response: 82 87 75 ->GDB: 8775 GDB: GDB: Read 2 bytes from 0xFC jtagRead command[0x05, 1]: 05 A0 02 00 00 00 FC 00 00 00 recv: 0x1b recv: 0x36 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 8c 93 recv: 0xfa recv: 0x4b CRC OK Got message seqno 54 (command_sequence == 54) response: 82 8C 93 ->GDB: 8c93 GDB: GDB: Read 2 bytes from 0xFE jtagRead command[0x05, 1]: 05 A0 02 00 00 00 FE 00 00 00 recv: 0x1b recv: 0x37 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 00 00 recv: 0xa3 recv: 0xe4 CRC OK Got message seqno 55 (command_sequence == 55) response: 82 00 00 ->GDB: 0000 GDB: GDB: Read 2 bytes from 0x100 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 00 01 00 00 recv: 0x1b recv: 0x38 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 89 81 recv: 0x2a recv: 0x87 CRC OK Got message seqno 56 (command_sequence == 56) response: 82 89 81 ->GDB: 8981 GDB: GDB: Read 2 bytes from 0x102 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 02 01 00 00 recv: 0x1b recv: 0x39 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 8f 5f recv: 0x2e recv: 0xc0 CRC OK Got message seqno 57 (command_sequence == 57) response: 82 8F 5F ->GDB: 8f5f GDB: GDB: Read 2 bytes from 0x104 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 04 01 00 00 recv: 0x1b recv: 0x3a recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 89 83 recv: 0x76 recv: 0xfc CRC OK Got message seqno 58 (command_sequence == 58) response: 82 89 83 ->GDB: 8983 GDB: GDB: Read 2 bytes from 0x106 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 06 01 00 00 recv: 0x1b recv: 0x3b recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ec cf recv: 0xd4 recv: 0x43 CRC OK Got message seqno 59 (command_sequence == 59) response: 82 EC CF ->GDB: eccf GDB: GDB: Read 1 bytes from 0x8010FE jtagRead command[0x05, 1]: 05 20 01 00 00 00 FE 10 00 00 recv: 0x1b recv: 0x3c recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0xcb recv: 0x83 CRC OK Got message seqno 60 (command_sequence == 60) response: 82 00 ->GDB: 00 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x3d recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x27 recv: 0x55 CRC OK Got message seqno 61 (command_sequence == 61) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 64 00 00 00 00 recv: 0xed recv: 0xa1 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x3e recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 64 00 00 00 recv: 0x46 recv: 0x93 CRC OK Got message seqno 62 (command_sequence == 62) response: 84 64 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x3f recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 64 00 00 00 recv: 0x13 recv: 0x16 CRC OK Got message seqno 63 (command_sequence == 63) response: 84 64 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x40 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fc 10 02 recv: 0xaf recv: 0x1f CRC OK Got message seqno 64 (command_sequence == 64) response: 82 FC 10 02 ->GDB: T0520:02;21:fc10;22:c8000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x41 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x3c recv: 0xe6 CRC OK Got message seqno 65 (command_sequence == 65) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 65 00 00 00 00 recv: 0xa9 recv: 0xaa CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x42 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 65 00 00 00 recv: 0x6f recv: 0xe9 CRC OK Got message seqno 66 (command_sequence == 66) response: 84 65 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x43 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 65 00 00 00 recv: 0x3a recv: 0x6c CRC OK Got message seqno 67 (command_sequence == 67) response: 84 65 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x44 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fb 10 02 recv: 0xff recv: 0xcd CRC OK Got message seqno 68 (command_sequence == 68) response: 82 FB 10 02 ->GDB: T0520:02;21:fb10;22:ca000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x45 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xe2 recv: 0xf0 CRC OK Got message seqno 69 (command_sequence == 69) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 66 00 00 00 00 recv: 0x65 recv: 0xb7 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x46 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 66 00 00 00 recv: 0xd4 recv: 0xc9 CRC OK Got message seqno 70 (command_sequence == 70) response: 84 66 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x47 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 66 00 00 00 recv: 0x81 recv: 0x4c CRC OK Got message seqno 71 (command_sequence == 71) response: 84 66 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x48 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xdc recv: 0x75 CRC OK Got message seqno 72 (command_sequence == 72) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:cc000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x49 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x80 recv: 0xcb CRC OK Got message seqno 73 (command_sequence == 73) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 67 00 00 00 00 recv: 0x21 recv: 0xbc CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x4a recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 67 00 00 00 recv: 0xf5 recv: 0xda CRC OK Got message seqno 74 (command_sequence == 74) response: 84 67 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x4b recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 67 00 00 00 recv: 0xa0 recv: 0x5f CRC OK Got message seqno 75 (command_sequence == 75) response: 84 67 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x4c recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x89 recv: 0x2b CRC OK Got message seqno 76 (command_sequence == 76) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:ce000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x4d recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x5e recv: 0xdd CRC OK Got message seqno 77 (command_sequence == 77) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 68 00 00 00 00 recv: 0xdd recv: 0xd6 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x4e recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 68 00 00 00 recv: 0x7a recv: 0x6d CRC OK Got message seqno 78 (command_sequence == 78) response: 84 68 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x4f recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 68 00 00 00 recv: 0x2f recv: 0xe8 CRC OK Got message seqno 79 (command_sequence == 79) response: 84 68 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x50 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x33 recv: 0xb8 CRC OK Got message seqno 80 (command_sequence == 80) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:d0000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x51 recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x53 recv: 0x92 CRC OK Got message seqno 81 (command_sequence == 81) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x52 recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0x06 recv: 0xca CRC OK Got message seqno 82 (command_sequence == 82) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x53 recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0xb9 recv: 0x04 CRC OK Got message seqno 83 (command_sequence == 83) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x54 recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 d3 00 00 01 fa 10 0c 01 recv: 0x9d recv: 0x18 CRC OK Got message seqno 84 (command_sequence == 84) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 D3 00 00 01 FA 10 0C 01 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x55 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xf7 recv: 0xb3 CRC OK Got message seqno 85 (command_sequence == 85) response: 82 FA 10 02 command[0x07, 1]: 07 recv: 0x1b recv: 0x56 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 68 00 00 00 recv: 0x4e recv: 0x72 CRC OK Got message seqno 86 (command_sequence == 86) response: 84 68 00 00 00 PC = d0 ->GDB: 000000000000000000000000000000000001000000000000d3000001fa100c0102fa10d0000000 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x57 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xf5 recv: 0xa0 CRC OK Got message seqno 87 (command_sequence == 87) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 69 00 00 00 00 recv: 0x99 recv: 0xdd CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x58 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 69 00 00 00 recv: 0xd4 recv: 0x63 CRC OK Got message seqno 88 (command_sequence == 88) response: 84 69 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x59 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 69 00 00 00 recv: 0x81 recv: 0xe6 CRC OK Got message seqno 89 (command_sequence == 89) response: 84 69 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x5a recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xbb recv: 0xaf CRC OK Got message seqno 90 (command_sequence == 90) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:d2000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x5b recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x97 recv: 0x9b CRC OK Got message seqno 91 (command_sequence == 91) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6a 00 00 00 00 recv: 0x55 recv: 0xc0 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x5c recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6a 00 00 00 recv: 0x6f recv: 0x43 CRC OK Got message seqno 92 (command_sequence == 92) response: 84 6A 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x5d recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6a 00 00 00 recv: 0x3a recv: 0xc6 CRC OK Got message seqno 93 (command_sequence == 93) response: 84 6A 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x5e recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xee recv: 0xf1 CRC OK Got message seqno 94 (command_sequence == 94) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:d4000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x5f recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x49 recv: 0x8d CRC OK Got message seqno 95 (command_sequence == 95) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6b 00 00 00 00 recv: 0x11 recv: 0xcb CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x60 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6b 00 00 00 recv: 0x26 recv: 0x6e CRC OK Got message seqno 96 (command_sequence == 96) response: 84 6B 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x61 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6b 00 00 00 recv: 0x73 recv: 0xeb CRC OK Got message seqno 97 (command_sequence == 97) response: 84 6B 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x62 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xde recv: 0x80 CRC OK Got message seqno 98 (command_sequence == 98) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:d6000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x63 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xa3 recv: 0x5b CRC OK Got message seqno 99 (command_sequence == 99) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6c 00 00 00 00 recv: 0xcd recv: 0xfb CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x64 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6c 00 00 00 recv: 0x71 recv: 0x3c CRC OK Got message seqno 100 (command_sequence == 100) response: 84 6C 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x65 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6c 00 00 00 recv: 0x24 recv: 0xb9 CRC OK Got message seqno 101 (command_sequence == 101) response: 84 6C 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x66 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x8b recv: 0xde CRC OK Got message seqno 102 (command_sequence == 102) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:d8000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x67 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x7d recv: 0x4d CRC OK Got message seqno 103 (command_sequence == 103) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6d 00 00 00 00 recv: 0x89 recv: 0xf0 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x68 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6d 00 00 00 recv: 0x50 recv: 0x2f CRC OK Got message seqno 104 (command_sequence == 104) response: 84 6D 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x69 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6d 00 00 00 recv: 0x05 recv: 0xaa CRC OK Got message seqno 105 (command_sequence == 105) response: 84 6D 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x6a recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x74 recv: 0x3c CRC OK Got message seqno 106 (command_sequence == 106) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:da000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x6b recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x1f recv: 0x76 CRC OK Got message seqno 107 (command_sequence == 107) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6e 00 00 00 00 recv: 0x45 recv: 0xed CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x6c recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6e 00 00 00 recv: 0xeb recv: 0x0f CRC OK Got message seqno 108 (command_sequence == 108) response: 84 6E 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x6d recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6e 00 00 00 recv: 0xbe recv: 0x8a CRC OK Got message seqno 109 (command_sequence == 109) response: 84 6E 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x6e recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x96 recv: 0x17 CRC OK Got message seqno 110 (command_sequence == 110) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:dc000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x6f recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xc1 recv: 0x60 CRC OK Got message seqno 111 (command_sequence == 111) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 6f 00 00 00 00 recv: 0x01 recv: 0xe6 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x70 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6f 00 00 00 recv: 0x12 recv: 0x09 CRC OK Got message seqno 112 (command_sequence == 112) response: 84 6F 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x71 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6f 00 00 00 recv: 0x47 recv: 0x8c CRC OK Got message seqno 113 (command_sequence == 113) response: 84 6F 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x72 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x2c recv: 0x84 CRC OK Got message seqno 114 (command_sequence == 114) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:de000000; GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x73 recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x7e recv: 0xef CRC OK Got message seqno 115 (command_sequence == 115) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x74 recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0xd3 recv: 0x4d CRC OK Got message seqno 116 (command_sequence == 116) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x75 recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0x9f recv: 0x57 CRC OK Got message seqno 117 (command_sequence == 117) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x76 recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 a8 00 21 00 fa 10 21 00 recv: 0x60 recv: 0xec CRC OK Got message seqno 118 (command_sequence == 118) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 A8 00 21 00 FA 10 21 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x77 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xe8 recv: 0x8f CRC OK Got message seqno 119 (command_sequence == 119) response: 82 FA 10 14 command[0x07, 1]: 07 recv: 0x1b recv: 0x78 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 6f 00 00 00 recv: 0xfe recv: 0x03 CRC OK Got message seqno 120 (command_sequence == 120) response: 84 6F 00 00 00 PC = de ->GDB: 000000000000000000000000000000000001000000000000a8002100fa10210014fa10de000000 GDB: ->GDB: GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x79 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x08 recv: 0x26 CRC OK Got message seqno 121 (command_sequence == 121) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 70 00 00 00 00 recv: 0xbd recv: 0x38 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x7a recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0x1d recv: 0x70 CRC OK Got message seqno 122 (command_sequence == 122) response: 84 70 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x7b recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0x48 recv: 0xf5 CRC OK Got message seqno 123 (command_sequence == 123) response: 84 70 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x7c recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xf1 recv: 0xcd CRC OK Got message seqno 124 (command_sequence == 124) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:e0000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x7d recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x81 recv: 0x33 CRC OK Got message seqno 125 (command_sequence == 125) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x7e recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0xa3 recv: 0x70 CRC OK Got message seqno 126 (command_sequence == 126) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x7f recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0xaf recv: 0xb3 CRC OK Got message seqno 127 (command_sequence == 127) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x80 recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 a8 00 21 00 fa 10 21 00 recv: 0xc9 recv: 0x57 CRC OK Got message seqno 128 (command_sequence == 128) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 A8 00 21 00 FA 10 21 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x81 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x4e recv: 0xb6 CRC OK Got message seqno 129 (command_sequence == 129) response: 82 FA 10 14 command[0x07, 1]: 07 recv: 0x1b recv: 0x82 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0x39 recv: 0xbd CRC OK Got message seqno 130 (command_sequence == 130) response: 84 70 00 00 00 PC = e0 ->GDB: 000000000000000000000000000000000001000000000000a8002100fa10210014fa10e0000000 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: ->GDB: GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x83 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x40 recv: 0x43 CRC OK Got message seqno 131 (command_sequence == 131) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 71 00 00 00 00 recv: 0xf9 recv: 0x33 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x84 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 71 00 00 00 recv: 0x4f recv: 0xa6 CRC OK Got message seqno 132 (command_sequence == 132) response: 84 71 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x85 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 71 00 00 00 recv: 0x1a recv: 0x23 CRC OK Got message seqno 133 (command_sequence == 133) response: 84 71 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x86 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xa8 recv: 0x16 CRC OK Got message seqno 134 (command_sequence == 134) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:e2000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x87 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x9e recv: 0x55 CRC OK Got message seqno 135 (command_sequence == 135) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 72 00 00 00 00 recv: 0x35 recv: 0x2e CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x88 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 72 00 00 00 recv: 0x18 recv: 0x8c CRC OK Got message seqno 136 (command_sequence == 136) response: 84 72 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x89 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 72 00 00 00 recv: 0x4d recv: 0x09 CRC OK Got message seqno 137 (command_sequence == 137) response: 84 72 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x8a recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x57 recv: 0xf4 CRC OK Got message seqno 138 (command_sequence == 138) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:e4000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x8b recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xfc recv: 0x6e CRC OK Got message seqno 139 (command_sequence == 139) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 73 00 00 00 00 recv: 0x71 recv: 0x25 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x8c recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 73 00 00 00 recv: 0xd5 recv: 0x95 CRC OK Got message seqno 140 (command_sequence == 140) response: 84 73 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x8d recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 73 00 00 00 recv: 0x80 recv: 0x10 CRC OK Got message seqno 141 (command_sequence == 141) response: 84 73 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x8e recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x02 recv: 0xaa CRC OK Got message seqno 142 (command_sequence == 142) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:e6000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x8f recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x22 recv: 0x78 CRC OK Got message seqno 143 (command_sequence == 143) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 74 00 00 00 00 recv: 0xad recv: 0x15 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x90 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 74 00 00 00 recv: 0xb6 recv: 0xd8 CRC OK Got message seqno 144 (command_sequence == 144) response: 84 74 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x91 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 74 00 00 00 recv: 0xe3 recv: 0x5d CRC OK Got message seqno 145 (command_sequence == 145) response: 84 74 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x92 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xb8 recv: 0x39 CRC OK Got message seqno 146 (command_sequence == 146) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:e8000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x93 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x38 recv: 0x18 CRC OK Got message seqno 147 (command_sequence == 147) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 75 00 00 00 00 recv: 0xe9 recv: 0x1e CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x94 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 75 00 00 00 recv: 0x7b recv: 0xc1 CRC OK Got message seqno 148 (command_sequence == 148) response: 84 75 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x95 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 75 00 00 00 recv: 0x2e recv: 0x44 CRC OK Got message seqno 149 (command_sequence == 149) response: 84 75 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x96 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xed recv: 0x67 CRC OK Got message seqno 150 (command_sequence == 150) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:ea000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x97 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xe6 recv: 0x0e CRC OK Got message seqno 151 (command_sequence == 151) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 76 00 00 00 00 recv: 0x25 recv: 0x03 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x98 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 76 00 00 00 recv: 0x2c recv: 0xeb CRC OK Got message seqno 152 (command_sequence == 152) response: 84 76 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x99 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 76 00 00 00 recv: 0x79 recv: 0x6e CRC OK Got message seqno 153 (command_sequence == 153) response: 84 76 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x9a recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x12 recv: 0x85 CRC OK Got message seqno 154 (command_sequence == 154) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:ec000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x9b recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x84 recv: 0x35 CRC OK Got message seqno 155 (command_sequence == 155) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 77 00 00 00 00 recv: 0x61 recv: 0x08 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x9c recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0xe1 recv: 0xf2 CRC OK Got message seqno 156 (command_sequence == 156) response: 84 77 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x9d recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0xb4 recv: 0x77 CRC OK Got message seqno 157 (command_sequence == 157) response: 84 77 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x9e recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x47 recv: 0xdb CRC OK Got message seqno 158 (command_sequence == 158) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:ee000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x9f recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x58 recv: 0x0e CRC OK Got message seqno 159 (command_sequence == 159) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0xa0 recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0x1e recv: 0x45 CRC OK Got message seqno 160 (command_sequence == 160) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0xa1 recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0x5a recv: 0xb5 CRC OK Got message seqno 161 (command_sequence == 161) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0xa2 recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 a8 00 22 00 fa 10 22 00 recv: 0xf9 recv: 0xa2 CRC OK Got message seqno 162 (command_sequence == 162) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 A8 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xa3 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xe6 recv: 0xff CRC OK Got message seqno 163 (command_sequence == 163) response: 82 FA 10 14 command[0x07, 1]: 07 recv: 0x1b recv: 0xa4 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0x65 recv: 0xc6 CRC OK Got message seqno 164 (command_sequence == 164) response: 84 77 00 00 00 PC = ee ->GDB: 000000000000000000000000000000000001000000000000a8002200fa10220014fa10ee000000 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xa5 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x01 recv: 0xe8 CRC OK Got message seqno 165 (command_sequence == 165) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 78 00 00 00 00 recv: 0x9d recv: 0x62 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xa6 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 78 00 00 00 recv: 0x27 recv: 0x76 CRC OK Got message seqno 166 (command_sequence == 166) response: 84 78 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xa7 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 78 00 00 00 recv: 0x72 recv: 0xf3 CRC OK Got message seqno 167 (command_sequence == 167) response: 84 78 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xa8 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xff recv: 0xbd CRC OK Got message seqno 168 (command_sequence == 168) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:f0000000; GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0xa9 recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x68 recv: 0xb9 CRC OK Got message seqno 169 (command_sequence == 169) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0xaa recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0x6e recv: 0x78 CRC OK Got message seqno 170 (command_sequence == 170) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0xab recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0x6a recv: 0x51 CRC OK Got message seqno 171 (command_sequence == 171) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0xac recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 a8 00 22 00 fa 10 22 00 recv: 0xb5 recv: 0xf7 CRC OK Got message seqno 172 (command_sequence == 172) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 A8 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xad recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x3b recv: 0xb6 CRC OK Got message seqno 173 (command_sequence == 173) response: 82 FA 10 14 command[0x07, 1]: 07 recv: 0x1b recv: 0xae recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 78 00 00 00 recv: 0xcb recv: 0x7c CRC OK Got message seqno 174 (command_sequence == 174) response: 84 78 00 00 00 PC = f0 ->GDB: 000000000000000000000000000000000001000000000000a8002200fa10220014fa10f0000000 GDB: ->GDB: GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xaf recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xd2 recv: 0xce CRC OK Got message seqno 175 (command_sequence == 175) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 79 00 00 00 00 recv: 0xd9 recv: 0x69 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xb0 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 79 00 00 00 recv: 0x89 recv: 0x78 CRC OK Got message seqno 176 (command_sequence == 176) response: 84 79 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xb1 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 79 00 00 00 recv: 0xdc recv: 0xfd CRC OK Got message seqno 177 (command_sequence == 177) response: 84 79 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xb2 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x32 recv: 0xdb CRC OK Got message seqno 178 (command_sequence == 178) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:f2000000; GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: ->GDB: GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xb3 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xc8 recv: 0xae CRC OK Got message seqno 179 (command_sequence == 179) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7a 00 00 00 00 recv: 0x15 recv: 0x74 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xb4 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7a 00 00 00 recv: 0x32 recv: 0x58 CRC OK Got message seqno 180 (command_sequence == 180) response: 84 7A 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xb5 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7a 00 00 00 recv: 0x67 recv: 0xdd CRC OK Got message seqno 181 (command_sequence == 181) response: 84 7A 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xb6 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x67 recv: 0x85 CRC OK Got message seqno 182 (command_sequence == 182) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:f4000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xb7 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x16 recv: 0xb8 CRC OK Got message seqno 183 (command_sequence == 183) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7b 00 00 00 00 recv: 0x51 recv: 0x7f CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xb8 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7b 00 00 00 recv: 0x13 recv: 0x4b CRC OK Got message seqno 184 (command_sequence == 184) response: 84 7B 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xb9 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7b 00 00 00 recv: 0x46 recv: 0xce CRC OK Got message seqno 185 (command_sequence == 185) response: 84 7B 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xba recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0x98 recv: 0x67 CRC OK Got message seqno 186 (command_sequence == 186) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:f6000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xbb recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x74 recv: 0x83 CRC OK Got message seqno 187 (command_sequence == 187) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7c 00 00 00 00 recv: 0x8d recv: 0x4f CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xbc recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7c 00 00 00 recv: 0x44 recv: 0x19 CRC OK Got message seqno 188 (command_sequence == 188) response: 84 7C 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xbd recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7c 00 00 00 recv: 0x11 recv: 0x9c CRC OK Got message seqno 189 (command_sequence == 189) response: 84 7C 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xbe recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xcd recv: 0x39 CRC OK Got message seqno 190 (command_sequence == 190) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:f8000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xbf recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xaa recv: 0x95 CRC OK Got message seqno 191 (command_sequence == 191) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7d 00 00 00 00 recv: 0xc9 recv: 0x44 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xc0 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7d 00 00 00 recv: 0x6d recv: 0x63 CRC OK Got message seqno 192 (command_sequence == 192) response: 84 7D 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xc1 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7d 00 00 00 recv: 0x38 recv: 0xe6 CRC OK Got message seqno 193 (command_sequence == 193) response: 84 7D 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xc2 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 14 recv: 0xf8 recv: 0x85 CRC OK Got message seqno 194 (command_sequence == 194) response: 82 FA 10 14 ->GDB: T0520:14;21:fa10;22:fa000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xc3 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xb1 recv: 0x26 CRC OK Got message seqno 195 (command_sequence == 195) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7e 00 00 00 00 recv: 0x05 recv: 0x59 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xc4 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7e 00 00 00 recv: 0xd6 recv: 0x43 CRC OK Got message seqno 196 (command_sequence == 196) response: 84 7E 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xc5 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7e 00 00 00 recv: 0x83 recv: 0xc6 CRC OK Got message seqno 197 (command_sequence == 197) response: 84 7E 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xc6 recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x1a recv: 0xae CRC OK Got message seqno 198 (command_sequence == 198) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:fc000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0xc7 recv: 0x00 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x6f recv: 0x30 CRC OK Got message seqno 199 (command_sequence == 199) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 7f 00 00 00 00 recv: 0x41 recv: 0x52 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0xc8 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7f 00 00 00 recv: 0xf7 recv: 0x50 CRC OK Got message seqno 200 (command_sequence == 200) response: 84 7F 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0xc9 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7f 00 00 00 recv: 0xa2 recv: 0xd5 CRC OK Got message seqno 201 (command_sequence == 201) response: 84 7F 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xca recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0xe5 recv: 0x4c CRC OK Got message seqno 202 (command_sequence == 202) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:fe000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0xcb recv: 0x00 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0xe6 recv: 0x03 CRC OK Got message seqno 203 (command_sequence == 203) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0xcc recv: 0x00 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0xaf recv: 0x29 CRC OK Got message seqno 204 (command_sequence == 204) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0xcd recv: 0x00 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0x2f recv: 0xe4 CRC OK Got message seqno 205 (command_sequence == 205) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0xce recv: 0x00 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 22 00 fa 10 22 00 recv: 0x8d recv: 0xe2 CRC OK Got message seqno 206 (command_sequence == 206) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0xcf recv: 0x00 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x21 recv: 0x47 CRC OK Got message seqno 207 (command_sequence == 207) response: 82 FA 10 02 command[0x07, 1]: 07 recv: 0x1b recv: 0xd0 recv: 0x00 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 7f 00 00 00 recv: 0xc3 recv: 0x4f CRC OK Got message seqno 208 (command_sequence == 208) response: 84 7F 00 00 00 PC = fe ->GDB: 00000000000000000000000000000000000100000000000000002200fa10220002fa10fe000000 GDB: GDB: Read 2 bytes from 0x100 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 00 01 00 00 recv: 0x1b recv: 0xd1 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 89 81 recv: 0x1c recv: 0x9d CRC OK Got message seqno 209 (command_sequence == 209) response: 82 89 81 ->GDB: 8981 GDB: GDB: Read 2 bytes from 0x102 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 02 01 00 00 recv: 0x1b recv: 0xd2 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 8f 5f recv: 0x56 recv: 0x82 CRC OK Got message seqno 210 (command_sequence == 210) response: 82 8F 5F ->GDB: 8f5f GDB: GDB: Read 2 bytes from 0x104 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 04 01 00 00 recv: 0x1b recv: 0xd3 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 89 83 recv: 0x40 recv: 0xe6 CRC OK Got message seqno 211 (command_sequence == 211) response: 82 89 83 ->GDB: 8983 GDB: GDB: Read 2 bytes from 0x106 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 06 01 00 00 recv: 0x1b recv: 0xd4 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ec cf recv: 0x30 recv: 0xb1 CRC OK Got message seqno 212 (command_sequence == 212) response: 82 EC CF ->GDB: eccf GDB: GDB: Read 2 bytes from 0x106 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 06 01 00 00 recv: 0x1b recv: 0xd5 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ec cf recv: 0x17 recv: 0x9d CRC OK Got message seqno 213 (command_sequence == 213) response: 82 EC CF ->GDB: eccf GDB: GDB: Read 2 bytes from 0x108 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 08 01 00 00 recv: 0x1b recv: 0xd6 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 f8 94 recv: 0xd9 recv: 0xf7 CRC OK Got message seqno 214 (command_sequence == 214) response: 82 F8 94 ->GDB: f894 GDB: GDB: Read 2 bytes from 0x10A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 0A 01 00 00 recv: 0x1b recv: 0xd7 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff cf recv: 0xa0 recv: 0x7a CRC OK Got message seqno 215 (command_sequence == 215) response: 82 FF CF ->GDB: ffcf GDB: GDB: Read 2 bytes from 0x10C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 0C 01 00 00 recv: 0x1b recv: 0xd8 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xff recv: 0xe6 CRC OK Got message seqno 216 (command_sequence == 216) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x10E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 0E 01 00 00 recv: 0x1b recv: 0xd9 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xd8 recv: 0xca CRC OK Got message seqno 217 (command_sequence == 217) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x110 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 10 01 00 00 recv: 0x1b recv: 0xda recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xb1 recv: 0xbe CRC OK Got message seqno 218 (command_sequence == 218) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x112 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 12 01 00 00 recv: 0x1b recv: 0xdb recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x96 recv: 0x92 CRC OK Got message seqno 219 (command_sequence == 219) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x114 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 14 01 00 00 recv: 0x1b recv: 0xdc recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x63 recv: 0x56 CRC OK Got message seqno 220 (command_sequence == 220) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x116 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 16 01 00 00 recv: 0x1b recv: 0xdd recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x44 recv: 0x7a CRC OK Got message seqno 221 (command_sequence == 221) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x118 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 18 01 00 00 recv: 0x1b recv: 0xde recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x2d recv: 0x0e CRC OK Got message seqno 222 (command_sequence == 222) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x11A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 1A 01 00 00 recv: 0x1b recv: 0xdf recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x0a recv: 0x22 CRC OK Got message seqno 223 (command_sequence == 223) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x11C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 1C 01 00 00 recv: 0x1b recv: 0xe0 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x31 recv: 0xf1 CRC OK Got message seqno 224 (command_sequence == 224) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x11E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 1E 01 00 00 recv: 0x1b recv: 0xe1 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x16 recv: 0xdd CRC OK Got message seqno 225 (command_sequence == 225) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x120 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 20 01 00 00 recv: 0x1b recv: 0xe2 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x7f recv: 0xa9 CRC OK Got message seqno 226 (command_sequence == 226) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x122 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 22 01 00 00 recv: 0x1b recv: 0xe3 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x58 recv: 0x85 CRC OK Got message seqno 227 (command_sequence == 227) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x124 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 24 01 00 00 recv: 0x1b recv: 0xe4 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xad recv: 0x41 CRC OK Got message seqno 228 (command_sequence == 228) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x126 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 26 01 00 00 recv: 0x1b recv: 0xe5 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x8a recv: 0x6d CRC OK Got message seqno 229 (command_sequence == 229) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x128 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 28 01 00 00 recv: 0x1b recv: 0xe6 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xe3 recv: 0x19 CRC OK Got message seqno 230 (command_sequence == 230) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x12A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 2A 01 00 00 recv: 0x1b recv: 0xe7 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xc4 recv: 0x35 CRC OK Got message seqno 231 (command_sequence == 231) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x12C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 2C 01 00 00 recv: 0x1b recv: 0xe8 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x18 recv: 0x98 CRC OK Got message seqno 232 (command_sequence == 232) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x12E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 2E 01 00 00 recv: 0x1b recv: 0xe9 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x3f recv: 0xb4 CRC OK Got message seqno 233 (command_sequence == 233) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x130 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 30 01 00 00 recv: 0x1b recv: 0xea recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x56 recv: 0xc0 CRC OK Got message seqno 234 (command_sequence == 234) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x132 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 32 01 00 00 recv: 0x1b recv: 0xeb recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x71 recv: 0xec CRC OK Got message seqno 235 (command_sequence == 235) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x134 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 34 01 00 00 recv: 0x1b recv: 0xec recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x84 recv: 0x28 CRC OK Got message seqno 236 (command_sequence == 236) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x136 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 36 01 00 00 recv: 0x1b recv: 0xed recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xa3 recv: 0x04 CRC OK Got message seqno 237 (command_sequence == 237) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x138 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 38 01 00 00 recv: 0x1b recv: 0xee recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xca recv: 0x70 CRC OK Got message seqno 238 (command_sequence == 238) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x13A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 3A 01 00 00 recv: 0x1b recv: 0xef recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xed recv: 0x5c CRC OK Got message seqno 239 (command_sequence == 239) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x13C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 3C 01 00 00 recv: 0x1b recv: 0xf0 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x63 recv: 0x23 CRC OK Got message seqno 240 (command_sequence == 240) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x13E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 3E 01 00 00 recv: 0x1b recv: 0xf1 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x44 recv: 0x0f CRC OK Got message seqno 241 (command_sequence == 241) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x140 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 40 01 00 00 recv: 0x1b recv: 0xf2 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x2d recv: 0x7b CRC OK Got message seqno 242 (command_sequence == 242) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x142 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 42 01 00 00 recv: 0x1b recv: 0xf3 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x0a recv: 0x57 CRC OK Got message seqno 243 (command_sequence == 243) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x144 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 44 01 00 00 recv: 0x1b recv: 0xf4 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xff recv: 0x93 CRC OK Got message seqno 244 (command_sequence == 244) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x146 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 46 01 00 00 recv: 0x1b recv: 0xf5 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xd8 recv: 0xbf CRC OK Got message seqno 245 (command_sequence == 245) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x148 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 48 01 00 00 recv: 0x1b recv: 0xf6 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xb1 recv: 0xcb CRC OK Got message seqno 246 (command_sequence == 246) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x14A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 4A 01 00 00 recv: 0x1b recv: 0xf7 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x96 recv: 0xe7 CRC OK Got message seqno 247 (command_sequence == 247) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x14C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 4C 01 00 00 recv: 0x1b recv: 0xf8 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x4a recv: 0x4a CRC OK Got message seqno 248 (command_sequence == 248) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x14E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 4E 01 00 00 recv: 0x1b recv: 0xf9 recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x6d recv: 0x66 CRC OK Got message seqno 249 (command_sequence == 249) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x150 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 50 01 00 00 recv: 0x1b recv: 0xfa recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x04 recv: 0x12 CRC OK Got message seqno 250 (command_sequence == 250) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x152 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 52 01 00 00 recv: 0x1b recv: 0xfb recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x23 recv: 0x3e CRC OK Got message seqno 251 (command_sequence == 251) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x154 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 54 01 00 00 recv: 0x1b recv: 0xfc recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xd6 recv: 0xfa CRC OK Got message seqno 252 (command_sequence == 252) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x156 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 56 01 00 00 recv: 0x1b recv: 0xfd recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xf1 recv: 0xd6 CRC OK Got message seqno 253 (command_sequence == 253) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x158 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 58 01 00 00 recv: 0x1b recv: 0xfe recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0x98 recv: 0xa2 CRC OK Got message seqno 254 (command_sequence == 254) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x15A jtagRead command[0x05, 1]: 05 A0 02 00 00 00 5A 01 00 00 recv: 0x1b recv: 0xff recv: 0x00 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xbf recv: 0x8e CRC OK Got message seqno 255 (command_sequence == 255) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x15C jtagRead command[0x05, 1]: 05 A0 02 00 00 00 5C 01 00 00 recv: 0x1b recv: 0x00 recv: 0x01 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xf4 recv: 0xe3 CRC OK Got message seqno 256 (command_sequence == 256) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x15E jtagRead command[0x05, 1]: 05 A0 02 00 00 00 5E 01 00 00 recv: 0x1b recv: 0x01 recv: 0x01 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xd3 recv: 0xcf CRC OK Got message seqno 257 (command_sequence == 257) response: 82 FF FF ->GDB: ffff GDB: GDB: Read 2 bytes from 0x160 jtagRead command[0x05, 1]: 05 A0 02 00 00 00 60 01 00 00 recv: 0x1b recv: 0x02 recv: 0x01 recv: 0x03 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 3 bytes read: 82 ff ff recv: 0xba recv: 0xbb CRC OK Got message seqno 258 (command_sequence == 258) response: 82 FF FF ->GDB: ffff GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x03 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x77 recv: 0x17 CRC OK Got message seqno 259 (command_sequence == 259) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 80 00 00 00 00 recv: 0x1b recv: 0xa7 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x04 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 80 00 00 00 recv: 0x8e recv: 0x36 CRC OK Got message seqno 260 (command_sequence == 260) response: 84 80 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x05 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 80 00 00 00 recv: 0xdb recv: 0xb3 CRC OK Got message seqno 261 (command_sequence == 261) response: 84 80 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x06 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x23 recv: 0xdd CRC OK Got message seqno 262 (command_sequence == 262) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:00010000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x07 recv: 0x01 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0xa6 recv: 0x03 CRC OK Got message seqno 263 (command_sequence == 263) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x08 recv: 0x01 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0x84 recv: 0x54 CRC OK Got message seqno 264 (command_sequence == 264) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x09 recv: 0x01 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 00 recv: 0xc1 recv: 0x78 CRC OK Got message seqno 265 (command_sequence == 265) response: 82 00 ->GDB: 00 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x0a recv: 0x01 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 22 00 fa 10 22 00 recv: 0x4f recv: 0x23 CRC OK Got message seqno 266 (command_sequence == 266) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x0b recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x4d recv: 0x6a CRC OK Got message seqno 267 (command_sequence == 267) response: 82 FA 10 02 command[0x07, 1]: 07 recv: 0x1b recv: 0x0c recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 80 00 00 00 recv: 0x62 recv: 0x3c CRC OK Got message seqno 268 (command_sequence == 268) response: 84 80 00 00 00 PC = 100 ->GDB: 00000000000000000000000000000000000100000000000000002200fa10220002fa1000010000 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x0d recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x7a recv: 0x27 CRC OK Got message seqno 269 (command_sequence == 269) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 81 00 00 00 00 recv: 0x5f recv: 0xac CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x0e recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 81 00 00 00 recv: 0x62 recv: 0x22 CRC OK Got message seqno 270 (command_sequence == 270) response: 84 81 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x0f recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 81 00 00 00 recv: 0x37 recv: 0xa7 CRC OK Got message seqno 271 (command_sequence == 271) response: 84 81 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x10 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 02 recv: 0x11 recv: 0x59 CRC OK Got message seqno 272 (command_sequence == 272) response: 82 FA 10 02 ->GDB: T0520:02;21:fa10;22:02010000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x11 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x60 recv: 0x47 CRC OK Got message seqno 273 (command_sequence == 273) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 82 00 00 00 00 recv: 0x93 recv: 0xb1 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x12 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 82 00 00 00 recv: 0xed recv: 0x1d CRC OK Got message seqno 274 (command_sequence == 274) response: 84 82 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x13 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 82 00 00 00 recv: 0xb8 recv: 0x98 CRC OK Got message seqno 275 (command_sequence == 275) response: 84 82 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x14 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0xdd recv: 0x14 CRC OK Got message seqno 276 (command_sequence == 276) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:04010000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x15 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xbe recv: 0x51 CRC OK Got message seqno 277 (command_sequence == 277) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 83 00 00 00 00 recv: 0xd7 recv: 0xba CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x16 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 83 00 00 00 recv: 0x20 recv: 0x04 CRC OK Got message seqno 278 (command_sequence == 278) response: 84 83 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x17 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 83 00 00 00 recv: 0x75 recv: 0x81 CRC OK Got message seqno 279 (command_sequence == 279) response: 84 83 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x18 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x22 recv: 0xf6 CRC OK Got message seqno 280 (command_sequence == 280) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:06010000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x19 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xdc recv: 0x6a CRC OK Got message seqno 281 (command_sequence == 281) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 70 00 00 00 00 recv: 0xbd recv: 0x38 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x1a recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0x5c recv: 0x59 CRC OK Got message seqno 282 (command_sequence == 282) response: 84 70 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x1b recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0x09 recv: 0xdc CRC OK Got message seqno 283 (command_sequence == 283) response: 84 70 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x1c recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x77 recv: 0xa8 CRC OK Got message seqno 284 (command_sequence == 284) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:e0000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x1d recv: 0x01 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x44 recv: 0x15 CRC OK Got message seqno 285 (command_sequence == 285) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x1e recv: 0x01 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0xde recv: 0x8d CRC OK Got message seqno 286 (command_sequence == 286) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x1f recv: 0x01 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 01 recv: 0xc3 recv: 0x32 CRC OK Got message seqno 287 (command_sequence == 287) response: 82 01 ->GDB: 01 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x20 recv: 0x01 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 01 00 22 00 fa 10 22 00 recv: 0x05 recv: 0x00 CRC OK Got message seqno 288 (command_sequence == 288) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 01 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x21 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0xd6 recv: 0x8c CRC OK Got message seqno 289 (command_sequence == 289) response: 82 FA 10 21 command[0x07, 1]: 07 recv: 0x1b recv: 0x22 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 70 00 00 00 recv: 0xd8 recv: 0x6d CRC OK Got message seqno 290 (command_sequence == 290) response: 84 70 00 00 00 PC = e0 ->GDB: 00000000000000000000000000000000000100000000000001002200fa10220021fa10e0000000 GDB: BP ADD type: 1 addr: 0xde ENABLED Slot 0 full Slot 1 full Slot 0 full Slot 1 full Slot 0 full Slot 1 full ->GDB: OK GDB: BP ADD type: 1 addr: 0xf0 ENABLED Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full Slot 0 full Slot 1 full Slot 2 full ->GDB: OK GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x23 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x87 recv: 0xa1 CRC OK Got message seqno 291 (command_sequence == 291) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 71 00 00 00 00 recv: 0xf9 recv: 0x33 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x24 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 71 00 00 00 recv: 0xae recv: 0x76 CRC OK Got message seqno 292 (command_sequence == 292) response: 84 71 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x25 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 71 00 00 00 recv: 0xfb recv: 0xf3 CRC OK Got message seqno 293 (command_sequence == 293) response: 84 71 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x26 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x30 recv: 0x2c CRC OK Got message seqno 294 (command_sequence == 294) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:e2000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x27 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x59 recv: 0xb7 CRC OK Got message seqno 295 (command_sequence == 295) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 72 00 00 00 00 recv: 0x35 recv: 0x2e CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x28 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 72 00 00 00 recv: 0xf9 recv: 0x5c CRC OK Got message seqno 296 (command_sequence == 296) response: 84 72 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x29 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 72 00 00 00 recv: 0xac recv: 0xd9 CRC OK Got message seqno 297 (command_sequence == 297) response: 84 72 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x2a recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0xcf recv: 0xce CRC OK Got message seqno 298 (command_sequence == 298) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:e4000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x2b recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x3b recv: 0x8c CRC OK Got message seqno 299 (command_sequence == 299) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 73 00 00 00 00 recv: 0x71 recv: 0x25 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x2c recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 73 00 00 00 recv: 0x34 recv: 0x45 CRC OK Got message seqno 300 (command_sequence == 300) response: 84 73 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x2d recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 73 00 00 00 recv: 0x61 recv: 0xc0 CRC OK Got message seqno 301 (command_sequence == 301) response: 84 73 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x2e recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x9a recv: 0x90 CRC OK Got message seqno 302 (command_sequence == 302) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:e6000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x2f recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xe5 recv: 0x9a CRC OK Got message seqno 303 (command_sequence == 303) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 74 00 00 00 00 recv: 0xad recv: 0x15 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x30 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 74 00 00 00 recv: 0x57 recv: 0x08 CRC OK Got message seqno 304 (command_sequence == 304) response: 84 74 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x31 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 74 00 00 00 recv: 0x02 recv: 0x8d CRC OK Got message seqno 305 (command_sequence == 305) response: 84 74 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x32 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x20 recv: 0x03 CRC OK Got message seqno 306 (command_sequence == 306) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:e8000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x33 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0xff recv: 0xfa CRC OK Got message seqno 307 (command_sequence == 307) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 75 00 00 00 00 recv: 0xe9 recv: 0x1e CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x34 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 75 00 00 00 recv: 0x9a recv: 0x11 CRC OK Got message seqno 308 (command_sequence == 308) response: 84 75 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x35 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 75 00 00 00 recv: 0xcf recv: 0x94 CRC OK Got message seqno 309 (command_sequence == 309) response: 84 75 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x36 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 21 recv: 0x75 recv: 0x5d CRC OK Got message seqno 310 (command_sequence == 310) response: 82 FA 10 21 ->GDB: T0520:21;21:fa10;22:ea000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x37 recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x21 recv: 0xec CRC OK Got message seqno 311 (command_sequence == 311) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 76 00 00 00 00 recv: 0x25 recv: 0x03 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x38 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 76 00 00 00 recv: 0xcd recv: 0x3b CRC OK Got message seqno 312 (command_sequence == 312) response: 84 76 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x39 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 76 00 00 00 recv: 0x98 recv: 0xbe CRC OK Got message seqno 313 (command_sequence == 313) response: 84 76 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x3a recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 35 recv: 0x2f recv: 0xe9 CRC OK Got message seqno 314 (command_sequence == 314) response: 82 FA 10 35 ->GDB: T0520:35;21:fa10;22:ec000000; GDB: command[0x09, 1]: 09 01 01 recv: 0x1b recv: 0x3b recv: 0x01 recv: 0x01 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 1 bytes read: 80 recv: 0x43 recv: 0xd7 CRC OK Got message seqno 315 (command_sequence == 315) response: 80 Waiting for input. recv: 0x1b recv: 0xff recv: 0xff recv: 0x06 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 6 bytes read: e0 77 00 00 00 00 recv: 0x61 recv: 0x08 CRC OK command[0x07, 1]: 07 recv: 0x1b recv: 0x3c recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0x00 recv: 0x22 CRC OK Got message seqno 316 (command_sequence == 316) response: 84 77 00 00 00 command[0x07, 1]: 07 recv: 0x1b recv: 0x3d recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0x55 recv: 0xa7 CRC OK Got message seqno 317 (command_sequence == 317) response: 84 77 00 00 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x3e recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 35 recv: 0x7a recv: 0xb7 CRC OK Got message seqno 318 (command_sequence == 318) response: 82 FA 10 35 ->GDB: T0520:35;21:fa10;22:ee000000; GDB: GDB: Read 39 bytes from 0xC6 jtagRead command[0x05, 1]: 05 A0 28 00 00 00 C6 00 00 00 recv: 0x1b recv: 0x3f recv: 0x01 recv: 0x29 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 41 bytes read: 82 df 93 cf 93 0f 92 cd b7 de b7 a1 e2 b0 e0 e1 e2 f0 e0 80 81 88 6a 8c 93 19 82 a2 e2 b0 e0 e2 e2 f0 e0 80 81 88 6a 8c 93 recv: 0x69 recv: 0x68 CRC OK Got message seqno 319 (command_sequence == 319) response: 82 DF 93 CF 93 0F 92 CD B7 DE B7 A1 E2 B0 E0 E1 E2 F0 E0 80 81 88 6A 8C 93 19 82 A2 E2 B0 E0 E2 E2 F0 E0 80 81 88 6A 8C 93 ->GDB: df93cf930f92cdb7deb7a1e2b0e0e1e2f0e08081886a8c931982a2e2b0e0e2e2f0e08081886a8c GDB: GDB: Read 25 bytes from 0xED jtagRead command[0x05, 1]: 05 A0 1A 00 00 00 EC 00 00 00 recv: 0x1b recv: 0x40 recv: 0x01 recv: 0x1b recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 27 bytes read: 82 8c 93 00 00 a2 e2 b0 e0 e2 e2 f0 e0 80 81 87 75 8c 93 00 00 89 81 8f 5f 89 83 recv: 0x5a recv: 0x1c CRC OK Got message seqno 320 (command_sequence == 320) response: 82 8C 93 00 00 A2 E2 B0 E0 E2 E2 F0 E0 80 81 87 75 8C 93 00 00 89 81 8F 5F 89 83 ->GDB: 930000a2e2b0e0e2e2f0e0808187758c93000089818f5f8983 GDB: BP DEL type: 1 addr: 0xde DISABLED ->GDB: OK GDB: BP DEL type: 1 addr: 0xf0 DISABLED ->GDB: OK GDB: ->GDB: GDB: ->GDB: GDB: GDB: Read 1 bytes from 0x8010FB jtagRead command[0x05, 1]: 05 20 01 00 00 00 FB 10 00 00 recv: 0x1b recv: 0x41 recv: 0x01 recv: 0x02 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 2 bytes read: 82 01 recv: 0xe1 recv: 0xf0 CRC OK Got message seqno 321 (command_sequence == 321) response: 82 01 ->GDB: 01 GDB: GDB: (Registers)Read 32 bytes from 0x800000 jtagRead command[0x05, 1]: 05 20 20 00 00 00 00 00 00 00 recv: 0x1b recv: 0x42 recv: 0x01 recv: 0x21 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 33 bytes read: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 a8 00 22 00 fa 10 22 00 recv: 0x82 recv: 0x94 CRC OK Got message seqno 322 (command_sequence == 322) response: 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 A8 00 22 00 FA 10 22 00 jtagRead command[0x05, 1]: 05 20 03 00 00 00 5D 00 00 00 recv: 0x1b recv: 0x43 recv: 0x01 recv: 0x04 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 4 bytes read: 82 fa 10 35 recv: 0xde recv: 0x5e CRC OK Got message seqno 323 (command_sequence == 323) response: 82 FA 10 35 command[0x07, 1]: 07 recv: 0x1b recv: 0x44 recv: 0x01 recv: 0x05 recv: 0x00 recv: 0x00 recv: 0x00 recv: 0x0e sDATA: reading 5 bytes read: 84 77 00 00 00 recv: 0xe4 recv: 0x41 CRC OK Got message seqno 324 (command_sequence == 324) response: 84 77 00 00 00 PC = ee ->GDB: 000000000000000000000000000000000001000000000000a8002200fa10220035fa10ee000000
