#include #include #include "globals.h" int main(void) { // General settings WDTCTL = WDTPW + WDTHOLD;// + WDTTMSEL; // Stop watchdog timer DCOCTL |= DCO2 + DCO0; // set internal DCO to maximum frequency (8 MHz) BCSCTL1 |= RSEL2 + RSEL1 + RSEL0; // set internal DCO to maximum frequency (8 MHz) BCSCTL1 |= XT2OFF + XTS + DIVA_0; // XT2 off (+XTS if crystal1 present) P1DIR |= 0x01; // Set P1.0 to output direction P2DIR |= 0x1F; // Set P2.0-P2.1 to output direction (RF90, RF180, Gx, Gy, Gz) // (Gy changes to DAC output later) P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD P5SEL |= 0x70; // output ACLK, MCLK and SMCLK to pins (just for measurement purposes) // Check OSCFault flag unsigned int j; do { IFG1 &= ~OFIFG; // Clear OSCFault flag for (j = 0xFF; j > 0; j--); // Time for flag to set } while ((IFG1 & OFIFG)); // OSCFault flag still set? BCSCTL2 = SELM_3 + DIVM_0 + DIVS_0; //+ SELS // MCLK sourced from crystal1 // UART settings UCTL0 |= SWRST + CHAR + PENA; // 8-bit characters, odd parity ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD UTCTL0 |= SSEL0; // UCLK= ACLK //UTCTL0 |= SSEL1; // UCLK= SMCLK UBR00 = 0xA0; // 4MHz 0x22 115200 (0x68 38400,0xA0 9600) UBR10 = 0x01; // 4MHz 0x00 115200 UMCTL0 = 0x5B; // 4MHz 0xDD 115200 modulation UCTL0 &= ~SWRST; // Initialize USART state machine IE1 |= URXIE0; // Enable USART0 RX/TX interrupt (URXIE0 has to be cleared when using DMA) /* wait forever */ for (;;) { // wait for timer or ADC interrupts } return 0; } /* Timer B0 interrupt service routine */ #pragma vector=TIMERB0_VECTOR __interrupt void Timer_B (void) { } #pragma vector=ADC_VECTOR __interrupt void ADC12ISR (void) { } #pragma vector=UART0RX_VECTOR __interrupt void usart0_rx (void) { __disable_interrupt(); if (configMode > 0) { URCTL0 &= ~URXWIE; switch(configMode) { case 1: tEcho = RXBUF0; configMode++; break; case 2: tEcho = (tEcho << 8) | RXBUF0; configMode++; break; case 3: tRep = RXBUF0; configMode++; break; case 4: tRep = (tRep << 8) | RXBUF0; configMode++; break; case 5: tRF90 = RXBUF0; configMode++; break; case 6: tRF180 = RXBUF0; configMode++; break; case 7: nrOfCycles = RXBUF0; configMode++; break; case 8: Gx = RXBUF0; configMode++; break; case 9: Gx = (Gx << 8) | RXBUF0; configMode++; break; case 10: gyNrOfCycles = RXBUF0; configMode++; break; case 11: configMode=0; //conversions tRep *= 1000; // conversion ms to us tRep += tA/2 + tEcho + tC; tRepTemp = tRep; tRF90adj = tRF90/1.6; tRF180adj = tRF180/1.6; tB=tC; break; } } else if (RXBUF0 == 'a') { } else if (RXBUF0 == 'b') { } else if (RXBUF0 == 'c') { } else if (RXBUF0 == 'z') { // setup times tR and tE configMode = 1; URCTL0 &= ~URXWIE; } else { } }
