[ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780 [ 0.000000] initial memory mapped : 0 - 20000000 [ 0.000000] init_memory_mapping: 0000000000000000-00000000bffb0000 [ 0.000000] 0000000000 - 00bfe00000 page 2M [ 0.000000] 00bfe00000 - 00bffb0000 page 4k [ 0.000000] kernel direct mapping tables up to bffb0000 @ 1fffb000-20000000 [ 0.000000] RAMDISK: 366e2000 - 37369000 [ 0.000000] ACPI: RSDP 00000000000f9bb0 00014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 00000000bffb0000 0003C (v01 ACRSYS ACRPRDCT 20081111 ANNI 00000097) [ 0.000000] ACPI: FACP 00000000bffb0200 00084 (v01 111108 FACP0906 20081111 MSFT 00000097) [ 0.000000] ACPI: DSDT 00000000bffb0440 05595 (v01 0AAAA 0AAAA000 00000000 INTL 20051117) [ 0.000000] ACPI: FACS 00000000bffbe000 00040 [ 0.000000] ACPI: APIC 00000000bffb0390 0006C (v01 111108 APIC0906 20081111 MSFT 00000097) [ 0.000000] ACPI: MCFG 00000000bffb0400 0003C (v01 111108 OEMMCFG 20081111 MSFT 00000097) [ 0.000000] ACPI: OEMB 00000000bffbe040 00071 (v01 111108 OEMB0906 20081111 MSFT 00000097) [ 0.000000] ACPI: GSCI 00000000bffbe0c0 02024 (v01 111108 GMCHSCI 20081111 MSFT 00000097) [ 0.000000] ACPI: SLIC 000000000009f659 00176 (v01 ACRSYS ACRPRDCT 00000001 ANNI 00000001) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] No NUMA configuration found [ 0.000000] Faking a node at 0000000000000000-00000000bffb0000 [ 0.000000] Initmem setup node 0 0000000000000000-00000000bffb0000 [ 0.000000] NODE_DATA [00000000bffab000 - 00000000bffaffff] [ 0.000000] [ffffea0000000000-ffffea00029fffff] PMD -> [ffff8800bc600000-ffff8800beffffff] on node 0 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] DMA32 0x00001000 -> 0x00100000 [ 0.000000] Normal empty [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x000bffb0 [ 0.000000] On node 0 totalpages: 786239 [ 0.000000] DMA zone: 56 pages used for memmap [ 0.000000] DMA zone: 6 pages reserved [ 0.000000] DMA zone: 3921 pages, LIFO batch:0 [ 0.000000] DMA32 zone: 10695 pages used for memmap [ 0.000000] DMA32 zone: 771561 pages, LIFO batch:31 [ 0.000000] ACPI: PM-Timer IO Port: 0x808 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled) [ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 4, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e3000 [ 0.000000] PM: Registered nosave memory: 00000000000e3000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:3ee00000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 28 pages/cpu @ffff8800bfc00000 s84416 r8192 d22080 u524288 [ 0.000000] pcpu-alloc: s84416 r8192 d22080 u524288 alloc=1*2097152 [ 0.000000] pcpu-alloc: [0] 0 1 2 3 [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 775482 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.38-8-generic root=UUID=B2048FB6048F7C5B loop=/ubuntu/disks/root.disk ro quiet splash [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Checking aperture... [ 0.000000] No AGP bridge found [ 0.000000] Calgary: detecting Calgary via BIOS EBDA area [ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing! [ 0.000000] Memory: 3075152k/3145408k available (5940k kernel code, 452k absent, 69804k reserved, 5017k data, 956k init) [ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] RCU-based detection of stalled CPUs is disabled. [ 0.000000] NR_IRQS:16640 nr_irqs:712 16 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] allocated 31457280 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2402.884 MHz processor. [ 0.000004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4805.76 BogoMIPS (lpj=24028840) [ 0.000008] pid_max: default: 32768 minimum: 301 [ 0.000032] Security Framework initialized [ 0.000051] AppArmor: AppArmor initialized [ 0.000053] Yama: becoming mindful. [ 0.010382] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.014002] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.015761] Mount-cache hash table entries: 256 [ 0.015945] Initializing cgroup subsys ns [ 0.015950] ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup. [ 0.015953] Initializing cgroup subsys cpuacct [ 0.015957] Initializing cgroup subsys memory [ 0.015966] Initializing cgroup subsys devices [ 0.015969] Initializing cgroup subsys freezer [ 0.015971] Initializing cgroup subsys net_cls [ 0.015973] Initializing cgroup subsys blkio [ 0.016012] CPU: Physical Processor ID: 0 [ 0.016014] CPU: Processor Core ID: 0 [ 0.016016] mce: CPU supports 6 MCE banks [ 0.016023] CPU0: Thermal monitoring enabled (TM2) [ 0.016028] using mwait in idle threads. [ 0.018444] ACPI: Core revision 20110112 [ 0.021050] ftrace: allocating 24314 entries in 96 pages [ 0.030056] Setting APIC routing to flat [ 0.030355] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.131346] CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz stepping 0b [ 0.140000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver. [ 0.140000] PEBS disabled due to CPU errata. [ 0.140000] ... version: 2 [ 0.140000] ... bit width: 40 [ 0.140000] ... generic registers: 2 [ 0.140000] ... value mask: 000000ffffffffff [ 0.140000] ... max period: 000000007fffffff [ 0.140000] ... fixed-purpose events: 3 [ 0.140000] ... event mask: 0000000700000003 [ 0.140000] Booting Node 0, Processors #1 #2 #3 Ok. [ 0.640008] Brought up 4 CPUs [ 0.640011] Total of 4 processors activated (19135.14 BogoMIPS). [ 0.641708] devtmpfs: initialized [ 0.641708] print_constraints: dummy: [ 0.641708] Time: 18:38:56 Date: 05/17/11 [ 0.641708] NET: Registered protocol family 16 [ 0.641708] Trying to unpack rootfs image as initramfs... [ 0.641708] ACPI: bus type pci registered [ 0.641708] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.641708] PCI: not using MMCONFIG [ 0.641708] PCI: Using configuration type 1 for base access [ 0.660793] bio: create slab at 0 [ 0.661764] ACPI: EC: Detected MSI hardware, enabling workarounds. [ 0.661764] ACPI: EC: Look up EC in DSDT [ 0.662179] ACPI: Executed 1 blocks of module-level executable AML code [ 0.664501] ACPI: Interpreter enabled [ 0.664505] ACPI: (supports S0 S1 S4 S5) [ 0.664522] ACPI: Using IOAPIC for interrupt routing [ 0.664544] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.665559] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources [ 0.704768] ACPI: No dock devices found. [ 0.704772] HEST: Table not found. [ 0.704775] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.704937] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.705105] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] [ 0.705108] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.705110] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.705112] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff] [ 0.705114] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xdfffffff] [ 0.705117] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xffffffff] [ 0.705130] pci 0000:00:00.0: [8086:29c0] type 0 class 0x000600 [ 0.705169] pci 0000:00:01.0: [8086:29c1] type 1 class 0x000604 [ 0.705198] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold [ 0.705201] pci 0000:00:01.0: PME# disabled [ 0.705241] pci 0000:00:1a.0: [8086:2937] type 0 class 0x000c03 [ 0.705284] pci 0000:00:1a.0: reg 20: [io 0xbc00-0xbc1f] [ 0.705326] pci 0000:00:1a.1: [8086:2938] type 0 class 0x000c03 [ 0.705366] pci 0000:00:1a.1: reg 20: [io 0xb880-0xb89f] [ 0.705417] pci 0000:00:1a.7: [8086:293c] type 0 class 0x000c03 [ 0.705436] pci 0000:00:1a.7: reg 10: [mem 0xf9fffc00-0xf9ffffff] [ 0.705506] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold [ 0.705511] pci 0000:00:1a.7: PME# disabled [ 0.705535] pci 0000:00:1b.0: [8086:293e] type 0 class 0x000403 [ 0.705549] pci 0000:00:1b.0: reg 10: [mem 0xf9ff8000-0xf9ffbfff 64bit] [ 0.705599] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold [ 0.705602] pci 0000:00:1b.0: PME# disabled [ 0.705620] pci 0000:00:1c.0: [8086:2940] type 1 class 0x000604 [ 0.705670] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.705674] pci 0000:00:1c.0: PME# disabled [ 0.705696] pci 0000:00:1c.4: [8086:2948] type 1 class 0x000604 [ 0.705753] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold [ 0.705756] pci 0000:00:1c.4: PME# disabled [ 0.705778] pci 0000:00:1c.5: [8086:294a] type 1 class 0x000604 [ 0.705828] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold [ 0.705831] pci 0000:00:1c.5: PME# disabled [ 0.705853] pci 0000:00:1d.0: [8086:2934] type 0 class 0x000c03 [ 0.705893] pci 0000:00:1d.0: reg 20: [io 0xb800-0xb81f] [ 0.705939] pci 0000:00:1d.1: [8086:2935] type 0 class 0x000c03 [ 0.705979] pci 0000:00:1d.1: reg 20: [io 0xb480-0xb49f] [ 0.706020] pci 0000:00:1d.2: [8086:2936] type 0 class 0x000c03 [ 0.706060] pci 0000:00:1d.2: reg 20: [io 0xb400-0xb41f] [ 0.706106] pci 0000:00:1d.3: [8086:2939] type 0 class 0x000c03 [ 0.706147] pci 0000:00:1d.3: reg 20: [io 0xb080-0xb09f] [ 0.706196] pci 0000:00:1d.7: [8086:293a] type 0 class 0x000c03 [ 0.706215] pci 0000:00:1d.7: reg 10: [mem 0xf9fff800-0xf9fffbff] [ 0.706289] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.706293] pci 0000:00:1d.7: PME# disabled [ 0.706312] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604 [ 0.706364] pci 0000:00:1f.0: [8086:2918] type 0 class 0x000601 [ 0.706445] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0a00 (mask 00ff) [ 0.706484] pci 0000:00:1f.2: [8086:2921] type 0 class 0x000101 [ 0.706498] pci 0000:00:1f.2: reg 10: [io 0xb000-0xb007] [ 0.706505] pci 0000:00:1f.2: reg 14: [io 0xac00-0xac03] [ 0.706513] pci 0000:00:1f.2: reg 18: [io 0xa880-0xa887] [ 0.706520] pci 0000:00:1f.2: reg 1c: [io 0xa800-0xa803] [ 0.706528] pci 0000:00:1f.2: reg 20: [io 0xa480-0xa48f] [ 0.706535] pci 0000:00:1f.2: reg 24: [io 0xa400-0xa40f] [ 0.706576] pci 0000:00:1f.3: [8086:2930] type 0 class 0x000c05 [ 0.706590] pci 0000:00:1f.3: reg 10: [mem 0xf9fff400-0xf9fff4ff 64bit] [ 0.706609] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f] [ 0.706639] pci 0000:00:1f.5: [8086:2926] type 0 class 0x000101 [ 0.706654] pci 0000:00:1f.5: reg 10: [io 0xa000-0xa007] [ 0.706661] pci 0000:00:1f.5: reg 14: [io 0x9c00-0x9c03] [ 0.706668] pci 0000:00:1f.5: reg 18: [io 0x9880-0x9887] [ 0.706676] pci 0000:00:1f.5: reg 1c: [io 0x9800-0x9803] [ 0.706683] pci 0000:00:1f.5: reg 20: [io 0x9480-0x948f] [ 0.706691] pci 0000:00:1f.5: reg 24: [io 0x9400-0x940f] [ 0.706762] pci 0000:01:00.0: [10de:0600] type 0 class 0x000300 [ 0.706771] pci 0000:01:00.0: reg 10: [mem 0xfd000000-0xfdffffff] [ 0.706782] pci 0000:01:00.0: reg 14: [mem 0xd0000000-0xdfffffff 64bit pref] [ 0.706792] pci 0000:01:00.0: reg 1c: [mem 0xfa000000-0xfbffffff 64bit] [ 0.706799] pci 0000:01:00.0: reg 24: [io 0xcc00-0xcc7f] [ 0.706807] pci 0000:01:00.0: reg 30: [mem 0xfe9e0000-0xfe9fffff pref] [ 0.706847] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.706851] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.706854] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfe9fffff] [ 0.706859] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref] [ 0.706900] pci 0000:00:1c.0: PCI bridge to [bus 02-02] [ 0.706904] pci 0000:00:1c.0: bridge window [io 0xf000-0x0000] (disabled) [ 0.706908] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff] (disabled) [ 0.706913] pci 0000:00:1c.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled) [ 0.706966] pci 0000:03:00.0: [11ab:6121] type 0 class 0x000101 [ 0.706982] pci 0000:03:00.0: reg 10: [io 0xdc00-0xdc07] [ 0.706994] pci 0000:03:00.0: reg 14: [io 0xd880-0xd883] [ 0.707005] pci 0000:03:00.0: reg 18: [io 0xd800-0xd807] [ 0.707017] pci 0000:03:00.0: reg 1c: [io 0xd480-0xd483] [ 0.707028] pci 0000:03:00.0: reg 20: [io 0xd400-0xd40f] [ 0.707040] pci 0000:03:00.0: reg 24: [mem 0xfeaffc00-0xfeafffff] [ 0.707082] pci 0000:03:00.0: supports D1 [ 0.707084] pci 0000:03:00.0: PME# supported from D0 D1 D3hot [ 0.707088] pci 0000:03:00.0: PME# disabled [ 0.707105] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.707113] pci 0000:00:1c.4: PCI bridge to [bus 03-03] [ 0.707118] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff] [ 0.707122] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff] [ 0.707128] pci 0000:00:1c.4: bridge window [mem 0xfff00000-0x000fffff pref] (disabled) [ 0.707189] pci 0000:04:00.0: [10ec:8168] type 0 class 0x000200 [ 0.707207] pci 0000:04:00.0: reg 10: [io 0xe800-0xe8ff] [ 0.707237] pci 0000:04:00.0: reg 18: [mem 0xfebff000-0xfebfffff 64bit] [ 0.707272] pci 0000:04:00.0: reg 30: [mem 0xfebc0000-0xfebdffff pref] [ 0.707317] pci 0000:04:00.0: supports D1 D2 [ 0.707319] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold [ 0.707324] pci 0000:04:00.0: PME# disabled [ 0.707346] pci 0000:04:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force' [ 0.707355] pci 0000:00:1c.5: PCI bridge to [bus 04-04] [ 0.707358] pci 0000:00:1c.5: bridge window [io 0xe000-0xefff] [ 0.707362] pci 0000:00:1c.5: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.707367] pci 0000:00:1c.5: bridge window [mem 0xfff00000-0x000fffff pref] (disabled) [ 0.707429] pci 0000:00:1e.0: PCI bridge to [bus 05-05] (subtractive decode) [ 0.707432] pci 0000:00:1e.0: bridge window [io 0xf000-0x0000] (disabled) [ 0.707436] pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff] (disabled) [ 0.707441] pci 0000:00:1e.0: bridge window [mem 0xfff00000-0x000fffff pref] (disabled) [ 0.707444] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.707446] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.707448] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.707450] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff] (subtractive decode) [ 0.707453] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff] (subtractive decode) [ 0.707455] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xffffffff] (subtractive decode) [ 0.707475] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.707564] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT] [ 0.707650] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT] [ 0.707688] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P8._PRT] [ 0.707717] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT] [ 0.707822] pci0000:00: Requesting ACPI _OSC control (0x1d) [ 0.707959] pci0000:00: ACPI _OSC control (0x1d) granted [ 0.711969] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12 14 15) [ 0.712014] ACPI: PCI Interrupt Link [LNKB] (IRQs *5) [ 0.712054] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12 *14 15) [ 0.712101] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12 14 15) [ 0.712143] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 14 15) *0, disabled. [ 0.712186] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12 14 *15) [ 0.712229] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 6 7 10 11 12 14 15) [ 0.712274] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 *7 10 11 12 14 15) [ 0.712383] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.712386] vgaarb: loaded [ 0.712575] SCSI subsystem initialized [ 0.712640] libata version 3.00 loaded. [ 0.712640] usbcore: registered new interface driver usbfs [ 0.712640] usbcore: registered new interface driver hub [ 0.712640] usbcore: registered new device driver usb [ 0.712640] wmi: Mapper loaded [ 0.712640] PCI: Using ACPI for IRQ routing [ 0.712640] PCI: pci_cache_line_size set to 64 bytes [ 0.712640] reserve RAM buffer: 000000000009f800 - 000000000009ffff [ 0.712640] reserve RAM buffer: 00000000bffb0000 - 00000000bfffffff [ 0.712640] NetLabel: Initializing [ 0.712640] NetLabel: domain hash size = 128 [ 0.712640] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.712640] NetLabel: unlabeled traffic allowed by default [ 0.721362] AppArmor: AppArmor Filesystem Enabled [ 0.721397] pnp: PnP ACPI init [ 0.721428] ACPI: bus type pnp registered [ 0.721553] pnp 00:00: [bus 00-ff] [ 0.721555] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.721558] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.721560] pnp 00:00: [io 0x0d00-0xffff window] [ 0.721562] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.721564] pnp 00:00: [mem 0x000d0000-0x000dffff window] [ 0.721566] pnp 00:00: [mem 0xc0000000-0xdfffffff window] [ 0.721568] pnp 00:00: [mem 0xf0000000-0xffffffff window] [ 0.721649] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.721658] pnp 00:01: [mem 0xfed14000-0xfed19fff] [ 0.721720] system 00:01: [mem 0xfed14000-0xfed19fff] has been reserved [ 0.721723] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.721759] pnp 00:02: [dma 4] [ 0.721760] pnp 00:02: [io 0x0000-0x000f] [ 0.721762] pnp 00:02: [io 0x0081-0x0083] [ 0.721764] pnp 00:02: [io 0x0087] [ 0.721766] pnp 00:02: [io 0x0089-0x008b] [ 0.721767] pnp 00:02: [io 0x008f] [ 0.721769] pnp 00:02: [io 0x00c0-0x00df] [ 0.721792] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.721802] pnp 00:03: [io 0x0070-0x0071] [ 0.721814] pnp 00:03: [irq 8] [ 0.721837] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.721846] pnp 00:04: [io 0x0061] [ 0.721872] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.721881] pnp 00:05: [io 0x00f0-0x00ff] [ 0.721886] pnp 00:05: [irq 13] [ 0.721912] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.722134] pnp 00:06: [io 0x03f8-0x03ff] [ 0.722139] pnp 00:06: [irq 4] [ 0.722141] pnp 00:06: [dma 0 disabled] [ 0.722200] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.722452] pnp 00:07: [io 0x03f0-0x03f5] [ 0.722454] pnp 00:07: [io 0x03f7] [ 0.722460] pnp 00:07: [irq 6] [ 0.722462] pnp 00:07: [dma 2] [ 0.722517] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.722722] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled] [ 0.722725] pnp 00:08: [io 0x0a00-0x0adf] [ 0.722726] pnp 00:08: [io 0x0ae0-0x0aef] [ 0.722773] system 00:08: [io 0x0a00-0x0adf] has been reserved [ 0.722776] system 00:08: [io 0x0ae0-0x0aef] has been reserved [ 0.722779] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.722847] pnp 00:09: [io 0x0010-0x001f] [ 0.722849] pnp 00:09: [io 0x0022-0x003f] [ 0.722850] pnp 00:09: [io 0x0044-0x005f] [ 0.722852] pnp 00:09: [io 0x0062-0x0063] [ 0.722854] pnp 00:09: [io 0x0065-0x006f] [ 0.722855] pnp 00:09: [io 0x0072-0x007f] [ 0.722857] pnp 00:09: [io 0x0080] [ 0.722859] pnp 00:09: [io 0x0084-0x0086] [ 0.722860] pnp 00:09: [io 0x0088] [ 0.722862] pnp 00:09: [io 0x008c-0x008e] [ 0.722864] pnp 00:09: [io 0x0090-0x009f] [ 0.722865] pnp 00:09: [io 0x00a2-0x00bf] [ 0.722867] pnp 00:09: [io 0x00e0-0x00ef] [ 0.722869] pnp 00:09: [io 0x04d0-0x04d1] [ 0.722870] pnp 00:09: [io 0x0800-0x087f] [ 0.722872] pnp 00:09: [io 0x0000-0xffffffffffffffff disabled] [ 0.722874] pnp 00:09: [io 0x0480-0x04bf] [ 0.722876] pnp 00:09: [mem 0xfed1c000-0xfed1ffff] [ 0.722878] pnp 00:09: [mem 0xfed20000-0xfed8ffff] [ 0.722941] system 00:09: [io 0x04d0-0x04d1] has been reserved [ 0.722944] system 00:09: [io 0x0800-0x087f] has been reserved [ 0.722946] system 00:09: [io 0x0480-0x04bf] has been reserved [ 0.722948] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.722951] system 00:09: [mem 0xfed20000-0xfed8ffff] has been reserved [ 0.722954] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.723028] pnp 00:0a: [mem 0xffb00000-0xffbfffff] [ 0.723030] pnp 00:0a: [mem 0xfff00000-0xffffffff] [ 0.723061] pnp 00:0a: Plug and Play ACPI device, IDs INT0800 (active) [ 0.723101] pnp 00:0b: [mem 0xffc00000-0xffefffff] [ 0.723144] system 00:0b: [mem 0xffc00000-0xffefffff] has been reserved [ 0.723147] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.723223] pnp 00:0c: [io 0x0060] [ 0.723225] pnp 00:0c: [io 0x0064] [ 0.723227] pnp 00:0c: [mem 0xfec00000-0xfec00fff] [ 0.723229] pnp 00:0c: [mem 0xfee00000-0xfee00fff] [ 0.723278] system 00:0c: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.723281] system 00:0c: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.723284] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.723314] pnp 00:0d: [mem 0xe0000000-0xefffffff] [ 0.723357] system 00:0d: [mem 0xe0000000-0xefffffff] has been reserved [ 0.723360] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.723509] pnp 00:0e: [mem 0x00000000-0x0009ffff] [ 0.723511] pnp 00:0e: [mem 0x000c0000-0x000cffff] [ 0.723513] pnp 00:0e: [mem 0x000e0000-0x000fffff] [ 0.723521] pnp 00:0e: [mem 0x00100000-0xbfffffff] [ 0.723523] pnp 00:0e: [mem 0x00000000-0xffffffffffffffff disabled] [ 0.723580] system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.723583] system 00:0e: [mem 0x000c0000-0x000cffff] has been reserved [ 0.723585] system 00:0e: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.723588] system 00:0e: [mem 0x00100000-0xbfffffff] could not be reserved [ 0.723591] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.723709] pnp: PnP ACPI: found 15 devices [ 0.723711] ACPI: ACPI bus type pnp unregistered [ 0.730009] Switching to clocksource acpi_pm [ 0.730153] pci 0000:00:1c.0: BAR 14: assigned [mem 0xc0000000-0xc01fffff] [ 0.730157] pci 0000:00:1c.0: BAR 15: assigned [mem 0xc0200000-0xc03fffff 64bit pref] [ 0.730161] pci 0000:00:1c.4: BAR 15: assigned [mem 0xc0400000-0xc05fffff 64bit pref] [ 0.730164] pci 0000:00:1c.5: BAR 15: assigned [mem 0xc0600000-0xc07fffff 64bit pref] [ 0.730168] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.730170] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.730173] pci 0000:00:01.0: bridge window [io 0xc000-0xcfff] [ 0.730099] Switched to NOHz mode on CPU #1 [ 0.730178] pci 0000:00:01.0: bridge window [mem 0xfa000000-0xfe9fffff] [ 0.730181] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref] [ 0.730187] pci 0000:00:1c.0: PCI bridge to [bus 02-02] [ 0.730190] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff] [ 0.730120] Switched to NOHz mode on CPU #2 [ 0.730200] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xc01fffff] [ 0.730204] pci 0000:00:1c.0: bridge window [mem 0xc0200000-0xc03fffff 64bit pref] [ 0.730210] pci 0000:00:1c.4: PCI bridge to [bus 03-03] [ 0.730213] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff] [ 0.730218] pci 0000:00:1c.4: bridge window [mem 0xfea00000-0xfeafffff] [ 0.730221] pci 0000:00:1c.4: bridge window [mem 0xc0400000-0xc05fffff 64bit pref] [ 0.730228] pci 0000:00:1c.5: PCI bridge to [bus 04-04] [ 0.730153] Switched to NOHz mode on CPU #3 [ 0.730234] pci 0000:00:1c.5: bridge window [io 0xe000-0xefff] [ 0.730239] pci 0000:00:1c.5: bridge window [mem 0xfeb00000-0xfebfffff] [ 0.730242] pci 0000:00:1c.5: bridge window [mem 0xc0600000-0xc07fffff 64bit pref] [ 0.730248] pci 0000:00:1e.0: PCI bridge to [bus 05-05] [ 0.730250] pci 0000:00:1e.0: bridge window [io disabled] [ 0.730254] pci 0000:00:1e.0: bridge window [mem disabled] [ 0.730257] pci 0000:00:1e.0: bridge window [mem pref disabled] [ 0.730278] pci 0000:00:01.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.730281] pci 0000:00:01.0: setting latency timer to 64 [ 0.730286] pci 0000:00:1c.0: enabling device (0104 -> 0107) [ 0.730292] pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.730296] pci 0000:00:1c.0: setting latency timer to 64 [ 0.730301] pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 0.730305] pci 0000:00:1c.4: setting latency timer to 64 [ 0.730311] pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16 [ 0.730314] pci 0000:00:1c.5: setting latency timer to 64 [ 0.730320] pci 0000:00:1e.0: setting latency timer to 64 [ 0.730324] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.730326] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.730328] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.730330] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff] [ 0.730332] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xdfffffff] [ 0.730334] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xffffffff] [ 0.730336] pci_bus 0000:01: resource 0 [io 0xc000-0xcfff] [ 0.730338] pci_bus 0000:01: resource 1 [mem 0xfa000000-0xfe9fffff] [ 0.730340] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref] [ 0.730342] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff] [ 0.730344] pci_bus 0000:02: resource 1 [mem 0xc0000000-0xc01fffff] [ 0.730346] pci_bus 0000:02: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref] [ 0.730349] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff] [ 0.730350] pci_bus 0000:03: resource 1 [mem 0xfea00000-0xfeafffff] [ 0.730353] pci_bus 0000:03: resource 2 [mem 0xc0400000-0xc05fffff 64bit pref] [ 0.730355] pci_bus 0000:04: resource 0 [io 0xe000-0xefff] [ 0.730356] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff] [ 0.730359] pci_bus 0000:04: resource 2 [mem 0xc0600000-0xc07fffff 64bit pref] [ 0.730361] pci_bus 0000:05: resource 4 [io 0x0000-0x0cf7] [ 0.730363] pci_bus 0000:05: resource 5 [io 0x0d00-0xffff] [ 0.730365] pci_bus 0000:05: resource 6 [mem 0x000a0000-0x000bffff] [ 0.730367] pci_bus 0000:05: resource 7 [mem 0x000d0000-0x000dffff] [ 0.730369] pci_bus 0000:05: resource 8 [mem 0xc0000000-0xdfffffff] [ 0.730371] pci_bus 0000:05: resource 9 [mem 0xf0000000-0xffffffff] [ 0.730424] NET: Registered protocol family 2 [ 0.730574] IP route cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.731978] TCP established hash table entries: 524288 (order: 11, 8388608 bytes) [ 0.739907] Switched to NOHz mode on CPU #0 [ 0.740141] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes) [ 0.741194] TCP: Hash tables configured (established 524288 bind 65536) [ 0.741196] TCP reno registered [ 0.741208] UDP hash table entries: 2048 (order: 4, 65536 bytes) [ 0.741276] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes) [ 0.741500] NET: Registered protocol family 1 [ 0.741683] pci 0000:01:00.0: Boot video device [ 0.741692] PCI: CLS 32 bytes, default 64 [ 0.742153] audit: initializing netlink socket (disabled) [ 0.742163] type=2000 audit(1305657535.739:1): initialized [ 0.754319] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.756076] VFS: Disk quotas dquot_6.5.2 [ 0.756130] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.756741] fuse init (API version 7.16) [ 0.756823] msgmni has been set to 6006 [ 0.757113] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.757149] io scheduler noop registered [ 0.757151] io scheduler deadline registered [ 0.757189] io scheduler cfq registered (default) [ 0.757299] pcieport 0000:00:01.0: setting latency timer to 64 [ 0.757330] pcieport 0000:00:01.0: irq 40 for MSI/MSI-X [ 0.757394] pcieport 0000:00:1c.0: setting latency timer to 64 [ 0.757433] pcieport 0000:00:1c.0: irq 41 for MSI/MSI-X [ 0.757519] pcieport 0000:00:1c.4: setting latency timer to 64 [ 0.757552] pcieport 0000:00:1c.4: irq 42 for MSI/MSI-X [ 0.757636] pcieport 0000:00:1c.5: setting latency timer to 64 [ 0.757675] pcieport 0000:00:1c.5: irq 43 for MSI/MSI-X [ 0.757779] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt [ 0.757782] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 0.757785] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded [ 0.757800] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt [ 0.757804] pcie_pme 0000:00:1c.0:pcie01: service driver pcie_pme loaded [ 0.757820] pcieport 0000:00:1c.4: Signaling PME through PCIe PME interrupt [ 0.757822] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt [ 0.757827] pcie_pme 0000:00:1c.4:pcie01: service driver pcie_pme loaded [ 0.757847] pcieport 0000:00:1c.5: Signaling PME through PCIe PME interrupt [ 0.757850] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt [ 0.757853] pcie_pme 0000:00:1c.5:pcie01: service driver pcie_pme loaded [ 0.757869] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.757909] pciehp 0000:00:1c.0:pcie04: HPC vendor_id 8086 device_id 2940 ss_vid 1462 ss_did 7360 [ 0.757929] pciehp 0000:00:1c.0:pcie04: service driver pciehp loaded [ 0.757939] pciehp 0000:00:1c.4:pcie04: HPC vendor_id 8086 device_id 2948 ss_vid 1462 ss_did 7360 [ 0.757955] pciehp 0000:00:1c.4:pcie04: service driver pciehp loaded [ 0.757965] pciehp 0000:00:1c.5:pcie04: HPC vendor_id 8086 device_id 294a ss_vid 1462 ss_did 7360 [ 0.757980] pciehp 0000:00:1c.5:pcie04: service driver pciehp loaded [ 0.757987] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.758034] intel_idle: MWAIT substates: 0x20 [ 0.758036] intel_idle: does not run on family 6 model 15 [ 0.758145] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 0.758150] ACPI: Power Button [PWRB] [ 0.758191] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 0.758194] ACPI: Power Button [PWRF] [ 0.758351] ACPI: acpi_idle registered with cpuidle [ 0.759617] ERST: Table is not found! [ 0.759683] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled [ 0.780226] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.883763] Freeing initrd memory: 12828k freed [ 1.070631] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.070942] Linux agpgart interface v0.103 [ 1.072144] brd: module loaded [ 1.072651] loop: module loaded [ 1.072733] i2c-core: driver [adp5520] using legacy suspend method [ 1.072735] i2c-core: driver [adp5520] using legacy resume method [ 1.072833] ata_piix 0000:00:1f.2: version 2.13 [ 1.072859] ata_piix 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 1.072864] ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ] [ 1.072906] ata_piix 0000:00:1f.2: setting latency timer to 64 [ 1.073160] scsi0 : ata_piix [ 1.073244] scsi1 : ata_piix [ 1.074293] ata1: SATA max UDMA/133 cmd 0xb000 ctl 0xac00 bmdma 0xa480 irq 19 [ 1.074297] ata2: SATA max UDMA/133 cmd 0xa880 ctl 0xa800 bmdma 0xa488 irq 19 [ 1.074316] ata_piix 0000:00:1f.5: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 1.074321] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ] [ 1.074376] ata_piix 0000:00:1f.5: setting latency timer to 64 [ 1.074591] scsi2 : ata_piix [ 1.074663] scsi3 : ata_piix [ 1.075498] ata3: SATA max UDMA/133 cmd 0xa000 ctl 0x9c00 bmdma 0x9480 irq 19 [ 1.075501] ata4: SATA max UDMA/133 cmd 0x9880 ctl 0x9800 bmdma 0x9488 irq 19 [ 1.075546] pata_acpi 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 1.075584] pata_acpi 0000:03:00.0: setting latency timer to 64 [ 1.075597] pata_acpi 0000:03:00.0: PCI INT A disabled [ 1.075867] Fixed MDIO Bus: probed [ 1.075893] PPP generic driver version 2.4.2 [ 1.075930] tun: Universal TUN/TAP device driver, 1.6 [ 1.075932] tun: (C) 1999-2004 Max Krasnyansky [ 1.076007] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.076024] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 1.076040] ehci_hcd 0000:00:1a.7: setting latency timer to 64 [ 1.076043] ehci_hcd 0000:00:1a.7: EHCI Host Controller [ 1.076079] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1 [ 1.076131] ehci_hcd 0000:00:1a.7: debug port 1 [ 1.080029] ehci_hcd 0000:00:1a.7: cache line size of 32 is not supported [ 1.080043] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9fffc00 [ 1.100013] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00 [ 1.100144] hub 1-0:1.0: USB hub found [ 1.100149] hub 1-0:1.0: 4 ports detected [ 1.100217] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 1.100226] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 1.100229] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 1.100269] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2 [ 1.110051] ehci_hcd 0000:00:1d.7: debug port 1 [ 1.113933] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 1.113946] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9fff800 [ 1.130016] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 1.130105] hub 2-0:1.0: USB hub found [ 1.130109] hub 2-0:1.0: 8 ports detected [ 1.130180] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.130191] uhci_hcd: USB Universal Host Controller Interface driver [ 1.130237] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 1.130243] uhci_hcd 0000:00:1a.0: setting latency timer to 64 [ 1.130246] uhci_hcd 0000:00:1a.0: UHCI Host Controller [ 1.130280] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3 [ 1.140047] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000bc00 [ 1.140156] hub 3-0:1.0: USB hub found [ 1.140160] hub 3-0:1.0: 2 ports detected [ 1.140223] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low) -> IRQ 21 [ 1.140229] uhci_hcd 0000:00:1a.1: setting latency timer to 64 [ 1.140232] uhci_hcd 0000:00:1a.1: UHCI Host Controller [ 1.140264] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4 [ 1.140311] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000b880 [ 1.140423] hub 4-0:1.0: USB hub found [ 1.140428] hub 4-0:1.0: 2 ports detected [ 1.140486] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23 [ 1.140491] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 1.140494] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 1.140528] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5 [ 1.140568] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000b800 [ 1.140673] hub 5-0:1.0: USB hub found [ 1.140677] hub 5-0:1.0: 2 ports detected [ 1.140734] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19 [ 1.140741] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 1.140744] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 1.140775] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6 [ 1.140814] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000b480 [ 1.140924] hub 6-0:1.0: USB hub found [ 1.140928] hub 6-0:1.0: 2 ports detected [ 1.140984] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 1.140991] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 1.140994] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 1.141025] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7 [ 1.141065] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000b400 [ 1.141171] hub 7-0:1.0: USB hub found [ 1.141175] hub 7-0:1.0: 2 ports detected [ 1.141232] uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16 [ 1.141238] uhci_hcd 0000:00:1d.3: setting latency timer to 64 [ 1.141240] uhci_hcd 0000:00:1d.3: UHCI Host Controller [ 1.141273] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 8 [ 1.141312] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000b080 [ 1.141419] hub 8-0:1.0: USB hub found [ 1.141422] hub 8-0:1.0: 2 ports detected [ 1.141533] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.143809] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.143815] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.143918] mousedev: PS/2 mouse device common for all mice [ 1.144031] rtc_cmos 00:03: RTC can wake from S4 [ 1.150065] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 1.150086] rtc0: alarms up to one month, y3k, 114 bytes nvram [ 1.150181] device-mapper: uevent: version 1.0.3 [ 1.150247] device-mapper: ioctl: 4.19.1-ioctl (2011-01-07) initialised: dm-devel@redhat.com [ 1.150316] device-mapper: multipath: version 1.2.0 loaded [ 1.150318] device-mapper: multipath round-robin: version 1.0.0 loaded [ 1.150432] cpuidle: using governor ladder [ 1.150434] cpuidle: using governor menu [ 1.150653] TCP cubic registered [ 1.150763] NET: Registered protocol family 10 [ 1.151193] NET: Registered protocol family 17 [ 1.151206] Registering the dns_resolver key type [ 1.151338] PM: Hibernation image not present or could not be loaded. [ 1.151351] registered taskstats version 1 [ 1.151616] Magic number: 11:760:645 [ 1.151717] rtc_cmos 00:03: setting system clock to 2011-05-17 18:38:57 UTC (1305657537) [ 1.151720] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found [ 1.151721] EDD information not available. [ 1.420027] usb 1-2: new high speed USB device using ehci_hcd and address 2 [ 1.430627] ata3: SATA link down (SStatus 0 SControl 300) [ 1.441242] ata4: SATA link down (SStatus 0 SControl 300) [ 1.580046] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 1.580148] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 1.600243] ata1.00: ATAPI: SONY DVD RW DRU-870S, 1.61, max UDMA/100 [ 1.600318] ata2.00: HPA detected: current 976771055, native 976773168 [ 1.600323] ata2.00: ATA-7: SAMSUNG HD502IJ, 1AA01113, max UDMA7 [ 1.600325] ata2.00: 976771055 sectors, multi 16: LBA48 NCQ (depth 0/32) [ 1.620249] ata2.00: configured for UDMA/133 [ 1.640133] ata1.00: configured for UDMA/100 [ 1.641923] scsi 0:0:0:0: CD-ROM SONY DVD RW DRU-870S 1.61 PQ: 0 ANSI: 5 [ 1.644147] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray [ 1.644150] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 1.644241] sr 0:0:0:0: Attached scsi CD-ROM sr0 [ 1.644293] sr 0:0:0:0: Attached scsi generic sg0 type 5 [ 1.644468] scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD502IJ 1AA0 PQ: 0 ANSI: 5 [ 1.644596] sd 1:0:0:0: [sda] 976771055 512-byte logical blocks: (500 GB/465 GiB) [ 1.644604] sd 1:0:0:0: Attached scsi generic sg1 type 0 [ 1.644665] sd 1:0:0:0: [sda] Write Protect is off [ 1.644667] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.644696] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.660241] sda: sda1 sda2 [ 1.660470] sd 1:0:0:0: [sda] Attached SCSI disk [ 1.662099] Freeing unused kernel memory: 956k freed [ 1.662405] Write protecting the kernel read-only data: 10240k [ 1.663150] Freeing unused kernel memory: 184k freed [ 1.667891] Freeing unused kernel memory: 1444k freed [ 1.685845] <30>udev[79]: starting version 167 [ 1.718403] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 1.718430] r8169 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 [ 1.718475] r8169 0000:04:00.0: setting latency timer to 64 [ 1.718550] r8169 0000:04:00.0: irq 44 for MSI/MSI-X [ 1.718989] r8169 0000:04:00.0: eth0: RTL8168b/8111b at 0xffffc90000626000, 00:21:85:3e:a7:ea, XID 18000000 IRQ 44 [ 1.726719] ahci 0000:03:00.0: version 3.0 [ 1.727911] pata_marvell 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 1.727949] pata_marvell 0000:03:00.0: setting latency timer to 64 [ 1.728458] scsi4 : pata_marvell [ 1.728650] scsi5 : pata_marvell [ 1.728712] ata5: PATA max UDMA/100 cmd 0xdc00 ctl 0xd880 bmdma 0xd400 irq 16 [ 1.728715] ata6: PATA max UDMA/133 cmd 0xd800 ctl 0xd480 bmdma 0xd408 irq 16 [ 1.734128] Floppy drive(s): fd0 is 1.44M [ 1.740062] Refined TSC clocksource calibration: 2402.379 MHz. [ 1.740067] Switching to clocksource tsc [ 1.753823] FDC 0 is a post-1991 82077 [ 2.100011] usb 4-2: new low speed USB device using uhci_hcd and address 2 [ 2.151940] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null) [ 2.590013] usb 6-1: new low speed USB device using uhci_hcd and address 2 [ 3.050020] usb 6-2: new full speed USB device using uhci_hcd and address 3 [ 8.430954] <30>udev[293]: starting version 167 [ 8.441640] lp: driver loaded but no devices found [ 8.556843] nvidia: module license 'NVIDIA' taints kernel. [ 8.556847] Disabling lock debugging due to kernel taint [ 8.605395] type=1400 audit(1305650344.943:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=502 comm="apparmor_parser" [ 8.606196] type=1400 audit(1305650344.943:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=502 comm="apparmor_parser" [ 8.606706] type=1400 audit(1305650344.943:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=502 comm="apparmor_parser" [ 8.686028] input: Trust GM-4200 Gamer Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb6/6-1/6-1:1.0/input/input2 [ 8.686549] generic-usb 0003:145F:011A.0003: input,hidraw0: USB HID v1.11 Mouse [Trust GM-4200 Gamer Optical Mouse] on usb-0000:00:1d.1-1/input0 [ 8.686822] usbcore: registered new interface driver usbhid [ 8.686824] usbhid: USB HID core driver [ 8.736477] cfg80211: Calling CRDA to update world regulatory domain [ 8.746973] usbcore: registered new interface driver usbserial [ 8.747252] USB Serial support registered for generic [ 8.763476] cfg80211: World regulatory domain updated: [ 8.763479] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 8.763482] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.763484] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 8.763487] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 8.763489] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.763492] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 8.797169] cfg80211: Updating information on frequency 2412 MHz for a 20 MHz width channel with regulatory rule: [ 8.797173] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797175] cfg80211: Updating information on frequency 2417 MHz for a 20 MHz width channel with regulatory rule: [ 8.797177] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797179] cfg80211: Updating information on frequency 2422 MHz for a 20 MHz width channel with regulatory rule: [ 8.797182] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797184] cfg80211: Updating information on frequency 2427 MHz for a 20 MHz width channel with regulatory rule: [ 8.797186] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797188] cfg80211: Updating information on frequency 2432 MHz for a 20 MHz width channel with regulatory rule: [ 8.797190] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797192] cfg80211: Updating information on frequency 2437 MHz for a 20 MHz width channel with regulatory rule: [ 8.797195] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797196] cfg80211: Updating information on frequency 2442 MHz for a 20 MHz width channel with regulatory rule: [ 8.797199] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797201] cfg80211: Updating information on frequency 2447 MHz for a 20 MHz width channel with regulatory rule: [ 8.797203] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797205] cfg80211: Updating information on frequency 2452 MHz for a 20 MHz width channel with regulatory rule: [ 8.797207] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797209] cfg80211: Updating information on frequency 2457 MHz for a 20 MHz width channel with regulatory rule: [ 8.797211] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797213] cfg80211: Updating information on frequency 2462 MHz for a 20 MHz width channel with regulatory rule: [ 8.797216] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797218] cfg80211: Updating information on frequency 2467 MHz for a 20 MHz width channel with regulatory rule: [ 8.797220] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797222] cfg80211: Updating information on frequency 2472 MHz for a 20 MHz width channel with regulatory rule: [ 8.797224] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.797226] cfg80211: Updating information on frequency 2484 MHz for a 20 MHz width channel with regulatory rule: [ 8.797228] cfg80211: 2474000 KHz - 2494000 KHz @ KHz), (300 mBi, 2000 mBm) [ 8.802117] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' [ 8.802990] Registered led device: rt2800usb-phy0::radio [ 8.803046] Registered led device: rt2800usb-phy0::assoc [ 8.803103] Registered led device: rt2800usb-phy0::quality [ 8.803634] usbcore: registered new interface driver rt2800usb [ 8.804491] rt2870sta: module is from the staging directory, the quality is unknown, you have been warned. [ 8.823785] rtusb init ---> [ 8.823857] usbcore: registered new interface driver rt2870 [ 8.824350] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22 [ 8.824398] HDA Intel 0000:00:1b.0: irq 45 for MSI/MSI-X [ 8.824422] HDA Intel 0000:00:1b.0: setting latency timer to 64 [ 8.912382] hda_codec: ALC888: BIOS auto-probing. [ 8.926472] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3 [ 9.205556] Adding 262136k swap on /host/ubuntu/disks/swap.disk. Priority:-1 extents:1 across:262136k [ 9.237199] EXT4-fs (loop0): re-mounted. Opts: errors=remount-ro [ 9.304677] RPC: Registered udp transport module. [ 9.304680] RPC: Registered tcp transport module. [ 9.304682] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 9.338262] type=1400 audit(1305650345.673:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=742 comm="apparmor_parser" [ 9.340055] type=1400 audit(1305650345.683:6): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=742 comm="apparmor_parser" [ 9.344107] type=1400 audit(1305650345.683:7): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=739 comm="apparmor_parser" [ 9.349194] type=1400 audit(1305650345.683:8): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince" pid=740 comm="apparmor_parser" [ 9.351412] type=1400 audit(1305650345.693:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=752 comm="apparmor_parser" [ 9.353018] type=1400 audit(1305650345.693:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=739 comm="apparmor_parser" [ 9.353532] type=1400 audit(1305650345.693:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=739 comm="apparmor_parser" [ 9.367656] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 9.367665] nvidia 0000:01:00.0: setting latency timer to 64 [ 9.367669] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem [ 9.368132] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 270.41.06 Mon Apr 18 14:53:56 PDT 2011 [ 9.384656] FS-Cache: Loaded [ 9.390717] input: MLK Trust Deskset 15176 as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/input/input4 [ 9.390840] sunplus 0003:04FC:05D8.0001: input,hidraw1: USB HID v1.00 Keyboard [MLK Trust Deskset 15176] on usb-0000:00:1a.1-2/input0 [ 9.414864] FS-Cache: Netfs 'nfs' registered for caching [ 9.415487] sunplus 0003:04FC:05D8.0002: fixing up Sunplus Wireless Desktop report descriptor [ 9.416288] input: MLK Trust Deskset 15176 as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/input/input5 [ 9.416484] sunplus 0003:04FC:05D8.0002: input,hiddev0,hidraw2: USB HID v1.00 Mouse [MLK Trust Deskset 15176] on usb-0000:00:1a.1-2/input1 [ 9.416760] usbcore: registered new interface driver usbserial_generic [ 9.416762] usbserial: USB Serial Driver core [ 9.428952] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 9.445320] USB Serial support registered for pl2303 [ 9.445550] pl2303 6-2:1.0: pl2303 converter detected [ 9.457116] usb 6-2: pl2303 converter now attached to ttyUSB0 [ 9.457498] usbcore: registered new interface driver pl2303 [ 9.457500] pl2303: Prolific PL2303 USB to serial adaptor driver [ 9.530501] ppdev: user-space parallel port driver [ 10.050644] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 10.054340] r8169 0000:04:00.0: eth0: link down [ 10.054841] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 10.059401] svc: failed to register lockdv1 RPC service (errno 97). [ 10.059454] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory [ 10.070420] NFSD: starting 90-second grace period [ 10.466113] EXT4-fs (loop0): re-mounted. Opts: errors=remount-ro,commit=0 [ 11.610850] EXT4-fs (loop0): re-mounted. Opts: errors=remount-ro,commit=0 [ 11.795033] r8169 0000:04:00.0: eth0: link up [ 11.795418] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 21.950003] eth0: no IPv6 routers present [ 132.954595] wlan0: authenticate with 00:24:fe:a3:50:f2 (try 1) [ 132.959472] wlan0: authenticated [ 132.959487] wlan0: associate with 00:24:fe:a3:50:f2 (try 1) [ 132.961973] wlan0: RX AssocResp from 00:24:fe:a3:50:f2 (capab=0x431 status=0 aid=1) [ 132.961976] wlan0: associated [ 132.996597] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 134.008032] Intel AES-NI instructions are not detected. [ 134.084810] padlock_aes: VIA PadLock not detected. [ 143.950005] wlan0: no IPv6 routers present [ 179.236545] wlan0: deauthenticating from 00:24:fe:a3:50:f2 by local choice (reason=3) [ 181.432091] cfg80211: All devices are disconnected, going to restore regulatory settings [ 181.432098] cfg80211: Restoring regulatory settings [ 181.432106] cfg80211: Calling CRDA to update world regulatory domain [ 181.435458] cfg80211: Updating information on frequency 2412 MHz for a 20 MHz width channel with regulatory rule: [ 181.435462] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435465] cfg80211: Updating information on frequency 2417 MHz for a 20 MHz width channel with regulatory rule: [ 181.435467] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435469] cfg80211: Updating information on frequency 2422 MHz for a 20 MHz width channel with regulatory rule: [ 181.435472] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435474] cfg80211: Updating information on frequency 2427 MHz for a 20 MHz width channel with regulatory rule: [ 181.435476] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435478] cfg80211: Updating information on frequency 2432 MHz for a 20 MHz width channel with regulatory rule: [ 181.435480] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435482] cfg80211: Updating information on frequency 2437 MHz for a 20 MHz width channel with regulatory rule: [ 181.435485] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435487] cfg80211: Updating information on frequency 2442 MHz for a 20 MHz width channel with regulatory rule: [ 181.435489] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435491] cfg80211: Updating information on frequency 2447 MHz for a 20 MHz width channel with regulatory rule: [ 181.435493] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435495] cfg80211: Updating information on frequency 2452 MHz for a 20 MHz width channel with regulatory rule: [ 181.435498] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435500] cfg80211: Updating information on frequency 2457 MHz for a 20 MHz width channel with regulatory rule: [ 181.435502] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435504] cfg80211: Updating information on frequency 2462 MHz for a 20 MHz width channel with regulatory rule: [ 181.435506] cfg80211: 2402000 KHz - 2472000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435508] cfg80211: Updating information on frequency 2467 MHz for a 20 MHz width channel with regulatory rule: [ 181.435511] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435513] cfg80211: Updating information on frequency 2472 MHz for a 20 MHz width channel with regulatory rule: [ 181.435515] cfg80211: 2457000 KHz - 2482000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435517] cfg80211: Updating information on frequency 2484 MHz for a 20 MHz width channel with regulatory rule: [ 181.435520] cfg80211: 2474000 KHz - 2494000 KHz @ KHz), (300 mBi, 2000 mBm) [ 181.435522] cfg80211: World regulatory domain updated: [ 181.435523] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp) [ 181.435526] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 181.435528] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 181.435531] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm) [ 181.435533] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 181.435535] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm) [ 572.540036] usb 6-2: USB disconnect, address 3 [ 572.540196] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0 [ 572.540212] pl2303 6-2:1.0: device disconnected [ 599.570010] usb 6-2: new full speed USB device using uhci_hcd and address 4 [ 599.739269] pl2303 6-2:1.0: pl2303 converter detected [ 599.751322] usb 6-2: pl2303 converter now attached to ttyUSB0
