000001cf [MSG]: BootMain start
000001ec Jump to fel
00000200 for debug
00000214 BootMain.c
00000220 WRN:L%d(%s):
00000230 ERR: wBoot_get_para failed
0000024c c:\rabbit.bot
00000260 user force to debug mode
00000280 jump to fel because of update file found
000002ac c:\natch.ini
000002c0 unable to malloc memory for bootini
00000380 c:\boot.ini
0000038c unable to parser boot.ini
00000768 BootOS.c
00000774 WRN:L%d(%s):
00000784 logo name is invalid or dont need show logo
000007b4 img file %s base addres is NULL
000007dc open img file %s failed
000007f8 the img file %s length %d is larger than img max size %d
00000b1c melis
00000b28 The all optional count is %d
00000b48 no os to boot
00000b58 only one os to boot
00000b70 do not need delay time
00000b8c fail to show multi pictures
00000bac wait user input
00000bc4 key pressed down
00000bd8 NO OS to Boot
00000be8 test for multi os boot with display
00000c3c jump to
00000de4 ramdisk.iso
0000101c c:\drv_de.drv
0000102c Board.c
00001034 WRN:L%d(%s):
00001044 ERR: wBoot_driver_install display driver failed
00001078 ERR: open display driver failed
0000109c ERR: De Open LCD or TV failed
000010bc ERR: De_RequestLayer failed
000010dc ERR: display driver not open yet
000011f0 fel_detect.c
00001200 WRN:L%d(%s):
00001210 dest file is not exist
000016a4 ui.c
000016ac WRN:L%d(%s):
000016bc ERR: wBoot_malloc failed
000016d8 ERR: Not need to wait LCD open
000016f8 ERR: De_SetLayerPara failed
00001b04 ERR: Parse_Pic_BMP failed
00001b20 multi displya fail: malloc memory for display buffer failed
00001b64 decode %s bmp file failed
000021f4 display_interface.c
00002208 WRN:L%d(%s):
00002218 ERR: display driver not open yet
0000223c ERR: wBoot_driver_ioctl DISP_CMD_SET_BKCOLOR failed
0000227c ERR: LCD not close
00002298 DISPLAY ERROR: HDMI not support mode %d
000022c4 DISPLAY ERROR: CVBS not support mode %d
0000255c DISPLAY ERROR: YPBPR not support mode %d
00002590 DISPLAY ERROR: VGA not support mode %d
000025b8 DISPLAY ERROR: DISPLAY not support mode %d
000025f8 ERR: display driver turn off display device failed
00002634 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_REQUEST failed
00002874 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_RELEASE failed
000028b4 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_OPEN failed
000028f0 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_CLOSE failed
00002930 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_GET_FB failed
00002b90 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_SET_FB failed
00002bd4 ERR: wBoot_driver_ioctl DISP_CMD_LAYER_GET_PARA failed
00002c0c ERR: wBoot_driver_ioctl DISP_CMD_LAYER_SET_PARA failed
00003464 segment
0000346c script_info
00003478 logo_info
00003484 img_name
00003490 img_size
0000349c img_base
000034b0 script_base
000034bc script_size
000034c8 logo_name
000037d8 logo_show
000037e4 logo_address
000037f4 system
000037fc start_os_name
0000380c timeout
00003814 display_device
00003824 display_mode
00003834 os_show[0]
00003a30 script.c
00003a3c WRN:L%d(%s):
00003a4c the input script is empty
00003a6c unable to open script file %s
00003a8c unable to malloc memory for script
00003ab0 script is invalid
000040e8 0123456789ABCDEF
000040fc 0123456789abcdef
000041ef (  R"
00004506 aB@02
00004738 Unknown signal
0000474c Invalid Operation
00004760 Divide By Zero
00004770 Overflow
0000477c Underflow
00004788 Inexact Result
00004798 : Heap memory corrupted
000047e4 Abnormal termination
000047fb Arithmetic exception:
00004812 Illegal instruction
00004829 Interrupt received
00004840 Illegal address
00004857 Termination request
0000486e Stack overflow
00004885 Redirect: can't open:
0000489c Out of heap memory
000048b3 User-defined signal 1
000048ca User-defined signal 2
000048e1 Pure virtual fn called
000048f8 C++ library exception
0000490f Out of heap
00004930 eGon2app
0000496b @ARM
00004980 ARM Linker, RVCT2.2 [Build 349]
000049a1 Input Comments:
000049b2 aeabi_idiv0.o
000049c1 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
000049f0 --schedule --cpu=4 --depend=aeabi_idiv0.d --fpu=none -oaeabi_idiv0.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}"
00004af2 rt_memclr.o
00004aff ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00004b2e --schedule --cpu=4 --depend=rt_memclr.d --fpu=none -ort_memclr.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --pr
00004c30 uread4.o
00004c3a ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00004c69 --schedule --cpu=4 --depend=uread4.d --fpu=none -ouread4.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --predefin
00004d6b strncpy.o
00004d76 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00004da5 --schedule --cpu=4 --depend=strncpy.d --fpu=none -ostrncpy.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi//Ospace -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}"
00004ea7 strcpy.o
00004eb1 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00004edf armcc --arm -c --split_ldm --no_hide_all --no_use_directive_sections -ostrcpy.o --depend=strcpy.d --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --trace=zz --cpu=4 --fpu=none -Ospace --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../ -I../../angel -I../../public -J../../stdh -Dstrcpy_c ../../string.c
0000502f aeabi_sdiv.o
0000503d ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
0000506c --schedule --cpu=4 --depend=aeabi_sdiv.d --fpu=none -oaeabi_sdiv.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --
0000516e tmplib.o
00005178 ARM Linker, RVCT2.2 [Build 349]
00005199 Input Comments:
000051aa tmplib.o
000051b4 ARM Linker, RVCT2.2 [Build 349]
000051d5 Input Comments:
000051e6 tmplib.o
000051f0 ARM Linker, RVCT2.2 [Build 349]
00005211 Input Comments:
00005222 tmplib.o
0000522c ARM Linker, RVCT2.2 [Build 349]
0000524d Input Comments:
0000525e tmplib.o
00005268 ARM Linker, RVCT2.2 [Build 349]
00005289 Input Comments:
0000529a tmplib.o
000052a4 ARM Linker, RVCT2.2 [Build 349]
000052c5 Input Comments:
000052d6 display_interface.o
000052eb ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00005319 armcc --debug -c -odisplay_interface.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL display_interface.c
00005501 tmplib.o
0000550b ARM Linker, RVCT2.2 [Build 349]
0000552c Input Comments:
0000553d ui.o
00005543 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00005571 armcc --debug -c -oui.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL ui.c
0000573d tmplib.o
00005747 ARM Linker, RVCT2.2 [Build 349]
00005768 Input Comments:
00005779 tmplib.o
00005783 ARM Linker, RVCT2.2 [Build 349]
000057a4 Input Comments:
000057b5 tmplib.o
000057bf ARM Linker, RVCT2.2 [Build 349]
000057e0 Input Comments:
000057f1 picture.o
000057fc ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
0000582a armcc --debug -c -opicture.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL picture.c
00005a04 tmplib.o
00005a0e ARM Linker, RVCT2.2 [Build 349]
00005a2f Input Comments:
00005a40 service.o
00005a4b ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00005a79 armcc --debug -c -oservice.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL service.c
00005c51 tmplib.o
00005c5b ARM Linker, RVCT2.2 [Build 349]
00005c7c Input Comments:
00005c8d script.o
00005c97 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00005cc5 armcc --debug -c -oscript.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL script.c
00005e99 tmplib.o
00005ea3 ARM Linker, RVCT2.2 [Build 349]
00005ec4 Input Comments:
00005ed5 ss_sys.o
00005edf ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00005f0d armcc --debug -c -oss_sys.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL ss_sys.c
000060e1 tmplib.o
000060eb ARM Linker, RVCT2.2 [Build 349]
0000610c Input Comments:
0000611d tmplib.o
00006127 ARM Linker, RVCT2.2 [Build 349]
00006148 Input Comments:
00006159 tmplib.o
00006163 ARM Linker, RVCT2.2 [Build 349]
00006184 Input Comments:
00006195 tmplib.o
0000619f ARM Linker, RVCT2.2 [Build 349]
000061c0 Input Comments:
000061d1 magic.o
000061da ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00006208 armcc --debug -c -omagic.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL magic.c
000063d8 BootMain.o
000063e4 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00006412 armcc --debug -c -oBootMain.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL BootMain.c
000065e8 tmplib.o
000065f2 ARM Linker, RVCT2.2 [Build 349]
00006613 Input Comments:
00006624 tmplib.o
0000662e ARM Linker, RVCT2.2 [Build 349]
0000664f Input Comments:
00006660 melis_boot.o
0000666e ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
0000669c armcc --debug -c -omelis_boot.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL melis_boot.c
00006877 tmplib.o
00006881 ARM Linker, RVCT2.2 [Build 349]
000068a2 Input Comments:
000068b3 BootOS.o
000068bd ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
000068eb armcc --debug -c -oBootOS.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL BootOS.c
00006ac0 tmplib.o
00006aca ARM Linker, RVCT2.2 [Build 349]
00006aeb Input Comments:
00006afc tmplib.o
00006b06 ARM Linker, RVCT2.2 [Build 349]
00006b27 Input Comments:
00006b38 fel_detect.o
00006b46 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00006b74 armcc --debug -c -ofel_detect.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL fel_detect.c
00006d4f tmplib.o
00006d59 ARM Linker, RVCT2.2 [Build 349]
00006d7a Input Comments:
00006d8b Board.o
00006d94 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00006dc2 armcc --debug -c -oBoard.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Include -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\BootOS -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Common -ID:\winners\eBase\eGON\eGON2\boot1\apps\BootMain_android\Board -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL Board.c
00006f95 __raise.o
00006fa0 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00006fce armcc --arm -c --split_ldm --no_hide_all --no_use_directive_sections -o__raise.o --depend=__raise.d --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --trace=zz --cpu=4 --fpu=none -Ospace --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../ -I../../angel -I../../public -J../../stdh -D__raise_c ../../signal.c
00007121 rt_div0.o
0000712c ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
0000715b --schedule --cpu=4 --depend=rt_div0.d --fpu=none -ort_div0.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --predef
0000725d aeabi_memset.o
0000726d ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
0000729c --schedule --cpu=4 --depend=aeabi_memset.d --fpu=none -oaeabi_memset.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}
0000739e strcmp.o
000073a8 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
000073d7 --schedule --cpu=4 --depend=strcmp.d --fpu=none -ostrcmp.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi//Ospace -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --
000074d9 rt_memcpy_w.o
000074e8 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00007517 --schedule --cpu=4 --depend=rt_memcpy_w.d --fpu=none -ort_memcpy_w.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}"
00007619 eGon2_common.o
00007629 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00007657 armcc --debug -c -oeGon2_common.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\include -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL eGon2_common.c
00007722 format_transformed.o
00007738 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00007766 armcc --debug -c -oformat_transformed.o --cpu=ARM926EJ-S -O0 -ID:\winners\eBase\eGON\eGON2\boot1\include -ID:\winners\eBase\eGON\eGON2\boot1\include -DEPDK_DEBUG_LEVEL=EPDK_DEBUG_LEVEL_LOG_ALL format_transformed.c
0000783d sys_wrch.o
00007849 ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00007877 armcc --arm -c --split_ldm --no_hide_all --no_use_directive_sections -osys_wrch.o --depend=sys_wrch.d --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --trace=zz --cpu=4 --fpu=none -Ospace --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../ -I../../angel -I../../public -J../../stdh -Dsys_wrch_c ../../angel/sysapp.c
000079d3 defsig.o
000079dd ARM/Thumb C/C++ Compiler, RVCT2.2 [Build 349]
00007a0b armcc --arm -c --split_ldm --no_hide_all --no_use_directive_sections -odefsig.o --depend=defsig.d --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --trace=zz --cpu=4 --fpu=none -Ospace --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../ -I../../angel -I../../public -J../../stdh -Ddefsig_c ../../signal.c
00007b5b rt_memclr_w.o
00007b6a ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00007b99 --schedule --cpu=4 --depend=rt_memclr_w.d --fpu=none -ort_memclr_w.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}"
00007c9b rt_raise.o
00007ca7 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00007cd6 --schedule --cpu=4 --depend=rt_raise.d --fpu=none -ort_raise.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --pred
00007dd8 sys_exit.o
00007de4 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00007e13 --schedule --cpu=4 --depend=sys_exit.d --fpu=none -osys_exit.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --pred
00007f15 use_semi.o
00007f21 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
00007f50 --schedule --cpu=4 --depend=use_semi.d --fpu=none -ouse_semi.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --pred
00008052 rt_memcpy.o
0000805f ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
0000808e --schedule --cpu=4 --depend=rt_memcpy.d --fpu=none -ort_memcpy.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --pr
00008190 dc.o
00008196 ARM/Thumb Macro Assembler, RVCT2.2 [Build 349]
000081c5 --schedule --cpu=4 --depend=dc.d --fpu=none -odc.o --schedule_cpu=ARM9E-S --schedule_cpu=ARM10200E --schedule_cpu=ARM1136JF-S --apcs=/no8byte/nointerwork/noswst/norwpi/ropi -I../../,../../angel,../../../clx --predefine="ARM SETL {TRUE}" --predefine="CAN_U
000082c9 EXEC_MOD
000082d2 EXEC_MOD
000082db EXEC_MOD
000082e4 EGON2_MAGIC
000082f0 .note
000082f6 .comment
000082ff .shstrtab
