Version 4 SHEET 1 3012 2060 WIRE -48 -112 -48 -144 WIRE -784 -32 -848 -32 WIRE -720 -32 -784 -32 WIRE -624 -32 -720 -32 WIRE -512 -32 -544 -32 WIRE -352 -32 -512 -32 WIRE -256 -32 -288 -32 WIRE -160 -32 -256 -32 WIRE -1344 -16 -1584 -16 WIRE -960 -16 -1120 -16 WIRE -720 -16 -720 -32 WIRE -48 16 -48 -32 WIRE -512 32 -512 -32 WIRE -384 32 -512 32 WIRE -336 32 -384 32 WIRE -256 32 -256 -32 WIRE -512 48 -512 32 WIRE -256 48 -256 32 WIRE -1008 64 -1584 64 WIRE -960 64 -1008 64 WIRE -560 64 -624 64 WIRE -384 80 -384 32 WIRE -336 80 -336 32 WIRE -160 80 -160 -32 WIRE -560 112 -608 112 WIRE -1008 128 -1008 64 WIRE -512 192 -512 128 WIRE -384 192 -384 144 WIRE -384 192 -512 192 WIRE -336 192 -336 144 WIRE -336 192 -384 192 WIRE -512 208 -512 192 WIRE -848 304 -848 80 WIRE -720 304 -720 48 WIRE -720 304 -848 304 WIRE -640 304 -720 304 WIRE -512 304 -512 288 WIRE -512 304 -640 304 WIRE -256 304 -256 112 WIRE -256 304 -512 304 WIRE -160 304 -160 160 WIRE -160 304 -256 304 WIRE 528 480 416 480 WIRE -96 496 -176 496 WIRE 528 512 528 480 WIRE -96 528 -96 496 WIRE 416 624 416 480 WIRE 528 624 528 592 WIRE -176 640 -176 496 WIRE -96 640 -96 608 WIRE 96 688 -32 688 WIRE 176 688 160 688 WIRE -176 752 -176 720 WIRE -32 752 -32 688 WIRE -32 752 -176 752 WIRE 32 752 -32 752 WIRE 176 768 176 688 WIRE 176 768 96 768 WIRE 208 768 176 768 WIRE 416 768 416 704 WIRE 416 768 336 768 WIRE 32 784 -32 784 WIRE 416 800 416 768 WIRE -176 816 -176 752 WIRE -32 848 -32 784 WIRE -1872 880 -1872 848 WIRE -1616 880 -1680 880 WIRE 272 896 272 848 WIRE -1360 912 -1408 912 WIRE -1616 944 -1664 944 WIRE -176 960 -176 896 WIRE 416 960 416 880 WIRE -1872 1008 -1872 960 WIRE 80 1104 -112 1104 WIRE 208 1104 144 1104 WIRE 288 1104 272 1104 WIRE 336 1104 288 1104 WIRE 496 1104 432 1104 WIRE 80 1136 16 1136 WIRE 208 1152 208 1104 WIRE 336 1152 208 1152 WIRE -352 1168 -352 1104 WIRE -112 1168 -112 1104 WIRE -352 1280 -352 1248 WIRE -112 1280 -112 1248 FLAG -1872 848 Td IOPIN -1872 848 Out FLAG -1680 880 Td IOPIN -1680 880 In FLAG -1664 944 trig IOPIN -1664 944 In FLAG -1008 128 0 FLAG -624 64 0 FLAG -608 112 mos IOPIN -608 112 In FLAG -256 32 ZK FLAG -1872 1008 0 FLAG -176 960 0 FLAG 416 960 0 FLAG -32 848 ref FLAG 208 768 reg FLAG 336 768 ac FLAG 272 976 0 FLAG 272 848 res FLAG -112 1280 0 FLAG -512 192 sh FLAG 16 1136 res FLAG -352 1280 0 FLAG -352 1104 ref FLAG 288 1104 trig FLAG -640 304 GNDdc FLAG -96 640 0 FLAG -784 -32 ctrl FLAG 528 624 0 FLAG 496 1104 mos FLAG -48 16 0 FLAG -48 -144 trig IOPIN -48 -144 Out SYMBOL voltage -1584 -32 R0 WINDOW 3 -47 -16 VRight 0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR Value SINE(0 325.269 50 0 0 0 0) SYMATTR InstName V1 SYMBOL rect -832 48 R0 SYMATTR InstName X2 SYMBOL ind -640 -16 R270 WINDOW 0 32 56 VTop 0 WINDOW 3 5 56 VBottom 0 SYMATTR InstName L1 SYMATTR Value 174µ SYMBOL cap -736 -16 R0 SYMATTR InstName C2 SYMATTR Value 5µ SYMBOL cap -272 48 R0 SYMATTR InstName C3 SYMATTR Value 0.4m SYMBOL res -176 64 R0 SYMATTR InstName R1 SYMATTR Value 250 SYMBOL pwm -1376 896 R0 SYMATTR InstName X1 SYMBOL voltage -1872 864 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName Td SYMATTR Value 0.47 SYMBOL sw -512 32 R0 SYMATTR InstName S1 SYMATTR Value Mos SYMBOL diode -352 -16 R270 WINDOW 0 32 32 VTop 0 WINDOW 3 0 32 VBottom 0 SYMATTR InstName D1 SYMBOL LISN -1232 -16 R0 SYMATTR InstName EN6100047 SYMBOL Misc\\EuropeanResistor -192 624 R0 SYMATTR InstName R2 SYMATTR Value 50k SYMBOL Misc\\EuropeanResistor -192 800 R0 SYMATTR InstName R3 SYMATTR Value 251.256 SYMBOL Misc\\EuropeanResistor 400 608 R0 WINDOW 0 -76 38 Left 0 WINDOW 3 -131 78 Left 0 SYMATTR InstName R4 SYMATTR Value 324.2691k SYMBOL Misc\\EuropeanResistor 400 784 R0 WINDOW 0 -29 36 Left 0 WINDOW 3 -34 81 Left 0 SYMATTR InstName R5 SYMATTR Value 1k SYMBOL ampsimp 64 768 R0 SYMATTR InstName U1 SYMBOL cap 160 672 R90 WINDOW 0 0 32 VBottom 0 WINDOW 3 32 32 VTop 0 SYMATTR InstName C4 SYMATTR Value 1.5e-5 SYMBOL bv 272 880 R0 WINDOW 3 -89 136 Left 0 SYMATTR Value V=V(reg)*V(ac)*.25 SYMATTR InstName B1 SYMBOL Misc\\EuropeanResistor -528 192 R0 SYMATTR InstName R6 SYMATTR Value 0.001 SYMBOL Digital\\diffschmitt 80 1056 R0 SYMATTR InstName A1 SYMATTR SpiceLine Vt=0 Vh=0.1m Vhigh=1 Vlow=0 SYMATTR SpiceLine2 Td=1n SYMBOL bv -112 1152 R0 WINDOW 3 -87 170 Left 0 SYMATTR Value V=V(sh,GNDdc)*109.289 SYMATTR InstName B2 SYMBOL voltage -352 1152 R0 WINDOW 123 0 0 Left 0 WINDOW 39 0 0 Left 0 SYMATTR InstName V2 SYMATTR Value 2 SYMBOL Digital\\srflop 384 1056 R0 SYMATTR InstName A2 SYMBOL bv -96 512 R0 WINDOW 3 44 52 Left 0 SYMATTR Value V=V(ZK,GNDdc) SYMATTR InstName B3 SYMBOL bv 528 496 R0 WINDOW 3 44 52 Left 0 SYMATTR Value V=V(ctrl,GNDdc) SYMATTR InstName B4 SYMBOL bv -48 -128 R0 WINDOW 3 -63 181 Left 0 SYMATTR Value V=inv(500*I(L1)) SYMATTR InstName ZCD1 SYMATTR Prefix BV SYMBOL diode -368 144 R180 WINDOW 0 24 72 Left 0 WINDOW 3 24 0 Left 0 SYMATTR InstName D3 SYMBOL cap -352 80 R0 SYMATTR InstName C1 SYMATTR Value 1n TEXT -992 -280 Left 0 !.tran 0 500m 0 TEXT -832 -256 Left 0 !.model D1 D(Ron=.02 Roff=1Meg Vfwd=.7)\n.model D3 D(Ron=0.1 Roff=1Meg Vfwd=.7)\n.model Mos SW(Ron=.02 Roff=1Meg Vt=0.01) TEXT -1032 -184 Left 0 !.ic V(zk)=370 TEXT -216 624 VRight 0 ;400 V is equivalent to 2V TEXT 464 1072 VLeft 0 ;peak Value of input voltage is same as 1V TEXT -1928 752 Left 0 ;*********************manual Mode, no feedback*************************** TEXT -1920 1064 Left 0 ;Am Ausgang des Monoflops die Line "out" mit einem Label versehen. Name des Labels: "mos"\nWenn out mit "mos" gelabelt ist, bekommt der Schalter S1 über das Monoflop eine konstante \nEinschaltzeit vorgeben. Manueller Betrieb, da keine Rückführung vorhanden ist. TEXT -408 352 Left 0 ;************************************** Peak current control mode******************************** TEXT -320 384 Left 0 ;B3 und B4 bilden das Potential am Zwischenkreis nach. Die B-quellen sind nötig,\nda bei einem Label das potential durch den Gleichrichter gegen Masse geht. Mit \ndem Differenzpotential V(ZK,GNDdc) kann man das Potential korrekt über der Masse abbilden. TEXT -464 1368 Left 0 ;Spannungsteiler:\nR2,R3 bilden eine Spannung nach, in der 400V 2V entspricht. Dementsprechend ist dann \nV2 mit 2V als Referenzeingang dimensioniert. Außerdem stelle ich noch die initial condition der \nZwischenkreisspannung auf 400V.\n \nSpannungsteiler R4, R5: Der Spannungsteiler wird dazu benötigt, um die korrekte Stromform zu erzeugen.\nDemnach ist dieser Spannungsteiler auf 1V entspricht Scheiteilwert der Netzspannung normiert.\n \nI-Regler: \nIch dachte erst an einen I-regler, da die Strecke einen Pol und eine Nullstelle besitzt, kann ich die \nReglerverstärkung so einstellen, dass mein Regelkreis eine Frequenz von ca. 10-30Hz aufweist. In Sisotool\nentspricht das allerdings einer geringen Dämpfung.\n \nMulitplikator B1: Dieser Multiplikator gibt die Stromform über die Netzperiode vor\n \nSchmitt Trigger A1:\n Der Schmitttrigger wird eig. nur als Komparator benutzt, um den\nStrom in Subinterval 1 mit dem Sollstrom (vorgegeben durch den Multiplizierer)\nzu vergleichen. Ist der Strom im Shunt höher, wird das FF zurückgesetzt.\n \nSR FF: Jede Schaltperiode wird durch den Zero Current detector (B-quelle ZCD) eröffnet und durch \nden Schmitt Trigger wieder zurückgesetzt TEXT 552 696 Left 0 ;Für die Regelung:\nTransferfunction von control-to-output berechnet. \nSteht im BCMcontrol.pdf Formel 9 mit Werten von Tabelle II. TEXT 488 16 Left 0 ;Annahmen:\nBei 380 V und 200 A Strom von 1.9A. Wg. Mittelung der Dreiecke muss also am Sinusmaximum TEXT -168 -272 Left 0 ;*******Zero Current Detector*********\nnecessary for both modes TEXT 552 792 Left 0 ;Pol im OP ist sozusagen filter, dass die 100 Hz nicht ausgeregtelt werden
