jens@jens-linux:~/Desktop/arduino-0022/hardware/tools$ sudo avrdude -c dapa -p m8 -P /dev/parport0 -n -v [sudo] password for jens: avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "/etc/avrdude.conf" User configuration file is "/home/jens/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/parport0 Using Programmer : dapa AVR Part : ATMEGA8 Chip Erase delay : 10000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00 lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : PPI Description : Direct AVR Parallel Access cable VCC = 3 BUFF = (not used) RESET = 16 SCK = 1 MOSI = 2 MISO = 11 ERR LED = 0 RDY LED = 0 PGM LED = 0 VFY LED = 0 avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9307 avrdude: safemode: lfuse reads as FF avrdude: safemode: hfuse reads as D9 avrdude: safemode: lfuse reads as FF avrdude: safemode: hfuse reads as D9 avrdude: safemode: Fuses OK avrdude done. Thank you. jens@jens-linux:~/Desktop/arduino-0022/hardware/tools$ ############################################################################### ############################################################################### jens@jens-linux:~/Desktop/arduino-0022/hardware/tools$ sudo avrdude -c dapa -p m8 -P /dev/parport0 -U hfuse:w:0xca:m -U lfuse:w:0xdf:m avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9307 avrdude: reading input file "0xca" avrdude: writing hfuse (1 bytes): Writing | | 0% 0.00s ***failed; Writing | ################################################## | 100% 0.02s avrdude: 1 bytes of hfuse written avrdude: verifying hfuse memory against 0xca: avrdude: load data hfuse data from input file 0xca: avrdude: input file 0xca contains 1 bytes avrdude: reading on-chip hfuse data: Reading | ################################################## | 100% 0.00s avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0000 0xca != 0xff avrdude: verification error; content mismatch avrdude: safemode: hfuse changed! Was ca, and is now ff Would you like this fuse to be changed back? [y/n]
