BUILD: [01:0000000037:PROGC ] Linking obj\ARMV4I\retail\TestApp.exe BUILD: [01:0000000055:ERRORE] Test.obj : error LNK2019: unresolved external symbol "private: static void __cdecl std::ios_base::_Ios_base_dtor(class std::ios_base *)" (?_Ios_base_dtor@ios_base@std@@CAXPAV12@@Z) referenced in function "public: virtual __cdecl std::ios_base::~ios_base(void)" (??1ios_base@std@@UAA@XZ) BUILD: [01:0000000056:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: __cdecl std::_Mutex::~_Mutex(void)" (??1_Mutex@std@@QAA@XZ) referenced in function "public: virtual __cdecl std::basic_streambuf >::~basic_streambuf >(void)" (??1?$basic_streambuf@DU?$char_traits@D@std@@@std@@UAA@XZ) BUILD: [01:0000000057:ERRORE] Test.obj : error LNK2019: unresolved external symbol _invalid_parameter_noinfo referenced in function "public: class std::basic_string,class std::allocator > & __cdecl std::vector,class std::allocator >,class std::allocator,class std::allocator > > >::operator[](unsigned int)" (??A?$vector@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$allocator@V?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@2@@std@@QAAAAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@1@I@Z) BUILD: [01:0000000058:ERRORE] Functions.obj : error LNK2001: unresolved external symbol _invalid_parameter_noinfo BUILD: [01:0000000059:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: void __cdecl std::_Mutex::_Unlock(void)" (?_Unlock@_Mutex@std@@QAAXXZ) referenced in function "public: void __cdecl std::basic_streambuf >::_Unlock(void)" (?_Unlock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAAXXZ) BUILD: [01:0000000060:ERRORE] Functions.obj : error LNK2001: unresolved external symbol "public: void __cdecl std::_Mutex::_Unlock(void)" (?_Unlock@_Mutex@std@@QAAXXZ) BUILD: [01:0000000061:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: void __cdecl std::_Mutex::_Lock(void)" (?_Lock@_Mutex@std@@QAAXXZ) referenced in function "public: void __cdecl std::basic_streambuf >::_Lock(void)" (?_Lock@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QAAXXZ) BUILD: [01:0000000062:ERRORE] Functions.obj : error LNK2001: unresolved external symbol "public: void __cdecl std::_Mutex::_Lock(void)" (?_Lock@_Mutex@std@@QAAXXZ) BUILD: [01:0000000063:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ) referenced in function "public: int __cdecl std::basic_string,class std::allocator >::compare(unsigned int,unsigned int,char const *,unsigned int)const " (?compare@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@QBAHIIPBDI@Z) BUILD: [01:0000000064:ERRORE] Functions.obj : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xran(void)" (?_Xran@_String_base@std@@SAXXZ) BUILD: [01:0000000065:ERRORE] Test.obj : error LNK2001: unresolved external symbol "long const std::_BADOFF" (?_BADOFF@std@@3JB) BUILD: [01:0000000066:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: __cdecl std::_Mutex::_Mutex(void)" (??0_Mutex@std@@QAA@XZ) referenced in function "protected: __cdecl std::basic_streambuf >::basic_streambuf >(void)" (??0?$basic_streambuf@DU?$char_traits@D@std@@@std@@IAA@XZ) BUILD: [01:0000000067:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ) referenced in function "protected: bool __cdecl std::basic_string,class std::allocator >::_Grow(unsigned int,bool)" (?_Grow@?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@IAA_NI_N@Z) BUILD: [01:0000000068:ERRORE] Functions.obj : error LNK2001: unresolved external symbol "public: static void __cdecl std::_String_base::_Xlen(void)" (?_Xlen@_String_base@std@@SAXXZ) BUILD: [01:0000000069:ERRORE] Test.obj : error LNK2019: unresolved external symbol _Stoulx referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,unsigned short &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAAG@Z) BUILD: [01:0000000070:ERRORE] Test.obj : error LNK2019: unresolved external symbol _Stolx referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,long &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAAJ@Z) BUILD: [01:0000000071:ERRORE] Test.obj : error LNK2019: unresolved external symbol _strtoi64 referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,__int64 &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAA_J@Z) BUILD: [01:0000000072:ERRORE] Test.obj : error LNK2019: unresolved external symbol _strtoui64 referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,unsigned __int64 &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAA_K@Z) BUILD: [01:0000000073:ERRORE] Test.obj : error LNK2019: unresolved external symbol _Stofx referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,float &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAAM@Z) BUILD: [01:0000000074:ERRORE] Test.obj : error LNK2019: unresolved external symbol _Stodx referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,double &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAAN@Z) BUILD: [01:0000000075:ERRORE] Test.obj : error LNK2019: unresolved external symbol _Stoldx referenced in function "protected: virtual class std::istreambuf_iterator > __cdecl std::num_get > >::do_get(class std::istreambuf_iterator >,class std::istreambuf_iterator >,class std::ios_base &,int &,long double &)const " (?do_get@?$num_get@DV?$istreambuf_iterator@DU?$char_traits@D@std@@@std@@@std@@MBA?AV?$istreambuf_iterator@DU?$char_traits@D@std@@@2@V32@0AAVios_base@2@AAHAAO@Z) BUILD: [01:0000000076:ERRORE] Test.obj : error LNK2019: unresolved external symbol "public: static void __cdecl std::ios_base::_Addstd(class std::ios_base *)" (?_Addstd@ios_base@std@@SAXPAV12@@Z) referenced in function "protected: void __cdecl std::basic_ios >::init(class std::basic_streambuf > *,bool)" (?init@?$basic_ios@DU?$char_traits@D@std@@@std@@IAAXPAV?$basic_streambuf@DU?$char_traits@D@std@@@2@_N@Z) BUILD: [01:0000000077:ERRORE] Test.obj : error LNK2001: unresolved external symbol "class std::basic_ostream > std::cout" (?cout@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A) BUILD: [01:0000000078:ERRORE] Functions.obj : error LNK2001: unresolved external symbol "class std::basic_ostream > std::cout" (?cout@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A) BUILD: [01:0000000079:ERRORE] obj\ARMV4I\retail\TestApp.exe : fatal error LNK1120: 18 unresolved externals BUILD: [01:0000000084:ERRORE] EDITBIN : fatal error LNK1104: cannot open file 'obj\ARMV4I\retail\TestApp.exe'
