Mount nfs root 192.168.0.3:/pollinux/nandfs... done Switch root Creating device nodes...done Set log level... Setting up /tmp... done Starting logging daemons...done Setting up network...done Mounting config fs... done done du: /config/debug/: No such file or directory done Starting command server... - done Setting up timezone... done /etc/init.d/S19network: .: 10: Can't open /config/settings.conf Loading luddite (256M_NOIP)... lud-core lud-pnx8550 phStbDspInfo done Loading pre-TM modules... fusion mmio i2c3203 i2c0105 tda1004x tda10021 tda10048 stv0297 demux dvb ak470 saa8510 tda9983 output_mode: PAL-RGB denc21 phStbRpc phStbDP phStbRTC phStbGpio phStbAudio snd phStbDrawdone Populating /dev using udev: RESTORE GPIO12 done Starting Trimedia 0 ...done Starting TriMedia 1 ...done Loading post-TM modules...done Starting network servers...telnetd httpd - done Starting autofs...usb samba - done Starting DSP file services...phStbRoot: started (Linux). done StandbyMicro grep: /etc/display.mode: No such file or directory grep: /etc/display.mode: No such file or directory Starting USB Mouse Services Reset STATE flag to indicate that we've booted successfully... Failed to read hw config done Reset UPFLAG so updater uses default timeout... Failed to read hw config done Start PC/SC daemon... done Updating time Init crontab... /usr/sbin/ntpupdater: .: 7: Can't open /config/settings.conf Start cron... done cp: /config/persist.log: No such file or directory Skip StbPvr application: 'nomainapp' specified in kernel cmdline grep: /config/StbMainApp/settings.conf: No such file or directory Skip main application: 'nomainapp' specified in kernel cmdline Mounting user fs... 192.168.0.3:/pollinux/nandfs.user Starting userfs RC scripts...
