	<id>https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=Gjlayde</id>
	<link rel="self" type="application/atom+xml" href="https://www.mikrocontroller.net/api.php?action=feedcontributions&amp;feedformat=atom&amp;user=Gjlayde"/>
	<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/articles/Spezial:Beitr%C3%A4ge/Gjlayde"/>
	<updated>2026-05-17T22:46:42Z</updated>
	<generator>MediaWiki 1.43.8</generator>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107742</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107742"/>
		<updated>2025-10-19T19:16:46Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: PR64331&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR118012 118012] || Expensive code (mul, neg) instead of bit test&lt;br /&gt;
| &amp;lt;tt&amp;gt;-mpr118012&amp;lt;/tt&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR113934 113934] || Switch AVR to LRA&lt;br /&gt;
| 16&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| 16&lt;br /&gt;
| [http://gcc.gnu.org/PR122187 122187] || ICE in avr_out_extr&lt;br /&gt;
| 15.3, 14.4 &lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| 15&lt;br /&gt;
| [http://gcc.gnu.org/PR115726 115726] || Wrong code with __memx and local register variables&lt;br /&gt;
| 14.2, 13.4, 12.5&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| 10.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107741</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107741"/>
		<updated>2025-10-19T19:08:47Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Bugs */&lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| 16&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107740</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107740"/>
		<updated>2025-10-19T19:08:02Z</updated>
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| 16&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107739</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107739"/>
		<updated>2025-10-19T18:59:47Z</updated>
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| 16&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107738</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107738"/>
		<updated>2025-10-19T18:59:21Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR118012 118012] || Expensive code (mul, neg) instead of bit test&lt;br /&gt;
| &amp;lt;tt&amp;gt;-mpr118012&amp;lt;/tt&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR113934 113934] || Switch AVR to LRA&lt;br /&gt;
| 16&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| 16&lt;br /&gt;
| [http://gcc.gnu.org/PR122187 122187] || ICE in avr_out_extr&lt;br /&gt;
| 15.3, 14.4 &lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| 15&lt;br /&gt;
| [http://gcc.gnu.org/PR115726 115726] || Wrong code with __memx and local register variables&lt;br /&gt;
| 14.2, 13.4, 12.5&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| 10.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107731</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107731"/>
		<updated>2025-10-11T13:50:46Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: &lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| 16&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107729</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107729"/>
		<updated>2025-10-07T17:13:25Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */ 122187&lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Bitmanipulation&amp;diff=107724</id>
		<title>Bitmanipulation</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Bitmanipulation&amp;diff=107724"/>
		<updated>2025-10-02T21:28:34Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: avr-gcc weblink aktualisiert&lt;/p&gt;
&lt;div&gt;== Bitoperatoren ==&lt;br /&gt;
Bitoperatoren stammen ursprünglich aus dem Bereich des Maschinen-Codes und Assembler, existieren aber auch in den meisten Hochsprachen, wie C.&lt;br /&gt;
&amp;gt;&amp;gt;    nach rechts schieben&lt;br /&gt;
&amp;lt;&amp;lt;    nach links schieben (Bsp.: a&amp;lt;&amp;lt;b ist das gleiche wie a * 2^b;&lt;br /&gt;
          bzw. bei 1&amp;lt;&amp;lt;3 wird die 1 um drei Stellen nach links geschoben)&lt;br /&gt;
|     bitweises ODER&lt;br /&gt;
&amp;amp;     bitweises UND&lt;br /&gt;
^     bitweises exklusives ODER&lt;br /&gt;
~     bitweises NICHT&lt;br /&gt;
Bitoperatoren in dieser Schreibweise können in Assemblercode für&lt;br /&gt;
konstante Ausdrücke benutzt werden.&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;asm&amp;quot;&amp;gt; &lt;br /&gt;
ldi temp, (1&amp;lt;&amp;lt;3) | (1&amp;lt;&amp;lt;1) | (1&amp;lt;&amp;lt;2) | (1&amp;lt;&amp;lt;0)&lt;br /&gt;
entspricht:&lt;br /&gt;
ldi temp, 8 | 2 | 4 | 1&lt;br /&gt;
ldi temp, 15&lt;br /&gt;
== Bitmaske ==&lt;br /&gt;
Im Folgenden ist häufiger von dem Begriff &#039;&#039;Bitmaske&#039;&#039; die Rede. Damit wird eine Folge von einzelnen Bits bezeichnet, die den Zustand null („0“) oder eins („1“) darstellen können.&lt;br /&gt;
Bitmasken werden im allgemeinen dazu verwendet, um unter Anwendung eines Operators (z.&amp;amp;nbsp;B. UND, ODER, XOR) eine Eingabe zu manipulieren. Das Ergebnis ist dann die Anwendung des Operators und der Bitmaske auf die Eingabe.&lt;br /&gt;
Wenn ein Operator eine Funktion mit zwei Argumenten ist, dann lässt sich dessen Anwendung wie folgt schreiben:&lt;br /&gt;
Ergebnis = Operator( Eingabe, Bitmaske )&lt;br /&gt;
Die Bitmaske ist häufig eine Konstante, da diese z.&amp;amp;nbsp;B. die Information über die Position einer Information in einem Register darstellt. Das kann z.&amp;amp;nbsp;B. ein Überlaufflag in einem Timer-Statusregister sein.&lt;br /&gt;
== Bits setzen ==&lt;br /&gt;
Wenn in einem Byte mehrere [[Digitaltechnik|Bits]] auf „eins“ gesetzt werden sollen, wird dies durch eine [[AVR-Tutorial:_Logik#ODER|ODER]]-Verknüpfung erreicht. Alle Bits, welche in der Bitmaske gleich „1“ sind, werden auf „1“ gesetzt. Alle Bits, die in der Maske auf „0“ gesetzt sind, bleiben unverändert.&lt;br /&gt;
=== AVR-Assembler ===&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;asm&amp;quot;&amp;gt;&lt;br /&gt;
sbr r16, 0b11110000     ; setzt Bits 4..7 in r16, ist ein Pseudobefehl,&lt;br /&gt;
                        ; funktioniert nur für die Arbeitsregister r16..r31&lt;br /&gt;
ori r16, 0b11110000     ; setzt Bits 4..7 in r16, ori ist identisch mit sbr,&lt;br /&gt;
sbi PORTB, 5            ; setzt Bit 5 in Port B;&lt;br /&gt;
sbi PORTB, PB5          ; identisch, besser lesbar;&lt;br /&gt;
                        ; funktioniert nur für die IO-Register 0..0x1F&lt;br /&gt;
                        ; Für IO-Register mit IO-Adresse 0x20..0x3F muss&lt;br /&gt;
                        ; in/out verwendet werden:&lt;br /&gt;
in  r16, TIMSK          ; setzt Bit TOIE1 in TIMSK&lt;br /&gt;
sbr r16, (1&amp;lt;&amp;lt;TOIE1)&lt;br /&gt;
out TIMSK, r16&lt;br /&gt;
                        ; Für IO-Register oberhalb der IO-Adresse 0x3F muss&lt;br /&gt;
                        ; lds/sts verwendet werden:&lt;br /&gt;
                        ; setzt Bit RXCIE0 in UCSR0B&lt;br /&gt;
lds r16, UCSR0B&lt;br /&gt;
sbr r16, (1&amp;lt;&amp;lt;RXCIE0)&lt;br /&gt;
sts UCSR0B, r16&lt;br /&gt;
Man beachte den Unterschied! Eine „5“ würde von &amp;lt;code&amp;gt;sbr&amp;lt;/code&amp;gt; als „setze Bit 2 und 0“ gedeutet (=0b00000101), während &amp;lt;code&amp;gt;sbi&amp;lt;/code&amp;gt; sie als „setze Bit 5“ versteht. Der Befehl &#039;&#039;&#039;&amp;lt;code&amp;gt;sbr&amp;lt;/code&amp;gt;&#039;&#039;&#039; erwartet ein Bit&#039;&#039;&#039;muster&#039;&#039;&#039; für eine ODER-Verknüpfung, während der Befehl &#039;&#039;&#039;&amp;lt;code&amp;gt;sbi&amp;lt;/code&amp;gt;&#039;&#039;&#039; die Bit&#039;&#039;&#039;nummer&#039;&#039;&#039; benötigt. Darauf sind auch die Includefiles von Atmel im AVR-Studio (Assembler) als auch [[WinAVR]] (C) ausgelegt. Die Namen der Bits sind als Bit&#039;&#039;&#039;nummer&#039;&#039;&#039; definiert. Das ist wichtig, wenn man Register von großen AVRs manipuliert, z.&amp;amp;nbsp;B. ATmega48. Hier muss aus der Bitnummer über eine Schiebeoperation erst das Bit&#039;&#039;&#039;muster&#039;&#039;&#039; gemacht werden.&lt;br /&gt;
=== Standard-C ===&lt;br /&gt;
PORTB |= 0xF0;   // Kurzschreibweise, entspricht PORTB = PORTB | 0xF0; bitweises ODER&lt;br /&gt;
/* übersichtlicher mittels Bit-Definitionen */&lt;br /&gt;
#define MEINBIT0 0&lt;br /&gt;
#define MEINBIT1 1&lt;br /&gt;
PORTB |= ((1 &amp;lt;&amp;lt; MEINBIT0) | (1 &amp;lt;&amp;lt; MEINBIT2)); // setzt Bit 0 und 2 in PORTB auf &amp;quot;1&amp;quot;&lt;br /&gt;
Die letzte Zeile „entschlüsselt“:&lt;br /&gt;
# &#039;&#039;&#039;&amp;lt;code&amp;gt;(1 &amp;amp;lt;&amp;amp;lt; n)&amp;lt;/code&amp;gt;&#039;&#039;&#039; : Zuerst wird durch die „&amp;lt;code&amp;gt;&amp;amp;lt;&amp;amp;lt;&amp;lt;/code&amp;gt;“-Ausdrücke eine „1“ n-mal nach links geschoben. Dies ergibt somit (in Binärschreibweise) 0b00000001 für &amp;lt;code&amp;gt;(1 &amp;amp;lt;&amp;amp;lt; MEINBIT0)&amp;lt;/code&amp;gt; und 0b00000100 für &amp;lt;code&amp;gt;(1 &amp;amp;lt;&amp;amp;lt; MEINBIT2)&amp;lt;/code&amp;gt;.&lt;br /&gt;
# &#039;&#039;&#039;&amp;lt;code&amp;gt;|&amp;lt;/code&amp;gt;&#039;&#039;&#039; : Das Ergebnis wird bitweise ODER-verknüpft, also 0b00000001 &#039;&#039;oder&#039;&#039; 0b00000100 wird zu 0b00000101.&lt;br /&gt;
# &#039;&#039;&#039;&amp;lt;code&amp;gt;|=&amp;lt;/code&amp;gt;&#039;&#039;&#039; : Diese Maske wird mit dem aktuellen Inhalt von PORTB bitweise ODER-verknüpft und das Ergebnis PORTB wieder zugewiesen.&lt;br /&gt;
PORTB |= variable;         // Kurzschreibweise&lt;br /&gt;
PORTB  = PORTB | variable; // lange Schreibweise&lt;br /&gt;
: Ist PORTB vorher z.&amp;amp;nbsp;B. 0b01111010, dann ist der Inhalt nach der Operation 0b01111010 &#039;&#039;oder&#039;&#039; 0b00000101 = 0b01111111, die gewünschten Bits sind somit gesetzt!&lt;br /&gt;
Anmerkung: Will man das gezeigte Beispiel der Bitmanipulation auf größere Datentypen anwenden, ist zu beachten, dass der Compiler in der Operation &amp;lt;code&amp;gt;(1 &amp;amp;lt;&amp;amp;lt; MEINBIT1)&amp;lt;/code&amp;gt; stillschweigend, gemäß den C-Regeln, die 1 als Integer-Typ ansieht. Beim AVR-GCC bedeutet das 16-Bit/signed und die folgende Operation bringt ggf. nicht das gewünschte Ergebnis (Stichwort: „Integer Promotion“).&lt;br /&gt;
Angenommen, Bit 15 soll in einer 32-Bit weiten Variable gesetzt werden.&lt;br /&gt;
#define MEINBIT15 15&lt;br /&gt;
#define MEINBIT42 42&lt;br /&gt;
uint32_t reg_32; /* uint32_t definiert per typedef z.&amp;amp;nbsp;B. in stdint.h */&lt;br /&gt;
uint64_t reg_64; /* uint64_t definiert per typedef z.&amp;amp;nbsp;B. in stdint.h */&lt;br /&gt;
reg_32 |= (1 &amp;lt;&amp;lt; MEINBIT15);              /* FEHLER: Setzt die Bits 31..15, da ((int)1 &amp;lt;&amp;lt; 15) == 0xFFFF8000 */&lt;br /&gt;
reg_32 |= ((uint32_t)1 &amp;lt;&amp;lt; MEINBIT15);    /* Hier wird nur Bit 15 gesetzt. */&lt;br /&gt;
reg_32 |= (1U &amp;lt;&amp;lt; MEINBIT15);             /* */&lt;br /&gt;
reg_32 |= (1L &amp;lt;&amp;lt; MEINBIT15);             /* andere Schreibweise. */&lt;br /&gt;
reg_64 |= (1LL &amp;lt;&amp;lt; MEINBIT42);            /* Hier wird nur Bit 42 gesetzt,&lt;br /&gt;
                                            andere Schreibweise für 64 Bit (long long). */&lt;br /&gt;
Bei Compilern für 32-bit-Controller (z.&amp;amp;nbsp;B. ARM7TDMI) sind Integers per default 32-bit und Konstanten sind somit implizit ebenfalls 32-bit weit. Man sollte aber dennoch die oben gezeigte Vorgehensweise verwenden, um Probleme zu vermeiden, die entstehen könnten, wenn Code unter verschiedenen Plattformen/Compilern verwendet werden soll.&lt;br /&gt;
== Bits löschen ==&lt;br /&gt;
Wenn in einem Byte mehrere [[Digitaltechnik|Bits]] auf „null“ gesetzt werden sollen, wird dies durch eine [[AVR-Tutorial: Logik#UND|UND]]-Verknüpfung erreicht. Alle Bits, welche in der Bitmaske gleich „0“ sind, werden auf „0“ gesetzt. Alle Bits, die in der Maske auf „1“ gesetzt sind, bleiben unverändert.&lt;br /&gt;
cbr r16, 0b00001111     ; löscht Bits 0..3 in r16, ist ein Pseudobefehl,&lt;br /&gt;
andi r16, 0b11110000    ; löscht Bits 0..3 in r16, andi ist identisch mit cbr,&lt;br /&gt;
andi r16, ~0b00001111   ; andere Schreibweise, hier wird die Bitmaske durch ~ invertiert,&lt;br /&gt;
                        ; dadurch kann man einfach alle zu löschenden Bit als &#039;1&#039; angeben&lt;br /&gt;
                        ; so wie bei den Bitmasken für das Setzen von Bits (positive Logik)&lt;br /&gt;
cbi PORTB, 5            ; löscht Bit 5 in Port B&lt;br /&gt;
cbi PORTB, PB5          ; identisch, besser lesbar&lt;br /&gt;
                        ; funktioniert nur für die IO-Register 0..31&lt;br /&gt;
                        ; in/out verwendet werden, weil dieser Bereich nicht&lt;br /&gt;
                        ; bitadressierbar ist:&lt;br /&gt;
in  r16, TIMSK          ; löscht Bit TOIE1 in TIMSK&lt;br /&gt;
cbr r16, 1&amp;lt;&amp;lt;TOIE1&lt;br /&gt;
                        ; löscht Bit RXCIE0 in UCSR0B&lt;br /&gt;
lds r16, UCSR0B &lt;br /&gt;
cbr r16, 1&amp;lt;&amp;lt;RXCIE0&lt;br /&gt;
Auch hier gilt: Man beachte den Unterschied! Eine „5“ würde von &amp;lt;code&amp;gt;cbr&amp;lt;/code&amp;gt; als „lösche Bit 2 und 0“ gedeutet, während &amp;lt;code&amp;gt;cbi&amp;lt;/code&amp;gt; sie als „lösche Bit 5“ versteht. Der Befehl &#039;&#039;&#039;&amp;lt;code&amp;gt;cbr&amp;lt;/code&amp;gt;&#039;&#039;&#039; erwartet ein Bit&#039;&#039;&#039;muster&#039;&#039;&#039; für eine UND-NOT-Verknüpfung (nicht zu verwechseln mit NAND), während der Befehl &#039;&#039;&#039;&amp;lt;code&amp;gt;cbi&amp;lt;/code&amp;gt;&#039;&#039;&#039; die Bit&#039;&#039;&#039;nummer&#039;&#039;&#039; benötigt. Darauf sind auch die Includefiles von Atmel im AVR-Studio (Assembler) als auch [[WinAVR]] (C) ausgelegt. Die Namen der Bits sind als Bit&#039;&#039;&#039;nummer&#039;&#039;&#039; definiert. Das ist wichtig, wenn man Register von großen AVRs manipuliert, z.&amp;amp;nbsp;B. ATmega48. Hier muss aus der Bitnummer über eine Schiebeoperation „&amp;lt;code&amp;gt;&amp;amp;lt;&amp;amp;lt;&amp;lt;/code&amp;gt;“ erst das Bit&#039;&#039;&#039;muster&#039;&#039;&#039; gemacht werden.&lt;br /&gt;
PORTB &amp;amp;= 0xF0;   // entspricht PORTB = PORTB &amp;amp; 0xF0; bitweises UND&lt;br /&gt;
                 // Bits 0..3 (das &amp;quot;niederwertige&amp;quot; Nibble) werden gelöscht&lt;br /&gt;
#define MEINBIT1 1  &lt;br /&gt;
#define MEINBIT2 2  &lt;br /&gt;
PORTB &amp;amp;= ~((1 &amp;lt;&amp;lt; MEINBIT0) | (1 &amp;lt;&amp;lt; MEINBIT2)); // löscht Bits 0 und 2 in PORTB&lt;br /&gt;
Die letzte Zeile entschlüsselt:&lt;br /&gt;
# &#039;&#039;&#039;&amp;lt;code&amp;gt;~&amp;lt;/code&amp;gt;&#039;&#039;&#039; : Der Wert in der Klammer wird bitweise invertiert, aus 0b00000101 wird 0b11111010.&lt;br /&gt;
# &#039;&#039;&#039;&amp;lt;code&amp;gt;&amp;amp;=&amp;lt;/code&amp;gt;&#039;&#039;&#039; : PORTB wird mit der berechneten Maske UND-verknüpft und das Ergebnis wieder PORTB zugewiesen.&lt;br /&gt;
PORTB &amp;amp;= variable;          // Kurzschreibweise&lt;br /&gt;
PORTB  = PORTB &amp;amp; variable;  // lange Schreibweise&lt;br /&gt;
: Ist PORTB vorher z.&amp;amp;nbsp;B. 0b01111111, dann ist der Inhalt nach der Operation 0b01111111 &#039;&#039;und&#039;&#039; 0b11111010 = 0b01111010, die gewünschten Bits 0 und 2 sind somit gelöscht.&lt;br /&gt;
Die C-Ausdrücke mittels Definitionen von Bitnummern und Schiebeoperator (&amp;lt;code&amp;gt;&amp;amp;lt;&amp;amp;lt;&amp;lt;/code&amp;gt;) sehen auf den ersten Blick etwas „erschreckend“ aus und sind mehr „Tipparbeit“, funktionieren aber universell und sind deutlicher und nachvollziehbarer als „handoptimierte“ Konstanten. Bei eingeschalteter Optimierung löst der Compiler die Ausdrücke mit konstanten Werten bereits zur Compilierungszeit auf und es entsteht kein zusätzlicher Maschinencode. Bei AVR sind die Definitionen meist Teil der Entwicklungsumgebungen (bei avr-libc z.&amp;amp;nbsp;B. implizit durch &amp;lt;code&amp;gt;#include &amp;amp;lt;avr/io.h&amp;amp;gt;&amp;lt;/code&amp;gt;). Sie entsprechen den Angaben und Beispielen in den Datenblättern und sind damit &#039;&#039;de facto&#039;&#039; ein Standard beim Zugriff auf Bits in Hardware-Registern.&lt;br /&gt;
&#039;&#039;&#039;Wichtiger Hinweis&#039;&#039;&#039;: Die ODER-Verknüpfung und die anschließende Invertierung kann man nicht vertauschen (Theorem von DeMorgan)! Folgendes Beispiel soll die Richtigkeit der Aussage zeigen:&lt;br /&gt;
 ~(0b0001 | 0b0010) == 0b1100&lt;br /&gt;
  ~0b0001 | ~0b0010 == 0b1111&lt;br /&gt;
&#039;&#039;&#039;Noch ein wichtiger Hinweis&#039;&#039;&#039;: Der Operator &amp;lt;code&amp;gt;~&amp;lt;/code&amp;gt; mit einem Operanden vom Typ &amp;lt;code&amp;gt;int&amp;lt;/code&amp;gt; negiert nur so viele Bits, wie der Typ &amp;lt;code&amp;gt;int&amp;lt;/code&amp;gt; hat.&lt;br /&gt;
Will man ein Bit in einer breiteren Variablen löschen, dann sollte die nach links zu shiftende „1“ den Typ dieser Variablen haben.&lt;br /&gt;
Ein Programm, welches das verdeutlicht:&lt;br /&gt;
int main(int argc, const char* argv[])&lt;br /&gt;
    int bit = 60;&lt;br /&gt;
    uint64_t ui64;&lt;br /&gt;
    printf(&amp;quot;sizeof(int)=%d\n&amp;quot;, (int)sizeof(int));&lt;br /&gt;
    ui64 = 0xFFFFFFFFFFFFFFFF;    &lt;br /&gt;
    ui64 &amp;amp;= ~(1&amp;lt;&amp;lt;60); /* Keine Wirkung bei sizeof(int) &amp;lt; 8 */&lt;br /&gt;
    /* gcc warnt sogar:    &lt;br /&gt;
     * gcc -Wall bit_clear.c -o bit_clear&lt;br /&gt;
     * bit_clear.c: In function ‘main’:&lt;br /&gt;
     * bit_clear.c:11:5: warning: left shift count &amp;gt;= width of type [enabled by default]&lt;br /&gt;
     */    &lt;br /&gt;
    printf(&amp;quot;%d\n&amp;quot;, ui64!=0xFFFFFFFFFFFFFFFF);&lt;br /&gt;
    ui64 &amp;amp;= ~((uint64_t)1&amp;lt;&amp;lt;60); /* OK */&lt;br /&gt;
    ui64 = 0xFFFFFFFFFFFFFFFF;&lt;br /&gt;
    ui64 &amp;amp;= ~(1LL&amp;lt;&amp;lt;60); /* auch OK, und kürzer */&lt;br /&gt;
    ui64 &amp;amp;= ~(1&amp;lt;&amp;lt;bit); /* Ohne Warnung, und funktioniert manchmal, je nach Optimierung */&lt;br /&gt;
/* Ausgabe auf meinem PC ohne Optimierung:&lt;br /&gt;
 * sizeof(int)=4&lt;br /&gt;
 * 0&lt;br /&gt;
 * 1&lt;br /&gt;
 * 1&lt;br /&gt;
 * 1&lt;br /&gt;
 * Ausgabe auf meinem PC mit -O2&lt;br /&gt;
 * 0&lt;br /&gt;
 * 1&lt;br /&gt;
 * 1&lt;br /&gt;
 * 0&lt;br /&gt;
=== Niederwertigstes gesetztes Bit löschen (Standard-C) ===&lt;br /&gt;
Folgender Code löscht von allen 1-Bits in einer Integer-Variablen das niederwertigste, unabhängig von der Position desselben.&lt;br /&gt;
Beispiel: 01101000 → 01100000&lt;br /&gt;
uint8_t byte;&lt;br /&gt;
byte = irgendwas();&lt;br /&gt;
byte = byte &amp;amp; (byte - 1); /* Diese seltsame Operation löscht das&lt;br /&gt;
                             niederwertigste 1-Bit */&lt;br /&gt;
Byte  :   01101000&lt;br /&gt;
Byte-1:   01100111&lt;br /&gt;
Ergebnis: 01100000&lt;br /&gt;
Das funktioniert also mit jeder beliebigen Zahl.&lt;br /&gt;
Dies kann bspw. zur schnellen Paritätsgenerierung eingesetzt werden:&lt;br /&gt;
uint8_t pareven(uint8_t byte) {&lt;br /&gt;
  uint8_t par = 0;&lt;br /&gt;
  while(byte) {&lt;br /&gt;
    byte = byte &amp;amp; (byte - 1);&lt;br /&gt;
    par = ~par;&lt;br /&gt;
  return par;&lt;br /&gt;
Das genannte gilt natürlich nicht nur für 8-Bit-Integers, sondern für beliebige, vom Compiler unterstützte Wortlängen.&lt;br /&gt;
== Bits invertieren ==&lt;br /&gt;
Im allgemeinen Sprachgebrauch oft &#039;&#039;&#039;Toggeln&#039;&#039;&#039; genannt (aus dem Englischen: &#039;&#039;to toggle&#039;&#039;). Wenn in einem Byte mehrere [[Digitaltechnik|Bits]] invertiert („getoggelt“) werden sollen, wird dies durch eine [[AVR-Tutorial: Logik#XOR (Exklusives Oder)|XOR]]-Verknüpfung erreicht. Alle Bits, welche in der Bitmaske gleich „1“ sind, werden invertiert. Alle Bits, die in der Maske auf „0“ gesetzt sind, bleiben unverändert.&lt;br /&gt;
Bei [[AVR]]s erlaubt dies folgender Assemblercode. Hier wird ein Ausgangspin invertiert.&lt;br /&gt;
  sbic  PortB, 0    ; Überspringe den nächsten Befehl, wenn das Bit 0 im Port gelöscht ist&lt;br /&gt;
  rjmp  ClrBitNow   ; Springe zu ClrBitNow&lt;br /&gt;
  sbi   PortB, 0    ; Setze Bit 0 in PortB&lt;br /&gt;
  rjmp  BitReady    ; Springe zu BitReady&lt;br /&gt;
ClrBitNow:&lt;br /&gt;
  cbi  PortB, 0    ; Lösche Bit 0 in PortB&lt;br /&gt;
BitReady:&lt;br /&gt;
&#039;&#039;&#039;Noch kürzer geht&#039;s so:&#039;&#039;&#039; Die zweite Zeile mit dem Befehl &amp;lt;code&amp;gt;ldi&amp;lt;/code&amp;gt; lädt die Bitmaske, in welcher die zu toggelnden Bits auf „1“ gesetzt sind. In diesem Beispiel wird das dritte Bit invertiert. Der Vorteil dieser Methode ist neben der Kürze und Übersichtlichkeit auch die Möglichkeit, bis zu acht Bits gleichzeitig zu toggeln. Diese Methode ist natürlich auch auf normale Daten anwendbar, nicht nur auf IO-Ports.&lt;br /&gt;
 in     R24, PORTE   ; Daten lesen&lt;br /&gt;
 ldi    R25, 0x04    ; Bitmaske laden, hier Bit #2&lt;br /&gt;
 eor    R24, R25     ; Exklusiv ODER&lt;br /&gt;
 out    PORTE, R24   ; Daten zurückschreiben&lt;br /&gt;
Eine andere Möglichkeit gibt es, wenn man nur das 8. Bit kippen will:&lt;br /&gt;
 in      r16, PORTB&lt;br /&gt;
 subi    r16, 0x80&lt;br /&gt;
 out     PORTB, r16&lt;br /&gt;
 PORTB ^= (1&amp;lt;&amp;lt;PB0);    /* XOR, Kurzschreibweise für PORTB = PORTB ^ (1&amp;lt;&amp;lt;PB0) */&lt;br /&gt;
=== Neuere ATmegas ===&lt;br /&gt;
Bei den neueren ATmegas (z.&amp;amp;nbsp;B. ATmega48) kann man (auf Ausgang gesetzte) IO-Pins direkt ohne den Umweg über Register toggeln, indem man das entsprechende Bit im PINx-Register &#039;&#039;setzt&#039;&#039;:&lt;br /&gt;
sbi PIND, 2       ; Bit 2 von Port D toggeln&lt;br /&gt;
=== 8051er ===&lt;br /&gt;
cpl bitadresse&lt;br /&gt;
== Bits prüfen ==&lt;br /&gt;
Will man prüfen, ob ein oder mehrere Bits in einer Variablen gesetzt oder gelöscht sind, muss man sie mit einer Bitmaske UND-verknüpfen. Die Bitmaske muss an den Stellen der zu prüfenden Bits eine „1“ haben, an allen anderen eine „0“.&lt;br /&gt;
* Ist das Ergebnis gleich null, sind alle geprüften Bits gelöscht.&lt;br /&gt;
* Ist das Ergebnis ungleich null, ist mindestens ein geprüftes Bit gesetzt.&lt;br /&gt;
* Ist das Ergebnis gleich der Bitmaske, sind alle geprüften Bits gesetzt.&lt;br /&gt;
Der AVR hat spezielle Befehle, um direkt einzelne Bits in den CPU-Registern r0…r31 sowie den IO-Registern 0…0x1F zu prüfen.&lt;br /&gt;
; Befehle zur Prüfung von einzelnen Bits&lt;br /&gt;
    sbrs    r16,3       ; überspringe den nächsten Befehl, wenn in r16 Bit #3 gesetzt ist&lt;br /&gt;
    rjmp    bit_ist_nicht_gesetzt&lt;br /&gt;
    sbrc    r16,5       ; überspringe den nächsten Befehl, wenn in r16 Bit #5 gelöscht ist&lt;br /&gt;
    rjmp    bit_ist_nicht_geloescht&lt;br /&gt;
    sbis    timsk,3     ; überspringe den nächsten Befehl, wenn in timsk Bit #3 gesetzt ist&lt;br /&gt;
    sbic    timsk,5     ; überspringe den nächsten Befehl, wenn in timsk Bit #5 gelöscht ist&lt;br /&gt;
; Befehle zur Prüfung von mehreren Bits&lt;br /&gt;
    andi    r16,0b1010  ; prüfe Bit #1 und #3 in r16&lt;br /&gt;
    breq    alle_bits_sind_geloescht&lt;br /&gt;
    brne    mind_ein_bit_ist_gesetzt&lt;br /&gt;
    cpi     r16,0b1010&lt;br /&gt;
    breq    alle_bits_sind_gesetzt&lt;br /&gt;
    // prüfe, ob Bit 4 in der Variablen tmp gelöscht ist&lt;br /&gt;
    // die Klammer ist wichtig!&lt;br /&gt;
    if (!(tmp &amp;amp; 0x10)) {&lt;br /&gt;
       // hier die Anweisungen, wenn das Bit gelöscht ist&lt;br /&gt;
    // prüfe, ob Bit 0 und Bit 4 in der Variablen tmp gelöscht sind&lt;br /&gt;
    if ((tmp &amp;amp; 0x11) == 0) {&lt;br /&gt;
       // hier die Anweisungen, wenn beide Bits gelöscht sind&lt;br /&gt;
    // prüfe, ob Bit 0 oder Bit 4 in der Variablen tmp gesetzt ist&lt;br /&gt;
    if (tmp &amp;amp; 0x11) {&lt;br /&gt;
       // hier die Anweisungen, wenn mindestens ein Bit gesetzt ist&lt;br /&gt;
    // prüfe, ob Bit 0 oder Bit 4 in der Variablen tmp gelöscht sind&lt;br /&gt;
    if (~tmp &amp;amp; 0x11) {&lt;br /&gt;
       // hier die Anweisungen, wenn mindestens ein Bit gelöscht ist&lt;br /&gt;
    // prüfe, ob Bit 4 in der Variablen tmp gesetzt ist&lt;br /&gt;
    if (tmp &amp;amp; 0x10) {&lt;br /&gt;
       // hier die Anweisungen, wenn das Bit gesetzt ist&lt;br /&gt;
    // prüfe, ob Bit 0 und Bit 4 in der Variablen tmp gesetzt sind&lt;br /&gt;
    if ((tmp &amp;amp; 0x11) == 0x11) {&lt;br /&gt;
       // hier die Anweisungen, wenn beide Bits gesetzt sind&lt;br /&gt;
== Hilfsfunktionen zur Bitmanipulation in C/C++ ==&lt;br /&gt;
Um &amp;quot;einfacher&amp;quot; elementare Bitmanipulationen durchzuführen bietet es sich an einige Hilfsfunktionen zu definieren. Dabei gibt es zwei verschiedene Möglichkeiten diese zu realiseren:&lt;br /&gt;
* Als C-Makro [[C_Makros]]&lt;br /&gt;
* Als Inline-Funktion&lt;br /&gt;
In beiden Fällen wird bei eingeschalteter Optimierung letztendlich vom Compiler ein sehr kompakter (und identischer!) Code erzeugt, jedoch ist dringend von der Verwendung von Makros abzuraten (siehe [[Makro]] )!&lt;br /&gt;
Im Fehlerfall zeigt der Compiler bei der Verwendung vom Makros keine eindeutigen Fehlermeldungen an, da es sich um simple Ersetzungen handelt - bei der Verwendung von Inline-Funktionen hingegen gibt es eine &amp;quot;brauchbare&amp;quot; Fehlermeldung!&lt;br /&gt;
=== Beispiele - Inline Variante ===&lt;br /&gt;
// Achtung: Zugriffe erfolgen über Pointer&lt;br /&gt;
// PORTA, PB2 setzen&lt;br /&gt;
BIT_SET(&amp;amp;PORTA, PB2);&lt;br /&gt;
// PORTC, PB0 löschen&lt;br /&gt;
BIT_CLEAR(&amp;amp;PORTC, PB0);&lt;br /&gt;
// PORTA, PB2 direkt setzen&lt;br /&gt;
// HIGH&lt;br /&gt;
BIT_BOOL_SET(&amp;amp;PORTA, PB2, 1);&lt;br /&gt;
// LOW&lt;br /&gt;
BIT_BOOL_SET(&amp;amp;PORTA, PB2, 0);&lt;br /&gt;
=== Beispiele - MakroVariante ===&lt;br /&gt;
// Achtung: Zugriffe erfolgen direkt über die Variablen/Portnamen&lt;br /&gt;
BIT_SET(PORTA, PB2);&lt;br /&gt;
BIT_CLEAR(PORTC, PB0);&lt;br /&gt;
Um die Hilfsfunktionen verwenden zu können einfach folgenden Code in eine neue Header-Datei (z.B. BitIO.h) kopieren:&lt;br /&gt;
=== Hilfsfunktionen als Inline-Methoden ===&lt;br /&gt;
Achtung: Wenn nur ein C Compiler verwendet wird, kennt dieser den Typ &amp;quot;bool&amp;quot; nicht, dieser muss dann vorher definiert werden!&lt;br /&gt;
/**&lt;br /&gt;
 *  BitIO.h&lt;br /&gt;
 *	@author 	Andi Dittrich &amp;lt;http://andidittrich.de&amp;gt;&lt;br /&gt;
 *	@version	1.0&lt;br /&gt;
 *	@license	MIT Style X11 License&lt;br /&gt;
#ifndef BITIO_H_&lt;br /&gt;
#define BITIO_H_&lt;br /&gt;
// set bit&lt;br /&gt;
static inline void BIT_SET(volatile uint8_t *target, uint8_t bit) __attribute__((always_inline));&lt;br /&gt;
static inline void BIT_SET(volatile uint8_t *target, uint8_t bit){&lt;br /&gt;
	*target |= (1&amp;lt;&amp;lt;bit);&lt;br /&gt;
// set clear&lt;br /&gt;
static inline void BIT_CLEAR(volatile uint8_t *target, uint8_t bit) __attribute__((always_inline));&lt;br /&gt;
static inline void BIT_CLEAR(volatile uint8_t *target, uint8_t bit){&lt;br /&gt;
	*target &amp;amp;= ~(1&amp;lt;&amp;lt;bit);&lt;br /&gt;
// bit toogle&lt;br /&gt;
static inline void BIT_TOGGLE(volatile uint8_t *target, uint8_t bit) __attribute__((always_inline));&lt;br /&gt;
static inline void BIT_TOGGLE(volatile uint8_t *target, uint8_t bit){&lt;br /&gt;
	*target ^= (1&amp;lt;&amp;lt;bit);&lt;br /&gt;
// set bit by boolean&lt;br /&gt;
static inline void BIT_BOOL_SET(volatile uint8_t *target, uint8_t bit, bool enable) __attribute__((always_inline));&lt;br /&gt;
static inline void BIT_BOOL_SET(volatile uint8_t *target, uint8_t bit, bool enable){&lt;br /&gt;
	if (enable){&lt;br /&gt;
		BIT_SET(target, bit);&lt;br /&gt;
	}else{&lt;br /&gt;
		BIT_CLEAR(target, bit);&lt;br /&gt;
#endif /* BITIO_H_ */&lt;br /&gt;
=== Hilfsfunktionen als C-Makro (nicht empfohlen) ===&lt;br /&gt;
/* Bit setzen */&lt;br /&gt;
#define set_bit(var, bit) ((var) |= (1 &amp;lt;&amp;lt; (bit)))&lt;br /&gt;
/* Bit löschen */&lt;br /&gt;
#define clear_bit(var, bit) ((var) &amp;amp;= (unsigned)~(1 &amp;lt;&amp;lt; (bit)))&lt;br /&gt;
/* Bit togglen */&lt;br /&gt;
#define toggle_bit(var,bit) ((var) ^= (1 &amp;lt;&amp;lt; (bit)))&lt;br /&gt;
== Bitmanipulation beim MSP430 ==&lt;br /&gt;
Beim MSP430 und dessen Compilern sind die Bitnamen meist anders definiert. Und zwar nicht als Bitnummer, sondern als Bitmuster. Darum schreibt man dort die Bitzugriffe in C anders. Das kann auch bei anderen Mikrocontrollern bzw. C-Compilern so sein. Wichtig ist, dass man seine eignen Definitionen in der gleichen Weise wie der Compiler anlegt, um Verwirrung zu vermeiden, siehe [[Strukturierte Programmierung auf Mikrocontrollern]]&lt;br /&gt;
// Definition von Bitnamen in den Headerfiles des Compilers&lt;br /&gt;
#define PD4 4               // Definition im AVR GCC als Bitnummer&lt;br /&gt;
#define PD5 5&lt;br /&gt;
#define P14 (1&amp;lt;&amp;lt;4)          // Definition im MSP430 GCC als Bitmuster&lt;br /&gt;
#define P15 (1&amp;lt;&amp;lt;5)&lt;br /&gt;
// Bitmanipulation im Programm&lt;br /&gt;
   DDRD = (1&amp;lt;&amp;lt;PD5) | (1&amp;lt;&amp;lt;PD4);   // AVR GCC&lt;br /&gt;
   P1DIR = P15 | P14;            // MSP430 GCC&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/179566#1729219 Forumsbeitrag]: Bits aus einem Array extrahieren&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/169509#1631439 Forumsbeitrag]: Bits für ein Schieberegister zusammenstellen, TLC5941&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/353071?goto=3947567#3947567 Forumsbeitrag]: TLC5947 und ATmega16 Bitmanipulation&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/15466?goto=107726#107720 Forumsbeitrag]: Bitreihenfolge ändern&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/386393#4418405 Forumsbeitrag]: Übersichtliche Abfrage von vielen Pins&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/394065#4527806 Forumsbeitrag]: Verschiedene Möglichkeiten der Bitmanipulation bei IO-Registern&lt;br /&gt;
* [https://gcc.gnu.org/onlinedocs/gcc/AVR-Built-in-Functions.html AVR Built-in Functions] – spezielle Funktion im avr-gcc zur schnellen Bitvertauschung (englisch)&lt;br /&gt;
* Sean Eron Anderson: [https://graphics.stanford.edu/~seander/bithacks.html Bit Twiddling Hacks] – Sammlung von komplexeren Bitmanipulationen (englisch)&lt;br /&gt;
* Günther Jena: [https://www.semiversus.com/dic/mikrocontroller/bitmanipulation.html Bitmanipulation mit C] – mit Übungen&lt;br /&gt;
[[Category:8051]]&lt;br /&gt;
[[Category:AVR-Arithmetik]]&lt;/div&gt;</summary>
		<id>https://www.mikrocontroller.net/index.php?title=Bin%C3%A4re_Daten_zum_Programm_hinzuf%C3%BCgen&amp;diff=107582</id>
		<title>Binäre Daten zum Programm hinzufügen</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Bin%C3%A4re_Daten_zum_Programm_hinzuf%C3%BCgen&amp;diff=107582"/>
		<updated>2025-07-10T09:45:41Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: #enbed&lt;/p&gt;
&lt;div&gt;Will man beliebige Daten einem Programm hinzufügen (z.B. Bitmaps, Fonts, Seriennummern, ...) gibt es dafür mehrere Möglichkeiten.&lt;br /&gt;
== Einfügen als C-Array ==&lt;br /&gt;
Die Daten werden mit einem Hilfsprogramm in ein C-Array umgewandelt und dann in die Anwendung einkompiliert. Zum Umwandeln &lt;br /&gt;
von Binärdaten in ein C-Array gibt es bereits einige fertige Lösungen. So kann z.B. der kostenlose Hexeditor [http://mh-nexus.de/en/hxd/ HxD]&lt;br /&gt;
eine Datei als C-Array exportieren. Mit Hilfe des Kommandozeilentools srec_cat ist dies ebenfalls möglich.&lt;br /&gt;
$ srec_cat my_data.bin -binary -output my_c_file.c -c-Array my_var_name -include&lt;br /&gt;
Es wird dann eine C-Datei erzeugt die ein Array &amp;lt;tt&amp;gt;my_var_name&amp;lt;/tt&amp;gt; und einige Hilfsvariablen dazu enthält.&lt;br /&gt;
Diese Datei wird dann ins Projekt eingebunden und ganz normal verwendet. &lt;br /&gt;
Beim avr-gcc ist noch darauf zu achten, dass die Daten — falls gewünscht — im Programmspeicher und nicht im RAM landen. Siehe [[AVR-GCC-Tutorial#Programmspeicher (Flash)|AVR-GCC Tutorial]]&lt;br /&gt;
; Vorteile:&lt;br /&gt;
* Einfach zu verwenden&lt;br /&gt;
* Portabel&lt;br /&gt;
* Typsicher&lt;br /&gt;
; Nachteile:&lt;br /&gt;
* Zusätzliche Dateien (c/h) nötig&lt;br /&gt;
* C-Datei bei großen Binärdateien sehr groß&lt;br /&gt;
* Ein zusätzlicher Schritt beim Bauen nötig&lt;br /&gt;
* Daten müssen zum Zeitpunkt des Kompilierens bekannt sein&lt;br /&gt;
== objcopy ==&lt;br /&gt;
Mit objcopy wird aus der Binärdatei eine Objektdatei erstellt die zum Projekt gelinkt werden kann.&lt;br /&gt;
Hier ein Beispiel wie das mit den GNU-Tools für den AVR gemacht wird.&lt;br /&gt;
$ avr-objcopy -I binary my_data.bin --binary-architecture avr4 -O elf32-avr my_data.o&lt;br /&gt;
$ avr-nm -t my_data.o &lt;br /&gt;
000008c6 D _binary__home_mat_my_data_bin_end&lt;br /&gt;
000008c6 A _binary__home_mat_my_data_bin_size&lt;br /&gt;
00000000 D _binary__home_mat_my_data_bin_start&lt;br /&gt;
Die Objektdatei enthält dann drei Symbole, deren Namen allerdings etwas unhandlich sind und — je nach Aufruf von objcopy — auch noch den kompletten Pfad der Binärdatei enthalten. Es ist allerdings möglich, mit einem weiteren Aufruf von objcopy den Symbolen brauchbarere Namen zu verpassen. Dieses Datenpaket kann dann in C verwendet werden, wenn man folgende Zeile einfügt:&lt;br /&gt;
extern unsigned char _binary__home_mat_my_data_bin_start[];&lt;br /&gt;
Beim Linken des Projekts wird die Objekdatei dann mit zum Projekt hinzu gelinkt.&lt;br /&gt;
* Keine zusätzliche Datei nötig&lt;br /&gt;
* Keine manuell zu verwaltende Adresse&lt;br /&gt;
* Nicht komplett portabel. Der Aufruf von objcopy ist je nach System immer etwas unterschiedlich.&lt;br /&gt;
* Unhandliche Symbolnamen, mögliche Lösung siehe unten&lt;br /&gt;
* Nicht typsicher&lt;br /&gt;
* Daten müssen zum Zeitpunkt des Linkens bekannt sein&lt;br /&gt;
Standardmäßig gehen die Daten ins Datensegment (.data). Da man die (meist umfangreichen) Daten beim AVR im Flash haben möchte, erweitert sich die Kommandozeile für ein Makefile:&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;Makefile&amp;quot;&amp;gt;&lt;br /&gt;
spDINER.o: TomsDiner.lpc		# Explizite Regel: Zieldatei: Quelldatei&lt;br /&gt;
	avr-objcopy -I binary \		# Eingabedatei binär&lt;br /&gt;
-O elf32-avr \					# Ausgabedatei ELF&lt;br /&gt;
--rename-section .data=.progmem.1,contents \	# Ausgabe-Sektion &amp;quot;.progmem&amp;quot; =&lt;br /&gt;
\						# in den unteren 64 K Flash vom Linker einbauen lassen&lt;br /&gt;
--redefine-sym _binary_$(subst .,_,$&amp;lt;)_start=$(@:.o=) \	# Das umständliche Startsymbol...&lt;br /&gt;
\						# durch Zieldateiname ohne &amp;quot;.o&amp;quot; ersetzen&lt;br /&gt;
-N _binary_$(subst .,_,$&amp;lt;)_end \	# Das Endesymbol löschen (optional)&lt;br /&gt;
-N _binary_$(subst .,_,$&amp;lt;)_size \	# Das Längensymbol löschen (optional)&lt;br /&gt;
$&amp;lt; \					# Eingabedatei&lt;br /&gt;
$@						# Ausgabedatei&lt;br /&gt;
Leider ist es mit avr-objcopy nicht möglich, dem (hier umbenannten) Start-Symbol (im Beispiel: &#039;&#039;&#039;spDINER&#039;&#039;&#039;) die Eigenschaft &amp;quot;STT_OBJECT&amp;quot; zu verpassen. (In der Symboltabelle erscheint dann bei &#039;&#039;&#039;avr-objdump -t&#039;&#039;&#039; ein &amp;quot;O&amp;quot;.)&lt;br /&gt;
Dadurch wird der Disassembler &#039;&#039;&#039;avr-objdump -d&#039;&#039;&#039; die Binärdaten als (sinnlosen) Kode disassemblieren anstatt die Bytes uninterpretiert auszuspucken. Patcht man mit einem Hex-Editor dieses Bit hinzu, funktioniert die Disassemblierung korrekt.&lt;br /&gt;
&#039;&#039;&#039;Achtung:&#039;&#039;&#039; Vergisst man beim Aufruf von &#039;&#039;&#039;objcopy&#039;&#039;&#039; die Zieldatei, wird die Quelldatei überschrieben!! Das ist fatal, wenn die Quelldatei keine Zwischendatei in einem Makefile darstellt.&lt;br /&gt;
== .incbin ==&lt;br /&gt;
Die GNU Binutils bieten die Direktive &amp;lt;tt&amp;gt;.incbin&amp;lt;/tt&amp;gt; mit welcher der Binärinhalt einer Datei eingefügt werden kann.  Dazu legt man ein Assembler-Modul mydata.S an und includiert die gewünschte Datei:&lt;br /&gt;
In mydata.S&lt;br /&gt;
.section .progmem.data,&amp;quot;a&amp;quot;,@progbits&lt;br /&gt;
.global my_data&lt;br /&gt;
.type   my_data,@object&lt;br /&gt;
my_data:&lt;br /&gt;
.incbin &amp;quot;maydata.bin&amp;quot;&lt;br /&gt;
.size my_data, .-my_data&lt;br /&gt;
Diese Assembler-Datei wird mit&lt;br /&gt;
$ gcc -c my_data.S&lt;br /&gt;
assembliert und die resultierende Object-Datei &amp;lt;tt&amp;gt;my_data.o&amp;lt;/tt&amp;gt; zum Executable hinzugelinkt. Im C-Programm definiert man für der Zugriff auf die Daten den Prototyp&lt;br /&gt;
extern unsigned char my_data[];&lt;br /&gt;
* Frei wählbarer Symbolname&lt;br /&gt;
* Funktionierende Disassemblierung&lt;br /&gt;
* Nur mit den GNU-Binutils anwendbar&lt;br /&gt;
* Extra Assembler-Datei notwendig&lt;br /&gt;
== srec_cat ==&lt;br /&gt;
Wenn die Ausgabedatei des Compilers eine HEX-Datei ist (typisch bei µC Anwendungen) dann kann die Binärdatei mit Hilfe von srec_cat in die original Datei eingefügt werden. Bei dieser Methode kann dann allerdings nicht mehr über einen symbolischen Namen auf die Daten zugegriffen werden sondern es muss mit festen Adressen gearbeitet werden. Beispiel für eine Datei, die in die finale&lt;br /&gt;
Intel-HEX-Datei beim Offset 0xF000 eingefügt wird.&lt;br /&gt;
srec_cat myprog.hex -intel my_data.bin -binary -offset 0xF000 -output my_output.hex -intel -address-length=2&lt;br /&gt;
In C kann dann mittels eines Pointers bzw. beim AVR mitteles den pgm_read-Funktionen auf diese Daten zugegriffen werden.&lt;br /&gt;
unsigned char *my_data = (unsigned char*) 0xF000;&lt;br /&gt;
* Daten müssen zum Zeitpunkt des Linkens nicht bekannt sein (z.B. Seriennummer)&lt;br /&gt;
* Fixe Adresse muss verwendet werden&lt;br /&gt;
== #embed ==&lt;br /&gt;
C23 führt #embed ein, was benutzt werden kann um eine Datei in die C-Quelle einzufügen:&lt;br /&gt;
static const char foo_c[] =&lt;br /&gt;
#embed &amp;quot;foo.c&amp;quot;&lt;br /&gt;
    // Append \0 so that foo_c becomes a proper C string&lt;br /&gt;
    // (assuming foo.c is a text file).&lt;br /&gt;
    , &#039;\0&#039;&lt;br /&gt;
int main (void)&lt;br /&gt;
    printf (&amp;quot;== foo.c has %d bytes ==\n%s\n&amp;quot;,&lt;br /&gt;
            (int) sizeof (foo_c) - 1, foo_c);&lt;br /&gt;
* Einfache Handhabung&lt;br /&gt;
* Es können zusätzliche Zeichen vor oder nach der Datei eingefügt werden, und es können zum Beispiel mehrere Dateien zu einem Array zusammengefasst werden.&lt;br /&gt;
* sizeof kann verwendet werden.&lt;br /&gt;
* Erst ab C23 verfügbar, oder falls der Compiler #embed als Erweiterung unterstützt, etwa als GNU-C.&lt;br /&gt;
* Datei muss zur Compile-Zeit bekannt sein.&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107575</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107575"/>
		<updated>2025-06-27T16:20:54Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Optimierung */&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR118012 118012] || Expensive code (mul, neg) instead of bit test&lt;br /&gt;
| &amp;lt;tt&amp;gt;-mpr118012&amp;lt;/tt&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR113934 113934] || Switch AVR to LRA&lt;br /&gt;
| 16&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| 15&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| 14.2, 13.4, 12.5&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| 10.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107574</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107574"/>
		<updated>2025-06-27T16:16:12Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| varasm&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 16&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107285</id>
		<title>AVR-GCC</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107285"/>
		<updated>2025-02-13T15:10:55Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Vorbereitungen */&lt;/p&gt;
&lt;div&gt;avr-gcc ist ein freier [[C]]-Cross-[[Compiler]] für [[AVR]]-[[Mikrocontroller]].&lt;br /&gt;
avr-gcc kann von der Leistungsfähigkeit kommerzieller [[Compiler]] gut mithalten. Sogar C++-Programme sind möglich; in der aktuellen Fassung wird C++ jedoch nur eingeschränkt unterstützt (Stand 3/2012).&lt;br /&gt;
== Bestandteile ==&lt;br /&gt;
Die Toolchain (Werkzeugsammlung) besteht aus mehreren Kommandozeilen-Programmen, die sich auf einfache Weise in einen Editor oder eine Entwicklungsumgebung einbinden lassen. Weit verbreitet ist die Verwendung von make zur Steuerung, siehe [[AVR-GCC-Tutorial/Exkurs Makefiles|AVR-GCC-Tutorial: Exkurs Makefiles]]. &lt;br /&gt;
Die Bestandteile im einzelnen:&lt;br /&gt;
* Binutils: Assembler, Linker und weitere Hilfsprogramme.&lt;br /&gt;
* GCC: Der eigentliche C(++)-Compiler.&lt;br /&gt;
* [https://avrdudes.github.io/avr-libc/ AVR-LibC]: Die C-Standardbibliothek mit AVR-spezifischen Headerdateien und Funktionen.&lt;br /&gt;
* [[AVRDUDE]]: universelle AVR-Programmiersoftware, kein eigentlicher Teil der Toolchain, aber oft verwendet.&lt;br /&gt;
=== Linux/Unix ===&lt;br /&gt;
Atmel bietet die [http://www.atmel.com/tools/ATMELAVRTOOLCHAINFORLINUX.aspx Atmel AVR Toolchain] in verschiedenen Versionen zum Herunterladen an.&lt;br /&gt;
Wenn keine aktuelle avr-gcc-Version als Paket (Paketname ist, zumindest bei Debian, gcc-avr) für die verwendete Distribution zur Verfügung steht, dann können sich [[Unix]]/[[Linux]]-Nutzer den Sourcecode herunterladen und selbst kompilieren, dazu gibt es Schritt-für-Schritt-Anleitungen&amp;lt;ref&amp;gt;[https://avrdudes.github.io/avr-libc/avr-libc-user-manual/install_tools.html AVR-LibC: Building and Installing under Linux, FreeBSD, and Others]&amp;lt;/ref&amp;gt;&amp;lt;ref&amp;gt;[http://www.roboternetz.de/wissen/index.php/Avr-gcc_und_avrdude_installieren www.roboternetz.de: avr-gcc und avrdude installieren]&amp;lt;/ref&amp;gt;.&lt;br /&gt;
Das [http://www.femtoos.org FemtoOS]-Paket beinhaltet Scripte zum automatischen Herunterladen und Bauen einer avr-gcc Version 4.3.3.&lt;br /&gt;
Empfehlenswert ist auch [http://cdk4avr.sf.net CDK4AVR], das die entsprechenden Tools als einfach installierbare Linux-Pakete bereitstellt. Leider ist das Projekt schon etwas älter, im Forum findet sich ein [http://www.mikrocontroller.net/topic/130972 Beitrag], aktuellere Sourcen mit den entsprechenden Patches zu versehen und zu kompilieren. Patches zu den Binutils und GCC-Sourcen sind unumgänglich, da die offiziellen Sourcen aufgrund des Umfangs an Prozessortargets den aktuellsten Entwicklungen hinterherhinken und damit bereits bekannte Fehler eventuell noch nicht behoben sind. Weitere Tipps zur AVR-Programmierung unter Linux stehen im Artikel [[AVR und Linux]].&lt;br /&gt;
=== Mac OS X ===&lt;br /&gt;
Die beste fertige Toolchain ist das [http://www.obdev.at/crosspack/ Crosspack]. Dieses enthält auch die AVR-Libc, avrdude und avarice. Leider gab es bei Mac OS 10.5.6 eine tiefgreifende Änderung beim fork()-Systemcall, der bewirkt, dass avarice mit JTAGICE mkII und Dragon nicht funktioniert. Geräte mit Serial-USB-Konvertern (AVRISP clones etc) funktionieren dagegen problemlos. &lt;br /&gt;
Wer die Toolchain von Hand bauen möchte kann das natürlich auch tun, dazu einfach den unter &amp;quot;Linux/Unix&amp;quot; verlinkten Anleitungen folgen. Unter [[Mac OS X]] muss man dazu zuerst die [http://developer.apple.com/Tools/ Apple Developer Tools] installieren.&lt;br /&gt;
Teile der Toolchain (AVR-Libc und avrdude) kann folgendermaßen installieren:&lt;br /&gt;
==== Mit MacPorts ====&lt;br /&gt;
Wenn man [http://www.macports.org/ MacPorts] benutzt kann man folgendes in das Terminal eingeben, um den Toolchain zu installieren:&lt;br /&gt;
 sudo port install avr-libc&lt;br /&gt;
Das Programmiertool avrdude bekommt man genauso:&lt;br /&gt;
 sudo port install avrdude&lt;br /&gt;
==== Mit Homebrew ====&lt;br /&gt;
Mit dem neueren Tool [http://brew.sh Homebrew] funktioniert das folgendermaßen:&lt;br /&gt;
avrdude kann sofort installiert werden:&lt;br /&gt;
 brew install avrdude&lt;br /&gt;
Für den restlichen Toolchain muss man erst ein &#039;Tap&#039; hinzufügen:&lt;br /&gt;
 brew tap osx-cross/avr&lt;br /&gt;
und kann dann den eigentlichen Toolchain installieren:&lt;br /&gt;
 brew install avr-libc&lt;br /&gt;
Weblinks:&lt;br /&gt;
* [http://tinkerlog.com/2007/09/29/programming-avr-with-a-macbook/ Programming AVR with a MacBook] (engl.)&lt;br /&gt;
* [http://www.ladyada.net/library/avrdevtut/setup-mac.html AVR Tutorial from Lady Ada] (engl.)&lt;br /&gt;
* [http://www.obdev.at/crosspack/ Crosspack]&lt;br /&gt;
* [http://www.digithink.com/OSX-AVR OSX-AVR (nicht mehr aktuell)]&lt;br /&gt;
* [http://www.definefalsetrue.com/index.php/Mac-OS-X/bootfeedx.html BootFeedX Bootloaderfrontend]&lt;br /&gt;
* [http://github.com/osx-cross/homebrew-avr/ homebrew-avr]&lt;br /&gt;
=== Windows ===&lt;br /&gt;
Man kann sich auch für Windows den GCC selbst bauen oder man sucht von anderen erstellte Binaries.&lt;br /&gt;
Atmel bietet die [http://www.atmel.com/tools/atmelavrtoolchainforwindows.aspx Atmel AVR Toolchain] in verschiedenen Versionen zum Herunterladen an. Allerdings ohne &amp;quot;make&amp;quot;.&lt;br /&gt;
Der alte Klassiker [[WinAVR]] wird seit 2010 nicht mehr gepflegt und funktioniert&lt;br /&gt;
ab Windows 8 nur noch eingeschränkt.&lt;br /&gt;
Die Firma SysProgs bietet aktuelle Versionen der [http://gnutoolchains.com GNU Toolchain]&lt;br /&gt;
einschließlich &amp;quot;make&amp;quot; für viele Systemarchitekturen zum Download an.&lt;br /&gt;
==== Selbst bauen ====&lt;br /&gt;
Zuerst sei einmal die offizielle (englische) Anleitung genannt: [https://avrdudes.github.io/avr-libc/avr-libc-user-manual/install_tools.html Building and Installing avr-gcc]&lt;br /&gt;
Das hier ist die etwas ausführlichere Beschreibung, die mir Johann L. gegeben hat, damit ich meinen Compiler erstellen konnte. Der Post dazu findet sich [https://www.mikrocontroller.net/topic/384825?goto=4394391#4394606 hier]. &lt;br /&gt;
Zuerst einmal braucht man am besten ein Linux, zum Beispiel ein aktuelles Ubuntu. dort müssen diverse Programme wie gcc, autoconf, subversion usw. installiert sein. Wenn etwas fehlt meckert configure, das einfach aufmerksam lesen und dann die Programme nachinstallieren. Danach erneut configure aufrufen.&lt;br /&gt;
Um die Toolchain für Windows zu bauen brauchen wir noch mingw32 (aktueller Name in den meisten Paketquellen: mingw32-w64-gcc oder gcc-w64-mingw32). Eventuell findet sich das in den Paketquellen eurer Distribution, sonst kann ich auf [http://www.blogcompiler.com/2010/07/11/compile-for-windows-on-linux/ diese Seite] verweisen.&lt;br /&gt;
===== Vorbereitungen =====&lt;br /&gt;
Wie schon gesagt brauchen wir ein Linux, zum Beispiel in einer VM. Ein minimales Linux-Hintergrundwissen wären auch gut, aber es geht notfalls (Google &amp;amp; co. sind die Freunde) auch ohne.&lt;br /&gt;
&#039;&#039;&#039;Achtung:&#039;&#039;&#039; Auf diesem Linux darf kein avr-gcc und keine avr-libc vorhanden sein!&lt;br /&gt;
Dazu brauchen wir die folgende Software:&lt;br /&gt;
* GNU Binutils: [https://www.sourceware.org/binutils/ Download], am besten die neueste Version (runter scrollen, aktuell ist 2.27)&lt;br /&gt;
* GCC Sourcen: [https://gcc.gnu.org/ Download], diese sollten aus dem svn kommen (svn co svn://gcc.gnu.org/svn/gcc/branches/&#039;&#039;branchname&#039;&#039; gcc ,mit &#039;&#039;branchname&#039;&#039; gcc-&#039;&#039;version&#039;&#039;-branch, aktuell ist gcc-6-branch) oder aus dem aktuellen &#039;&#039;trunk&#039;&#039; (svn co svn://gcc.gnu.org/svn/gcc/trunk).&lt;br /&gt;
* Die AVR-LibC: [https://avrdudes.github.io/avr-libc/ Download]. &#039;&#039;Achtung:&#039;&#039; Ab GCC v5 muss mindestens eine AVR-LibC &amp;amp;ge; v2.0.0 verwendet werden. Ältere GCCs brauchen natürlich auch eine AVR-LibC vor dieser Version.&lt;br /&gt;
Alles herunterladen und entpacken.&lt;br /&gt;
Zu den Downloads kommen dann noch 2 Umgebungsvariablen:&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;bash&amp;quot;&amp;gt;&lt;br /&gt;
$ PREFIX=$HOME/local/avr&lt;br /&gt;
$ export PREFIX&lt;br /&gt;
$ PATH=$PATH:$PREFIX/bin&lt;br /&gt;
$ export PATH&lt;br /&gt;
Damit legt ihr das Installationsverzeichnis fest und fügt auch gleich das Verzeichnis für die ausführbaren Dateien zum Pfad hinzu.&lt;br /&gt;
Im Folgenden gehe ich von diesem Ordner-Layout aus:&lt;br /&gt;
$HOME&lt;br /&gt;
+ BuildToolchain&lt;br /&gt;
   + Downloads&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + binutils&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   + avr-libc&lt;br /&gt;
   + buildLinux&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   + buildWindows&lt;br /&gt;
      + gcc&lt;br /&gt;
===== Erstellen der Binutils =====&lt;br /&gt;
Wechselt in das Verzeichnis BuildToolchain/buildLinux/binutils.&lt;br /&gt;
Von dort aus werden wir die binutils konfigurieren und erstellen.&lt;br /&gt;
&#039;&#039;&#039;Achtung:&#039;&#039;&#039; man darf weder GCC noch die Binutils in einem Verzeichnis innerhalb des Quellordners der Downloads konfigurieren, sonst kommen wirre Fehler. Wer sich an die Anleitung hält kann diesen Fehler (fast) nicht machen.&lt;br /&gt;
Also, wir sind soweit. Jetzt geht es ans Konfigurieren der binutils und danach ans kompilieren, aber das ist ganz leicht:&lt;br /&gt;
$ ../../Downloads/binutils/configure --prefix=$PREFIX --target=avr --disable-nls&lt;br /&gt;
Wenn configure fehlende Programme meldet: nachinstallieren und erneut versuchen.&lt;br /&gt;
$ make&lt;br /&gt;
$ make install&lt;br /&gt;
Damit sind die binutils für Linux fertig. Ihr könnt nachkontrollieren, ob die binutils da sind: Im Ordner $PREFIX/bin sollten sich die Dateien befinden, darunter avr-objcopy, avr-as, avr-size, etc.&lt;br /&gt;
===== Erstellen vom GCC =====&lt;br /&gt;
Als erstes muss sich der GCC noch ein paar zusätzliche Dateien herunterladen, das geschieht automatisch mit dem Befehl (ausgeführt in BuildToolchain/Downloads/gcc):&lt;br /&gt;
./contrib/download_prerequisites&lt;br /&gt;
Wechselt ins Verzeichnis BuildToolchain/buildLinux/gcc&lt;br /&gt;
Dort führt ihr das Folgende aus:&lt;br /&gt;
$ ../../Downloads/gcc/configure --prefix=$PREFIX --target=avr \&lt;br /&gt;
    --enable-languages=c,c++,lto --disable-nls --disable-libssp --with-dwarf2&lt;br /&gt;
$ make&lt;br /&gt;
===== Erstellen der AVR-LibC =====&lt;br /&gt;
Als erstes muss die AVR-LibC zum konfigurieren bereit gemacht werden:&lt;br /&gt;
Im Verzeichnis BuildToolchain/Downloads/avr-libc die Datei bootstrap ausführen&lt;br /&gt;
./bootstrap&lt;br /&gt;
Danach wechselt ihr ins Verzeichnis BuildToolchain/buildLinux/avr-libc&lt;br /&gt;
$ ../../Downloads/avr-libc/configure --prefix=$PREFIX --build=`./config.guess` --host=avr&lt;br /&gt;
$ make&lt;br /&gt;
===== Testen unter Linux =====&lt;br /&gt;
So, jetzt seit ihr schon bei der Hälfte: Der Compiler läuft schon unter Linux! &lt;br /&gt;
Das testet ihr am besten schon mit ein paar einfachen LED-blink-Programmen, damit auch sichergestellt ist, dass bis hierhin alles geklappt hat.&lt;br /&gt;
Das einfachste und wichtigste Kommando dürfte sein&lt;br /&gt;
$ avr-gcc --version&lt;br /&gt;
Dort sollte die Versionsnummer der GCC stehen. Wenn eine ältere Nummer dasteht, hab ihr entweder einen alten Download bemüht, oder eine andere Version vom avr-gcc war noch installiert.&lt;br /&gt;
Wenn der Fehler kommt, dass das Programm nicht gefunden werden kann, dann befindet sich avr-gcc nicht im PATH, das bedeutet ihr habt die Umgebungsvariablen nicht richtig gesetzt (siehe oben).&lt;br /&gt;
===== Bau für Windows =====&lt;br /&gt;
Ihr müsst keine neuen Dateien runter laden, lediglich die Programme nochmal etwas anders konfigurieren.&lt;br /&gt;
Die Schritte davor &#039;&#039;&#039;müssen&#039;&#039;&#039; jedoch ausgeführt werden!&lt;br /&gt;
Wechselt ins Verzeichnis BuildToolchain/buildWindows/binutils und führt das Folgende aus&lt;br /&gt;
$ ../../Download/binutils/configure --prefix=$HOME/local/avr4win --target=avr --disable-nls \&lt;br /&gt;
    --host=plattform-w64-mingw32 --build=plattform-linux-gnu&lt;br /&gt;
$ make&lt;br /&gt;
Wobei &#039;&#039;plattform&#039;&#039; euer Ziel-System ist, also entweder i686 oder x86_64, je nach dem, was ihr für ein mingw installiert habt und ob ihr den Compiler für 32bit (i686) oder 64bit (x86_64) baut.&lt;br /&gt;
Wechselt ins Verzeichnis BuildToolchain/buildWindows/gcc und führt das Folgende aus&lt;br /&gt;
$ ../../Downloads/gcc/configure --prefix=$HOME/local/avr4win --target=avr --disable-nls \&lt;br /&gt;
    --host=plattform-w64-mingw32 --build=plattform-linux-gnu --enable-languages=c,c++,lto --with-gnu-as \&lt;br /&gt;
    --with-gnu-ld --disable-shared --with-dwarf2&lt;br /&gt;
$ make&lt;br /&gt;
Wechselt ins Verzeichnis BuildToolchain/buildLinux/avr-libc und führt den folgenden Befehl aus:&lt;br /&gt;
$ make install prefix=$HOME/local/avr4win&lt;br /&gt;
Eigentlich ist der Compiler auch &amp;quot;schon&amp;quot; fertig. Aber in den Binaries sind noch die gesamten Symbole enthalten, was die .exe-Dateien aufbläht. Um diese los zu werden, kann man einfach noch diesen Befehl ausführen:&lt;br /&gt;
$ find . -name &#039;*.exe&#039; -exec plattform-w64-mingw32-strip {} &#039;;&#039;&lt;br /&gt;
Damit sollten ihr im Ordner $HOME/local/avr4win die gesamte Toolchain haben. Diesen Ordner müsst ihr nur noch auf euren Windows-PC kopieren.&lt;br /&gt;
Für das klassische WinAVR fehlt noch Programmers Notepad, sowie die Utility-Programme, vor allem avrdude und make. Diese kann man entweder seperat downloaden oder aus einer WinAVR-Installation kopieren. Die Versionen davon spielen keine Rolle.&lt;br /&gt;
Win32:&lt;br /&gt;
* [[AVR-Studio]]: ab Version 4.12 mit WinAVR-Unterstützung, integrierter Simulator, Debugger, rudimentäre Projektverwaltung&lt;br /&gt;
* Programmers-Notepad: wird bei [[WinAVR]] mitgeliefert, ein guter Editor mit einer rudimentären Projektverwaltung&lt;br /&gt;
* [http://www.myavr.info/download/benutzerhandbuch_sisy_avr.pdf SiSy-AVR]: ein CASE-Tool mit WinAVR-Unterstützung, das eine Entwicklungsumgebung bereitstellt.&lt;br /&gt;
Plattformunabhängig:&lt;br /&gt;
* [http://www.eclipse.org/ Eclipse] mit CDT und dem [http://avr-eclipse.sourceforge.net/index.html AVR Eclipse Plugin]&lt;br /&gt;
* [[Code::Blocks]]: vielseitige, freie Entwicklungsumgebung für Windows und Linux&lt;br /&gt;
* [http://www.netbeans.org/ Netbeans] in der C++ - Version mit [[WinAVR]] oder [[avr-gcc]] als Toolchain&lt;br /&gt;
Linux:&lt;br /&gt;
*[http://sourceforge.net/projects/kontrollerlab/?_test=b KontrollerLab] ist eine freie Entwicklungsumgebung für AVR momentan aber noch im Beta-stadium.&lt;br /&gt;
== Bibliotheken / Libraries ==&lt;br /&gt;
Die [https://github.com/avrdudes/avr-libc AVR-LibC] ist die gebräuchliche &amp;quot;Laufzeitbibliothek&amp;quot; zum avr-gcc C-Compiler, welche den Zugriff auf die AVR-Hardware erheblich erleichtert. Die offizielle Dokumentation zur AVR-LibC mit vielen Hinweisen auch zum Compiler avr-gcc und verschiedener Tools (z.&amp;amp;nbsp;B. [[AVRDUDE]]) findet man [https://avrdudes.github.io/avr-libc/ hier].&lt;br /&gt;
Auch die [http://www.procyonengineering.com/embedded/avr/avrlib/ Procyon AVRlib] enthält nützlichen Code z.&amp;amp;nbsp;B. für UART, LCD,.... Bei der Procyon AVRlib ist die Lizenz zu beachten (in Kurzform: man muss dritten auf Verlangen den gesamten Quellcode der Firmware zur Verfügung stellen, falls Teile der Procyon Bibliothek genutzt werden).&lt;br /&gt;
Zum Zugriff auf interne Funktionen oder externe Peripherie existieren einige fertige Komponenten. Z.B. &amp;quot;Projects&amp;quot;-Bereich von [http://www.avrfreaks.net/ avrfreaks.net] (Anmeldung erforderlich (kostenlos)). &lt;br /&gt;
Die Erstellung eigener Bibliotheken ist im Artikel  [[Libraries]] erklärt.&lt;br /&gt;
Eine Liste mit einigen Hinweisen:&lt;br /&gt;
* 07.10.11 → es kann Probleme mit der aktuellen Eclipse-Version (Indigo) und WinAVR geben. Falls ihr Indigo installiert habt und Eclipse die Definitionen wie z.B. DDRA nicht kennt, jedoch kompillieren kann, dann müsst ihr auf die Version Helios SR2 wechseln. Danach läuft alles wie gehabt!&lt;br /&gt;
* Keine &amp;quot;antiken&amp;quot; Versionen verwenden. Für MS-Windows-Nutzer: aktuelles WinAVR installieren. Für Linux/Unix-Nutzer: letzte stabile Version selbst kompilieren oder aus &amp;quot;Distribution-Packages&amp;quot; installieren (z.&amp;amp;nbsp;B. [http://cdk4avr.sourceforge.net/ cdk4avr]).&lt;br /&gt;
* Bei Problemen zuerst in die [https://avrdudes.github.io/avr-libc/avr-libc-user-manual/ Anleitung] der AVR-LibC schauen. Insbesondere die [https://avrdudes.github.io/avr-libc/avr-libc-user-manual/FAQ.html FAQ] lesen.&lt;br /&gt;
* Sicherstellen, dass der MCU-Parameter (zum Compiler/Linker, meist im Makefile defniert) mit dem Zielprozessor übereinstimmt.&lt;br /&gt;
* [[AVR-GCC-Tutorial]] in diesem Wiki lesen.&lt;br /&gt;
* Im Zweifel nicht INTERRUPT(...) sondern SIGNAL(...) nutzen. In neueren Versionen der AVR-LibC wurde &amp;quot;ISR&amp;quot; als Ersatz für SIGNAL eingeführt und sollte genutzt werden (SIGNAL und INTERRUPT werden langfristig entfallen). Darauf achten, dass die Vektor- bzw. Signal-Namen (&amp;quot;Parameter&amp;quot;) zu ISR bzw. SIGNAL (und INTERRUPT wenn denn unbedingt erforderlich) richtig geschrieben sind. [https://avrdudes.github.io/avr-libc/avr-libc-user-manual/group__avr__interrupts.html#avr_signames Die Namen] sind in der in der entsprechenden Header-Datei (ioxxx.h) für den Controller und der AVR-LibC-Dokumenation aufgelistet. Im Zweifel den erzeugten Interrupt-Vektor im Assembler-Listing prüfen, es darf &#039;&#039;&#039;kein&#039;&#039;&#039; SIG_&#039;&#039;xxx&#039;&#039; oder xxx_vect mehr zu sehen sein, sondern _vector_&#039;&#039;N&#039;&#039; (wobei &#039;&#039;N&#039;&#039; eine Zahl ist). Neuere Versionen des avr-gcc zeigen eine Warnung, falls etwas falsch geschrieben wurde, ältere Versionen nicht.&lt;br /&gt;
* Zugriff auf Daten(-Tabellen) im Programmspeicher (Flash) erfolgt über Program-Space-Funktionen (pgm_read* oder __flash). Lediglich die Definition einer Variablen/eines Feldes mit dem PROGMEM Attribut zu versehen, reicht (im Gegensatz zu Codevision, IAR, Imagecraft) nicht aus.&lt;br /&gt;
* Nicht alle AVRs werden vollständig von der AVR-LibC bzw. dem Compiler unterstützt. Bei Problemen hilft oft ein Blick in den erzeugten Assembler-Code. Die Anzahl der unterstützen Controller steigt jedoch mit Version zu Version von Binutils, AVR-LibC und avrdude. Evtl. reicht einfach ein Update auf neuere Software-Versionen (z.&amp;amp;nbsp;B. im jeweils aktuellen WinAVR-Packet).&lt;br /&gt;
* inp(), outp(), sbi() und cbi() werden in der aktuellen Bibliotheksversion nicht offiziell unterstützt (man muss eine spezielle Header-Datei einbinden(deprecated.h). Es wird schon seit längerem empfohlen, diese Makros nicht mehr zu nutzen. Einige Anleitungen sind in diesem Punkt veraltet. Mit halbwegs aktuellen avr-gcc/avr-libc-Versionen kann einfach z.&amp;amp;nbsp;B. DDRB=0xfe bzw. foo=PINB geschrieben werden.  Mit PORTB |= _BV(1) setzt man PORTB.1, mit PORTB &amp;amp;= ~_BV(1) löscht man es wieder, mit PORTB ^= _BV(1) kann man es umschalten (_BV(x) entspricht dabei (1&amp;lt;&amp;lt;x)). Die ersten beiden Varianten erzeugen bei eingeschalteter Optimierung und passenden Parametern (wie hier im Beispiel Register im &amp;quot;unteren&amp;quot; Speicherbereich) die SBI bzw. CBI Prozessorbefehle.&lt;br /&gt;
* Mit dem Tool avr-nm erhält man eine Übersicht über die Platzausnutzung in der erzeugten ELF-Datei bzw. dem damit gefüllten AVR. Das Tool wird per Kommandozeile mit &lt;br /&gt;
::&amp;lt;pre&amp;gt;avr-nm --size-sort --print-size -r -td &amp;lt;your_ELF_file&amp;gt;&amp;lt;/pre&amp;gt;&lt;br /&gt;
:aufgerufen und gibt eine vierspaltige Liste aus: Die erste Spalte ist die Adresse, die zweite die benötigte Größe, die dritte der Typ und die vierte der Name des Symbols. Alle Symbole vom Typ &amp;quot;T&amp;quot; (globale Funktionen), &amp;quot;t&amp;quot; (lokale Funktionen) und letztlich auch die mit einem &amp;quot;D&amp;quot; oder &amp;quot;d&amp;quot; (globale bzw. lokale Daten mit Initialisierungswerten im ROM) betreffen das FLASH-ROM. Typen &amp;quot;B&amp;quot; und &amp;quot;b&amp;quot; brauchen ausschließlich RAM (werden beim Start mit 0 initialisiert). (vgl. [http://www.mikrocontroller.net/topic/59960#467920 Forenbeitrag] von Jörg Wunsch)&lt;br /&gt;
* Mit dem Tool avr-size erhält man eine Übersicht über den Platzbedarf in den text, data und bss Sektionen innerhalb der ELF Binärdatei. Die Sektionen text und data benötigen Platz im FLASH-ROM und die Sektionen data und bss benötigen zur Laufzeit Platz im SRAM.&lt;br /&gt;
* [[AVR-GCC-Codeoptimierung]]&lt;br /&gt;
* [[GCC: unbenutzte Funktionen entfernen]]&lt;br /&gt;
* [http://www.roboternetz.de/wissen/index.php/Avr-gcc/Interna AVR-GCC Interna]&lt;br /&gt;
* [https://www.mikrocontroller.net/topic/479027#5934443 Forumsbeitrag]: RAM Verbrauch auch von lokalen variablen ermitteln&lt;br /&gt;
* [http://winavr.sourceforge.net/install_config_WinAVR.pdf Tutorial von C. O&#039;Flynn und E. Weddington] Einstieg in die Nutzung des avr-gcc unter MS-Windows mit WinAVR (englisch)&lt;br /&gt;
* [http://www.linuxfocus.org/Deutsch/November2004/article352.shtml AVR-GCC und Linux]&lt;br /&gt;
* [http://www.mikrocontroller.net/forum/list-2-1.html GCC-Forum auf mikrocontroller.net]&lt;br /&gt;
[[Category:AVR]]&lt;br /&gt;
[[Category:Compiler]]&lt;br /&gt;
[[Kategorie:avr-gcc| ]]&lt;/div&gt;</summary>
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107284</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107284"/>
		<updated>2025-02-13T15:07:32Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Bestandteile */&lt;/p&gt;
* Die AVR-libc: [http://download.savannah.gnu.org/releases/avr-libc/ Download]. &#039;&#039;Achtung:&#039;&#039; Ab gcc-Version 5 muss mindestens eine avr-libc-Version &amp;gt;= 2.0.0 verwendet werden. Ältere GCCs brauchen natürlich auch eine avr-libc vor dieser Version.&lt;br /&gt;
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107283</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107283"/>
		<updated>2025-02-13T15:05:44Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Tipps &amp;amp; Tricks */&lt;/p&gt;
* AVR-Libc: Die C-Standardbibliothek mit AVR-spezifischen Headerdateien und Funktionen.&lt;br /&gt;
* [[AVRDUDE]]: universelle AVR-Programmiersoftware, kein eigentlicher Teil der Toolchain, aber oft verwendet&lt;br /&gt;
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107282</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107282"/>
		<updated>2025-02-13T15:03:47Z</updated>
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
* Im Zweifel nicht INTERRUPT(...) sondern SIGNAL(...) nutzen. In neueren Versionen der AVR-LibC wurde &amp;quot;ISR&amp;quot; als Ersatz für SIGNAL eingeführt und sollte genutzt werden (SIGNAL und INTERRUPT werden langfristig entfallen). Darauf achten, dass die Vektor- bzw. Signal-Namen (&amp;quot;Parameter&amp;quot;) zu ISR bzw. SIGNAL (und INTERRUPT wenn denn unbedingt erforderlich) richtig geschrieben sind. Die Namen sind in der in der entsprechenden Header-Datei (ioxxx.h) für den Controller und der [https://avrdudes.github.io/avr-libc/avr-libc-user-manual/group__avr__interrupts.html#avr_signames AVR-LibC-Dokumenation] aufgelistet. Im Zweifel den erzeugten Interrupt-Vektor im Assembler-Listing prüfen, es darf &#039;&#039;&#039;kein&#039;&#039;&#039; SIG_&#039;&#039;xxx&#039;&#039; oder xxx_vect mehr zu sehen sein, sondern _vector_&#039;&#039;N&#039;&#039; (wobei &#039;&#039;N&#039;&#039; eine Zahl ist). Neuere Versionen des avr-gcc zeigen eine Warnung, falls etwas falsch geschrieben wurde, ältere Versionen nicht.&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107281</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107281"/>
		<updated>2025-02-13T14:55:39Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: linkfix avr-libc&lt;/p&gt;
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
* Im Zweifel nicht INTERRUPT(...) sondern SIGNAL(...) nutzen. In neueren Versionen der avr-libc wurde &amp;quot;ISR&amp;quot; als Ersatz für SIGNAL eingeführt und sollte genutzt werden (SIGNAL und INTERRUPT werden langfristig entfallen). Darauf achten, dass die Vektor- bzw. Signal-Namen (&amp;quot;Parameter&amp;quot;) zu ISR bzw. SIGNAL (und INTERRUPT wenn denn unbedingt erforderlich) richtig geschrieben sind. Die Namen sind in der in der entsprechenden Header-Datei (ioxxx.h) für den Controller und der avr-libc-Dokumenation aufgelistet. Im Zweifel den erzeugten Interrupt-Vektor im Assembler-Listing prüfen, es darf &#039;&#039;&#039;kein&#039;&#039;&#039; SIG_&#039;&#039;xxx&#039;&#039; oder xxx_vect mehr zu sehen sein, sondern _vector_&#039;&#039;N&#039;&#039; (wobei &#039;&#039;N&#039;&#039; eine Zahl ist). Neuere Versionen der avr-gcc zeigen eine Warnung, falls etwas falsch geschrieben wurde, ältere Versionen nicht.&lt;br /&gt;
* Zugriff auf Daten(-Tabellen) im Programmspeicher (Flash) erfolgt über Program-Space-Funktionen (pgm_read*). Lediglich die Definition einer Variablen/eines Feldes mit dem PROGMEM Attribut zu versehen, reicht (im Gegensatz zu Codevision, IAR, Imagecraft) nicht aus.&lt;br /&gt;
* Nicht alle AVRs werden vollständig von der avr-libc bzw. dem Compiler unterstützt. Bei Problemen hilft oft ein Blick in den erzeugten Assembler-Code. Die Anzahl der unterstützen Controller steigt jedoch mit Version zu Version von binutils, avr-libc und avrdude. Evtl. reicht einfach ein Update auf neuere Software-Versionen (z.&amp;amp;nbsp;B. im jeweils aktuellen WinAVR-Packet).&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107280</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107280"/>
		<updated>2025-02-13T14:51:38Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Erstellen der avr-libc */&lt;/p&gt;
Wenn keine aktuelle avr-gcc-Version als Paket (Paketname ist, zumindest bei Debian, gcc-avr) für die verwendete Distribution zur Verfügung steht, dann können sich [[Unix]]/[[Linux]]-Nutzer den Sourcecode herunterladen und selbst kompilieren, dazu gibt es Schritt-für-Schritt-Anleitungen&amp;lt;ref&amp;gt;[http://www.nongnu.org/avr-libc/user-manual/install_tools.html AVR-Libc: Building and Installing under Linux, FreeBSD, and Others]&amp;lt;/ref&amp;gt;&amp;lt;ref&amp;gt;[http://www.roboternetz.de/wissen/index.php/Avr-gcc_und_avrdude_installieren www.roboternetz.de: avr-gcc und avrdude installieren]&amp;lt;/ref&amp;gt;.&lt;br /&gt;
Zuerst sei einmal die offizielle (englische) Anleitung genannt: [http://www.nongnu.org/avr-libc/user-manual/install_tools.html Building and Installing avr-gcc]&lt;br /&gt;
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
* Bei Problemen zuerst in die [http://www.nongnu.org/avr-libc/user-manual/index.html Anleitung] der avr-libc schauen. Insbesondere die FAQ lesen.&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107279</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107279"/>
		<updated>2025-02-13T14:51:13Z</updated>
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
===== Erstellen der avr-libc =====&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107278</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC&amp;diff=107278"/>
		<updated>2025-02-13T14:48:51Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Bibliotheken / Libraries */ avr-libc: nongnu -&amp;gt; github&lt;/p&gt;
$HOME&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
   |   |&lt;br /&gt;
   |   + gcc&lt;br /&gt;
      + gcc&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Als erstes muss die avr-libs zum konfigurieren bereit gemacht werden:&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
$ make&lt;br /&gt;
Win32:&lt;br /&gt;
Linux:&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107165</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107165"/>
		<updated>2024-11-19T20:43:56Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Bugs */&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| 15&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| 14.2, 13.4, 12.5&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| 10.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107164</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107164"/>
		<updated>2024-11-19T20:42:52Z</updated>
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107163</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107163"/>
		<updated>2024-11-19T20:39:56Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Optimierung */&lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107162</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107162"/>
		<updated>2024-11-19T17:39:33Z</updated>
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 15&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 10.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107161</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107161"/>
		<updated>2024-11-19T15:02:03Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: &lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| 15&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| 14.2, 13.4, 12.5&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| 10.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=AVR-Simulation&amp;diff=107102</id>
		<title>AVR-Simulation</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-Simulation&amp;diff=107102"/>
		<updated>2024-10-02T16:39:29Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* AVRtest */ Link nach GitHub&lt;/p&gt;
== SimulAVR ==&lt;br /&gt;
[http://www.nongnu.org/simulavr/ SimulAVR] ist ein Simulator, der einige Prozessoren der AVR-Familie auf einem PC-Hostsystem (Windows, Linux, Mac OS X) simulieren kann. Dieser Simulator ist auch im [[WinAVR]]-Paket enthalten (/WinAVR/bin/simulavr.exe).&lt;br /&gt;
Eine Verwendung von SimulAVR ist das sog. Signal Tracing, d.h. das aufzeichnen von Änderungen der diversen Register (z.B. der Pins eines I/O-Ports) in eine VCD-Datei. Auch wenn die Laufzeit des Simulators oft langsamer als die der Hardware ist, entsprechen diese Aufzeichnungen auf den CPU-Takt genau dem, was auf der Hardware passieren würde. Wie diese Aufzeichnungen gemacht werden ist bei SimulAVR selbst kaum dokumentiert, doch bei RepRap gibt es eine kleine [http://reprap.org/wiki/SimulAVR#Signal_tracing SimulAVR Anleitung], die eine gute Passage dazu enthält.&lt;br /&gt;
Die Hauptanwendung von SimulAVR dürfte das Debuggen sein. Dafür wird SimulAVR über ein dazu passendes Frontend bedient. GDB und Insight sind zwei, ebenfalls in WinAVR enthaltene, Programme, die ein solches Frontend bilden. &lt;br /&gt;
Wer &amp;quot;textorientiertes&amp;quot; Debugging mag, oder beispielsweise &#039;&#039;emacs&#039;&#039; als Frontend verwenden möchte, der nutzt den [[GDB]], den GNU Debugger. Er ist im WinAVR-Paket enthalten (/WinAVR/bin/avr-gdb.exe). Wer gleich eine grafische Benutzeroberfläche (GUI) verwenden möchte, nutzt Insight (welches intern ebenfalls den GDB verwendet). &lt;br /&gt;
Beide Debugger, also GDB oder Insight, benötigen ein Backend. Entweder handelt es sich dabei um einen ICE/[[JTAG]]-Debugger wie z.&amp;amp;nbsp;B. [http://avarice.sourceforge.net/ AVaRICE] als Interface zu einem realen AVR-Mikrocontroller oder um einen Simulator.&lt;br /&gt;
=== Starten von SimulAVR ===&lt;br /&gt;
[[Datei:SimulAVR-Display.png|right|220px]]&lt;br /&gt;
Um SimulAVR mit default-Parametern zu starten, reicht es aus, folgende Zeile in einer Shell/Eingabeaufforderung einzugeben:&lt;br /&gt;
 $ simulavr -g -d &amp;lt;AVR-Prozessortyp&amp;gt;&lt;br /&gt;
SimulAVR startet dann mit den defaultparametern und stellt einen GDBServer-Prozess auf dem lokalen oder entfernten Host auf Port 1212 zur Verfügung.&lt;br /&gt;
Das &#039;&#039;Backend&#039;&#039; der Simulation ist nun Einsatzbereit.&lt;br /&gt;
Eine weitere Möglichkeit ist, SimulAVR mit Display zu starten. Dann werden während der Ausführung die Werte der Register und dem RAM angezeigt (siehe Bild).&lt;br /&gt;
 $ simulavr -g -P simulavr-disp -d &amp;lt;AVR-Prozessortyp&amp;gt;&lt;br /&gt;
Eine Übersicht der unterstützten AVR-Prozessoren und der SimulAVR spezifischen Parameter bekommt man durch folgende Zeile:&lt;br /&gt;
 $ simulavr --help&lt;br /&gt;
=== Starten des GDB ===&lt;br /&gt;
Um das (vorläufige) Frontend GDB zu starten, reicht folgende Zeile:&lt;br /&gt;
 $ avr-gdb&lt;br /&gt;
Der GDB meldet sich mit folgendem Bildschirm:&lt;br /&gt;
Current directory is c:/WinAVR/testprj4/&lt;br /&gt;
GNU gdb 6.1&lt;br /&gt;
Copyright 2004 Free Software Foundation, Inc.&lt;br /&gt;
GDB is free software, covered by the GNU General Public License, and you are&lt;br /&gt;
welcome to change it and/or distribute copies of it under certain conditions.&lt;br /&gt;
Type &amp;quot;show copying&amp;quot; to see the conditions.&lt;br /&gt;
There is absolutely no warranty for GDB.  Type &amp;quot;show warranty&amp;quot; for details.&lt;br /&gt;
This GDB was configured as &amp;quot;--host=i686-pc-cygwin --target=avr&amp;quot;.&lt;br /&gt;
(gdb) &lt;br /&gt;
&#039;&#039;&#039;(gdb)&#039;&#039;&#039; ist der Prompt.&lt;br /&gt;
Soll während dem Debuggen der Quellcode angezeigt werden, der zur Zeit ausgeführt wird, kann GDB wie folgt gestartet werden.&lt;br /&gt;
 $ avr-gdb -tui&lt;br /&gt;
Beim (gdb) prompt dann das Layout auf Assembler umschalten.,&lt;br /&gt;
 (gdb) layout asm&lt;br /&gt;
=== Simulieren/Debuggen ===&lt;br /&gt;
Im ersten Schritt muss dem GDB die gewünschte Datei (vorher mittels entsprechendem &#039;&#039;Makefile&#039;&#039; erzeugt) bekannt gemacht werden. Es ist darauf zu achten, dass das Programm mit Debugsymbolen kompiliert wurde.&lt;br /&gt;
 (gdb) file main.elf &lt;br /&gt;
 Reading symbols from main.elf...done.&lt;br /&gt;
Als nächstes muss dem GDB mitgeteilt werden, welches Ziel (target) er als Backend verwenden soll:&lt;br /&gt;
 (gdb) target remote localhost:1212&lt;br /&gt;
oder kürzer:&lt;br /&gt;
 (gdb) targ rem :1212&lt;br /&gt;
 Remote debugging using :1212&lt;br /&gt;
 0x00000000 in __vectors ()&lt;br /&gt;
Jetzt muss das Programm in den Simulator geladen werden:&lt;br /&gt;
 (gdb) load&lt;br /&gt;
 Loading section .data, size 0x32 lma 0x1bc&lt;br /&gt;
 Loading section .text, size 0x1bc lma 0x0&lt;br /&gt;
 Start address 0x0, load size 494&lt;br /&gt;
 Transfer rate: 3952 bits in &amp;lt;1 sec, 30 bytes/write.&lt;br /&gt;
Da diese 3 Schritte üblicherweise, bei jedem Start einer Simulationssitzung ausgeführt werden müssen, können sie zeilenweise in eine Textdatei (Vorschlag: gdb.conf) geschrieben werden, diese Datei wird dem gdb dann mit dem Parameter &amp;quot;-x&amp;quot; (eXecute) mitgegeben:&lt;br /&gt;
avr-gdb -x gdb.conf&lt;br /&gt;
Alternativ zu dem remote-debugging kann auch der avr-gdb-interne Simulator benutzt werden. Dieser wird mit&amp;lt;br /&amp;gt;&lt;br /&gt;
 target sim&amp;lt;br /&amp;gt;&lt;br /&gt;
gestartet.&lt;br /&gt;
Damit der Simulator nicht das gesamte Programm abarbeitet, sollte man &#039;&#039;breakpoints&#039;&#039; setzen.&lt;br /&gt;
Den Ersten am besten bei &#039;&#039;main&#039;&#039;:&lt;br /&gt;
 (gdb) b main&lt;br /&gt;
 Breakpoint 1 at 0xd2: file main.c, line 16.&lt;br /&gt;
Jetzt kann man das Programm im Simulator mit &#039;&#039;continue&#039;&#039; starten:&lt;br /&gt;
 (gdb) c&lt;br /&gt;
 Continuing.&lt;br /&gt;
Bei Erreichen des zuvor gesetzten &#039;&#039;breakpoints&#039;&#039; stoppt GDB und meldet:&lt;br /&gt;
 Breakpoint 1, main () at main.c:16&lt;br /&gt;
 (gdb)&lt;br /&gt;
Eine Liste der verfügbaren debug-befehle des GDB findet sich durch die Eingabe von &#039;&#039;&#039;help&#039;&#039;&#039;.&lt;br /&gt;
=== Data Display Debugger ===&lt;br /&gt;
[[Datei:ddd_c.png|right|200px]]&lt;br /&gt;
Eine sehr komfortable Benutzeroberfläche zum gdb erhält man mit dem Programm &amp;quot;ddd&amp;quot; (Data Display Debugger), https://de.wikipedia.org/wiki/Data_Display_Debugger&lt;br /&gt;
Diesem gibt man beim Aufruf mit, welcher gdb, mit welcher Verbindung zum Ziel genutzt werden soll. Falls das Startscript, wie oben genutzt werden soll z.B.:&lt;br /&gt;
ddd --debugger &amp;quot;avr-gdb -x gdb.conf&amp;quot;&lt;br /&gt;
Wenn das Projekt mit den entsprechenden Debug-Informationen übersetzt wurde, dann zeigt der DDD die Zeile im Quelltext (auch bei Assemblerteilen), Variableninhalte lassen sich inspizieren, indem der Mauszeiger drauf positioniert wird.&lt;br /&gt;
[[Datei:ddd_asm.png|right|200px]]&lt;br /&gt;
=== ToDo ===&lt;br /&gt;
[TODO] Einige häufige GDB-Commands als Beispiel einfügen.&lt;br /&gt;
== VMLab ==&lt;br /&gt;
[http://www.amctools.com/vmlab.htm VMLab] ist eine komplette Freeware-IDE mit Debugger und Simulator für MS-Windows. VMLab arbeitet mit [[WinAVR]] zusammen und kann AVR-Peripheriehardware simulieren. Leider hat der Autor von VMLab die Entwicklung im Jahr 2006 eingestellt, da dem Projekt nicht der gewünschte kommerzielle Erfolg vergönnt war. Die aktuelle Version ist 3.15 von Oktober 2009.&lt;br /&gt;
* Forumsbeitrag [http://www.mikrocontroller.net/topic/24494#714662 VMLAB Bug bei Stackpointer/Interrupt?]&lt;br /&gt;
* [http://www.mikrocontroller.net/topic/85212#716727 Workaround]&lt;br /&gt;
== AVR Studio ==&lt;br /&gt;
[[Bild: AVR-Studio_Simulation.png|thumb|right|250px|Simulator-Ansicht in AVR Studio]]&lt;br /&gt;
[[AVR-Studio|AVR Studio]] von Atmel enthält neben dem Übersetzungsteil, dem Debuggingteil auch einen Simulatorteil. Eine Übersicht über alle drei Programmteile gibt der Powerpoint-Vortrag [http://ece353.ecs.umass.edu/lab2/labc-lectureslides2012.pptx AVR Studio: The comprehensive tutorial] (MS PowerPoint &#039;&#039;2007&#039;&#039;) von Jeremy Gummeson und Brendan Kemp.&lt;br /&gt;
Wenn nur ein Breakpoint gesetzt ist, kann mit F5 das Programm einen Abarbeitungszyklus machen. Die Bearbeitung bleibt dann wieder beim Breakpoint stehen. Mit der Stoppuhr kann dann die Zeit für den abgearbeiteten Programmteil gemessen werden. Mit der rechten Mouse-Taste kann die Stoppuhr zurückgesetzt werden.&lt;br /&gt;
Ausführliche Anleitung zum Ablauf einer Simulation:  [http://www2.tech.purdue.edu/ecet/courses/ecet309/Reference_Materials/Simulation_AVR_Studio_4.pdf Tutorial der Purdue University] (engl., PDF) (link tot!)&lt;br /&gt;
Externe Signale können mit den Tools HAPSIM oder über eine Stimulidatei in den Simulator eingespeist werden. &lt;br /&gt;
Zu beachten ist, dass sich mit der Einführung des AVR Simulator 2, welcher  Vorteile wie Unterstützung von [[I2C|TWI]] bietet, das Datenformat für extern zugeführte Stimuli-Files geändert hat. Eine kleine Einführung inkl. Beispiel bietet die im AVR-Studio enthaltene Hilfe:&lt;br /&gt;
:AVR Studio Help → AVR Tools User Guide → Simulator → Simulator2 Stimuli&lt;br /&gt;
=== HAPSIM ===&lt;br /&gt;
[http://www.helmix.at/hapsim/index.htm HAPSIM] (Helmis AVR Periphery Simulator) ist ein Tool zur graphischen Simulation von Tasten, [[LED]], [[LCD]] und Terminalfunktionen in AVR Studio. (deutsch/engl., Windows, Freeware). Hinweise zur Installation von Hapsim nach einem AVR Studio Update stehen im [http://www.mikrocontroller.net/topic/118668 Forum]. HAPSIM kann nur mit AVRStudio 4.x verwendet werden, für den Fall, dass die Domain selbst nicht funktioniert kann folgender [http://members.aon.at/helmi/hapsim.htm Direktlink] verwendet werden.&lt;br /&gt;
=== Stimuli ===&lt;br /&gt;
Über eine sog. Stimuli-Datei lassen sich von ausserhalb Signale dem AVR Studio zuführen. Informationen zum Aufbau einer Stimulidatei finden sich in obigem &amp;quot;AVR Studio: The comprehensive tutorial&amp;quot; und bei Atmel ([http://support.atmel.com/bin/customer.exe?=&amp;amp;action=viewKbEntry&amp;amp;id=46 What is the format of the AVR Studio simulator stimuli files?]). Der [http://www.hot.ee/nppcsoftware/ Stimuli Generator for AVR Studio] ist eine Freeware für die Erzeugung von Stimulidateien und deren grafischen Darstellung. Für dieses Programm ist .NET 1.1 oder 2.0 erforderlich. Ein Python-Script zum Umwandeln der Stimuli-Log Datei in eine vcd-Datei, welche z.B. in gtkwave betrachtet werden kann, ist [https://github.com/althebaker43/avr_lcd/blob/8b177cc492d2e9a814bd21671c2267a6d3044811/atmel_studio/avr_lcd/stim2vcd.py hier] verfügbar.&lt;br /&gt;
=== LogAnalyser ===&lt;br /&gt;
[http://www.dresco.co.uk/LogAnalyser/ LogAnalyser] v1.00 (c) 2008 Jon Escombe is a graphical &amp;quot;logic analyser&amp;quot; style display of Atmel AVR Studio simulator log files. The project is built using the (excellent) zedGraph charting class library, and the source code is made available under GPL license. Requires Windows XP and .NET framework 2.0 to run.&lt;br /&gt;
=== TCPSimDBG ===&lt;br /&gt;
[http://www.avrfreaks.net/index.php?name=PNphpBB2&amp;amp;file=viewtopic&amp;amp;t=74350 TCPSimDBG] ist ein Plugin für [[AVR-Studio]] um Remote Simulating/Debugging über TCP/IP durchzuführen. Ein TCP/IP-Terminal oder Serverprogramm kann sich mit dem Simulator/Debugger von AVR-Studio verbinden und Informationen aus dem Debugprozess abrufen und ändern. Damit lassen sich virtuelle Geräte (Devices) eingerichten. (Atmel SDK Lizenz, Windows XP, 2003, Vista .NET 3.5 erforderlich)&lt;br /&gt;
=== AVR Logic Analyzer ===&lt;br /&gt;
[http://www.coynetechsystems.com/avrlogicanalyzer/index.php AVR Logic Analyzer] von Coyne Technology Systems ist ein AVR Studio Plugin zur grafischen Anzeige der simulierten I/O-Ports.&lt;br /&gt;
(kommerziell)&lt;br /&gt;
== Avrora ==&lt;br /&gt;
[http://avrora.sourceforge.net/ Avrora], a research project of the UCLA Compilers Group, is a set of simulation and analysis tools for programs written for the AVR microcontroller produced by Atmel and the Mica2 sensor nodes. Avrora contains a flexible framework for simulating and analyzing assembly programs, providing a clean Java API and infrastructure for experimentation, profiling, and analysis.&lt;br /&gt;
== Proteus VSM for Atmel AVR ==&lt;br /&gt;
[http://www.labcenter-electronics.com/products/avr.cfm Proteus VSM for Atmel AVR] ist ein kommerzieller AVR Simulator. &lt;br /&gt;
In der Codesammlung gibt es dafür ein [http://www.mikrocontroller.net/topic/118974#1072449 Virtuelles AVR Funk Pollin Simulationsmodell] von Daniel Cagara.&lt;br /&gt;
== CrossWorks for AVR == &lt;br /&gt;
[http://rowley.co.uk/avr/index.htm CrossWorks for AVR] besitzt einen &#039;&#039;core simulator&#039;&#039; für AVRs. (Windows, Mac OS X, Linux, Solaris)&lt;br /&gt;
== simavr ==&lt;br /&gt;
[https://github.com/buserror/simavr simavr] Das ist ein AVR simulator von Michel &amp;quot;buserror&amp;quot; Pollet für Linux, oder andere Platformen welche avr-gcc unterstützen. &lt;br /&gt;
In simavr schon implementiert:&lt;br /&gt;
    eeprom&lt;br /&gt;
    watchdog&lt;br /&gt;
    IO ports&lt;br /&gt;
    Timers, 8 &amp;amp;16&lt;br /&gt;
    The UART, including tx &amp;amp; rx interrupts&lt;br /&gt;
    SPI, master/slave including the interrupt&lt;br /&gt;
    i2c Master &amp;amp; Slave&lt;br /&gt;
    External Interrupts, INT0 and so on.&lt;br /&gt;
    ADC&lt;br /&gt;
    Self-programming&lt;br /&gt;
==== Benutzung GDB (unter ubuntu getestet)&amp;lt;br /&amp;gt; ====&lt;br /&gt;
Öffnen 2 Terminals in simavr Ordner. Dann laden simavr in erstem Terminal mit einem embedded software (z.B. atmega1280_i2ctest):&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;$ ./simavr/run_avr examples/board_i2ctest/atmega1280_i2ctest.axf -g&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Antwort:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;Loaded 2478 .text at address 0x0&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;Loaded 56 .data&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;avr_gdb_init listening on port 1234&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Im zweiten Terminal starten avr-gdb:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;$ avr-gdb -tui&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Jetzt müssen wir unsere software laden:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;(gdb) file examples/board_i2ctest/atmega1280_i2ctest.axf&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;Reading symbols from examples/board_i2ctest/atmega1280_i2ctest.axf...done.&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Danach eine Verbindung zwischen simavr und gdb aufbauen:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;(gdb) target remote localhost:1234&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;Remote debugging using localhost:1234&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;0x00000000 in __vectors ()&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Und wuala - wir sind schon bei Debugging:&amp;lt;br /&amp;gt;&lt;br /&gt;
1. Breakpoint setzen:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;(gdb) b 140&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;Breakpoint 1 at 0x234: file atmega1280_i2ctest.c, line 140.&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
2. Programm starten:&amp;lt;br /&amp;gt;&lt;br /&gt;
(&amp;lt;small&amp;gt;gdb) c&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
3. GDB haltet in der gewunschte Stelle&amp;lt;br /&amp;gt;&lt;br /&gt;
4. Zum nächsten Schrit gehen:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;(gdb) s&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
5. Oder zum Nachbohren:&amp;lt;br /&amp;gt;&lt;br /&gt;
&amp;lt;small&amp;gt;(gdb) n&amp;lt;br /&amp;gt;&amp;lt;/small&amp;gt;&lt;br /&gt;
Lizenz: GPL v3&amp;lt;br&amp;gt;&lt;br /&gt;
[http://www.avrfreaks.net/index.php?name=PNphpBB2&amp;amp;file=viewtopic&amp;amp;t=86665 Diskussion bei avrfreaks.net]&lt;br /&gt;
== AVRtest ==&lt;br /&gt;
AVRtest ist ein freier AVR Core-Simulator, der zur Ausführung der avr-gcc Testsuite verwendet wird. Über spezielle &amp;quot;Syscalls&amp;quot; können bestimmte Aktionen ausgelöst werden wie z.B. definierter Programmabbruch oder die Ausgabe eines Zeichens auf Console, so dass ein Programm wie&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;c&amp;quot;&amp;gt;#include &amp;lt;stdio.h&amp;gt;&lt;br /&gt;
int main (void)&lt;br /&gt;
    printf (&amp;quot;Hallo Welt!\n&amp;quot;);&lt;br /&gt;
analoge Resultate bringt wie ein Programm, das nativ auf dem Rechner ausgeführt wird.&lt;br /&gt;
AVRtest ist Open Source, einfach gehalten und auf Geschwindigkeit getrimmt. Die Eingabe von Stimuli ist nicht möglich, und interne Peripherie wird nicht unterstützt.&lt;br /&gt;
* Lizenz: GPL v2 oder höher&lt;br /&gt;
* Betriebssysteme: Windows, Linux, etc.&lt;br /&gt;
=== Weblinks ===&lt;br /&gt;
* [https://github.com/sprintersb/atest?tab=readme-ov-file#what-is-avrtest AVRtest: Projekt auf GitHib]&lt;br /&gt;
* [http://sourceforge.net/p/winavr/code/HEAD/tree/trunk/avrtest/ AVRtest: Projekt und README bei sourceforge (alt)]&lt;br /&gt;
* [http://lists.gnu.org/archive/html/avr-gcc-list/2011-06/msg00015.html Beschreibung in der avr-gcc-list Mailingliste (en)]&lt;br /&gt;
== BASCOM AVR ==&lt;br /&gt;
In [http://www.mcselec.com/ BASCOM AVR] ist ein Simulatorteil enthalten und damit ist auch die Simulation von Geräten (LCD, UART) möglich. BASCOM AVR wird von MCS Electronics verkauft (89€) und ist ein unter Windows laufender [[Basic|BASIC]] [[Compiler]] für Atmel AVR Mikrocontroller. Eine auf 4 KB Codegröße eingeschränkte Demoversion ist kostenlos erhältlich.&lt;br /&gt;
== AVR Simulator IDE ==&lt;br /&gt;
[http://oshonsoft.com/avr.html AVR Simulator IDE] from oshonsoft.com is a powerful application that supplies AVR developers with user-friendly graphical development environment for Windows with integrated simulator (emulator), Basic compiler, assembler, disassembler and debugger. (Kommerziell, Testversion verfügbar)&lt;br /&gt;
== MacSim - AVR simulator for OS X ==&lt;br /&gt;
[http://www.fracturedsoftware.com/macsimavr/ MacSim Alpha 4]&lt;br /&gt;
Einschränkungen u.A.:  &amp;quot;There are currently no timers, interrupts, or EEPROM. The processor is &#039;generic&#039; and has fixed size data and instruction memories.&amp;quot;&lt;/div&gt;</summary>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107053</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=107053"/>
		<updated>2024-08-07T17:58:45Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: &lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| 14.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106937</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106937"/>
		<updated>2024-06-17T17:37:42Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR86776 86776] || Need updating for CVE-2017-5753&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14.1&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106936</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106936"/>
		<updated>2024-06-17T17:36:54Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Bugs */&lt;/p&gt;
| rtl&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106935</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106935"/>
		<updated>2024-06-17T17:35:52Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Optimierung */&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114208 114208] || DSE deletes a store that&#039;s not dead&lt;br /&gt;
| rtl&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31704 31704] || Support &amp;lt;tt&amp;gt;avr-objdump -P avr-deviceinfo&amp;lt;/tt&amp;gt;&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of &amp;lt;tt&amp;gt;avr-objdump -P mem-usage&amp;lt;/tt&amp;gt; missing .rodata &lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR114243 114243] || -fsplit-wide-types bloats code by more than 50% &lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106932</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106932"/>
		<updated>2024-06-14T16:22:18Z</updated>
| rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106894</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106894"/>
		<updated>2024-05-23T09:17:54Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Binutils / avr-libc */&lt;/p&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR86776 86776] || Need updating for CVE-2017-5753&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106893</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106893"/>
		<updated>2024-05-23T09:17:20Z</updated>
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| v2.43&lt;br /&gt;
| v2.43&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106892</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106892"/>
		<updated>2024-05-23T09:14:25Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: &lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR31687 31687] || Output of avr-objdump -P mem-usage missing .rodata &lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| 14.2, 13.3, 12.4&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106863</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106863"/>
		<updated>2024-04-30T16:49:55Z</updated>
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR114100 114100] || Better indirect addressing on reduced Tiny&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR113927 113927] || [avr-tiny] Sets up a stack-frame even for trivial code&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106751</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106751"/>
		<updated>2024-04-12T11:52:17Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR86776 86776] || Need updating for CVE-2017-5753&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106690</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106690"/>
		<updated>2024-03-01T09:13:17Z</updated>
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| IPA&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106638</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106638"/>
		<updated>2024-02-15T13:53:20Z</updated>
&lt;div&gt;== Bugs ==&lt;br /&gt;
| IPA&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3&lt;br /&gt;
| 13.3, 12.4&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106635</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106635"/>
		<updated>2024-02-12T17:11:35Z</updated>
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106634</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106634"/>
		<updated>2024-02-12T16:43:26Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Erweiterungen */&lt;/p&gt;
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR86776 86776] || Need updating for CVE-2017-5753&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106620</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106620"/>
		<updated>2024-02-08T11:58:15Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| IPA&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.43&lt;br /&gt;
| 2.42&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in flash for AVR64* and AVR128* devices&lt;br /&gt;
| avr&lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || ATA5795 in wrong multilib set&lt;br /&gt;
| [http://gcc.gnu.org/PR113824 113824] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106601</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106601"/>
		<updated>2024-02-01T17:55:26Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Binutils / avr-libc */&lt;/p&gt;
&lt;div&gt;== Bugs ==&lt;br /&gt;
| IPA&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31321 31321] || Remove PROVIDE from definition of symbol __flmap_init_label&lt;br /&gt;
| 2.43&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| 2.42 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR31177 31177] || Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text&lt;br /&gt;
| 2.42&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28 rodata-in-flash&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| avr&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| 13.3, 12.4&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106588</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106588"/>
		<updated>2024-01-29T15:38:56Z</updated>
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| avr&lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR113156 113156] || avr build broken: ICE: &#039;global_options&#039; are modified in local context&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in Flash for Devices with FLMAP&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106567</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106567"/>
		<updated>2024-01-18T09:49:38Z</updated>
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR87376 87376] || Miscompilation with __memx and long long addition&lt;br /&gt;
| [http://gcc.gnu.org/PR86776 86776] || Need updating for CVE-2017-5753&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.42 optimization &lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29 &lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR84211 84211] || Perform a post-reload register optimization pass&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://gcc.gnu.org/PR82658 82658] || Right-shifting 8-bit unsigned integers.&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| avr&lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106557</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106557"/>
		<updated>2024-01-16T12:24:52Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Fixed */&lt;/p&gt;
{| {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t4&amp;quot; &lt;br /&gt;
!PR||Description||Note&lt;br /&gt;
| IPA&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29 &lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR112944 112944] || Support .rodata in flash for AVR64* and AVR128* devices&lt;br /&gt;
| avr&lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106556</id>
		<title>Avr-gcc Bugs</title>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106556"/>
		<updated>2024-01-16T08:23:01Z</updated>
&lt;div&gt;== Bugs ==&lt;br /&gt;
| IPA&lt;br /&gt;
| → [http://gcc.gnu.org/PR86635 86635]&lt;br /&gt;
| [http://gcc.gnu.org/PR86635 86635] || Wrong code with __memx and __gtsf2&lt;br /&gt;
| [http://gcc.gnu.org/PR81073 81073] || Link failure as C++ misses to instanciate some objects&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR80573 80573] || ICE: in assign_temp, at function.c:961&lt;br /&gt;
| [http://gcc.gnu.org/PR78707 78707] || ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)&lt;br /&gt;
| [http://gcc.gnu.org/PR78497 78497] || -save-temps adds -Wimplicit-fallthrough warnings&lt;br /&gt;
| [http://gcc.gnu.org/PR68384 68384] || LTO error for global register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR67352 67352] || incorrect warning with -Waddr-space-convert and struct in __flash&lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR65657 65657] || read from __memx tramples function argument&lt;br /&gt;
| [http://gcc.gnu.org/PR64331 64331] || avr.c:reg_unused_after uses outdated reg_dead notes&lt;br /&gt;
| [http://gcc.gnu.org/PR63630 63630] || ICE: Spill fail&lt;br /&gt;
| [http://gcc.gnu.org/PR62084 62084] || ICE: in convert_debug_memory_address (__memx, -g)&lt;br /&gt;
| middle-end → [http://gcc.gnu.org/PR52472 52472]&lt;br /&gt;
| [http://gcc.gnu.org/PR57597 57597] || ICE: in get_section, Segmentation fault with -fmerge-all-constants&lt;br /&gt;
| varasm&lt;br /&gt;
| [http://gcc.gnu.org/PR57482 57482] || --help=optimizers reports a wrong list &lt;br /&gt;
| [http://gcc.gnu.org/PR56479 56479] || ICE: can&#039;t allocate two 4-byte variables to &amp;quot;a&amp;quot; for inline asm&lt;br /&gt;
| [http://gcc.gnu.org/PR56442 56442] || postreload uses clobbered register&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/bugzilla/showdependencytree.cgi?id=56183 56183]&#039;&#039;&#039;&lt;br /&gt;
| &#039;&#039;Problems with register allocation&#039;&#039;&lt;br /&gt;
| meta-bug&lt;br /&gt;
| [http://gcc.gnu.org/PR56164 56164] || ICE: spill fail with __flash keyword&lt;br /&gt;
| [http://gcc.gnu.org/PR54330 54330] || Wrong optimization for code from fixed-bit.c&lt;br /&gt;
| [http://gcc.gnu.org/PR53615 53615] || Buffer overflow in the compiler?&lt;br /&gt;
| [http://gcc.gnu.org/PR52663 52663] || ICE: in purge_dead_edges, at cfgrtl.c:2462&lt;br /&gt;
| [http://gcc.gnu.org/PR52305 52305] || ICE: in avr_print_operand: unknown mode (const_double) &lt;br /&gt;
| asm&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50925 50925]&#039;&#039;&#039; || ICE: spill failure in newlib build&lt;br /&gt;
| [http://gcc.gnu.org/PR50739 50739] || nameless error with -fmerge-all-constants&lt;br /&gt;
| [http://gcc.gnu.org/PR49775 49775] || ICE: in based_loc_descr&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42204 42204]&#039;&#039;&#039; || update_eliminables should be called in reload after something changes &lt;br /&gt;
| [http://gcc.gnu.org/PR36571 36571] || Default untyped return for AVR is byte register. &lt;br /&gt;
== Binutils / avr-libc ==&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils&lt;br /&gt;
| [http://sourceware.org/PR16005 16005] || Linker crash with --relax&lt;br /&gt;
| [http://sourceware.org/PR13812 13812] || .trampolines location in linker script cause &amp;quot;internal error: out of range error&amp;quot;&lt;br /&gt;
| [http://sourceware.org/PR12494 12494] || Relaxation leads to wrong code optimization&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| binutils fixed&lt;br /&gt;
| [http://sourceware.org/PR31124 31124] || Support new Emulations for Devices with FLMAP&lt;br /&gt;
| [http://sourceware.org/PR21621 21621] || Wrong / missing warning &amp;quot;skipping two-word instruction&amp;quot;&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21849 21849] || Locate .progmemx.* at a higher address&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| [http://sourceware.org/PR21683 21683] || Support __gcc_isr pseudo-instruction&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21583 21583] || Move .jumptables to a higher address&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21569 21569] || Merge avr.sc and avrtiny.sc&lt;br /&gt;
| 2.29&lt;br /&gt;
| [http://sourceware.org/PR21472 21472] || Add new emulation for ATtiny416 et al. (don&#039;t put .rodata in RAM)&lt;br /&gt;
| 2.29 &lt;br /&gt;
| [http://sourceware.org/PR21404 21404] || Assertion fail in bfd/elf32-avr.c:2145&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20849 20849] || Don&#039;t put .rodata in RAM on AVR_TINY.&lt;br /&gt;
| 2.28&lt;br /&gt;
| [http://sourceware.org/PR20789 20789] || Fix relaxation of negative DIFF relocs.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20254 20254] || Relocs at end of section are not processed with .align.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR20221 20221] || Wrong code with .align and linker relaxation.&lt;br /&gt;
| 2.26&lt;br /&gt;
| [http://sourceware.org/PR15043 15043] || Support -mrmw option for LAC, LAT, LAS and XCH.&lt;br /&gt;
| 2.25&lt;br /&gt;
| [http://sourceware.org/PR14058 14058] || Internal overflow error on &amp;gt; 128kB flash&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13899 13899]&#039;&#039;&#039; || Wrong relaxation of R_AVR_16_PM with gs()&lt;br /&gt;
| 2.23&lt;br /&gt;
| &#039;&#039;&#039;[http://sourceware.org/PR13697 13697]&#039;&#039;&#039; || Wrong symbol values with --gc-sections and empty .data&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13503 13503] || Support RELOCs to represent a byte&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR13410 13410] || Relocation truncated to fit: R_AVR_13_PCREL against symbol...&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12742 12742] || mingw32 and --enable-lto in Canadian cross build&lt;br /&gt;
| 2.23&lt;br /&gt;
| [http://sourceware.org/PR12161 12161] || Unconforming ELF file causes SIGSEGV in avr-ld&lt;br /&gt;
| 2.23, 2.22.x&lt;br /&gt;
!colspan=&amp;quot;3&amp;quot;| avr-libc&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57114 57114] || Do not #define abs / labs&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 &amp;amp;rarr;57071]&lt;br /&gt;
| [https://savannah.nongnu.org/bugs/?57071 57071] || Fix math.h and function names that block 64-bit double&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?49567 49567] || Use meta-info from --print-multi-lib and --print-multi-directory&lt;br /&gt;
| 2.2&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9416 P-9416] || [patch,AVR_TINY] Avoid constraint &amp;quot;w&amp;quot; in delay_basic.h&lt;br /&gt;
| Patch&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9400 P-9400] || [patch] Add avrxmega3 multilibs&lt;br /&gt;
| &amp;amp;radic;&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?9187 P-9187] || [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.&lt;br /&gt;
| [http://savannah.nongnu.org/patch/?8729 P-8729] || [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38135 38135] || Install stdfix-avrlibc.h&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?38125 38125] || Distribute gcrt1.S&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36571 36571] || stdint.h: INTn_C not standard compliant&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?36454 36454] || string.h: Error for long long in C90&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| &#039;&#039;&#039;[http://savannah.nongnu.org/bugs/?35407 35407]&#039;&#039;&#039; || Missing multilib versions for tiny-stack targets&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?34695 34695] || stdint.h fixed-width int types without __attribute__((mode))&lt;br /&gt;
| [http://savannah.nongnu.org/bugs/?33698 33698] || RJMP/RCALL can cause &amp;quot;relocation truncated to fit: R_AVR_13_PCREL&amp;quot; linker error&lt;br /&gt;
|  &amp;amp;radic; ?&lt;br /&gt;
== Optimierung ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t2&amp;quot;&lt;br /&gt;
! PR || Optimization || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR110093 110093] || Move frenzy leading to code bloat.&lt;br /&gt;
| Regression&lt;br /&gt;
| [http://gcc.gnu.org/PR109910 109910] || Prologue/epilogue saves/restores regs that are never changed.&lt;br /&gt;
| [http://gcc.gnu.org/PR88209 88209] || Inefficient array initialization&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| [http://gcc.gnu.org/PR81625 81625] || v4.7 ... v8 is bloating code by &amp;gt; 25% compared to v3.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81611 81611] || gcc un-learned loop / post-increment optimization &lt;br /&gt;
| [http://gcc.gnu.org/PR81540 81540] || tree-switch-conversion leads to code bloat&lt;br /&gt;
| tree-ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR81533 81533] || Constructing an object that can be initialized at at load-time &lt;br /&gt;
| c++&lt;br /&gt;
| [http://gcc.gnu.org/PR80929 80929] || Division with constant no more optimized to mult&lt;br /&gt;
| [http://gcc.gnu.org/PR65082 65082] || Wasted cycles when using a register based varible&lt;br /&gt;
| [http://gcc.gnu.org/PR56439 56439] || unnecessary spill for global and local register variables&lt;br /&gt;
| [http://gcc.gnu.org/PR55181 55181] || Expensive shift loop instead of bit-testing instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR54378 54378] || Code bloat for long &amp;lt;&amp;lt; shifts&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53049 53049]&#039;&#039;&#039; || expand/TER unappropriate moving unspec volatile&lt;br /&gt;
| [http://gcc.gnu.org/PR52664 52664] || gcc.dg/tree-ssa/pr31261.c fails&lt;br /&gt;
| ssa&lt;br /&gt;
| [http://gcc.gnu.org/PR52278 52278] || inefficient register allocation for SUBREGs&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR49807 49807] || Missed byte (subreg) extraction when storing to volatile mem&lt;br /&gt;
| [http://gcc.gnu.org/PR49491 49491] || Superfluous move because of unnecessary spill for 2-operand insn&lt;br /&gt;
| RA&lt;br /&gt;
| [http://gcc.gnu.org/PR39760 39760] || register allocation costs are not well described on AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR38629 38629] || target-specific parameters for inline heuristics not defined for AVR &lt;br /&gt;
| [http://gcc.gnu.org/PR36884 36884] || ifcvt poor optimization &lt;br /&gt;
| RTL-optimize, -fno-if-conversion&lt;br /&gt;
| [http://gcc.gnu.org/PR36561 36561] || store using long array index not hoisted out of loop &lt;br /&gt;
| [http://gcc.gnu.org/PR30908 30908] || tree cost for types which are &amp;gt; WORD_SIZE &lt;br /&gt;
| [http://gcc.gnu.org/PR27663 27663] || missed-optimization transforming a byte array to unsigned long&lt;br /&gt;
| patch upstream&lt;br /&gt;
| [http://gcc.gnu.org/PR18065 18065] || usual arithmetic conversion not applying correctly&lt;br /&gt;
| [http://gcc.gnu.org/PR11180 11180] || Optimization decrease performance of struct assignment. &lt;br /&gt;
|  &lt;br /&gt;
| [http://gcc.gnu.org/PR3507 3507] || appalling optimisation with sub/cmp on multiple targets&lt;br /&gt;
== Debug-Info, Build, ... ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t3&amp;quot;&lt;br /&gt;
!PR||Debug-Info, Build, Ada, Fortran||Note&lt;br /&gt;
| [http://gcc.gnu.org/pr52641 52641] || Test cases fail for 16-bit int targets&lt;br /&gt;
| testsuite&lt;br /&gt;
== Erweiterungen ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t5&amp;quot;&lt;br /&gt;
! PR || Extensions || Note&lt;br /&gt;
| avr&lt;br /&gt;
| [http://gcc.gnu.org/PR84163 84163] || Allow address space qualifier for compound literals&lt;br /&gt;
| C&lt;br /&gt;
| [http://gcc.gnu.org/PR57390 57390] || Support fixed-point types in C++&lt;br /&gt;
| C++&lt;br /&gt;
== Ungültig ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot;&lt;br /&gt;
! PR || Invalid || Note&lt;br /&gt;
| [http://gcc.gnu.org/PR61044 61044] || Computed goto with label differences does not work&lt;br /&gt;
| → Label differences not suported on AVR:&amp;lt;br/&amp;gt;[http://gcc.gnu.org/onlinedocs/gcc/Labels-as-Values.html Labels as Values]&lt;br /&gt;
| [http://gcc.gnu.org/PR57501 57501] || crttn24a.o missing path with -mmcu=attiny24a&lt;br /&gt;
| → Caused by [http://savannah.nongnu.org/bugs/?35407 AVR-LibC #35407]&lt;br /&gt;
| [http://gcc.gnu.org/PR52474 52474] || mulhisi3: arithmetics produce completely wrong result&lt;br /&gt;
| → Caused by patch from Atmel&lt;br /&gt;
| [http://gcc.gnu.org/PR38549 38549] || eicall not properly set for &amp;gt; 128K program space &lt;br /&gt;
| → [http://gcc.gnu.org/PR50820 50820]&lt;br /&gt;
|colspan=&amp;quot;3&amp;quot; align=&amp;quot;center&amp;quot;|&amp;amp;nbsp;&lt;br /&gt;
! PR || Won&#039;t fix || Note&lt;br /&gt;
| [http://sourceware.org/PR14406 14406] || Support .progmem&amp;lt;N&amp;gt;.data sections in the default ld script&lt;br /&gt;
| → [https://sourceware.org/bugzilla/show_bug.cgi?id=14406#c2 Begründung + Beispiel für ld-Skript Erweiterung]&lt;br /&gt;
| [http://gcc.gnu.org/PR56254 56254] || Support __builtin_avr_delay_cycles with non-const delays&lt;br /&gt;
| [http://gcc.gnu.org/PR49857 49857] || Put constant switch-tables into flash&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR43745 43745] || Put VTABLES in Flash&lt;br /&gt;
| [http://gcc.gnu.org/PR38342 38342] || __attribute__((progmem)) not propagated from typedef to data&lt;br /&gt;
| → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716] &lt;br /&gt;
== Fixed ==&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t7&amp;quot;&lt;br /&gt;
! PR || Fixed || Note&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 14&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR112952 112952] || Fix attributes &amp;lt;code&amp;gt;address&amp;lt;/code&amp;gt;,  &amp;lt;code&amp;gt;io&amp;lt;/code&amp;gt; and &amp;lt;code&amp;gt;io_low&amp;lt;/code&amp;gt;&lt;br /&gt;
| 13.3, 12.4&lt;br /&gt;
| 12.3&lt;br /&gt;
| 11.0&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| 8.0&lt;br /&gt;
| 8.0&lt;br /&gt;
| 7.4&lt;br /&gt;
| 7.2&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 7.0&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.2&lt;br /&gt;
| 6.0&lt;br /&gt;
| 5.0&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| 4.7.1&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.3&lt;br /&gt;
| 4.5.0&lt;br /&gt;
		<id>https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106555</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=Avr-gcc_Bugs&amp;diff=106555"/>
		<updated>2024-01-16T08:21:06Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: &lt;/p&gt;
| [http://gcc.gnu.org/PR92606 92606] || Invalid merge of symbols in progmem and data sections (WA: &amp;lt;tt&amp;gt;-fno-ipa-icf-variables&amp;lt;/tt&amp;gt;)&lt;br /&gt;
| IPA&lt;br /&gt;
| [http://gcc.gnu.org/PR86869 86869] || ICE when taking address of array member of __memx struct pointer&lt;br /&gt;
| C++&lt;br /&gt;
|  &lt;br /&gt;
| varasm&lt;br /&gt;
| asm&lt;br /&gt;
| dwarf-2&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29.x&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29&lt;br /&gt;
| 2.29 &lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.28&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.26&lt;br /&gt;
| 2.25&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.23&lt;br /&gt;
| 2.2&lt;br /&gt;
| 2.2&lt;br /&gt;
| Patch&lt;br /&gt;
| 1.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR109907 109907] || Code bloat for single bit extractions&lt;br /&gt;
| Patch&lt;br /&gt;
| C++&lt;br /&gt;
| c++&lt;br /&gt;
| ssa&lt;br /&gt;
| RA&lt;br /&gt;
| RA&lt;br /&gt;
|  &lt;br /&gt;
| avr&lt;br /&gt;
| C&lt;br /&gt;
| C++&lt;br /&gt;
| (patch)&lt;br /&gt;
| [http://gcc.gnu.org/PR112830 112830] || ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR105523 105523] || Avoid diagnostic &amp;lt;i&amp;gt;&amp;quot;array subscript 0 is outside array bounds of &#039;volatile uint8_t[0] [-Warray-bounds]&amp;quot;&amp;lt;/i&amp;gt;&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR101188 101188] || Uses content of a clobbered register&lt;br /&gt;
| 14&lt;br /&gt;
| [http://gcc.gnu.org/PR53372 53372] || Section attribute ignored with address space&lt;br /&gt;
| 13.3&lt;br /&gt;
| [http://gcc.gnu.org/PR107201 107201] || &amp;lt;tt&amp;gt;-nodevicelib&amp;lt;/tt&amp;gt; not working together with &amp;lt;tt&amp;gt;-mmcu=avr*&amp;lt;/tt&amp;gt; devices &lt;br /&gt;
| 13.2, 12.4&lt;br /&gt;
| [http://gcc.gnu.org/PR109650 109650] || Wrong code with -Os (cc0 → CCmode fallout)&lt;br /&gt;
| [http://gcc.gnu.org/PR105753 105753] || ICE: in add_clobbers, at config/avr/avr-dimode.md:2705&lt;br /&gt;
| [http://gcc.gnu.org/PR99184 99184] || Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc.&lt;br /&gt;
| 12.3, 11.4, 10.5&lt;br /&gt;
| [http://gcc.gnu.org/PR90706 90706] || Useless code generated for stack / register operations&lt;br /&gt;
| 12.3&lt;br /&gt;
| [http://gcc.gnu.org/PR92729 92729] || Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+&lt;br /&gt;
| 11.0&lt;br /&gt;
| [http://gcc.gnu.org/PR92055 92055] || Support 64-bit double&lt;br /&gt;
| [http://gcc.gnu.org/gcc-10/changes.html#avr 10.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR86040 86040] || RAMPZ not cleared after reading from __flashN&lt;br /&gt;
| 9.3, 8.4, 7.5&lt;br /&gt;
| [http://gcc.gnu.org/PR85805 85805] || Wrong code for 64 bit comparisons on avr-gcc&lt;br /&gt;
| 8.3 combine&lt;br /&gt;
| [http://gcc.gnu.org/PR85495 85495] || lto-wrapper.exe: fatal error: file too short: No error&lt;br /&gt;
| 8.0 LTO&lt;br /&gt;
| [http://gcc.gnu.org/PR83801 83801] || String constant in __flash not put into .progmem&lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83729 83729] || ICE in convert_memory_address_addr_space_1 at explow.c:300 &lt;br /&gt;
| 8.0 C&lt;br /&gt;
| [http://gcc.gnu.org/PR83738 83738] || Don&#039;t save registers in main / auto-add OS_task to main&lt;br /&gt;
| [http://gcc.gnu.org/gcc-8/changes.html#avr 8.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR81754 81754] || Building of avr compiler broken&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR20296 20296]&amp;lt;br/&amp;gt;[http://gcc.gnu.org/PR81268 81268]&lt;br /&gt;
| Speeding up small ISRs&amp;lt;br/&amp;gt;Support __gcc_isr pseudo-instruction&lt;br /&gt;
| [http://gcc.gnu.org/PR81075 81075] || Move jump-tables out of .text&lt;br /&gt;
| 8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR81072 81072] || Add XMEGA devices with flash seen in RAM address space&lt;br /&gt;
| [http://gcc.gnu.org/PR84209 84209] || Don&#039;t split SP in split2&lt;br /&gt;
| 7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR81910 81910] || ICE with &amp;quot;address&amp;quot; attribute on type&lt;br /&gt;
| 7.3, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81487 81487] || ld.exe: error: asprintf failed&lt;br /&gt;
| 7.2, 6.5, 5.5 mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR81473 81473] || Build fails due to INT8_MIN and friends&lt;br /&gt;
| 7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR81407 81407] || C++: Error if a variable in progmem needs constructing&lt;br /&gt;
| 7.2, 6.5, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR81305 81305] || avrtiny uses LDS for SREG with -O0&lt;br /&gt;
| [http://gcc.gnu.org/PR80492 80492] || Wrong code whith loop unrolling and local asm regs&lt;br /&gt;
| 7.2, 6.4 tree&lt;br /&gt;
| [http://gcc.gnu.org/PR79883 79883] || i18n: untranslated &amp;quot;interrupt&amp;quot; or &amp;quot;signal&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR75964 75964] || Insn-combiner removes comparison after ABS&lt;br /&gt;
| 7.2, 6.5, 5.5 rtl&lt;br /&gt;
| [http://gcc.gnu.org/PR78883 78883] || ICE triggered by change to combine.c&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78562 78562] || Wrong warning for built-in functions with -flto&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR78093 78093] || New variable attribute &amp;quot;absdata&amp;quot; to enable LDS / STS on Reduced Tiny&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71948 71948] || Make [http://gcc.gnu.org/onlinedocs/gcc/AVR-Variable-Attributes.html progmem] work on reduced Tiny by adding 0x4000 to symbols&lt;br /&gt;
| [http://gcc.gnu.org/gcc-7/changes.html#avr 7.0]&lt;br /&gt;
| [http://gcc.gnu.org/PR71678 71678] || ICE from switch / case on long long (casesi + DImode)&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR71676 71676] || casesi won&#039;t handle switch values larger than 16 bits&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60300 60300] || Minor prologue improvement w.r.t code size&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR41076 41076] || Pessimal code for logical OR of 8-bit fields&lt;br /&gt;
| 7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR67353 67353] || Option-ize Warning &amp;quot;appears to be a misspelled signal / interrupt handler&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR80462 80462] || Incorrect warning: uninitialized variable &#039;xxx&#039; put into program memory area&lt;br /&gt;
| 6.4, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR77326 77326] || Invalid optimization omits comparison&lt;br /&gt;
| 6.3, 5.5&lt;br /&gt;
| [http://gcc.gnu.org/PR72767 72767] || Some branches report too small insn length&lt;br /&gt;
| 6.2, 5.5 &lt;br /&gt;
| [http://gcc.gnu.org/PR71976 71976] || insn-combine removes 64-bit shift&lt;br /&gt;
| [http://gcc.gnu.org/PR71151 71151] || Strings in .progmem.gcc_sw_section with -fdata-sections + const merging&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR71103 71103] || ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref&lt;br /&gt;
| 6.2, 5.5, 4.9.4&lt;br /&gt;
| [http://gcc.gnu.org/PR71053 71053] || volatile read-and-test loop optimized to test loop (without read)&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR70677 70677] || Disable &amp;lt;tt&amp;gt;-fcaller-saves&amp;lt;/tt&amp;gt; per default&lt;br /&gt;
| 6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR30417 30417] || Wrap spec generating -Tdata into %{!Tdata:...}&lt;br /&gt;
| [http://gcc.gnu.org/PR67839 67839] || Bit addressable instructions generated for invalid memory address&lt;br /&gt;
| 6.0&lt;br /&gt;
| [http://gcc.gnu.org/PR65296 65296] || fix various issues with avr specs files&lt;br /&gt;
| 5.2 → [http://savannah.nongnu.org/bugs/?44574 avr-libc #44574]&lt;br /&gt;
| [http://gcc.gnu.org/PR65192 65192] || ICE: attiny: In tiny_valid_direct_memory_access_range&lt;br /&gt;
| 5.0 (transient)&lt;br /&gt;
| [http://gcc.gnu.org/PR52472 52472] || ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g)&lt;br /&gt;
| 5.0&lt;br /&gt;
=== Älter als v5 ===&lt;br /&gt;
{|  {{Tabelle}} border=&amp;quot;1&amp;quot; class=&amp;quot;sortable&amp;quot; id=&amp;quot;t8&amp;quot;&lt;br /&gt;
| [http://gcc.gnu.org/PR65196 65196] || ICE: avr_adjust_insn_length uses recog_memoized on invalid insn&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR64452 64452] || ICE: When passing struct member to varargs function&lt;br /&gt;
| 4.9.3, 4.8.5&lt;br /&gt;
| [http://gcc.gnu.org/PR63633 63633] || ICE: unrecognizable insn with mult insns&lt;br /&gt;
| 4.9.3&lt;br /&gt;
| [http://gcc.gnu.org/PR63223 63223] || Make jumptables work with -Wl,--section-start,.text=&lt;br /&gt;
| 4.9.2&lt;br /&gt;
| [http://gcc.gnu.org/PR61443 61443] || ICE: unrecognizable insn when varargs argument is indirect addr-space access&lt;br /&gt;
| 4.9.1, 4.8.4&lt;br /&gt;
| [http://gcc.gnu.org/PR61055 61055] || Wrong test instruction after increment (-O1 or -fno-peephole2)&lt;br /&gt;
| 4.9.1, 4.8.3, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR60991 60991] || Stack corruption when using __memx pointers or __int24 in large stack frame&lt;br /&gt;
| [http://gcc.gnu.org/PR56833 56833] || Postreload uses clobbered register&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50807 50807] || Constructor writing to RAM for variable in Flash&lt;br /&gt;
| 4.9.0&lt;br /&gt;
| [http://gcc.gnu.org/PR60486 60486] || Superfluous or missing comparision after addition or subtraction&lt;br /&gt;
| 4.8.3&lt;br /&gt;
| [http://gcc.gnu.org/PR59396 59396] || Wrong warning with ISR() and LTO&lt;br /&gt;
| 4.8.3, 4.8.1&lt;br /&gt;
| [http://gcc.gnu.org/PR57844 57844] || ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes&lt;br /&gt;
| 4.8.2, 4.7.4&lt;br /&gt;
| [http://gcc.gnu.org/PR57631 57631] || Use assembler name for sanity checking of ISR names&lt;br /&gt;
| [http://gcc.gnu.org/PR57516 57516] || Incorrect fixed-point rounding result in the overflow case&lt;br /&gt;
| 4.8.2&lt;br /&gt;
| [http://gcc.gnu.org/PR57506 57506] || Some devices are present twice in avr-mcus.def&lt;br /&gt;
| [http://gcc.gnu.org/PR56263 56263] || Provide strict address-space checking&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR56064 56064] || Fold VIEW_CONVERT_EXPR with FIXED_CST&lt;br /&gt;
| 4.8.0 tree-ssa &lt;br /&gt;
| [http://gcc.gnu.org/PR54814 54814] || ICE: Hundreds of spill fails in test suite for class R0_REG&lt;br /&gt;
| 4.8.0.&lt;br /&gt;
| [http://gcc.gnu.org/PR54854 54854] || Remove &amp;lt;tt&amp;gt;-mshort-calls&amp;lt;/tt&amp;gt; option&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54815 54815] || missed optimization with operations with constant operands&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR54222 54222] || ISO/IEC TR 18037 fixed-point support&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR53344 53344] || Assemble 3-byte symbols&lt;br /&gt;
| 4.8.0&lt;br /&gt;
| [http://gcc.gnu.org/PR55974 55974] || Wrong suffix for __INT24_MAX__, __UINT24_MAX__ with -mint8&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55897 55897] || Allocate __memx data to .progmemx.data&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR55243 55243] || [ada] STAMP variable is not defined in t-avr&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR50293 50293] || -flto fails if GCC is installed in directory with space in path name&lt;br /&gt;
| 4.7.3&lt;br /&gt;
| [http://gcc.gnu.org/PR54536 54536] || Incorrect library_name for at90usb1287&lt;br /&gt;
| 4.7.2, 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR54476 54476] || Time/memory hog with __builtin_avr_delay_cycles (-1ul) on 64-bit hosts&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR54461 54461]&#039;&#039;&#039; || Add configure option for better AVR-Libc integration&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR54220 54220] || Naked functions need frame at -O0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53595 53595]&#039;&#039;&#039; || Code size increase of +10% between two 4.7.1 snapshots&lt;br /&gt;
| 4.7.2&lt;br /&gt;
| [http://gcc.gnu.org/PR53448 53448] || __attribute__((aligned(2))) ignored&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53256 53256]&#039;&#039;&#039; || Attribute &#039;interrupt&#039; shall override attribute &#039;signal&#039;&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR53065 53065] || ICE: in replace_reg_with_saved_mem, at caller-save.c:1125&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR53033 53033]&#039;&#039;&#039; || Wrong register number for 3-byte loads via X&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52737 52737]&#039;&#039;&#039; || -mtiny-stack shall not influence multilib selection&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52692 52692] || Add support for avr-specific built-ins + LTO&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52545 52545] || SECTION_EXCLUDE flag clobbers SECTION_MACH_DEP&lt;br /&gt;
| 4.7.1 other&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR52543 52543]&#039;&#039;&#039; || lower-subreg.c: code bloat of 300%-400% for multi-word memory splits&lt;br /&gt;
| &#039;&#039;&#039;HACK&#039;&#039;&#039; 4.7.1 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR52508 52508] || HAVE_RAMPZ as condition to set RAMPZ prior to flash-read is no more appropriate&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52507 52507] || movmem loop for __memx address space uses wrong loop label&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52506 52506] || XMEGA: Wrong order of save/restore of RAMPX/Y/Z/D SFRs in ISR pro-/epilogue&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52505 52505] || __memx address space reading unintentionally from RAM&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52496 52496] || avr-specific built-ins missing memory barrier&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52488 52488] || ICE: unreconizable addqi -2000 insn&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| [http://gcc.gnu.org/PR52484 52484] || Missing __memx insn because of wrong register footprint&lt;br /&gt;
| 4.7.1 &lt;br /&gt;
| [http://gcc.gnu.org/PR52461 52461] || XMEGA+EBI: RAMPZ clobbered&lt;br /&gt;
| 4.7.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51527 51527]&#039;&#039;&#039; || ICE: &#039;convert_to_integer&#039; enters infinite recursion for __int24&lt;br /&gt;
| 4.7.1 c&lt;br /&gt;
| [http://gcc.gnu.org/PR46261 46261] || ICE: when compiled with -mint8 &lt;br /&gt;
| 4.7.1, 4.6.4, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR52261 52261] || Add XMEGA support&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52148 52148] ||ICE: spill_failure for movmemhi&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51782 51782]&#039;&#039;&#039; || Missing address-space information leads to wrong code&lt;br /&gt;
| 4.7.0 middle-end&lt;br /&gt;
| [http://gcc.gnu.org/PR51425 51425] || no SBIS/SBIC instructions&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51409 51409]&#039;&#039;&#039; || Building avr-gcc fails if configured for other languages than from C family&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51345 51345] || Devices with 8-bit SP need their own multilib(s)&lt;br /&gt;
| 4.7.0 ABI&lt;br /&gt;
| [http://gcc.gnu.org/PR51050 51050] || ICE: invalid rtl sharing found in the insn (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR51002 51002] || SP_H register is used even on targets that do not have it (ATtiny26)&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50931 50931] || Support a 24-bit scalar integer mode&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50910 50910] || Inefficient division by 2&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50887 50887] || Support ACCUMULATE_OUTGOING_ARGS &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50775 50775]&#039;&#039;&#039; || Register allocator sets up frame and frame pointer with low register pressure&lt;br /&gt;
| 4.7.0, ra&lt;br /&gt;
| [http://gcc.gnu.org/PR50616 50616] || ICE: lto1.exe: invalid resolution in the resolution file&lt;br /&gt;
| 4.7.0, lto, mingw32&lt;br /&gt;
| [http://gcc.gnu.org/PR50566 50566] || Add support for better logging by means of -mlog=&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50465 50465] || Use insn attribute to depict if and how instruction lengths have to be adjusted&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50449 50449] || Loading some 32-bit constants not optimal&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50448 50448] || Missed optimization accessing struct component with integer address&lt;br /&gt;
| [http://gcc.gnu.org/PR50447 50447] || Better support of AND, OR, XOR and PLUS with constant integers&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50446 50446] || Implement rotate patterns with offset 1&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR50358 50358] || Implement [u]maddqihi4 [u]msubqihi4 patterns&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50063 50063]&#039;&#039;&#039; || wrong code for gcc.dg/torture/pta-ptrarith-3.c&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49939 49939] || Skip 2-word instructions if applicable&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49903 49903] || Redundant comparisons in binary-seach switch/case expansion&lt;br /&gt;
| 4.7.0 FIXME&lt;br /&gt;
| [http://gcc.gnu.org/PR49881 49881] || Inefficient stack manipulation around calls&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR49868 49868]&#039;&#039;&#039; || Implement named address space to place/access data in flash memory&lt;br /&gt;
| 4.7.0 ← [http://sourceware.org/PR13503 binutils PR13503]&lt;br /&gt;
| [http://gcc.gnu.org/PR49864 49864] || ICE: in maybe_record_trace_start, at dwarf2cfi.c:2439&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR49687 49687] || Missed optimization for widening MUL&lt;br /&gt;
| [http://gcc.gnu.org/PR49313 49313] || Inefficient libgcc implementations for avr&lt;br /&gt;
| [http://gcc.gnu.org/PR47597 47597] || ICE: call frame debugging information is not handled when case is post_dec &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46278 46278]&#039;&#039;&#039; || avr-gcc 4.5.1 doing suboptimal reloads using X &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR45099 45099] || Warning could be issued for use of register variables that will fail.&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR43746 43746] || -fmerge-constants and -fmerge-all-constants don&#039;t work at AVR target &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR42210 42210] || optimizing assignment to a bit field&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR39621 39621] || Delaying operation to end of function causes high stack usage&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR36467 36467] || Missed optimization with pointer arithmetic and mul* &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR35860 35860] || [4.3/4.4/4.5/4.6 Regression] [avr] code bloat caused by -fsplit-wide-types &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34888 34888] || Stack patterns not optimal &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34792 34792] || c++ worse than c compiler at 8-bit optimisations &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34791 34791] || optimisation of 8-bit logic sometimes fails &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34790 34790] || no sibling call optimisation&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR34789 34789] || sometimes the compiler keeps addresses in registers unnecessarily &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR33049 33049] || bit extraction non optimal, inversing logic solves problem&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29560 29560] || Poor optimization for byte shifts &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR29524 29524] || [4.3/4.4/4.5/4.6 Regression] Too much RAM used: __clz_tab[] linked&lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR18145 18145] || Do not emit __do_copy_data or __do_clear_bss if .data or .bss is empty. &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR17994 17994] || avr-gcc does not output a dwarf2 .debug_frame section &lt;br /&gt;
| 4.7.0&lt;br /&gt;
| [http://gcc.gnu.org/PR52741 52741] || -mtiny-stack must not make assumptions on upper 8 bits of SP/FP&lt;br /&gt;
| 4.6.4&lt;br /&gt;
| [http://gcc.gnu.org/PR51756 51756] || Wrong warning: uninitialized variable put into program memory area&lt;br /&gt;
| 4.6.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR51374 51374]&#039;&#039;&#039; || insn combine reorders volatile memory accesses&lt;br /&gt;
| 4.6.3 middle-end&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50820 50820]&#039;&#039;&#039; || Use EIND consistently&lt;br /&gt;
| 4.6.2, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR50816 50816] || Discriminators are emitted in DWARF 2 format &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR50652 50652]&#039;&#039;&#039; || Incorrect data start value for ATmega164A&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR50289 50289] || call-prologues saving/restoring global register variables&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49824 49824] || Missing documentation for OS_task and OS_main attributes &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49764 49764] || [avr-g++] Rejects attribute progmem&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR49487 49487] || ICE: bytewise rotate&lt;br /&gt;
| 4.6.2&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR46779 46779]&#039;&#039;&#039; || wrong code generation for values held in R28/R29 &lt;br /&gt;
| [http://gcc.gnu.org/PR34734 34734] || attribute((progmem)) not handled properly in C++ for AVRs&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?33716 avr-libc #33716]&lt;br /&gt;
| [http://gcc.gnu.org/PR44643 44643] || ICE: in c-typeck.c&lt;br /&gt;
| 4.6.2 → [http://savannah.nongnu.org/bugs/?32988 avr-libc #32988]&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR39633 39633]&#039;&#039;&#039; || missing 8-bit comparison (*cmpqi)&lt;br /&gt;
| [http://gcc.gnu.org/PR39386 39386] || different computation results for O1 and O0 executables &lt;br /&gt;
| 4.6.2&lt;br /&gt;
| [http://gcc.gnu.org/PR48459 48459] || [4.6/4.7 Regression] avr: Assertion failure with -gdwarf-2&lt;br /&gt;
| 4.6.1&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR45263 45263]&#039;&#039;&#039; || registers used in __do_global_ctors can get clobbered &lt;br /&gt;
| 4.6.1, 4.5.4&lt;br /&gt;
| [http://gcc.gnu.org/PR45261 45261] || Doesn&#039;t indicate failure status when it doesn&#039;t support (attiny2313A) &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR42240 42240]&#039;&#039;&#039; || [4.3/4.4 Regression] wrong epilogue on naked function &lt;br /&gt;
| 4.5.3&lt;br /&gt;
| &#039;&#039;&#039;[http://gcc.gnu.org/PR41885 41885]&#039;&#039;&#039; || Rotate patterns do not correctly consider overlap. &lt;br /&gt;
| 4.5.0&lt;br /&gt;
* [https://gcc.gnu.org/bugzilla/buglist.cgi?bug_status=UNCONFIRMED&amp;amp;bug_status=NEW&amp;amp;bug_status=ASSIGNED&amp;amp;bug_status=WAITING&amp;amp;bug_status=REOPENED&amp;amp;cf_gcctarget=avr&amp;amp;cf_gcctarget_type=allwordssubstr&amp;amp;cf_known_to_fail_type=allwords&amp;amp;cf_known_to_work_type=allwords&amp;amp;product=gcc&amp;amp;query_format=advanced&amp;amp;order=changeddate%2Cbug_status%2Cpriority%2Cassigned_to%2Cbug_id&amp;amp;query_based_on= gcc.gnu.org/bugzilla: avr]&lt;br /&gt;
* [http://savannah.nongnu.org/bugs/?group=avr-libc avr-libc: Fehler]&lt;br /&gt;
[[Kategorie: avr-gcc]]&lt;/div&gt;</summary>
		<author><name>Gjlayde</name></author>
		<id>https://www.mikrocontroller.net/index.php?title=AVR-GCC-Tutorial&amp;diff=106550</id>
		<link rel="alternate" type="text/html" href="https://www.mikrocontroller.net/index.php?title=AVR-GCC-Tutorial&amp;diff=106550"/>
		<updated>2024-01-11T08:57:35Z</updated>
		<summary type="html">&lt;p&gt;Gjlayde: /* Flash mit __flash und Embedded-C */&lt;/p&gt;
&lt;div&gt;Dieses Tutorial soll den Einstieg in die Programmierung von Atmel [[AVR]]-Mikrocontrollern in der Programmiersprache [[C]] mit dem freien C-Compiler [[avr-gcc]] aus der [http://gcc.gnu.org/ GNU Compiler Collection] (GCC) erleichtern.&lt;br /&gt;
Vorausgesetzt werden Grundkenntnisse der Programmiersprache C. Diese Kenntnisse kann man sich online erarbeiten, z. B. mit dem [http://www.schellong.de/c.htm C Tutorial von Helmut Schellong] ([[C|Liste von C-Tutorials]]). Nicht erforderlich sind Vorkenntnisse in der Programmierung von Mikrocontrollern.&lt;br /&gt;
= Vorwort =&lt;br /&gt;
In diesem Text wird häufig auf die Standardbibliothek avr-libc verwiesen, für die es eine [http://www.nongnu.org/avr-libc/user-manual/index.html Online-Dokumentation] gibt, in der sich auch viele nützliche Informationen zum Compiler und zur Programmierung von AVR-Controllern finden. Beim Paket [[WinAVR]] gehört die avr-libc Dokumentation zum Lieferumfang und wird mitinstalliert.&lt;br /&gt;
Der Compiler und die Standardbibliothek avr-libc werden ständig weiterentwickelt. Einige Unterschiede, die sich im Verlauf der Entwicklung ergeben haben, werden hier und im Artikel [[AVR-GCC-Tutorial/Alte Quellen|Alte Quellen]] zwar angesprochen, Anfängern und Umsteigern sei jedoch empfohlen, eine aktuelle Versionen zu nutzen.&lt;br /&gt;
Das ursprüngliche Tutorial stammt von Christian Schifferle, viele neue Abschnitte und aktuelle Anpassungen von Martin Thomas.&lt;br /&gt;
Dieses Tutorial ist in [[Media:AVR-GCC-Tutorial.pdf|PDF-Form]] erhältlich (zur Zeit nur eine sehr veraltete Version).&lt;br /&gt;
== Weiterführende Kapitel ==&lt;br /&gt;
Um dieses riesige Tutorial etwas überschaubarer zu gestalten, wurden einige Kapitel ausgelagert, die nicht unmittelbar mit den Grundlagen von avr-gcc in Verbindung stehen. All diese Seiten gehören zur [[:Kategorie:avr-gcc Tutorial]].&lt;br /&gt;
;UART: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Der UART|Der UART]]&#039;&#039;&lt;br /&gt;
;ADC: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Analoge Ein- und Ausgabe|Analoge Ein- und Ausgabe (ADC)]]&#039;&#039;&lt;br /&gt;
;Timer: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Die Timer und Zähler des AVR|Die Timer und Zähler des AVR]]&#039;&#039;&lt;br /&gt;
;LCD: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/LCD-Ansteuerung|LCD-Ansteuerung]]&#039;&#039;&lt;br /&gt;
;Watchdog: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Der Watchdog|Der Watchdog]]&#039;&#039;&lt;br /&gt;
;Assembler: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Assembler und Inline-Assembler|Assembler und Inline-Assembler]]&#039;&#039;&lt;br /&gt;
;alte Quellen anpassen: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Alte Quellen|Alte Quellen anpassen]]&#039;&#039;&lt;br /&gt;
;Makefiles: → Hauptartikel: &#039;&#039;[[AVR-GCC-Tutorial/Exkurs Makefiles|Exkurs Makefiles]]&#039;&#039; sowie als Alternative für sehr kleine Projekte → Hauptartikel: &#039;&#039;[[C ohne Makefile]]&#039;&#039;&lt;br /&gt;
Um eigene Programme für AVRs mittels einer AVR-Toolchain zu erstellen wird folgende Hard- und Software benötigt:&lt;br /&gt;
* Eine AVR-Toolchain bestehend aus avr-gcc, den avr-Binutils (Assembler, Linker, etc) und einer Standard-C Bibliothek.  Üblich ist die AVR-LibC, die auch quasi in allen avr-gcc Distributionen enthalten ist.&lt;br /&gt;
Hardware wird keine benötigt – bis auf einen PC natürlich, auf dem der Compiler ablaufen kann.  Selbst ohne AVR-Hardware kann man also bereits C-Programme für AVRs schreiben, compiliern und sich das Look-and-Feel von avr-gcc sowie von IDEs wie [[Atmel Studio]], Eclipse oder leichtgewichtigeren Entwicklungsumbgebungen anschauen. Selbst das Debuggen und Simulieren ist mithilfe entsprechender Tools wie Debugger und Simulator in gewissen Grenzen möglich.&lt;br /&gt;
Um Programme für AVRs mittels einer AVR-Toolchain zu testen, wird folgende Hard- und Software benötigt:&lt;br /&gt;
* Platine oder Versuchsaufbau für die Aufnahme eines AVR-Controllers, der vom avr-gcc Compiler unterstützt wird.&amp;lt;ref&amp;gt;Für eine Liste der unterstützten COntroller siehe die Dokumentation des Compilers oder [http://www.nongnu.org/avr-libc/user-manual/index.html#supported_devices AVR-Libc: Supported Devices].&amp;lt;/ref&amp;gt; Dieses Testboard kann durchaus auch selbst gelötet oder auf einem Steckbrett aufgebaut werden. Einige Registerbeschreibungen dieses Tutorials beziehen sich auf den inzwischen veralteten AT90S2313. Der weitaus größte Teil des Textes ist aber für alle Controller der AVR-Familie gültig. &lt;br /&gt;
:Brauchbare Testplattformen sind auch das [[STK500]] und der [[AVR Butterfly]] von Atmel. Weitere Infos findet man in den Artikeln [[AVR#Starterkits|AVR Starterkits]] und [[AVR-Tutorial: Equipment]].&lt;br /&gt;
* Programmiersoftware und -[[AVR In System Programmer |hardware]] z. B. PonyProg (siehe auch: [[Pony-Prog Tutorial]]) oder [[AVRDUDE]] mit [[STK200]]-Dongle oder die von Atmel verfügbare Hard- und Software ([[STK500]], Atmel AVRISP, [[AVR-Studio]]).&lt;br /&gt;
* Nicht unbedingt erforderlich, aber zur Simulation und zum Debuggen unter MS-Windows recht nützlich: [[AVR-Studio]].&lt;br /&gt;
* Wer unter Windows und Linux gleichermassen entwickeln will, der sollte sich die [http://www.eclipse.org/ IDE Eclipse for C/C++ Developers] und das [http://avr-eclipse.sourceforge.net/wiki/index.php/The_AVR_Eclipse_Plugin AVR-Eclipse Plugin] ansehen. Beide sind unter Windows und Linux einfach zu installieren, siehe auch [[AVR Eclipse]]. Ebenfalls unter Linux und Windows verfügbar ist die Entwicklungsumgebung [http://www.codeblocks.org/ Code::Blocks]&amp;lt;ref&amp;gt;Aktuelle, stabile Versionen sind als Nightly Builds regelmäßig im [http://forums.codeblocks.org/ Forum] verfügbar.&amp;lt;/ref&amp;gt;. Innerhalb dieser Entwicklungsumgebung können ohne die Installation zusätzlicher Plugins &amp;quot;AVR-Projekte&amp;quot; angelegt werden. Für Linux gibt es auch noch das [http://www.roboternetz.de/phpBB2/zeigebeitrag.php?t=25220 KontrollerLab].&lt;br /&gt;
= Was tun, wenn&#039;s nicht klappt? =&lt;br /&gt;
* Herausfinden, ob es tatsächlich ein avr(-gcc) spezifisches Problem ist oder nur die eigenen C-Kenntnisse einer Auffrischung bedürfen. Allgemeine C-Fragen kann man eventuell &amp;quot;beim freundlichen Programmierer zwei Büro-, Zimmer- oder Haustüren weiter&amp;quot; loswerden. Ansonsten: [[C]]-Buch (gibt&#039;s auch &amp;quot;gratis&amp;quot; online) lesen.&lt;br /&gt;
* Die [[AVR Checkliste]] durcharbeiten.&lt;br /&gt;
* Das [http://www.mikrocontroller.net/forum/gcc GCC-Forum auf  www.mikrocontroller.net] nach vergleichbaren Problemen absuchen.&lt;br /&gt;
* Das avr-gcc-Forum bei [http://www.avrfreaks.net AVRfreaks] nach vergleichbaren Problemen absuchen.&lt;br /&gt;
* Nach Beispielcode suchen. Vor allem im &#039;&#039;Projects&#039;&#039;-Bereich von [http://www.avrfreaks.net AVRfreaks] (anmelden).&lt;br /&gt;
* Bei Problemen mit der Ansteuerung interner AVR-Funktionen mit C-Code: das Datenblatt des Controllers lesen (ganz und am Besten zweimal). Datenblätter sind  auf den [http://www.atmel.com Atmel Webseiten] als pdf-Dateien verfügbar. Das komplette Datenblatt (complete) und nicht die Kurzfassung (summary) verwenden.&lt;br /&gt;
* Die Beispielprogramme im [[AVR-Tutorial]] sind zwar in AVR-Assembler verfasst, Erläuterungen und Vorgehensweisen sind aber auch auf C-Programme übertragbar.&lt;br /&gt;
* Einen Beitrag in eines der Foren oder eine Mail an die Mailing-Liste schreiben. Dabei möglichst viel Information geben: Controller, Compilerversion, genutzte Bibliotheken, Ausschnitte aus dem Quellcode oder besser ein [http://www.mikrocontroller.net/topic/72767#598986 Testprojekt] mit allen notwendigen Dateien, um das Problem nachzuvollziehen, sowie genaue Fehlermeldungen bzw. Beschreibung des Fehlverhaltens. Bei Ansteuerung externer Geräte die Beschaltung beschreiben oder skizzieren (z. B. mit [http://www.tech-chat.de/ Andys ASCII Circuit]). Siehe dazu auch: &#039;&#039;&#039;[http://www.tty1.net/smart-questions_de.html &amp;quot;Wie man Fragen richtig stellt&amp;quot;]&#039;&#039;&#039;.&lt;br /&gt;
Aus dem C-Quellcode erzeugt der avr-gcc Compiler (zusammen mit Hilfsprogrammen wie z.&amp;amp;nbsp;B. Präprozessor, Assembler und Linker) Maschinencode für den AVR-Controller. Üblicherweise liegt dieser Code dann im Intel Hex-Format vor (&amp;quot;Hex-Datei&amp;quot;). Die Programmiersoftware (z.&amp;amp;nbsp;B. [[AVRDUDE]], PonyProg oder AVRStudio/STK500-plugin) liest diese Datei ein und überträgt die enthaltene Information (den Maschinencode) in den Speicher des Controllers. Im Prinzip sind also &amp;quot;nur&amp;quot; der avr-gcc-Compiler (und wenige Hilfsprogramme) mit den &amp;quot;richtigen&amp;quot; Optionen aufzurufen, um aus C-Code eine &amp;quot;Hex-Datei&amp;quot; zu erzeugen. Grundsätzlich stehen dazu drei verschiedene Ansätze zur Verfügung:&lt;br /&gt;
* Die Verwendung einer integrierten Entwicklungsumgebung (IDE = &#039;&#039;&#039;I&#039;&#039;&#039;ntegrated &#039;&#039;&#039;D&#039;&#039;&#039;evelopment &#039;&#039;&#039;E&#039;&#039;&#039;nvironment), bei der alle Einstellungen z.&amp;amp;nbsp;B. in Dialogboxen durchgeführt werden können. Unter Anderem kann AVRStudio ab Version 4.12 (kostenlos auf [http://www.atmel.com/ atmel.com]) zusammen mit WinAVR als integrierte Entwicklungsumgebung für den Compiler avr-gcc genutzt werden (dazu müssen AVRStudio und WinAVR auf dem Rechner installiert sein). Weitere IDEs (ohne Anspruch auf Vollständigkeit): [http://www.eclipse.org/ Eclipse for C/C++ Developers] (d.h. inkl. CDT) und das [http://avr-eclipse.sourceforge.net/wiki/index.php/The_AVR_Eclipse_Plugin AVR-Eclipse Plugin] (für diverse Plattformen, u.a. Linux und MS Windows, IDE und Plugin kostenlos), [http://sourceforge.net/projects/kontrollerlab KontrollerLab] (Linux/KDE, kostenlos). [http://www.atmanecl.com/EnglishSite/SoftwareEnglish.htm AtmanAvr] (MS Windows, relativ günstig), KamAVR (MS-Windows, kostenlos, wird augenscheinlich nicht mehr weiterentwickelt), [http://www.amctools.com/vmlab.htm VMLab] (MS Windows, ab Version 3.12 ebenfalls kostenlos). Integrierte Entwicklungsumgebungen unterscheiden sich stark in Ihrer Bedienung und stehen auch nicht für alle Plattformen zur Verfügung, auf denen der Compiler  ausführbar ist (z.&amp;amp;nbsp;B. AVRStudio nur für MS-Windows). Zur Anwendung des avr-gcc Compilers mit IDEs sei hier auf deren Dokumentation verwiesen. &lt;br /&gt;
* Die Nutzung des Programms make mit passenden Makefiles. In den folgenden Abschnitten wird die Generierung von Maschinencode für einen AVR (&amp;quot;hex-Datei&amp;quot;) aus C-Quellcode (&amp;quot;c-Dateien&amp;quot;) anhand von &amp;quot;make&amp;quot; und den &amp;quot;Makefiles&amp;quot; näher erläutert. Viele der darin beschriebenen Optionen findet man auch im Konfigurationsdialog des avr-gcc-Plugins von AVRStudio (AVRStudio generiert ein makefile in einem Unterverzeichnis des Projektverzeichnisses). &lt;br /&gt;
* Das Generieren des Programms ohne IDE und ohne Makefile. In diesem Fall muss die Quellcodedatei durch eine vorgefertigte Kommandofolge an den Compiler übergeben werden. Der Artikel [[C ohne Makefile]] zeigt, wie das funktioniert. Diese Vorgehensweise empfiehlt sich jedoch nur für kleine Programme, die nicht auf verschiedene Quellcodedateien verteilt sind.&lt;br /&gt;
Beim Wechsel vom makefile-Ansatz nach WinAVR-Vorlage zu AVRStudio ist darauf zu achten, dass AVRStudio (Stand: AVRStudio Version 4.13) bei einem neuen Projekt die Optimierungsoption (vgl. Artikel [[AVR-GCC-Tutorial/Exkurs_Makefiles|AVR-GCC-Tutorial/Exkurs: Makefiles]], typisch: -Os) nicht einstellt und die mathematische Bibliothek der avr-libc (libm.a, Linker-Option -lm) nicht einbindet. (Hinweis: Bei Version 4.16 wird beides bereits gesetzt). Beides ist Standard bei Verwendung von makefiles nach WinAVR-Vorlage und sollte daher auch im Konfigurationsdialog des avr-gcc-Plugins von AVRStudio &amp;quot;manuell&amp;quot; eingestellt werden, um auch mit AVRStudio kompakten Code zu erzeugen.&lt;br /&gt;
Ein kurzes Wort zur Hardware: Bei diesem Programm werden alle Pins von PORTB auf Ausgang gesetzt, und einige davon werden auf HIGH andere auf LOW gesetzt. Das kann je nach angeschlossener Hardware an diesen Pins kritisch sein. Am ungefährlichsten ist es, wenn nichts an den Pins angeschlossen ist und man die Funktion des Programmes durch eine Spannungsmessung mit einem Multimeter kontrolliert. Die Spannung wird dabei zwischen GND-Pin und den einzelnen Pins von PORTB gemessen.&lt;br /&gt;
   und Stern-Schrägstrich sind Kommentare */&lt;br /&gt;
   DDRB  = 0xFF;             // (3)&lt;br /&gt;
   while(1) {                // (5)&lt;br /&gt;
     /* &amp;quot;leere&amp;quot; Schleife*/   // (6)&lt;br /&gt;
   }                         // (7)&lt;br /&gt;
   return 0;                 // (8)&lt;br /&gt;
# In dieser Zeile wird eine sogenannte Header-Datei eingebunden. In &amp;lt;code&amp;gt;avr/io.h&amp;lt;/code&amp;gt; sind die Registernamen definiert, die im späteren Verlauf genutzt werden. Auch unter Windows wird ein&amp;amp;nbsp;&amp;lt;code&amp;gt;/&amp;lt;/code&amp;gt; zur Kennzeichnung von Unterverzeichnissen in Include-Dateinamen verwendet und kein&amp;amp;nbsp;&amp;lt;code&amp;gt;\&amp;lt;/code&amp;gt;.&lt;br /&gt;
# Hier beginnt das eigentliche Programm. Jedes C-Programm beginnt mit den Anweisungen in der Funktion &amp;lt;code&amp;gt;main&amp;lt;/code&amp;gt;.&lt;br /&gt;
# Die Anschlüsse eines AVR (Pins) werden zu Blöcken zusammengefasst, einen solchen Block bezeichnet man als Port. Beim ATmega16 hat jeder Port 8 Anschlüsse, bei kleineren AVRs können einem Port auch weniger als 8 Anschlüsse zugeordnet sein. Da per Definition (Datenblatt) alle gesetzten Bits in einem Datenrichtungsregister den entsprechenden Anschluss auf Ausgang schalten, werden mit DDRB=0xff alle Anschlüsse des Ports B als Ausgänge eingestellt.&lt;br /&gt;
# Die den ersten beiden Bits des Ports zugeordneten Anschlüsse (PB0 und PB1) werden 1, alle anderen Anschlüsse des Ports B (PB2-PB7) zu 0. Aktivierte Ausgänge (logisch 1 oder &amp;quot;high&amp;quot;) liegen auf Betriebsspannung (VCC, meist 5 Volt), nicht aktivierte Ausgänge führen 0 Volt (GND, Bezugspotential). Es ist sinnvoll, sich möglichst frühzeitig eine alternative Schreibweise beizubringen, die wegen der leichteren Überprüfbarkeit und Portierbarkeit oft im weiteren Tutorial und in Forenbeiträgen benutzt wird. Die Zuordnung sieht in diesem Fall so aus, Näheres dazu im Artikel [[Bitmanipulation]]:&amp;lt;syntaxhighlight lang=&amp;quot;c&amp;quot;&amp;gt;PORTB = (1&amp;lt;&amp;lt;PB1) | (1&amp;lt;&amp;lt;PB0);&amp;lt;/syntaxhighlight&amp;gt;&lt;br /&gt;
# ist der Beginn der sogenannte &#039;&#039;Hauptschleife&#039;&#039; (main-loop). Dies ist eine Endlosschleife, welche kontinuierlich wiederkehrende Befehle enthält.&lt;br /&gt;
# In diesem Beispiel ist die Hauptschleife leer. Der Controller durchläuft die Schleife immer wieder, ohne dass etwas passiert. Eine solche Schleife ist notwendig, da es auf dem Controller kein Betriebssystem gibt, das nach Beendigung des Programmes die Kontrolle übernehmen könnte. Ohne diese Schleife kehrt das Programm aus &amp;lt;code&amp;gt;main&amp;lt;/code&amp;gt; zurück, alle Interrupts werden deaktiviert und eine Endlosschleife betreten.&lt;br /&gt;
# Ende der Hauptschleife und Sprung zur passenden, öffnenden Klammer, also zu 5.&lt;br /&gt;
# ist das Programmende. Die Zeile ist nur aus Gründen der C-Kompatibilität enthalten: &amp;lt;syntaxhighlight lang=&amp;quot;c&amp;quot;&amp;gt;int main(void)&amp;lt;/syntaxhighlight&amp;gt; besagt, dass die Funktion einen int-Wert zurückgibt. Die Anweisung wird aber nicht erreicht, da das Programm die Hauptschleife nie verlässt.&lt;br /&gt;
Um diesen Quellcode in ein lauffähiges Programm zu übersetzen, wird hier ein Makefile genutzt. Das verwendete Makefile findet sich auf der Seite [[Beispiel Makefile]] und basiert auf der Vorlage, die in WinAVR mitgeliefert wird und wurde bereits angepasst (Controllertyp ATmega16). Man kann das Makefile bearbeiten und an andere Controller anpassen oder sich mit dem Programm MFile menügesteuert ein Makefile &amp;quot;zusammenklicken&amp;quot;. Das Makefile speichert man unter dem Namen &amp;lt;code&amp;gt;Makefile&amp;lt;/code&amp;gt; (ohne Endung) im selben Verzeichnis, in dem auch die Datei &amp;lt;code&amp;gt;main.c&amp;lt;/code&amp;gt; mit dem Programmcode abgelegt ist. Detailliertere Erklärungen zur Funktion von Makefiles finden sich im Artikel [[AVR-GCC-Tutorial/Exkurs_Makefiles|Exkurs: Makefiles]].&lt;br /&gt;
D:\beispiel&amp;gt;dir&lt;br /&gt;
 Verzeichnis von D:\beispiel&lt;br /&gt;
Nun gibt man &#039;&#039;make all&#039;&#039; ein. Falls das mit WinAVR installierte Programmers Notepad genutzt wird, gibt es dazu einen Menüpunkt im Tools Menü. Sind alle Einstellungen korrekt, entsteht eine Datei &amp;lt;code&amp;gt;main.hex&amp;lt;/code&amp;gt;, in welcher der Code für den AVR enthalten ist. &lt;br /&gt;
D:\beispiel&amp;gt;make all&lt;br /&gt;
o obj/main.o&lt;br /&gt;
Linking: main.elf&lt;br /&gt;
Der Inhalt der hex-Datei kann nun zum Controller übertragen werden. Dies kann z.&amp;amp;nbsp;B. über In-System-Programming ([[ISP]]) erfolgen, das im [[AVR-Tutorial: Equipment]] beschrieben ist. Makefiles nach der WinAVR/MFile-Vorlage sind für die Nutzung des Programms [[AVRDUDE]] vorbereitet. Wenn man den Typ und Anschluss des Programmiergerätes richtig eingestellt hat, kann mit &#039;&#039;make program&#039;&#039; die Übertragung mittels AVRDUDE gestartet werden. Jede andere Software, die hex-Dateien lesen und zu einem AVR übertragen kann&amp;lt;ref&amp;gt;z.&amp;amp;nbsp;B. [[Pony-Prog_Tutorial|Ponyprog]], yapp, AVRStudio&amp;lt;/ref&amp;gt;, kann natürlich ebenfalls genutzt werden.&lt;br /&gt;
Startet man nun den Controller (Reset-Taster oder Stromzufuhr aus/an), werden vom Programm die Anschlüsse PB0 und PB1 auf 1 gesetzt. Man kann mit einem Messgerät nun an diesem Anschluss die Betriebsspannung messen oder eine [[LED]] leuchten lassen (Anode an den Pin, Vorwiderstand nicht vergessen). An den Anschlüssen PB2-PB7 misst man 0 Volt. Eine mit der Anode mit einem dieser Anschlüsse verbundene LED leuchtet nicht.&lt;br /&gt;
= Ganzzahlige Datentypen (Integer) =&lt;br /&gt;
Standardisierte Datentypen werden in der Header-Datei &amp;lt;code&amp;gt;stdint.h&amp;lt;/code&amp;gt; definiert, die folgendermaßen eingebunden werden kann:&lt;br /&gt;
&amp;lt;syntaxhighlight lang=&amp;quot;c&amp;quot;&amp;gt;#include &amp;lt;stdint.h&amp;gt;&amp;lt;/syntaxhighlight&amp;gt;&lt;br /&gt;
|+ &#039;&#039;&#039;int-Typen aus &amp;lt;code&amp;gt;stdint.h&amp;lt;/code&amp;gt; (C99)&#039;&#039;&#039;&amp;lt;br/&amp;gt;&amp;amp;nbsp;&lt;br /&gt;
!colspan=&amp;quot;5&amp;quot;| Vorzeichenbehaftete int-Typen&lt;br /&gt;
! Typname || Bit-Breite ||colspan=&amp;quot;2&amp;quot;| Wertebereich&lt;br /&gt;
|align=&amp;quot;center| &#039;&#039;&#039;C-Entsprechung&#039;&#039;&#039; (avr-gcc)&lt;br /&gt;
|&amp;lt;code&amp;gt;int8_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 8 || −128 ⋯ 127 || −2&amp;lt;sup&amp;gt;7&amp;lt;/sup&amp;gt; ⋯ 2&amp;lt;sup&amp;gt;7&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;signed char&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;int16_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 16 || −32768 ⋯ 32767 || −2&amp;lt;sup&amp;gt;15&amp;lt;/sup&amp;gt; ⋯ 2&amp;lt;sup&amp;gt;15&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;signed short&amp;lt;/code&amp;gt;, &amp;lt;code&amp;gt;signed int&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;int32_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 32 || −2147483648 ⋯ 2147483647 || −2&amp;lt;sup&amp;gt;31&amp;lt;/sup&amp;gt; ⋯ 2&amp;lt;sup&amp;gt;31&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;signed long&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;int64_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 64 || −9223372036854775808 ⋯ 9223372036854775807 || −2&amp;lt;sup&amp;gt;63&amp;lt;/sup&amp;gt; ⋯ 2&amp;lt;sup&amp;gt;63&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;signed long long&amp;lt;/code&amp;gt;&lt;br /&gt;
!colspan=&amp;quot;5&amp;quot;| Vorzeichenlose int-Typen&lt;br /&gt;
|&amp;lt;code&amp;gt;uint8_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 8 || 0 ⋯ 255 || 0 ⋯ 2&amp;lt;sup&amp;gt;8&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;unsigned char&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;uint16_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 16 || 0 ⋯ 65535 || 0 ⋯ 2&amp;lt;sup&amp;gt;16&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;unsigned short&amp;lt;/code&amp;gt;, &amp;lt;code&amp;gt;unsigned int&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;uint32_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 32 || 0 ⋯ 4294967295 || 0 ⋯ 2&amp;lt;sup&amp;gt;32&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;unsigned long&amp;lt;/code&amp;gt;&lt;br /&gt;
|&amp;lt;code&amp;gt;uint64_t&amp;lt;/code&amp;gt; ||align=&amp;quot;right&amp;quot;| 64 || 0 ⋯ 18446744073709551615 || 0 ⋯ 2&amp;lt;sup&amp;gt;64&amp;lt;/sup&amp;gt;−1 || &amp;lt;code&amp;gt;unsigned long long&amp;lt;/code&amp;gt;&lt;br /&gt;
Neben den Typen gibt es auch Makros für die Bereichsgrenzen wie &amp;lt;code&amp;gt;INT8_MIN&amp;lt;/code&amp;gt; oder &amp;lt;code&amp;gt;UINT16_MAX&amp;lt;/code&amp;gt;. Siehe dazu auch: [http://www.nongnu.org/avr-libc/user-manual/group__avr__stdint.html Dokumentation der avr-libc: Standard Integer Types].&lt;br /&gt;
= Grundsätzlicher Programmaufbau eines µC-Programms =&lt;br /&gt;
[[Image:Sequentielle Programme.gif|left]]&lt;br /&gt;
Wesentlichen immer den gleichen Aufbau hat. Es wird hier nach dem sogenannten EVA-Prinzip gehandelt. EVA steht für &amp;quot;Eingabe, Verarbeitung, Ausgabe&amp;quot;.&lt;br /&gt;
[[Image:Interrupt Programme.gif|left]]&lt;br /&gt;
Bei dieser Methode werden beim Programmstart zuerst die gewünschten Interruptquellen aktiviert und dann in eine Endlosschleife gegangen, in welcher Dinge erledigt werden können, welche nicht zeitkritisch sind. Wenn ein Interrupt ausgelöst wird, so wird automatisch die zugeordnete Interruptfunktion ausgeführt.&lt;br /&gt;
= Zugriff auf Register =&lt;br /&gt;
Register haben einen besonderen Stellenwert bei den AVR Controllern. Sie dienen dem Zugriff auf die Ports und die Schnittstellen des Controllers. Wir unterscheiden zwischen 8-Bit und 16-Bit Registern. Vorerst behandeln wir die 8-Bit Register.&lt;br /&gt;
Einzelne Register sind bei allen AVRs vorhanden, andere wiederum nur bei bestimmten Typen. So sind beispielsweise die Register, welche für den Zugriff auf den UART notwendig sind, selbstverständlich nur bei denjenigen Modellen vorhanden, welche über einen integrierten Hardware UART bzw. USART verfügen.&lt;br /&gt;
Die Namen der Register sind in den Headerdateien zu den entsprechenden AVR-Typen definiert. Dazu muss man den Namen der controllerspezifischen Headerdatei nicht kennen. Es reicht aus, die allgemeine Headerdatei &#039;&#039;avr/io.h&#039;&#039; einzubinden:&lt;br /&gt;
Ist im Makefile der MCU-Typ z.&amp;amp;nbsp;B. mit dem Inhalt atmega8 definiert (und wird somit per -mmcu=atmega8 an den Compiler übergeben), wird beim Einlesen der io.h-Datei implizit (&amp;quot;automatisch&amp;quot;) auch die iom8.h-Datei mit den Register-Definitionen für den ATmega8 eingelesen.&lt;br /&gt;
Intern wird diese &amp;quot;Automatik&amp;quot; wie folgt realisiert: Der Controllertyp wird dem Compiler als Parameter übergeben (vgl. &#039;&#039;avr-gcc -c -mmcu=atmega16 [...]&#039;&#039; im Einführungsbeispiel). Wird ein Makefile nach der WinAVR/mfile-Vorlage verwendet, setzt man die Variable &#039;&#039;MCU&#039;&#039;, der Inhalt dieser Variable wird dann an passender Stelle für die Compilerparameter verwendet. Der Compiler definiert intern eine dem mmcu-Parameter zugeordnete &amp;quot;Variable&amp;quot; (genauer: ein Makro) mit dem Namen des Controllers, vorangestelltem &#039;&#039;__AVR_&#039;&#039; und angehängten Unterstrichen (z.&amp;amp;nbsp;B. wird bei &#039;&#039;-mmcu=atmega16&#039;&#039; das Makro &#039;&#039;__AVR_ATmega16__&#039;&#039; definiert). Beim Einbinden der Header-Datei &#039;&#039;avr/io.h&#039;&#039; wird geprüft, ob das jeweilige Makro definiert ist und die zum Controller passende Definitionsdatei eingelesen. Zur Veranschaulichung einige Ausschnitte aus einem Makefile:&lt;br /&gt;
[...]&lt;br /&gt;
MCU = atmega16&lt;br /&gt;
[...]&lt;br /&gt;
[...]&lt;br /&gt;
[...]&lt;br /&gt;
[...]&lt;br /&gt;
	@echo&lt;br /&gt;
[...]&lt;br /&gt;
// avr/io.h &lt;br /&gt;
[...]&lt;br /&gt;
// [...]&lt;br /&gt;
#else&lt;br /&gt;
#  endif&lt;br /&gt;
Die Beispiele in den folgenden Abschnitten demonstrieren den Zugriff auf Register anhand der Register für I/O-Ports (PORTx, DDRx, PINx), die Vorgehensweise ist jedoch für alle Register (z.&amp;amp;nbsp;B. die des UART, ADC, SPI) analog.&lt;br /&gt;
== Schreiben in Register ==&lt;br /&gt;
Zum Schreiben kann man Register einfach wie eine Variable setzen.&amp;lt;ref&amp;gt;In Quellcodes, die für ältere Versionen des avr-gcc/der avr-libc entwickelt wurden, erfolgt der Schreibzugriff über die Funktion outp(). Aktuelle Versionen des Compilers unterstützen den Zugriff nun direkt, outp() ist nicht mehr erforderlich.&amp;lt;/ref&amp;gt;&lt;br /&gt;
int main()&lt;br /&gt;
       (alle Pins als Ausgang, vgl. Abschnitt Zugriff auf Ports): */&lt;br /&gt;
    DDRA = 0xff;    &lt;br /&gt;
    PORTA = 0x03;   &lt;br /&gt;
    /* Ausführliche Schreibweise: identische Funktionalität, mehr Tipparbeit&lt;br /&gt;
       aber übersichtlicher und selbsterklärend: */&lt;br /&gt;
    DDRB = (1 &amp;lt;&amp;lt; DDB0) | (1 &amp;lt;&amp;lt; DDB1) | (1 &amp;lt;&amp;lt; DDB2) | (1 &amp;lt;&amp;lt; DDB3) | (1 &amp;lt;&amp;lt; DDB4);&lt;br /&gt;
    while (1);&lt;br /&gt;
Die ausführliche Schreibweise sollte bevorzugt verwendet werden, da dadurch die Zuweisungen selbsterklärend sind und somit der Code leichter nachvollzogen werden kann. Atmel verwendet sie auch bei Beispielen in Datenblätten und in den allermeisten Quellcodes zu Application-Notes. Mehr zu der Schreibweise mit &amp;quot;|&amp;quot; und &amp;quot;&amp;lt;&amp;lt;&amp;quot; findet man unter [[Bitmanipulation]].&lt;br /&gt;
Der gcc C-Compiler unterstützt ab Version 4.3.0 Konstanten im Binärformat, z.&amp;amp;nbsp;B. DDRB&amp;amp;nbsp;=&amp;amp;nbsp;0b00011111. Diese Schreibweise ist jedoch nur in GNU-C verfügbar und nicht in ISO-C definiert. Man sollte sie daher nicht verwenden, wenn Code mit anderen ausgetauscht oder mit anderen Compilern bzw. älteren Versionen des gcc genutzt werden soll.&lt;br /&gt;
== Verändern von Registerinhalten ==&lt;br /&gt;
Einzelne Bits setzt und löscht man &amp;quot;Standard-C-konform&amp;quot; mittels logischer (Bit-) Operationen. &lt;br /&gt;
 x |= (1 &amp;lt;&amp;lt; Bitnummer);  // Hiermit wird ein Bit in x gesetzt&lt;br /&gt;
 x &amp;amp;= ~(1 &amp;lt;&amp;lt; Bitnummer); // Hiermit wird ein Bit in x geloescht&lt;br /&gt;
Es wird jeweils nur der Zustand des angegebenen Bits geändert, der vorherige Zustand der anderen Bits bleibt erhalten. &lt;br /&gt;
#define MEINBIT 2&lt;br /&gt;
DDRA &amp;amp;= ~( (1&amp;lt;&amp;lt;PA0) | (1&amp;lt;&amp;lt;PA3) );  /* PA0 und PA3 als Eingaenge */&lt;br /&gt;
PORTA |= ( (1&amp;lt;&amp;lt;PA0) | (1&amp;lt;&amp;lt;PA3) );  /* Interne Pull-Up fuer beide einschalten */&lt;br /&gt;
Bei bestimmten AVR Registern mit Bits, die durch Beschreiben mit einer logischen 1 gelöscht werden, muss eine absolute Zuweisung benutzt werden. Ein ODER löscht in diesen Registern ALLE gesetzten Bits!&lt;br /&gt;
TIFR2 = (1&amp;lt;&amp;lt;OCF2A); // Nur Bit OCF2A löschen&lt;br /&gt;
== Lesen aus Registern ==&lt;br /&gt;
Zum Lesen kann man auf Register einfach wie auf eine Variable zugreifen. In Quellcodes, die für ältere Versionen des avr-gcc/der avr-libc entwickelt wurden, erfolgt der Lesezugriff über die Funktion inp(). Aktuelle Versionen des Compilers unterstützen den Zugriff nun direkt und inp() ist nicht mehr erforderlich.&lt;br /&gt;
uint8_t foo;&lt;br /&gt;
//...&lt;br /&gt;
    foo = PINB;    &lt;br /&gt;
    //...&lt;br /&gt;
Die Abfrage der Zustände von Bits erfolgt durch Einlesen des gesamten Registerinhalts und ausblenden der Bits deren Zustand nicht von Interesse ist. Einige Beispiele zum Prüfen ob Bits gesetzt oder gelöscht sind:&lt;br /&gt;
#define MEINBIT0 0 &lt;br /&gt;
extern test1();&lt;br /&gt;
// Funkion test1 aufrufen, wenn Bit 0 in Register PINA gesetzt (1) ist&lt;br /&gt;
i = PINA;         // Inhalt in Arbeitsvariable&lt;br /&gt;
i = i &amp;amp; 0x01;     // alle Bits bis auf Bit 0 ausblenden (bitweise und)&lt;br /&gt;
                  // falls das Bit gesetzt war, hat i den Inhalt 1&lt;br /&gt;
if ( i != 0 ) {   // Ergebnis ungleich 0 (wahr)? &lt;br /&gt;
  test1();         // dann muss Bit 0 in i gesetzt sein -&amp;gt; Funktion aufrufen&lt;br /&gt;
// verkürzt:&lt;br /&gt;
if ( ( PINA &amp;amp; 0x01 ) != 0 ) {&lt;br /&gt;
// nochmals verkürzt:&lt;br /&gt;
if ( PINA &amp;amp; 0x01 ) {&lt;br /&gt;
// mit definierter Bitnummer:&lt;br /&gt;
if ( PINA &amp;amp; ( 1 &amp;lt;&amp;lt; MEINBIT0 ) ) {&lt;br /&gt;
// Funktion aufrufen, wenn Bit 0 und/oder Bit 2 gesetzt ist. (Bit 0 und 2 also Wert 5) &lt;br /&gt;
// (Bedenke: Bit 0 hat Wert 1, Bit 1 hat Wert 2 und Bit 2 hat Wert 4)&lt;br /&gt;
if ( PINA &amp;amp; 0x05 ) {&lt;br /&gt;
  test1();  // Vergleich &amp;lt;&amp;gt; 0 (wahr), also mindestens eines der Bits gesetzt&lt;br /&gt;
// mit definierten Bitnummern:&lt;br /&gt;
if ( PINA &amp;amp; ( ( 1 &amp;lt;&amp;lt; MEINBIT0 ) | ( 1 &amp;lt;&amp;lt; MEINBIT2 ) ) ) {&lt;br /&gt;
// Funktion aufrufen, wenn Bit 0 und Bit 2 gesetzt sind&lt;br /&gt;
if ( ( PINA &amp;amp; 0x05 ) == 0x05 ) {  // nur wahr, wenn beide Bits gesetzt&lt;br /&gt;
// Funktion test2() aufrufen, wenn Bit 0 gelöscht (0) ist&lt;br /&gt;
i = PINA;        // einlesen in temporäre Variable&lt;br /&gt;
i = i &amp;amp; 0x01;    // maskieren von Bit 0&lt;br /&gt;
if ( i == 0 ) {  // Vergleich ist wahr, wenn Bit 0 nicht gesetzt ist&lt;br /&gt;
  test2();&lt;br /&gt;
// analog mit not-Operator&lt;br /&gt;
if ( !i ) {&lt;br /&gt;
if ( !( PINA &amp;amp; 0x01 ) ) {&lt;br /&gt;
== Warten auf einen bestimmten Zustand ==&lt;br /&gt;
Es gibt in der Bibliothek avr-libc Funktionen, die warten, bis ein bestimmter Zustand eines Bits erreicht ist. Es ist allerdings normalerweise eine eher unschöne Programmiertechnik, da in diesen Funktionen &amp;quot;blockierend&amp;quot; gewartet wird. Der Programmablauf bleibt also an dieser Stelle stehen, bis das maskierte Ereignis erfolgt ist. Setzt man den [[Watchdog]] ein, muss man darauf achten, dass dieser auch noch getriggert wird (Zurücksetzen des Watchdogtimers). &lt;br /&gt;
while ( !(WARTEPIN &amp;amp; (1 &amp;lt;&amp;lt; WARTEBIT)) ) {}&lt;br /&gt;
Die Funktion &#039;&#039;&#039;loop_until_bit_is_clear&#039;&#039;&#039; wartet in einer Schleife, bis das definierte Bit gelöscht ist. Wenn das Bit beim Aufruf der Funktion bereits gelöscht ist, wird die Funktion sofort wieder verlassen.&lt;br /&gt;
while ( WARTEPIN &amp;amp; (1&amp;lt;&amp;lt;WARTEBIT) ) {}&lt;br /&gt;
Siehe auch: &lt;br /&gt;
== 16-Bit Register (ADC, ICR1, OCR1x, TCNT1, UBRR) ==&lt;br /&gt;
Einige der Portregister in den AVR-Controllern sind 16 Bit breit. Im Datenblatt sind diese Register üblicherweise mit dem Suffix &amp;quot;L&amp;quot; (Low-Byte) und &amp;quot;H&amp;quot; (High-Byte) versehen. Die avr-libc definiert zusätzlich die meisten dieser Variablen die Bezeichnung ohne &amp;quot;L&amp;quot; oder &amp;quot;H&amp;quot;. Auf diese Register kann dann direkt zugegriffen werden. Dies ist zum Beispiel der Fall für Register wie ADC oder TCNT1.&lt;br /&gt;
    uint16_t foo;&lt;br /&gt;
    /* setzt die Wort-Variable foo auf den Wert der letzten AD-Wandlung */&lt;br /&gt;
    foo = ADC; &lt;br /&gt;
Bei anderen Registern, wie zum Beispiel Baudraten-Register, liegen High- und Low-Teil nicht direkt nebeneinander im SFR-Bereich, so dass ein 16-Bit Zugriff nicht möglich ist und der Zugriff zusammengebastelt werden muss:&lt;br /&gt;
   uint16_t baud = F_CPU / (UART_BAUD_RATE * 16L) -1;&lt;br /&gt;
   UBRRH = (uint8_t) (baud &amp;gt;&amp;gt; 8);&lt;br /&gt;
   UBRRL = (uint8_t) baud;&lt;br /&gt;
Bei einigen AVR-Typen wie ATmega8 oder ATmega16 teilen sich UBRRH und UCSRC die gleiche Speicher-Adresse. Damit der AVR trotzdem zwischen den beiden Registern unterscheiden kann, bestimmt das Bit7 (URSEL), welches Register tatsächlich beschrieben werden soll. &#039;&#039;1000 0011&#039;&#039; (0x83) adressiert demnach UCSRC und übergibt den Wert &#039;&#039;3&#039;&#039;. Und &#039;&#039;0000 0011&#039;&#039; (0x3) adressiert UBRRH und übergibt ebenfalls den Wert &#039;&#039;3&#039;&#039;. &lt;br /&gt;
Speziell bei den 16-Bit-Timern und auch beim ADC ist es bei allen Zugriffen auf Datenregister erforderlich, dass diese Daten synchronisiert sind. Wenn z.&amp;amp;nbsp;B. bei einem 16-Bit-Timer das High-Byte des Zählregisters gelesen wurde und vor dem Lesezugriff auf das Low-Byte ein Überlauf des Low-Bytes stattfindet, erhält man einen völlig unsinnigen Wert. Auch die Compare-Register müssen synchron geschrieben werden, da es ansonsten zu unerwünschten Compare-Ereignissen kommen kann. &lt;br /&gt;
* Bei den Timer-Registern (das gilt für alle TCNT-, OCR- und ICR-Register bei den 16-Bit-Timern) wird bei einem &#039;&#039;Lesezugriff&#039;&#039; auf das Low-Byte automatisch das High-Byte in ein temporäres Register, das ansonsten nach außen nicht sichtbar ist, geschoben. Greift man nun &#039;&#039;anschließend&#039;&#039; auf das High-Byte zu, dann wird eben dieses temporäre Register gelesen.&lt;br /&gt;
* Bei einem &#039;&#039;Schreibzugriff&#039;&#039; auf eines der genannten Register wird das High-Byte in besagtem temporären Register zwischengespeichert und erst beim Schreiben des Low-Bytes werden &#039;&#039;beide&#039;&#039; gleichzeitig in das eigentliche Register übernommen.&lt;br /&gt;
Das bedeutet für die Reihenfolge:&lt;br /&gt;
* Lesezugriff: Erst Low-Byte, dann High-Byte&lt;br /&gt;
* Schreibzugriff: Erst High-Byte, dann Low-Byte&lt;br /&gt;
Des weiteren ist zu beachten, dass es für all diese 16-Bit-Register nur ein einziges temporäres Register gibt, so dass das Auftreten eines Interrupts, in dessen Handler ein solches Register manipuliert wird, bei einem durch ihn unterbrochenen Zugriff i.d.R. zu Datenmüll führt. 16-Bit-Zugriffe sind generell nicht atomar! Wenn mit Interrupts gearbeitet wird, kann es erforderlich sein, vor einem solchen Zugriff auf ein 16-Bit-Register die Interrupt-Bearbeitung zu deaktivieren.&lt;br /&gt;
Beim ADC-Datenregister ADCH/ADCL ist die Synchronisierung anders gelöst. Hier wird beim Lesezugriff (ADCH/ADCL sind logischerweise read-only) auf das Low-Byte ADCL beide Teilregister für Zugriffe seitens des ADC so lange gesperrt, bis das High-Byte ADCH ausgelesen wurde. Dadurch kann der ADC nach einem Zugriff auf ADCL keinen neuen Wert in ADCH/ADCL ablegen, bis ADCH gelesen wurde. Ergebnisse von Wandlungen, die zwischen einem Zugriff auf ADCL und ADCH beendet werden, gehen verloren!&lt;br /&gt;
Nach einem Zugriff auf ADCL muss grundsätzlich ADCH gelesen werden!&lt;br /&gt;
In beiden Fällen – also sowohl bei den Timern als auch beim ADC – werden vom C-Compiler 16-Bit Pseudo-Register zur Verfügung gestellt (z.&amp;amp;nbsp;B. TCNT1H/TCNT1L → TCNT1, ADCH/ADCL → ADC bzw. ADCW), bei deren Verwendung der Compiler automatisch die richtige Zugriffsreihenfolge regelt. In C-Programmen sollten grundsätzlich diese 16-Bit-Register verwendet werden! Sollte trotzdem ein Zugriff auf ein Teilregister erforderlich sein, sind obige Angaben zu berücksichtigen.&lt;br /&gt;
ADC und ADCW sind unterschiedliche Bezeichner für das selbe Registerpaar. Üblicherweise kann man in C-Programmen ADC verwenden, was analog zu den anderen 16-Bit-Registern benannt ist. ADCW (ADC Word) existiert nur deshalb, weil die Headerdateien auch für Assembler vorgesehen sind und es bereits einen Assembler-Befehl namens &#039;&#039;adc&#039;&#039; gibt. &lt;br /&gt;
uint8_t key_pressed (volatile uint8_t *inputreg, uint8_t inputbit)&lt;br /&gt;
  if (last_state == (*inputreg &amp;amp; (1&amp;lt;&amp;lt;inputbit)))&lt;br /&gt;
  _delay_ms(20);&lt;br /&gt;
  last_state = *inputreg &amp;amp; (1&amp;lt;&amp;lt;inputbit);&lt;br /&gt;
  return *inputreg &amp;amp; (1&amp;lt;&amp;lt;inputbit);&lt;br /&gt;
void foo (void)&lt;br /&gt;
   uint8_t i = key_pressed (&amp;amp;PINB, PB1);&lt;br /&gt;
Siehe auch: [http://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_port_pass avr-libc FAQ: &amp;quot;How do I pass an IO port as a parameter to a function?&amp;quot;]&lt;br /&gt;
= Zugriff auf IO-Ports =&lt;br /&gt;
(GPIO - General Purpose Input/Output). Diese Register dienen dazu:&lt;br /&gt;
* einzustellen welche der Anschlüsse (&amp;quot;Beinchen&amp;quot;) des Controllers als Ein- oder Ausgänge dienen&lt;br /&gt;
* bei Ausgängen deren Zustand festzulegen&lt;br /&gt;
* bei Eingängen deren Zustand zu erfassen&lt;br /&gt;
Mittels GPIO werden digitale Zustände gesetzt und erfasst, d.h. die Spannung an einem Ausgang wird ein- oder ausgeschaltet und an einem Eingang wird erfasst, ob die anliegende Spannung über oder unter einem bestimmten Schwellwert liegt. Im Datenblatt Abschnitt Electrical Characteristics/DC Characteristics finden sich die Spannungswerte (V_OL, V_OH für Ausgänge, V_IL, V_IH für Eingänge).&lt;br /&gt;
Die physischen Ein- und Ausgänge werden bei AVR-Controllern zu logischen Ports gruppiert.&lt;br /&gt;
Alle Ports werden über Register gesteuert. Dazu sind jedem Port 3 Register zugeordnet:&lt;br /&gt;
! width=&amp;quot;10%&amp;quot;|  DDRx&lt;br /&gt;
&#039;&#039;&#039;x&#039;&#039;&#039; entspricht &#039;&#039;&#039;A&#039;&#039;&#039;, &#039;&#039;&#039;B&#039;&#039;&#039;, &#039;&#039;&#039; C&#039;&#039;&#039; usw. je nach gewünschtem Port. Bit im Register gesetzt (1) für Ausgang, Bit gelöscht (0) für Eingang.&lt;br /&gt;
! PINx&lt;br /&gt;
! PORTx&lt;br /&gt;
Die folgenden Beispiele gehen von einem AVR aus, der sowohl Port A als auch Port B besitzt. Sie müssen für andere AVRs (zum Beispiel ATmega8/48/88/168) entsprechend angepasst werden.&lt;br /&gt;
Angenommen am Port B sollen die Pins 0 bis 4 als Ausgänge definiert werden, die noch verbleibenden Pins 5 bis 7 sollen als Eingänge fungieren. Dazu ist es daher notwendig, im für das Port B zuständigen Datenrichtungsregister DDRB folgende Bitkonfiguration einzutragen&lt;br /&gt;
   | 0 | 0 | 0 | 1 | 1 | 1 | 1 | 1 |&lt;br /&gt;
   | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |&lt;br /&gt;
In C liest sich das dann so:&lt;br /&gt;
// in io.h wird u.a. DDRB definiert:&lt;br /&gt;
  // Binaer 00011111 = Hexadezimal 1F&lt;br /&gt;
  // direkte Zuweisung - standardkonform */&lt;br /&gt;
  DDRB = 0x1F;    /* &lt;br /&gt;
  // Uebersichtliche Alternative - Binaerschreibweise, aber kein ISO-C&lt;br /&gt;
  DDRB = 0b00011111;&lt;br /&gt;
  // Ausfuehrliche Schreibweise: identische Funktionalitaet, mehr Tipparbeit&lt;br /&gt;
  // aber uebersichtlicher und selbsterklaerend:&lt;br /&gt;
  DDRB |= (1 &amp;lt;&amp;lt; DDB0) | (1 &amp;lt;&amp;lt; DDB1) | (1 &amp;lt;&amp;lt; DDB2) | (1 &amp;lt;&amp;lt; DDB3) | (1 &amp;lt;&amp;lt; DDB4); &lt;br /&gt;
Die Pins 5 bis 7 werden (da 0) als Eingänge geschaltet. Weitere Beispiele:&lt;br /&gt;
  // Alle Pins des Ports B als Ausgang definieren:&lt;br /&gt;
  DDRB = 0xff; &lt;br /&gt;
  // Pin0 wieder auf Eingang und andere im urspruenglichen Zustand belassen:&lt;br /&gt;
  DDRB &amp;amp;= ~(1 &amp;lt;&amp;lt; DDB0);&lt;br /&gt;
  // Pin 3 und 4 auf Eingang und andere im urspruenglichen Zustand belassen:&lt;br /&gt;
  DDRB &amp;amp;= ~((1 &amp;lt;&amp;lt; DDB3) | (1 &amp;lt;&amp;lt; DDB4));&lt;br /&gt;
  // Pin 0 und 3 wieder auf Ausgang und andere im ursprünglichen Zustand belassen:&lt;br /&gt;
  DDRB |= (1 &amp;lt;&amp;lt; DDB0) | (1 &amp;lt;&amp;lt; DDB3);&lt;br /&gt;
  // Alle Pins auf Eingang:&lt;br /&gt;
  DDRB = 0x00;&lt;br /&gt;
Die Bitnummern (z.&amp;amp;nbsp;B. PCx, PINCx und DDCx für den Port C) sind in den io*.h-Dateien der avr-libc definiert und dienen lediglich der besseren Lesbarkeit. Man muss diese Definitionen nicht verwenden oder kann auch einfach &amp;quot;immer&amp;quot; PAx, PBx, PCx usw. nutzen, auch wenn der Zugriff auf Bits in DDRx- oder PINx-Registern erfolgt. Für den Compiler sind die Ausdrücke (1&amp;lt;&amp;lt;PC7), (1&amp;lt;&amp;lt;DDC7) und (1&amp;lt;&amp;lt;PINC7) identisch zu (1&amp;lt;&amp;lt;7) (genauer: der Präprozessor ersetzt die Ausdrücke (1&amp;lt;&amp;lt;PC7),... zu (1&amp;lt;&amp;lt;7)). Ein Ausschnitt der Definitionen für Port C eines ATmega32 aus der iom32.h-Datei zur Verdeutlichung (analog für die weiteren Ports):&lt;br /&gt;
/* PORTC */&lt;br /&gt;
#define PC7     7&lt;br /&gt;
#define PC6     6&lt;br /&gt;
#define PC5     5&lt;br /&gt;
#define PC4     4&lt;br /&gt;
#define PC3     3&lt;br /&gt;
#define PC2     2&lt;br /&gt;
#define PC1     1&lt;br /&gt;
#define PC0     0&lt;br /&gt;
/* DDRC */&lt;br /&gt;
#define DDC7    7&lt;br /&gt;
#define DDC6    6&lt;br /&gt;
#define DDC5    5&lt;br /&gt;
#define DDC4    4&lt;br /&gt;
#define DDC3    3&lt;br /&gt;
#define DDC2    2&lt;br /&gt;
#define DDC1    1&lt;br /&gt;
#define DDC0    0&lt;br /&gt;
/* PINC */&lt;br /&gt;
#define PINC7   7&lt;br /&gt;
#define PINC6   6&lt;br /&gt;
#define PINC5   5&lt;br /&gt;
#define PINC4   4&lt;br /&gt;
#define PINC3   3&lt;br /&gt;
#define PINC2   2&lt;br /&gt;
#define PINC1   1&lt;br /&gt;
#define PINC0   0&lt;br /&gt;
== Ausgänge ==&lt;br /&gt;
Mit dem Befehl&lt;br /&gt;
    // Uebersichtliche Alternative - Binaerschreibweise&lt;br /&gt;
    PORTB = 0b00000100;    /* direkte Zuweisung - uebersichtlich */&lt;br /&gt;
    PORTB &amp;amp;= ~(1&amp;lt;&amp;lt;PB2); /* loescht Bit 2 in PORTB und setzt damit Pin PB2 auf low */ &lt;br /&gt;
Siehe auch [[Bitmanipulation]]&lt;br /&gt;
&#039;&#039;Falls der Anfangszustand von Ausgängen kritisch ist, muss die Reihenfolge beachtet werden, mit der die Datenrichtung (DDRx) eingestellt und der Ausgabewert (PORTx) gesetzt wird:&#039;&#039;&lt;br /&gt;
Für Ausgangspins, die mit Anfangswert &amp;quot;high&amp;quot; initialisiert werden sollen:&lt;br /&gt;
* zuerst die Bits im PORTx-Register setzen&lt;br /&gt;
* anschließend die Datenrichtung auf Ausgang stellen&lt;br /&gt;
Daraus ergibt sich die Abfolge für einen Pin, der bisher als Eingang mit abgeschaltetem Pull-Up konfiguriert war:&lt;br /&gt;
* setze PORTx: interner Pull-Up aktiv&lt;br /&gt;
* setze DDRx: Ausgang (&amp;quot;high&amp;quot;)&lt;br /&gt;
Bei der Reihenfolge erst DDRx und dann PORTx kann es zu einem kurzen &amp;quot;low-Puls&amp;quot; kommen, der auch externe Pull-Up-Widerstände &amp;quot;überstimmt&amp;quot;. Die (ungünstige) Abfolge: Eingang -&amp;gt; setze DDRx: Ausgang (auf &amp;quot;low&amp;quot;, da PORTx nach Reset 0) -&amp;gt; setze PORTx: Ausgang auf high. Vergleiche dazu auch das Datenblatt Abschnitt &#039;&#039;Configuring the Pin&#039;&#039;.&lt;br /&gt;
Hat der Ausgang der anderen Schaltung keinen TTL-Pegel so müssen wir den Pegel über entsprechende Hardware (z.&amp;amp;nbsp;B. Optokoppler, [[Widerstand#Spannungsteiler|Spannungsteiler]], &amp;quot;Levelshifter&amp;quot; aka [[Pegelwandler]]) anpassen.&lt;br /&gt;
{| class=&amp;quot;wikitable&amp;quot; style=&amp;quot;text-align:center; width:20em&amp;quot;&lt;br /&gt;
|+ &#039;&#039;&#039;Logikpegel&#039;&#039;&#039;&lt;br /&gt;
! VCC [V]&lt;br /&gt;
! Low [V]&lt;br /&gt;
! High [V]&lt;br /&gt;
! 5&lt;br /&gt;
| 1,0 || 3,5&lt;br /&gt;
! 3,3&lt;br /&gt;
| 0,66 || 2,3&lt;br /&gt;
! 1,8&lt;br /&gt;
| 0,36 || 1,26 &lt;br /&gt;
{{Warnung|Dabei ist wichtig, zur Abfrage der Eingänge &#039;&#039;nicht&#039;&#039; etwa Portregister &#039;&#039;&#039;PORTx&#039;&#039;&#039; zu verwenden, sondern Eingangsregister &#039;&#039;&#039;PINx&#039;&#039;&#039;. Ansonsten liest man nicht den Zustand der Eingänge, sondern den Status der internen Pull-Up-Widerstände. Die Abfrage der Pinzustände über PORTx statt PINx ist ein häufiger Fehler beim AVR-&amp;quot;Erstkontakt&amp;quot;.}}&lt;br /&gt;
uint8_t bPortD;&lt;br /&gt;
bPortD = PIND;&lt;br /&gt;
  /* Aktion */&lt;br /&gt;
Siehe auch [[Bitmanipulation#Bits_prüfen]]&lt;br /&gt;
=== Interne Pull-Up Widerstände ===&lt;br /&gt;
Portpins für Ein- und Ausgänge (GPIO) eines AVR verfügen über zuschaltbare interne Pull-Up Widerstände (nominal mehrere 10kOhm, z.&amp;amp;nbsp;B. ATmega16 20-50kOhm). Diese können in vielen Fällen statt externer Widerstände genutzt werden.&lt;br /&gt;
DDRC  &amp;amp;= ~(1&amp;lt;&amp;lt;PC7);  /* Pin PC7 als Eingang */&lt;br /&gt;
=== Taster und Schalter ===&lt;br /&gt;
Der Anschluss mechanischer Kontakte an den Mikrocontroller, ist zwischen zwei unterschiedliche Methoden zu unterscheiden: &#039;&#039;Active Low&#039;&#039; und &#039;&#039;Active High&#039;&#039;.&lt;br /&gt;
&amp;lt;gallery widths=&amp;quot;300&amp;quot; heights=&amp;quot;300&amp;quot; caption=&amp;quot;Anschluss mechanischer Kontakte an einen µC&amp;quot;&amp;gt;&lt;br /&gt;
Image:Active Low.gif|&#039;&#039;&#039;Active Low:&#039;&#039;&#039; Bei dieser Methode wird der Kontakt zwischen den Eingangspin des Controllers und Masse geschaltet. Damit bei offenem Schalter der Controller kein undefiniertes Signal bekommt, wird zwischen die Versorgungsspannung und den Eingangspin ein sogenannter &#039;&#039;&#039;Pull-Up&#039;&#039;&#039; Widerstand geschaltet. Dieser dient dazu, den Pegel bei geöffnetem Schalter auf logisch 1 zu ziehen.&lt;br /&gt;
Image:Active High.gif|&#039;&#039;&#039;Active High:&#039;&#039;&#039; Hier wird der Kontakt zwischen die Versorgungsspannung und den Eingangspin geschaltet. Damit bei offener Schalterstellung kein undefiniertes Signal am Controller ansteht, wird zwischen den Eingangspin und die Masse ein &#039;&#039;&#039;Pull-Down&#039;&#039;&#039; Widerstand geschaltet. Dieser dient dazu, den Pegel bei geöffneter Schalterstellung auf logisch 0 zu halten. &lt;br /&gt;
Der Widerstandswert von Pull-Up- und Pull-Down-Widerständen ist an sich nicht kritisch. Wird er allerdings zu hoch gewählt, ist die Wirkung eventuell nicht gegeben. Als üblicher Wert haben sich 10 kOhm eingebürgert. Die AVRs verfügen an den meisten Pins über zuschaltbare interne Pull-Up Widerstände (vgl. Abschnitt [[AVR-GCC-Tutorial#Interne Pull-Up Widerstände|Interne Pull-Up Widerstände]]), welche insbesondere wie hier bei Tastern und ähnlichen Bauteilen (z.&amp;amp;nbsp;B. Drehgebern) statt externer Bauteile verwendet werden können. Interne Pull-Down-Widerstand sind nicht verfügbar und müssen daher in Form zusätzlicher Bauteile in die Schaltung eingefügt werden.&lt;br /&gt;
==== Taster entprellen ====&lt;br /&gt;
Siehe: &#039;&#039;[[Entprellung#Warteschleifen-Verfahren|Entprellung: Warteschleifen-Verfahren]]&lt;br /&gt;
Der einfachste Fall, das Zeitvertrödeln, kann in vielen Fällen und mit großer Genauigkeit anhand der avr-libc Bibliotheksfunktionen _delay_ms() und _delay_us() erledigt werden. Die Bibliotheksfunktionen sind einfachen Zählschleifen (Warteschleifen) vorzuziehen, da leere Zählschleifen ohne besondere Vorkehrungen sonst bei eingeschalteter Optimierung vom avr-gcc-Compiler wegoptimiert werden. Weiterhin sind die Bibliotheksfunktionen bereits darauf vorbereitet, die in F_CPU definierte Taktfrequenz zu verwenden. Außerdem sind die Funktionen der Bibliothek wirklich getestet.&lt;br /&gt;
Einfach!? Schon, aber während gewartet wird, macht der µC nichts anderes mehr (abgesehen von möglicherweise auftretenden Interrupts, falls welche aktiviert sind). Die Wartefunktion blockiert den Programmablauf. Möchte man einerseits warten, um z.&amp;amp;nbsp;B. eine LED blinken zu lassen und gleichzeitig andere Aktionen ausführen z.&amp;amp;nbsp;B. weitere LED bedienen, sollten die Timer/Counter des AVR verwendet werden, siehe Artikel [[Multitasking]].&lt;br /&gt;
Die Bibliotheksfunktionen funktionieren allerdings nur dann korrekt, wenn sie mit zur Übersetzungszeit (beim Compilieren) bekannten konstanten Werten aufgerufen werden. Der Quellcode muss mit eingeschalteter Optimierung übersetzt werden, sonst wird sehr viel Maschinencode erzeugt, und die Wartezeiten stimmen nicht mehr mit dem Parameter überein.&lt;br /&gt;
Eine weitere Einschränkung liegt darin, daß sie möglicherweise länger warten, als erwartet, nämlich in dem Fall, daß Interrupts auftreten und die _delay...()-Funktion unterbrechen. Genau genommen warten diese nämlich nicht eine bestimmte Zeit, sondern verbrauchen eine bestimmte Anzahl von Prozessortakten. Die wiederum ist so bemessen, daß ohne Unterbrechung durch Interrupts die gewünschte Wartezeit erreicht wird.&lt;br /&gt;
Wird das Warten aber durch eine oder mehrere ISR unterbrochen, die zusammen 1% Prozessorzeit verbrauchen, dann dauert das Warten etwa 1% länger. Bei 50% Last durch die ISR dauert das Warten doppelt solange wie gewünscht, bei 90% zehnmal solange...&lt;br /&gt;
Abhängig von der Version der Bibliothek verhalten sich die Bibliotheksfunktionen etwas unterschiedlich.&lt;br /&gt;
== avr-libc Versionen bis 1.6 ==&lt;br /&gt;
Die Wartezeit der Funktion _delay_ms() ist auf 262,14ms/F_CPU (in MHz) begrenzt, d.h. bei 20 MHz kann man nur max. 13,1ms warten. Die Wartezeit der Funktion _delay_us() ist auf 768us/F_CPU (in MHz) begrenzt, d.h. bei 20 MHz kann man nur max. 38,4µs warten. Längere Wartezeiten müssen dann über einen mehrfachen Aufruf in einer Schleife gelöst werden.&lt;br /&gt;
/* Definiere F_CPU, wenn F_CPU nicht bereits vorher definiert &lt;br /&gt;
   (z.&amp;amp;nbsp;B. durch Übergabe als Parameter zum Compiler innerhalb &lt;br /&gt;
   des Makefiles). Zusätzlich Ausgabe einer Warnung, die auf die&lt;br /&gt;
   &amp;quot;nachträgliche&amp;quot; Definition hinweist */&lt;br /&gt;
#define F_CPU 3686400UL     /* Quarz mit 3.6864 Mhz */&lt;br /&gt;
 lange, variable Verzögerungszeit, Einheit in Millisekunden&lt;br /&gt;
Prüfung der Schleifenbedingung lässt die Wartezeit geringfügig&lt;br /&gt;
ungenau werden (macht hier vielleicht 2-3ms aus).&lt;br /&gt;
void long_delay(uint16_t ms)&lt;br /&gt;
    for(; ms&amp;gt;0; ms--) _delay_ms(1);&lt;br /&gt;
    DDRB = ( 1 &amp;lt;&amp;lt; PB0 );        // PB0 an PORTB als Ausgang setzen&lt;br /&gt;
    while( 1 )                  // Endlosschleife&lt;br /&gt;
    {                &lt;br /&gt;
        PORTB ^= ( 1 &amp;lt;&amp;lt; PB0 );  // Toggle PB0 z.&amp;amp;nbsp;B. angeschlossene LED&lt;br /&gt;
        long_delay(1000);       // Eine Sekunde warten...&lt;br /&gt;
== avr-libc Versionen ab 1.7 ==&lt;br /&gt;
_delay_ms() kann mit einem Argument bis 6553,5 ms (= 6,5535 Sekunden) benutzt werden. Es ist nicht möglich, eine Variable als Argument zu übergeben. Wird die früher gültige Grenze von 262,14 ms/F_CPU (in MHz) überschritten, so arbeitet _delay_ms() einfach etwas ungenauer und zählt nur noch mit einer Auflösung von 1/10 ms. Eine Verzögerung von 1000,10 ms ließe sich nicht mehr von einer von 1000,19 ms unterscheiden. Ein Verlust, der sich im Allgemeinen verschmerzen lässt. Dem Programmierer wird keine Rückmeldung gegeben, dass die Funktion ggf. gröber arbeitet, d.h. wenn es darauf ankommt, bitte den Parameter wie bisher geschickt wählen.&lt;br /&gt;
Die Funktion _delay_us() wurde ebenfalls erweitert. Wenn deren maximal als genau behandelbares Argument überschritten wird, benutzt diese intern _delay_ms(). Damit gelten in diesem Fall die _delay_ms() Einschränkungen.&lt;br /&gt;
Beispiel: Blinken einer LED an PORTB Pin PB0 im ca. 1s Rhythmus, avr-libc ab Version 1.6&lt;br /&gt;
   (z.B. durch Übergabe als Parameter zum Compiler innerhalb &lt;br /&gt;
    while( 1 ) {                // Endlosschleife&lt;br /&gt;
        PORTB ^= ( 1 &amp;lt;&amp;lt; PB0 );  // Toggle PB0 z.B. angeschlossene LED&lt;br /&gt;
        _delay_ms(1000);        // Eine Sekunde +/-1/10000 Sekunde warten...&lt;br /&gt;
                                // funktioniert nicht mit Bibliotheken vor 1.6&lt;br /&gt;
Die _delay_ms() und die _delay_us aus &#039;&#039;&#039;avr-libc 1.7.0&#039;&#039;&#039; sind fehlerhaft. _delay_ms () läuft 4x schneller als erwartet. Abhilfe ist eine korrigierte Includedatei: [http://www.mikrocontroller.net/topic/196738#1943039]&lt;br /&gt;
&amp;lt;div style=&amp;quot;float:right; margin:2em;&amp;quot;&amp;gt;&lt;br /&gt;
Tritt ein Interrupt auf, unterbricht (engl. interrupts) der Controller die Verarbeitung des Hauptprogramms und verzweigt zu einer Interruptroutine. Das Hauptprogramm wird also beim Eintreffen eines Interrupts unterbrochen, die Interruptroutine ausgeführt und danach erst wieder das Hauptprogramm an der Unterbrechungsstelle fortgesetzt (vgl. die Abbildung).&lt;br /&gt;
Um Interrupts verarbeiten zu können, ist folgendes zu beachten:&lt;br /&gt;
* Für jede aktivierte Interruptquelle ist eine Funktion zu programmieren, in der die beim Auftreten des jeweiligen Interrupts erforderlichen Verarbeitungsschritte enthalten sind. Für diese Funktion existieren verschiedene Bezeichnungen. Üblich sind die englischen Begriffe Interrupt-Handler oder Interrupt-Service-Routinen (ISR), man findet aber auch die Bezeichnungen Interruptverarbeitungs- oder -behandlungsroutine oder auch kurz Interruptroutine. Zum Beispiel wird üblicherweise in der ISR zur Verarbeitung des Empfangsinterrupts eines UARTs (UART-RX Interrupt) das empfangene Zeichen in einen Zwischenspeicher (FIFO-Buffer) kopiert, dessen Inhalt später von anderen Programmteilen geleert wird. Sofern der Zwischenspeicher ausreichend groß ist, geht also kein Zeichen verloren, auch wenn im Hauptprogramm zeitintensive Operationen durchgeführt werden.&lt;br /&gt;
* Die benötigten Interrupts sind in den jeweiligen Funktionsbausteinen einzuschalten. Dies erfolgt über das jeweilige Aktivierungsbit (Interrupt Enable) in einem der Hardwareregister (z.B. RX(Complete)Interrupt Enable eines UARTs)&lt;br /&gt;
* Sämtliche Interrupts werden über einen weiteren globalen Schalter aktiviert und deaktiviert. Zur Verarbeitung der Interrupts ist dieser Schalter zu aktivieren (sei(), siehe unten).&lt;br /&gt;
Alle Punkte sind zu beachten. Fehlt z.B. die globale Aktivierung, werden Interruptroutinen auch dann nicht aufgerufen, wenn sie im Funktionsbaustein eingeschaltet sind und eine Behandlungsroutine verhanden ist.&lt;br /&gt;
Siehe auch&lt;br /&gt;
* [http://www.mikrocontroller.net/forum/read-1-235092.html#new Ausführlicher Thread im Forum]&lt;br /&gt;
* Artikel [[Interrupt]]&lt;br /&gt;
* Artikel [[Multitasking]]&lt;br /&gt;
Um unliebsamen Überraschungen vorzubeugen, sollten einige Grundregeln bei der Implementierung der Interruptroutinen beachtet werden. Interruptroutinen sollten möglichst kurz und schnell abarbeitbar sein, daraus folgt:&lt;br /&gt;
(*)&lt;br /&gt;
Hinweis: &lt;br /&gt;
* Reset&lt;br /&gt;
Die Anzahl der möglichen Interruptquellen variiert zwischen den verschiedenen Microcontroller-Typen. Im Zweifel hilft ein Blick ins Datenblatt (&amp;quot;Interrupt Vectors&amp;quot;).&lt;br /&gt;
== Register ==&lt;br /&gt;
Interrupts zusammenhängen.&lt;br /&gt;
!width=&amp;quot;10%&amp;quot;| GIMSK&lt;br /&gt;
| &#039;&#039;&#039;G&#039;&#039;&#039;eneral &#039;&#039;&#039;I&#039;&#039;&#039;nterrupt &#039;&#039;&#039;M&#039;&#039;&#039;a&#039;&#039;&#039;sk&#039;&#039;&#039; Register.&amp;lt;br /&amp;gt;&lt;br /&gt;
! Bit &lt;br /&gt;
| 7 || 6|| 5 || 4 || 3 || 2 || 1 || 0&lt;br /&gt;
! Name&lt;br /&gt;
| &#039;&#039;&#039;INT1&#039;&#039;&#039; || &#039;&#039;&#039;INT0&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039;&lt;br /&gt;
! R/W&lt;br /&gt;
| R/W || R/W || R || R || R || R || R || R&lt;br /&gt;
! Initialwert&lt;br /&gt;
! GIFR&lt;br /&gt;
! Bit&lt;br /&gt;
! Name&lt;br /&gt;
| &#039;&#039;&#039;INTF1&#039;&#039;&#039; || &#039;&#039;&#039;INTF0&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039; || &#039;&#039;&#039;-&#039;&#039;&#039;&lt;br /&gt;
! R/W&lt;br /&gt;
:Dieses Bit wird gesetzt, wenn am &#039;&#039;&#039;INT1&#039;&#039;&#039;-Pin eine Interrupt-Bedingung, entsprechend der Konfiguration, als eingetreten erkannt wird. Wenn das Global Enable Interrupt Flag gesetzt ist, wird die Interruptroutine angesprungen.&lt;br /&gt;
:Dieses Bit wird gesetzt, wenn am &#039;&#039;&#039;INT0&#039;&#039;&#039;-Pin eine Interrupt-Bedingung, entsprechend der Konfiguration, als eingetreten erkannt wird. Wenn das Global Enable Interrupt Flag gesetzt ist, wird die Interruptroutine angesprungen.&lt;br /&gt;
! MCUCR&lt;br /&gt;
Das MCU Control Register enthält Kontrollbits für allgemeine MCU-Funktionen.&lt;br /&gt;
! Bit&lt;br /&gt;
! Name&lt;br /&gt;
| &#039;&#039;&#039;-&#039;&#039;&#039;|| &#039;&#039;&#039;-&#039;&#039;&#039;|| &#039;&#039;&#039;SE&#039;&#039;&#039;|| &#039;&#039;&#039;SM&#039;&#039;&#039;|| &#039;&#039;&#039;ISC11&#039;&#039;&#039;|| &#039;&#039;&#039;ISC10&#039;&#039;&#039;|| &#039;&#039;&#039;ISC01&#039;&#039;&#039;|| &#039;&#039;&#039;ISC00&#039;&#039;&#039;&lt;br /&gt;
! R/W&lt;br /&gt;
| R || R || R/W || R/W || R/W || R/W || R/W || R/W&lt;br /&gt;
:Dieses Bit bestimmt über den Schlafmodus.&lt;br /&gt;
:{| class=&amp;quot;wikitable&amp;quot;&lt;br /&gt;
!width=&amp;quot;10%&amp;quot;| ISC11 ||width=&amp;quot;10%&amp;quot;| ISC10 || Bedeutung&lt;br /&gt;
Der Interrupt wird getriggert, solange der Pin auf 0 bleibt.&lt;br /&gt;
| Reserviert&lt;br /&gt;
!width=&amp;quot;10%&amp;quot;| ISC01 ||width=&amp;quot;10%&amp;quot;| ISC00 || Bedeutung&lt;br /&gt;
Wenn ein Interrupt eintrifft, wird automatisch das &#039;&#039;&#039;Global Interrupt Enable&#039;&#039;&#039; Bit im Status Register &#039;&#039;&#039;SREG&#039;&#039;&#039; gelöscht und alle weiteren Interrupts unterbunden. Dieses wird automatisch wieder gesetzt, wenn die Interruptroutine beendet wird. Wenn in der Zwischenzeit weitere Interrupts eintreffen, werden die zugehörigen Interrupt-Bits gesetzt und die Interrupts bei Beendigung der laufenden Interrupt-Routine in der Reihenfolge ihrer Priorität ausgeführt. Dies kann&lt;br /&gt;
eigentlich nur dann zu Problemen führen, wenn ein hoch priorisierter Interrupt ständig und in kurzer Folge auftritt. Dieser sperrt dann möglicherweise alle anderen Interrupts mit niedrigerer Priorität. Dies ist einer der Gründe, weshalb die Interrupt-Routinen sehr kurz gehalten werden sollen.  Es ist möglich das GIE-Bit in der ISR zu setzen und so schon wieder weitere Interrupts zuzulassen - allerdings sollte man damit vorsichtig sein und genau wissen was man damit macht. Kritisch wird es vor allem wenn der gleiche Interrupt noch einmal kommt, bevor die ISR abgearbeitet ist. &lt;br /&gt;
== Interrupts mit avr-gcc ==&lt;br /&gt;
&amp;lt;!-- &#039;&#039;Anmerkung eines Nutzers: Ich habe mir das Thema hier angearbeitet und hatte am Anfang starke Probleme: Jeder Interrupt muss nochmals einzeln aktiviert werden. Es reicht nicht nur per &#039;&#039;sei()&#039;&#039; die Interrupts global zu aktiveren.&#039;&#039; - mthomas: Hoffentlich duch die modifizerte Einleitung etwas offensichtlicher erläutert. Ansonsten bitte per Eintrag auf die Diskussionseite nochmals melden) --&amp;gt; &lt;br /&gt;
    cli();&lt;br /&gt;
Oft steht man vor der Aufgabe, dass eine Codesequenz nicht unterbrochen werden darf. Es liegt dann nahe, zu Beginn dieser Sequenz ein cli() und am Ende ein sei() einzufügen. Dies ist jedoch ungünstig, wenn die Interrupts vor Aufruf der Sequenz deaktiviert waren und danach auch weiterhin deaktiviert bleiben sollen. Ein sei() würde ungeachtet des vorherigen  Zustands die Interrupts aktivieren, was zu unerwünschten Seiteneffekten führen kann. Die aus dem folgenden Beispiel ersichtliche Vorgehensweise ist in solchen Fällen vorzuziehen:&lt;br /&gt;
//...&lt;br /&gt;
   cli();&lt;br /&gt;
   //...&lt;br /&gt;
   cli();  &lt;br /&gt;
   //...&lt;br /&gt;
   cli();  &lt;br /&gt;
   NichtSoGut();&lt;br /&gt;
   //...&lt;br /&gt;
Nachdem nun die Interrupts aktiviert sind, braucht es selbstverständlich noch den auszuführenden Code, der ablaufen soll, wenn ein Interrupt eintrifft.&lt;br /&gt;
Zu den aktivierten Interrupts ist eine Funktion zu programmieren, deren Code aufgerufen wird, wenn der betreffende Interrupt auftritt (Interrupt-Handler, Interrupt-Service-Routine). Dazu existiert die Definition (ein Makro) &#039;&#039;&#039;ISR&#039;&#039;&#039;.&lt;br /&gt;
=== ISR ===&lt;br /&gt;
(&#039;&#039;ISR()&#039;&#039; ersetzt bei neueren Versionen der avr-libc &#039;&#039;SIGNAL()&#039;&#039;. SIGNAL sollte nicht mehr genutzt werden, zur Portierung von SIGNAL nach ISR siehe den [[AVR-GCC-Tutorial#Anhang|Anhang]].)&lt;br /&gt;
//...&lt;br /&gt;
//...&lt;br /&gt;
/* avr/iom8.h  - definitions for ATmega8 */&lt;br /&gt;
//...&lt;br /&gt;
//...&lt;br /&gt;
&amp;qu
