diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6.config board/friendlyarm/mini2440/linux-2.6.37.6.config
--- board/friendlyarm/mini2440/linux-2.6.37.6.config	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6.config	2011-05-25 21:25:57.000000000 +0200
@@ -0,0 +1,2114 @@
+# Automatically generated make config: don't edit
+# Linux/arm 2.6.37.6 Kernel Configuration
+# Wed May 25 21:25:57 2011
+CONFIG_ARM=y
+CONFIG_HAVE_PWM=y
+CONFIG_SYS_SUPPORTS_APM_EMULATION=y
+CONFIG_GENERIC_GPIO=y
+CONFIG_ARCH_USES_GETTIMEOFFSET=y
+CONFIG_HAVE_PROC_CPU=y
+CONFIG_NO_IOPORT=y
+CONFIG_GENERIC_HARDIRQS=y
+CONFIG_STACKTRACE_SUPPORT=y
+CONFIG_HAVE_LATENCYTOP_SUPPORT=y
+CONFIG_LOCKDEP_SUPPORT=y
+CONFIG_TRACE_IRQFLAGS_SUPPORT=y
+CONFIG_HARDIRQS_SW_RESEND=y
+CONFIG_GENERIC_IRQ_PROBE=y
+CONFIG_RWSEM_GENERIC_SPINLOCK=y
+CONFIG_ARCH_HAS_CPUFREQ=y
+CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
+CONFIG_GENERIC_HWEIGHT=y
+CONFIG_GENERIC_CALIBRATE_DELAY=y
+CONFIG_NEED_DMA_MAP_STATE=y
+CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
+CONFIG_VECTORS_BASE=0xffff0000
+CONFIG_DEFCONFIG_LIST="/limodules/$UNAME_RELEASE/.config"
+CONFIG_CONSTRUCTORS=y
+CONFIG_HAVE_IRQ_WORK=y
+# General setup
+CONFIG_EXPERIMENTAL=y
+CONFIG_BROKEN_ON_SMP=y
+CONFIG_INIT_ENV_ARG_LIMIT=32
+CONFIG_CROSS_COMPILE=""
+CONFIG_LOCALVERSION=""
+# CONFIG_LOCALVERSION_AUTO is not set
+CONFIG_HAVE_KERNEL_GZIP=y
+CONFIG_HAVE_KERNEL_LZMA=y
+CONFIG_HAVE_KERNEL_LZO=y
+CONFIG_KERNEL_GZIP=y
+# CONFIG_KERNEL_LZMA is not set
+# CONFIG_KERNEL_LZO is not set
+CONFIG_SWAP=y
+CONFIG_SYSVIPC=y
+CONFIG_SYSVIPC_SYSCTL=y
+CONFIG_POSIX_MQUEUE=y
+CONFIG_POSIX_MQUEUE_SYSCTL=y
+# CONFIG_BSD_PROCESS_ACCT is not set
+# CONFIG_TASKSTATS is not set
+# CONFIG_AUDIT is not set
+# CONFIG_HAVE_GENERIC_HARDIRQS is not set
+# CONFIG_SPARSE_IRQ is not set
+# RCU Subsystem
+CONFIG_TINY_RCU=y
+# CONFIG_PREEMPT_RCU is not set
+# CONFIG_TREE_RCU_TRACE is not set
+# CONFIG_IKCONFIG is not set
+CONFIG_LOG_BUF_SHIFT=17
+# CONFIG_CGROUPS is not set
+CONFIG_NAMESPACES=y
+CONFIG_UTS_NS=y
+CONFIG_IPC_NS=y
+CONFIG_USER_NS=y
+CONFIG_PID_NS=y
+CONFIG_NET_NS=y
+# CONFIG_SYSFS_DEPRECATED is not set
+CONFIG_RELAY=y
+CONFIG_BLK_DEV_INITRD=y
+CONFIG_INITRAMFS_SOURCE=""
+CONFIG_RD_GZIP=y
+CONFIG_RD_BZIP2=y
+CONFIG_RD_LZMA=y
+CONFIG_RD_LZO=y
+CONFIG_CC_OPTIMIZE_FOR_SIZE=y
+CONFIG_SYSCTL=y
+CONFIG_ANON_INODES=y
+# CONFIG_EMBEDDED is not set
+CONFIG_UID16=y
+CONFIG_SYSCTL_SYSCALL=y
+CONFIG_KALLSYMS=y
+# CONFIG_KALLSYMS_ALL is not set
+# CONFIG_KALLSYMS_EXTRA_PASS is not set
+CONFIG_HOTPLUG=y
+CONFIG_PRINTK=y
+CONFIG_BUG=y
+CONFIG_ELF_CORE=y
+CONFIG_BASE_FULL=y
+CONFIG_FUTEX=y
+CONFIG_EPOLL=y
+CONFIG_SIGNALFD=y
+CONFIG_TIMERFD=y
+CONFIG_EVENTFD=y
+CONFIG_SHMEM=y
+CONFIG_AIO=y
+CONFIG_HAVE_PERF_EVENTS=y
+CONFIG_PERF_USE_VMALLOC=y
+# Kernel Performance Events And Counters
+# CONFIG_PERF_EVENTS is not set
+# CONFIG_PERF_COUNTERS is not set
+CONFIG_VM_EVENT_COUNTERS=y
+CONFIG_SLUB_DEBUG=y
+# CONFIG_COMPAT_BRK is not set
+# CONFIG_SLAB is not set
+CONFIG_SLUB=y
+# CONFIG_PROFILING is not set
+CONFIG_HAVE_OPROFILE=y
+# CONFIG_KPROBES is not set
+CONFIG_HAVE_KPROBES=y
+CONFIG_HAVE_KRETPROBES=y
+CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
+CONFIG_HAVE_CLK=y
+# GCOV-based kernel profiling
+# CONFIG_GCOV_KERNEL is not set
+CONFIG_HAVE_GENERIC_DMA_COHERENT=y
+CONFIG_SLABINFO=y
+CONFIG_RT_MUTEXES=y
+CONFIG_BASE_SMALL=0
+CONFIG_MODULES=y
+CONFIG_MODULE_FORCE_LOAD=y
+CONFIG_MODULE_UNLOAD=y
+CONFIG_MODULE_FORCE_UNLOAD=y
+# CONFIG_MODVERSIONS is not set
+# CONFIG_MODULE_SRCVERSION_ALL is not set
+CONFIG_BLOCK=y
+CONFIG_LBDAF=y
+# CONFIG_BLK_DEV_BSG is not set
+CONFIG_BLK_DEV_INTEGRITY=y
+# IO Schedulers
+CONFIG_IOSCHED_NOOP=y
+CONFIG_IOSCHED_DEADLINE=y
+CONFIG_IOSCHED_CFQ=y
+# CONFIG_DEFAULT_DEADLINE is not set
+CONFIG_DEFAULT_CFQ=y
+# CONFIG_DEFAULT_NOOP is not set
+CONFIG_DEFAULT_IOSCHED="cfq"
+# CONFIG_INLINE_SPIN_TRYLOCK is not set
+# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
+# CONFIG_INLINE_SPIN_LOCK is not set
+# CONFIG_INLINE_SPIN_LOCK_BH is not set
+# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
+# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
+CONFIG_INLINE_SPIN_UNLOCK=y
+# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
+CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
+# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
+# CONFIG_INLINE_READ_TRYLOCK is not set
+# CONFIG_INLINE_READ_LOCK is not set
+# CONFIG_INLINE_READ_LOCK_BH is not set
+# CONFIG_INLINE_READ_LOCK_IRQ is not set
+# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
+CONFIG_INLINE_READ_UNLOCK=y
+# CONFIG_INLINE_READ_UNLOCK_BH is not set
+CONFIG_INLINE_READ_UNLOCK_IRQ=y
+# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
+# CONFIG_INLINE_WRITE_TRYLOCK is not set
+# CONFIG_INLINE_WRITE_LOCK is not set
+# CONFIG_INLINE_WRITE_LOCK_BH is not set
+# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
+# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
+CONFIG_INLINE_WRITE_UNLOCK=y
+# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
+CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
+# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
+# CONFIG_MUTEX_SPIN_ON_OWNER is not set
+CONFIG_FREEZER=y
+# System Type
+CONFIG_MMU=y
+# CONFIG_ARCH_AAEC2000 is not set
+# CONFIG_ARCH_INTEGRATOR is not set
+# CONFIG_ARCH_REALVIEW is not set
+# CONFIG_ARCH_VERSATILE is not set
+# CONFIG_ARCH_VEXPRESS is not set
+# CONFIG_ARCH_AT91 is not set
+# CONFIG_ARCH_BCMRING is not set
+# CONFIG_ARCH_CLPS711X is not set
+# CONFIG_ARCH_CNS3XXX is not set
+# CONFIG_ARCH_GEMINI is not set
+# CONFIG_ARCH_EBSA110 is not set
+# CONFIG_ARCH_EP93XX is not set
+# CONFIG_ARCH_FOOTBRIDGE is not set
+# CONFIG_ARCH_MXC is not set
+# CONFIG_ARCH_STMP3XXX is not set
+# CONFIG_ARCH_NETX is not set
+# CONFIG_ARCH_H720X is not set
+# CONFIG_ARCH_IOP13XX is not set
+# CONFIG_ARCH_IOP32X is not set
+# CONFIG_ARCH_IOP33X is not set
+# CONFIG_ARCH_IXP23XX is not set
+# CONFIG_ARCH_IXP2000 is not set
+# CONFIG_ARCH_IXP4XX is not set
+# CONFIG_ARCH_DOVE is not set
+# CONFIG_ARCH_KIRKWOOD is not set
+# CONFIG_ARCH_LOKI is not set
+# CONFIG_ARCH_LPC32XX is not set
+# CONFIG_ARCH_MV78XX0 is not set
+# CONFIG_ARCH_ORION5X is not set
+# CONFIG_ARCH_MMP is not set
+# CONFIG_ARCH_KS8695 is not set
+# CONFIG_ARCH_NS9XXX is not set
+# CONFIG_ARCH_W90X900 is not set
+# CONFIG_ARCH_NUC93X is not set
+# CONFIG_ARCH_TEGRA is not set
+# CONFIG_ARCH_PNX4008 is not set
+# CONFIG_ARCH_PXA is not set
+# CONFIG_ARCH_MSM is not set
+# CONFIG_ARCH_SHMOBILE is not set
+# CONFIG_ARCH_RPC is not set
+# CONFIG_ARCH_SA1100 is not set
+CONFIG_ARCH_S3C2410=y
+# CONFIG_ARCH_S3C64XX is not set
+# CONFIG_ARCH_S5P64X0 is not set
+# CONFIG_ARCH_S5P6442 is not set
+# CONFIG_ARCH_S5PC100 is not set
+# CONFIG_ARCH_S5PV210 is not set
+# CONFIG_ARCH_S5PV310 is not set
+# CONFIG_ARCH_SHARK is not set
+# CONFIG_ARCH_TCC_926 is not set
+# CONFIG_ARCH_LH7A40X is not set
+# CONFIG_ARCH_U300 is not set
+# CONFIG_ARCH_U8500 is not set
+# CONFIG_ARCH_NOMADIK is not set
+# CONFIG_ARCH_DAVINCI is not set
+# CONFIG_ARCH_OMAP is not set
+# CONFIG_PLAT_SPEAR is not set
+CONFIG_PLAT_SAMSUNG=y
+# Boot options
+# CONFIG_S3C_BOOT_WATCHDOG is not set
+# CONFIG_S3C_BOOT_ERROR_RESET is not set
+CONFIG_S3C_BOOT_UART_FORCE_FIFO=y
+CONFIG_S3C_LOWLEVEL_UART_PORT=0
+CONFIG_S3C_GPIO_CFG_S3C24XX=y
+CONFIG_S3C_GPIO_PULL_UP=y
+CONFIG_SAMSUNG_GPIO_EXTRA=0
+CONFIG_S3C_GPIO_SPACE=0
+CONFIG_S3C_ADC=y
+CONFIG_S3C_DEV_USB_HOST=y
+CONFIG_S3C_DEV_WDT=y
+CONFIG_S3C_DEV_NAND=y
+CONFIG_S3C_DMA=y
+# Power management
+# CONFIG_SAMSUNG_PM_DEBUG is not set
+# CONFIG_SAMSUNG_PM_CHECK is not set
+CONFIG_PLAT_S3C24XX=y
+CONFIG_CPU_LLSERIAL_S3C2440_ONLY=y
+CONFIG_CPU_LLSERIAL_S3C2440=y
+CONFIG_S3C2410_CLOCK=y
+CONFIG_S3C24XX_PWM=y
+CONFIG_S3C24XX_GPIO_EXTRA=0
+CONFIG_S3C2410_DMA=y
+# CONFIG_S3C2410_DMA_DEBUG is not set
+# S3C2400 Machines
+CONFIG_S3C2410_PM=y
+CONFIG_S3C2410_GPIO=y
+# S3C2410 Machines
+# CONFIG_ARCH_SMDK2410 is not set
+# CONFIG_ARCH_H1940 is not set
+# CONFIG_MACH_N30 is not set
+# CONFIG_ARCH_BAST is not set
+# CONFIG_MACH_OTOM is not set
+# CONFIG_MACH_AML_M5900 is not set
+# CONFIG_MACH_TCT_HAMMER is not set
+# CONFIG_MACH_VR1000 is not set
+# CONFIG_MACH_QT2410 is not set
+# S3C2412 Machines
+# CONFIG_MACH_JIVE is not set
+# CONFIG_MACH_SMDK2413 is not set
+# CONFIG_MACH_SMDK2412 is not set
+# CONFIG_MACH_VSTMS is not set
+# S3C2416 Machines
+# CONFIG_MACH_SMDK2416 is not set
+CONFIG_CPU_S3C2440=y
+CONFIG_CPU_S3C244X=y
+CONFIG_S3C2440_DMA=y
+# S3C2440 and S3C2442 Machines
+# CONFIG_MACH_ANUBIS is not set
+# CONFIG_MACH_NEO1973_GTA02 is not set
+# CONFIG_MACH_OSIRIS is not set
+# CONFIG_MACH_RX3715 is not set
+# CONFIG_ARCH_S3C2440 is not set
+# CONFIG_MACH_NEXCODER_2440 is not set
+# CONFIG_SMDK2440_CPU2440 is not set
+# CONFIG_SMDK2440_CPU2442 is not set
+# CONFIG_MACH_AT2440EVB is not set
+CONFIG_MACH_MINI2440=y
+# CONFIG_MACH_RX1950 is not set
+# S3C2443 Machines
+# CONFIG_MACH_SMDK2443 is not set
+# Processor Type
+CONFIG_CPU_ARM920T=y
+CONFIG_CPU_32v4T=y
+CONFIG_CPU_ABRT_EV4T=y
+CONFIG_CPU_PABRT_LEGACY=y
+CONFIG_CPU_CACHE_V4WT=y
+CONFIG_CPU_CACHE_VIVT=y
+CONFIG_CPU_COPY_V4WB=y
+CONFIG_CPU_TLB_V4WBI=y
+CONFIG_CPU_CP15=y
+CONFIG_CPU_CP15_MMU=y
+# Processor Features
+CONFIG_ARM_THUMB=y
+# CONFIG_CPU_ICACHE_DISABLE is not set
+# CONFIG_CPU_DCACHE_DISABLE is not set
+# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
+CONFIG_ARM_L1_CACHE_SHIFT=5
+# Bus support
+# CONFIG_PCI_SYSCALL is not set
+# CONFIG_ARCH_SUPPORTS_MSI is not set
+# CONFIG_PCCARD is not set
+# Kernel Features
+CONFIG_VMSPLIT_3G=y
+# CONFIG_VMSPLIT_2G is not set
+# CONFIG_VMSPLIT_1G is not set
+CONFIG_PAGE_OFFSET=0xC0000000
+CONFIG_PREEMPT_NONE=y
+# CONFIG_PREEMPT_VOLUNTARY is not set
+# CONFIG_PREEMPT is not set
+CONFIG_HZ=200
+CONFIG_AEABI=y
+# CONFIG_OABI_COMPAT is not set
+# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
+# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
+# CONFIG_HIGHMEM is not set
+CONFIG_SELECT_MEMORY_MODEL=y
+CONFIG_FLATMEM_MANUAL=y
+CONFIG_FLATMEM=y
+CONFIG_FLAT_NODE_MEM_MAP=y
+CONFIG_HAVE_MEMBLOCK=y
+CONFIG_PAGEFLAGS_EXTENDED=y
+CONFIG_SPLIT_PTLOCK_CPUS=999999
+# CONFIG_PHYS_ADDR_T_64BIT is not set
+CONFIG_ZONE_DMA_FLAG=0
+CONFIG_VIRT_TO_BUS=y
+# CONFIG_KSM is not set
+CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
+CONFIG_NEED_PER_CPU_KM=y
+CONFIG_FORCE_MAX_ZONEORDER=11
+CONFIG_ALIGNMENT_TRAP=y
+# CONFIG_UACCESS_WITH_MEMCPY is not set
+# CONFIG_SECCOMP is not set
+# CONFIG_CC_STACKPROTECTOR is not set
+# CONFIG_DEPRECATED_PARAM_STRUCT is not set
+# Boot options
+CONFIG_ZBOOT_ROM_TEXT=0
+CONFIG_ZBOOT_ROM_BSS=0
+CONFIG_CMDLINE=""
+# CONFIG_XIP_KERNEL is not set
+CONFIG_KEXEC=y
+CONFIG_ATAGS_PROC=y
+# CONFIG_AUTO_ZRELADDR is not set
+# CPU Power Management
+# CONFIG_CPU_FREQ is not set
+CONFIG_CPU_IDLE=y
+CONFIG_CPU_IDLE_GOV_LADDER=y
+# Floating point emulation
+# At least one emulation must be selected
+# Userspace binary formats
+CONFIG_BINFMT_ELF=y
+CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
+CONFIG_HAVE_AOUT=y
+CONFIG_BINFMT_AOUT=m
+CONFIG_BINFMT_MISC=m
+# Power management options
+CONFIG_PM=y
+# CONFIG_PM_DEBUG is not set
+CONFIG_PM_SLEEP=y
+CONFIG_SUSPEND_NVS=y
+CONFIG_SUSPEND=y
+CONFIG_SUSPEND_FREEZER=y
+CONFIG_APM_EMULATION=y
+# CONFIG_PM_RUNTIME is not set
+CONFIG_PM_OPS=y
+CONFIG_ARCH_SUSPEND_POSSIBLE=y
+CONFIG_NET=y
+# Networking options
+CONFIG_PACKET=y
+CONFIG_UNIX=y
+CONFIG_XFRM=y
+CONFIG_XFRM_USER=m
+# CONFIG_XFRM_SUB_POLICY is not set
+# CONFIG_XFRM_MIGRATE is not set
+# CONFIG_XFRM_STATISTICS is not set
+CONFIG_NET_KEY=m
+# CONFIG_NET_KEY_MIGRATE is not set
+CONFIG_INET=y
+CONFIG_IP_MULTICAST=y
+CONFIG_IP_ADVANCED_ROUTER=y
+CONFIG_ASK_IP_FIB_HASH=y
+# CONFIG_IP_FIB_TRIE is not set
+CONFIG_IP_FIB_HASH=y
+CONFIG_IP_MULTIPLE_TABLES=y
+CONFIG_IP_ROUTE_MULTIPATH=y
+CONFIG_IP_ROUTE_VERBOSE=y
+CONFIG_IP_PNP=y
+CONFIG_IP_PNP_DHCP=y
+CONFIG_IP_PNP_BOOTP=y
+CONFIG_IP_PNP_RARP=y
+# CONFIG_NET_IPIP is not set
+# CONFIG_NET_IPGRE_DEMUX is not set
+CONFIG_IP_MROUTE=y
+# CONFIG_IP_MROUTE_MULTIPLE_TABLES is not set
+CONFIG_IP_PIMSM_V1=y
+CONFIG_IP_PIMSM_V2=y
+# CONFIG_ARPD is not set
+CONFIG_SYN_COOKIES=y
+# CONFIG_INET_AH is not set
+# CONFIG_INET_ESP is not set
+# CONFIG_INET_IPCOMP is not set
+# CONFIG_INET_XFRM_TUNNEL is not set
+# CONFIG_INET_TUNNEL is not set
+# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
+# CONFIG_INET_XFRM_MODE_TUNNEL is not set
+# CONFIG_INET_XFRM_MODE_BEET is not set
+# CONFIG_INET_LRO is not set
+CONFIG_INET_DIAG=m
+CONFIG_INET_TCP_DIAG=m
+# CONFIG_TCP_CONG_ADVANCED is not set
+CONFIG_TCP_CONG_CUBIC=y
+CONFIG_DEFAULT_TCP_CONG="cubic"
+# CONFIG_TCP_MD5SIG is not set
+# CONFIG_IPV6 is not set
+# CONFIG_NETWORK_SECMARK is not set
+# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
+# CONFIG_NETFILTER is not set
+# CONFIG_IP_DCCP is not set
+# CONFIG_IP_SCTP is not set
+# CONFIG_RDS is not set
+# CONFIG_TIPC is not set
+# CONFIG_ATM is not set
+# CONFIG_L2TP is not set
+# CONFIG_BRIDGE is not set
+# CONFIG_NET_DSA is not set
+# CONFIG_VLAN_8021Q is not set
+# CONFIG_DECNET is not set
+# CONFIG_LLC2 is not set
+# CONFIG_IPX is not set
+# CONFIG_ATALK is not set
+# CONFIG_X25 is not set
+# CONFIG_LAPB is not set
+# CONFIG_ECONET is not set
+# CONFIG_WAN_ROUTER is not set
+# CONFIG_PHONET is not set
+# CONFIG_IEEE802154 is not set
+# CONFIG_NET_SCHED is not set
+# CONFIG_DCB is not set
+CONFIG_DNS_RESOLVER=y
+# Network testing
+CONFIG_NET_PKTGEN=m
+# CONFIG_HAMRADIO is not set
+# CONFIG_CAN is not set
+# CONFIG_IRDA is not set
+# CONFIG_BT is not set
+# CONFIG_AF_RXRPC is not set
+CONFIG_FIB_RULES=y
+CONFIG_WIRELESS=y
+CONFIG_WIRELESS_EXT=y
+CONFIG_WEXT_CORE=y
+CONFIG_WEXT_PROC=y
+CONFIG_WEXT_SPY=y
+CONFIG_WEXT_PRIV=y
+# CONFIG_CFG80211 is not set
+# CONFIG_WIRELESS_EXT_SYSFS is not set
+CONFIG_LIB80211=m
+CONFIG_LIB80211_CRYPT_WEP=m
+CONFIG_LIB80211_CRYPT_CCMP=m
+CONFIG_LIB80211_CRYPT_TKIP=m
+# CONFIG_LIB80211_DEBUG is not set
+# CFG80211 needs to be enabled for MAC80211
+# Some wireless drivers require a rate control algorithm
+# CONFIG_WIMAX is not set
+# CONFIG_RFKILL is not set
+# CONFIG_NET_9P is not set
+# CONFIG_CAIF is not set
+# CONFIG_CEPH_LIB is not set
+# Device Drivers
+# Generic Driver Options
+CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
+# CONFIG_DEVTMPFS is not set
+CONFIG_STANDALONE=y
+CONFIG_PREVENT_FIRMWARE_BUILD=y
+CONFIG_FW_LOADER=y
+# CONFIG_FIRMWARE_IN_KERNEL is not set
+CONFIG_EXTRA_FIRMWARE=""
+# CONFIG_DEBUG_DRIVER is not set
+# CONFIG_DEBUG_DEVRES is not set
+# CONFIG_SYS_HYPERVISOR is not set
+CONFIG_CONNECTOR=m
+CONFIG_MTD=y
+# CONFIG_MTD_DEBUG is not set
+# CONFIG_MTD_TESTS is not set
+CONFIG_MTD_CONCAT=y
+CONFIG_MTD_PARTITIONS=y
+# CONFIG_MTD_REDBOOT_PARTS is not set
+CONFIG_MTD_CMDLINE_PARTS=y
+# CONFIG_MTD_AFS_PARTS is not set
+# CONFIG_MTD_AR7_PARTS is not set
+# User Modules And Translation Layers
+CONFIG_MTD_CHAR=y
+CONFIG_MTD_BLKDEVS=y
+CONFIG_MTD_BLOCK=y
+CONFIG_FTL=y
+CONFIG_NFTL=y
+CONFIG_NFTL_RW=y
+CONFIG_INFTL=y
+CONFIG_RFD_FTL=y
+# CONFIG_SSFDC is not set
+# CONFIG_SM_FTL is not set
+# CONFIG_MTD_OOPS is not set
+# RAM/ROM/Flash chip drivers
+CONFIG_MTD_CFI=y
+CONFIG_MTD_JEDECPROBE=y
+CONFIG_MTD_GEN_PROBE=y
+# CONFIG_MTD_CFI_ADV_OPTIONS is not set
+CONFIG_MTD_MAP_BANK_WIDTH_1=y
+CONFIG_MTD_MAP_BANK_WIDTH_2=y
+CONFIG_MTD_MAP_BANK_WIDTH_4=y
+# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
+# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
+# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
+CONFIG_MTD_CFI_I1=y
+CONFIG_MTD_CFI_I2=y
+# CONFIG_MTD_CFI_I4 is not set
+# CONFIG_MTD_CFI_I8 is not set
+# CONFIG_MTD_CFI_INTELEXT is not set
+CONFIG_MTD_CFI_AMDSTD=y
+CONFIG_MTD_CFI_STAA=y
+CONFIG_MTD_CFI_UTIL=y
+CONFIG_MTD_RAM=y
+CONFIG_MTD_ROM=y
+# CONFIG_MTD_ABSENT is not set
+# Mapping drivers for chip access
+# CONFIG_MTD_COMPLEX_MAPPINGS is not set
+# CONFIG_MTD_PHYSMAP is not set
+# CONFIG_MTD_ARM_INTEGRATOR is not set
+# CONFIG_MTD_IMPA7 is not set
+# CONFIG_MTD_PLATRAM is not set
+# Self-contained MTD device drivers
+# CONFIG_MTD_DATAFLASH is not set
+# CONFIG_MTD_M25P80 is not set
+# CONFIG_MTD_SST25L is not set
+# CONFIG_MTD_SLRAM is not set
+# CONFIG_MTD_PHRAM is not set
+# CONFIG_MTD_MTDRAM is not set
+# CONFIG_MTD_BLOCK2MTD is not set
+# Disk-On-Chip Device Drivers
+# CONFIG_MTD_DOC2000 is not set
+# CONFIG_MTD_DOC2001 is not set
+# CONFIG_MTD_DOC2001PLUS is not set
+CONFIG_MTD_NAND_ECC=y
+# CONFIG_MTD_NAND_ECC_SMC is not set
+CONFIG_MTD_NAND=y
+CONFIG_MTD_NAND_VERIFY_WRITE=y
+# CONFIG_MTD_SM_COMMON is not set
+# CONFIG_MTD_NAND_MUSEUM_IDS is not set
+# CONFIG_MTD_NAND_GPIO is not set
+CONFIG_MTD_NAND_IDS=y
+CONFIG_MTD_NAND_S3C2410=y
+# CONFIG_MTD_NAND_S3C2410_DEBUG is not set
+# CONFIG_MTD_NAND_S3C2410_HWECC is not set
+# CONFIG_MTD_NAND_S3C2410_CLKSTOP is not set
+# CONFIG_MTD_NAND_DISKONCHIP is not set
+# CONFIG_MTD_NAND_NANDSIM is not set
+CONFIG_MTD_NAND_PLATFORM=y
+# CONFIG_MTD_ALAUDA is not set
+# CONFIG_MTD_ONENAND is not set
+# LPDDR flash memory drivers
+CONFIG_MTD_LPDDR=y
+CONFIG_MTD_QINFO_PROBE=y
+# CONFIG_MTD_UBI is not set
+# CONFIG_PARPORT is not set
+CONFIG_BLK_DEV=y
+# CONFIG_BLK_DEV_COW_COMMON is not set
+CONFIG_BLK_DEV_LOOP=m
+# CONFIG_BLK_DEV_CRYPTOLOOP is not set
+# CONFIG_BLK_DEV_DRBD is not set
+CONFIG_BLK_DEV_NBD=m
+# CONFIG_BLK_DEV_UB is not set
+CONFIG_BLK_DEV_RAM=y
+CONFIG_BLK_DEV_RAM_COUNT=16
+CONFIG_BLK_DEV_RAM_SIZE=65536
+# CONFIG_BLK_DEV_XIP is not set
+CONFIG_CDROM_PKTCDVD=m
+CONFIG_CDROM_PKTCDVD_BUFFERS=8
+# CONFIG_CDROM_PKTCDVD_WCACHE is not set
+# CONFIG_ATA_OVER_ETH is not set
+# CONFIG_MG_DISK is not set
+# CONFIG_BLK_DEV_RBD is not set
+CONFIG_MISC_DEVICES=y
+# CONFIG_AD525X_DPOT is not set
+# CONFIG_ICS932S401 is not set
+# CONFIG_ENCLOSURE_SERVICES is not set
+# CONFIG_APDS9802ALS is not set
+# CONFIG_ISL29003 is not set
+# CONFIG_ISL29020 is not set
+# CONFIG_SENSORS_TSL2550 is not set
+# CONFIG_SENSORS_BH1780 is not set
+# CONFIG_SENSORS_BH1770 is not set
+# CONFIG_SENSORS_APDS990X is not set
+# CONFIG_HMC6352 is not set
+# CONFIG_DS1682 is not set
+# CONFIG_TI_DAC7512 is not set
+# CONFIG_BMP085 is not set
+# CONFIG_C2PORT is not set
+# EEPROM support
+CONFIG_EEPROM_AT24=y
+# CONFIG_EEPROM_AT25 is not set
+# CONFIG_EEPROM_LEGACY is not set
+# CONFIG_EEPROM_MAX6875 is not set
+# CONFIG_EEPROM_93CX6 is not set
+# CONFIG_IWMC3200TOP is not set
+# Texas Instruments shared transport line discipline
+CONFIG_HAVE_IDE=y
+# CONFIG_IDE is not set
+# SCSI device support
+CONFIG_SCSI_MOD=m
+# CONFIG_RAID_ATTRS is not set
+CONFIG_SCSI=m
+CONFIG_SCSI_DMA=y
+# CONFIG_SCSI_TGT is not set
+# CONFIG_SCSI_NETLINK is not set
+# CONFIG_SCSI_PROC_FS is not set
+# SCSI support type (disk, tape, CD-ROM)
+CONFIG_BLK_DEV_SD=m
+# CONFIG_CHR_DEV_ST is not set
+# CONFIG_CHR_DEV_OSST is not set
+# CONFIG_BLK_DEV_SR is not set
+CONFIG_CHR_DEV_SG=m
+# CONFIG_CHR_DEV_SCH is not set
+# CONFIG_SCSI_MULTI_LUN is not set
+# CONFIG_SCSI_CONSTANTS is not set
+# CONFIG_SCSI_LOGGING is not set
+# CONFIG_SCSI_SCAN_ASYNC is not set
+CONFIG_SCSI_WAIT_SCAN=m
+# SCSI Transports
+# CONFIG_SCSI_SPI_ATTRS is not set
+# CONFIG_SCSI_FC_ATTRS is not set
+# CONFIG_SCSI_ISCSI_ATTRS is not set
+# CONFIG_SCSI_SAS_ATTRS is not set
+# CONFIG_SCSI_SAS_LIBSAS is not set
+# CONFIG_SCSI_SRP_ATTRS is not set
+# CONFIG_SCSI_LOWLEVEL is not set
+# CONFIG_SCSI_DH is not set
+# CONFIG_SCSI_OSD_INITIATOR is not set
+# CONFIG_ATA is not set
+# CONFIG_MD is not set
+CONFIG_NETDEVICES=y
+# CONFIG_DUMMY is not set
+# CONFIG_BONDING is not set
+# CONFIG_MACVLAN is not set
+# CONFIG_EQUALIZER is not set
+CONFIG_TUN=m
+# CONFIG_VETH is not set
+CONFIG_MII=y
+# CONFIG_PHYLIB is not set
+CONFIG_NET_ETHERNET=y
+# CONFIG_AX88796 is not set
+# CONFIG_SMC91X is not set
+CONFIG_DM9000=y
+CONFIG_DM9000_DEBUGLEVEL=4
+# CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL is not set
+# CONFIG_ENC28J60 is not set
+# CONFIG_ETHOC is not set
+# CONFIG_SMC911X is not set
+# CONFIG_SMSC911X is not set
+# CONFIG_DNET is not set
+# CONFIG_IBM_NEW_EMAC_ZMII is not set
+# CONFIG_IBM_NEW_EMAC_RGMII is not set
+# CONFIG_IBM_NEW_EMAC_TAH is not set
+# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
+# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
+# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
+# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
+# CONFIG_B44 is not set
+# CONFIG_KS8851 is not set
+# CONFIG_KS8851_MLL is not set
+# CONFIG_NETDEV_1000 is not set
+# CONFIG_NETDEV_10000 is not set
+CONFIG_WLAN=y
+# CONFIG_USB_ZD1201 is not set
+CONFIG_HOSTAP=m
+CONFIG_HOSTAP_FIRMWARE=y
+CONFIG_HOSTAP_FIRMWARE_NVRAM=y
+# Enable WiMAX (Networking options) to see the WiMAX drivers
+# USB Network Adapters
+# CONFIG_USB_CATC is not set
+# CONFIG_USB_KAWETH is not set
+# CONFIG_USB_PEGASUS is not set
+# CONFIG_USB_RTL8150 is not set
+# CONFIG_USB_USBNET is not set
+# CONFIG_USB_IPHETH is not set
+# CONFIG_WAN is not set
+# CAIF transport drivers
+CONFIG_PPP=m
+CONFIG_PPP_MULTILINK=y
+CONFIG_PPP_FILTER=y
+CONFIG_PPP_ASYNC=m
+CONFIG_PPP_SYNC_TTY=m
+CONFIG_PPP_DEFLATE=m
+CONFIG_PPP_BSDCOMP=m
+CONFIG_PPP_MPPE=m
+# CONFIG_PPPOE is not set
+# CONFIG_SLIP is not set
+CONFIG_SLHC=m
+# CONFIG_NETCONSOLE is not set
+# CONFIG_NETPOLL is not set
+# CONFIG_NET_POLL_CONTROLLER is not set
+# CONFIG_ISDN is not set
+# CONFIG_PHONE is not set
+# Input device support
+CONFIG_INPUT=y
+CONFIG_INPUT_FF_MEMLESS=y
+# CONFIG_INPUT_POLLDEV is not set
+# CONFIG_INPUT_SPARSEKMAP is not set
+# Userland interfaces
+CONFIG_INPUT_MOUSEDEV=y
+CONFIG_INPUT_MOUSEDEV_PSAUX=y
+CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
+CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
+# CONFIG_INPUT_JOYDEV is not set
+CONFIG_INPUT_EVDEV=y
+CONFIG_INPUT_EVBUG=m
+# Input Device Drivers
+CONFIG_INPUT_KEYBOARD=y
+# CONFIG_KEYBOARD_ADP5588 is not set
+# CONFIG_KEYBOARD_ATKBD is not set
+# CONFIG_KEYBOARD_QT2160 is not set
+# CONFIG_KEYBOARD_LKKBD is not set
+CONFIG_KEYBOARD_GPIO=y
+# CONFIG_KEYBOARD_GPIO_POLLED is not set
+# CONFIG_KEYBOARD_TCA6416 is not set
+# CONFIG_KEYBOARD_MATRIX is not set
+# CONFIG_KEYBOARD_LM8323 is not set
+# CONFIG_KEYBOARD_MAX7359 is not set
+# CONFIG_KEYBOARD_MCS is not set
+# CONFIG_KEYBOARD_NEWTON is not set
+# CONFIG_KEYBOARD_OPENCORES is not set
+# CONFIG_KEYBOARD_STOWAWAY is not set
+# CONFIG_KEYBOARD_SUNKBD is not set
+# CONFIG_KEYBOARD_XTKBD is not set
+CONFIG_INPUT_MOUSE=y
+CONFIG_MOUSE_PS2=y
+CONFIG_MOUSE_PS2_ALPS=y
+CONFIG_MOUSE_PS2_LOGIPS2PP=y
+CONFIG_MOUSE_PS2_SYNAPTICS=y
+CONFIG_MOUSE_PS2_TRACKPOINT=y
+# CONFIG_MOUSE_PS2_ELANTECH is not set
+# CONFIG_MOUSE_PS2_SENTELIC is not set
+# CONFIG_MOUSE_PS2_TOUCHKIT is not set
+# CONFIG_MOUSE_SERIAL is not set
+# CONFIG_MOUSE_APPLETOUCH is not set
+# CONFIG_MOUSE_BCM5974 is not set
+# CONFIG_MOUSE_VSXXXAA is not set
+# CONFIG_MOUSE_GPIO is not set
+# CONFIG_MOUSE_SYNAPTICS_I2C is not set
+# CONFIG_INPUT_JOYSTICK is not set
+# CONFIG_INPUT_TABLET is not set
+CONFIG_INPUT_TOUCHSCREEN=y
+# CONFIG_TOUCHSCREEN_ADS7846 is not set
+# CONFIG_TOUCHSCREEN_AD7877 is not set
+# CONFIG_TOUCHSCREEN_AD7879 is not set
+# CONFIG_TOUCHSCREEN_BU21013 is not set
+# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
+# CONFIG_TOUCHSCREEN_DYNAPRO is not set
+# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
+# CONFIG_TOUCHSCREEN_EETI is not set
+# CONFIG_TOUCHSCREEN_FUJITSU is not set
+CONFIG_TOUCHSCREEN_S3C2410=y
+# CONFIG_TOUCHSCREEN_GUNZE is not set
+# CONFIG_TOUCHSCREEN_ELO is not set
+# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
+# CONFIG_TOUCHSCREEN_MCS5000 is not set
+# CONFIG_TOUCHSCREEN_MTOUCH is not set
+# CONFIG_TOUCHSCREEN_INEXIO is not set
+# CONFIG_TOUCHSCREEN_MK712 is not set
+# CONFIG_TOUCHSCREEN_PENMOUNT is not set
+# CONFIG_TOUCHSCREEN_QT602240 is not set
+# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
+# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
+# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
+# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
+# CONFIG_TOUCHSCREEN_TSC2007 is not set
+# CONFIG_TOUCHSCREEN_W90X900 is not set
+# CONFIG_TOUCHSCREEN_TPS6507X is not set
+# CONFIG_INPUT_MISC is not set
+# Hardware I/O ports
+CONFIG_SERIO=y
+CONFIG_SERIO_SERPORT=y
+CONFIG_SERIO_LIBPS2=y
+CONFIG_SERIO_RAW=y
+# CONFIG_SERIO_ALTERA_PS2 is not set
+# CONFIG_SERIO_PS2MULT is not set
+# CONFIG_GAMEPORT is not set
+# Character devices
+CONFIG_VT=y
+CONFIG_CONSOLE_TRANSLATIONS=y
+CONFIG_VT_CONSOLE=y
+CONFIG_HW_CONSOLE=y
+CONFIG_VT_HW_CONSOLE_BINDING=y
+CONFIG_DEVKMEM=y
+# CONFIG_SERIAL_NONSTANDARD is not set
+# CONFIG_N_GSM is not set
+# Serial drivers
+# CONFIG_SERIAL_8250 is not set
+# Non-8250 serial port support
+CONFIG_SERIAL_SAMSUNG=y
+CONFIG_SERIAL_SAMSUNG_UARTS=3
+CONFIG_SERIAL_SAMSUNG_CONSOLE=y
+CONFIG_SERIAL_S3C2440=y
+# CONFIG_SERIAL_MAX3100 is not set
+# CONFIG_SERIAL_MAX3107 is not set
+CONFIG_SERIAL_CORE=y
+CONFIG_SERIAL_CORE_CONSOLE=y
+# CONFIG_SERIAL_TIMBERDALE is not set
+# CONFIG_SERIAL_ALTERA_JTAGUART is not set
+# CONFIG_SERIAL_ALTERA_UART is not set
+CONFIG_UNIX98_PTYS=y
+# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
+CONFIG_LEGACY_PTYS=y
+CONFIG_LEGACY_PTY_COUNT=128
+CONFIG_IPMI_HANDLER=m
+# CONFIG_IPMI_PANIC_EVENT is not set
+CONFIG_IPMI_DEVICE_INTERFACE=m
+CONFIG_IPMI_SI=m
+CONFIG_IPMI_WATCHDOG=m
+CONFIG_IPMI_POWEROFF=m
+CONFIG_HW_RANDOM=y
+# CONFIG_HW_RANDOM_TIMERIOMEM is not set
+# CONFIG_R3964 is not set
+# CONFIG_RAW_DRIVER is not set
+# CONFIG_TCG_TPM is not set
+# CONFIG_RAMOOPS is not set
+CONFIG_I2C=y
+CONFIG_I2C_BOARDINFO=y
+CONFIG_I2C_COMPAT=y
+CONFIG_I2C_CHARDEV=y
+# CONFIG_I2C_MUX is not set
+CONFIG_I2C_HELPER_AUTO=y
+CONFIG_I2C_ALGOBIT=y
+# I2C Hardware Bus support
+# I2C system bus drivers (mostly embedded / system-on-chip)
+# CONFIG_I2C_DESIGNWARE is not set
+# CONFIG_I2C_GPIO is not set
+# CONFIG_I2C_OCORES is not set
+# CONFIG_I2C_PCA_PLATFORM is not set
+CONFIG_HAVE_S3C2410_I2C=y
+CONFIG_I2C_S3C2410=y
+CONFIG_I2C_SIMTEC=y
+# CONFIG_I2C_XILINX is not set
+# External I2C/SMBus adapter drivers
+# CONFIG_I2C_PARPORT_LIGHT is not set
+# CONFIG_I2C_TAOS_EVM is not set
+# CONFIG_I2C_TINY_USB is not set
+# Other I2C/SMBus bus drivers
+# CONFIG_I2C_STUB is not set
+# CONFIG_I2C_DEBUG_CORE is not set
+# CONFIG_I2C_DEBUG_ALGO is not set
+# CONFIG_I2C_DEBUG_BUS is not set
+CONFIG_SPI=y
+# CONFIG_SPI_DEBUG is not set
+CONFIG_SPI_MASTER=y
+# SPI Master Controller Drivers
+CONFIG_SPI_BITBANG=y
+# CONFIG_SPI_GPIO is not set
+CONFIG_SPI_S3C24XX=y
+# CONFIG_SPI_S3C24XX_FIQ is not set
+# CONFIG_SPI_S3C24XX_GPIO is not set
+# CONFIG_SPI_XILINX is not set
+# CONFIG_SPI_DESIGNWARE is not set
+# SPI Protocol Masters
+CONFIG_SPI_SPIDEV=y
+# CONFIG_SPI_TLE62X0 is not set
+# PPS support
+# CONFIG_PPS is not set
+CONFIG_ARCH_REQUIRE_GPIOLIB=y
+CONFIG_GPIOLIB=y
+# CONFIG_DEBUG_GPIO is not set
+CONFIG_GPIO_SYSFS=y
+# Memory mapped GPIO expanders:
+# CONFIG_GPIO_BASIC_MMIO is not set
+# CONFIG_GPIO_IT8761E is not set
+# CONFIG_GPIO_VX855 is not set
+# I2C GPIO expanders:
+# CONFIG_GPIO_MAX7300 is not set
+# CONFIG_GPIO_MAX732X is not set
+# CONFIG_GPIO_PCA953X is not set
+# CONFIG_GPIO_PCF857X is not set
+# CONFIG_GPIO_SX150X is not set
+# CONFIG_GPIO_ADP5588 is not set
+# PCI GPIO expanders:
+# SPI GPIO expanders:
+# CONFIG_GPIO_MAX7301 is not set
+# CONFIG_GPIO_MCP23S08 is not set
+# CONFIG_GPIO_MC33880 is not set
+# CONFIG_GPIO_74X164 is not set
+# AC97 GPIO expanders:
+# MODULbus GPIO expanders:
+# CONFIG_W1 is not set
+# CONFIG_POWER_SUPPLY is not set
+CONFIG_HWMON=y
+# CONFIG_HWMON_VID is not set
+# CONFIG_HWMON_DEBUG_CHIP is not set
+# Native drivers
+# CONFIG_SENSORS_AD7414 is not set
+# CONFIG_SENSORS_AD7418 is not set
+# CONFIG_SENSORS_ADCXX is not set
+# CONFIG_SENSORS_ADM1021 is not set
+# CONFIG_SENSORS_ADM1025 is not set
+# CONFIG_SENSORS_ADM1026 is not set
+# CONFIG_SENSORS_ADM1029 is not set
+# CONFIG_SENSORS_ADM1031 is not set
+# CONFIG_SENSORS_ADM9240 is not set
+# CONFIG_SENSORS_ADT7411 is not set
+# CONFIG_SENSORS_ADT7462 is not set
+# CONFIG_SENSORS_ADT7470 is not set
+# CONFIG_SENSORS_ADT7475 is not set
+# CONFIG_SENSORS_ASC7621 is not set
+# CONFIG_SENSORS_ATXP1 is not set
+# CONFIG_SENSORS_DS1621 is not set
+# CONFIG_SENSORS_F71805F is not set
+# CONFIG_SENSORS_F71882FG is not set
+# CONFIG_SENSORS_F75375S is not set
+# CONFIG_SENSORS_G760A is not set
+# CONFIG_SENSORS_GL518SM is not set
+# CONFIG_SENSORS_GL520SM is not set
+# CONFIG_SENSORS_GPIO_FAN is not set
+# CONFIG_SENSORS_IBMAEM is not set
+# CONFIG_SENSORS_IBMPEX is not set
+# CONFIG_SENSORS_IT87 is not set
+# CONFIG_SENSORS_JC42 is not set
+# CONFIG_SENSORS_LM63 is not set
+# CONFIG_SENSORS_LM70 is not set
+# CONFIG_SENSORS_LM73 is not set
+CONFIG_SENSORS_LM75=y
+# CONFIG_SENSORS_LM77 is not set
+# CONFIG_SENSORS_LM78 is not set
+# CONFIG_SENSORS_LM80 is not set
+# CONFIG_SENSORS_LM83 is not set
+# CONFIG_SENSORS_LM85 is not set
+# CONFIG_SENSORS_LM87 is not set
+# CONFIG_SENSORS_LM90 is not set
+# CONFIG_SENSORS_LM92 is not set
+# CONFIG_SENSORS_LM93 is not set
+# CONFIG_SENSORS_LTC4215 is not set
+# CONFIG_SENSORS_LTC4245 is not set
+# CONFIG_SENSORS_LTC4261 is not set
+# CONFIG_SENSORS_LM95241 is not set
+# CONFIG_SENSORS_MAX1111 is not set
+# CONFIG_SENSORS_MAX1619 is not set
+# CONFIG_SENSORS_MAX6650 is not set
+# CONFIG_SENSORS_PC87360 is not set
+# CONFIG_SENSORS_PC87427 is not set
+# CONFIG_SENSORS_PCF8591 is not set
+# CONFIG_SENSORS_SHT15 is not set
+# CONFIG_SENSORS_S3C is not set
+# CONFIG_SENSORS_SMM665 is not set
+# CONFIG_SENSORS_DME1737 is not set
+# CONFIG_SENSORS_EMC1403 is not set
+# CONFIG_SENSORS_EMC2103 is not set
+# CONFIG_SENSORS_SMSC47M1 is not set
+# CONFIG_SENSORS_SMSC47M192 is not set
+# CONFIG_SENSORS_SMSC47B397 is not set
+# CONFIG_SENSORS_ADS7828 is not set
+# CONFIG_SENSORS_ADS7871 is not set
+# CONFIG_SENSORS_AMC6821 is not set
+# CONFIG_SENSORS_THMC50 is not set
+# CONFIG_SENSORS_TMP102 is not set
+# CONFIG_SENSORS_TMP401 is not set
+# CONFIG_SENSORS_TMP421 is not set
+# CONFIG_SENSORS_VT1211 is not set
+# CONFIG_SENSORS_W83781D is not set
+# CONFIG_SENSORS_W83791D is not set
+# CONFIG_SENSORS_W83792D is not set
+# CONFIG_SENSORS_W83793 is not set
+# CONFIG_SENSORS_W83795 is not set
+# CONFIG_SENSORS_W83L785TS is not set
+# CONFIG_SENSORS_W83L786NG is not set
+# CONFIG_SENSORS_W83627HF is not set
+# CONFIG_SENSORS_W83627EHF is not set
+# CONFIG_SENSORS_LIS3_SPI is not set
+# CONFIG_SENSORS_LIS3_I2C is not set
+CONFIG_THERMAL=m
+# CONFIG_THERMAL_HWMON is not set
+CONFIG_WATCHDOG=y
+# CONFIG_WATCHDOG_NOWAYOUT is not set
+# Watchdog Device Drivers
+# CONFIG_SOFT_WATCHDOG is not set
+CONFIG_S3C2410_WATCHDOG=y
+# CONFIG_MAX63XX_WATCHDOG is not set
+# USB-based Watchdog Cards
+# CONFIG_USBPCWATCHDOG is not set
+CONFIG_SSB_POSSIBLE=y
+# Sonics Silicon Backplane
+# CONFIG_SSB is not set
+CONFIG_MFD_SUPPORT=y
+# CONFIG_MFD_CORE is not set
+# CONFIG_MFD_88PM860X is not set
+# CONFIG_MFD_SM501 is not set
+# CONFIG_MFD_ASIC3 is not set
+# CONFIG_HTC_EGPIO is not set
+# CONFIG_HTC_PASIC3 is not set
+# CONFIG_HTC_I2CPLD is not set
+# CONFIG_TPS65010 is not set
+# CONFIG_TPS6507X is not set
+# CONFIG_TWL4030_CORE is not set
+# CONFIG_MFD_STMPE is not set
+# CONFIG_MFD_TC35892 is not set
+# CONFIG_MFD_TMIO is not set
+# CONFIG_MFD_T7L66XB is not set
+# CONFIG_MFD_TC6387XB is not set
+# CONFIG_MFD_TC6393XB is not set
+# CONFIG_PMIC_DA903X is not set
+# CONFIG_PMIC_ADP5520 is not set
+# CONFIG_MFD_MAX8925 is not set
+# CONFIG_MFD_MAX8998 is not set
+# CONFIG_MFD_WM8400 is not set
+# CONFIG_MFD_WM831X_I2C is not set
+# CONFIG_MFD_WM831X_SPI is not set
+# CONFIG_MFD_WM8350_I2C is not set
+# CONFIG_MFD_WM8994 is not set
+# CONFIG_MFD_PCF50633 is not set
+# CONFIG_MFD_MC13XXX is not set
+# CONFIG_ABX500_CORE is not set
+# CONFIG_EZX_PCAP is not set
+# CONFIG_MFD_TPS6586X is not set
+# CONFIG_REGULATOR is not set
+# CONFIG_MEDIA_SUPPORT is not set
+# Graphics support
+# CONFIG_DRM is not set
+# CONFIG_VGASTATE is not set
+CONFIG_VIDEO_OUTPUT_CONTROL=y
+CONFIG_FB=y
+CONFIG_FIRMWARE_EDID=y
+# CONFIG_FB_DDC is not set
+# CONFIG_FB_BOOT_VESA_SUPPORT is not set
+CONFIG_FB_CFB_FILLRECT=y
+CONFIG_FB_CFB_COPYAREA=y
+CONFIG_FB_CFB_IMAGEBLIT=y
+# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
+# CONFIG_FB_SYS_FILLRECT is not set
+# CONFIG_FB_SYS_COPYAREA is not set
+# CONFIG_FB_SYS_IMAGEBLIT is not set
+# CONFIG_FB_FOREIGN_ENDIAN is not set
+# CONFIG_FB_SYS_FOPS is not set
+# CONFIG_FB_SVGALIB is not set
+# CONFIG_FB_MACMODES is not set
+# CONFIG_FB_BACKLIGHT is not set
+CONFIG_FB_MODE_HELPERS=y
+CONFIG_FB_TILEBLITTING=y
+# Frame buffer hardware drivers
+# CONFIG_FB_UVESA is not set
+# CONFIG_FB_S1D13XXX is not set
+CONFIG_FB_S3C2410=y
+# CONFIG_FB_S3C2410_DEBUG is not set
+# CONFIG_FB_VIRTUAL is not set
+# CONFIG_FB_METRONOME is not set
+# CONFIG_FB_MB862XX is not set
+# CONFIG_FB_BROADSHEET is not set
+CONFIG_BACKLIGHT_LCD_SUPPORT=y
+CONFIG_LCD_CLASS_DEVICE=y
+# CONFIG_LCD_L4F00242T03 is not set
+# CONFIG_LCD_LMS283GF05 is not set
+# CONFIG_LCD_LTV350QV is not set
+# CONFIG_LCD_TDO24M is not set
+# CONFIG_LCD_VGG2432A4 is not set
+CONFIG_LCD_PLATFORM=y
+# CONFIG_LCD_S6E63M0 is not set
+CONFIG_BACKLIGHT_CLASS_DEVICE=y
+# CONFIG_BACKLIGHT_GENERIC is not set
+CONFIG_BACKLIGHT_PWM=y
+# CONFIG_BACKLIGHT_ADP8860 is not set
+# Display device support
+CONFIG_DISPLAY_SUPPORT=y
+# Display hardware drivers
+# Console display driver support
+CONFIG_DUMMY_CONSOLE=y
+CONFIG_FRAMEBUFFER_CONSOLE=y
+CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
+CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
+CONFIG_FONTS=y
+CONFIG_FONT_8x8=y
+CONFIG_FONT_8x16=y
+CONFIG_FONT_6x11=y
+CONFIG_FONT_7x14=y
+CONFIG_FONT_PEARL_8x8=y
+CONFIG_FONT_ACORN_8x8=y
+CONFIG_FONT_MINI_4x6=y
+CONFIG_FONT_SUN8x16=y
+CONFIG_FONT_SUN12x22=y
+CONFIG_FONT_10x18=y
+CONFIG_LOGO=y
+# CONFIG_LOGO_LINUX_MONO is not set
+# CONFIG_LOGO_LINUX_VGA16 is not set
+CONFIG_LOGO_LINUX_CLUT224=y
+# CONFIG_SOUND is not set
+CONFIG_HID_SUPPORT=y
+CONFIG_HID=y
+CONFIG_HIDRAW=y
+# USB Input Devices
+CONFIG_USB_HID=y
+CONFIG_HID_PID=y
+CONFIG_USB_HIDDEV=y
+# Special HID drivers
+# CONFIG_HID_3M_PCT is not set
+CONFIG_HID_A4TECH=y
+# CONFIG_HID_ACRUX_FF is not set
+CONFIG_HID_APPLE=y
+CONFIG_HID_BELKIN=y
+# CONFIG_HID_CANDO is not set
+CONFIG_HID_CHERRY=y
+CONFIG_HID_CHICONY=y
+CONFIG_HID_CYPRESS=y
+# CONFIG_HID_DRAGONRISE is not set
+# CONFIG_HID_EGALAX is not set
+CONFIG_HID_EZKEY=y
+CONFIG_HID_KYE=y
+# CONFIG_HID_UCLOGIC is not set
+# CONFIG_HID_WALTOP is not set
+CONFIG_HID_GYRATION=y
+# CONFIG_HID_TWINHAN is not set
+CONFIG_HID_KENSINGTON=y
+CONFIG_HID_LOGITECH=y
+# CONFIG_LOGITECH_FF is not set
+# CONFIG_LOGIRUMBLEPAD2_FF is not set
+# CONFIG_LOGIG940_FF is not set
+# CONFIG_LOGIWII_FF is not set
+CONFIG_HID_MICROSOFT=y
+# CONFIG_HID_MOSART is not set
+CONFIG_HID_MONTEREY=y
+CONFIG_HID_NTRIG=y
+# CONFIG_HID_ORTEK is not set
+CONFIG_HID_PANTHERLORD=y
+# CONFIG_PANTHERLORD_FF is not set
+CONFIG_HID_PETALYNX=y
+# CONFIG_HID_PICOLCD is not set
+# CONFIG_HID_QUANTA is not set
+# CONFIG_HID_ROCCAT is not set
+# CONFIG_HID_ROCCAT_KONE is not set
+# CONFIG_HID_ROCCAT_PYRA is not set
+CONFIG_HID_SAMSUNG=y
+CONFIG_HID_SONY=y
+# CONFIG_HID_STANTUM is not set
+CONFIG_HID_SUNPLUS=y
+# CONFIG_HID_GREENASIA is not set
+# CONFIG_HID_SMARTJOYPLUS is not set
+CONFIG_HID_TOPSEED=y
+# CONFIG_HID_THRUSTMASTER is not set
+# CONFIG_HID_ZEROPLUS is not set
+# CONFIG_HID_ZYDACRON is not set
+CONFIG_USB_SUPPORT=y
+CONFIG_USB_ARCH_HAS_HCD=y
+CONFIG_USB_ARCH_HAS_OHCI=y
+# CONFIG_USB_ARCH_HAS_EHCI is not set
+CONFIG_USB=y
+# CONFIG_USB_DEBUG is not set
+# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
+# Miscellaneous USB options
+CONFIG_USB_DEVICEFS=y
+# CONFIG_USB_DEVICE_CLASS is not set
+# CONFIG_USB_DYNAMIC_MINORS is not set
+# CONFIG_USB_MON is not set
+# CONFIG_USB_WUSB is not set
+# CONFIG_USB_WUSB_CBAF is not set
+# USB Host Controller Drivers
+# CONFIG_USB_C67X00_HCD is not set
+# CONFIG_USB_OXU210HP_HCD is not set
+# CONFIG_USB_ISP116X_HCD is not set
+# CONFIG_USB_ISP1760_HCD is not set
+# CONFIG_USB_ISP1362_HCD is not set
+CONFIG_USB_OHCI_HCD=y
+# CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
+# CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
+CONFIG_USB_OHCI_LITTLE_ENDIAN=y
+# CONFIG_USB_SL811_HCD is not set
+# CONFIG_USB_R8A66597_HCD is not set
+# CONFIG_USB_HWA_HCD is not set
+# CONFIG_USB_MUSB_HDRC is not set
+# USB Device Class drivers
+CONFIG_USB_ACM=m
+# CONFIG_USB_PRINTER is not set
+CONFIG_USB_WDM=m
+# CONFIG_USB_TMC is not set
+# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
+# also be needed; see USB_STORAGE Help for more info
+CONFIG_USB_STORAGE=m
+# CONFIG_USB_STORAGE_DEBUG is not set
+CONFIG_USB_STORAGE_DATAFAB=m
+# CONFIG_USB_STORAGE_FREECOM is not set
+CONFIG_USB_STORAGE_ISD200=m
+CONFIG_USB_STORAGE_USBAT=m
+CONFIG_USB_STORAGE_SDDR09=m
+CONFIG_USB_STORAGE_SDDR55=m
+CONFIG_USB_STORAGE_JUMPSHOT=m
+CONFIG_USB_STORAGE_ALAUDA=m
+# CONFIG_USB_STORAGE_ONETOUCH is not set
+# CONFIG_USB_STORAGE_KARMA is not set
+# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
+# CONFIG_USB_UAS is not set
+CONFIG_USB_LIBUSUAL=y
+# USB Imaging devices
+# CONFIG_USB_MDC800 is not set
+# CONFIG_USB_MICROTEK is not set
+# USB port drivers
+CONFIG_USB_SERIAL=m
+# CONFIG_USB_EZUSB is not set
+# CONFIG_USB_SERIAL_GENERIC is not set
+# CONFIG_USB_SERIAL_AIRCABLE is not set
+# CONFIG_USB_SERIAL_ARK3116 is not set
+# CONFIG_USB_SERIAL_BELKIN is not set
+# CONFIG_USB_SERIAL_CH341 is not set
+# CONFIG_USB_SERIAL_WHITEHEAT is not set
+# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
+CONFIG_USB_SERIAL_CP210X=m
+# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
+# CONFIG_USB_SERIAL_EMPEG is not set
+CONFIG_USB_SERIAL_FTDI_SIO=m
+# CONFIG_USB_SERIAL_FUNSOFT is not set
+# CONFIG_USB_SERIAL_VISOR is not set
+# CONFIG_USB_SERIAL_IPAQ is not set
+# CONFIG_USB_SERIAL_IR is not set
+# CONFIG_USB_SERIAL_EDGEPORT is not set
+# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
+# CONFIG_USB_SERIAL_GARMIN is not set
+# CONFIG_USB_SERIAL_IPW is not set
+# CONFIG_USB_SERIAL_IUU is not set
+# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
+# CONFIG_USB_SERIAL_KEYSPAN is not set
+# CONFIG_USB_SERIAL_KLSI is not set
+# CONFIG_USB_SERIAL_KOBIL_SCT is not set
+# CONFIG_USB_SERIAL_MCT_U232 is not set
+# CONFIG_USB_SERIAL_MOS7720 is not set
+# CONFIG_USB_SERIAL_MOS7840 is not set
+# CONFIG_USB_SERIAL_MOTOROLA is not set
+# CONFIG_USB_SERIAL_NAVMAN is not set
+# CONFIG_USB_SERIAL_PL2303 is not set
+# CONFIG_USB_SERIAL_OTI6858 is not set
+# CONFIG_USB_SERIAL_QCAUX is not set
+# CONFIG_USB_SERIAL_QUALCOMM is not set
+CONFIG_USB_SERIAL_SPCP8X5=m
+# CONFIG_USB_SERIAL_HP4X is not set
+# CONFIG_USB_SERIAL_SAFE is not set
+# CONFIG_USB_SERIAL_SAMBA is not set
+# CONFIG_USB_SERIAL_SIEMENS_MPI is not set
+# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
+# CONFIG_USB_SERIAL_SYMBOL is not set
+# CONFIG_USB_SERIAL_TI is not set
+# CONFIG_USB_SERIAL_CYBERJACK is not set
+# CONFIG_USB_SERIAL_XIRCOM is not set
+# CONFIG_USB_SERIAL_OPTION is not set
+# CONFIG_USB_SERIAL_OMNINET is not set
+# CONFIG_USB_SERIAL_OPTICON is not set
+# CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set
+# CONFIG_USB_SERIAL_ZIO is not set
+# CONFIG_USB_SERIAL_SSU100 is not set
+# CONFIG_USB_SERIAL_DEBUG is not set
+# USB Miscellaneous drivers
+# CONFIG_USB_EMI62 is not set
+# CONFIG_USB_EMI26 is not set
+# CONFIG_USB_ADUTUX is not set
+# CONFIG_USB_SEVSEG is not set
+# CONFIG_USB_RIO500 is not set
+# CONFIG_USB_LEGOTOWER is not set
+# CONFIG_USB_LCD is not set
+# CONFIG_USB_LED is not set
+# CONFIG_USB_CYPRESS_CY7C63 is not set
+# CONFIG_USB_CYTHERM is not set
+# CONFIG_USB_IDMOUSE is not set
+# CONFIG_USB_FTDI_ELAN is not set
+# CONFIG_USB_APPLEDISPLAY is not set
+# CONFIG_USB_LD is not set
+# CONFIG_USB_TRANCEVIBRATOR is not set
+# CONFIG_USB_IOWARRIOR is not set
+# CONFIG_USB_TEST is not set
+# CONFIG_USB_ISIGHTFW is not set
+# CONFIG_USB_YUREX is not set
+CONFIG_USB_GADGET=y
+# CONFIG_USB_GADGET_DEBUG is not set
+# CONFIG_USB_GADGET_DEBUG_FILES is not set
+# CONFIG_USB_GADGET_DEBUG_FS is not set
+CONFIG_USB_GADGET_VBUS_DRAW=2
+CONFIG_USB_GADGET_SELECTED=y
+# CONFIG_USB_GADGET_R8A66597 is not set
+CONFIG_USB_GADGET_S3C2410=y
+CONFIG_USB_S3C2410=y
+# CONFIG_USB_S3C2410_DEBUG is not set
+# CONFIG_USB_GADGET_M66592 is not set
+# CONFIG_USB_GADGET_DUMMY_HCD is not set
+# CONFIG_USB_GADGET_DUALSPEED is not set
+CONFIG_USB_ZERO=m
+# CONFIG_USB_AUDIO is not set
+CONFIG_USB_ETH=m
+CONFIG_USB_ETH_RNDIS=y
+# CONFIG_USB_ETH_EEM is not set
+CONFIG_USB_GADGETFS=m
+# CONFIG_USB_FUNCTIONFS is not set
+CONFIG_USB_FILE_STORAGE=m
+# CONFIG_USB_FILE_STORAGE_TEST is not set
+# CONFIG_USB_MASS_STORAGE is not set
+CONFIG_USB_G_SERIAL=m
+# CONFIG_USB_MIDI_GADGET is not set
+# CONFIG_USB_G_PRINTER is not set
+CONFIG_USB_CDC_COMPOSITE=m
+# CONFIG_USB_G_MULTI is not set
+# CONFIG_USB_G_HID is not set
+# CONFIG_USB_G_DBGP is not set
+# OTG and related infrastructure
+# CONFIG_USB_GPIO_VBUS is not set
+# CONFIG_USB_ULPI is not set
+# CONFIG_NOP_USB_XCEIV is not set
+CONFIG_MMC=y
+# CONFIG_MMC_DEBUG is not set
+# CONFIG_MMC_UNSAFE_RESUME is not set
+# MMC/SD/SDIO Card Drivers
+CONFIG_MMC_BLOCK=y
+CONFIG_MMC_BLOCK_MINORS=8
+CONFIG_MMC_BLOCK_BOUNCE=y
+CONFIG_SDIO_UART=y
+# CONFIG_MMC_TEST is not set
+# MMC/SD/SDIO Host Controller Drivers
+CONFIG_MMC_SDHCI=y
+# CONFIG_MMC_SDHCI_PLTFM is not set
+# CONFIG_MMC_SDHCI_S3C is not set
+CONFIG_MMC_SPI=y
+CONFIG_MMC_S3C=y
+# CONFIG_MMC_S3C_HW_SDIO_IRQ is not set
+CONFIG_MMC_S3C_PIO=y
+# CONFIG_MMC_S3C_DMA is not set
+# CONFIG_MMC_S3C_PIODMA is not set
+# CONFIG_MMC_USHC is not set
+# CONFIG_MEMSTICK is not set
+CONFIG_NEW_LEDS=y
+CONFIG_LEDS_CLASS=y
+# LED drivers
+CONFIG_LEDS_S3C24XX=y
+# CONFIG_LEDS_PCA9532 is not set
+CONFIG_LEDS_GPIO=y
+CONFIG_LEDS_GPIO_PLATFORM=y
+# CONFIG_LEDS_LP3944 is not set
+# CONFIG_LEDS_LP5521 is not set
+# CONFIG_LEDS_LP5523 is not set
+# CONFIG_LEDS_PCA955X is not set
+# CONFIG_LEDS_DAC124S085 is not set
+# CONFIG_LEDS_PWM is not set
+# CONFIG_LEDS_BD2802 is not set
+# CONFIG_LEDS_LT3593 is not set
+CONFIG_LEDS_TRIGGERS=y
+# LED Triggers
+CONFIG_LEDS_TRIGGER_TIMER=y
+CONFIG_LEDS_TRIGGER_HEARTBEAT=y
+CONFIG_LEDS_TRIGGER_BACKLIGHT=y
+CONFIG_LEDS_TRIGGER_GPIO=y
+CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
+# iptables trigger is under Netfilter config (LED target)
+# CONFIG_ACCESSIBILITY is not set
+CONFIG_RTC_LIB=y
+CONFIG_RTC_CLASS=y
+CONFIG_RTC_HCTOSYS=y
+CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
+# CONFIG_RTC_DEBUG is not set
+# RTC interfaces
+CONFIG_RTC_INTF_SYSFS=y
+CONFIG_RTC_INTF_PROC=y
+CONFIG_RTC_INTF_DEV=y
+CONFIG_RTC_INTF_DEV_UIE_EMUL=y
+# CONFIG_RTC_DRV_TEST is not set
+# I2C RTC drivers
+# CONFIG_RTC_DRV_DS1307 is not set
+# CONFIG_RTC_DRV_DS1374 is not set
+# CONFIG_RTC_DRV_DS1672 is not set
+# CONFIG_RTC_DRV_DS3232 is not set
+# CONFIG_RTC_DRV_MAX6900 is not set
+# CONFIG_RTC_DRV_RS5C372 is not set
+# CONFIG_RTC_DRV_ISL1208 is not set
+# CONFIG_RTC_DRV_ISL12022 is not set
+# CONFIG_RTC_DRV_X1205 is not set
+# CONFIG_RTC_DRV_PCF8563 is not set
+# CONFIG_RTC_DRV_PCF8583 is not set
+# CONFIG_RTC_DRV_M41T80 is not set
+# CONFIG_RTC_DRV_BQ32K is not set
+# CONFIG_RTC_DRV_S35390A is not set
+# CONFIG_RTC_DRV_FM3130 is not set
+# CONFIG_RTC_DRV_RX8581 is not set
+# CONFIG_RTC_DRV_RX8025 is not set
+# SPI RTC drivers
+# CONFIG_RTC_DRV_M41T94 is not set
+# CONFIG_RTC_DRV_DS1305 is not set
+# CONFIG_RTC_DRV_DS1390 is not set
+# CONFIG_RTC_DRV_MAX6902 is not set
+# CONFIG_RTC_DRV_R9701 is not set
+# CONFIG_RTC_DRV_RS5C348 is not set
+# CONFIG_RTC_DRV_DS3234 is not set
+# CONFIG_RTC_DRV_PCF2123 is not set
+# Platform RTC drivers
+# CONFIG_RTC_DRV_CMOS is not set
+# CONFIG_RTC_DRV_DS1286 is not set
+# CONFIG_RTC_DRV_DS1511 is not set
+# CONFIG_RTC_DRV_DS1553 is not set
+# CONFIG_RTC_DRV_DS1742 is not set
+# CONFIG_RTC_DRV_STK17TA8 is not set
+# CONFIG_RTC_DRV_M48T86 is not set
+# CONFIG_RTC_DRV_M48T35 is not set
+# CONFIG_RTC_DRV_M48T59 is not set
+# CONFIG_RTC_DRV_MSM6242 is not set
+# CONFIG_RTC_DRV_BQ4802 is not set
+# CONFIG_RTC_DRV_RP5C01 is not set
+# CONFIG_RTC_DRV_V3020 is not set
+# on-CPU RTC drivers
+CONFIG_RTC_DRV_S3C=y
+CONFIG_DMADEVICES=y
+# CONFIG_DMADEVICES_DEBUG is not set
+# DMA Devices
+# CONFIG_TIMB_DMA is not set
+# CONFIG_AUXDISPLAY is not set
+# CONFIG_UIO is not set
+# CONFIG_STAGING is not set
+# File systems
+CONFIG_EXT2_FS=m
+CONFIG_EXT2_FS_XATTR=y
+CONFIG_EXT2_FS_POSIX_ACL=y
+CONFIG_EXT2_FS_SECURITY=y
+# CONFIG_EXT2_FS_XIP is not set
+CONFIG_EXT3_FS=y
+CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
+CONFIG_EXT3_FS_XATTR=y
+CONFIG_EXT3_FS_POSIX_ACL=y
+CONFIG_EXT3_FS_SECURITY=y
+# CONFIG_EXT4_FS is not set
+CONFIG_JBD=y
+# CONFIG_JBD_DEBUG is not set
+CONFIG_FS_MBCACHE=y
+# CONFIG_REISERFS_FS is not set
+# CONFIG_JFS_FS is not set
+CONFIG_FS_POSIX_ACL=y
+# CONFIG_XFS_FS is not set
+# CONFIG_GFS2_FS is not set
+# CONFIG_OCFS2_FS is not set
+# CONFIG_BTRFS_FS is not set
+# CONFIG_NILFS2_FS is not set
+CONFIG_FILE_LOCKING=y
+CONFIG_FSNOTIFY=y
+CONFIG_DNOTIFY=y
+CONFIG_INOTIFY_USER=y
+# CONFIG_FANOTIFY is not set
+# CONFIG_QUOTA is not set
+# CONFIG_QUOTACTL is not set
+CONFIG_AUTOFS4_FS=y
+# CONFIG_FUSE_FS is not set
+CONFIG_GENERIC_ACL=y
+# Caches
+# CONFIG_FSCACHE is not set
+# CD-ROM/DVD Filesystems
+# CONFIG_ISO9660_FS is not set
+# CONFIG_UDF_FS is not set
+# DOS/FAT/NT Filesystems
+CONFIG_FAT_FS=y
+CONFIG_MSDOS_FS=y
+CONFIG_VFAT_FS=y
+CONFIG_FAT_DEFAULT_CODEPAGE=437
+CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
+# CONFIG_NTFS_FS is not set
+# Pseudo filesystems
+CONFIG_PROC_FS=y
+CONFIG_PROC_SYSCTL=y
+CONFIG_PROC_PAGE_MONITOR=y
+CONFIG_SYSFS=y
+CONFIG_TMPFS=y
+CONFIG_TMPFS_POSIX_ACL=y
+# CONFIG_HUGETLB_PAGE is not set
+CONFIG_CONFIGFS_FS=m
+CONFIG_MISC_FILESYSTEMS=y
+# CONFIG_ADFS_FS is not set
+# CONFIG_AFFS_FS is not set
+# CONFIG_ECRYPT_FS is not set
+# CONFIG_HFS_FS is not set
+# CONFIG_HFSPLUS_FS is not set
+# CONFIG_BEFS_FS is not set
+# CONFIG_BFS_FS is not set
+# CONFIG_EFS_FS is not set
+CONFIG_JFFS2_FS=y
+CONFIG_JFFS2_FS_DEBUG=0
+CONFIG_JFFS2_FS_WRITEBUFFER=y
+# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
+# CONFIG_JFFS2_SUMMARY is not set
+# CONFIG_JFFS2_FS_XATTR is not set
+# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
+CONFIG_JFFS2_ZLIB=y
+# CONFIG_JFFS2_LZO is not set
+CONFIG_JFFS2_RTIME=y
+# CONFIG_JFFS2_RUBIN is not set
+# CONFIG_LOGFS is not set
+CONFIG_CRAMFS=y
+# CONFIG_SQUASHFS is not set
+# CONFIG_VXFS_FS is not set
+# CONFIG_MINIX_FS is not set
+# CONFIG_OMFS_FS is not set
+# CONFIG_HPFS_FS is not set
+# CONFIG_QNX4FS_FS is not set
+CONFIG_ROMFS_FS=y
+# CONFIG_ROMFS_BACKED_BY_BLOCK is not set
+# CONFIG_ROMFS_BACKED_BY_MTD is not set
+CONFIG_ROMFS_BACKED_BY_BOTH=y
+CONFIG_ROMFS_ON_BLOCK=y
+CONFIG_ROMFS_ON_MTD=y
+# CONFIG_SYSV_FS is not set
+# CONFIG_UFS_FS is not set
+CONFIG_NETWORK_FILESYSTEMS=y
+CONFIG_NFS_FS=y
+CONFIG_NFS_V3=y
+CONFIG_NFS_V3_ACL=y
+CONFIG_NFS_V4=y
+# CONFIG_NFS_V4_1 is not set
+CONFIG_ROOT_NFS=y
+# CONFIG_NFS_USE_LEGACY_DNS is not set
+CONFIG_NFS_USE_KERNEL_DNS=y
+# CONFIG_NFS_USE_NEW_IDMAPPER is not set
+# CONFIG_NFSD is not set
+CONFIG_LOCKD=y
+CONFIG_LOCKD_V4=y
+CONFIG_NFS_ACL_SUPPORT=y
+CONFIG_NFS_COMMON=y
+CONFIG_SUNRPC=y
+CONFIG_SUNRPC_GSS=y
+CONFIG_RPCSEC_GSS_KRB5=y
+# CONFIG_CEPH_FS is not set
+# CONFIG_CIFS is not set
+# CONFIG_NCP_FS is not set
+# CONFIG_CODA_FS is not set
+# CONFIG_AFS_FS is not set
+# Partition Types
+CONFIG_PARTITION_ADVANCED=y
+# CONFIG_ACORN_PARTITION is not set
+# CONFIG_OSF_PARTITION is not set
+# CONFIG_AMIGA_PARTITION is not set
+# CONFIG_ATARI_PARTITION is not set
+# CONFIG_MAC_PARTITION is not set
+CONFIG_MSDOS_PARTITION=y
+CONFIG_BSD_DISKLABEL=y
+CONFIG_MINIX_SUBPARTITION=y
+CONFIG_SOLARIS_X86_PARTITION=y
+CONFIG_UNIXWARE_DISKLABEL=y
+CONFIG_LDM_PARTITION=y
+# CONFIG_LDM_DEBUG is not set
+# CONFIG_SGI_PARTITION is not set
+# CONFIG_ULTRIX_PARTITION is not set
+# CONFIG_SUN_PARTITION is not set
+# CONFIG_KARMA_PARTITION is not set
+CONFIG_EFI_PARTITION=y
+# CONFIG_SYSV68_PARTITION is not set
+CONFIG_NLS=y
+CONFIG_NLS_DEFAULT="cp437"
+# CONFIG_NLS_CODEPAGE_437 is not set
+# CONFIG_NLS_CODEPAGE_737 is not set
+# CONFIG_NLS_CODEPAGE_775 is not set
+CONFIG_NLS_CODEPAGE_850=m
+# CONFIG_NLS_CODEPAGE_852 is not set
+# CONFIG_NLS_CODEPAGE_855 is not set
+# CONFIG_NLS_CODEPAGE_857 is not set
+# CONFIG_NLS_CODEPAGE_860 is not set
+# CONFIG_NLS_CODEPAGE_861 is not set
+# CONFIG_NLS_CODEPAGE_862 is not set
+# CONFIG_NLS_CODEPAGE_863 is not set
+# CONFIG_NLS_CODEPAGE_864 is not set
+# CONFIG_NLS_CODEPAGE_865 is not set
+# CONFIG_NLS_CODEPAGE_866 is not set
+# CONFIG_NLS_CODEPAGE_869 is not set
+# CONFIG_NLS_CODEPAGE_936 is not set
+# CONFIG_NLS_CODEPAGE_950 is not set
+# CONFIG_NLS_CODEPAGE_932 is not set
+# CONFIG_NLS_CODEPAGE_949 is not set
+# CONFIG_NLS_CODEPAGE_874 is not set
+# CONFIG_NLS_ISO8859_8 is not set
+CONFIG_NLS_CODEPAGE_1250=m
+# CONFIG_NLS_CODEPAGE_1251 is not set
+CONFIG_NLS_ASCII=m
+CONFIG_NLS_ISO8859_1=m
+# CONFIG_NLS_ISO8859_2 is not set
+# CONFIG_NLS_ISO8859_3 is not set
+# CONFIG_NLS_ISO8859_4 is not set
+# CONFIG_NLS_ISO8859_5 is not set
+# CONFIG_NLS_ISO8859_6 is not set
+# CONFIG_NLS_ISO8859_7 is not set
+# CONFIG_NLS_ISO8859_9 is not set
+# CONFIG_NLS_ISO8859_13 is not set
+# CONFIG_NLS_ISO8859_14 is not set
+CONFIG_NLS_ISO8859_15=m
+# CONFIG_NLS_KOI8_R is not set
+# CONFIG_NLS_KOI8_U is not set
+CONFIG_NLS_UTF8=m
+# CONFIG_DLM is not set
+# Kernel hacking
+# CONFIG_PRINTK_TIME is not set
+# CONFIG_ENABLE_WARN_DEPRECATED is not set
+# CONFIG_ENABLE_MUST_CHECK is not set
+CONFIG_FRAME_WARN=1024
+# CONFIG_MAGIC_SYSRQ is not set
+CONFIG_STRIP_ASM_SYMS=y
+# CONFIG_UNUSED_SYMBOLS is not set
+CONFIG_DEBUG_FS=y
+# CONFIG_HEADERS_CHECK is not set
+CONFIG_DEBUG_KERNEL=y
+# CONFIG_DEBUG_SHIRQ is not set
+# CONFIG_LOCKUP_DETECTOR is not set
+# CONFIG_HARDLOCKUP_DETECTOR is not set
+# CONFIG_DETECT_HUNG_TASK is not set
+# CONFIG_SCHED_DEBUG is not set
+# CONFIG_SCHEDSTATS is not set
+# CONFIG_TIMER_STATS is not set
+# CONFIG_DEBUG_OBJECTS is not set
+# CONFIG_SLUB_DEBUG_ON is not set
+# CONFIG_SLUB_STATS is not set
+# CONFIG_DEBUG_KMEMLEAK is not set
+# CONFIG_DEBUG_RT_MUTEXES is not set
+# CONFIG_RT_MUTEX_TESTER is not set
+# CONFIG_DEBUG_SPINLOCK is not set
+# CONFIG_DEBUG_MUTEXES is not set
+CONFIG_BKL=y
+# CONFIG_DEBUG_LOCK_ALLOC is not set
+# CONFIG_PROVE_LOCKING is not set
+# CONFIG_SPARSE_RCU_POINTER is not set
+# CONFIG_LOCK_STAT is not set
+# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
+# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
+# CONFIG_DEBUG_KOBJECT is not set
+CONFIG_DEBUG_BUGVERBOSE=y
+CONFIG_DEBUG_INFO=y
+# CONFIG_DEBUG_INFO_REDUCED is not set
+# CONFIG_DEBUG_VM is not set
+# CONFIG_DEBUG_WRITECOUNT is not set
+CONFIG_DEBUG_MEMORY_INIT=y
+# CONFIG_DEBUG_LIST is not set
+# CONFIG_TEST_LIST_SORT is not set
+# CONFIG_DEBUG_SG is not set
+# CONFIG_DEBUG_NOTIFIERS is not set
+# CONFIG_DEBUG_CREDENTIALS is not set
+# CONFIG_BOOT_PRINTK_DELAY is not set
+# CONFIG_RCU_TORTURE_TEST is not set
+# CONFIG_BACKTRACE_SELF_TEST is not set
+# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
+# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
+# CONFIG_LKDTM is not set
+# CONFIG_FAULT_INJECTION is not set
+# CONFIG_LATENCYTOP is not set
+CONFIG_SYSCTL_SYSCALL_CHECK=y
+# CONFIG_PAGE_POISONING is not set
+CONFIG_HAVE_FUNCTION_TRACER=y
+CONFIG_HAVE_DYNAMIC_FTRACE=y
+CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
+CONFIG_TRACING_SUPPORT=y
+CONFIG_FTRACE=y
+# CONFIG_FUNCTION_TRACER is not set
+# CONFIG_SCHED_TRACER is not set
+# CONFIG_ENABLE_DEFAULT_TRACERS is not set
+CONFIG_BRANCH_PROFILE_NONE=y
+# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
+# CONFIG_PROFILE_ALL_BRANCHES is not set
+# CONFIG_STACK_TRACER is not set
+# CONFIG_BLK_DEV_IO_TRACE is not set
+# CONFIG_DYNAMIC_DEBUG is not set
+# CONFIG_ATOMIC64_SELFTEST is not set
+# CONFIG_SAMPLES is not set
+CONFIG_HAVE_ARCH_KGDB=y
+# CONFIG_KGDB is not set
+# CONFIG_STRICT_DEVMEM is not set
+CONFIG_ARM_UNWIND=y
+CONFIG_DEBUG_USER=y
+# CONFIG_DEBUG_ERRORS is not set
+# CONFIG_DEBUG_STACK_USAGE is not set
+# CONFIG_DEBUG_LL is not set
+# CONFIG_OC_ETM is not set
+CONFIG_DEBUG_S3C_UART=0
+# Security options
+CONFIG_KEYS=y
+# CONFIG_KEYS_DEBUG_PROC_KEYS is not set
+# CONFIG_SECURITY_DMESG_RESTRICT is not set
+# CONFIG_SECURITY is not set
+# CONFIG_SECURITYFS is not set
+CONFIG_DEFAULT_SECURITY_DAC=y
+CONFIG_DEFAULT_SECURITY=""
+CONFIG_CRYPTO=y
+# Crypto core or helper
+CONFIG_CRYPTO_ALGAPI=y
+CONFIG_CRYPTO_ALGAPI2=y
+CONFIG_CRYPTO_AEAD=m
+CONFIG_CRYPTO_AEAD2=y
+CONFIG_CRYPTO_BLKCIPHER=y
+CONFIG_CRYPTO_BLKCIPHER2=y
+CONFIG_CRYPTO_HASH=y
+CONFIG_CRYPTO_HASH2=y
+CONFIG_CRYPTO_RNG=m
+CONFIG_CRYPTO_RNG2=y
+CONFIG_CRYPTO_PCOMP=m
+CONFIG_CRYPTO_PCOMP2=y
+CONFIG_CRYPTO_MANAGER=y
+CONFIG_CRYPTO_MANAGER2=y
+CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
+CONFIG_CRYPTO_GF128MUL=m
+CONFIG_CRYPTO_NULL=m
+CONFIG_CRYPTO_WORKQUEUE=y
+CONFIG_CRYPTO_CRYPTD=m
+CONFIG_CRYPTO_AUTHENC=m
+CONFIG_CRYPTO_TEST=m
+# Authenticated Encryption with Associated Data
+CONFIG_CRYPTO_CCM=m
+CONFIG_CRYPTO_GCM=m
+CONFIG_CRYPTO_SEQIV=m
+# Block modes
+CONFIG_CRYPTO_CBC=y
+CONFIG_CRYPTO_CTR=m
+CONFIG_CRYPTO_CTS=m
+CONFIG_CRYPTO_ECB=y
+CONFIG_CRYPTO_LRW=m
+CONFIG_CRYPTO_PCBC=m
+CONFIG_CRYPTO_XTS=m
+# Hash modes
+CONFIG_CRYPTO_HMAC=y
+CONFIG_CRYPTO_XCBC=m
+# CONFIG_CRYPTO_VMAC is not set
+# Digest
+CONFIG_CRYPTO_CRC32C=m
+CONFIG_CRYPTO_GHASH=m
+CONFIG_CRYPTO_MD4=m
+CONFIG_CRYPTO_MD5=y
+CONFIG_CRYPTO_MICHAEL_MIC=y
+CONFIG_CRYPTO_RMD128=m
+CONFIG_CRYPTO_RMD160=m
+CONFIG_CRYPTO_RMD256=m
+CONFIG_CRYPTO_RMD320=m
+CONFIG_CRYPTO_SHA1=m
+CONFIG_CRYPTO_SHA256=m
+CONFIG_CRYPTO_SHA512=m
+CONFIG_CRYPTO_TGR192=m
+CONFIG_CRYPTO_WP512=m
+# Ciphers
+CONFIG_CRYPTO_AES=y
+CONFIG_CRYPTO_ANUBIS=m
+CONFIG_CRYPTO_ARC4=y
+CONFIG_CRYPTO_BLOWFISH=m
+CONFIG_CRYPTO_CAMELLIA=m
+CONFIG_CRYPTO_CAST5=m
+CONFIG_CRYPTO_CAST6=m
+CONFIG_CRYPTO_DES=y
+CONFIG_CRYPTO_FCRYPT=m
+CONFIG_CRYPTO_KHAZAD=m
+CONFIG_CRYPTO_SALSA20=m
+CONFIG_CRYPTO_SEED=m
+CONFIG_CRYPTO_SERPENT=m
+CONFIG_CRYPTO_TEA=m
+CONFIG_CRYPTO_TWOFISH=m
+CONFIG_CRYPTO_TWOFISH_COMMON=m
+# Compression
+CONFIG_CRYPTO_DEFLATE=m
+CONFIG_CRYPTO_ZLIB=m
+CONFIG_CRYPTO_LZO=m
+# Random Number Generation
+CONFIG_CRYPTO_ANSI_CPRNG=m
+CONFIG_CRYPTO_HW=y
+# CONFIG_BINARY_PRINTF is not set
+# Library routines
+CONFIG_BITREVERSE=y
+CONFIG_GENERIC_FIND_LAST_BIT=y
+CONFIG_CRC_CCITT=m
+CONFIG_CRC16=m
+CONFIG_CRC_T10DIF=y
+CONFIG_CRC_ITU_T=y
+CONFIG_CRC32=y
+CONFIG_CRC7=y
+CONFIG_LIBCRC32C=m
+CONFIG_ZLIB_INFLATE=y
+CONFIG_ZLIB_DEFLATE=y
+CONFIG_LZO_COMPRESS=m
+CONFIG_LZO_DECOMPRESS=y
+CONFIG_DECOMPRESS_GZIP=y
+CONFIG_DECOMPRESS_BZIP2=y
+CONFIG_DECOMPRESS_LZMA=y
+CONFIG_DECOMPRESS_LZO=y
+CONFIG_HAS_IOMEM=y
+CONFIG_HAS_DMA=y
+CONFIG_NLATTR=y
+CONFIG_GENERIC_ATOMIC64=y
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0001.patch board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0001.patch
--- board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0001.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0001.patch	2011-05-25 20:32:58.000000000 +0200
@@ -0,0 +1,47 @@
+diff -NaurwB linux-2.6.37.6/arch/arm/mach-s3c2440/mach-mini2440.c linux-2.6.37.6_neu/arch/arm/mach-s3c2440/mach-mini2440.c
+--- linux-2.6.37.6/arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 19:41:25.000000000 +0200
++++ linux-2.6.37.6_neu/arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 20:01:06.515576002 +0200
+@@ -185,6 +185,43 @@
+ 		.lcdcon5	= (S3C2410_LCDCON5_FRM565 |
+ 				   S3C2410_LCDCON5_HWSWP),
++  [3] = { /* mini2440 + 3.5" TFT + TS -- New model as Nov 2009 "T35" */
++    _LCD_DECLARE(
++      7,                      /* The 3.5 is quite fast */
++      240, 21, 25, 6,         /* x timing */
++      320, 2, 4, 2,           /* y timing */
++      40),                    /* refresh rate */
++    .lcdcon5        = (S3C2410_LCDCON5_FRM565 |
++				   S3C2410_LCDCON5_INVVLINE |
++				   S3C2410_LCDCON5_INVVFRAME |
++				   S3C2410_LCDCON5_INVVDEN |
++				   S3C2410_LCDCON5_PWREN),
++  [4] = { /* mini2440 + 5.6" TFT + touchscreen -- Innolux AT056TN52 */
++          /* be sure the "power" jumper is set accordingly ! */
++    _LCD_DECLARE(
++      10,                     /* the 5.3" runs slower */
++      640, 41, 68, 22,        /* x timing */
++      480, 26, 6, 2,          /* y timing */
++  [5] = { /* mini2440 + 3,5" TFT + touchscreen -- SONY X35 */
++    _LCD_DECLARE(
++      7,
++      240, 1, 26, 5,          /* x timing */
++      320, 1, 5, 9,           /* y timing */
++      60),                    /* refresh rate */
++      S3C2410_LCDCON5_INVVCLK |
++      S3C2410_LCDCON5_HWSWP),
+ /* todo - put into gpio header */
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0002.patch board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0002.patch
--- board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0002.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0002.patch	2011-05-25 20:13:57.000000000 +0200
@@ -0,0 +1,53 @@
+--- linux-2.6.37.6/arch/arm/mach-s3c2440/mach-mini2440.c	2011-03-27 21:01:41.000000000 +0200
++++ linux-2.6.37.6_neu/arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 20:12:29.155576002 +0200
+@@ -47,6 +47,7 @@
+ #include <plat/iic.h>
+ #include <plat/mci.h>
+ #include <plat/udc.h>
++#include <plat/ts.h>
+ #include <linux/mtd/mtd.h>
+ #include <linux/mtd/nand.h>
+@@ -491,6 +492,11 @@
++static struct s3c2410_ts_mach_info mini2440_ts_cfg __initdata = {
++ .delay = 10000,
++ .presc = 0xff, /* slow as we can go */
+  * I2C devices
+@@ -521,6 +527,7 @@
+ 	&s3c_device_nand,
+ 	&s3c_device_sdi,
+ 	&s3c_device_iis,
++  &s3c_device_adc,
+ 	&mini2440_audio,
+@@ -605,8 +612,13 @@
+ 			features->done |= FEATURE_BACKLIGHT;
+ 			break;
+ 		case 't':
++      if (features->done & FEATURE_TOUCH)
+ 			printk(KERN_INFO "MINI2440: '%c' ignored, "
+-				"touchscreen not compiled in\n", f);
++        "touchscreen already set\n", f);
++      else
++        features->optional[features->count++] =
++        &s3c_device_ts;
++        features->done |= FEATURE_TOUCH;
+ 			break;
+ 		case 'c':
+ 			if (features->done & FEATURE_CAMERA)
+@@ -677,6 +689,7 @@
+ 	s3c24xx_mci_set_platdata(&mini2440_mmc_cfg);
+ 	s3c_nand_set_platdata(&mini2440_nand_info);
+ 	s3c_i2c0_set_platdata(NULL);
++  s3c24xx_ts_set_platdata(&mini2440_ts_cfg);
+ 	i2c_register_board_info(0, mini2440_i2c_devs,
+ 				ARRAY_SIZE(mini2440_i2c_devs));
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0003.patch board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0003.patch
--- board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0003.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0003.patch	2011-05-25 20:16:34.000000000 +0200
@@ -0,0 +1,10 @@
+--- linux-2.6.37.6/arch/arm/mach-s3c2440/Kconfig	2011-03-27 21:01:41.000000000 +0200
++++ linux-2.6.37.6_neu/arch/arm/mach-s3c2440/Kconfig	2011-05-25 20:15:31.685576002 +0200
+@@ -185,6 +185,7 @@
+ 	select LEDS_TRIGGER_BACKLIGHT
+ 	select S3C_DEV_NAND
+ 	select S3C_DEV_USB_HOST
++  select TOUCHSCREEN_S3C2410
+ 	help
+ 	  Say Y here to select support for the MINI2440. Is a 10cm x 10cm board
+ 	  available via various sources. It can come with a 3.5" or 7" touch LCD.
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0004.patch board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0004.patch
--- board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0004.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0004.patch	2011-05-25 20:24:21.000000000 +0200
@@ -0,0 +1,142 @@
+--- linux-2.6.37.6/arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 20:12:29.000000000 +0200
++++ linux-2.6.37.6_neu/arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 20:24:04.125576002 +0200
+@@ -39,7 +39,6 @@
+ #include <plat/regs-serial.h>
+ #include <mach/regs-gpio.h>
+-#include <mach/leds-gpio.h>
+ #include <mach/regs-mem.h>
+ #include <mach/regs-lcd.h>
+ #include <mach/irqs.h>
+@@ -401,78 +400,70 @@
+ /* LEDS */
+-static struct s3c24xx_led_platdata mini2440_led1_pdata = {
++static struct gpio_led gpio_leds[] = {
+ 	.name		= "led1",
+ 	.gpio		= S3C2410_GPB(5),
+-	.flags		= S3C24XX_LEDF_ACTLOW | S3C24XX_LEDF_TRISTATE,
+-	.def_trigger	= "heartbeat",
+-static struct s3c24xx_led_platdata mini2440_led2_pdata = {
++    .active_low = 1,
++    .default_trigger = "heartbeat",
+ 	.name		= "led2",
+ 	.gpio		= S3C2410_GPB(6),
+-	.def_trigger	= "nand-disk",
+-static struct s3c24xx_led_platdata mini2440_led3_pdata = {
++    .active_low = 1,
++    .default_trigger = "nand-disk",
++    .default_state = LEDS_GPIO_DEFSTATE_OFF,
+ 	.name		= "led3",
+ 	.gpio		= S3C2410_GPB(7),
+-	.def_trigger	= "mmc0",
+-static struct s3c24xx_led_platdata mini2440_led4_pdata = {
++    .active_low = 1,
++    .default_trigger = "mmc0",
+ 	.name		= "led4",
+ 	.gpio		= S3C2410_GPB(8),
+-	.def_trigger	= "",
++    .active_low = 1,
++    .default_trigger = "none",
+-static struct s3c24xx_led_platdata mini2440_led_backlight_pdata = {
++static struct gpio_led backlight_led[] = {
+ 	.name		= "backlight",
+ 	.gpio		= S3C2410_GPG(4),
+-	.def_trigger	= "backlight",
++    .active_low = 0,
++    .default_trigger = "backlight",
++    .default_state = LEDS_GPIO_DEFSTATE_ON,
+-static struct platform_device mini2440_led1 = {
+-	.name		= "s3c24xx_led",
+-	.id		= 1,
+-	.dev		= {
+-		.platform_data	= &mini2440_led1_pdata,
++static struct gpio_led_platform_data gpio_led_info = {
++  .leds = gpio_leds,
++  .num_leds = ARRAY_SIZE(gpio_leds),
+-static struct platform_device mini2440_led2 = {
+-	.id		= 2,
+-	.dev		= {
+-		.platform_data	= &mini2440_led2_pdata,
++static struct gpio_led_platform_data backlight_info = {
++  .leds = backlight_led,
++  .num_leds = ARRAY_SIZE(backlight_led),
+-static struct platform_device mini2440_led3 = {
+-	.id		= 3,
+-	.dev		= {
+-		.platform_data	= &mini2440_led3_pdata,
+-static struct platform_device mini2440_led4 = {
+-	.id		= 4,
++static struct platform_device mini2440_leds = {
++  .name = "leds-gpio",
++  .id = 0,
+ 	.dev		= {
+-		.platform_data	= &mini2440_led4_pdata,
++  .platform_data = &gpio_led_info,
+ static struct platform_device mini2440_led_backlight = {
+-	.id		= 5,
++  .id = 1,
+ 	.dev		= {
+-		.platform_data	= &mini2440_led_backlight_pdata,
++  .platform_data = &backlight_info,
+ /* AUDIO */
+@@ -519,10 +510,7 @@
+ 	&s3c_device_rtc,
+ 	&s3c_device_usbgadget,
+ 	&mini2440_device_eth,
+-	&mini2440_led1,
+-	&mini2440_led2,
+-	&mini2440_led3,
+-	&mini2440_led4,
++  &mini2440_leds,
+ 	&mini2440_button_device,
+ 	&s3c_device_nand,
+ 	&s3c_device_sdi,
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0005.patch board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0005.patch
--- board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0005.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.37.6-patches/linux-2.6.37.6-0005.patch	2011-05-25 21:40:17.000000000 +0200
@@ -0,0 +1,20 @@
+--- /arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 20:35:36.635576001 +0200
++++ /arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-25 21:14:12.755576001 +0200
+@@ -222,6 +222,17 @@
++	[6] = {  /* mini2440 + LVDS-Adapter (LQ121S1LG61) */
++		_LCD_DECLARE(
++			10,
++			800, 88, 40, 128,	/* x timing */
++			600, 23, 39, 4, 	/* y timing */
++			24),	/* refresh rate */
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39.config board/friendlyarm/mini2440/linux-2.6.39.config
--- board/friendlyarm/mini2440/linux-2.6.39.config	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39.config	2011-05-25 21:25:57.000000000 +0200
@@ -0,0 +1,2114 @@
+# Automatically generated make config: don't edit
+# Linux/arm 2.6.37.6 Kernel Configuration
+# Wed May 25 21:25:57 2011
+CONFIG_ARM=y
+CONFIG_HAVE_PWM=y
+CONFIG_SYS_SUPPORTS_APM_EMULATION=y
+CONFIG_GENERIC_GPIO=y
+CONFIG_ARCH_USES_GETTIMEOFFSET=y
+CONFIG_HAVE_PROC_CPU=y
+CONFIG_NO_IOPORT=y
+CONFIG_GENERIC_HARDIRQS=y
+CONFIG_STACKTRACE_SUPPORT=y
+CONFIG_HAVE_LATENCYTOP_SUPPORT=y
+CONFIG_LOCKDEP_SUPPORT=y
+CONFIG_TRACE_IRQFLAGS_SUPPORT=y
+CONFIG_HARDIRQS_SW_RESEND=y
+CONFIG_GENERIC_IRQ_PROBE=y
+CONFIG_RWSEM_GENERIC_SPINLOCK=y
+CONFIG_ARCH_HAS_CPUFREQ=y
+CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
+CONFIG_GENERIC_HWEIGHT=y
+CONFIG_GENERIC_CALIBRATE_DELAY=y
+CONFIG_NEED_DMA_MAP_STATE=y
+CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
+CONFIG_VECTORS_BASE=0xffff0000
+CONFIG_DEFCONFIG_LIST="/limodules/$UNAME_RELEASE/.config"
+CONFIG_CONSTRUCTORS=y
+CONFIG_HAVE_IRQ_WORK=y
+# General setup
+CONFIG_EXPERIMENTAL=y
+CONFIG_BROKEN_ON_SMP=y
+CONFIG_INIT_ENV_ARG_LIMIT=32
+CONFIG_CROSS_COMPILE=""
+CONFIG_LOCALVERSION=""
+# CONFIG_LOCALVERSION_AUTO is not set
+CONFIG_HAVE_KERNEL_GZIP=y
+CONFIG_HAVE_KERNEL_LZMA=y
+CONFIG_HAVE_KERNEL_LZO=y
+CONFIG_KERNEL_GZIP=y
+# CONFIG_KERNEL_LZMA is not set
+# CONFIG_KERNEL_LZO is not set
+CONFIG_SWAP=y
+CONFIG_SYSVIPC=y
+CONFIG_SYSVIPC_SYSCTL=y
+CONFIG_POSIX_MQUEUE=y
+CONFIG_POSIX_MQUEUE_SYSCTL=y
+# CONFIG_BSD_PROCESS_ACCT is not set
+# CONFIG_TASKSTATS is not set
+# CONFIG_AUDIT is not set
+# CONFIG_HAVE_GENERIC_HARDIRQS is not set
+# CONFIG_SPARSE_IRQ is not set
+# RCU Subsystem
+CONFIG_TINY_RCU=y
+# CONFIG_PREEMPT_RCU is not set
+# CONFIG_TREE_RCU_TRACE is not set
+# CONFIG_IKCONFIG is not set
+CONFIG_LOG_BUF_SHIFT=17
+# CONFIG_CGROUPS is not set
+CONFIG_NAMESPACES=y
+CONFIG_UTS_NS=y
+CONFIG_IPC_NS=y
+CONFIG_USER_NS=y
+CONFIG_PID_NS=y
+CONFIG_NET_NS=y
+# CONFIG_SYSFS_DEPRECATED is not set
+CONFIG_RELAY=y
+CONFIG_BLK_DEV_INITRD=y
+CONFIG_INITRAMFS_SOURCE=""
+CONFIG_RD_GZIP=y
+CONFIG_RD_BZIP2=y
+CONFIG_RD_LZMA=y
+CONFIG_RD_LZO=y
+CONFIG_CC_OPTIMIZE_FOR_SIZE=y
+CONFIG_SYSCTL=y
+CONFIG_ANON_INODES=y
+# CONFIG_EMBEDDED is not set
+CONFIG_UID16=y
+CONFIG_SYSCTL_SYSCALL=y
+CONFIG_KALLSYMS=y
+# CONFIG_KALLSYMS_ALL is not set
+# CONFIG_KALLSYMS_EXTRA_PASS is not set
+CONFIG_HOTPLUG=y
+CONFIG_PRINTK=y
+CONFIG_BUG=y
+CONFIG_ELF_CORE=y
+CONFIG_BASE_FULL=y
+CONFIG_FUTEX=y
+CONFIG_EPOLL=y
+CONFIG_SIGNALFD=y
+CONFIG_TIMERFD=y
+CONFIG_EVENTFD=y
+CONFIG_SHMEM=y
+CONFIG_AIO=y
+CONFIG_HAVE_PERF_EVENTS=y
+CONFIG_PERF_USE_VMALLOC=y
+# Kernel Performance Events And Counters
+# CONFIG_PERF_EVENTS is not set
+# CONFIG_PERF_COUNTERS is not set
+CONFIG_VM_EVENT_COUNTERS=y
+CONFIG_SLUB_DEBUG=y
+# CONFIG_COMPAT_BRK is not set
+# CONFIG_SLAB is not set
+CONFIG_SLUB=y
+# CONFIG_PROFILING is not set
+CONFIG_HAVE_OPROFILE=y
+# CONFIG_KPROBES is not set
+CONFIG_HAVE_KPROBES=y
+CONFIG_HAVE_KRETPROBES=y
+CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
+CONFIG_HAVE_CLK=y
+# GCOV-based kernel profiling
+# CONFIG_GCOV_KERNEL is not set
+CONFIG_HAVE_GENERIC_DMA_COHERENT=y
+CONFIG_SLABINFO=y
+CONFIG_RT_MUTEXES=y
+CONFIG_BASE_SMALL=0
+CONFIG_MODULES=y
+CONFIG_MODULE_FORCE_LOAD=y
+CONFIG_MODULE_UNLOAD=y
+CONFIG_MODULE_FORCE_UNLOAD=y
+# CONFIG_MODVERSIONS is not set
+# CONFIG_MODULE_SRCVERSION_ALL is not set
+CONFIG_BLOCK=y
+CONFIG_LBDAF=y
+# CONFIG_BLK_DEV_BSG is not set
+CONFIG_BLK_DEV_INTEGRITY=y
+# IO Schedulers
+CONFIG_IOSCHED_NOOP=y
+CONFIG_IOSCHED_DEADLINE=y
+CONFIG_IOSCHED_CFQ=y
+# CONFIG_DEFAULT_DEADLINE is not set
+CONFIG_DEFAULT_CFQ=y
+# CONFIG_DEFAULT_NOOP is not set
+CONFIG_DEFAULT_IOSCHED="cfq"
+# CONFIG_INLINE_SPIN_TRYLOCK is not set
+# CONFIG_INLINE_SPIN_TRYLOCK_BH is not set
+# CONFIG_INLINE_SPIN_LOCK is not set
+# CONFIG_INLINE_SPIN_LOCK_BH is not set
+# CONFIG_INLINE_SPIN_LOCK_IRQ is not set
+# CONFIG_INLINE_SPIN_LOCK_IRQSAVE is not set
+CONFIG_INLINE_SPIN_UNLOCK=y
+# CONFIG_INLINE_SPIN_UNLOCK_BH is not set
+CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
+# CONFIG_INLINE_SPIN_UNLOCK_IRQRESTORE is not set
+# CONFIG_INLINE_READ_TRYLOCK is not set
+# CONFIG_INLINE_READ_LOCK is not set
+# CONFIG_INLINE_READ_LOCK_BH is not set
+# CONFIG_INLINE_READ_LOCK_IRQ is not set
+# CONFIG_INLINE_READ_LOCK_IRQSAVE is not set
+CONFIG_INLINE_READ_UNLOCK=y
+# CONFIG_INLINE_READ_UNLOCK_BH is not set
+CONFIG_INLINE_READ_UNLOCK_IRQ=y
+# CONFIG_INLINE_READ_UNLOCK_IRQRESTORE is not set
+# CONFIG_INLINE_WRITE_TRYLOCK is not set
+# CONFIG_INLINE_WRITE_LOCK is not set
+# CONFIG_INLINE_WRITE_LOCK_BH is not set
+# CONFIG_INLINE_WRITE_LOCK_IRQ is not set
+# CONFIG_INLINE_WRITE_LOCK_IRQSAVE is not set
+CONFIG_INLINE_WRITE_UNLOCK=y
+# CONFIG_INLINE_WRITE_UNLOCK_BH is not set
+CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
+# CONFIG_INLINE_WRITE_UNLOCK_IRQRESTORE is not set
+# CONFIG_MUTEX_SPIN_ON_OWNER is not set
+CONFIG_FREEZER=y
+# System Type
+CONFIG_MMU=y
+# CONFIG_ARCH_AAEC2000 is not set
+# CONFIG_ARCH_INTEGRATOR is not set
+# CONFIG_ARCH_REALVIEW is not set
+# CONFIG_ARCH_VERSATILE is not set
+# CONFIG_ARCH_VEXPRESS is not set
+# CONFIG_ARCH_AT91 is not set
+# CONFIG_ARCH_BCMRING is not set
+# CONFIG_ARCH_CLPS711X is not set
+# CONFIG_ARCH_CNS3XXX is not set
+# CONFIG_ARCH_GEMINI is not set
+# CONFIG_ARCH_EBSA110 is not set
+# CONFIG_ARCH_EP93XX is not set
+# CONFIG_ARCH_FOOTBRIDGE is not set
+# CONFIG_ARCH_MXC is not set
+# CONFIG_ARCH_STMP3XXX is not set
+# CONFIG_ARCH_NETX is not set
+# CONFIG_ARCH_H720X is not set
+# CONFIG_ARCH_IOP13XX is not set
+# CONFIG_ARCH_IOP32X is not set
+# CONFIG_ARCH_IOP33X is not set
+# CONFIG_ARCH_IXP23XX is not set
+# CONFIG_ARCH_IXP2000 is not set
+# CONFIG_ARCH_IXP4XX is not set
+# CONFIG_ARCH_DOVE is not set
+# CONFIG_ARCH_KIRKWOOD is not set
+# CONFIG_ARCH_LOKI is not set
+# CONFIG_ARCH_LPC32XX is not set
+# CONFIG_ARCH_MV78XX0 is not set
+# CONFIG_ARCH_ORION5X is not set
+# CONFIG_ARCH_MMP is not set
+# CONFIG_ARCH_KS8695 is not set
+# CONFIG_ARCH_NS9XXX is not set
+# CONFIG_ARCH_W90X900 is not set
+# CONFIG_ARCH_NUC93X is not set
+# CONFIG_ARCH_TEGRA is not set
+# CONFIG_ARCH_PNX4008 is not set
+# CONFIG_ARCH_PXA is not set
+# CONFIG_ARCH_MSM is not set
+# CONFIG_ARCH_SHMOBILE is not set
+# CONFIG_ARCH_RPC is not set
+# CONFIG_ARCH_SA1100 is not set
+CONFIG_ARCH_S3C2410=y
+# CONFIG_ARCH_S3C64XX is not set
+# CONFIG_ARCH_S5P64X0 is not set
+# CONFIG_ARCH_S5P6442 is not set
+# CONFIG_ARCH_S5PC100 is not set
+# CONFIG_ARCH_S5PV210 is not set
+# CONFIG_ARCH_S5PV310 is not set
+# CONFIG_ARCH_SHARK is not set
+# CONFIG_ARCH_TCC_926 is not set
+# CONFIG_ARCH_LH7A40X is not set
+# CONFIG_ARCH_U300 is not set
+# CONFIG_ARCH_U8500 is not set
+# CONFIG_ARCH_NOMADIK is not set
+# CONFIG_ARCH_DAVINCI is not set
+# CONFIG_ARCH_OMAP is not set
+# CONFIG_PLAT_SPEAR is not set
+CONFIG_PLAT_SAMSUNG=y
+# Boot options
+# CONFIG_S3C_BOOT_WATCHDOG is not set
+# CONFIG_S3C_BOOT_ERROR_RESET is not set
+CONFIG_S3C_BOOT_UART_FORCE_FIFO=y
+CONFIG_S3C_LOWLEVEL_UART_PORT=0
+CONFIG_S3C_GPIO_CFG_S3C24XX=y
+CONFIG_S3C_GPIO_PULL_UP=y
+CONFIG_SAMSUNG_GPIO_EXTRA=0
+CONFIG_S3C_GPIO_SPACE=0
+CONFIG_S3C_ADC=y
+CONFIG_S3C_DEV_USB_HOST=y
+CONFIG_S3C_DEV_WDT=y
+CONFIG_S3C_DEV_NAND=y
+CONFIG_S3C_DMA=y
+# Power management
+# CONFIG_SAMSUNG_PM_DEBUG is not set
+# CONFIG_SAMSUNG_PM_CHECK is not set
+CONFIG_PLAT_S3C24XX=y
+CONFIG_CPU_LLSERIAL_S3C2440_ONLY=y
+CONFIG_CPU_LLSERIAL_S3C2440=y
+CONFIG_S3C2410_CLOCK=y
+CONFIG_S3C24XX_PWM=y
+CONFIG_S3C24XX_GPIO_EXTRA=0
+CONFIG_S3C2410_DMA=y
+# CONFIG_S3C2410_DMA_DEBUG is not set
+# S3C2400 Machines
+CONFIG_S3C2410_PM=y
+CONFIG_S3C2410_GPIO=y
+# S3C2410 Machines
+# CONFIG_ARCH_SMDK2410 is not set
+# CONFIG_ARCH_H1940 is not set
+# CONFIG_MACH_N30 is not set
+# CONFIG_ARCH_BAST is not set
+# CONFIG_MACH_OTOM is not set
+# CONFIG_MACH_AML_M5900 is not set
+# CONFIG_MACH_TCT_HAMMER is not set
+# CONFIG_MACH_VR1000 is not set
+# CONFIG_MACH_QT2410 is not set
+# S3C2412 Machines
+# CONFIG_MACH_JIVE is not set
+# CONFIG_MACH_SMDK2413 is not set
+# CONFIG_MACH_SMDK2412 is not set
+# CONFIG_MACH_VSTMS is not set
+# S3C2416 Machines
+# CONFIG_MACH_SMDK2416 is not set
+CONFIG_CPU_S3C2440=y
+CONFIG_CPU_S3C244X=y
+CONFIG_S3C2440_DMA=y
+# S3C2440 and S3C2442 Machines
+# CONFIG_MACH_ANUBIS is not set
+# CONFIG_MACH_NEO1973_GTA02 is not set
+# CONFIG_MACH_OSIRIS is not set
+# CONFIG_MACH_RX3715 is not set
+# CONFIG_ARCH_S3C2440 is not set
+# CONFIG_MACH_NEXCODER_2440 is not set
+# CONFIG_SMDK2440_CPU2440 is not set
+# CONFIG_SMDK2440_CPU2442 is not set
+# CONFIG_MACH_AT2440EVB is not set
+CONFIG_MACH_MINI2440=y
+# CONFIG_MACH_RX1950 is not set
+# S3C2443 Machines
+# CONFIG_MACH_SMDK2443 is not set
+# Processor Type
+CONFIG_CPU_ARM920T=y
+CONFIG_CPU_32v4T=y
+CONFIG_CPU_ABRT_EV4T=y
+CONFIG_CPU_PABRT_LEGACY=y
+CONFIG_CPU_CACHE_V4WT=y
+CONFIG_CPU_CACHE_VIVT=y
+CONFIG_CPU_COPY_V4WB=y
+CONFIG_CPU_TLB_V4WBI=y
+CONFIG_CPU_CP15=y
+CONFIG_CPU_CP15_MMU=y
+# Processor Features
+CONFIG_ARM_THUMB=y
+# CONFIG_CPU_ICACHE_DISABLE is not set
+# CONFIG_CPU_DCACHE_DISABLE is not set
+# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
+CONFIG_ARM_L1_CACHE_SHIFT=5
+# Bus support
+# CONFIG_PCI_SYSCALL is not set
+# CONFIG_ARCH_SUPPORTS_MSI is not set
+# CONFIG_PCCARD is not set
+# Kernel Features
+CONFIG_VMSPLIT_3G=y
+# CONFIG_VMSPLIT_2G is not set
+# CONFIG_VMSPLIT_1G is not set
+CONFIG_PAGE_OFFSET=0xC0000000
+CONFIG_PREEMPT_NONE=y
+# CONFIG_PREEMPT_VOLUNTARY is not set
+# CONFIG_PREEMPT is not set
+CONFIG_HZ=200
+CONFIG_AEABI=y
+# CONFIG_OABI_COMPAT is not set
+# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
+# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
+# CONFIG_HIGHMEM is not set
+CONFIG_SELECT_MEMORY_MODEL=y
+CONFIG_FLATMEM_MANUAL=y
+CONFIG_FLATMEM=y
+CONFIG_FLAT_NODE_MEM_MAP=y
+CONFIG_HAVE_MEMBLOCK=y
+CONFIG_PAGEFLAGS_EXTENDED=y
+CONFIG_SPLIT_PTLOCK_CPUS=999999
+# CONFIG_PHYS_ADDR_T_64BIT is not set
+CONFIG_ZONE_DMA_FLAG=0
+CONFIG_VIRT_TO_BUS=y
+# CONFIG_KSM is not set
+CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
+CONFIG_NEED_PER_CPU_KM=y
+CONFIG_FORCE_MAX_ZONEORDER=11
+CONFIG_ALIGNMENT_TRAP=y
+# CONFIG_UACCESS_WITH_MEMCPY is not set
+# CONFIG_SECCOMP is not set
+# CONFIG_CC_STACKPROTECTOR is not set
+# CONFIG_DEPRECATED_PARAM_STRUCT is not set
+# Boot options
+CONFIG_ZBOOT_ROM_TEXT=0
+CONFIG_ZBOOT_ROM_BSS=0
+CONFIG_CMDLINE=""
+# CONFIG_XIP_KERNEL is not set
+CONFIG_KEXEC=y
+CONFIG_ATAGS_PROC=y
+# CONFIG_AUTO_ZRELADDR is not set
+# CPU Power Management
+# CONFIG_CPU_FREQ is not set
+CONFIG_CPU_IDLE=y
+CONFIG_CPU_IDLE_GOV_LADDER=y
+# Floating point emulation
+# At least one emulation must be selected
+# Userspace binary formats
+CONFIG_BINFMT_ELF=y
+CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
+CONFIG_HAVE_AOUT=y
+CONFIG_BINFMT_AOUT=m
+CONFIG_BINFMT_MISC=m
+# Power management options
+CONFIG_PM=y
+# CONFIG_PM_DEBUG is not set
+CONFIG_PM_SLEEP=y
+CONFIG_SUSPEND_NVS=y
+CONFIG_SUSPEND=y
+CONFIG_SUSPEND_FREEZER=y
+CONFIG_APM_EMULATION=y
+# CONFIG_PM_RUNTIME is not set
+CONFIG_PM_OPS=y
+CONFIG_ARCH_SUSPEND_POSSIBLE=y
+CONFIG_NET=y
+# Networking options
+CONFIG_PACKET=y
+CONFIG_UNIX=y
+CONFIG_XFRM=y
+CONFIG_XFRM_USER=m
+# CONFIG_XFRM_SUB_POLICY is not set
+# CONFIG_XFRM_MIGRATE is not set
+# CONFIG_XFRM_STATISTICS is not set
+CONFIG_NET_KEY=m
+# CONFIG_NET_KEY_MIGRATE is not set
+CONFIG_INET=y
+CONFIG_IP_MULTICAST=y
+CONFIG_IP_ADVANCED_ROUTER=y
+CONFIG_ASK_IP_FIB_HASH=y
+# CONFIG_IP_FIB_TRIE is not set
+CONFIG_IP_FIB_HASH=y
+CONFIG_IP_MULTIPLE_TABLES=y
+CONFIG_IP_ROUTE_MULTIPATH=y
+CONFIG_IP_ROUTE_VERBOSE=y
+CONFIG_IP_PNP=y
+CONFIG_IP_PNP_DHCP=y
+CONFIG_IP_PNP_BOOTP=y
+CONFIG_IP_PNP_RARP=y
+# CONFIG_NET_IPIP is not set
+# CONFIG_NET_IPGRE_DEMUX is not set
+CONFIG_IP_MROUTE=y
+# CONFIG_IP_MROUTE_MULTIPLE_TABLES is not set
+CONFIG_IP_PIMSM_V1=y
+CONFIG_IP_PIMSM_V2=y
+# CONFIG_ARPD is not set
+CONFIG_SYN_COOKIES=y
+# CONFIG_INET_AH is not set
+# CONFIG_INET_ESP is not set
+# CONFIG_INET_IPCOMP is not set
+# CONFIG_INET_XFRM_TUNNEL is not set
+# CONFIG_INET_TUNNEL is not set
+# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
+# CONFIG_INET_XFRM_MODE_TUNNEL is not set
+# CONFIG_INET_XFRM_MODE_BEET is not set
+# CONFIG_INET_LRO is not set
+CONFIG_INET_DIAG=m
+CONFIG_INET_TCP_DIAG=m
+# CONFIG_TCP_CONG_ADVANCED is not set
+CONFIG_TCP_CONG_CUBIC=y
+CONFIG_DEFAULT_TCP_CONG="cubic"
+# CONFIG_TCP_MD5SIG is not set
+# CONFIG_IPV6 is not set
+# CONFIG_NETWORK_SECMARK is not set
+# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
+# CONFIG_NETFILTER is not set
+# CONFIG_IP_DCCP is not set
+# CONFIG_IP_SCTP is not set
+# CONFIG_RDS is not set
+# CONFIG_TIPC is not set
+# CONFIG_ATM is not set
+# CONFIG_L2TP is not set
+# CONFIG_BRIDGE is not set
+# CONFIG_NET_DSA is not set
+# CONFIG_VLAN_8021Q is not set
+# CONFIG_DECNET is not set
+# CONFIG_LLC2 is not set
+# CONFIG_IPX is not set
+# CONFIG_ATALK is not set
+# CONFIG_X25 is not set
+# CONFIG_LAPB is not set
+# CONFIG_ECONET is not set
+# CONFIG_WAN_ROUTER is not set
+# CONFIG_PHONET is not set
+# CONFIG_IEEE802154 is not set
+# CONFIG_NET_SCHED is not set
+# CONFIG_DCB is not set
+CONFIG_DNS_RESOLVER=y
+# Network testing
+CONFIG_NET_PKTGEN=m
+# CONFIG_HAMRADIO is not set
+# CONFIG_CAN is not set
+# CONFIG_IRDA is not set
+# CONFIG_BT is not set
+# CONFIG_AF_RXRPC is not set
+CONFIG_FIB_RULES=y
+CONFIG_WIRELESS=y
+CONFIG_WIRELESS_EXT=y
+CONFIG_WEXT_CORE=y
+CONFIG_WEXT_PROC=y
+CONFIG_WEXT_SPY=y
+CONFIG_WEXT_PRIV=y
+# CONFIG_CFG80211 is not set
+# CONFIG_WIRELESS_EXT_SYSFS is not set
+CONFIG_LIB80211=m
+CONFIG_LIB80211_CRYPT_WEP=m
+CONFIG_LIB80211_CRYPT_CCMP=m
+CONFIG_LIB80211_CRYPT_TKIP=m
+# CONFIG_LIB80211_DEBUG is not set
+# CFG80211 needs to be enabled for MAC80211
+# Some wireless drivers require a rate control algorithm
+# CONFIG_WIMAX is not set
+# CONFIG_RFKILL is not set
+# CONFIG_NET_9P is not set
+# CONFIG_CAIF is not set
+# CONFIG_CEPH_LIB is not set
+# Device Drivers
+# Generic Driver Options
+CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
+# CONFIG_DEVTMPFS is not set
+CONFIG_STANDALONE=y
+CONFIG_PREVENT_FIRMWARE_BUILD=y
+CONFIG_FW_LOADER=y
+# CONFIG_FIRMWARE_IN_KERNEL is not set
+CONFIG_EXTRA_FIRMWARE=""
+# CONFIG_DEBUG_DRIVER is not set
+# CONFIG_DEBUG_DEVRES is not set
+# CONFIG_SYS_HYPERVISOR is not set
+CONFIG_CONNECTOR=m
+CONFIG_MTD=y
+# CONFIG_MTD_DEBUG is not set
+# CONFIG_MTD_TESTS is not set
+CONFIG_MTD_CONCAT=y
+CONFIG_MTD_PARTITIONS=y
+# CONFIG_MTD_REDBOOT_PARTS is not set
+CONFIG_MTD_CMDLINE_PARTS=y
+# CONFIG_MTD_AFS_PARTS is not set
+# CONFIG_MTD_AR7_PARTS is not set
+# User Modules And Translation Layers
+CONFIG_MTD_CHAR=y
+CONFIG_MTD_BLKDEVS=y
+CONFIG_MTD_BLOCK=y
+CONFIG_FTL=y
+CONFIG_NFTL=y
+CONFIG_NFTL_RW=y
+CONFIG_INFTL=y
+CONFIG_RFD_FTL=y
+# CONFIG_SSFDC is not set
+# CONFIG_SM_FTL is not set
+# CONFIG_MTD_OOPS is not set
+# RAM/ROM/Flash chip drivers
+CONFIG_MTD_CFI=y
+CONFIG_MTD_JEDECPROBE=y
+CONFIG_MTD_GEN_PROBE=y
+# CONFIG_MTD_CFI_ADV_OPTIONS is not set
+CONFIG_MTD_MAP_BANK_WIDTH_1=y
+CONFIG_MTD_MAP_BANK_WIDTH_2=y
+CONFIG_MTD_MAP_BANK_WIDTH_4=y
+# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
+# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
+# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
+CONFIG_MTD_CFI_I1=y
+CONFIG_MTD_CFI_I2=y
+# CONFIG_MTD_CFI_I4 is not set
+# CONFIG_MTD_CFI_I8 is not set
+# CONFIG_MTD_CFI_INTELEXT is not set
+CONFIG_MTD_CFI_AMDSTD=y
+CONFIG_MTD_CFI_STAA=y
+CONFIG_MTD_CFI_UTIL=y
+CONFIG_MTD_RAM=y
+CONFIG_MTD_ROM=y
+# CONFIG_MTD_ABSENT is not set
+# Mapping drivers for chip access
+# CONFIG_MTD_COMPLEX_MAPPINGS is not set
+# CONFIG_MTD_PHYSMAP is not set
+# CONFIG_MTD_ARM_INTEGRATOR is not set
+# CONFIG_MTD_IMPA7 is not set
+# CONFIG_MTD_PLATRAM is not set
+# Self-contained MTD device drivers
+# CONFIG_MTD_DATAFLASH is not set
+# CONFIG_MTD_M25P80 is not set
+# CONFIG_MTD_SST25L is not set
+# CONFIG_MTD_SLRAM is not set
+# CONFIG_MTD_PHRAM is not set
+# CONFIG_MTD_MTDRAM is not set
+# CONFIG_MTD_BLOCK2MTD is not set
+# Disk-On-Chip Device Drivers
+# CONFIG_MTD_DOC2000 is not set
+# CONFIG_MTD_DOC2001 is not set
+# CONFIG_MTD_DOC2001PLUS is not set
+CONFIG_MTD_NAND_ECC=y
+# CONFIG_MTD_NAND_ECC_SMC is not set
+CONFIG_MTD_NAND=y
+CONFIG_MTD_NAND_VERIFY_WRITE=y
+# CONFIG_MTD_SM_COMMON is not set
+# CONFIG_MTD_NAND_MUSEUM_IDS is not set
+# CONFIG_MTD_NAND_GPIO is not set
+CONFIG_MTD_NAND_IDS=y
+CONFIG_MTD_NAND_S3C2410=y
+# CONFIG_MTD_NAND_S3C2410_DEBUG is not set
+# CONFIG_MTD_NAND_S3C2410_HWECC is not set
+# CONFIG_MTD_NAND_S3C2410_CLKSTOP is not set
+# CONFIG_MTD_NAND_DISKONCHIP is not set
+# CONFIG_MTD_NAND_NANDSIM is not set
+CONFIG_MTD_NAND_PLATFORM=y
+# CONFIG_MTD_ALAUDA is not set
+# CONFIG_MTD_ONENAND is not set
+# LPDDR flash memory drivers
+CONFIG_MTD_LPDDR=y
+CONFIG_MTD_QINFO_PROBE=y
+# CONFIG_MTD_UBI is not set
+# CONFIG_PARPORT is not set
+CONFIG_BLK_DEV=y
+# CONFIG_BLK_DEV_COW_COMMON is not set
+CONFIG_BLK_DEV_LOOP=m
+# CONFIG_BLK_DEV_CRYPTOLOOP is not set
+# CONFIG_BLK_DEV_DRBD is not set
+CONFIG_BLK_DEV_NBD=m
+# CONFIG_BLK_DEV_UB is not set
+CONFIG_BLK_DEV_RAM=y
+CONFIG_BLK_DEV_RAM_COUNT=16
+CONFIG_BLK_DEV_RAM_SIZE=65536
+# CONFIG_BLK_DEV_XIP is not set
+CONFIG_CDROM_PKTCDVD=m
+CONFIG_CDROM_PKTCDVD_BUFFERS=8
+# CONFIG_CDROM_PKTCDVD_WCACHE is not set
+# CONFIG_ATA_OVER_ETH is not set
+# CONFIG_MG_DISK is not set
+# CONFIG_BLK_DEV_RBD is not set
+CONFIG_MISC_DEVICES=y
+# CONFIG_AD525X_DPOT is not set
+# CONFIG_ICS932S401 is not set
+# CONFIG_ENCLOSURE_SERVICES is not set
+# CONFIG_APDS9802ALS is not set
+# CONFIG_ISL29003 is not set
+# CONFIG_ISL29020 is not set
+# CONFIG_SENSORS_TSL2550 is not set
+# CONFIG_SENSORS_BH1780 is not set
+# CONFIG_SENSORS_BH1770 is not set
+# CONFIG_SENSORS_APDS990X is not set
+# CONFIG_HMC6352 is not set
+# CONFIG_DS1682 is not set
+# CONFIG_TI_DAC7512 is not set
+# CONFIG_BMP085 is not set
+# CONFIG_C2PORT is not set
+# EEPROM support
+CONFIG_EEPROM_AT24=y
+# CONFIG_EEPROM_AT25 is not set
+# CONFIG_EEPROM_LEGACY is not set
+# CONFIG_EEPROM_MAX6875 is not set
+# CONFIG_EEPROM_93CX6 is not set
+# CONFIG_IWMC3200TOP is not set
+# Texas Instruments shared transport line discipline
+CONFIG_HAVE_IDE=y
+# CONFIG_IDE is not set
+# SCSI device support
+CONFIG_SCSI_MOD=m
+# CONFIG_RAID_ATTRS is not set
+CONFIG_SCSI=m
+CONFIG_SCSI_DMA=y
+# CONFIG_SCSI_TGT is not set
+# CONFIG_SCSI_NETLINK is not set
+# CONFIG_SCSI_PROC_FS is not set
+# SCSI support type (disk, tape, CD-ROM)
+CONFIG_BLK_DEV_SD=m
+# CONFIG_CHR_DEV_ST is not set
+# CONFIG_CHR_DEV_OSST is not set
+# CONFIG_BLK_DEV_SR is not set
+CONFIG_CHR_DEV_SG=m
+# CONFIG_CHR_DEV_SCH is not set
+# CONFIG_SCSI_MULTI_LUN is not set
+# CONFIG_SCSI_CONSTANTS is not set
+# CONFIG_SCSI_LOGGING is not set
+# CONFIG_SCSI_SCAN_ASYNC is not set
+CONFIG_SCSI_WAIT_SCAN=m
+# SCSI Transports
+# CONFIG_SCSI_SPI_ATTRS is not set
+# CONFIG_SCSI_FC_ATTRS is not set
+# CONFIG_SCSI_ISCSI_ATTRS is not set
+# CONFIG_SCSI_SAS_ATTRS is not set
+# CONFIG_SCSI_SAS_LIBSAS is not set
+# CONFIG_SCSI_SRP_ATTRS is not set
+# CONFIG_SCSI_LOWLEVEL is not set
+# CONFIG_SCSI_DH is not set
+# CONFIG_SCSI_OSD_INITIATOR is not set
+# CONFIG_ATA is not set
+# CONFIG_MD is not set
+CONFIG_NETDEVICES=y
+# CONFIG_DUMMY is not set
+# CONFIG_BONDING is not set
+# CONFIG_MACVLAN is not set
+# CONFIG_EQUALIZER is not set
+CONFIG_TUN=m
+# CONFIG_VETH is not set
+CONFIG_MII=y
+# CONFIG_PHYLIB is not set
+CONFIG_NET_ETHERNET=y
+# CONFIG_AX88796 is not set
+# CONFIG_SMC91X is not set
+CONFIG_DM9000=y
+CONFIG_DM9000_DEBUGLEVEL=4
+# CONFIG_DM9000_FORCE_SIMPLE_PHY_POLL is not set
+# CONFIG_ENC28J60 is not set
+# CONFIG_ETHOC is not set
+# CONFIG_SMC911X is not set
+# CONFIG_SMSC911X is not set
+# CONFIG_DNET is not set
+# CONFIG_IBM_NEW_EMAC_ZMII is not set
+# CONFIG_IBM_NEW_EMAC_RGMII is not set
+# CONFIG_IBM_NEW_EMAC_TAH is not set
+# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
+# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
+# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
+# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
+# CONFIG_B44 is not set
+# CONFIG_KS8851 is not set
+# CONFIG_KS8851_MLL is not set
+# CONFIG_NETDEV_1000 is not set
+# CONFIG_NETDEV_10000 is not set
+CONFIG_WLAN=y
+# CONFIG_USB_ZD1201 is not set
+CONFIG_HOSTAP=m
+CONFIG_HOSTAP_FIRMWARE=y
+CONFIG_HOSTAP_FIRMWARE_NVRAM=y
+# Enable WiMAX (Networking options) to see the WiMAX drivers
+# USB Network Adapters
+# CONFIG_USB_CATC is not set
+# CONFIG_USB_KAWETH is not set
+# CONFIG_USB_PEGASUS is not set
+# CONFIG_USB_RTL8150 is not set
+# CONFIG_USB_USBNET is not set
+# CONFIG_USB_IPHETH is not set
+# CONFIG_WAN is not set
+# CAIF transport drivers
+CONFIG_PPP=m
+CONFIG_PPP_MULTILINK=y
+CONFIG_PPP_FILTER=y
+CONFIG_PPP_ASYNC=m
+CONFIG_PPP_SYNC_TTY=m
+CONFIG_PPP_DEFLATE=m
+CONFIG_PPP_BSDCOMP=m
+CONFIG_PPP_MPPE=m
+# CONFIG_PPPOE is not set
+# CONFIG_SLIP is not set
+CONFIG_SLHC=m
+# CONFIG_NETCONSOLE is not set
+# CONFIG_NETPOLL is not set
+# CONFIG_NET_POLL_CONTROLLER is not set
+# CONFIG_ISDN is not set
+# CONFIG_PHONE is not set
+# Input device support
+CONFIG_INPUT=y
+CONFIG_INPUT_FF_MEMLESS=y
+# CONFIG_INPUT_POLLDEV is not set
+# CONFIG_INPUT_SPARSEKMAP is not set
+# Userland interfaces
+CONFIG_INPUT_MOUSEDEV=y
+CONFIG_INPUT_MOUSEDEV_PSAUX=y
+CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
+CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
+# CONFIG_INPUT_JOYDEV is not set
+CONFIG_INPUT_EVDEV=y
+CONFIG_INPUT_EVBUG=m
+# Input Device Drivers
+CONFIG_INPUT_KEYBOARD=y
+# CONFIG_KEYBOARD_ADP5588 is not set
+# CONFIG_KEYBOARD_ATKBD is not set
+# CONFIG_KEYBOARD_QT2160 is not set
+# CONFIG_KEYBOARD_LKKBD is not set
+CONFIG_KEYBOARD_GPIO=y
+# CONFIG_KEYBOARD_GPIO_POLLED is not set
+# CONFIG_KEYBOARD_TCA6416 is not set
+# CONFIG_KEYBOARD_MATRIX is not set
+# CONFIG_KEYBOARD_LM8323 is not set
+# CONFIG_KEYBOARD_MAX7359 is not set
+# CONFIG_KEYBOARD_MCS is not set
+# CONFIG_KEYBOARD_NEWTON is not set
+# CONFIG_KEYBOARD_OPENCORES is not set
+# CONFIG_KEYBOARD_STOWAWAY is not set
+# CONFIG_KEYBOARD_SUNKBD is not set
+# CONFIG_KEYBOARD_XTKBD is not set
+CONFIG_INPUT_MOUSE=y
+CONFIG_MOUSE_PS2=y
+CONFIG_MOUSE_PS2_ALPS=y
+CONFIG_MOUSE_PS2_LOGIPS2PP=y
+CONFIG_MOUSE_PS2_SYNAPTICS=y
+CONFIG_MOUSE_PS2_TRACKPOINT=y
+# CONFIG_MOUSE_PS2_ELANTECH is not set
+# CONFIG_MOUSE_PS2_SENTELIC is not set
+# CONFIG_MOUSE_PS2_TOUCHKIT is not set
+# CONFIG_MOUSE_SERIAL is not set
+# CONFIG_MOUSE_APPLETOUCH is not set
+# CONFIG_MOUSE_BCM5974 is not set
+# CONFIG_MOUSE_VSXXXAA is not set
+# CONFIG_MOUSE_GPIO is not set
+# CONFIG_MOUSE_SYNAPTICS_I2C is not set
+# CONFIG_INPUT_JOYSTICK is not set
+# CONFIG_INPUT_TABLET is not set
+CONFIG_INPUT_TOUCHSCREEN=y
+# CONFIG_TOUCHSCREEN_ADS7846 is not set
+# CONFIG_TOUCHSCREEN_AD7877 is not set
+# CONFIG_TOUCHSCREEN_AD7879 is not set
+# CONFIG_TOUCHSCREEN_BU21013 is not set
+# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
+# CONFIG_TOUCHSCREEN_DYNAPRO is not set
+# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
+# CONFIG_TOUCHSCREEN_EETI is not set
+# CONFIG_TOUCHSCREEN_FUJITSU is not set
+CONFIG_TOUCHSCREEN_S3C2410=y
+# CONFIG_TOUCHSCREEN_GUNZE is not set
+# CONFIG_TOUCHSCREEN_ELO is not set
+# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
+# CONFIG_TOUCHSCREEN_MCS5000 is not set
+# CONFIG_TOUCHSCREEN_MTOUCH is not set
+# CONFIG_TOUCHSCREEN_INEXIO is not set
+# CONFIG_TOUCHSCREEN_MK712 is not set
+# CONFIG_TOUCHSCREEN_PENMOUNT is not set
+# CONFIG_TOUCHSCREEN_QT602240 is not set
+# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
+# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
+# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
+# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
+# CONFIG_TOUCHSCREEN_TSC2007 is not set
+# CONFIG_TOUCHSCREEN_W90X900 is not set
+# CONFIG_TOUCHSCREEN_TPS6507X is not set
+# CONFIG_INPUT_MISC is not set
+# Hardware I/O ports
+CONFIG_SERIO=y
+CONFIG_SERIO_SERPORT=y
+CONFIG_SERIO_LIBPS2=y
+CONFIG_SERIO_RAW=y
+# CONFIG_SERIO_ALTERA_PS2 is not set
+# CONFIG_SERIO_PS2MULT is not set
+# CONFIG_GAMEPORT is not set
+# Character devices
+CONFIG_VT=y
+CONFIG_CONSOLE_TRANSLATIONS=y
+CONFIG_VT_CONSOLE=y
+CONFIG_HW_CONSOLE=y
+CONFIG_VT_HW_CONSOLE_BINDING=y
+CONFIG_DEVKMEM=y
+# CONFIG_SERIAL_NONSTANDARD is not set
+# CONFIG_N_GSM is not set
+# Serial drivers
+# CONFIG_SERIAL_8250 is not set
+# Non-8250 serial port support
+CONFIG_SERIAL_SAMSUNG=y
+CONFIG_SERIAL_SAMSUNG_UARTS=3
+CONFIG_SERIAL_SAMSUNG_CONSOLE=y
+CONFIG_SERIAL_S3C2440=y
+# CONFIG_SERIAL_MAX3100 is not set
+# CONFIG_SERIAL_MAX3107 is not set
+CONFIG_SERIAL_CORE=y
+CONFIG_SERIAL_CORE_CONSOLE=y
+# CONFIG_SERIAL_TIMBERDALE is not set
+# CONFIG_SERIAL_ALTERA_JTAGUART is not set
+# CONFIG_SERIAL_ALTERA_UART is not set
+CONFIG_UNIX98_PTYS=y
+# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
+CONFIG_LEGACY_PTYS=y
+CONFIG_LEGACY_PTY_COUNT=128
+CONFIG_IPMI_HANDLER=m
+# CONFIG_IPMI_PANIC_EVENT is not set
+CONFIG_IPMI_DEVICE_INTERFACE=m
+CONFIG_IPMI_SI=m
+CONFIG_IPMI_WATCHDOG=m
+CONFIG_IPMI_POWEROFF=m
+CONFIG_HW_RANDOM=y
+# CONFIG_HW_RANDOM_TIMERIOMEM is not set
+# CONFIG_R3964 is not set
+# CONFIG_RAW_DRIVER is not set
+# CONFIG_TCG_TPM is not set
+# CONFIG_RAMOOPS is not set
+CONFIG_I2C=y
+CONFIG_I2C_BOARDINFO=y
+CONFIG_I2C_COMPAT=y
+CONFIG_I2C_CHARDEV=y
+# CONFIG_I2C_MUX is not set
+CONFIG_I2C_HELPER_AUTO=y
+CONFIG_I2C_ALGOBIT=y
+# I2C Hardware Bus support
+# I2C system bus drivers (mostly embedded / system-on-chip)
+# CONFIG_I2C_DESIGNWARE is not set
+# CONFIG_I2C_GPIO is not set
+# CONFIG_I2C_OCORES is not set
+# CONFIG_I2C_PCA_PLATFORM is not set
+CONFIG_HAVE_S3C2410_I2C=y
+CONFIG_I2C_S3C2410=y
+CONFIG_I2C_SIMTEC=y
+# CONFIG_I2C_XILINX is not set
+# External I2C/SMBus adapter drivers
+# CONFIG_I2C_PARPORT_LIGHT is not set
+# CONFIG_I2C_TAOS_EVM is not set
+# CONFIG_I2C_TINY_USB is not set
+# Other I2C/SMBus bus drivers
+# CONFIG_I2C_STUB is not set
+# CONFIG_I2C_DEBUG_CORE is not set
+# CONFIG_I2C_DEBUG_ALGO is not set
+# CONFIG_I2C_DEBUG_BUS is not set
+CONFIG_SPI=y
+# CONFIG_SPI_DEBUG is not set
+CONFIG_SPI_MASTER=y
+# SPI Master Controller Drivers
+CONFIG_SPI_BITBANG=y
+# CONFIG_SPI_GPIO is not set
+CONFIG_SPI_S3C24XX=y
+# CONFIG_SPI_S3C24XX_FIQ is not set
+# CONFIG_SPI_S3C24XX_GPIO is not set
+# CONFIG_SPI_XILINX is not set
+# CONFIG_SPI_DESIGNWARE is not set
+# SPI Protocol Masters
+CONFIG_SPI_SPIDEV=y
+# CONFIG_SPI_TLE62X0 is not set
+# PPS support
+# CONFIG_PPS is not set
+CONFIG_ARCH_REQUIRE_GPIOLIB=y
+CONFIG_GPIOLIB=y
+# CONFIG_DEBUG_GPIO is not set
+CONFIG_GPIO_SYSFS=y
+# Memory mapped GPIO expanders:
+# CONFIG_GPIO_BASIC_MMIO is not set
+# CONFIG_GPIO_IT8761E is not set
+# CONFIG_GPIO_VX855 is not set
+# I2C GPIO expanders:
+# CONFIG_GPIO_MAX7300 is not set
+# CONFIG_GPIO_MAX732X is not set
+# CONFIG_GPIO_PCA953X is not set
+# CONFIG_GPIO_PCF857X is not set
+# CONFIG_GPIO_SX150X is not set
+# CONFIG_GPIO_ADP5588 is not set
+# PCI GPIO expanders:
+# SPI GPIO expanders:
+# CONFIG_GPIO_MAX7301 is not set
+# CONFIG_GPIO_MCP23S08 is not set
+# CONFIG_GPIO_MC33880 is not set
+# CONFIG_GPIO_74X164 is not set
+# AC97 GPIO expanders:
+# MODULbus GPIO expanders:
+# CONFIG_W1 is not set
+# CONFIG_POWER_SUPPLY is not set
+CONFIG_HWMON=y
+# CONFIG_HWMON_VID is not set
+# CONFIG_HWMON_DEBUG_CHIP is not set
+# Native drivers
+# CONFIG_SENSORS_AD7414 is not set
+# CONFIG_SENSORS_AD7418 is not set
+# CONFIG_SENSORS_ADCXX is not set
+# CONFIG_SENSORS_ADM1021 is not set
+# CONFIG_SENSORS_ADM1025 is not set
+# CONFIG_SENSORS_ADM1026 is not set
+# CONFIG_SENSORS_ADM1029 is not set
+# CONFIG_SENSORS_ADM1031 is not set
+# CONFIG_SENSORS_ADM9240 is not set
+# CONFIG_SENSORS_ADT7411 is not set
+# CONFIG_SENSORS_ADT7462 is not set
+# CONFIG_SENSORS_ADT7470 is not set
+# CONFIG_SENSORS_ADT7475 is not set
+# CONFIG_SENSORS_ASC7621 is not set
+# CONFIG_SENSORS_ATXP1 is not set
+# CONFIG_SENSORS_DS1621 is not set
+# CONFIG_SENSORS_F71805F is not set
+# CONFIG_SENSORS_F71882FG is not set
+# CONFIG_SENSORS_F75375S is not set
+# CONFIG_SENSORS_G760A is not set
+# CONFIG_SENSORS_GL518SM is not set
+# CONFIG_SENSORS_GL520SM is not set
+# CONFIG_SENSORS_GPIO_FAN is not set
+# CONFIG_SENSORS_IBMAEM is not set
+# CONFIG_SENSORS_IBMPEX is not set
+# CONFIG_SENSORS_IT87 is not set
+# CONFIG_SENSORS_JC42 is not set
+# CONFIG_SENSORS_LM63 is not set
+# CONFIG_SENSORS_LM70 is not set
+# CONFIG_SENSORS_LM73 is not set
+CONFIG_SENSORS_LM75=y
+# CONFIG_SENSORS_LM77 is not set
+# CONFIG_SENSORS_LM78 is not set
+# CONFIG_SENSORS_LM80 is not set
+# CONFIG_SENSORS_LM83 is not set
+# CONFIG_SENSORS_LM85 is not set
+# CONFIG_SENSORS_LM87 is not set
+# CONFIG_SENSORS_LM90 is not set
+# CONFIG_SENSORS_LM92 is not set
+# CONFIG_SENSORS_LM93 is not set
+# CONFIG_SENSORS_LTC4215 is not set
+# CONFIG_SENSORS_LTC4245 is not set
+# CONFIG_SENSORS_LTC4261 is not set
+# CONFIG_SENSORS_LM95241 is not set
+# CONFIG_SENSORS_MAX1111 is not set
+# CONFIG_SENSORS_MAX1619 is not set
+# CONFIG_SENSORS_MAX6650 is not set
+# CONFIG_SENSORS_PC87360 is not set
+# CONFIG_SENSORS_PC87427 is not set
+# CONFIG_SENSORS_PCF8591 is not set
+# CONFIG_SENSORS_SHT15 is not set
+# CONFIG_SENSORS_S3C is not set
+# CONFIG_SENSORS_SMM665 is not set
+# CONFIG_SENSORS_DME1737 is not set
+# CONFIG_SENSORS_EMC1403 is not set
+# CONFIG_SENSORS_EMC2103 is not set
+# CONFIG_SENSORS_SMSC47M1 is not set
+# CONFIG_SENSORS_SMSC47M192 is not set
+# CONFIG_SENSORS_SMSC47B397 is not set
+# CONFIG_SENSORS_ADS7828 is not set
+# CONFIG_SENSORS_ADS7871 is not set
+# CONFIG_SENSORS_AMC6821 is not set
+# CONFIG_SENSORS_THMC50 is not set
+# CONFIG_SENSORS_TMP102 is not set
+# CONFIG_SENSORS_TMP401 is not set
+# CONFIG_SENSORS_TMP421 is not set
+# CONFIG_SENSORS_VT1211 is not set
+# CONFIG_SENSORS_W83781D is not set
+# CONFIG_SENSORS_W83791D is not set
+# CONFIG_SENSORS_W83792D is not set
+# CONFIG_SENSORS_W83793 is not set
+# CONFIG_SENSORS_W83795 is not set
+# CONFIG_SENSORS_W83L785TS is not set
+# CONFIG_SENSORS_W83L786NG is not set
+# CONFIG_SENSORS_W83627HF is not set
+# CONFIG_SENSORS_W83627EHF is not set
+# CONFIG_SENSORS_LIS3_SPI is not set
+# CONFIG_SENSORS_LIS3_I2C is not set
+CONFIG_THERMAL=m
+# CONFIG_THERMAL_HWMON is not set
+CONFIG_WATCHDOG=y
+# CONFIG_WATCHDOG_NOWAYOUT is not set
+# Watchdog Device Drivers
+# CONFIG_SOFT_WATCHDOG is not set
+CONFIG_S3C2410_WATCHDOG=y
+# CONFIG_MAX63XX_WATCHDOG is not set
+# USB-based Watchdog Cards
+# CONFIG_USBPCWATCHDOG is not set
+CONFIG_SSB_POSSIBLE=y
+# Sonics Silicon Backplane
+# CONFIG_SSB is not set
+CONFIG_MFD_SUPPORT=y
+# CONFIG_MFD_CORE is not set
+# CONFIG_MFD_88PM860X is not set
+# CONFIG_MFD_SM501 is not set
+# CONFIG_MFD_ASIC3 is not set
+# CONFIG_HTC_EGPIO is not set
+# CONFIG_HTC_PASIC3 is not set
+# CONFIG_HTC_I2CPLD is not set
+# CONFIG_TPS65010 is not set
+# CONFIG_TPS6507X is not set
+# CONFIG_TWL4030_CORE is not set
+# CONFIG_MFD_STMPE is not set
+# CONFIG_MFD_TC35892 is not set
+# CONFIG_MFD_TMIO is not set
+# CONFIG_MFD_T7L66XB is not set
+# CONFIG_MFD_TC6387XB is not set
+# CONFIG_MFD_TC6393XB is not set
+# CONFIG_PMIC_DA903X is not set
+# CONFIG_PMIC_ADP5520 is not set
+# CONFIG_MFD_MAX8925 is not set
+# CONFIG_MFD_MAX8998 is not set
+# CONFIG_MFD_WM8400 is not set
+# CONFIG_MFD_WM831X_I2C is not set
+# CONFIG_MFD_WM831X_SPI is not set
+# CONFIG_MFD_WM8350_I2C is not set
+# CONFIG_MFD_WM8994 is not set
+# CONFIG_MFD_PCF50633 is not set
+# CONFIG_MFD_MC13XXX is not set
+# CONFIG_ABX500_CORE is not set
+# CONFIG_EZX_PCAP is not set
+# CONFIG_MFD_TPS6586X is not set
+# CONFIG_REGULATOR is not set
+# CONFIG_MEDIA_SUPPORT is not set
+# Graphics support
+# CONFIG_DRM is not set
+# CONFIG_VGASTATE is not set
+CONFIG_VIDEO_OUTPUT_CONTROL=y
+CONFIG_FB=y
+CONFIG_FIRMWARE_EDID=y
+# CONFIG_FB_DDC is not set
+# CONFIG_FB_BOOT_VESA_SUPPORT is not set
+CONFIG_FB_CFB_FILLRECT=y
+CONFIG_FB_CFB_COPYAREA=y
+CONFIG_FB_CFB_IMAGEBLIT=y
+# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
+# CONFIG_FB_SYS_FILLRECT is not set
+# CONFIG_FB_SYS_COPYAREA is not set
+# CONFIG_FB_SYS_IMAGEBLIT is not set
+# CONFIG_FB_FOREIGN_ENDIAN is not set
+# CONFIG_FB_SYS_FOPS is not set
+# CONFIG_FB_SVGALIB is not set
+# CONFIG_FB_MACMODES is not set
+# CONFIG_FB_BACKLIGHT is not set
+CONFIG_FB_MODE_HELPERS=y
+CONFIG_FB_TILEBLITTING=y
+# Frame buffer hardware drivers
+# CONFIG_FB_UVESA is not set
+# CONFIG_FB_S1D13XXX is not set
+CONFIG_FB_S3C2410=y
+# CONFIG_FB_S3C2410_DEBUG is not set
+# CONFIG_FB_VIRTUAL is not set
+# CONFIG_FB_METRONOME is not set
+# CONFIG_FB_MB862XX is not set
+# CONFIG_FB_BROADSHEET is not set
+CONFIG_BACKLIGHT_LCD_SUPPORT=y
+CONFIG_LCD_CLASS_DEVICE=y
+# CONFIG_LCD_L4F00242T03 is not set
+# CONFIG_LCD_LMS283GF05 is not set
+# CONFIG_LCD_LTV350QV is not set
+# CONFIG_LCD_TDO24M is not set
+# CONFIG_LCD_VGG2432A4 is not set
+CONFIG_LCD_PLATFORM=y
+# CONFIG_LCD_S6E63M0 is not set
+CONFIG_BACKLIGHT_CLASS_DEVICE=y
+# CONFIG_BACKLIGHT_GENERIC is not set
+CONFIG_BACKLIGHT_PWM=y
+# CONFIG_BACKLIGHT_ADP8860 is not set
+# Display device support
+CONFIG_DISPLAY_SUPPORT=y
+# Display hardware drivers
+# Console display driver support
+CONFIG_DUMMY_CONSOLE=y
+CONFIG_FRAMEBUFFER_CONSOLE=y
+CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
+CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
+CONFIG_FONTS=y
+CONFIG_FONT_8x8=y
+CONFIG_FONT_8x16=y
+CONFIG_FONT_6x11=y
+CONFIG_FONT_7x14=y
+CONFIG_FONT_PEARL_8x8=y
+CONFIG_FONT_ACORN_8x8=y
+CONFIG_FONT_MINI_4x6=y
+CONFIG_FONT_SUN8x16=y
+CONFIG_FONT_SUN12x22=y
+CONFIG_FONT_10x18=y
+CONFIG_LOGO=y
+# CONFIG_LOGO_LINUX_MONO is not set
+# CONFIG_LOGO_LINUX_VGA16 is not set
+CONFIG_LOGO_LINUX_CLUT224=y
+# CONFIG_SOUND is not set
+CONFIG_HID_SUPPORT=y
+CONFIG_HID=y
+CONFIG_HIDRAW=y
+# USB Input Devices
+CONFIG_USB_HID=y
+CONFIG_HID_PID=y
+CONFIG_USB_HIDDEV=y
+# Special HID drivers
+# CONFIG_HID_3M_PCT is not set
+CONFIG_HID_A4TECH=y
+# CONFIG_HID_ACRUX_FF is not set
+CONFIG_HID_APPLE=y
+CONFIG_HID_BELKIN=y
+# CONFIG_HID_CANDO is not set
+CONFIG_HID_CHERRY=y
+CONFIG_HID_CHICONY=y
+CONFIG_HID_CYPRESS=y
+# CONFIG_HID_DRAGONRISE is not set
+# CONFIG_HID_EGALAX is not set
+CONFIG_HID_EZKEY=y
+CONFIG_HID_KYE=y
+# CONFIG_HID_UCLOGIC is not set
+# CONFIG_HID_WALTOP is not set
+CONFIG_HID_GYRATION=y
+# CONFIG_HID_TWINHAN is not set
+CONFIG_HID_KENSINGTON=y
+CONFIG_HID_LOGITECH=y
+# CONFIG_LOGITECH_FF is not set
+# CONFIG_LOGIRUMBLEPAD2_FF is not set
+# CONFIG_LOGIG940_FF is not set
+# CONFIG_LOGIWII_FF is not set
+CONFIG_HID_MICROSOFT=y
+# CONFIG_HID_MOSART is not set
+CONFIG_HID_MONTEREY=y
+CONFIG_HID_NTRIG=y
+# CONFIG_HID_ORTEK is not set
+CONFIG_HID_PANTHERLORD=y
+# CONFIG_PANTHERLORD_FF is not set
+CONFIG_HID_PETALYNX=y
+# CONFIG_HID_PICOLCD is not set
+# CONFIG_HID_QUANTA is not set
+# CONFIG_HID_ROCCAT is not set
+# CONFIG_HID_ROCCAT_KONE is not set
+# CONFIG_HID_ROCCAT_PYRA is not set
+CONFIG_HID_SAMSUNG=y
+CONFIG_HID_SONY=y
+# CONFIG_HID_STANTUM is not set
+CONFIG_HID_SUNPLUS=y
+# CONFIG_HID_GREENASIA is not set
+# CONFIG_HID_SMARTJOYPLUS is not set
+CONFIG_HID_TOPSEED=y
+# CONFIG_HID_THRUSTMASTER is not set
+# CONFIG_HID_ZEROPLUS is not set
+# CONFIG_HID_ZYDACRON is not set
+CONFIG_USB_SUPPORT=y
+CONFIG_USB_ARCH_HAS_HCD=y
+CONFIG_USB_ARCH_HAS_OHCI=y
+# CONFIG_USB_ARCH_HAS_EHCI is not set
+CONFIG_USB=y
+# CONFIG_USB_DEBUG is not set
+# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
+# Miscellaneous USB options
+CONFIG_USB_DEVICEFS=y
+# CONFIG_USB_DEVICE_CLASS is not set
+# CONFIG_USB_DYNAMIC_MINORS is not set
+# CONFIG_USB_MON is not set
+# CONFIG_USB_WUSB is not set
+# CONFIG_USB_WUSB_CBAF is not set
+# USB Host Controller Drivers
+# CONFIG_USB_C67X00_HCD is not set
+# CONFIG_USB_OXU210HP_HCD is not set
+# CONFIG_USB_ISP116X_HCD is not set
+# CONFIG_USB_ISP1760_HCD is not set
+# CONFIG_USB_ISP1362_HCD is not set
+CONFIG_USB_OHCI_HCD=y
+# CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
+# CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
+CONFIG_USB_OHCI_LITTLE_ENDIAN=y
+# CONFIG_USB_SL811_HCD is not set
+# CONFIG_USB_R8A66597_HCD is not set
+# CONFIG_USB_HWA_HCD is not set
+# CONFIG_USB_MUSB_HDRC is not set
+# USB Device Class drivers
+CONFIG_USB_ACM=m
+# CONFIG_USB_PRINTER is not set
+CONFIG_USB_WDM=m
+# CONFIG_USB_TMC is not set
+# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
+# also be needed; see USB_STORAGE Help for more info
+CONFIG_USB_STORAGE=m
+# CONFIG_USB_STORAGE_DEBUG is not set
+CONFIG_USB_STORAGE_DATAFAB=m
+# CONFIG_USB_STORAGE_FREECOM is not set
+CONFIG_USB_STORAGE_ISD200=m
+CONFIG_USB_STORAGE_USBAT=m
+CONFIG_USB_STORAGE_SDDR09=m
+CONFIG_USB_STORAGE_SDDR55=m
+CONFIG_USB_STORAGE_JUMPSHOT=m
+CONFIG_USB_STORAGE_ALAUDA=m
+# CONFIG_USB_STORAGE_ONETOUCH is not set
+# CONFIG_USB_STORAGE_KARMA is not set
+# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
+# CONFIG_USB_UAS is not set
+CONFIG_USB_LIBUSUAL=y
+# USB Imaging devices
+# CONFIG_USB_MDC800 is not set
+# CONFIG_USB_MICROTEK is not set
+# USB port drivers
+CONFIG_USB_SERIAL=m
+# CONFIG_USB_EZUSB is not set
+# CONFIG_USB_SERIAL_GENERIC is not set
+# CONFIG_USB_SERIAL_AIRCABLE is not set
+# CONFIG_USB_SERIAL_ARK3116 is not set
+# CONFIG_USB_SERIAL_BELKIN is not set
+# CONFIG_USB_SERIAL_CH341 is not set
+# CONFIG_USB_SERIAL_WHITEHEAT is not set
+# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
+CONFIG_USB_SERIAL_CP210X=m
+# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
+# CONFIG_USB_SERIAL_EMPEG is not set
+CONFIG_USB_SERIAL_FTDI_SIO=m
+# CONFIG_USB_SERIAL_FUNSOFT is not set
+# CONFIG_USB_SERIAL_VISOR is not set
+# CONFIG_USB_SERIAL_IPAQ is not set
+# CONFIG_USB_SERIAL_IR is not set
+# CONFIG_USB_SERIAL_EDGEPORT is not set
+# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
+# CONFIG_USB_SERIAL_GARMIN is not set
+# CONFIG_USB_SERIAL_IPW is not set
+# CONFIG_USB_SERIAL_IUU is not set
+# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
+# CONFIG_USB_SERIAL_KEYSPAN is not set
+# CONFIG_USB_SERIAL_KLSI is not set
+# CONFIG_USB_SERIAL_KOBIL_SCT is not set
+# CONFIG_USB_SERIAL_MCT_U232 is not set
+# CONFIG_USB_SERIAL_MOS7720 is not set
+# CONFIG_USB_SERIAL_MOS7840 is not set
+# CONFIG_USB_SERIAL_MOTOROLA is not set
+# CONFIG_USB_SERIAL_NAVMAN is not set
+# CONFIG_USB_SERIAL_PL2303 is not set
+# CONFIG_USB_SERIAL_OTI6858 is not set
+# CONFIG_USB_SERIAL_QCAUX is not set
+# CONFIG_USB_SERIAL_QUALCOMM is not set
+CONFIG_USB_SERIAL_SPCP8X5=m
+# CONFIG_USB_SERIAL_HP4X is not set
+# CONFIG_USB_SERIAL_SAFE is not set
+# CONFIG_USB_SERIAL_SAMBA is not set
+# CONFIG_USB_SERIAL_SIEMENS_MPI is not set
+# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
+# CONFIG_USB_SERIAL_SYMBOL is not set
+# CONFIG_USB_SERIAL_TI is not set
+# CONFIG_USB_SERIAL_CYBERJACK is not set
+# CONFIG_USB_SERIAL_XIRCOM is not set
+# CONFIG_USB_SERIAL_OPTION is not set
+# CONFIG_USB_SERIAL_OMNINET is not set
+# CONFIG_USB_SERIAL_OPTICON is not set
+# CONFIG_USB_SERIAL_VIVOPAY_SERIAL is not set
+# CONFIG_USB_SERIAL_ZIO is not set
+# CONFIG_USB_SERIAL_SSU100 is not set
+# CONFIG_USB_SERIAL_DEBUG is not set
+# USB Miscellaneous drivers
+# CONFIG_USB_EMI62 is not set
+# CONFIG_USB_EMI26 is not set
+# CONFIG_USB_ADUTUX is not set
+# CONFIG_USB_SEVSEG is not set
+# CONFIG_USB_RIO500 is not set
+# CONFIG_USB_LEGOTOWER is not set
+# CONFIG_USB_LCD is not set
+# CONFIG_USB_LED is not set
+# CONFIG_USB_CYPRESS_CY7C63 is not set
+# CONFIG_USB_CYTHERM is not set
+# CONFIG_USB_IDMOUSE is not set
+# CONFIG_USB_FTDI_ELAN is not set
+# CONFIG_USB_APPLEDISPLAY is not set
+# CONFIG_USB_LD is not set
+# CONFIG_USB_TRANCEVIBRATOR is not set
+# CONFIG_USB_IOWARRIOR is not set
+# CONFIG_USB_TEST is not set
+# CONFIG_USB_ISIGHTFW is not set
+# CONFIG_USB_YUREX is not set
+CONFIG_USB_GADGET=y
+# CONFIG_USB_GADGET_DEBUG is not set
+# CONFIG_USB_GADGET_DEBUG_FILES is not set
+# CONFIG_USB_GADGET_DEBUG_FS is not set
+CONFIG_USB_GADGET_VBUS_DRAW=2
+CONFIG_USB_GADGET_SELECTED=y
+# CONFIG_USB_GADGET_R8A66597 is not set
+CONFIG_USB_GADGET_S3C2410=y
+CONFIG_USB_S3C2410=y
+# CONFIG_USB_S3C2410_DEBUG is not set
+# CONFIG_USB_GADGET_M66592 is not set
+# CONFIG_USB_GADGET_DUMMY_HCD is not set
+# CONFIG_USB_GADGET_DUALSPEED is not set
+CONFIG_USB_ZERO=m
+# CONFIG_USB_AUDIO is not set
+CONFIG_USB_ETH=m
+CONFIG_USB_ETH_RNDIS=y
+# CONFIG_USB_ETH_EEM is not set
+CONFIG_USB_GADGETFS=m
+# CONFIG_USB_FUNCTIONFS is not set
+CONFIG_USB_FILE_STORAGE=m
+# CONFIG_USB_FILE_STORAGE_TEST is not set
+# CONFIG_USB_MASS_STORAGE is not set
+CONFIG_USB_G_SERIAL=m
+# CONFIG_USB_MIDI_GADGET is not set
+# CONFIG_USB_G_PRINTER is not set
+CONFIG_USB_CDC_COMPOSITE=m
+# CONFIG_USB_G_MULTI is not set
+# CONFIG_USB_G_HID is not set
+# CONFIG_USB_G_DBGP is not set
+# OTG and related infrastructure
+# CONFIG_USB_GPIO_VBUS is not set
+# CONFIG_USB_ULPI is not set
+# CONFIG_NOP_USB_XCEIV is not set
+CONFIG_MMC=y
+# CONFIG_MMC_DEBUG is not set
+# CONFIG_MMC_UNSAFE_RESUME is not set
+# MMC/SD/SDIO Card Drivers
+CONFIG_MMC_BLOCK=y
+CONFIG_MMC_BLOCK_MINORS=8
+CONFIG_MMC_BLOCK_BOUNCE=y
+CONFIG_SDIO_UART=y
+# CONFIG_MMC_TEST is not set
+# MMC/SD/SDIO Host Controller Drivers
+CONFIG_MMC_SDHCI=y
+# CONFIG_MMC_SDHCI_PLTFM is not set
+# CONFIG_MMC_SDHCI_S3C is not set
+CONFIG_MMC_SPI=y
+CONFIG_MMC_S3C=y
+# CONFIG_MMC_S3C_HW_SDIO_IRQ is not set
+CONFIG_MMC_S3C_PIO=y
+# CONFIG_MMC_S3C_DMA is not set
+# CONFIG_MMC_S3C_PIODMA is not set
+# CONFIG_MMC_USHC is not set
+# CONFIG_MEMSTICK is not set
+CONFIG_NEW_LEDS=y
+CONFIG_LEDS_CLASS=y
+# LED drivers
+CONFIG_LEDS_S3C24XX=y
+# CONFIG_LEDS_PCA9532 is not set
+CONFIG_LEDS_GPIO=y
+CONFIG_LEDS_GPIO_PLATFORM=y
+# CONFIG_LEDS_LP3944 is not set
+# CONFIG_LEDS_LP5521 is not set
+# CONFIG_LEDS_LP5523 is not set
+# CONFIG_LEDS_PCA955X is not set
+# CONFIG_LEDS_DAC124S085 is not set
+# CONFIG_LEDS_PWM is not set
+# CONFIG_LEDS_BD2802 is not set
+# CONFIG_LEDS_LT3593 is not set
+CONFIG_LEDS_TRIGGERS=y
+# LED Triggers
+CONFIG_LEDS_TRIGGER_TIMER=y
+CONFIG_LEDS_TRIGGER_HEARTBEAT=y
+CONFIG_LEDS_TRIGGER_BACKLIGHT=y
+CONFIG_LEDS_TRIGGER_GPIO=y
+CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
+# iptables trigger is under Netfilter config (LED target)
+# CONFIG_ACCESSIBILITY is not set
+CONFIG_RTC_LIB=y
+CONFIG_RTC_CLASS=y
+CONFIG_RTC_HCTOSYS=y
+CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
+# CONFIG_RTC_DEBUG is not set
+# RTC interfaces
+CONFIG_RTC_INTF_SYSFS=y
+CONFIG_RTC_INTF_PROC=y
+CONFIG_RTC_INTF_DEV=y
+CONFIG_RTC_INTF_DEV_UIE_EMUL=y
+# CONFIG_RTC_DRV_TEST is not set
+# I2C RTC drivers
+# CONFIG_RTC_DRV_DS1307 is not set
+# CONFIG_RTC_DRV_DS1374 is not set
+# CONFIG_RTC_DRV_DS1672 is not set
+# CONFIG_RTC_DRV_DS3232 is not set
+# CONFIG_RTC_DRV_MAX6900 is not set
+# CONFIG_RTC_DRV_RS5C372 is not set
+# CONFIG_RTC_DRV_ISL1208 is not set
+# CONFIG_RTC_DRV_ISL12022 is not set
+# CONFIG_RTC_DRV_X1205 is not set
+# CONFIG_RTC_DRV_PCF8563 is not set
+# CONFIG_RTC_DRV_PCF8583 is not set
+# CONFIG_RTC_DRV_M41T80 is not set
+# CONFIG_RTC_DRV_BQ32K is not set
+# CONFIG_RTC_DRV_S35390A is not set
+# CONFIG_RTC_DRV_FM3130 is not set
+# CONFIG_RTC_DRV_RX8581 is not set
+# CONFIG_RTC_DRV_RX8025 is not set
+# SPI RTC drivers
+# CONFIG_RTC_DRV_M41T94 is not set
+# CONFIG_RTC_DRV_DS1305 is not set
+# CONFIG_RTC_DRV_DS1390 is not set
+# CONFIG_RTC_DRV_MAX6902 is not set
+# CONFIG_RTC_DRV_R9701 is not set
+# CONFIG_RTC_DRV_RS5C348 is not set
+# CONFIG_RTC_DRV_DS3234 is not set
+# CONFIG_RTC_DRV_PCF2123 is not set
+# Platform RTC drivers
+# CONFIG_RTC_DRV_CMOS is not set
+# CONFIG_RTC_DRV_DS1286 is not set
+# CONFIG_RTC_DRV_DS1511 is not set
+# CONFIG_RTC_DRV_DS1553 is not set
+# CONFIG_RTC_DRV_DS1742 is not set
+# CONFIG_RTC_DRV_STK17TA8 is not set
+# CONFIG_RTC_DRV_M48T86 is not set
+# CONFIG_RTC_DRV_M48T35 is not set
+# CONFIG_RTC_DRV_M48T59 is not set
+# CONFIG_RTC_DRV_MSM6242 is not set
+# CONFIG_RTC_DRV_BQ4802 is not set
+# CONFIG_RTC_DRV_RP5C01 is not set
+# CONFIG_RTC_DRV_V3020 is not set
+# on-CPU RTC drivers
+CONFIG_RTC_DRV_S3C=y
+CONFIG_DMADEVICES=y
+# CONFIG_DMADEVICES_DEBUG is not set
+# DMA Devices
+# CONFIG_TIMB_DMA is not set
+# CONFIG_AUXDISPLAY is not set
+# CONFIG_UIO is not set
+# CONFIG_STAGING is not set
+# File systems
+CONFIG_EXT2_FS=m
+CONFIG_EXT2_FS_XATTR=y
+CONFIG_EXT2_FS_POSIX_ACL=y
+CONFIG_EXT2_FS_SECURITY=y
+# CONFIG_EXT2_FS_XIP is not set
+CONFIG_EXT3_FS=y
+CONFIG_EXT3_DEFAULTS_TO_ORDERED=y
+CONFIG_EXT3_FS_XATTR=y
+CONFIG_EXT3_FS_POSIX_ACL=y
+CONFIG_EXT3_FS_SECURITY=y
+# CONFIG_EXT4_FS is not set
+CONFIG_JBD=y
+# CONFIG_JBD_DEBUG is not set
+CONFIG_FS_MBCACHE=y
+# CONFIG_REISERFS_FS is not set
+# CONFIG_JFS_FS is not set
+CONFIG_FS_POSIX_ACL=y
+# CONFIG_XFS_FS is not set
+# CONFIG_GFS2_FS is not set
+# CONFIG_OCFS2_FS is not set
+# CONFIG_BTRFS_FS is not set
+# CONFIG_NILFS2_FS is not set
+CONFIG_FILE_LOCKING=y
+CONFIG_FSNOTIFY=y
+CONFIG_DNOTIFY=y
+CONFIG_INOTIFY_USER=y
+# CONFIG_FANOTIFY is not set
+# CONFIG_QUOTA is not set
+# CONFIG_QUOTACTL is not set
+CONFIG_AUTOFS4_FS=y
+# CONFIG_FUSE_FS is not set
+CONFIG_GENERIC_ACL=y
+# Caches
+# CONFIG_FSCACHE is not set
+# CD-ROM/DVD Filesystems
+# CONFIG_ISO9660_FS is not set
+# CONFIG_UDF_FS is not set
+# DOS/FAT/NT Filesystems
+CONFIG_FAT_FS=y
+CONFIG_MSDOS_FS=y
+CONFIG_VFAT_FS=y
+CONFIG_FAT_DEFAULT_CODEPAGE=437
+CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
+# CONFIG_NTFS_FS is not set
+# Pseudo filesystems
+CONFIG_PROC_FS=y
+CONFIG_PROC_SYSCTL=y
+CONFIG_PROC_PAGE_MONITOR=y
+CONFIG_SYSFS=y
+CONFIG_TMPFS=y
+CONFIG_TMPFS_POSIX_ACL=y
+# CONFIG_HUGETLB_PAGE is not set
+CONFIG_CONFIGFS_FS=m
+CONFIG_MISC_FILESYSTEMS=y
+# CONFIG_ADFS_FS is not set
+# CONFIG_AFFS_FS is not set
+# CONFIG_ECRYPT_FS is not set
+# CONFIG_HFS_FS is not set
+# CONFIG_HFSPLUS_FS is not set
+# CONFIG_BEFS_FS is not set
+# CONFIG_BFS_FS is not set
+# CONFIG_EFS_FS is not set
+CONFIG_JFFS2_FS=y
+CONFIG_JFFS2_FS_DEBUG=0
+CONFIG_JFFS2_FS_WRITEBUFFER=y
+# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
+# CONFIG_JFFS2_SUMMARY is not set
+# CONFIG_JFFS2_FS_XATTR is not set
+# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
+CONFIG_JFFS2_ZLIB=y
+# CONFIG_JFFS2_LZO is not set
+CONFIG_JFFS2_RTIME=y
+# CONFIG_JFFS2_RUBIN is not set
+# CONFIG_LOGFS is not set
+CONFIG_CRAMFS=y
+# CONFIG_SQUASHFS is not set
+# CONFIG_VXFS_FS is not set
+# CONFIG_MINIX_FS is not set
+# CONFIG_OMFS_FS is not set
+# CONFIG_HPFS_FS is not set
+# CONFIG_QNX4FS_FS is not set
+CONFIG_ROMFS_FS=y
+# CONFIG_ROMFS_BACKED_BY_BLOCK is not set
+# CONFIG_ROMFS_BACKED_BY_MTD is not set
+CONFIG_ROMFS_BACKED_BY_BOTH=y
+CONFIG_ROMFS_ON_BLOCK=y
+CONFIG_ROMFS_ON_MTD=y
+# CONFIG_SYSV_FS is not set
+# CONFIG_UFS_FS is not set
+CONFIG_NETWORK_FILESYSTEMS=y
+CONFIG_NFS_FS=y
+CONFIG_NFS_V3=y
+CONFIG_NFS_V3_ACL=y
+CONFIG_NFS_V4=y
+# CONFIG_NFS_V4_1 is not set
+CONFIG_ROOT_NFS=y
+# CONFIG_NFS_USE_LEGACY_DNS is not set
+CONFIG_NFS_USE_KERNEL_DNS=y
+# CONFIG_NFS_USE_NEW_IDMAPPER is not set
+# CONFIG_NFSD is not set
+CONFIG_LOCKD=y
+CONFIG_LOCKD_V4=y
+CONFIG_NFS_ACL_SUPPORT=y
+CONFIG_NFS_COMMON=y
+CONFIG_SUNRPC=y
+CONFIG_SUNRPC_GSS=y
+CONFIG_RPCSEC_GSS_KRB5=y
+# CONFIG_CEPH_FS is not set
+# CONFIG_CIFS is not set
+# CONFIG_NCP_FS is not set
+# CONFIG_CODA_FS is not set
+# CONFIG_AFS_FS is not set
+# Partition Types
+CONFIG_PARTITION_ADVANCED=y
+# CONFIG_ACORN_PARTITION is not set
+# CONFIG_OSF_PARTITION is not set
+# CONFIG_AMIGA_PARTITION is not set
+# CONFIG_ATARI_PARTITION is not set
+# CONFIG_MAC_PARTITION is not set
+CONFIG_MSDOS_PARTITION=y
+CONFIG_BSD_DISKLABEL=y
+CONFIG_MINIX_SUBPARTITION=y
+CONFIG_SOLARIS_X86_PARTITION=y
+CONFIG_UNIXWARE_DISKLABEL=y
+CONFIG_LDM_PARTITION=y
+# CONFIG_LDM_DEBUG is not set
+# CONFIG_SGI_PARTITION is not set
+# CONFIG_ULTRIX_PARTITION is not set
+# CONFIG_SUN_PARTITION is not set
+# CONFIG_KARMA_PARTITION is not set
+CONFIG_EFI_PARTITION=y
+# CONFIG_SYSV68_PARTITION is not set
+CONFIG_NLS=y
+CONFIG_NLS_DEFAULT="cp437"
+# CONFIG_NLS_CODEPAGE_437 is not set
+# CONFIG_NLS_CODEPAGE_737 is not set
+# CONFIG_NLS_CODEPAGE_775 is not set
+CONFIG_NLS_CODEPAGE_850=m
+# CONFIG_NLS_CODEPAGE_852 is not set
+# CONFIG_NLS_CODEPAGE_855 is not set
+# CONFIG_NLS_CODEPAGE_857 is not set
+# CONFIG_NLS_CODEPAGE_860 is not set
+# CONFIG_NLS_CODEPAGE_861 is not set
+# CONFIG_NLS_CODEPAGE_862 is not set
+# CONFIG_NLS_CODEPAGE_863 is not set
+# CONFIG_NLS_CODEPAGE_864 is not set
+# CONFIG_NLS_CODEPAGE_865 is not set
+# CONFIG_NLS_CODEPAGE_866 is not set
+# CONFIG_NLS_CODEPAGE_869 is not set
+# CONFIG_NLS_CODEPAGE_936 is not set
+# CONFIG_NLS_CODEPAGE_950 is not set
+# CONFIG_NLS_CODEPAGE_932 is not set
+# CONFIG_NLS_CODEPAGE_949 is not set
+# CONFIG_NLS_CODEPAGE_874 is not set
+# CONFIG_NLS_ISO8859_8 is not set
+CONFIG_NLS_CODEPAGE_1250=m
+# CONFIG_NLS_CODEPAGE_1251 is not set
+CONFIG_NLS_ASCII=m
+CONFIG_NLS_ISO8859_1=m
+# CONFIG_NLS_ISO8859_2 is not set
+# CONFIG_NLS_ISO8859_3 is not set
+# CONFIG_NLS_ISO8859_4 is not set
+# CONFIG_NLS_ISO8859_5 is not set
+# CONFIG_NLS_ISO8859_6 is not set
+# CONFIG_NLS_ISO8859_7 is not set
+# CONFIG_NLS_ISO8859_9 is not set
+# CONFIG_NLS_ISO8859_13 is not set
+# CONFIG_NLS_ISO8859_14 is not set
+CONFIG_NLS_ISO8859_15=m
+# CONFIG_NLS_KOI8_R is not set
+# CONFIG_NLS_KOI8_U is not set
+CONFIG_NLS_UTF8=m
+# CONFIG_DLM is not set
+# Kernel hacking
+# CONFIG_PRINTK_TIME is not set
+# CONFIG_ENABLE_WARN_DEPRECATED is not set
+# CONFIG_ENABLE_MUST_CHECK is not set
+CONFIG_FRAME_WARN=1024
+# CONFIG_MAGIC_SYSRQ is not set
+CONFIG_STRIP_ASM_SYMS=y
+# CONFIG_UNUSED_SYMBOLS is not set
+CONFIG_DEBUG_FS=y
+# CONFIG_HEADERS_CHECK is not set
+CONFIG_DEBUG_KERNEL=y
+# CONFIG_DEBUG_SHIRQ is not set
+# CONFIG_LOCKUP_DETECTOR is not set
+# CONFIG_HARDLOCKUP_DETECTOR is not set
+# CONFIG_DETECT_HUNG_TASK is not set
+# CONFIG_SCHED_DEBUG is not set
+# CONFIG_SCHEDSTATS is not set
+# CONFIG_TIMER_STATS is not set
+# CONFIG_DEBUG_OBJECTS is not set
+# CONFIG_SLUB_DEBUG_ON is not set
+# CONFIG_SLUB_STATS is not set
+# CONFIG_DEBUG_KMEMLEAK is not set
+# CONFIG_DEBUG_RT_MUTEXES is not set
+# CONFIG_RT_MUTEX_TESTER is not set
+# CONFIG_DEBUG_SPINLOCK is not set
+# CONFIG_DEBUG_MUTEXES is not set
+CONFIG_BKL=y
+# CONFIG_DEBUG_LOCK_ALLOC is not set
+# CONFIG_PROVE_LOCKING is not set
+# CONFIG_SPARSE_RCU_POINTER is not set
+# CONFIG_LOCK_STAT is not set
+# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
+# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
+# CONFIG_DEBUG_KOBJECT is not set
+CONFIG_DEBUG_BUGVERBOSE=y
+CONFIG_DEBUG_INFO=y
+# CONFIG_DEBUG_INFO_REDUCED is not set
+# CONFIG_DEBUG_VM is not set
+# CONFIG_DEBUG_WRITECOUNT is not set
+CONFIG_DEBUG_MEMORY_INIT=y
+# CONFIG_DEBUG_LIST is not set
+# CONFIG_TEST_LIST_SORT is not set
+# CONFIG_DEBUG_SG is not set
+# CONFIG_DEBUG_NOTIFIERS is not set
+# CONFIG_DEBUG_CREDENTIALS is not set
+# CONFIG_BOOT_PRINTK_DELAY is not set
+# CONFIG_RCU_TORTURE_TEST is not set
+# CONFIG_BACKTRACE_SELF_TEST is not set
+# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
+# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
+# CONFIG_LKDTM is not set
+# CONFIG_FAULT_INJECTION is not set
+# CONFIG_LATENCYTOP is not set
+CONFIG_SYSCTL_SYSCALL_CHECK=y
+# CONFIG_PAGE_POISONING is not set
+CONFIG_HAVE_FUNCTION_TRACER=y
+CONFIG_HAVE_DYNAMIC_FTRACE=y
+CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
+CONFIG_TRACING_SUPPORT=y
+CONFIG_FTRACE=y
+# CONFIG_FUNCTION_TRACER is not set
+# CONFIG_SCHED_TRACER is not set
+# CONFIG_ENABLE_DEFAULT_TRACERS is not set
+CONFIG_BRANCH_PROFILE_NONE=y
+# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
+# CONFIG_PROFILE_ALL_BRANCHES is not set
+# CONFIG_STACK_TRACER is not set
+# CONFIG_BLK_DEV_IO_TRACE is not set
+# CONFIG_DYNAMIC_DEBUG is not set
+# CONFIG_ATOMIC64_SELFTEST is not set
+# CONFIG_SAMPLES is not set
+CONFIG_HAVE_ARCH_KGDB=y
+# CONFIG_KGDB is not set
+# CONFIG_STRICT_DEVMEM is not set
+CONFIG_ARM_UNWIND=y
+CONFIG_DEBUG_USER=y
+# CONFIG_DEBUG_ERRORS is not set
+# CONFIG_DEBUG_STACK_USAGE is not set
+# CONFIG_DEBUG_LL is not set
+# CONFIG_OC_ETM is not set
+CONFIG_DEBUG_S3C_UART=0
+# Security options
+CONFIG_KEYS=y
+# CONFIG_KEYS_DEBUG_PROC_KEYS is not set
+# CONFIG_SECURITY_DMESG_RESTRICT is not set
+# CONFIG_SECURITY is not set
+# CONFIG_SECURITYFS is not set
+CONFIG_DEFAULT_SECURITY_DAC=y
+CONFIG_DEFAULT_SECURITY=""
+CONFIG_CRYPTO=y
+# Crypto core or helper
+CONFIG_CRYPTO_ALGAPI=y
+CONFIG_CRYPTO_ALGAPI2=y
+CONFIG_CRYPTO_AEAD=m
+CONFIG_CRYPTO_AEAD2=y
+CONFIG_CRYPTO_BLKCIPHER=y
+CONFIG_CRYPTO_BLKCIPHER2=y
+CONFIG_CRYPTO_HASH=y
+CONFIG_CRYPTO_HASH2=y
+CONFIG_CRYPTO_RNG=m
+CONFIG_CRYPTO_RNG2=y
+CONFIG_CRYPTO_PCOMP=m
+CONFIG_CRYPTO_PCOMP2=y
+CONFIG_CRYPTO_MANAGER=y
+CONFIG_CRYPTO_MANAGER2=y
+CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
+CONFIG_CRYPTO_GF128MUL=m
+CONFIG_CRYPTO_NULL=m
+CONFIG_CRYPTO_WORKQUEUE=y
+CONFIG_CRYPTO_CRYPTD=m
+CONFIG_CRYPTO_AUTHENC=m
+CONFIG_CRYPTO_TEST=m
+# Authenticated Encryption with Associated Data
+CONFIG_CRYPTO_CCM=m
+CONFIG_CRYPTO_GCM=m
+CONFIG_CRYPTO_SEQIV=m
+# Block modes
+CONFIG_CRYPTO_CBC=y
+CONFIG_CRYPTO_CTR=m
+CONFIG_CRYPTO_CTS=m
+CONFIG_CRYPTO_ECB=y
+CONFIG_CRYPTO_LRW=m
+CONFIG_CRYPTO_PCBC=m
+CONFIG_CRYPTO_XTS=m
+# Hash modes
+CONFIG_CRYPTO_HMAC=y
+CONFIG_CRYPTO_XCBC=m
+# CONFIG_CRYPTO_VMAC is not set
+# Digest
+CONFIG_CRYPTO_CRC32C=m
+CONFIG_CRYPTO_GHASH=m
+CONFIG_CRYPTO_MD4=m
+CONFIG_CRYPTO_MD5=y
+CONFIG_CRYPTO_MICHAEL_MIC=y
+CONFIG_CRYPTO_RMD128=m
+CONFIG_CRYPTO_RMD160=m
+CONFIG_CRYPTO_RMD256=m
+CONFIG_CRYPTO_RMD320=m
+CONFIG_CRYPTO_SHA1=m
+CONFIG_CRYPTO_SHA256=m
+CONFIG_CRYPTO_SHA512=m
+CONFIG_CRYPTO_TGR192=m
+CONFIG_CRYPTO_WP512=m
+# Ciphers
+CONFIG_CRYPTO_AES=y
+CONFIG_CRYPTO_ANUBIS=m
+CONFIG_CRYPTO_ARC4=y
+CONFIG_CRYPTO_BLOWFISH=m
+CONFIG_CRYPTO_CAMELLIA=m
+CONFIG_CRYPTO_CAST5=m
+CONFIG_CRYPTO_CAST6=m
+CONFIG_CRYPTO_DES=y
+CONFIG_CRYPTO_FCRYPT=m
+CONFIG_CRYPTO_KHAZAD=m
+CONFIG_CRYPTO_SALSA20=m
+CONFIG_CRYPTO_SEED=m
+CONFIG_CRYPTO_SERPENT=m
+CONFIG_CRYPTO_TEA=m
+CONFIG_CRYPTO_TWOFISH=m
+CONFIG_CRYPTO_TWOFISH_COMMON=m
+# Compression
+CONFIG_CRYPTO_DEFLATE=m
+CONFIG_CRYPTO_ZLIB=m
+CONFIG_CRYPTO_LZO=m
+# Random Number Generation
+CONFIG_CRYPTO_ANSI_CPRNG=m
+CONFIG_CRYPTO_HW=y
+# CONFIG_BINARY_PRINTF is not set
+# Library routines
+CONFIG_BITREVERSE=y
+CONFIG_GENERIC_FIND_LAST_BIT=y
+CONFIG_CRC_CCITT=m
+CONFIG_CRC16=m
+CONFIG_CRC_T10DIF=y
+CONFIG_CRC_ITU_T=y
+CONFIG_CRC32=y
+CONFIG_CRC7=y
+CONFIG_LIBCRC32C=m
+CONFIG_ZLIB_INFLATE=y
+CONFIG_ZLIB_DEFLATE=y
+CONFIG_LZO_COMPRESS=m
+CONFIG_LZO_DECOMPRESS=y
+CONFIG_DECOMPRESS_GZIP=y
+CONFIG_DECOMPRESS_BZIP2=y
+CONFIG_DECOMPRESS_LZMA=y
+CONFIG_DECOMPRESS_LZO=y
+CONFIG_HAS_IOMEM=y
+CONFIG_HAS_DMA=y
+CONFIG_NLATTR=y
+CONFIG_GENERIC_ATOMIC64=y
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0001-s3c2440-mini2440-Add-support-for-new-LCD-panels.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0001-s3c2440-mini2440-Add-support-for-new-LCD-panels.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0001-s3c2440-mini2440-Add-support-for-new-LCD-panels.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0001-s3c2440-mini2440-Add-support-for-new-LCD-panels.patch	2011-05-31 16:05:21.000000000 +0200
@@ -0,0 +1,70 @@
+From 797f5ccc062116efbd28b143b127e0d321c473af Mon Sep 17 00:00:00 2001
+From: Marek Belisko <marek.belisko@open-nandra.com>
+Date: Fri, 18 Mar 2011 13:13:05 +0100
+Subject: [PATCH 1/4] s3c2440: mini2440: Add support for new LCD panels.
+This patch add support for new mini2440 board LCD's:
+3.5" TFT + TS (TD035STED4)
+5.6" TFT (Innolux AT056TN52).
+3.5" TFT + TS (SONY X35)
+Values overtaken from mini2440 kernel:
+git://repo.or.cz/linux-2.6/mini2440.git
+and https://github.com/a1ien/mini2440-linux-kernel
+Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com>
+ arch/arm/mach-s3c2440/mach-mini2440.c |   37 +++++++++++++++++++++++++++++++++
+ 1 files changed, 37 insertions(+), 0 deletions(-)
+diff --git arch/arm/mach-s3c2440/mach-mini2440.c arch/arm/mach-s3c2440/mach-mini2440.c
+index dfedc9c..ce152b4 100644
+--- arch/arm/mach-s3c2440/mach-mini2440.c
++++ arch/arm/mach-s3c2440/mach-mini2440.c
+@@ -167,6 +167,43 @@ static struct s3c2410fb_display mini2440_lcd_cfg[] __initdata = {
+ 		.lcdcon5	= (S3C2410_LCDCON5_FRM565 |
+ 				   S3C2410_LCDCON5_HWSWP),
++	[3] = {	/* mini2440 + 3.5" TFT + TS -- New model as Nov 2009 "T35" */
++		_LCD_DECLARE(
++			7,			/* The 3.5 is quite fast */
++			240, 21, 25, 6,		/* x timing */
++			320, 2, 4, 2,		/* y timing */
++			40),			/* refresh rate */
++		.lcdcon5	= (S3C2410_LCDCON5_FRM565 |
++				   S3C2410_LCDCON5_INVVLINE |
++				   S3C2410_LCDCON5_INVVFRAME |
++				   S3C2410_LCDCON5_INVVDEN |
++				   S3C2410_LCDCON5_PWREN),
++	[4] = { /* mini2440 + 5.6" TFT + touchscreen -- Innolux AT056TN52 */
++		/* be sure the "power" jumper is set accordingly ! */
++		_LCD_DECLARE(
++			10,			/* the 5.3" runs slower */
++			640, 41, 68, 22,	/* x timing */
++			480, 26, 6, 2,		/* y timing */
++	[5] = { /* mini2440 + 3,5" TFT + touchscreen -- SONY X35 */
++		_LCD_DECLARE(
++			7,
++			240, 1, 26, 5,		/* x timing */
++			320, 1, 5, 9,		/* y timing */
++			60),			/* refresh rate */
++					S3C2410_LCDCON5_INVVCLK |
++					S3C2410_LCDCON5_HWSWP),
+ /* todo - put into gpio header */
+1.7.1
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0002-s3c2440-mini2440-Add-touchscreen-support-for-mini244.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0002-s3c2440-mini2440-Add-touchscreen-support-for-mini244.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0002-s3c2440-mini2440-Add-touchscreen-support-for-mini244.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0002-s3c2440-mini2440-Add-touchscreen-support-for-mini244.patch	2011-03-29 08:03:58.000000000 +0200
@@ -0,0 +1,73 @@
+From 39b3082542f900fab53ba823d182a2fb56430113 Mon Sep 17 00:00:00 2001
+Date: Mon, 21 Mar 2011 08:17:05 +0100
+Subject: [PATCH 2/4] s3c2440: mini2440: Add touchscreen support for mini2440.
+Patch add support for mini2440 touchscreen.
+Some code borrowed from:
+ arch/arm/mach-s3c2440/mach-mini2440.c |   17 +++++++++++++++--
+ 1 files changed, 15 insertions(+), 2 deletions(-)
+index ce152b4..163d318 100644
+@@ -47,6 +47,7 @@
+ #include <plat/iic.h>
+ #include <plat/mci.h>
+ #include <plat/udc.h>
++#include <plat/ts.h>
+ #include <linux/mtd/mtd.h>
+ #include <linux/mtd/nand.h>
+@@ -530,6 +531,11 @@ static struct platform_device uda1340_codec = {
+ 		.id = -1,
++static struct s3c2410_ts_mach_info mini2440_ts_cfg __initdata = {
++	.delay = 10000,
++	.presc = 0xff, /* slow as we can go */
+ static struct platform_device *mini2440_devices[] __initdata = {
+ 	&s3c_device_ohci,
+ 	&s3c_device_wdt,
+@@ -548,6 +554,7 @@ static struct platform_device *mini2440_devices[] __initdata = {
+ 	&uda1340_codec,
+ 	&mini2440_audio,
+ 	&samsung_asoc_dma,
++	&s3c_device_adc,
+ static void __init mini2440_map_io(void)
+@@ -631,8 +638,13 @@ static void mini2440_parse_features(
+ 			features->done |= FEATURE_BACKLIGHT;
+ 			break;
+ 		case 't':
+-			printk(KERN_INFO "MINI2440: '%c' ignored, "
+-				"touchscreen not compiled in\n", f);
++			if (features->done & FEATURE_TOUCH)
++				printk(KERN_INFO "MINI2440: '%c' ignored, "
++					"touchscreen already set\n", f);
++			else
++				features->optional[features->count++] =
++						&s3c_device_ts;
++			features->done |= FEATURE_TOUCH;
+ 			break;
+ 		case 'c':
+ 			if (features->done & FEATURE_CAMERA)
+@@ -699,6 +711,7 @@ static void __init mini2440_init(void)
+ 	s3c24xx_mci_set_platdata(&mini2440_mmc_cfg);
+ 	s3c_nand_set_platdata(&mini2440_nand_info);
+ 	s3c_i2c0_set_platdata(NULL);
++	s3c24xx_ts_set_platdata(&mini2440_ts_cfg);
+ 	i2c_register_board_info(0, mini2440_i2c_devs,
+ 				ARRAY_SIZE(mini2440_i2c_devs));
+1.7.1
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0003-s3c2440-mini2440-Select-touchscreen-by-default.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0003-s3c2440-mini2440-Select-touchscreen-by-default.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0003-s3c2440-mini2440-Select-touchscreen-by-default.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0003-s3c2440-mini2440-Select-touchscreen-by-default.patch	2011-03-29 08:03:58.000000000 +0200
@@ -0,0 +1,25 @@
+From 422ec63f257ea300e9ad8754f357cde1d1917485 Mon Sep 17 00:00:00 2001
+Date: Mon, 28 Mar 2011 14:24:58 +0200
+Subject: [PATCH 3/4] s3c2440: mini2440: Select touchscreen by default.
+ arch/arm/mach-s3c2440/Kconfig |    1 +
+ 1 files changed, 1 insertions(+), 0 deletions(-)
+diff --git arch/arm/mach-s3c2440/Kconfig arch/arm/mach-s3c2440/Kconfig
+index 50825a3..e713eea 100644
+--- arch/arm/mach-s3c2440/Kconfig
++++ arch/arm/mach-s3c2440/Kconfig
+@@ -186,6 +186,7 @@ config MACH_MINI2440
+ 	select LEDS_TRIGGER_BACKLIGHT
+ 	select S3C_DEV_NAND
+ 	select S3C_DEV_USB_HOST
++	select TOUCHSCREEN_S3C2410
+ 	help
+ 	  Say Y here to select support for the MINI2440. Is a 10cm x 10cm board
+ 	  available via various sources. It can come with a 3.5" or 7" touch LCD.
+1.7.1
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0004-s3c2440-mini2440-Enable-the-backlight-LED-earlier-at.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0004-s3c2440-mini2440-Enable-the-backlight-LED-earlier-at.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0004-s3c2440-mini2440-Enable-the-backlight-LED-earlier-at.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0004-s3c2440-mini2440-Enable-the-backlight-LED-earlier-at.patch	2011-03-29 08:03:58.000000000 +0200
@@ -0,0 +1,63 @@
+From 50194dd2c9fdd83f38936a30e03191c3851830a4 Mon Sep 17 00:00:00 2001
+Date: Mon, 28 Mar 2011 15:12:52 +0200
+Subject: [PATCH 4/4] s3c2440: mini2440: Enable the backlight LED earlier at boot time.
+Code overtaken from:
+http://repo.or.cz/w/linux-2.6/mini2440.git
+Use flag that allows s3c24xx LED to start in the "on" state.
+This is necesary to enable LCD backlight during early boot stage.
+Signed-off-by: Michel Pollet <buserror@gmail.com>
+ arch/arm/mach-s3c2410/include/mach/leds-gpio.h |    1 +
+ arch/arm/mach-s3c2440/mach-mini2440.c          |    1 +
+ drivers/leds/leds-s3c24xx.c                    |    6 +++++-
+ 3 files changed, 7 insertions(+), 1 deletions(-)
+diff --git arch/arm/mach-s3c2410/include/mach/leds-gpio.h arch/arm/mach-s3c2410/include/mach/leds-gpio.h
+index d8a7672..c3ae81f 100644
+--- arch/arm/mach-s3c2410/include/mach/leds-gpio.h
++++ arch/arm/mach-s3c2410/include/mach/leds-gpio.h
+@@ -16,6 +16,7 @@
+ #define S3C24XX_LEDF_ACTLOW	(1<<0)		/* LED is on when GPIO low */
+ #define S3C24XX_LEDF_TRISTATE	(1<<1)		/* tristate to turn off */
++#define S3C24XX_LEDF_STARTON    (1<<2)          /* Initialise 'on' */
+ struct s3c24xx_led_platdata {
+ 	unsigned int		 gpio;
+index 163d318..46f2034 100644
+@@ -451,6 +451,7 @@ static struct s3c24xx_led_platdata mini2440_led4_pdata = {
+ static struct s3c24xx_led_platdata mini2440_led_backlight_pdata = {
+ 	.name		= "backlight",
+ 	.gpio		= S3C2410_GPG(4),
++	.flags		= S3C24XX_LEDF_STARTON,
+ 	.def_trigger	= "backlight",
+diff --git drivers/leds/leds-s3c24xx.c drivers/leds/leds-s3c24xx.c
+index a77771d..42d0a08 100644
+--- drivers/leds/leds-s3c24xx.c
++++ drivers/leds/leds-s3c24xx.c
+@@ -95,7 +95,11 @@ static int s3c24xx_led_probe(struct platform_device *dev)
+ 		s3c2410_gpio_cfgpin(pdata->gpio, S3C2410_GPIO_INPUT);
+ 	} else {
+ 		s3c2410_gpio_pullup(pdata->gpio, 0);
+-		s3c2410_gpio_setpin(pdata->gpio, 0);
++		if (pdata->flags & S3C24XX_LEDF_STARTON)
++			s3c2410_gpio_setpin(pdata->gpio, 1);
++		else
++			s3c2410_gpio_setpin(pdata->gpio, 0);
+ 		s3c2410_gpio_cfgpin(pdata->gpio, S3C2410_GPIO_OUTPUT);
+1.7.1
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0005-s3c2440-mini2440-nfs-DM9000-Networkpatch.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0005-s3c2440-mini2440-nfs-DM9000-Networkpatch.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0005-s3c2440-mini2440-nfs-DM9000-Networkpatch.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0005-s3c2440-mini2440-nfs-DM9000-Networkpatch.patch	2011-05-31 16:18:54.000000000 +0200
@@ -0,0 +1,15 @@
+To unsubscribe from this list: send the line "unsubscribe linux-nfs" in
+the body of a message to majordomo@vger.kernel.org
+More majordomo info at  http://vger.kernel.org/majordomo-info.html
+--- fs/nfs/nfsroot.c	2011-05-19 06:06:34.000000000 +0200
++++ fs/nfs/nfsroot.c	2011-05-31 16:16:43.250268002 +0200
+@@ -87,7 +87,7 @@
+ #define NFS_ROOT		"/tftpboot/%s"
+ /* Default NFSROOT mount options. */
+-#define NFS_DEF_OPTIONS		"udp"
++#define NFS_DEF_OPTIONS    "vers=2,udp,rsize=4096,wsize=4096"
+ /* Parameters passed from the kernel command line */
+ static char nfs_root_parms[256] __initdata = "";
diff -u --recursive --new-file board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0006-s3c2440-mini2440-Display-support-LQ121S1LG61-over-LVDS.patch board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0006-s3c2440-mini2440-Display-support-LQ121S1LG61-over-LVDS.patch
--- board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0006-s3c2440-mini2440-Display-support-LQ121S1LG61-over-LVDS.patch	1970-01-01 01:00:00.000000000 +0100
+++ board/friendlyarm/mini2440/linux-2.6.39-patches/linux-2.6.39-0006-s3c2440-mini2440-Display-support-LQ121S1LG61-over-LVDS.patch	2011-05-31 16:24:06.000000000 +0200
@@ -0,0 +1,20 @@
+--- arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-31 16:20:00.290268002 +0200
++++ arch/arm/mach-s3c2440/mach-mini2440.c	2011-05-31 16:21:42.540268001 +0200
+@@ -205,6 +205,17 @@
++	[6] = {  /* mini2440 + LVDS-Adapter (LQ121S1LG61) */
++		_LCD_DECLARE(
++			10,
++			800, 88, 40, 128,	/* x timing */
++			600, 23, 39, 4, 	/* y timing */
++			24),	/* refresh rate */
diff -u configs/mini2440_defconfig configs/mini2440_defconfig
--- configs/mini2440_defconfig	2011-02-28 21:54:22.000000000 +0100
+++ configs/mini2440_defconfig	2011-05-31 15:59:33.000000000 +0200
@@ -15,7 +15,7 @@
 BR2_TARGET_ROOTFS_TAR=y
 # Bootloader
-BR2_TARGET_UBOOT=y
+BR2_TARGET_UBOOT=n
 BR2_TARGET_UBOOT_BOARDNAME="mini2440"
 BR2_TARGET_UBOOT_CUSTOM_TARBALL=y
 BR2_TARGET_UBOOT_CUSTOM_TARBALL_LOCATION="http://repo.or.cz/w/u-boot-openmoko/mini2440.git/snapshot/dev-mini2440-stable.tar.gz"
@@ -23,9 +23,15 @@
 # Kernel
+BR2_KERNEL_HEADERS_VERSION=y
+BR2_DEFAULT_KERNEL_VERSION="2.6.39"
 BR2_LINUX_KERNEL=y
-BR2_LINUX_KERNEL_CUSTOM_TARBALL=y
-BR2_LINUX_KERNEL_CUSTOM_TARBALL_LOCATION="http://www.pauljones.id.au/temp/linux-2.6.32.2-mini2440_20100113.tgz"
+BR2_LINUX_KERNEL_SAME_AS_HEADERS=y
+BR2_LINUX_KERNEL_PATCH="$(TOPDIR)/board/friendlyarm/mini2440/linux-2.6.39-patches/"
 BR2_LINUX_KERNEL_USE_CUSTOM_CONFIG=y
-BR2_LINUX_KERNEL_CUSTOM_CONFIG_FILE="board/friendlyarm/mini2440/linux-2.6.32.2.config"
-BR2_LINUX_KERNEL_UIMAGE=y
+BR2_LINUX_KERNEL_CUSTOM_CONFIG_FILE="$(TOPDIR)/board/friendlyarm/mini2440/linux-2.6.39.config"
+# Hostname
+BR2_TARGET_GENERIC_HOSTNAME="Mini2440"
+BR2_TARGET_GENERIC_ISSUE="Welcome to Mini2440"
