* [CLOC] [MEMC] [ITLB] [COPY] [CODE] [DATA] [JRAM] [CACH] [SIGN] Uncompressing DBL 1... [ZBSS] [CREG] [MAIN] Kreatel IP-STB booting... Firmware built Jan 4 2006 15:31:06, v1.33 IDT5V9885: EEPROM was already up-to-date PCI: Found type 0: 00:13.0, ID: 100B:0020 Using framebuffer at 0x07800000 (8192 kB) Current operating mode: Active Kreatel IP-STB @ 300 MHz (333 MHz, CL 2.5), 131072 kB RAM Booted in 479 msecs. Found ATI Xilleon X210 NAND flash support detected. Probing... Found flash on CS1: ST NAND128W3A (16777216 bytes) Found flash on CS0: ST NAND128W3A (16777216 bytes) bus 0000, function 0088, vendor 1033, device 0035 bus 0000, function 0089, vendor 1033, device 0035 bus 0000, function 008A, vendor 1033, device 00E0 bus 0000, function 0090, vendor 104C, device 9065 bus 0000, function 0098, vendor 100B, device 0020 Found National DP83815 at 0x2000, ROM address 0x00000000 Probing...[DP83815] National DP83815: MAC addr 00:02:9B:18:A6:53 National DP83815: Setting 100 Mbit full-duplex Infocast HW ID = kreatel-ip-stb-rev-15 Searching for server (DHCP)... Me: 192.168.1.180, Server: 213.64.105.106, Relay: 217.215.3.129 Splash boot order: 31 Kernel boot order: 31 Bootcast address: 224.2.2.2:22222 ***** Loading splash image ***** Loading splash image from Local Storage Local Storage: No valid splash image stored. Downloading splash image using Bootcast Loading control file kreatel-ip-stb-rev-15 from 224.2.2.2:22222 Splash name: splash-1710 Splash address: 239.0.2.3:22221 Download attempt aborted because of a change in the packet precoding. Bootcast: Couldn't download the splash image. Couldn't successfully download a splash image. Skipping! ***** Loading kernel image ***** Loading kernel image from Local Storage Local Storage: No valid kernel image stored. Downloading kernel image using Bootcast Bootcast: Trying to download the kernel image... Kernel name: kreatel-ip1720 Kernel address: 239.0.2.13:22220 flash: Storing image (15928798 bytes)... flash: Using kernel image stored in flash flash: Image size: 15928798 bytes (ELF)... done loaded at: 82000000 820C6768 zimage at: 8200F000 820C6768 Uncompressing Linux at load address 80100000 initrd at: 820C6768 82F3A80A relocated to: 802E0FF8 8115509A Booting linux kernel LINUX started... ATI Xilleon 210 (little endian), Solo mode PCI bus speed is 33MHz Initializing IRQs memsize: 112MB CPU revision is: 00018448 Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes. Primary data cache 16kB, 4-way, linesize 16 bytes. Linux version 2.4.30 (dailybuild@svn) (gcc version 3.4.6) #1 Mon Jan 21 17:40:26 CET 2008 Start xilleon_setup... Determined physical RAM map: memory: 00080000 @ 00000000 (ROM data) memory: 00080000 @ 00080000 (reserved) memory: 06f00000 @ 00100000 (usable) Initial ramdisk at: 0x802e1000 (15155354 bytes) On node 0 totalpages: 28672 zone(0): 28672 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: ip=192.168.1.180:213.64.105.106:0.0.0.0:255.255.255.0 rbl =1 dbl=1 bch=224.2.2.2:22222 ramsize=131072 last_key=none console=ttyS0,115200, n,8,1 calculating r4koff... 0016dd01(1498369) with HZ(100) CPU frequency 299.67 MHz Using 149.837 MHz high precision timer. Console: colour dummy device 80x25 Calibrating delay loop... 299.00 BogoMIPS Memory: 95688k/113664k available (1464k kernel code, 17976k reserved, 116k data, 112k init, 0k highmem) Dentry cache hash table entries: 16384 (order: 5, 131072 bytes) Inode cache hash table entries: 8192 (order: 4, 65536 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 32768 (order: 5, 131072 bytes) Checking for 'wait' instruction... available. POSIX conformance testing by UNIFIX Autoconfig PCI channel 0x802acc08 Scanning bus 00, I/O 0x00002000:0x00010001, Mem 0x10000000:0x18000001 00:11.0 Class 0c03: 1033:0035 (rev 43) Mem at 0x10000000 [size=0x1000] 00:11.1 Class 0c03: 1033:0035 (rev 43) Mem at 0x10001000 [size=0x1000] 00:11.2 Class 0c03: 1033:00e0 (rev 04) Mem at 0x10002000 [size=0x100] 00:12.0 Class 0000: 104c:9065 (rev 01) Mem at 0x10400000 [size=0x400000] Mem at 0x10800000 [size=0x800000] I/O at 0x00002000 [size=0x10] 00:13.0 Class 0200: 100b:0020 I/O at 0x00002100 [size=0x100] Mem at 0x11000000 [size=0x1000] 00:14.0 Class 0480: 1002:4860 (rev 02) Mem unavailable -- skipping I/O at 0x00002200 [size=0x100] Mem at 0x11008000 [size=0x8000] Mem at 0x1c000000 [size=0x4000000] 00:14.1 Class 0101: 1002:4861 (rev 01) I/O at 0x00002300 [size=0x8] I/O at 0x00002308 [size=0x4] I/O at 0x00002310 [size=0x8] I/O at 0x00002318 [size=0x4] I/O at 0x00002320 [size=0x10] 00:14.2 Class 0c03: 1002:4862 (rev 0a) Mem at 0x11010000 [size=0x1000] 00:14.5 Class 0401: 1002:4863 (rev 01) Mem at 0x11011000 [size=0x100] 00:14.6 Class 0703: 1002:4864 (rev 01) Mem at 0x11011100 [size=0x100] irq fixup slot 17 vendor 1033 irq 33 irq fixup slot 17 vendor 1033 irq 34 irq fixup slot 17 vendor 1033 irq 35 irq fixup slot 18 vendor 104c irq 33 irq fixup slot 19 vendor 100b irq 33 Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x0 JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Initial framebuffer at 0x0f800000, mapped to af800000, size 8388608 Console: switching to colour frame buffer device 90x36 Dummy keyboard driver installed. pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI en abled ttyS00 at 0xbe000010 (irq = 100) is a 16550A ttyS01 at 0xbe000000 (irq = 99) is a 16550A ttyS02 at 0xbe000020 (irq = 122) is a 16550A Kboxdev: registered device with major 120 Software Watchdog Timer: 0.05, timer margin: 60 sec RAMDISK driver initialized: 16 RAM disks of 32768K size 1024 blocksize natsemi dp8381x driver, version 1.07+LK1.0.17, Sep 27, 2002 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder eth0: NatSemi DP8381[56] at 0xb1000000, 00:02:9b:18:a6:53, IRQ 33. Xilleonfb: Xilleon Framebuffer Driver Xilleonfb: Unable to reserve framebuffer at 0xf800000 mice: PS/2 mouse device common for all mice NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 8192 bind 16384) eth0: link up. eth0: Setting full-duplex based on negotiated link capability. IP-Config: Complete: device=eth0, addr=192.168.1.180, mask=255.255.255.0, gw=255.255.255.255, host=192.168.1.180, domain=, nis-domain=(none), bootserver=213.64.105.106, rootserver=213.64.105.106, rootpath= ip_tables: (C) 2000-2002 Netfilter core team NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. RAMDISK: Compressed image found at block 0 Freeing initrd memory: 14800k freed VFS: Mounted root (ext2 filesystem) readonly. Freeing unused kernel memory: 112k freed --- Linuxrc mounting /rootdisk using up to maximum 512 MB RAM if available --- Linuxrc populating /rootdisk --- Mounting devfs --- Pivoting root mount: Mounting none on /sys failed: No such file or directory Thu Jan 1 00:00:00 UTC 1970 createuserproc: Added production parameters createuserproc: Added user parameters insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/07kb.o Warning: loading 07kb will taint the kernel: non-GPL license - Proprietary See http://www.tux.org/lkml/#export-tainted for information about tainted modu les insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/08ir.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/10usbcore.o usb.c: registered new driver usbdevfs usb.c: registered new driver hub insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/11usb-ohci.o usb-ohci.c: USB OHCI at membase 0xb0000000, IRQ 33 usb-ohci.c: usb-00:11.0, PCI device 1033:0035 usb.c: new USB bus registered, assigned bus number 1 hub.c: USB hub found hub.c: 3 ports detected usb-ohci.c: USB OHCI at membase 0xb0001000, IRQ 34 usb-ohci.c: usb-00:11.1, PCI device 1033:0035 usb.c: new USB bus registered, assigned bus number 2 hub.c: USB hub found hub.c: 2 ports detected usb-ohci.c: USB OHCI at membase 0xb1010000, IRQ 2 usb-ohci.c: usb-00:14.2, PCI device 1002:4862 usb.c: new USB bus registered, assigned bus number 3 hub.c: USB hub found hub.c: 2 ports detected insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/12ehci-hcd.o ehci_hcd 00:11.2: PCI device 1033:00e0 ehci_hcd 00:11.2: irq 35, pci mem b0002000 usb.c: new USB bus registered, assigned bus number 4 ehci_hcd 00:11.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4 hub.c: USB hub found hub.c: 5 ports detected insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/15hid.o usb.c: registered new driver hid hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik hid-core.c: USB HID support drivers insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/20scsi_mod.o SCSI subsystem driver Revision: 1.00 insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/21sd_mod.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/22usb-storage.o Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage USB Mass Storage support registered. insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/27fat.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/28vfat.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/30soundcore.o insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/31audio.o usb.c: registered new driver audio audio.c: v1.0.0:USB Audio Class driver insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/32videodev.o Linux video capture interface: v1.00 insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/33pwc.o pwc: Philips webcam module version 10.0.12 loaded. pwc: Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCV C830/840. pwc: Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30, pwc: the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100. usb.c: registered new driver Philips webcam insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/34ov511.o usb.c: registered new driver ov511 ov511.c: v1.63 for Linux 2.4 : ov511 USB Camera Driver insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/atyx220.o Warning: loading atyx220 will taint the kernel: no license See http://www.tux.org/lkml/#export-tainted for information about tainted modu les insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/dm642.o >> dm642pci_fxn_probe - Revision ID = 1 >> dm642pci_fxn_probe - Interrupt Line = 33 >> dm642pci_fxn_probe - PCI Device Enabled >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10400000 >> dm642pci_fxn_probe - Mapping MEM Space to Kernel Phys = 0x10800000 >> drvPciDm642ModuleInit - Requesting IRQ, irqId = 33 insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/kboxmtd.o Warning: loading kboxmtd will taint the kernel: non-GPL license - Proprietary See http://www.KBoxMTD: Found Winbond flash. tux.org/lkml/#exKBoxMTD: Winbond W39L040 flash detected port-tainted forKBoxMTD: Standard firmware detected information aboUsing the production data for NAND settings ut tainted modulKBoxMTD: NAND flash support detected. es Found flash on CS1 Size: 16777216 Found flash on CS0 Size: 16777216 KBoxMTD: Done insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/kfusd.o fusd: starting, $Revision: 1.97 $, $Date: 2003/07/11 22:29:39 $, debugging messa ges disabled insmod: /lib/modules/2.4.30: No such file or directory Using /lib/modules/yaffs.o yaffs Jan 21 2008 17:43:21 Installing. Mounting flash Mounting filesystem (/flash2) yaffs: dev is 7940 name is "1f:04" yaffs: Attempting MTD mount on 31.4, "1f:04" No time zone setting, using UTC Reading address from /tmp/bootloader_channel.conf Current system time is 2 Scanning infocast channel 224.2.2.2:22222 Setting timeout to 10 seconds TInfocastConnection is not connected. eth0 Link encap:Ethernet HWaddr 00:02:9B:18:A6:53 inet addr:192.168.1.180 Bcast:192.168.1.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:7 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:420 (420.0 B) TX bytes:0 (0.0 B) Interrupt:33 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Reading address from /proc/kboxbch Verifying read operation... Read: ImageLength: 77530 Reading at Block 24, length 77530 bytes... Verifying read operation... Verifying read operation... Verifying read operation... Verifying read operation... Verifying read operation... Read OK. BusyBox v1.01 (2008.01.21-21:36+0000) Built-in shell (ash) Enter 'help' for a list of built-in commands. /bin/sh: can't access tty; job control turned off / # Error: Unable to read name service address from file /tmp/nameservice_addres s defined by NS_ADDRESS_FILENAMx TInfocastConnection is not connected. TIpcBootloader_SetUpgradeCounter() BEGIN TIpcBootloader_SetUpgradeCounter() END (false) [217] (TNI)APPMOD_QMS_AMS_X86_LINUX__3.18.0 [217] ******************************************** [217] ******************************************** [217] Programa: QMS_AMS [217] Pid : 217 [217] ******************************************** LLD ERROR: unaccounted HKD client 811525e0!!! status 0x360c bits 0x400 warning: component 5 resource 0x1 not free! SOFTDOG: WDT device closed unexpectedly. WDT will not stop! SOFTDOG: Initiating system reboot. Warm reset Watchdog reset! *
