smartctl 5.40 2010-07-12 r3124 [x86_64-unknown-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.12 family Device Model: ST31000528AS Serial Number: 6VP0KD5L Firmware Version: CC35 User Capacity: 1,000,204,886,016 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: ATA-8-ACS revision 4 Local Time is: Mon May 16 08:58:38 2011 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. See vendor-specific Attribute list for failed Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 600) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 195) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x103f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 080 069 006 Pre-fail Always - 54317579 3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4211 5 Reallocated_Sector_Ct 0x0033 010 010 036 Pre-fail Always FAILING_NOW 3706 7 Seek_Error_Rate 0x000f 036 036 030 Pre-fail Always - 3878360661983 9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 4737 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 099 099 020 Old_age Always - 1401 183 Runtime_Bad_Block 0x0032 076 076 000 Old_age Always - 24 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 139 188 Command_Timeout 0x0032 069 001 000 Old_age Always - 4088871257022 189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2 190 Airflow_Temperature_Cel 0x0022 082 027 045 Old_age Always In_the_past 18 (5 177 18 18) 194 Temperature_Celsius 0x0022 018 073 000 Old_age Always - 18 (0 15 0 0) 195 Hardware_ECC_Recovered 0x001a 046 019 000 Old_age Always - 54317579 197 Current_Pending_Sector 0x0012 093 093 000 Old_age Always - 299 198 Offline_Uncorrectable 0x0010 093 093 000 Old_age Offline - 299 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1524713394887 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1188189617 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2380649118 SMART Error Log Version: 1 ATA Error Count: 510 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 510 occurred at disk power-on lifetime: 4737 hours (197 days + 9 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 04 9d 00 32 e0 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- a1 00 00 00 00 00 a0 00 00:00:47.531 IDENTIFY PACKET DEVICE ec 00 00 00 00 00 a0 00 00:00:47.531 IDENTIFY DEVICE 00 00 00 00 00 00 00 04 00:00:47.376 NOP [Abort queued commands] 00 00 00 00 00 00 00 04 00:00:47.211 NOP [Abort queued commands] 00 00 00 00 00 00 00 ff 00:00:46.891 NOP [Abort queued commands] Error 509 occurred at disk power-on lifetime: 4737 hours (197 days + 9 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 04 9d 00 32 e0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 a0 00 00:00:47.531 IDENTIFY DEVICE 00 00 00 00 00 00 00 04 00:00:47.376 NOP [Abort queued commands] 00 00 00 00 00 00 00 04 00:00:47.211 NOP [Abort queued commands] 00 00 00 00 00 00 00 ff 00:00:46.891 NOP [Abort queued commands] a1 00 00 00 00 00 a0 00 00:00:41.883 IDENTIFY PACKET DEVICE Error 508 occurred at disk power-on lifetime: 4737 hours (197 days + 9 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 04 9d 00 32 e0 Device Fault; Error: ABRT Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- a1 00 00 00 00 00 a0 00 00:00:41.883 IDENTIFY PACKET DEVICE ec 00 00 00 00 00 a0 00 00:00:41.882 IDENTIFY DEVICE 00 00 00 00 00 00 00 04 00:00:41.726 NOP [Abort queued commands] 00 00 00 00 00 00 00 04 00:00:41.562 NOP [Abort queued commands] 00 00 00 00 00 00 00 ff 00:00:41.243 NOP [Abort queued commands] Error 507 occurred at disk power-on lifetime: 4737 hours (197 days + 9 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 04 9d 00 32 e0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ec 00 00 00 00 00 a0 00 00:00:41.882 IDENTIFY DEVICE 00 00 00 00 00 00 00 04 00:00:41.726 NOP [Abort queued commands] 00 00 00 00 00 00 00 04 00:00:41.562 NOP [Abort queued commands] 00 00 00 00 00 00 00 ff 00:00:41.243 NOP [Abort queued commands] 60 00 08 ff ff ff 4f 00 00:00:38.937 READ FPDMA QUEUED Error 506 occurred at disk power-on lifetime: 4737 hours (197 days + 9 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 04 71 04 9d 00 32 40 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 00:00:38.937 READ FPDMA QUEUED 60 00 f8 ff ff ff 4f 00 00:00:38.697 READ FPDMA QUEUED 60 00 80 ff ff ff 4f 00 00:00:38.676 READ FPDMA QUEUED 60 00 c8 ff ff ff 4f 00 00:00:38.661 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 00:00:38.605 READ FPDMA QUEUED SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
