&gt;
* bis 4 Kanäle&lt;br /&gt;
* Basis: Atmega16 und NAND-Gate&lt;br /&gt;
* http://www.ikalogic.com/scanalogic_home.php&lt;br /&gt;
&#039;&#039;&#039;Version 2 Pro&#039;&#039;&#039;&lt;br /&gt;
* bis 20 Million Samples per second&lt;br /&gt;
* Maximum sampling buffer 256K&lt;br /&gt;
* Generator/Playback Modus&lt;br /&gt;
* USB HID mode&lt;br /&gt;
* Firmware upgrade feature&lt;br /&gt;
* Basis: Atmel AVR&lt;br /&gt;
* Aufgebaut und getestet&lt;br /&gt;
* http://www.ikalogic.com/scanalogic2/&lt;br /&gt;
=== MiniLog ===&lt;br /&gt;
Zur Zeit gibt es zwei Versionen, die sich hauptsächlich in der Samplerate und in der Speichergröße unterscheiden:&lt;br /&gt;
&#039;&#039;&#039;50 MSa/s Version&#039;&#039;&#039;&lt;br /&gt;
* 8 Kanäle&lt;br /&gt;
* 50 MSa/s&lt;br /&gt;
* 4k Samplespeicher&lt;br /&gt;
* Trigger auf beliebige Pegelkombinationen &lt;br /&gt;
* Basis ATMega644&lt;br /&gt;
* FT232 USB 115200 Baud&lt;br /&gt;
&#039;&#039;&#039;80 MSa/s Version&#039;&#039;&#039;&lt;br /&gt;
* 16k Samplespeicher (32k bei neuer Software)&lt;br /&gt;
* Basis ATMega88 / ATMega48&lt;br /&gt;
* FT232 USB 500000 Baud&lt;br /&gt;
Weitere Infos und Diskussion:&lt;br /&gt;
* http://www.avr.roehres-home.de/logikanalyzer/index.html&lt;br /&gt;
* http://www.mikrocontroller.net/topic/141602&lt;br /&gt;
== FPGA / CLPD ==&lt;br /&gt;
&amp;lt;!-- &lt;br /&gt;
Deditec LAs sind keine Selbstbauprojekte, daher hier entfernt. Ggf. neuen Artikel aufmachen oder anderen, passenderen ergänzen. Danke.&lt;br /&gt;
* 36 Kanäle&lt;br /&gt;
* 2 Trigger Ebene&lt;br /&gt;
=== SUMP Logic Analyzer ===&lt;br /&gt;
* Java Software&lt;br /&gt;
Der SUMP Logic Analyzer hat wahlweise einen einfachen Trigger (Rising/Falling mit Maskierung) oder einen komplexen 4stufigen Trigger, sowie einen einfachen zuschaltbaren Noise Filter, der Pulse kürzer als 1/100 MHz filtert um Crosstalk-Effekte in den Anschlussleitungen zu kompensieren. Der Speicher wird im Wartezustand als &amp;quot;Ringstack&amp;quot; kontinuierlich beschrieben. Dadurch können auch Daten von vor der Trigger-Auslösung ausgelesen werden.&lt;br /&gt;
* [http://www.sump.org/projects/analyzer/ Projektseite bei sump.org]&lt;br /&gt;
* [http://logicanalyzer.sourceforge.net/ LogicAnalyzer] is a framework as well as an application to operate a PC based logic analyzer. It&#039;s built using the Eclipse RCP and designed with extensibiliy in mind. Integrating devices, providing tools or creating completely new functionality is easy. The most prominent OpenSource logic analyzer hardware (namely the SUMP Logic Analyzer - and derivates such as the [[Logic_Analyzer#OpenBench_Logic_Sniffer|Open Workbench Logic Sniffer]]) work out of the box. It also serves as an example how easy it is to integrate new devices. (GPL)&lt;br /&gt;
=== BitHound Logic Analyzer ===&lt;br /&gt;
Hier handelt es sich um eine Erweiterung des SUMP auf einen Spartan-6. &lt;br /&gt;
Es gibt zwei Versionen; eine für das Xilinx-SP601 Development Board und eine für das Digilent ATLYS-Spartan-6 Board. &lt;br /&gt;
Der Analyzer-Core ist (noch) derselbe wie beim SUMP, der Speicher ist nun jedoch 128MB gross und die Datenübertragung erfolgt per Ethernet zum ebenfalls leicht verbesserten JAVA-Client. &lt;br /&gt;
* [http://www.bastli.ethz.ch/index.php?page=BitHoundEn Projektseite von www.bastli.ethz.ch]&lt;br /&gt;
* 32 Kanäle&lt;br /&gt;
=== miniLA ===&lt;br /&gt;
Der LA basiert auf einem Xilinx CPLD&lt;br /&gt;
* Ankopplung über USB oder LPT (neuere Version von mockup: nur USB)&lt;br /&gt;
neuere Version von mockup: &lt;br /&gt;
* 512 kSamples bzw. 1MSamples&lt;br /&gt;
* Ankoppelung über USB&lt;br /&gt;
* [http://minila.sourceforge.net Projektseite]&lt;br /&gt;
* [[MiniLA]] Artikel auf www.mikrocontroller.net&lt;br /&gt;
* http://www.mikrocontroller.net/topic/174860 Forum&lt;br /&gt;
* http://www.mikrocontroller.net/articles/Minila_Version_MockUp Artikel&lt;br /&gt;
=== coolLA ===&lt;br /&gt;
coolLA ist eine erweiterte Version des miniLA. Die wesentlichen Änderungen sind:&lt;br /&gt;
* USB Stromversorgung mit galvanischer Trennung&lt;br /&gt;
* Einsatz einer Coolrunner II CPLD&lt;br /&gt;
* Time- und Stateanalyse umschaltbar zusammen im System mit angepasster Software&lt;br /&gt;
* 512k Samples Speicher 32 Bit&lt;br /&gt;
* integrierte Datenempfänger&lt;br /&gt;
* 40-poliger IDE Stecker Intronix LogicPort kompatibel&lt;br /&gt;
* passt in Elpac Gehäuse&lt;br /&gt;
* [http://coolla.freeunix.net Projektseite mit Bilder und Download]&lt;br /&gt;
* [http://www.mikrocontroller.net/topic/175219#1682430 Forumbeitrag] von Wolfgang R. (portside)&lt;br /&gt;
* 24 Kanäle&lt;br /&gt;
* 32 channels&lt;br /&gt;
Die Software hat Interpreter für RS232, SPI, I2C, 1-Wire und einen A/D-Wandler.&lt;br /&gt;
Eine fertige Platine gibts von www.Seeedstudio.com für 50$ oder in Deutschland bei http://www.watterott.com/de/Open-Logic-Sniffer für 45,22€ inkl. Versand.&lt;br /&gt;
== PIC-basiert ==&lt;br /&gt;
=== PIC Logicx ===&lt;br /&gt;
[http://martin.hinner.info/electronics/piclogix/ PIC Logix] (GPL, optional Standalone VGA Ausgabe, PIC24 or dsPIC33)&lt;br /&gt;
=== Logic Analyzer III (USB) ===&lt;br /&gt;
[http://technology.niagarac.on.ca/people/mcsele/LogicAnalyzer.html Logic Analyzer III (USB)] uses a multithreaded Win-32 front-end and a native USB interface. It features a 20MS/s sample rate and a 4K sample depth. Zentrale Bauteile sind ein PIC18F4550 Mikrocontroller und ein AM7204 FIFO IC z.B. von AMD.&lt;br /&gt;
=== pk2-la ===&lt;br /&gt;
* Hardware: PICkit 2 Programmer Logic Tool Analyzer&lt;br /&gt;
** 3 Kanal bis 500 kHz&lt;br /&gt;
** http://www.microchip.com/pickit2&lt;br /&gt;
* Software: &lt;br /&gt;
** [http://pk2-la.sourceforge.net/ pk2-la]. The Microchip PICkit 2 has the ability to act as a logic analyzer and I/O probe. This project provides a reverse engineered libusb user space device driver and GUI to provide this functionality for users of unsupported operating systems. (Python, Lizenz: GPL)&lt;br /&gt;
== Parallelport LA ==&lt;br /&gt;
Bitte beachten: Derartige Parallelport LAs sind z.B. bei der Samplerate durch die PC-Hardware und das PC OS im Vergleich zu höherwertigen LAs eingeschränkt.&lt;br /&gt;
* [http://tfla-01.berlios.de/ The Fabulous Logic Analyzer] (GPL, multiplatform, Simple [[I2C]] analyzer)&lt;br /&gt;
* [http://akikorhonen.org/projects.php?action=view&amp;amp;id=59 Parallel port logic analyzer]&lt;br /&gt;
* [http://uvasux.googlepages.com/simplelogicanalyser Simple Logic Analyser]&lt;br /&gt;
* [http://www.xs4all.nl/~jwasys/old/diy2.html A logic analyzer using the PC&#039;s parallel port] (Win32)&lt;br /&gt;
* [http://www.codeproject.com/KB/system/17ChannelLogicAnalyzer.aspx 17 Channel Logic Analyzer] By Elmue auf www.codeproject.com (Windows)&lt;br /&gt;
&#039;&#039;[http://logicanalyzer.sourceforge.net/ LogicAnalyzer] is a framework as well as an application to operate a PC based logic analyzer. It&#039;s built using the Eclipse RCP and designed with extensibiliy in mind. Integrating devices, providing tools or creating completely new functionality is easy.&lt;br /&gt;
LogicAnalyzer main features:&lt;br /&gt;
* Platform independent ( LogicAnalyzer is built using Eclipse RCP, thus it&#039;s mostly platform independent. It also features a native and clean UI.)&lt;br /&gt;
* Rich set of tools ( Several tools come out of the box, such as frequency measurement, distance measurement and serial byte interpreter. LA also comes with an I2C protocol analyzer (SPI, as well as UART analyzer will follow).)&lt;br /&gt;
* SUMP integration ( The most prominent OpenSource logic analyzer hardware (namely the SUMP Logic Analyzer - and derivates such as the Open Workbench Logic Sniffer) work out of the box. It also serves as an example how easy it is to integrate new devices.)&lt;br /&gt;
== Sonstiges ==&lt;br /&gt;
* [http://sigrok.org/wiki/Logic_Analyzer_Comparison sigrok: Logic Analyzer Comparison] (TODO: evtl. dort sowie hier Einträge synchronisieren)&lt;br /&gt;
		<author><name>91.115.132.241</name></author>
