=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.03.26 00:38:03 =~=~=~=~=~=~=~=~=~=~=~= àààüàüüààüüàààààààüààààààüàüàüààüààüàààüààààààààààüàààààààààüààààüààüààààààüüàüàüüàüàüüüàüàüàüüàüàààüüüààüüüüàààüüààààüàààààààààààààüüàüààüàààüàüàààüàüààü HardwareID::Board hardwired to 5 HardwareID::FeatureDebugUart1 hardwired to 1 Telegent Kernel V0.9.14.11, built May 8 2008 20:40:48 TargetCfg: Bootscript = V 00130001 PLATFORM = EVO1_11 RAMSIZE = 256 (via Registry) FLASH = cfgFLASH PlatformID = 0x00010014 HardwareID = 0xFFFFF005.FFFFFFFF Manf. ID = 0x54476D62.33533046 UUID = {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF} PLL0 Clock = 250714285 Hz Memory Layout (256MB SC) PNX8550_RAM_SIZE = 0x10000000 (256 MB) MIPS_SIZE = 0x08000000 (128 MB) TRIMEDIA_SIZE0 = 0x01000000 ( 16 MB) TRIMEDIA_SIZE1 = 0x00A00000 ( 10 MB) SHARED_CACHED_SIZE = 0x02800000 ( 40 MB) SHARED_NC_SIZE = 0x01200000 ( 18 MB) FLASH FS Start = 0x04000000 ( 64 MB) (Scratch3=0x00000000) L1 Cache: Flags 0x0000 Instruction: SetsPerWay 256 NumWays 2 LineSize 0x0020 Size 0x4000 Data : SetsPerWay 128 NumWays 4 LineSize 0x0020 Size 0x4000 L2 Cache: Flags 0x0000 Instruction: SetsPerWay 0 NumWays 0 LineSize 0x0000 Size 0x0000 Data : SetsPerWay 0 NumWays 0 LineSize 0x0000 Size 0x0000 PCI Module Configuration: 0x40014: 0x00000245 -> 0x00000047(PCI_CTRL) 0x4004C: 0x00000000 -> 0x00002008(PCI_LAT_TMR) 0x4008C: 0x00070203 -> 0x001F0407(PCI_SLVTUNING) 0x40090: 0x00001802 -> 0x00001704(PCI_DMATUNING) ################# PCI register Dump ##################### PCI configuration: optimized read offset value name 0x40010: 0x01DA0F83(PCI_SETUP) 0x40014: 0x00000047(PCI_CTRL) 0x40018: 0x18000000(PCI_BASE1_LO) 0x4001C: 0x1A000000(PCI_BASE1_HI) 0x40020: 0x1C000000(PCI_BASE2_LO) 0x40024: 0x1E000000(PCI_BASE2_HI) 0x40028: 0x00008000(PCI_RDLIFETIME) 0x4002C: 0x00000000(PCI_GPPM_ADDR) 0x40030: 0x00000000(PCI_GPPM_WDAT) 0x40034: 0x00000000(PCI_GPPM_RDAT) 0x40038: 0x00000000(PCI_GPPM_CTRL) 0x4003C: 0x00000000(PCI_UNLOCKREG) 0x40040: 0x85501131(PCI_DEV_VEND_ID) 0x40044: 0x02900006(PCI_CFG_CMDSTAT) 0x40048: 0x04800010(PCI_CLASS_REV) 0x4004C: 0x00002008(PCI_LAT_TMR) 0x40050: 0x00000008(PCI_BASE10) 0x40054: 0x1BE00000(PCI_BASE14) 0x40058: 0x10000000(PCI_BASE18) 0x4006C: 0x00591131(PCI_SUBSYS_ID) 0x40074: 0x00000040(PCI_CAP_PTR) 0x4007C: 0x18090100(PCI_CFG_MISC) 0x40080: 0x00020001(PCI_PMC) 0x40084: 0x00000000(PCI_PWR_STATE) 0x40088: 0x00000001(PCI_IO) 0x4008C: 0x001F0407(PCI_SLVTUNING) 0x40090: 0x00001704(PCI_DMATUNING) 0x40800: 0x11E69800(PCI_DMAEADDR) 0x40804: 0x01B6D600(PCI_DMAIADDR) 0x40808: 0x00000080(PCI_DMALEN) 0x4080C: 0x00000286(PCI_DMACTRL) 0x40810: 0x00000002(PCI_XIOCTRL) 0x40814: 0x00494817(PCI_SEL0PROF) 0x40818: 0x00000000(PCI_SEL1PROF) 0x4081C: 0x00000000(PCI_SEL2PROF) 0x40820: 0x00000000(PCI_GPXIOADDR) 0x40824: 0x00000000(PCI_GPXIOWDATA) 0x40828: 0x00000000(PCI_GPXIORDATA) 0x4082C: 0x00000000(PCI_GPXIOCTRL) 0x40830: 0x00370050(PCI_NANDCTRLS) 0x40834: 0x00000000(PCI_SEL3PROF) 0x40838: 0x00000000(PCI_SEL4PROF) 0x40FB0: 0x00004000(PCI_GPXIO_STAT) 0x40FB4: 0x00000000(PCI_GPXIO_IMASK) 0x40FB8: 0x00000000(PCI_GPXIO_ICLR) 0x40FBC: 0x00000000(PCI_GPXIO_ISET) 0x40FC0: 0x00000000(PCI_GPPM_STATUS) 0x40FC4: 0x00000000(PCI_GPPM_IMASK) 0x40FC8: 0x00000000(PCI_GPPM_ICLR) 0x40FCC: 0x00000000(PCI_GPPM_ISET) 0x40FD0: 0x00005000(PCI_DMA_STATUS) 0x40FD4: 0x00000000(PCI_DMA_IMASK) 0x40FD8: 0x00000000(PCI_DMA_ICLR) 0x40FDC: 0x00000000(PCI_DMA_ISET) 0x40FE0: 0x00004000(PCI_ISTATUS) 0x40FE4: 0x00000000(PCI_IMASK) 0x40FE8: 0x00000000(PCI_ICLR) 0x40FEC: 0x00000000(PCI_ISET) 0x40FFC: 0xA0510000(PCI_MOD_ID) ################# XIO Profile Setup ##################### no. properties base addr. size 0: 0x00494817 0x10000000 0x04000000 1: 0x017C0101 0x14000000 0x00800000 2: 0x003C3F21 0x14800000 0x00800000 3: disabled 4: disabled Performing PCI device configuration: [0/ 8/0] SATA : CacheLineSize=8 ( 0) LatencyTimer=64 ( 0) MIN_GNT= 0 MAX_LAT= 0 [0/ 9/0] ISP1561_OHCI1: CacheLineSize=8 ( 0) LatencyTimer=40 ( 0) MIN_GNT= 1 MAX_LAT=42 [0/ 9/1] ISP1561_OHCI1: CacheLineSize=8 ( 8) LatencyTimer=40 ( 0) MIN_GNT= 1 MAX_LAT=42 [0/ 9/2] ISP1561_EHCI : CacheLineSize=8 ( 8) LatencyTimer=16 ( 0) MIN_GNT= 2 MAX_LAT=16 [0/10/0] DP83815/16 : CacheLineSize=0 ( 0) LatencyTimer=52 ( 0) MIN_GNT=11 MAX_LAT=52 [0/11/0]: no device at location [0/12/0]: no device at location OAL: GIC Interrupt Handling Method: Priority BSP: GIC Interrupt Handling Method: Priority OALArgsQuery::OAL_ARGS_QUERY_RTC called! OEMGetExtensionDRAM start=0x89a00000, length=0x02b00000 OALIoCtlHalPostInit() stub +OALInitVarsRTC() -OALInitVarsRTC() OEMIoControl: Unsupported Code 0x101008c - device 0x0101 func 35 OALIoCtlHalInitRegistry::stub OEMIoControl: Unsupported Code 0x10100d0 - device 0x0101 func 52 OALIoCtlHalGetHWEntropy() stub starting handle manager... API!WIN32_TFFS:GetRegistryConfig: Query registry for configuration... found config value at idx=1 in registry: vlbPrecision=1 found config value at idx=2 in registry: vlbMaxLen=16 found config value at idx=4 in registry: vlbIterationLen=32 found config value at idx=5 in registry: lbSize=0 found config value at idx=6 in registry: dataIOCacheLen=1 found config value at idx=7 in registry: zlib_CompressionLevel=1 found config value at idx=8 in registry: ISMMode=0 found config value at idx=9 in registry: traceSetting=12288 API!WIN32_TFFS:GetRegistryConfig: Query registry found no or not all entries instantiating TFFS API layer for Win32 and WinCE 5.00 CTFFSVolume::Mount() mounting TFFS API layer for Win32 and WinCE 5.00 mounting 3.00V01 Build 0526... starting VLBD (partion id=0, vlb precision=1, ism-mode=0, ism-partition=0)... globalMemStatus: Total=108476 KB Avail=108128 KB NANDFLASH: FFS Size not defined! Start = 0x4000000 (64 MB) ERROR: failed mounting VLBD (partion id=0, vlb precision=1)... ERROR: no volume mounted for partition=0... mounting FlashDisk took 94 ms Pnx8550Mmio.dll:MapPNX8550Mmio: Ramsize = 256 MB Pnx8550Mmio.dll:MapPNX8550Mmio: pMMIO = 0x4C200000 SBM_Init StandbyMicro: Using key table mapping from 'StandbyMicro.mapping' StandbyMicro: Trying Release directory StandbyMicro: Trying Windows directory StandbyMicro: line 84 not handled ' ' ERROR: OALIoCtlHalGetFbInfo: Unable to query key "TVStandard", using PAL SetAnalogVideoMode 0 TG_Anabel::Init Macrovision: Active = 0, Changeable = 1 SetScart to output... TG_Scart::Init ERROR: OALIoCtlHalGetFbInfo: Unable to query key "TVStandard", using PAL Setting up video output for mode 'pal', width=720, height=576, stride=1440 ERROR: OALIoCtlHalGetFbInfo: Unable to query key "TVStandard", using PAL TgCtrl.Splash - Waiting on StopEvent moreTV/SplashStop TG_Splash using bitmap \Windows\spl_scrn.bmp DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PPP). Driver cannot be unloaded. DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\SNMP). Driver cannot be unloaded. ISP1561 OHCI: Compiled Jul 14 2008 11:18:08 ISP1561 OHCI: USB\HCD\OHC DllMain sil3x12: FISReg(0) = 0x10401555 sil3x12: FISReg(1) = 0x10401555 sil3x12: changing to 0x10401554 sil3x12: CacheLineSize=8 sil3x12: FIFO(0) = 0x00000002 (was 0x00000000) sil3x12: FIFO(1) = 0x00000002 (was 0x00000000) Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::ResetController> SRST failed Atapi!CDisk[0]::InitController> Retrying to reset controller (remaining attempts 4) Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::ResetController> SRST failed Atapi!CDisk[0]::InitController> Retrying to reset controller (remaining attempts 3) Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::ResetController> SRST failed Atapi!CDisk[0]::InitController> Retrying to reset controller (remaining attempts 2) Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::ResetController> SRST failed Atapi!CDisk[0]::InitController> Retrying to reset controller (remaining attempts 1) Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::ResetController> SRST failed Atapi!CDisk[0]::InitController> Retrying to reset controller (remaining attempts 0) Atapi!CDisk[0]::Init> Failed to initialize device sil3x12: FISReg(0) = 0x10401554 sil3x12: FISReg(1) = 0x10401554 sil3x12: changing to 0x10401554 sil3x12: CacheLineSize=8 sil3x12: FIFO(0) = 0x00000002 (was 0x00000002) sil3x12: FIFO(1) = 0x00000002 (was 0x00000002) Atapi!CDisk[0]::ResetController> Device is busy; 9 seconds remaining Atapi!CDisk[0]::ResetController> Device is ready Atapi!CDisk[0]::InitController> Waiting 500ms before Identify Atapi!CDisk[0]::IsDevicePresent> Device is present Atapi!CDisk::SendExecuteDeviceDiagnostic> Device 0 passed, Device 1 passed or not present Atapi!CDisk::SendExecuteDeviceDiagnostic> ATA device Atapi!DumpIdentify> ... 5a c ff 3f 37 c8 10 0 0 0 0 0 3f 0 0 0 Z..?7.......?... 0 0 0 0 20 20 20 20 20 20 20 20 20 20 20 20 .... 4c 34 30 4a 46 44 56 32 0 0 0 40 4 0 2e 33 L40JFDV2...@...3 31 30 20 20 20 20 54 53 32 33 30 30 32 38 41 32 10 TS230028A2 20 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20 S 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80 .. 0 0 0 2f 0 40 0 2 0 2 7 0 ff 3f 10 0 .../.@.......?.. 3f 0 10 fc fb 0 10 0 ff ff ff f 0 0 7 4 ?............... 3 0 78 0 78 0 f0 0 78 0 0 0 0 0 0 0 ..x.x...x....... 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 ................ 7e 0 1b 0 6b 34 1 7d 3 40 69 34 1 3c 3 40 ~...k4.}.@i4.<.@ 7f 0 0 0 0 0 fe fe fe ff 0 0 0 fe 0 0 ................ 0 0 0 0 0 0 0 0 b0 f1 49 17 0 0 0 0 ..........I..... 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 1 0 b0 f1 49 17 b0 f1 49 17 20 20 2 0 b6 42 ....I...I. ...B 0 80 8a 0 6 3c a 3c 0 0 c6 7 0 1 0 8 .....<.<........ f0 10 0 10 2 0 30 0 0 0 0 0 0 0 6 fe ......0......... 0 0 3 fe 50 0 8a 0 4f 95 0 0 e3 0 b 0 ....P...O....... 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ................ 0 0 0 0 0 0 0 0 0 0 0 0 0 0 a5 d4 ................ rotational speed tolerance is > 0,5 disk transfer rate > 10Mbs fixed drive head switch time > 15us not MFM encoded hard sectored number of cylinders : 16383 number of heads : 16 unformatted bytes per track : 0 unformatted bytes per sector : 0 sectors per track : 63 buffer type : unspecified buffer size : 16384 sectors read/write multiple : supported, 16 sectors/interrupt double word IO : not supported LBA mode : supported DMA : supported PIO cycle timing mode : 2 DMA cycle timing mode : 2 current size fields valid : yes current number of cylinders : 16383 current number of heads : 16 current number of sectors/track : 63 current sector capacity : 16514064 sectors/interrupt with read/write multiple : 16 multi sector setting : invalid total user addressable sectors : 268435455 single word DMA modes supported : 0 single word transfer mode active : 0 multi word DMA modes supported : 7 multi word transfer mode active : 4 Atapi!CDisk[0]::Identify> Assuming direct-access device (hard disk drive) Atapi!CDisk[0]::Identify::ConfigLBA48> Device supports 48-bit LBA Atapi!CDisk[0]::Identify::ConfigLBA48> Max LBA Address = 0x000000001749f1b0 Atapi!CDisk[0]::InitController> Device responded to identify Atapi!CDisk[0]::Init> Enabled write cache Atapi!CDisk[0]::Init> Enabled read look-ahead Atapi!CDisk::Init> Selecting Ultra DMA mode 69 (0x45) DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PCI\Instance\DP838161). Driver cannot be unloaded. TG DP8381 Macphyter: DLL_PROCESS_ATTACH NdisMPciAssignResources(0x59600, 0) DP83816:DP83816Initialize() Adapter->IRQ = 0x7 tmman.c:sysBisInit: totalRamSize = 0x10000000 BIS Entry 1: Key 'ShCa' Value1=0x0C500000 Value2=0x0ED00000 BIS Entry 2: Key 'ShNC' Value1=0x0ED00000 Value2=0x0FF00000 BIS Entry 3: Key 'IpNC' Value1=0x0FF00000 Value2=0x0FFFF000 BIS Entry 4: Key 'Dma0' Value1=0x00000000 Value2=0x10000000 BIS Entry 5: Key 'BisC' Value1=0x6B577856 Value2=0x7073424D BIS Entry 6: Key 'Xio ' Value1=0x10000000 Value2=0x18000000 HalHandle: 0x5bc20 MMIO: Len=0x200000, Addr=0x4cb00000 SDRAM: Len=0x1000000, Addr=0x4e000000 Device Vendor Id: 0x0 Subsystem Id: 0x0 Class Revision Id: 0x0 DMX: created device DMX1 DMX: created device DMX2 SCUART Module ID = 0x01062100 SCU_Init: created device SCU1 +CFeProbe::run[1] CFeProbe::run[1]: probing frontend 'fe_tda10023'! FEN_Init[1]: Inititalization via RegisterDevice: using Context=257 as index (dll loaded by fe_loader)! +CFeProbe::run[2] CFeProbe::run[2]: waiting for other frontend probing to be finished FEN_Init[1]: created device FEN1 CFeProbe::run[1]: using 'fe_tda10023' for 'FEN1:'! -CFeProbe::run[1] CFeProbe::run[2]: probing frontend 'fe_tda10023'! FEN_Init[2]: Inititalization via RegisterDevice: using Context=258 as index (dll loaded by fe_loader)! Pnx8550Mmio.dll:MapPNX8550Mmio: Ramsize = 256 MB Pnx8550Mmio.dll:MapPNX8550Mmio: pMMIO = 0x4CD00000 tmman:namespaceOpen:Name[StbRpc]:NON EXISTENT:FAIL FEN_Init[2]: created device FEN2 CFeProbe::run[2]: using 'fe_tda10023' for 'FEN2:'! -CFeProbe::run[2] TG_Tgc1Init() Desktop - started Loading DSP Image... +TmLoadDspImageDefault() TmLoadDspImageDefault DspNo=0 Image='\Windows\phStbRootApp_0.mi' TmGetDspSymbol reading file '\Windows\phStbRootApp_0.sym' Symbol '__begin_mem' found: Line 1: '__begin_mem 0x08000000 ' TmGetDspSymbol reading file '\Windows\phStbRootApp_0.sym' Symbol '__end_mem' found: Line 2: '__end_mem 0x09000000 ' TmLoadDspImageFromFile: '\Windows\phStbRootApp_0.mi' ****************************************** DSP image file '\Windows\phStbRootApp_0.mi' not found! ****************************************** Nandlflash library version V1.2.0.0 TESTING Hynix, 8bit, 64MB NANDFLASH: FFS Start = 0x4000000 (64 MB), size = 0x0 (0 MB) DSP Image found Trying to load DSP Image from flash Loading DSP image at 0x08000000 (=128MB) Seconds for Loading image (bytes read=9084416): 2 Patching DSP image TmGetDspSymbol reading file '\Windows\phStbRootApp_0.sym' Symbol '_RealTMManShared' found: Line 0: '_RealTMManShared 0x0889f25c data ' Symbol TMManShared (address 0xA889F25C) patched with 0x0ed00000 TmGetDspSymbol reading file '\Windows\phStbRootApp_0.sym' Symbol '_phBuildInfo_DateTime' found: Line 3: '_phBuildInfo_DateTime 0x0885bfa8 data ' ****************************************** DSP Image Information: '$Build: SP6.4_256M_WINCE_RC8 Jul 8 2008 13:56:29 $' ****************************************** DSP image downloaded TmLoadDspImageDefault DspNo=1 Image='\Release\DspImages\phStbRootApp_1.mi' -TmLoadDspImageDefault() \Windows\Desktop.exe: Signalling Launch 21 HostComm: debug messages turned off! OALIoCtlQueryDispSettings() to be implemented Lyg.p: Layout Manager successfully initialized to 1 RTC: Setting alarm time via SetAlarmTime() not supported phStbRoot: started (TM). qRTC: Use RTC driver IOCTRL instead NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! \Windows\Desktop.exe: Setting up Debug Levels... Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Enabling flags 0xffffffff for component 'StbFileRead' Component: 'StbFileRead' - flags: 0xffffffff 4294967295 037777777777 0xffffffff: all Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Named flag = 0x100 256 Named flag = 0x200 512 Named flag = 0x8000 32768 Enabling flags 0x00008300 for component 'StbVideoRenderer' Component: 'StbVideoRenderer' - flags: 0x00008300 33536 0101400 0x00008000: warning 0x00000100: level_1 0x00000200: level_2 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Named flag = 0x400 1024 Named flag = 0x800 2048 Enabling flags 0x00000c00 for component 'StbAudioRenderer' Component: 'StbAudioRenderer' - flags: 0x00000c00 3072 06000 0x00000400: level_3 0x00000800: level_4 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Enabling flags 0xffffffff for component 'phFileRead' Component: 'phFileRead' - flags: 0xffffffff 4294967295 037777777777 0xffffffff: all RTC: Setting alarm time via SetAlarmTime() not supported Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 RTC: Use RTC driver IOCTRL instead Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! Setting up DesktopDisplay for mode 'pal' RTC: Setting alarm time via SetAlarmTime() not supported TmDesktopDisplay_Setup Using TV mode 'pal' RTC: Use RTC driver IOCTRL instead NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! TmSetupVideoScalerFilter(layer=4, type=1, content=2, fLevel=2, bpLevel=1, peakLevel=15) RTC: Setting alarm time via SetAlarmTime() not supported RTC: Use RTC driver IOCTRL instead NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! RTC: Setting alarm time via SetAlarmTime() not supported RTC: Use RTC driver IOCTRL instead \Windows\Desktop.exe: Setting up Z Order... NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! Setting up ZOrder RTC: Setting alarm time via SetAlarmTime() not supported phStbVideoRenderer_GetInstance - 0x0 RTC: Use RTC driver IOCTRL instead phStbVideoRenderer_SetZOrder - 0x0 NKRtcDrvSetAlarmTime: Error (GLE=0x0032)! Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 AnalogVideoSetMode 'pal' \Windows\Desktop.exe: SetScart to output... \Windows\Desktop.exe: Waiting forever
