<5>Linux version 2.6.21.3PNX8550 (root@smithy) (gcc version 4.0.0 (DENX ELDK 4.0 4.0.0)) #1743 Fri Feb 11 10:49:15 OMST 2011 <4>Setting initial splash screen display mode SD (50Hz) <4>CPU revision is: 00061200 <4>Determined physical RAM map: <4> memory: 07000000 @ 00000000 (usable) <6>Initrd not found or empty - disabling initrd <7>On node 0 totalpages: 28672 <7> DMA zone: 224 pages used for memmap <7> DMA zone: 0 pages reserved <7> DMA zone: 28448 pages, LIFO batch:7 <7> Normal zone: 0 pages used for memmap <4>Built 1 zonelists. Total pages: 28448 <5>Kernel command line: console=ttyS0 stb810_display=pal root=/dev/nfs nfsroot=192.168.85.27:/home/pollinfs ip=dhcp nomainapp=1 <4>Primary instruction cache 16kB, physically tagged, 2-way, linesize 32 bytes. <4>Primary data cache 16kB, 4-way, linesize 32 bytes. <6>Synthesized TLB refill handler (23 instructions). <6>Synthesized TLB load handler fastpath (32 instructions). <6>Synthesized TLB store handler fastpath (32 instructions). <6>Synthesized TLB modify handler fastpath (31 instructions). <4>PID hash table entries: 512 (order: 9, 2048 bytes) <4>Using 250.714 MHz high precision timer. <4>Console: colour dummy device 80x25 <4>Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) <4>Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) <6>Memory: 107648k/114688k available (2841k kernel code, 6996k reserved, 518k data, 2044k init, 0k highmem) <7>Calibrating delay loop... 249.34 BogoMIPS (lpj=498688) <4>Mount-cache hash table entries: 512 <6>NET: Registered protocol family 16 <4>registering PCI controller with io_map_base unset <5>SCSI subsystem initialized <6>usbcore: registered new interface driver usbfs <6>usbcore: registered new interface driver hub <6>usbcore: registered new device driver usb <6>Time: MIPS clocksource has been installed. <6>NET: Registered protocol family 2 <4>IP route cache hash table entries: 1024 (order: 0, 4096 bytes) <4>TCP established hash table entries: 4096 (order: 3, 32768 bytes) <4>TCP bind hash table entries: 4096 (order: 2, 16384 bytes) <6>TCP: Hash tables configured (established 4096 bind 4096) <6>TCP reno registered <6>NTFS driver 2.1.28 [Flags: R/O]. <6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. <6>io scheduler noop registered <6>io scheduler anticipatory registered (default) <4>Register GPIO SPI device <6>Serial: PNX8XXX driver $Revision: 1.2 $ <6>pnx8xxx-uart: ttyS0 at MMIO 0xbbe4a000 (irq = 27) is a PNX8XXX <6>pnx8xxx-uart: ttyS1 at MMIO 0xbbe4b000 (irq = 28) is a PNX8XXX <6>natsemi dp8381x driver, version 2.1, Sept 11, 2006 <6> originally by Donald Becker <6> http://www.scyld.com/network/natsemi.html <6> 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder <4>PCI: Enabling device 0000:00:0a.0 (0000 -> 0003) <7>PCI: Setting latency timer of device 0000:00:0a.0 to 64 <6>natsemi eth0: NatSemi DP8381[56] at 0x20092000 (0000:00:0a.0), 00:18:f3:79:9f:63, IRQ 55, port TP. <6>Driver for NAND Flash on the PNX8550 XIO bus (Mar 15 2010-17:54:27) <6>Auto detected a >= 64MByte device on a 8 bit bus <6>NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) <6>Scanning device for bad blocks <5>Creating 9 MTD partitions on "NAND 64MiB 3,3V 8-bit": <5>0x00000000-0x00004000 : "microBTM" <5>0x00004000-0x00040000 : "bootloader" <5>0x00040000-0x00600000 : "Updater" <5>0x00600000-0x00d00000 : "Kernel" <5>0x00d00000-0x00ff8000 : "Sys-Config" <5>0x00ff8000-0x01000000 : "HW-Config" <5>0x01000000-0x02400000 : "Root" <5>0x02400000-0x03e00000 : "User" <5>0x03e00000-0x04000000 : "Profile" <4>PCI: Enabling device 0000:00:09.2 (0000 -> 0002) <7>PCI: Setting latency timer of device 0000:00:09.2 to 64 <6>ehci_hcd 0000:00:09.2: EHCI Host Controller <6>ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1 <6>ehci_hcd 0000:00:09.2: irq 55, io mem 0x20093200 <6>ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004 <6>usb usb1: configuration #1 chosen from 1 choice <6>hub 1-0:1.0: USB hub found <6>hub 1-0:1.0: 4 ports detected <7>ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver <6>pnx8550-ohci pnx8550-ohci: PNX8550 OHCI <6>pnx8550-ohci pnx8550-ohci: new USB bus registered, assigned bus number 2 <6>pnx8550-ohci pnx8550-ohci: irq 13, io mem 0x1be48000 <6>usb usb2: configuration #1 chosen from 1 choice <6>hub 2-0:1.0: USB hub found <6>hub 2-0:1.0: 2 ports detected <4>PCI: Enabling device 0000:00:09.0 (0000 -> 0002) <7>PCI: Setting latency timer of device 0000:00:09.0 to 64 <6>ohci_hcd 0000:00:09.0: OHCI Host Controller <6>ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 3 <6>ohci_hcd 0000:00:09.0: irq 55, io mem 0x20090000 <6>usb usb3: configuration #1 chosen from 1 choice <6>hub 3-0:1.0: USB hub found <6>hub 3-0:1.0: 2 ports detected <4>PCI: Enabling device 0000:00:09.1 (0000 -> 0002) <7>PCI: Setting latency timer of device 0000:00:09.1 to 64 <6>ohci_hcd 0000:00:09.1: OHCI Host Controller <6>ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 4 <6>ohci_hcd 0000:00:09.1: irq 55, io mem 0x20091000 <6>usb usb4: configuration #1 chosen from 1 choice <6>hub 4-0:1.0: USB hub found <6>hub 4-0:1.0: 2 ports detected <6>usb 3-2: new low speed USB device using ohci_hcd and address 2 <6>usb 3-2: configuration #1 chosen from 1 choice <6>USB Universal Host Controller Interface driver v3.0 <6>Initializing USB Mass Storage driver... <6>usbcore: registered new interface driver usb-storage <6>USB Mass Storage support registered. <6>mice: PS/2 mouse device common for all mice <6>i2c /dev entries driver <6>TCP cubic registered <6>NET: Registered protocol family 1 <6>NET: Registered protocol family 17 <5>Bridge firewalling registered <6>802.1Q VLAN Support v1.8 Ben Greear <6>All bugs added by David S. Miller <6>ieee80211: 802.11 data/management/control stack, git-1.1.13 <6>ieee80211: Copyright (C) 2004-2005 Intel Corporation <7>ieee80211_crypt: registered algorithm 'NULL' <6>eth0: DSPCFG accepted after 0 usec. <5>eth0: link up. <6>eth0: Setting full-duplex based on negotiated link capability. <5>Sending DHCP requests .<5>eth0: increased tx threshold, txcfg 0xd0f01004. <4>., OK <4>IP-Config: Got DHCP answer from 192.168.85.27, my address is 192.168.85.184 <4>IP-Config: Complete: <4> device=eth0, addr=192.168.85.184, mask=255.255.255.0, gw=192.168.85.1, <4> host=192.168.85.184, domain=federation, nis-domain=(none), <4> bootserver=192.168.85.27, rootserver=192.168.85.27, rootpath= <6>Freeing unused kernel memory: 2044k freed <4>Algorithmics/MIPS FPU Emulator v1.5 <6>Luddite version 3, exported Mon Apr 25 10:40:08 BST 2005 <4>TM0: detected clock 270000000 <4>lud_core: Registering devfs device 0/lud <4>TM1: detected clock 270000000 <4>lud_core: Registering devfs device 1/lud <4>NXP /proc entries driver (Aug 13 2007-11:59:40) <4>PNX8550 GPIO driver (Aug 13 2007-11:59:32) <4>PNX8550 MMIO Driver (Aug 13 2007-11:59:38) <4>RTC driver (Aug 13 2007-11:59:41) <4>sfb: module license 'Proprietary' taints kernel. <3>Setting initial splash screen display mode SD (50Hz) <4>i2c-algo-IP3203.o: i2c IP3203 algorithm module <4>i2c-algo-IP0105.o: i2c IP0105 algorithm module <6>RTC driver: System time is 01/01/2005 01:31:26 <4>Shutting down RTC driver <4>Shutting down PNX8550 MMIO Driver <6>Shutting down PNX8550 GPIO driver <4>Shutting down NXP /proc entries driver <6>Luddite version 3, exported Mon Apr 25 10:40:08 BST 2005 <7>TM0: detected clock 270000000 <7>lud_core: Registering devfs device 0/lud <7>TM1: detected clock 270000000 <7>lud_core: Registering devfs device 1/lud <7>NXP /proc entries driver (Aug 13 2007-11:59:40) <6>dspinfo: Initialising DSP Info Driver <7>PNX8550 MMIO Driver (Aug 13 2007-11:59:38) <6>dspmem: Initialising DSP memory Driver <7>Philips PNX8550 Demux HW driver (Aug 13 2007-11:59:14) <7>DVB: registering new adapter (pnx8550vmsp0). <7>DVB: registering frontend 0 (Philips TDA10046H DVB-T)... <7>DVB: registering new adapter (pnx8550vmsp1). <7>DVB: registering frontend 1 (Philips TDA10046H DVB-T)... <7>DVB: registering new adapter (pnx8550pdma0). <7>DVB: registering new adapter (pnx8550pdma1). <7>NXP PNX8550 DVB adapter driver <7>Analog Backend driver (Aug 13 2007-11:59:55) <7>AK470X (AV Scart switch) driver (Aug 13 2007-11:59:57) - Device AK4706 Loopthrough disabled <7>SAA8510 (Anabel) driver <6>Using specified video mode (PAL-RGB) <6>vdenc0: PNX8510 Driver video denc device <6>Using specified video mode (PAL-CVBS) <6>vdenc1: PNX8550 Internal Vdenc video denc device <7>Dbg driver (Feb 20 2008-12:40:20) <7>TriMedia RPC driver <7>Debug Buffer Print driver (Aug 13 2007-11:59:09) <6>RTC driver: System time is 01/01/2005 01:31:33 <7>RTC driver (Aug 13 2007-11:59:41) <7>PNX8550 GPIO driver (Aug 13 2007-11:59:32) <7>STB-810 ALSA Audio Driver (Aug 13 2007-11:59:07) <6>pnxdraw: Initialised (Compiled Aug 13 2007-11:59:22) <4>Symbol usb_register_driver is being used by a non-GPL module, which will not be allowed in the future <4>Please see the file Documentation/feature-removal-schedule.txt in the kernel source tree for more details. <4>Symbol usb_deregister is being used by a non-GPL module, which will not be allowed in the future <4>Please see the file Documentation/feature-removal-schedule.txt in the kernel source tree for more details. <4>rtusb init ---> <6>usbcore: registered new interface driver rt2870 <4>Luddite 0: [ Mon Apr 25 10:40:08 BST 2005 tm32v2 TCS4.50 NDK (tmosal)] started <4>Luddite 1: [ Mon Apr 25 10:40:08 BST 2005 tm32v2 TCS4.50 NDK (tmosal)] started <7>phStbStreamingSystem kernel module proxy (Aug 13 2007-11:59:48) <7>Video Layer driver (Aug 13 2007-11:59:53) <7>5L: You have chosen an output format of 'pal' <7>2L: You have chosen an output format of 'pal' <7>Video Renderer driver (5L created) (Aug 13 2007-11:59:51) <7>FBRead Driver (Aug 13 2007-11:59:46) <7>Framebuffer driver: Using Format:ARGB8888 Width:720 Height:576 renderer_id=0 <7>Framebuffer driver: Created FBRead Resource:0 StbFBRead0 buffer:0xF500000 <7>Framebuffer driver: You have a non scaled output resolution <7>Framebuffer driver (Aug 13 2007-11:59:30) w=720 h=576 bytespp=4 <6>DSP Pipe driver Init <6>input: HID Keyboard Device as /class/input/input0 <6>input: USB HID v1.10 Keyboard [HID Keyboard Device] on usb-0000:00:09.0-2 <6>input: HID Keyboard Device as /class/input/input1 <6>input: USB HID v1.10 Device [HID Keyboard Device] on usb-0000:00:09.0-2 <6>usbcore: registered new interface driver usbhid <6>drivers/usb/input/hid-core.c: v2.6:USB HID core driver
