FlashReader V1.0.2.1, built Sep 4 2006 22:24:11 with ECC Bootscript version 0x00130001 EMG boot Hynix, 8bit, 64MB MicroBTM, Compiled Sep 11 2008 14:04:11 Using Uart 0 Initialising NAND driver...OK Loading Bootloader... Nand Address:00004400 (Page load to VAddr:80030000) Nand Address:00004600 (Page load to VAddr:80030200) Nand Address:00004800 (Page load to VAddr:80030400) Nand Address:00004A00 (Page load to VAddr:80030600) Nand Address:00004C00 (Page load to VAddr:80030800) Nand Address:00004E00 (Page load to VAddr:80030A00) Nand Address:00005000 (Page load to VAddr:80030C00) Nand Address:00005200 (Page load to VAddr:80030E00) Nand Address:00005400 (Page load to VAddr:80031000) Nand Address:00005600 (Page load to VAddr:80031200) Nand Address:00005800 (Page load to VAddr:80031400) Nand Address:00005A00 (Page load to VAddr:80031600) Nand Address:00005C00 (Page load to VAddr:80031800) Nand Address:00005E00 (Page load to VAddr:80031A00) Nand Address:00006000 (Page load to VAddr:80031C00) Nand Address:00006200 (Page load to VAddr:80031E00) Nand Address:00006400 (Page load to VAddr:80032000) Nand Address:00006600 (Page load to VAddr:80032200) Nand Address:00006800 (Page load to VAddr:80032400) Nand Address:00006A00 (Page load to VAddr:80032600) Nand Address:00006C00 (Page load to VAddr:80032800) Nand Address:00006E00 (Page load to VAddr:80032A00) Nand Address:00007000 (Page load to VAddr:80032C00) Nand Address:00007200 (Page load to VAddr:80032E00) Nand Address:00007400 (Page load to VAddr:80033000) Nand Address:00007600 (Page load to VAddr:80033200) Nand Address:00007800 (Page load to VAddr:80033400) Nand Address:00007A00 (Page load to VAddr:80033600) Nand Address:00007C00 (Page load to VAddr:80033800) Nand Address:00007E00 (Page load to VAddr:80033A00) Nand Address:00008000 (Page load to VAddr:80033C00) Nand Address:00008200 (Page load to VAddr:80033E00) Nand Address:00008400 (Page load to VAddr:80034000) Nand Address:00008600 (Page load to VAddr:80034200) Nand Address:00008800 (Page load to VAddr:80034400) Nand Address:00008A00 (Page load to VAddr:80034600) Nand Address:00008C00 (Page load to VAddr:80034800) Nand Address:00008E00 (Page load to VAddr:80034A00) Nand Address:00009000 (Page load to VAddr:80034C00) Nand Address:00009200 (Page load to VAddr:80034E00) Nand Address:00009400 (Page load to VAddr:80035000) Nand Address:00009600 (Page load to VAddr:80035200) Nand Address:00009800 (Page load to VAddr:80035400) Nand Address:00009A00 (Page load to VAddr:80035600) Nand Address:00009C00 (Page load to VAddr:80035800) Nand Address:00009E00 (Page load to VAddr:80035A00) Nand Address:0000A000 (Page load to VAddr:80035C00) Nand Address:0000A200 (Page load to VAddr:80035E00) Nand Address:0000A400 (Page load to VAddr:80036000) Nand Address:0000A600 (Page load to VAddr:80036200) Nand Address:0000A800 (Page load to VAddr:80036400) Nand Address:0000AA00 (Page load to VAddr:80036600) Nand Address:0000AC00 (Page load to VAddr:80036800) Nand Address:0000AE00 (Page load to VAddr:80036A00) Nand Address:0000B000 (Page load to VAddr:80036C00) Nand Address:0000B200 (Page load to VAddr:80036E00) Nand Address:0000B400 (Page load to VAddr:80037000) Nand Address:0000B600 (Page load to VAddr:80037200) Nand Address:0000B800 (Page load to VAddr:80037400) Nand Address:0000BA00 (Page load to VAddr:80037600) Nand Address:0000BC00 (Page load to VAddr:80037800) Nand Address:0000BE00 (Page load to VAddr:80037A00) Done Starting Bootloader... c ____ __ __ __ __ __ ______ ______ __ /\ _`\ /\ \/\ \ /\ \ /\ \ /'_ `\ /\ ___\/\ ___\ /'__`\ \ \ \_\ \ \ `\\ \\ `\`\/'/'/\ \_\ \\ \ \__/\ \ \__/ /\ \/\ \ \ \ ,__/\ \ , ` \`\/ > < \/_> _ <_\ \___``\ \___``\ \ \ \ \ \ \ \/ \ \ \`\ \ \/'/\`\ /\ \_\ \\/\ \_\ \/\ \_\ \ \ \_\ \ \ \_\ \ \_\ \_\ /\_\\ \_\ \____/ \ \____/\ \____/\ \____/ \/_/ \/_/\/_/ \/_/ \/_/\/___/ \/___/ \/___/ \/___/ ____ __ ___ __ /\ _`\ /\ \__/\_ \ /\ \ \ \ \_\ \ ___ ___\ \ ,_\//\ \ ___ __ \_\ \ __ _ __ \ \ _ <' / __`\ / __`\ \ \/ \ \ \ / __`\ /'__`\ /'_` \ /'__`\/\`'__\ \ \ \_\ \/\ \_\ \/\ \_\ \ \ \_ \_\ \_/\ \_\ \/\ \_\.\_/\ \_\ \/\ __/\ \ \/ \ \____/\ \____/\ \____/\ \__\/\____\ \____/\ \__/.\_\ \___,_\ \____\\ \_\ \/___/ \/___/ \/___/ \/__/\/____/\/___/ \/__/\/_/\/__,_ /\/____/ \/_/ €3 €ips Semiconductors, Compiled May 28 2009 12:16:51Press a key now...                                          cImmediate Boot!!! Load main vmlinux.raw, to 0x80060000 Loading vmlinux.raw size 5535908 to 0x80060000 ...5535908 done. Entry point = 0x803A9000 Command Line: console=ttyS0 stb810_display=pal root=/dev/nfs nfsroot=192.168.0.3:/pollinux/nandfs ip=192.168.0.254 Determined physical RAM map: memory: 07000000 @ 00000000 (usable) Initrd not found or empty - disabling initrd Built 1 zonelists. Total pages: 28448 Kernel command line: console=ttyS0 stb810_display=pal root=/dev/nfs nfsroot=192.168.0.3:/pollinux/nandfs ip=192.168.0.254 Primary instruction cache 16kB, physically tagged, 2-way, linesize 32 bytes. Primary data cache 16kB, 4-way, linesize 32 bytes. Synthesized TLB refill handler (23 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). PID hash table entries: 512 (order: 9, 2048 bytes) Using 250.714 MHz high precision timer. Linux version 2.6.21.3PNX8550 (root@smithy) (gcc version 4.0.0 (DENX ELDK 4.0 4.0.0)) #1743 Fri Feb 11 10:49:15 OMST 2011 Setting initial splash screen display mode SD (50Hz) CPU revision is: 00061200 Determined physical RAM map: memory: 07000000 @ 00000000 (usable) Initrd not found or empty - disabling initrd Built 1 zonelists. Total pages: 28448 Kernel command line: console=ttyS0 stb810_display=pal root=/dev/nfs nfsroot=192.168.0.3:/pollinux/nandfs ip=192.168.0.254 Primary instruction cache 16kB, physically tagged, 2-way, linesize 32 bytes. Primary data cache 16kB, 4-way, linesize 32 bytes. Synthesized TLB refill handler (23 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). PID hash table entries: 512 (order: 9, 2048 bytes) Using 250.714 MHz high precision timer. Console: colour dummy device 80x25 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 107648k/114688k available (2841k kernel code, 6996k reserved, 518k data, 2044k init, 0k highmem) Mount-cache hash table entries: 512 NET: Registered protocol family 16 registering PCI controller with io_map_base unset SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Time: MIPS clocksource has been installed. NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered NTFS driver 2.1.28 [Flags: R/O]. JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc. io scheduler noop registered io scheduler anticipatory registered (default) Register GPIO SPI device Serial: PNX8XXX driver $Revision: 1.2 $ pnx8xxx-uart: ttyS0 at MMIO 0xbbe4a000 (irq = 27) is a PNX8XXX pnx8xxx-uart: ttyS1 at MMIO 0xbbe4b000 (irq = 28) is a PNX8XXX natsemi dp8381x driver, version 2.1, Sept 11, 2006 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder PCI: Enabling device 0000:00:0a.0 (0000 -> 0003) natsemi eth0: NatSemi DP8381[56] at 0x20092000 (0000:00:0a.0), 00:18:f3:79:a1:f3, IRQ 55, port TP. Driver for NAND Flash on the PNX8550 XIO bus (Mar 15 2010-17:54:27) Auto detected a >= 64MByte device on a 8 bit bus NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 3530 at 0x03728000 Creating 9 MTD partitions on "NAND 64MiB 3,3V 8-bit": 0x00000000-0x00004000 : "microBTM" 0x00004000-0x00040000 : "bootloader" 0x00040000-0x00600000 : "Updater" 0x00600000-0x00d00000 : "Kernel" 0x00d00000-0x00ff8000 : "Sys-Config" 0x00ff8000-0x01000000 : "HW-Config" 0x01000000-0x02400000 : "Root" 0x02400000-0x03e00000 : "User" 0x03e00000-0x04000000 : "Profile" PCI: Enabling device 0000:00:09.2 (0000 -> 0002) ehci_hcd 0000:00:09.2: EHCI Host Controller ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1 ehci_hcd 0000:00:09.2: irq 55, io mem 0x20093200 ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 4 ports detected pnx8550-ohci pnx8550-ohci: PNX8550 OHCI pnx8550-ohci pnx8550-ohci: new USB bus registered, assigned bus number 2 pnx8550-ohci pnx8550-ohci: irq 13, io mem 0x1be48000 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected PCI: Enabling device 0000:00:09.0 (0000 -> 0002) ohci_hcd 0000:00:09.0: OHCI Host Controller ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 3 ohci_hcd 0000:00:09.0: irq 55, io mem 0x20090000 usb usb3: configuration #1 chosen from 1 choice hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected PCI: Enabling device 0000:00:09.1 (0000 -> 0002) ohci_hcd 0000:00:09.1: OHCI Host Controller ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 4 ohci_hcd 0000:00:09.1: irq 55, io mem 0x20091000 usb usb4: configuration #1 chosen from 1 choice hub 4-0:1.0: USB hub found hub 4-0:1.0: 2 ports detected USB Universal Host Controller Interface driver v3.0 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice i2c /dev entries driver TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Bridge firewalling registered 802.1Q VLAN Support v1.8 Ben Greear All bugs added by David S. Miller ieee80211: 802.11 data/management/control stack, git-1.1.13 ieee80211: Copyright (C) 2004-2005 Intel Corporation eth0: DSPCFG accepted after 0 usec. eth0: link up. eth0: Setting full-duplex based on negotiated link capability. IP-Config: Guessing netmask 255.255.255.0 IP-Config: Complete: device=eth0, addr=192.168.0.254, mask=255.255.255.0, gw=255.255.255.255, host=192.168.0.254, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=192.168.0.3, rootpath= Freeing unused kernel memory: 2044k freed Algorithmics/MIPS FPU Emulator v1.5 Loading profile... done Mount fstab... done Remount / read-write... done Find HW-Config... 5 done NFS Root. Skip updating. Creating device nodes...done Setup mdev as hotplug handler... done Set log level... Populate /dev... Load luddite and gpio/mmio/rtc...Cache HW-Config...Failed to read hw config Get display mode and load i2c and fb modules... Failed to read hw config Detect GPIO function...done Get System ID... Restore hotplug handler... done Restore log level... Unloading modules... Shutting down RTC driver Shutting down PNX8550 MMIO Driver Shutting down PNX8550 GPIO driver Shutting down NXP /proc entries driver done done Unmount all... done Mount nfs root 192.168.0.3:/pollinux/nandfs... done Switch root Creating device nodes...done Set log level... Setting up /tmp... done Starting logging daemons...done Setting up network...done Mounting config fs... done done du: /config/debug/: No such file or directory done Starting command server... - done Setting up timezone... done /etc/init.d/S19network: .: 10: Can't open /config/settings.conf Loading luddite (256M_NOIP)... lud-core lud-pnx8550 phStbDspInfo done Loading pre-TM modules... fusion mmio i2c3203 i2c0105 tda1004x tda10021 tda10048 stv0297 demux dvb ak470 saa8510 tda9983 output_mode: PAL-RGB denc21 phStbRpc phStbDP phStbRTC phStbGpio phStbAudio snd phStbDrawdone Populating /dev using udev: RESTORE GPIO12 done Starting Trimedia 0 ...done Starting TriMedia 1 ...done Loading post-TM modules...done Starting network servers...telnetd httpd - done Starting autofs...usb samba - done Starting DSP file services...phStbRoot: started (Linux). done StandbyMicro grep: /etc/display.mode: No such file or directory grep: /etc/display.mode: No such file or directory Starting USB Mouse Services Reset STATE flag to indicate that we've booted successfully... Failed to read hw config done Reset UPFLAG so updater uses default timeout... Failed to read hw config done Start PC/SC daemon... done Updating time Init crontab... /usr/sbin/ntpupdater: .: 7: Can't open /config/settings.conf Start cron... done cp: /config/persist.log: No such file or directory Starting StbPvr...- done grep: /config/StbMainApp/settings.conf: No such file or directory Starting main app cycle in background... Give app some time to start... done. Mounting user fs...
