BUILD: [01:0000000079:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xiosbase(198) : error C2470: 'ios_base' : looks like a function definition, but there is no parameter list; skipping apparent body BUILD: [01:0000000080:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(44) : error C2143: syntax error : missing ';' before '~' BUILD: [01:0000000082:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(44) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000083:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(55) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000084:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(55) : error C2061: syntax error : identifier 'seekdir' BUILD: [01:0000000085:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(61) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000086:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(61) : error C2061: syntax error : identifier 'seek_dir' BUILD: [01:0000000087:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(63) : error C2535: '_Traits::pos_type std::basic_streambuf<_Elem,_Traits>::pubseekoff(_Traits::off_type)' : member function already defined or declared BUILD: [01:0000000089:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(69) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000090:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(69) : error C2061: syntax error : identifier 'openmode' BUILD: [01:0000000091:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(74) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000092:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(74) : error C2061: syntax error : identifier 'open_mode' BUILD: [01:0000000093:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(75) : error C2535: '_Traits::pos_type std::basic_streambuf<_Elem,_Traits>::pubseekpos(_Traits::pos_type)' : member function already defined or declared BUILD: [01:0000000095:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(79) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000096:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(99) : error C2146: syntax error : missing ';' before identifier 'in_avail' BUILD: [01:0000000097:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(103) : warning C4183: 'in_avail': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000098:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(122) : error C2146: syntax error : missing ';' before identifier '_Sgetn_s' BUILD: [01:0000000099:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(122) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000100:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(125) : warning C4183: '_Sgetn_s': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000101:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(128) : error C2146: syntax error : missing ';' before identifier 'streamsize' BUILD: [01:0000000102:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(128) : error C2146: syntax error : missing ';' before identifier 'sgetn' BUILD: [01:0000000103:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(128) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000104:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(134) : warning C4183: 'sgetn': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000105:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(173) : error C2146: syntax error : missing ';' before identifier 'sputn' BUILD: [01:0000000106:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(173) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000107:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(176) : warning C4183: 'sputn': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000108:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(251) : error C2146: syntax error : missing ';' before identifier '_Gnavail' BUILD: [01:0000000109:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(254) : warning C4183: '_Gnavail': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000110:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(282) : error C2146: syntax error : missing ';' before identifier '_Pnavail' BUILD: [01:0000000111:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(285) : warning C4183: '_Pnavail': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000112:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(303) : error C2146: syntax error : missing ';' before identifier 'overflow' BUILD: [01:0000000113:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(303) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000114:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(306) : warning C4183: 'overflow': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000115:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(308) : error C2146: syntax error : missing ';' before identifier 'pbackfail' BUILD: [01:0000000116:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(308) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000117:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(308) : error C2086: '_Traits::int_type std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000119:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(311) : warning C4183: 'pbackfail': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000120:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(313) : error C2146: syntax error : missing ';' before identifier '__CLR_OR_THIS_CALL' BUILD: [01:0000000121:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(313) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::streamsize' : 'virtual' not permitted on data declarations BUILD: [01:0000000122:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(313) : error C2146: syntax error : missing ';' before identifier 'showmanyc' BUILD: [01:0000000123:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(316) : warning C4183: 'showmanyc': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000124:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(318) : error C2146: syntax error : missing ';' before identifier 'underflow' BUILD: [01:0000000125:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(318) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000126:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(318) : error C2086: '_Traits::int_type std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000128:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(321) : warning C4183: 'underflow': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000129:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(323) : error C2146: syntax error : missing ';' before identifier 'uflow' BUILD: [01:0000000130:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(323) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000131:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(323) : error C2086: '_Traits::int_type std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000133:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(327) : warning C4183: 'uflow': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000134:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(330) : error C2144: syntax error : 'int' should be preceded by ';' BUILD: [01:0000000135:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(330) : error C2146: syntax error : missing ';' before identifier '__CLR_OR_THIS_CALL' BUILD: [01:0000000136:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(330) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::streamsize' : 'virtual' not permitted on data declarations BUILD: [01:0000000137:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(330) : error C2146: syntax error : missing ';' before identifier 'xsgetn' BUILD: [01:0000000138:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(331) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000139:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(335) : warning C4183: 'xsgetn': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000140:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(337) : error C2146: syntax error : missing ';' before identifier '__CLR_OR_THIS_CALL' BUILD: [01:0000000141:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(337) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::streamsize' : 'virtual' not permitted on data declarations BUILD: [01:0000000142:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(337) : error C2146: syntax error : missing ';' before identifier '_Xsgetn_s' BUILD: [01:0000000143:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(338) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000144:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(365) : warning C4183: '_Xsgetn_s': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000145:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(367) : error C2146: syntax error : missing ';' before identifier '__CLR_OR_THIS_CALL' BUILD: [01:0000000146:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(367) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::streamsize' : 'virtual' not permitted on data declarations BUILD: [01:0000000147:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(367) : error C2146: syntax error : missing ';' before identifier 'xsputn' BUILD: [01:0000000148:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(368) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000149:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(395) : warning C4183: 'xsputn': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000150:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(397) : error C2146: syntax error : missing ';' before identifier 'seekoff' BUILD: [01:0000000151:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(397) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000152:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(397) : error C2086: '_Traits::int_type std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000154:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(397) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000155:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(397) : error C2061: syntax error : identifier 'seekdir' BUILD: [01:0000000156:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(401) : warning C4183: 'seekoff': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000157:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(403) : error C2146: syntax error : missing ';' before identifier 'seekpos' BUILD: [01:0000000158:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(403) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000159:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(403) : error C2086: '_Traits::int_type std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000161:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(404) : error C2653: 'ios_base' : is not a class or namespace name BUILD: [01:0000000162:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(404) : error C2061: syntax error : identifier 'openmode' BUILD: [01:0000000163:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(407) : warning C4183: 'seekpos': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000164:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(409) : error C2146: syntax error : missing ';' before identifier 'setbuf' BUILD: [01:0000000165:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(409) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000166:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(409) : error C2040: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'std::basic_streambuf<_Elem,_Traits> *' differs in levels of indirection from '_Traits::int_type' BUILD: [01:0000000167:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(409) : error C2061: syntax error : identifier 'streamsize' BUILD: [01:0000000168:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(412) : warning C4183: 'setbuf': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000169:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(414) : error C2146: syntax error : missing ';' before identifier 'sync' BUILD: [01:0000000170:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(414) : error C2433: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : 'virtual' not permitted on data declarations BUILD: [01:0000000171:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(414) : error C2371: 'std::basic_streambuf<_Elem,_Traits>::__CLR_OR_THIS_CALL' : redefinition; different basic types BUILD: [01:0000000173:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(417) : warning C4183: 'sync': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000174:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\streambuf(426) : error C2146: syntax error : missing ';' before identifier '_Mylock' BUILD: [01:0000000175:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(20) : error C2144: syntax error : 'int' should be preceded by ';' BUILD: [01:0000000176:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(22) : error C2144: syntax error : 'long' should be preceded by ';' BUILD: [01:0000000177:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(22) : error C2146: syntax error : missing ';' before identifier '_Stolx' BUILD: [01:0000000178:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(24) : error C2144: syntax error : 'unsigned long' should be preceded by ';' BUILD: [01:0000000179:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(24) : error C2146: syntax error : missing ';' before identifier '_Stoulx' BUILD: [01:0000000180:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(24) : error C2371: '__CLRCALL_PURE_OR_CDECL' : redefinition; different basic types BUILD: [01:0000000182:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(26) : error C2144: syntax error : 'float' should be preceded by ';' BUILD: [01:0000000183:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(26) : error C2146: syntax error : missing ';' before identifier '_Stofx' BUILD: [01:0000000184:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(26) : error C2371: '__CLRCALL_PURE_OR_CDECL' : redefinition; different basic types BUILD: [01:0000000186:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(28) : error C2144: syntax error : 'double' should be preceded by ';' BUILD: [01:0000000187:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(28) : error C2146: syntax error : missing ';' before identifier '_Stodx' BUILD: [01:0000000188:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(28) : error C2371: '__CLRCALL_PURE_OR_CDECL' : redefinition; different basic types BUILD: [01:0000000190:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(30) : error C2144: syntax error : 'long double' should be preceded by ';' BUILD: [01:0000000191:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(30) : error C2146: syntax error : missing ';' before identifier '_Stoldx' BUILD: [01:0000000192:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(30) : error C2371: '__CLRCALL_PURE_OR_CDECL' : redefinition; different basic types BUILD: [01:0000000195:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(123) : error C2144: syntax error : 'float' should be preceded by ';' BUILD: [01:0000000196:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(124) : error C2144: syntax error : 'double' should be preceded by ';' BUILD: [01:0000000197:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(124) : error C2086: 'int _MRTIMP2' : redefinition BUILD: [01:0000000199:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(125) : error C2144: syntax error : 'long double' should be preceded by ';' BUILD: [01:0000000200:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(125) : error C2086: 'int _MRTIMP2' : redefinition BUILD: [01:0000000202:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(198) : error C2146: syntax error : missing ';' before identifier 'decimal_point' BUILD: [01:0000000204:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(201) : warning C4183: 'decimal_point': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000205:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(203) : error C2146: syntax error : missing ';' before identifier 'thousands_sep' BUILD: [01:0000000206:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(203) : error C2086: '_Elem std::numpunct<_Elem>::__CLR_OR_THIS_CALL' : redefinition BUILD: [01:0000000208:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(206) : warning C4183: 'thousands_sep': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000209:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(208) : error C2146: syntax error : missing ';' before identifier 'grouping' BUILD: [01:0000000210:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(208) : error C2371: 'std::numpunct<_Elem>::__CLR_OR_THIS_CALL' : redefinition; different basic types BUILD: [01:0000000212:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(211) : warning C4183: 'grouping': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000213:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(213) : error C2146: syntax error : missing ';' before identifier 'falsename' BUILD: [01:0000000214:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(213) : error C2371: 'std::numpunct<_Elem>::__CLR_OR_THIS_CALL' : redefinition; different basic types BUILD: [01:0000000216:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(216) : warning C4183: 'falsename': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000217:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(218) : error C2146: syntax error : missing ';' before identifier 'truename' BUILD: [01:0000000218:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(218) : error C2371: 'std::numpunct<_Elem>::__CLR_OR_THIS_CALL' : redefinition; different basic types BUILD: [01:0000000220:WARNN ] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(221) : warning C4183: 'truename': missing return type; assumed to be a member function returning 'int' BUILD: [01:0000000221:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(223) : error C2146: syntax error : missing ';' before identifier 'numpunct' BUILD: [01:0000000222:ERRORE] C:\Programme\MicrosoftVisualStudio8\VC\ce\include\xlocnum(223) : fatal error C1003: error count exceeds 100; stopping compilation
