12:20:25 Parameter [DB] Protocol=mysql-5 12:20:25 Parameter [DB] HostName=localhost 12:20:25 Parameter [DB] Port=3306 12:20:25 Parameter [DB] Database=elela 12:20:25 Parameter [DB] User=xxxxxxx 12:20:25 Parameter [DB] Password=xxxxxx 12:20:25 Error dir not found: Parameter [Programm] VorlageDir 12:20:25 Parameter [Programm] TempDir=/home/klaus/test/elela/EleLa_20110206/ 12:20:25 Parameter [Bauteil] DefHanbuchDir=/home/klaus/test/elela/EleLa_20110206/bauteile 12:20:25 Parameter [Projekt] DefHanbuchDir=/home/klaus/test/elela/EleLa_20110206/projekt 12:20:25 Parameter [Linux] ComboItemHeight=9 12:20:25 Parameter [Linux] FontHeight=11 12:20:26 Error: Cannot open database! None of the dynamic libraries can be found: libmysqlclient.so.16, libmysqlclient.so.15, libmysqlclient.so (DB-Connect) 12:20:41 Error: Cannot open database! None of the dynamic libraries can be found: libmysqlclient.so.16, libmysqlclient.so.15, libmysqlclient.so (DB-Connect) 12:20:56 Error: Cannot open database! None of the dynamic libraries can be found: libmysqlclient.so.16, libmysqlclient.so.15, libmysqlclient.so (DB-Connect) 12:21:11 Error: Cannot open database! None of the dynamic libraries can be found: libmysqlclient.so.16, libmysqlclient.so.15, libmysqlclient.so (DB-Connect)
