----------------------------------------------------------------------- Boot Rescue-Image ----------------------------------------------------------------------- FlashReader V1.0.2.1, built Sep 4 2006 22:24:11 with ECC Bootscript version 0x00130001 Hynix, 8bit, 64MB U-Boot 2008.10-very-dirty (Jun 19 2011 - 16:21:27) NAND Adress is: 0xb0000000 NAND ID: 0x000076ad Prepare USB DRAM: 128 MB Using default environment I2C: Bus #0, at 0xBBE45000 I2C: Bus #1, at 0xBBE46000 I2C: Bus #2, at 0xBBE4C000 I2C: Bus #3, at 0xBBE69000 In: serial Out: serial Err: serial NAND: 0 MiB Model: ST3200822AS Firm: 3.01 Ser#: 4LJ0DF2V Type: Hard Disk Capacity: 190782.2 MB = 186.3 GB (390721968 x 512) Model: Firm: Ser#: Type: Hard Disk Capacity: not available Net: dp83815#0 Hit any key to stop autoboot: 0 Pollin PNX8950 # run load_rescue ## Booting kernel from Legacy Image at 805e2000 ... Image Name: PNX8xxx-MIPS-Rescue-gzip Created: 2011-06-19 16:07:07 UTC Image Type: MIPS Linux Kernel Image (gzip compressed) Data Size: 6151489 Bytes = 5.9 MB Load Address: 80060000 Entry Point: 80362000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Starting kernel ... Installing MMIO driver: modprobe: could not parse modules.dep done Populating /dev using udev: done Initializing random number generator... done. Starting network... udhcpc (v1.2.2) started Dec 31 17:00:08 udhcpc[246]: udhcpc (v1.2.2) started Sending discover... Dec 31 17:00:08 udhcpc[246]: Sending discover... Sending discover... Dec 31 17:00:11 udhcpc[246]: Sending discover... Sending select for 192.168.2.62... Dec 31 17:00:12 udhcpc[246]: Sending select for 192.168.2.62... Lease of 192.168.2.62 obtained, lease time 864000 Dec 31 17:00:12 udhcpc[246]: Lease of 192.168.2.62 obtained, lease time 864000 deleting routers route: SIOC[ADD|DEL]RT: No such process adding dns 192.168.2.10 Starting dropbear sshd: OK IP-FTP-Hack IP-Adresse ermitteln: 192.168.2.62 Patch /etc/proftpd.conf root login for ftp in rescue is ok Start proftpd... - setting default address to 192.168.2.62 done ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ / \ / \ / \ / \ / \ / \ / \ ( P | N | X | 8 | 9 | 5 | 0 ) \_/ \_/ \_/ \_/ \_/ \_/ \_/ User : root Passwort: root www.mikrocontroller.net ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Mein Dank geht an alle, die die Entwicklung mit voran getrieben haben - und hoffentlich auch weiter vorantreiben werden. CS. Besuchen Sie www.mikrocontroller.net ----------------------------------------------------------------------- Rescue-Image Verzeichnisse (einge) ----------------------------------------------------------------------- sh-3.1# ls /bin addgroup cp getopt mkdir pwd true zfgrep adduser date grep mknod rm umount zforce ash dd gunzip mktemp rmdir uname zgrep bash delgroup gzexe more run-parts usleep zless bashbug deluser gzip mount sed uuidgen zmore busybox df hostname mt sh vi znew cat dmesg kill mv sleep wget chattr echo ln netstat stty zcat chgrp egrep login pidof su zcmp chmod false ls ping sync zdiff chown fgrep lsattr ps touch zegrep sh-3.1# ls /dev console random tty3 tty57 fd sda tty30 tty58 full sda1 tty31 tty59 input sda2 tty32 tty6 kmem sda3 tty33 tty60 kmsg sda4 tty34 tty61 log tty tty35 tty62 loop0 tty0 tty36 tty63 mem tty1 tty37 tty7 mmio tty10 tty38 tty8 null tty11 tty39 tty9 port tty12 tty4 ttyS0 ptmx tty13 tty40 ttyS1 pts tty14 tty41 urandom ram0 tty15 tty42 usbdev1.1 ram1 tty16 tty43 usbdev1.1_ep00 ram10 tty17 tty44 usbdev1.1_ep81 ram11 tty18 tty45 usbdev2.1 ram12 tty19 tty46 usbdev2.1_ep00 ram13 tty2 tty47 usbdev2.1_ep81 ram14 tty20 tty48 usbdev3.1 ram15 tty21 tty49 usbdev3.1_ep00 ram2 tty22 tty5 usbdev3.1_ep81 ram3 tty23 tty50 usbdev4.1 ram4 tty24 tty51 usbdev4.1_ep00 ram5 tty25 tty52 usbdev4.1_ep81 ram6 tty26 tty53 vcs ram7 tty27 tty54 vcsa ram8 tty28 tty55 zero ram9 tty29 tty56 sh-3.1# ls /sbin badblocks halt mke2fs sulogin blkid hwclock mkfs.ext2 swapoff dhclient-script ifconfig mkfs.ext3 swapon dumpe2fs ifdown mklost+found switch_root e2fsck ifup modprobe syslogd e2label init pivot_root tune2fs fdisk insmod poweroff udevcontrol filefrag klogd reboot udevd findfs ldconfig rmmod udevsettle fsck logsave route udevstart fsck.ext2 lsmod scsi_id udevtrigger fsck.ext3 lspci setpci udhcpc getty mkdosfs start-stop-daemon usbmount sh-3.1# ls /usr/bin [ deallocvt logname time [[ dirname mc tty basename dos2unix mcedit udevinfo bunzip2 dropbearconvert md5sum udevtest bzcat dropbearkey nslookup uniq bzcmp du openvt unix2dos bzdiff env passwd unzip bzegrep expr patch uptime bzfgrep fdformat readlink uudecode bzgrep find reset uuencode bzip2 free scp vlock bzip2recover head sha1sum wc bzless hexdump sort wget bzmore hostid ssh which chvt id strings whoami clear install sudo xargs cmp killall tail yes cut ldd tee dbclient less telnet dc logger test sh-3.1# ls /usr/sbin chroot dropbear rdate visudo dhclient proftpd udevmonitor sh-3.1# ----------------------------------------------------------------------- Rescue-Image fdisk /dev/sda Info ----------------------------------------------------------------------- sh-3.1# fdisk /dev/sda The number of cylinders for this disk is set to 24321. There is nothing wrong with that, but this is larger than 1024, and could in certain setups cause problems with: 1) software that runs at boot time (e.g., old versions of LILO) 2) booting and partitioning software from other OSs (e.g., DOS FDISK, OS/2 FDISK) Command (m for help): p Disk /dev/sda: 200.0 GB, 200049647616 bytes 255 heads, 63 sectors/track, 24321 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 1 13 104391 83 Linux /dev/sda2 14 512 4008217+ 83 Linux /dev/sda3 513 1011 4008217+ 83 Linux /dev/sda4 1012 24321 187237575 83 Linux Command (m for help): q sh-3.1# df -h Filesystem Size Used Available Use% Mounted on tmpfs 61.7M 28.0k 61.6M 0% /tmp /dev/sda2 3.8G 7.6M 3.6G 0% /tmp/sda2 sh-3.1# mke2fs /dev/sda2 mke2fs 1.39 (29-May-2006) Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) 501952 inodes, 1002054 blocks 50102 blocks (5.00%) reserved for the super user First data block=0 Maximum filesystem blocks=1027604480 31 block groups 32768 blocks per group, 32768 fragments per group 16192 inodes per group Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736 Writing inode tables: done Writing superblocks and filesystem accounting information: done This filesystem will be automatically checked every 38 mounts or 180 days, whichever comes first. Use tune2fs -c or -i to override. sh-3.1# mkdir /tmp/sda2 sh-3.1# mount /dev/sda2 /tmp/sda2/ sh-3.1# mount sysfs on /sys type sysfs (rw) proc on /proc type proc (rw) devpts on /dev/pts type devpts (rw) tmpfs on /tmp type tmpfs (rw) /dev/sda2 on /tmp/sda2 type ext2 (rw) sh-3.1# tar xfvz PollinHDD.tar.gz sh: tar: command not found sh-3.1# busybox tar xfvz PollinHDD.tar.gz tar: vz: No such file or directory sh-3.1# gunzip PollinHDD.tar.gz sh-3.1# ls -la drwxr-xr-x 3 root root 4096 Dec 31 17:20 . drwxrwxrwt 4 root root 200 Dec 31 17:11 .. -rw-r--r-- 1 root root 101079040 Dec 31 17:16 PollinHDD.tar drwx------ 2 root root 16384 Dec 31 17:04 lost+found sh-3.1# busybox tar xf PollinHDD.tar sh-3.1# ls -la drwxr-xr-x 26 root root 4096 Dec 31 17:20 . drwxrwxrwt 4 root root 200 Dec 31 17:11 .. -rw-r--r-- 1 root root 101079040 Dec 31 17:16 PollinHDD.tar drwxr-xr-x 2 root root 4096 Dec 31 17:20 bin drwxr-xr-x 2 root root 4096 Dec 31 17:20 boot drwxr-xr-x 3 root root 4096 Dec 31 17:20 config drwxr-xr-x 4 root root 4096 Dec 31 17:20 config.defaults drwxr-xr-x 3 root root 4096 Dec 31 17:20 config.firmware drwxr-xr-x 3 root root 4096 Dec 31 17:20 config.templates drwxr-xr-x 3 root root 4096 Dec 31 17:20 dev drwxr-xr-x 8 root root 4096 Dec 31 17:20 etc drwxr-xr-x 3 root root 4096 Dec 31 17:20 home drwxr-xr-x 5 root root 4096 Dec 31 17:20 lib drwx------ 2 root root 16384 Jun 19 2011 lost+found drwxr-xr-x 2 root root 4096 Dec 31 17:20 media drwxr-xr-x 3 root root 4096 Dec 31 17:20 mnt drwxr-xr-x 5 root root 4096 Dec 31 17:20 opt drwxr-xr-x 2 root root 4096 Dec 31 17:20 proc drwxr-xr-x 3 root root 4096 Dec 31 17:20 profile drwxr-xr-x 2 root root 4096 Dec 31 17:20 samba drwxr-xr-x 2 root root 4096 Dec 31 17:20 sbin drwxr-xr-x 2 root root 4096 Dec 31 17:20 share drwxr-xr-x 2 root root 4096 Dec 31 17:20 sys drwxr-xr-x 2 root root 4096 Dec 31 17:20 tmp drwxr-xr-x 2 root root 4096 Dec 31 17:20 usb drwxr-xr-x 10 root root 4096 Dec 31 17:20 usr drwxr-xr-x 3 root root 4096 Dec 31 17:20 var sh-3.1# rm PollinHDD.tar ----------------------------------------------------------------------- Boot Linux-Image (kernel NAND, rootfs /dev/sda2 ----------------------------------------------------------------------- FlashReader V1.0.2.1, built Sep 4 2006 22:24:11 with ECC Bootscript version 0x00130001 Hynix, 8bit, 64MB U-Boot 2008.10-very-dirty (Jun 19 2011 - 16:21:27) NAND Adress is: 0xb0000000 NAND ID: 0x000076ad Prepare USB DRAM: 128 MB Using default environment I2C: Bus #0, at 0xBBE45000 I2C: Bus #1, at 0xBBE46000 I2C: Bus #2, at 0xBBE4C000 I2C: Bus #3, at 0xBBE69000 In: serial Out: serial Err: serial NAND: 0 MiB Model: ST3200822AS Firm: 3.01 Ser#: 4LJ0DF2V Type: Hard Disk Capacity: 190782.2 MB = 186.3 GB (390721968 x 512) Model: Firm: Ser#: Type: Hard Disk Capacity: not available Net: dp83815#0 Hit any key to stop autoboot: 0 ## Booting kernel from Legacy Image at 81500000 ... Image Name: PNX8xxx-MIPS-Linux Created: 2011-06-19 14:33:54 UTC Image Type: MIPS Linux Kernel Image (uncompressed) Data Size: 3566568 Bytes = 3.4 MB Load Address: 80060000 Entry Point: 803a9000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... ~~~~~~~~~~~~~ Linux Console ~~~~~~~~~~~~~~~~~~~~~ Determined physical RAM map: memory: 08000000 @ 00000000 (usable) Kernel command line: console=ttyS1,38400n8 kgdb=ttyS0 noinitrd root=/dev/sda2 rw ip=bootp Synthesized TLB refill handler (34 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). Linux version 2.6.21.3PNX8550 (root@dell) (gcc version 3.4.6) #1 Sun Jun 19 16:33:18 CEST 2011 Determined physical RAM map: memory: 08000000 @ 00000000 (usable) Kernel command line: console=ttyS1,38400n8 kgdb=ttyS0 noinitrd root=/dev/sda2 rw ip=bootp Synthesized TLB refill handler (34 instructions). Synthesized TLB load handler fastpath (32 instructions). Synthesized TLB store handler fastpath (32 instructions). Synthesized TLB modify handler fastpath (31 instructions). Memory: 125824k/131072k available (2856k kernel code, 5108k reserved, 503k data, 120k init, 0k highmem) NET: Registered protocol family 16 registering PCI controller with io_map_base unset Generic PHY: Registered new driver SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Time: MIPS clocksource has been installed. NET: Registered protocol family 2 TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered NTFS driver 2.1.28 [Flags: R/O]. io scheduler noop registered io scheduler anticipatory registered (default) tridentfb: Trident framebuffer 0.7.8-NEWAPI initializing Serial: PNX8XXX driver $Revision: 1.2 $ pnx8xxx-uart: ttyS0 at MMIO 0xbbe4a000 (irq = 27) is a PNX8XXX pnx8xxx-uart: ttyS1 at MMIO 0xbbe4b000 (irq = 28) is a PNX8XXX loop: loaded (max 8 devices) natsemi dp8381x driver, version 2.1, Sept 11, 2006 originally by Donald Becker http://www.scyld.com/network/natsemi.html 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder natsemi eth0: NatSemi DP8381[56] at 0x20092000 (0000:00:0a.0), 00:18:f3:79:a4:94, IRQ 55, port TP. QS6612: Registered new driver SMSC LAN83C185: Registered new driver Broadcom BCM5411: Registered new driver Broadcom BCM5421: Registered new driver Broadcom BCM5461: Registered new driver Linux video capture interface: v2.00 sata_sil 0000:00:08.0: Applying R_ERR on DMA activate FIS errata fix ata1: SATA max UDMA/100 cmd 0xc0016080 ctl 0xc001608a bmdma 0xc0016000 irq 55 ata2: SATA max UDMA/100 cmd 0xc00160c0 ctl 0xc00160ca bmdma 0xc0016008 irq 55 scsi0 : sata_sil ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) ata1.00: ATA-6: ST3200822AS, 3.01, max UDMA/133 ata1.00: 390721968 sectors, multi 0: LBA48 ata1.00: configured for UDMA/100 scsi1 : sata_sil ata2: SATA link down (SStatus 0 SControl 310) scsi 0:0:0:0: Direct-Access ATA ST3200822AS 3.01 PQ: 0 ANSI: 5 SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB) sda: Write Protect is off SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB) sda: Write Protect is off SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sda2 sda3 sda4 sd 0:0:0:0: Attached scsi disk sda video1394: Installed video1394 module NOTE: The dv1394 driver is unsupported and may be removed in a future Linux release. Use raw1394 instead. ehci_hcd 0000:00:09.2: EHCI Host Controller ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1 ehci_hcd 0000:00:09.2: irq 55, io mem 0x20093200 ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95, driver 10 Dec 2004 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 4 ports detected pnx8550-ohci pnx8550-ohci: PNX8550 OHCI pnx8550-ohci pnx8550-ohci: new USB bus registered, assigned bus number 2 pnx8550-ohci pnx8550-ohci: irq 13, io mem 0x1be48000 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected ohci_hcd 0000:00:09.0: OHCI Host Controller ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 3 ohci_hcd 0000:00:09.0: irq 55, io mem 0x20090000 usb usb3: configuration #1 chosen from 1 choice hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected ohci_hcd 0000:00:09.1: OHCI Host Controller ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 4 ohci_hcd 0000:00:09.1: irq 55, io mem 0x20091000 usb usb4: configuration #1 chosen from 1 choice hub 4-0:1.0: USB hub found hub 4-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. input: Roku Pandora2 input device as /class/input/input0 input: Roku Pandora2 output device as /class/input/input1 i2c /dev entries driver TCP cubic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 120k freed Start console /etc/init.d/S02devices BusyBox v1.2.2 (2010.04.14-04:06+0000) Built-in shell (ash) Enter 'help' for a list of built-in commands. (none) / # ----------------------------------------------------------------------- manuelles durchtickern der init-Scripte Linux-Image ----------------------------------------------------------------------- (none) init.d # ls S02devices S18command S50starttm S94pvr S05loglevel S18timezone S60posttmmodules S95stbMainApp S10ramdisk S19network S70servers S97userfs.bg S15logd.sh S20luddite S80autofs rcH S16network S30pretmmodules S80rootapp rcS S17configfs S40udev.sh S93local (none) init.d # ./S02devices start Creating device nodes...done (none) init.d # ./S05loglevel start Set log level... (none) init.d # ./S10ramdisk start Setting up /tmp... done (none) init.d # ./S15logd.sh start Starting logging daemons...done (none) init.d # ./S16network start Setting up network...done (none) init.d # ./S17configfs Usage: ./S17configfs {start|stop} (none) init.d # ./S17configfs start Mounting config fs... du: /config/debug/: No such file or directory done (none) init.d # ./S18command start Starting command server... - done (none) init.d # ./S18timezone start Setting up timezone... done (none) init.d # ./S19network start ./S19network: .: 10: Can't open /config/settings.conf (none) init.d # ./S20luddite start Loading luddite (256M_NOIP)... lud-core lud-pnx8550 phStbDspInfophStbDspInfo: module license 'Proprietary' taints kernel. done (none) init.d # ./S30pretmmodules start Loading pre-TM modules... fusionfusion: unable to get major 252 insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/extra/fusion.ko': Input/output error (-1): Input/output error modprobe: failed to load module fusion mmio i2c3203 i2c0105 tda1004xtda1004x: exports duplicate symbol tda10046_attach (owned by kernel) insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/tda1004x.ko': Invalid module format (-1): Exec format error modprobe: failed to load module tda1004x tda10021tda10021: exports duplicate symbol tda10021_attach (owned by kernel) insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/tda10021.ko': Invalid module format (-1): Exec format error modprobe: failed to load module tda10021 tda10048 stv0297stv0297: exports duplicate symbol stv0297_attach (owned by kernel) insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/stv0297.ko': Invalid module format (-1): Exec format error modprobe: failed to load module stv0297 demux dvbtda1004x: exports duplicate symbol tda10046_attach (owned by kernel) insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/tstv0297: exports duplicate symbol stv0297_attach (owned by kernel) da1004x.ko': Invalid module format (-1): Exec format error insmod: cannot insertda10021: exports duplicate symbol tda10021_attach (owned by kernel) t `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/stv0297.ko': Invalid module format (-1): Exec format error insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/kernel/drivers/media/dvb/frontends/tda10021.ko': Invalid module format (-1): Exec format error ak470 saa8510 tda9983 output_mode: PAL-RGB denc21 phStbRpc phStbDP phStbRTC phStbGpio phStbAudio snd phStbDrawdone (none) init.d # ./S40udev.sh start Populating /dev using udev: RESTORE GPIO12 done (none) init.d # ./S60posttmmodules start Loading post-TM modules...StbRpc Warning: phStbRpc_Xfer_Create: handler=0-VideoRenderer lud_get_node_link("rpc0-4") failed Assertion! err == 0: /opt/philips/sp7.2/stb810-SP7.2/src/project/streamSystem/comps/phStbVideoRenderer/src/kmodule/phStbVideoRenderer_Host.c:113: **ERROR: phStbRpc_ProxyInit => 0x88226801 Break instruction in kernel code[#1]: Cpu 0 $ 0 : 00000000 10008400 000000c3 80390000 $ 4 : 8038829c 00000001 00000001 00000000 $ 8 : 8038829c 00004001 803d0000 803d0000 $12 : 803d0000 fffffff9 0000000a ffffffff $16 : c0200000 87966146 00000000 00000000 $20 : 00000000 00000007 878a5e38 878a5e30 $24 : 00000000 00000002 $28 : 878a4000 878a5d60 00000024 c019d3cc Hi : 00000000 Lo : 00000e80 epc : c019d3cc Tainted: P ra : c019d3cc Status: 10008403 KERNEL EXL IE Cause : 10800024 PrId : 00061200 Modules linked in: phStbVideoRenderer(P) phStbVideoRenderer_Layer(P) phStbStreamingSystem(P) phStbDraw(P) snd_pcm_oss snd_mixer_oss phStbAudio(P) snd_pcm snd_timer snd soundcore snd_page_alloc phStbGpio phStbRTC phStbDP(P) phStbRpc phStbDbg denc2l(P) tda9983(P) saa8510(P) ak470x(P) analog_backend phStbDemux_dvbpnx8550 td1316_mk2(P) phStbDemux_dvbDemuxPnx8550(P) stv0297_tuner(P) phStbDemux_pnx8550(P) phStbDspMem(P) tda10048 i2c_algo_IP0105 i2c_algo_IP3203 phStbMmio phStbDspInfo(P) phStbProc lud_pnx8550 lud_core Process exe (pid: 570, threadinfo=878a4000, task=803e7000) Stack : c01f8b30 c01f8b34 c01f8b40 00000071 87a7bc00 87966146 c01f70c8 c01f7084 00000000 88226801 00000001 00000000 87966131 c01f7dbc c01f9274 00000004 00000000 c01f8fd0 fffffffc 801a4f68 fffffffc 801a4f68 803d0000 87b4af00 803d0000 80116d20 803d0000 80116d20 c01f86e0 80000006 00000160 80000008 00008124 87b4af00 00000000 c01f90e8 80116f20 00000000 c01f9278 00000005 00000002 c01f8fd8 c01fb8d0 c01fb564 00000004 c01f82ec 87b4e600 878a5d88 87966131 87966146 00000000 00000000 87bfbd00 87ee4c80 00000001 00000000 00000000 c020a000 87bfbd00 800c8c84 c01f90f0 00000000 00000000 00000000 00000000 0000000a c01f9100 80390000 c01f9100 c020e774 00000000 c020a000 00000126 00000000 00000126 800a9408 00000000 00000000 00000000 00000000 00000000 00000000 c01f1580 00000000 c0040fe0 00000000 87966100 c0211d44 00000019 0000001a 0000000c 00000000 00000008 00000011 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000044 00000000 00000003 1000d050 0000932f 7fd52d32 7fd52c54 00000006 00000006 00000003 2ad9a770 8006a580 004929fc 10014118 7ff0ac80 81010100 00000000 1000aa30 00000000 00000000 00000fa0 00000020 2aabf000 0000932f 1000d050 00000003 2aabdd40 2aafdcb8 00000000 00000001 00000000 2aab41a0 000007cd 0043cf70 00000003 1000d050 0000932f 7fd52d32 7fd52c54 00000006 00000006 00000003 00000246 2acec13c 00000003 00000000 2ada12e0 7fd52ac8 2ad9a770 0043cfa8 00008413 00000151 000001d1 2acec37c 10800020 2acec150 ... Call Trace:[][][][<801a4f68>][<801a4f68>][<80116d20>][<80116d20>][<80116f20>][][][<800c8c84>][<800a9408>][<8006a580>] Code: 24424cc4 0040f809 afa80010 <0200000d> 8fbf0018 03e00008 27bd0020 27bdffd0 3c02801b kobject phStbFBRead: registering. parent: , set: module kobject holders: registering. parent: phStbFBRead, set: kobject_uevent_env kobject filter function caused the event to drop! kobject_uevent_env fill_kobj_path: path = '/module/phStbFBRead' FBRead Driver (Aug 13 2007-11:59:46) phStbFB: Unknown symbol phStbVideoRenderer_GetZOrder phStbFB: Unknown symbol phStbVideoRenderer_GetVideoLayerResource phStbFB: Unknown symbol phStbVideoRenderer_GetOutputResolution phStbFB: Unknown symbol phStbVideoRenderer_GetInstance insmod: cannot insert `/lib/modules/2.6.21.3PNX8550/extra/phStbFB.ko': Unknown symbol in module (-1): No such file or directory modprobe: failed to load module phStbFB kobject phStbDspPipe: registering. parent: , set: module kobject holders: registering. parent: phStbDspPipe, set: kobject_uevent_env kobject filter function caused the event to drop! kobject_uevent_env fill_kobj_path: path = '/module/phStbDspPipe' DSP Pipe driver Init subsystem dsppipe: registering kobject dsppipe: registering. parent: , set: class kobject dsppipe0: registering. parent: dsppipe, set: class_obj kobject_uevent_env fill_kobj_path: path = '/class/dsppipe/dsppipe0' kobject dsppipe1: registering. parent: dsppipe, set: class_obj kobject_uevent_env fill_kobj_path: path = '/class/dsppipe/dsppipe1' kobject dsppipe2: registering. parent: dsppipe, set: class_obj kobject_uevent_env fill_kobj_path: path = '/class/dsppipe/dsppipe2' done (none) init.d # ./S70servers start Starting network servers...telnetd httpd - done (none) init.d # ./S80autofs Usage: ./S80autofs {start|stop} (none) init.d # ./S80autofs start Starting autofs...usb samba - done (none) init.d # ./S93local start StandbyMicro grep: /etc/display.mode: No such file or directory grep: /etc/display.mode: No such file or directory Starting USB Mouse Services Reset STATE flag to indicate that we've booted successfully... Failed to read hw config done Reset UPFLAG so updater uses default timeout... Failed to read hw config done Start PC/SC daemon... done Updating time Init crontab... Start cron... /usr/sbin/ntpupdater: .: 7: Can't open /config/settings.conf done cp: /config/persist.log: No such file or directory (none) init.d # ./S94pvr start Starting StbPvr...- done (none) init.d # ./S97userfs.bg start Mounting user fs... Starting userfs RC scripts... Setting up config fs... done /usr/local/etc/init.d/S90dhcpd: .: 4: Can't open /config/settings.conf /usr/local/etc/init.d/S93wifi: .: 6: Can't open /config/settings.conf /usr/local/etc/init.d/S94xworks: .: 11: Can't open /config/settings.conf Starting snmpd... failed: community password is not set. Use "hwconfigManager l -1 COMMPWD " done boot finished ----------------------------------------------------------------------- Linux-Image Verzeichnisse nur /dev ----------------------------------------------------------------------- (none) init.d # ls /dev MAKEDEV loop7 tty14 tty57 ak470x luddite tty15 tty58 audio mem tty16 tty59 bus mixer tty17 tty6 console mmio tty18 tty60 disk null tty19 tty61 dsp phdbg tty2 tty62 dspmem phrpc tty20 tty63 dsppipe0 pnxdraw tty21 tty7 dsppipe1 port tty22 tty8 dsppipe2 ptmx tty23 tty9 dvb pts tty24 ttyS0 event0 ram0 tty25 ttyS1 event1 ram1 tty26 urandom fd ram10 tty27 usbdev1.1 full ram11 tty28 usbdev1.1_ep00 gpio0 ram12 tty29 usbdev1.1_ep81 gpio1 ram13 tty3 usbdev2.1 gpio10 ram14 tty30 usbdev2.1_ep00 gpio11 ram15 tty31 usbdev2.1_ep81 gpio12 ram2 tty32 usbdev3.1 gpio13 ram3 tty33 usbdev3.1_ep00 gpio14 ram4 tty34 usbdev3.1_ep81 gpio15 ram5 tty35 usbdev4.1 gpio2 ram6 tty36 usbdev4.1_ep00 gpio3 ram7 tty37 usbdev4.1_ep81 gpio4 ram8 tty38 vcs gpio5 ram9 tty39 vcsa gpio6 random tty4 vdenc gpio7 root tty40 wlan gpio8 rtc tty41 wlan0 gpio9 saa8510 tty42 wlan1 i2c-0 sda tty43 wlan10 i2c-1 sda1 tty44 wlan11 i2c-2 sda2 tty45 wlan12 i2c-3 sda3 tty46 wlan13 input sda4 tty47 wlan14 kmem shm tty48 wlan15 kmsg snd tty49 wlan2 log standby tty5 wlan3 loop0 tty tty50 wlan4 loop1 tty0 tty51 wlan5 loop2 tty1 tty52 wlan6 loop3 tty10 tty53 wlan7 loop4 tty11 tty54 wlan8 loop5 tty12 tty55 wlan9 loop6 tty13 tty56 zero (none) init.d # cat /proc/devices Character devices: 1 mem 4 /dev/vc/0 4 tty 5 /dev/tty 5 /dev/console 5 /dev/ptmx 7 vcs 10 misc 13 input 14 sound 29 fb 38 luddite 81 video4linux 89 i2c 116 alsa 128 ptm 136 pts 171 ieee1394 180 usb 189 usb_device 204 ttyS 212 DVB 245 dsppipe 246 gpio 247 phrpc 248 phdbg 249 saa8510 250 ak470x 251 mmio 252 usb_endpoint 253 vdenc 254 pcmcia Block devices: 1 ramdisk 7 loop 8 sd 65 sd 66 sd 67 sd 68 sd 69 sd 70 sd 71 sd 128 sd 129 sd 130 sd 131 sd 132 sd 133 sd 134 sd 135 sd (none) init.d # cat /proc/asound/devices 0: [ 0] : control 16: [ 0- 0]: digital audio playback 24: [ 0- 0]: digital audio capture 33: : timer (none) init.d # df -h Filesystem Size Used Available Use% Mounted on /dev/root 3.8G 106.8M 3.5G 3% / tmpfs 61.6M 156.0k 61.4M 0% /tmp tmpfs 61.6M 156.0k 61.4M 0% /dev tmpfs 61.6M 0 61.6M 0% /dev/shm tmpfs 61.6M 156.0k 61.4M 0% /var tmpfs 61.6M 156.0k 61.4M 0% /usr/tmp /dev/sda3 3.8G 7.6M 3.6G 0% /mnt/hd1 (none) init.d # mount /dev/root on / type ext2 (rw) sysfs on /sys type sysfs (rw) proc on /proc type proc (rw) devpts on /dev/pts type devpts (rw) tmpfs on /tmp type tmpfs (rw) none on /proc/bus/usb type usbfs (rw) tmpfs on /dev type tmpfs (rw) devpts on /dev/pts type devpts (rw) tmpfs on /dev/shm type tmpfs (rw) tmpfs on /var type tmpfs (rw) tmpfs on /usr/tmp type tmpfs (rw) automount(pid605) on /usb type autofs (rw,fd=6,pgrp=605,timeout=10,minproto=2,maxproto=4,indirect) automount(pid612) on /samba type autofs (rw,fd=5,pgrp=612,timeout=10,minproto=2,maxproto=4,indirect) /dev/sda3 on /mnt/hd1 type ext2 (rw) (none) init.d # ls /mnt/hd1/ lost+found (none) init.d #
