FlashReader V1.0.2.1, built Sep 4 2006 22:24:11 with ECC Bootscript version 0x00130001 Hynix, 8bit, 64MB PNX8550 Exception handlers: TLB Miss handler patched original 0x80108700 (32 instr.) patched 0x8014B924 (39 instr.) GeneralException handler patched: original 0x80108B84 (596 instr.) patched 0x8014B86C (7 instr.) Windows CE Kernel for MIPS Built on Mar 29 2005 at 14:00:54 INFO:OALLogSetZones: g_oalLogMask: 0x3b4ffffb Telegent Kernel V0.9.3.16, built Sep 4 2006 22:23:55 TargetCfg: Bootscript = V 00130001 PLATFORM = EVO1_11 RAMSIZE = 256 FLASH = cfgFLASH PlatformID = 0x10011 (bootscript: 0x00010014) HardwareID = 0xFFFFFFFF.FFFFFFFF Manf. ID = 0x54476D62.33533046 UUID = {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF} L1 Cache: Flags 0x0000 Instruction: SetsPerWay 256 NumWays 2 LineSize 0x0020 Size 0x4000 Data : SetsPerWay 128 NumWays 4 LineSize 0x0020 Size 0x4000 L2 Cache: Flags 0x0000 Instruction: SetsPerWay 0 NumWays 0 LineSize 0x0000 Size 0x0000 Data : SetsPerWay 0 NumWays 0 LineSize 0x0000 Size 0x0000 OALArgsQuery::OAL_ARGS_QUERY_RTC called! OEMGetExtensionDRAM start=0x89a00000, length=0x02b00000 OALIoCtlHalPostInit() stub +OALInitVarsRTC() -OALInitVarsRTC() OEMIoControl: Unsupported Code 0x101008c - device 0x0101 func 35 OALIoCtlHalInitRegistry::stub OEMIoControl: Unsupported Code 0x10100d0 - device 0x0101 func 52 OALIoCtlHalGetHWEntropy() stub MapPNX8550Mmio: Ramsize = 256 MB DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\AFD). Driver cannot be unloaded. DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PPP). Driver cannot be unloaded. DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\SNMP). Driver cannot be unloaded. MapPNX8550Mmio: Ramsize = 256 MB SetAnalogVideoMode 0 TG_Anabel::Init SetScart to output... TG_Scart::Init Setting up video output for mode 'pal', width=720, height=576, stride=1440 CStreamDriver::init(): created device RTC1 SBM_Init MapPNX8550Mmio: Ramsize = 256 MB OALIoCtlHalUpdateRTC() Initial update: 2010/8/31 21:3:18.000, ticks=3508) ISP1561 OHCI: Compiled Sep 4 2006 22:23:05 ISP1561 OHCI: USB\HCD\OHC DllMain ISP1561 EHCI: Compiled Sep 4 2006 22:23:13 ISP1561 EHCI: USB\USB20\EHCI DllMain Atapi!CDisk::ResetController> Device is busy; 9 seconds remaining Atapi!CDisk::ResetController> Device is ready Atapi!CDisk::InitController> Device 0: Waiting 500ms before Identify Atapi!CDisk::IsDevicePresent> Device 0 is present Atapi!CDisk::SendExecuteDeviceDiagnostic> Device 0 passed, Device 1 passed or not present Atapi!CDisk::SendExecuteDeviceDiagnostic> ATA device Atapi!CDisk::Identify> Assuming direct-access device (hard disk drive) Atapi!CDisk::InitController> Device responded to identify Atapi!CDisk::Init> Enabled write cache Atapi!CDisk::Init> Enabled read look-ahead Atapi!CDisk::ResetController> Device is ready Atapi!CDisk::ResetController> SRST failed Atapi!CDisk::InitController> Device 0: Retrying to reset controller (remaining attempts 2) Atapi!CDisk::ResetController> Device is ready Atapi!CDisk::ResetController> SRST failed Atapi!CDisk::InitController> Device 0: Retrying to reset controller (remaining attempts 1) Atapi!CDisk::ResetController> Device is ready Atapi!CDisk::ResetController> SRST failed Atapi!CDisk::InitController> Device 0: Retrying to reset controller (remaining attempts 0) Atapi!CDisk::Init> Failed to initialize device DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PCI\Instance\DP838161). Driver cannot be unloaded. TG DP8381 Macphyter: DLL_PROCESS_ATTACH NdisMPciAssignResources(0x5AAF0, 0) DP83816:DP83816Initialize() Adapter->IRQ = 0x7 tmman.c:sysBisInit: totalRamSize = 0x10000000 BIS Entry 1: Key 'ShCa' Value1=0x0C500000 Value2=0x0ED00000 BIS Entry 2: Key 'ShNC' Value1=0x0ED00000 Value2=0x0FF00000 BIS Entry 3: Key 'IpNC' Value1=0x0FF00000 Value2=0x0FFFF000 BIS Entry 4: Key 'Dma0' Value1=0x00000000 Value2=0x10000000 BIS Entry 5: Key 'BisC' Value1=0x6B577856 Value2=0x7073424D BIS Entry 6: Key 'Xio ' Value1=0x10000000 Value2=0x18000000 HalHandle: 0x5be80 MMIO: Len=0x200000, Addr=0x4cb00000 SDRAM: Len=0x1000000, Addr=0x4e000000 Device Vendor Id: 0x0 Subsystem Id: 0x0 Class Revision Id: 0x0 ++tmman32:tmmanInitialize() --tmman32:tmmanInitialize() Global.DSPCount=1 MapPNX8550Mmio: Ramsize = 256 MB pnx8550_init_module : mapped VMSP buffer virt 50000000, phys 0ee00000 pnx8550 debug: vmsp_init, index 0, base 00118000 VMSP module id = 010e8107 downloaded 715 instructions to VMSP0 VMSP PC = 0000000d pnx8550 debug: vmsp_init, index 1, base 00120000 VMSP module id = 010e8107 downloaded 715 instructions to VMSP1 VMSP PC = 0000000d VMSP_CLOCK = 000003f7 DMX: created device DMX1 DMX: created device DMX2 VMSP timer thread started MapPNX8550Mmio: Ramsize = 256 MB SCU_Init: created device SCU1 +CFeProbe::run[1] CFeProbe::run[1]: probing frontend 'fe_tda10023'! FEN_Init: Inititalization via RegisterDevice: using Context=257 as index (dll loaded by fe_loader)! FEN_Init: failed creating device FEN1 CFeProbe::run[1]: probing failed for 'fe_tda10023' for 'FEN1:'! CFeProbe::run[1]: probing frontend 'fe_tda1004x'! FEN_Init: Inititalization via RegisterDevice: using Context=257 as index (dll loaded by fe_loader)! +CFeProbe::run[2] CFeProbe::run[2]: probing frontend 'fe_tda10023'! FEN_Init: Inititalization via RegisterDevice: using Context=258 as index (dll loaded by fe_loader)! FEN_Init: failed creating device FEN2 CFeProbe::run[2]: probing failed for 'fe_tda10023' for 'FEN2:'! CFeProbe::run[2]: probing frontend 'fe_tda1004x'! FEN_Init: Inititalization via RegisterDevice: using Context=258 as index (dll loaded by fe_loader)! ERROR: c:\wince500\platform\telegent\src\drivers\dvb\frontend\tda1004x\ctda1004x.cpp line 1327: tda1004x: timeout waiting for DSP ready tda1004x: found firmware revision 0 -- invalid tda1004x: waiting for firmware upload... ERROR: c:\wince500\platform\telegent\src\drivers\dvb\frontend\tda1004x\ctda1004x.cpp line 1327: tda1004x: timeout waiting for DSP ready tda1004x: found firmware revision 0 -- invalid tda1004x: waiting for firmware upload... CStreamDriver::init(): created device PIP1 CStreamDriver::init(): created device PIP2 tda1004x: found firmware revision 29 -- ok FEN_Init: created device FEN1 CFeProbe::run[1]: using 'fe_tda1004x' for 'FEN1:'! -CFeProbe::run[1] CStreamDriver::init(): created device PIP3 tda1004x: found firmware revision 29 -- ok FEN_Init: created device FEN2 CFeProbe::run[2]: using 'fe_tda1004x' for 'FEN2:'! -CFeProbe::run[2] CStreamDriver::init(): created device PIP4 CStreamDriver::init(): created device PIP5 CStreamDriver::init(): created device PIP6 CStreamDriver::init(): created device PIP7 CStreamDriver::init(): created device PIP8 CStreamDriver::init(): created device PIP9 ++tmman32:tmmanInitialize() --tmman32:tmmanInitialize() Global.DSPCount=1 tmman:TARGET:namespaceOpen:Slot#[0]:Type[4]:Idx[0]:Name[TMManVIntr] tmman:TARGET:namespaceOpen:Slot#[1]:Type[4]:Idx[1]:Name[TMManChannel] tmman:TARGET:namespaceOpen:Slot#[2]:Type[4]:Idx[2]:Name[TMManEvent] tmman:TARGET:namespaceOpen:Slot#[3]:Type[4]:Idx[3]:Name[DemuxMemory] tmman:namespaceOpen:Name[StbRpc]:NON EXISTENT:FAIL MapPNX8550Mmio: Ramsize = 256 MB TG_Tgc1Init() Desktop - started Desktop Enter MapPNX8550Mmio: Ramsize = 256 MB Loading DSP Image... +TmLoadDspImageDefault() Image='\Windows\phStbRootApp.mi' TmLoadDspImageFromFile: '\Windows\phStbRootApp.mi' DSP image file '\Windows\phStbRootApp.mi' not found! Hynix, 8bit, 64MB DSP Image found Trying to load DSP Image from flash Loading DSP image at 0x08000000 (=128MB) Seconds for Loading image (bytes read=10737364): 2 Patching image using symbol information in '\Windows\phStbRootApp.sym' Symbol '_RealTMManShared' found: Line 0: '_RealTMManShared 0x08a32c94 data ' Symbol TMManShared (address 0xA8A32C94) patched with 0x0ed00000 DSP image downloaded TmLoadDspImageDefault() returns 1 HostComm: debug messages turned off! phStbRoot: started (TM). 0Setting up Debug Levels... Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Enabling flags 0xffffffff for component 'StbFileRead' Component: 'StbFileRead' - flags: 0xffffffff 4294967295 037777777777 0xffffffff: all Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Named flag = 0x100 256 Named flag = 0x200 512 Named flag = 0x8000 32768 Enabling flags 0x00008300 for component 'StbVideoRenderer' Component: 'StbVideoRenderer' - flags: 0x00008300 33536 0101400 0x00008000: warning 0x00000100: level_1 0x00000200: level_2 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Named flag = 0x400 1024 Named flag = 0x800 2048 Enabling flags 0x00000c00 for component 'StbAudioRenderer' Component: 'StbAudioRenderer' - flags: 0x00000c00 3072 06000 0x00000400: level_3 0x00000800: level_4 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Enabling flags 0xffffffff for component 'phFileRead' Component: 'phFileRead' - flags: 0xffffffff 4294967295 037777777777 0xffffffff: all Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 Setting up DesktopDisplay for mode 'pal' TmDesktopDisplay_Setup Using TV mode 'pal' Setting up Z Order... Setting up ZOrder phStbVideoRenderer_GetInstance - 0x0 phStbVideoRenderer_SetZOrder - 0x0 Rpc call (phStbRpc_InternalFun_Cmd) => 0x0 AnalogVideoSetMode 'pal' SetScart to output... \Windows\Desktop.exe: Signalling Launch 21 OALIoCtlQueryDispSettings() to be implemented Lyg.p: Layout Manager successfully initialized to 1 Hotkeys - started \Windows\HotKeys.exe: Signalling Launch 31 SBM: Switching from feedMode=1 to 1 Search paths for 'HotKeys.xml' 1. '\Release\TestMedia' 2. '\USBDisk' 3. '\USBDisk\TestMedia' 4. '\HardDisk' 5. '\windows' Configuration file 'HotKeys.xml' not found in directory list SBM: Switching from feedMode=1 to 1 Hotkeys exiting RTC: Setting alarm tima via SetAlarmTime() not supported RTC: Use RTC driver IOCTRL instead NKRtcDrvSetRealTime: Error (GLE=0x0032)! Explorer(V2.0) taskbar thread started. NDISPWR:: Found adapter [PCI\DP838161]
