; 8080 Interpreter.
; This is part of the Z80-CP/M emulator written by Sprite_tm.
; Copyright (C) 2010 Sprite_tm
; Copyright (C) 2010 Leo C.
; Copyright (C) 2010 Horst S.
; This file is part of avrcpm.
; avrcpm is free software: you can redistribute it and/or modify it
; under the terms of the GNU General Public License as published by
; the Free Software Foundation, either version 3 of the License, or
; (at your option) any later version.
; avrcpm is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
; GNU General Public License for more details.
; You should have received a copy of the GNU General Public License
; along with avrcpm. If not, see .
; $Id$
.dseg
z_b: .byte 1
z_c: .byte 1
z_d: .byte 1
z_e: .byte 1
z_h: .byte 1
z_l: .byte 1
.cseg
;Init z80
z80_init:
ldi z_pcl,low (IPLADDR)
ldi z_pch,high(IPLADDR)
cbi flags,trace
printnewline
printstring "Ok, CPU is live!"
printnewline
main:
.if INS_DEBUG
cbi flags,trace
cpi z_pch,DBG_TRACE_BOTTOM
brlo notraceon
cpi z_pch,DBG_TRACE_TOP
brsh notraceon
sbi flags,trace
notraceon:
.endif
.if PRINT_PC
brlo noprintpc
brsh noprintpc
printnewline
printstring "PC="
movw temp,z_pcl
call printhexw
printstring " "
noprintpc:
.endif
.if INS_DEBUG
sbic flags,trace
call printregs
.endif
;hier kommt die Interruptbehandlung rein
mem_read_ds zl,z_pc ;zl = memReadByte(z_pc)
adiw z_pcl,1 ;++z_pc
ldi zh,high(opcjmp) ;
icall
rjmp main ;
; .listmac
; Generate a table entry for one instruction
; instr fetch, op, store
.macro instr
.ifndef opcjmp_table_pos_
.set todo_table_pos_ = PC
; Place the opcode jump table on the next available location.
.equ opcjmp = (PC+255) & 0xff00
.set opcjmp_table_pos_ = opcjmp
.endif
.if todo_table_pos_ < opcjmp + 256 + 128
.if todo_table_pos_ + 3 >= opcjmp
.set todo_table_pos_ = opcjmp + 256 + 128
.endif
.endif
.set do_@0_@1_@2 = todo_table_pos_ ; make a label
.org opcjmp_table_pos_
rjmp do_@0_@1_@2 ; generate a jump to the label
.set opcjmp_table_pos_ = PC
.org do_@0_@1_@2
.set fetch_ = (@0 != do_fetch_nop) ; must call or jump to fetch phase
.set op_ = (do_@1 != do_op_nop) ; must call or jump to op phase
.set store_ = (@2 != do_store_nop) ; must jump to store phase
.if fetch_ || op_ || store_ ; something to do
.if fetch_ ; must fetch
.if op_ || store_
rcall @0 ; fetch and come back here
.else ;
rjmp @0 ; fetch and return to main
.endif
.endif
.if op_ ; must exec op
.if store_
rcall do_@1 ; do op and come back here
.else
rjmp do_@1 ; do op and return to main
.endif
.endif
.if store_ ; must store
rjmp @2 ; store is allways last
.endif
.else
ret ; nop, go back to main
.endif
.endm
; ------------ Fetch phase stuff -----------------
;.org (PC+255) & 0xff00
fetch_ops:
do_fetch_nop:
ret
do_fetch_a:
mov opl,z_a
ret
do_fetch_b:
lds opl,z_b
ret
do_fetch_c:
lds opl,z_c
ret
do_fetch_d:
lds opl,z_d
ret
do_fetch_e:
lds opl,z_e
ret
do_fetch_h:
lds opl,z_h
ret
do_fetch_l:
lds opl,z_l
ret
do_fetch_af:
mov opl,z_flags
mov oph,z_a
ret
do_fetch_bc:
lds opl,z_c
lds oph,z_b
ret
do_fetch_de:
lds opl,z_e
lds oph,z_d
ret
do_fetch_hl:
lds opl,z_l
lds oph,z_h
ret
do_fetch_sp:
movw opl,z_spl
ret
do_fetch_mbc:
lds xh,z_b
lds xl,z_c
mem_read_d opl
ret
do_fetch_mde:
lds xh,z_d
lds xl,z_e
mem_read_d opl
ret
do_fetch_mhl:
lds xh,z_h
lds xl,z_l
mem_read_d opl
ret
do_fetch_msp:
movw x,z_spl
mem_read_d opl
adiw x,1
mem_read_d oph
ret
do_fetch_dir8:
mem_read_ds opl, z_pc
adiw z_pcl,1
ret
do_fetch_dir16:
adiw z_pcl,1
mem_read_ds oph, z_pc
adiw z_pcl,1
ret
do_fetch_rst:
movw x,z_pcl
sbiw x,1
mem_read_d opl
andi opl,0x38
ldi oph,0
ret
; ------------ Store phase stuff -----------------
store_ops:
do_store_nop:
ret
do_store_a:
mov z_a,opl
ret
do_store_b:
sts z_b,opl
ret
do_store_c:
sts z_c,opl
ret
do_store_d:
sts z_d,opl
ret
do_store_e:
sts z_e,opl
ret
do_store_h:
sts z_h,opl
ret
do_store_l:
sts z_l,opl
ret
do_store_af:
mov z_a,oph
mov z_flags,opl
ret
do_store_bc:
sts z_b,oph
sts z_c,opl
ret
do_store_de:
sts z_d,oph
sts z_e,opl
ret
do_store_hl:
sts z_h,oph
sts z_l,opl
ret
do_store_mbc:
lds xh,z_b
lds xl,z_c
mem_write_s opl
ret
do_store_mde:
lds xh,z_d
lds xl,z_e
mem_write_s opl
ret
do_store_mhl:
lds xh,z_h
lds xl,z_l
mem_write_s opl
ret
do_store_msp:
movw xl,z_spl
mem_write_s opl
adiw xl,1
mem_write_s oph
ret
do_store_sp:
movw z_spl,opl
ret
do_store_pc:
movw z_pcl,opl
ret
do_store_ret:
movw x,z_spl
mem_read_d z_pcl
adiw x,1
mem_read_d z_pch
adiw x,1
movw z_spl,x
.if STACK_DBG
printnewline
printstring "Stack pop "
movw temp,z_pcl
rcall printhexw
printstring ", SP is now "
movw temp,z_spl
rcall printhexw
printstring ". "
.endif
ret
do_store_call:
movw xl,z_spl
sbiw x,1
mem_write_s z_pch
sbiw x,1
mem_write_s z_pcl
movw z_spl,xl
.if STACK_DBG
printnewline
printstring "Stack push "
movw temp,z_pcl
rcall printhexw
movw temp,z_spl
rcall printhexw
printstring ". "
.endif
movw z_pcl,opl
ret
do_store_am:
mem_write_ds op, z_a
ret
; ------------ Operation phase stuff -----------------
;| Zilog |
;| ZZZZZZZ 88888 000 |
;| Z 8 8 0 0 |
;| Z 8 8 0 0 0 |
;| Z 88888 0 0 0 |
;| Z 8 8 0 0 0 |
;| Z 8 8 0 0 |
;| Z80 MICROPROCESSOR Instruction Set Summary |
;|Mnemonic |SZHPNC|Description |Notes |
;|ADC A,s |***V0*|Add with Carry |A=A+s+CY |
;|ADC HL,ss |**?V0*|Add with Carry |HL=HL+ss+CY |
;|ADD A,s |***V0*|Add |A=A+s |
;|ADD HL,ss |--?-0*|Add |HL=HL+ss |
;|ADD IX,pp |--?-0*|Add |IX=IX+pp |
;|ADD IY,rr |--?-0*|Add |IY=IY+rr |
;|AND s |**1P00|Logical AND |A=A&s |
;|BIT b,m |?*1?0-|Test Bit |m&{2^b} |
;|CALL cc,nn|------|Conditional Call |If cc CALL |
;|CALL nn |------|Unconditional Call |-[SP]=PC,PC=nn |
;|CCF |--?-0*|Complement Carry Flag|CY=~CY |
;|CP s |***V1*|Compare |A-s |
;|CPD |****1-|Compare and Decrement|A-[HL],HL=HL-1,BC=BC-1|
;|CPDR |****1-|Compare, Dec., Repeat|CPD till A=[HL]or BC=0|
;|CPI |****1-|Compare and Increment|A-[HL],HL=HL+1,BC=BC-1|
;|CPIR |****1-|Compare, Inc., Repeat|CPI till A=[HL]or BC=0|
;|CPL |--1-1-|Complement |A=~A |
;|DAA |***P-*|Decimal Adjust Acc. |A=BCD format |
;|DEC s |***V1-|Decrement |s=s-1 |
;|DEC xx |------|Decrement |xx=xx-1 |
;|DEC ss |------|Decrement |ss=ss-1 |
;|DI |------|Disable Interrupts | |
;|DJNZ e |------|Dec., Jump Non-Zero |B=B-1 till B=0 |
;|EI |------|Enable Interrupts | |
;|EX [SP],HL|------|Exchange |[SP]<->HL |
;|EX [SP],xx|------|Exchange |[SP]<->xx |
;|EX AF,AF' |------|Exchange |AF<->AF' |
;|EX DE,HL |------|Exchange |DE<->HL |
;|EXX |------|Exchange |qq<->qq' (except AF)|
;|HALT |------|Halt | |
;|IM n |------|Interrupt Mode | (n=0,1,2)|
;|IN A,[n] |------|Input |A=[n] |
;|IN r,[C] |***P0-|Input |r=[C] |
;|INC r |***V0-|Increment |r=r+1 |
;|INC [HL] |***V0-|Increment |[HL]=[HL]+1 |
;|INC xx |------|Increment |xx=xx+1 |
;|INC [xx+d]|***V0-|Increment |[xx+d]=[xx+d]+1 |
;|INC ss |------|Increment |ss=ss+1 |
;|IND |?*??1-|Input and Decrement |[HL]=[C],HL=HL-1,B=B-1|
;|INDR |?1??1-|Input, Dec., Repeat |IND till B=0 |
;|INI |?*??1-|Input and Increment |[HL]=[C],HL=HL+1,B=B-1|
;|INIR |?1??1-|Input, Inc., Repeat |INI till B=0 |
;|JP [HL] |------|Unconditional Jump |PC=[HL] |
;|JP [xx] |------|Unconditional Jump |PC=[xx] |
;|JP nn |------|Unconditional Jump |PC=nn |
;|JP cc,nn |------|Conditional Jump |If cc JP |
;|JR e |------|Unconditional Jump |PC=PC+e |
;|JR cc,e |------|Conditional Jump |If cc JR(cc=C,NC,NZ,Z)|
;|LD dst,src|------|Load |dst=src |
;|LD A,i |**0*0-|Load |A=i (i=I,R)|
;|LDD |--0*0-|Load and Decrement |[DE]=[HL],HL=HL-1,# |
;|LDDR |--000-|Load, Dec., Repeat |LDD till BC=0 |
;|LDI |--0*0-|Load and Increment |[DE]=[HL],HL=HL+1,# |
;|LDIR |--000-|Load, Inc., Repeat |LDI till BC=0 |
;|NEG |***V1*|Negate |A=-A |
;|NOP |------|No Operation | |
;|OR s |**0P00|Logical inclusive OR |A=Avs |
;|OTDR |?1??1-|Output, Dec., Repeat |OUTD till B=0 |
;|OTIR |?1??1-|Output, Inc., Repeat |OUTI till B=0 |
;|OUT [C],r |------|Output |[C]=r |
;|OUT [n],A |------|Output |[n]=A |
;|OUTD |?*??1-|Output and Decrement |[C]=[HL],HL=HL-1,B=B-1|
;|OUTI |?*??1-|Output and Increment |[C]=[HL],HL=HL+1,B=B-1|
;|POP xx |------|Pop |xx=[SP]+ |
;|POP qq |------|Pop |qq=[SP]+ |
;|PUSH xx |------|Push |-[SP]=xx |
;|PUSH qq |------|Push |-[SP]=qq |
;|RES b,m |------|Reset bit |m=m&{~2^b} |
;|RET |------|Return |PC=[SP]+ |
;|RET cc |------|Conditional Return |If cc RET |
;|RETI |------|Return from Interrupt|PC=[SP]+ |
;|RETN |------|Return from NMI |PC=[SP]+ |
;|RL m |**0P0*|Rotate Left |m={CY,m}<- |
;|RLA |--0-0*|Rotate Left Acc. |A={CY,A}<- |
;|RLC m |**0P0*|Rotate Left Circular |m=m<- |
;|RLCA |--0-0*|Rotate Left Circular |A=A<- |
;|RLD |**0P0-|Rotate Left 4 bits |{A,[HL]}={A,[HL]}<- ##|
;|RR m |**0P0*|Rotate Right |m=->{CY,m} |
;|RRA |--0-0*|Rotate Right Acc. |A=->{CY,A} |
;|RRC m |**0P0*|Rotate Right Circular|m=->m |
;|RRCA |--0-0*|Rotate Right Circular|A=->A |
;|RRD |**0P0-|Rotate Right 4 bits |{A,[HL]}=->{A,[HL]} ##|
;|RST p |------|Restart | (p=0H,8H,10H,...,38H)|
;|SBC A,s |***V1*|Subtract with Carry |A=A-s-CY |
;|SBC HL,ss |**?V1*|Subtract with Carry |HL=HL-ss-CY |
;|SCF |--0-01|Set Carry Flag |CY=1 |
;|SET b,m |------|Set bit |m=mv{2^b} |
;|SLA m |**0P0*|Shift Left Arithmetic|m=m*2 |
;|SRA m |**0P0*|Shift Right Arith. |m=m/2 |
;|SRL m |**0P0*|Shift Right Logical |m=->{0,m,CY} |
;|SUB s |***V1*|Subtract |A=A-s |
;|XOR s |**0P00|Logical Exclusive OR |A=Axs |
;| F |-*01? |Flag unaffected/affected/reset/set/unknown |
;| S |S |Sign flag (Bit 7) |
;| Z | Z |Zero flag (Bit 6) |
;| HC | H |Half Carry flag (Bit 4) |
;| P/V | P |Parity/Overflow flag (Bit 2, V=overflow) |
;| N | N |Add/Subtract flag (Bit 1) |
;| CY | C|Carry flag (Bit 0) |
;| n |Immediate addressing |
;| nn |Immediate extended addressing |
;| e |Relative addressing (PC=PC+2+offset) |
;| [nn] |Extended addressing |
;| [xx+d] |Indexed addressing |
;| r |Register addressing |
;| [rr] |Register indirect addressing |
;| |Implied addressing |
;| b |Bit addressing |
;| p |Modified page zero addressing (see RST) |
;|DEFB n(,...) |Define Byte(s) |
;|DEFB 'str'(,...) |Define Byte ASCII string(s) |
;|DEFS nn |Define Storage Block |
;|DEFW nn(,...) |Define Word(s) |
;| A B C D E |Registers (8-bit) |
;| AF BC DE HL |Register pairs (16-bit) |
;| F |Flag register (8-bit) |
;| I |Interrupt page address register (8-bit) |
;| IX IY |Index registers (16-bit) |
;| PC |Program Counter register (16-bit) |
;| R |Memory Refresh register |
;| SP |Stack Pointer register (16-bit) |
;| b |One bit (0 to 7) |
;| cc |Condition (C,M,NC,NZ,P,PE,PO,Z) |
;| d |One-byte expression (-128 to +127) |
;| dst |Destination s, ss, [BC], [DE], [HL], [nn] |
;| e |One-byte expression (-126 to +129) |
;| m |Any register r, [HL] or [xx+d] |
;| n |One-byte expression (0 to 255) |
;| nn |Two-byte expression (0 to 65535) |
;| pp |Register pair BC, DE, IX or SP |
;| qq |Register pair AF, BC, DE or HL |
;| qq' |Alternative register pair AF, BC, DE or HL |
;| r |Register A, B, C, D, E, H or L |
;| rr |Register pair BC, DE, IY or SP |
;| s |Any register r, value n, [HL] or [xx+d] |
;| src |Source s, ss, [BC], [DE], [HL], nn, [nn] |
;| ss |Register pair BC, DE, HL or SP |
;| xx |Index register IX or IY |
;| + - * / ^ |Add/subtract/multiply/divide/exponent |
;| & ~ v x |Logical AND/NOT/inclusive OR/exclusive OR |
;| <- -> |Rotate left/right |
;| [ ] |Indirect addressing |
;| [ ]+ -[ ] |Indirect addressing auto-increment/decrement|
;| { } |Combination of operands |
;| # |Also BC=BC-1,DE=DE-1 |
;| ## |Only lower 4 bits of accumulator A used |
;How the flags are supposed to work:
;7 ZFL_S - Sign flag (=MSBit of result)
;6 ZFL_Z - Zero flag. Is 1 when the result is 0
;4 ZFL_H - Half-carry (carry from bit 3 to 4)
;2 ZFL_P - Parity/2-complement Overflow
;1 ZFL_N - Subtract - set if last op was a subtract
;0 ZFL_C - Carry
;I sure hope I got the mapping between flags and instructions correct...
.equ ZFL_S = 7
.equ ZFL_Z = 6
.equ ZFL_H = 4
.equ ZFL_P = 2
.equ ZFL_N = 1
.equ ZFL_C = 0
.equ AVR_T = SREG_T
.equ AVR_H = SREG_H
.equ AVR_S = SREG_S
.equ AVR_V = SREG_V
.equ AVR_N = SREG_N
.equ AVR_Z = SREG_Z
.equ AVR_C = SREG_C
; Load table value from flash indexed by source reg.
; ldpmx dstreg,tablebase,indexreg
; (6 words, 8 cycles)
.macro ldpmx
ldi zh,high(@1*2) ; table must be page aligned
mov zl,@2
lpm @0,z
.endm
.macro do_z80_flags_HP
#if EM_Z80
bmov z_flags, ZFL_P, temp, AVR_V
bmov z_flags, ZFL_H, temp, AVR_H
#endif
.endm
.macro do_z80_flags_set_N
#if EM_Z80
ori z_flags, (1< ("
mov temp,opl
rcall printhex
printstring ") "
.endif
mov temp,z_a
mov temp2,opl
lcall portWrite
ret
do_op_in: ; in a,(opl)
.if PORT_DEBUG
printnewline
printstring "Port read: ("
mov temp,opl
rcall printhex
printstring ") -> "
.endif
mov temp2,opl
lcall portRead
mov opl,temp
.if PORT_DEBUG
rcall printhex
printstring " "
.endif
ret
;|----------|SZHP C|---------- 8080 ----------------------------|
;|INC r |**-P0-|Increment |r=r+1 |
;|INC [HL] |**-P0-|Increment |[HL]=[HL]+1 |
do_op_inc:
inc opl
#if EM_Z80
in temp, sreg
#endif
andi z_flags,(1<A |
;|RRCA |---- *|Rotate Right Circular|A=->A |
do_op_rrc:
;Rotate Right Cyclical. All bits move 1 to the
;right, the lsb becomes c and msb.
do_z80_flags_op_rotate
lsr opl
brcc do_op_rrc_noc
ori opl, 0x80
ori z_flags, (1<{CY,A} |
;|RRA |---- *|Rotate Right Acc. |A=->{CY,A} |
do_op_rr:
;Rotate Right. All bits move 1 to the right, the lsb
;becomes c, c becomes msb.
clc ; get z80 carry to avr carry
sbrc z_flags,ZFL_C
sec
do_z80_flags_op_rotate ; (clear ZFL_C, doesn't change AVR_C)
bmov z_flags,ZFL_C, opl,0 ; Bit 0 --> CY
ror opl
ret
;|RLA |---- *|Rotate Left Acc. |A={CY,A}<- |
do_op_rl:
;Rotate Left. All bits move 1 to the left, the msb
;becomes c, c becomes lsb.
clc
sbrc z_flags,ZFL_C
sec
bmov z_flags,ZFL_C, opl,7 ; Bit 7 --> CY
rol opl
ret
;|ADD A,s |***P *|Add |A=A+s |
do_op_adda:
add z_a,opl
in temp,sreg
ldpmx z_flags,sz53p_tab,z_a ;S,Z,P flag
bmov z_flags,ZFL_C, temp,AVR_C
do_z80_flags_HP
ret
;|ADC A,s |***P *|Add with Carry |A=A+s+CY |
do_op_adca:
clc
sbrc z_flags,ZFL_C
sec
adc z_a,opl
in temp,sreg
do_z80_flags_HP
ret
;|SUB s |***P *|Subtract |A=A-s |
do_op_subfa:
sub z_a,opl
in temp,sreg
do_z80_flags_HP
do_z80_flags_set_N
ret
;|CP s |***P *|Compare |A-s |
do_op_cpfa:
mov temp,z_a
sub temp,opl
mov opl,temp
in temp,sreg
ldpmx z_flags,sz53p_tab,opl ;S,Z,P
do_z80_flags_HP
do_z80_flags_set_N
ret
;|SBC A,s |***P *|Subtract with Carry |A=A-s-CY |
do_op_sbcfa:
clc
sbrc z_flags,ZFL_C
sec
sbc z_a,opl
in temp,sreg
do_z80_flags_HP
do_z80_flags_set_N
ret
;|AND s |**-P 0|Logical AND |A=A&s |
; TODO H-Flag
do_op_anda:
and z_a,opl ;
ldpmx z_flags,sz53p_tab,z_a ;S,Z,P,N,C
do_z80_flags_op_and
ret
;|OR s |**-P00|Logical inclusive OR |A=Avs |
; TODO: H-Flag
do_op_ora:
or z_a,opl
ldpmx z_flags,sz53p_tab,z_a ;S,Z,H,P,N,C
do_z80_flags_op_or
ret
;|XOR s |**-P 0|Logical Exclusive OR |A=Axs |
; TODO: H-Flag
do_op_xora:
eor z_a,opl
do_z80_flags_op_or
ret
;|ADD HL,ss |---- *|Add |HL=HL+ss |
do_op_addhl:
lds temp,z_l
lds temp2,z_h
add opl,temp
adc oph,temp2
in temp,sreg
bmov z_flags,ZFL_H, temp,AVR_H
do_z80_flags_clear_N
ret
do_op_sthl: ;store hl to mem loc in opl:h
movw xl,opl
lds temp,z_l
mem_write
adiw xl,1
lds temp,z_h
mem_write
ret
do_op_rmem16:
movw xl,opl
mem_read_d opl
adiw x,1
mem_read_d oph
ret
do_op_rmem8:
mem_read_ds opl, op
ret
;|DAA |***P-*|Decimal Adjust Acc. | |
; Not yet checked
; Description (http://www.z80.info/z80syntx.htm#DAA):
; This instruction conditionally adjusts the accumulator for BCD addition
; and subtraction operations. For addition (ADD, ADC, INC) or subtraction
; (SUB, SBC, DEC, NEC), the following table indicates the operation performed:
; | | C Flag | HEX value in | H Flag | HEX value in | Number | C flag|
; | Operation| Before | upper digit | Before | lower digit | added | After |
; | | DAA | (bit 7-4) | DAA | (bit 3-0) | to byte | DAA |
; | | 0 | 0-9 | 0 | 0-9 | 00 | 0 |
; | ADD | 0 | 0-8 | 0 | A-F | 06 | 0 |
; | | 0 | 0-9 | 1 | 0-3 | 06 | 0 |
; | ADC | 0 | A-F | 0 | 0-9 | 60 | 1 |
; | | 0 | 9-F | 0 | A-F | 66 | 1 |
; | INC | 0 | A-F | 1 | 0-3 | 66 | 1 |
; | | 1 | 0-2 | 0 | 0-9 | 60 | 1 |
; | | 1 | 0-2 | 0 | A-F | 66 | 1 |
; | | 1 | 0-3 | 1 | 0-3 | 66 | 1 |
; | SUB | 0 | 0-9 | 0 | 0-9 | 00 | 0 |
; | SBC | 0 | 0-8 | 1 | 6-F | FA | 0 |
; | DEC | 1 | 7-F | 0 | 0-9 | A0 | 1 |
; | NEG | 1 | 6-F | 1 | 6-F | 9A | 1 |
; Flags:
; C: See instruction.
; N: Unaffected.
; P/V: Set if Acc. is even parity after operation, reset otherwise.
; H: See instruction.
; Z: Set if Acc. is Zero after operation, reset otherwise.
; S: Set if most significant bit of Acc. is 1 after operation, reset otherwise.
#if 1
do_op_da:
ldi oph,0 ; what to add
sbrc z_flags,ZFL_H ; if H-Flag
rjmp op_da_06
mov temp,opl
andi temp,0x0f ; ... or lower digit > 9
cpi temp,0x0a
brlo op_da_06n
op_da_06:
ori oph,0x06
op_da_06n:
sbrc z_flags,(1< 9
brlo do_op_da_h ;
ori temp2,0x06 ; add 6 to lower digit
do_op_da_h: ;
sbrc z_flags,ZFL_H ; ... or H-Flag
ori temp2,0x06 ;
add opl,temp2 ;
ldi temp2,0 ;
mov temp,opl ;
andi temp,0xf0 ;
cpi temp,0xa0 ;
brlo do_op_da_c ;
ori temp2,0x60 ;
do_op_da_c: ; else sub-op
sbrc z_flags,ZFL_C ;
ori temp2,0x60 ;
andi z_flags, ~( (1<HL |
;-----------------------------Z80--------------------------------
do_op_exhl:
lds temp,z_l
lds temp2,z_h
sts z_l,opl
sts z_h,oph
movw opl,temp
ret
; TODO: Implement IFF1, IFF2
do_op_di:
ret
do_op_ei:
ret
do_op_ifnz:
sbrs z_flags, ZFL_Z
ret
pop temp ; nix tun
pop temp ; direkt zuruech zu main
ret
do_op_ifz:
sbrc z_flags, ZFL_Z
ret
pop temp ; nix tun
ret
do_op_ifnc:
sbrs z_flags, ZFL_C
ret
pop temp ; nix tun
ret
do_op_ifc:
sbrc z_flags, ZFL_C
ret
pop temp ; nix tun
ret
do_op_ifpo:
sbrs z_flags, ZFL_P
ret
pop temp ; nix tun
ret
do_op_ifpe:
sbrc z_flags, ZFL_P
ret
pop temp ; nix tun
ret
do_op_ifp: ;sign positive, aka s=0
sbrs z_flags, ZFL_S
ret
pop temp ; nix tun
ret
do_op_ifm: ;sign negative, aka s=1
sbrc z_flags, ZFL_S
ret
pop temp ; nix tun
ret
; ----------------------- Opcode decoding -------------------------
; Lookup table for Z80 opcodes. Translates the first byte of the instruction word into three
; operations: fetch, do something, store.
; The table is made of 256 words.
; .org (PC+255) & 0xff00
;todo_table:
;opcjmp:
instr do_fetch_nop, op_nop, do_store_nop ;00 ;NOP
instr do_fetch_DIR16, op_nop, do_store_BC ;01 nn nn ;LD BC,nn
instr do_fetch_A, op_nop, do_store_MBC ;02 ;LD (BC),A
instr do_fetch_BC, op_INC16, do_store_BC ;03 ;INC BC
instr do_fetch_B, op_INC, do_store_B ;04 ;INC B
instr do_fetch_B, op_DEC, do_store_B ;05 ;DEC B
instr do_fetch_DIR8, op_nop, do_store_B ;06 ;LD B,n
instr do_fetch_A, op_RLC, do_store_A ;07 ;RLCA
instr do_fetch_nop, op_INV, do_store_nop ;08 ;EX AF,AF'
instr do_fetch_BC, op_ADDHL, do_store_HL ;09 ;ADD HL,BC
instr do_fetch_MBC, op_nop, do_store_A ;0A ;LD A,(BC)
instr do_fetch_BC, op_DEC16, do_store_BC ;0B ;DEC BC
instr do_fetch_C, op_INC, do_store_C ;0C ;INC C
instr do_fetch_C, op_DEC, do_store_C ;0D ;DEC C
instr do_fetch_DIR8, op_nop, do_store_C ;0E nn ;LD C,n
instr do_fetch_A, op_RRC, do_store_A ;0F ;RRCA
instr do_fetch_nop, op_INV, do_store_nop ;10 oo ;DJNZ o
instr do_fetch_DIR16, op_nop, do_store_DE ;11 nn nn ;LD DE,nn
instr do_fetch_A, op_nop, do_store_MDE ;12 ;LD (DE),A
instr do_fetch_DE, op_INC16, do_store_DE ;13 ;INC DE
instr do_fetch_D, op_INC, do_store_D ;14 ;INC D
instr do_fetch_D, op_DEC, do_store_D ;15 ;DEC D
instr do_fetch_DIR8, op_nop, do_store_D ;16 nn ;LD D,n
instr do_fetch_A, op_RL, do_store_A ;17 ;RLA
instr do_fetch_nop, op_INV, do_store_nop ;18 oo ;JR o
instr do_fetch_DE, op_ADDHL, do_store_HL ;19 ;ADD HL,DE
instr do_fetch_MDE, op_nop, do_store_A ;1A ;LD A,(DE)
instr do_fetch_DE, op_DEC16, do_store_DE ;1B ;DEC DE
instr do_fetch_E, op_INC, do_store_E ;1C ;INC E
instr do_fetch_E, op_DEC, do_store_E ;1D ;DEC E
instr do_fetch_DIR8, op_nop, do_store_E ;1E nn ;LD E,n
instr do_fetch_A, op_RR, do_store_A ;1F ;RRA
instr do_fetch_nop, op_INV, do_store_nop ;20 oo ;JR NZ,o
instr do_fetch_DIR16, op_nop, do_store_HL ;21 nn nn ;LD HL,nn
instr do_fetch_DIR16, op_STHL, do_store_nop ;22 nn nn ;LD (nn),HL
instr do_fetch_HL, op_INC16, do_store_HL ;23 ;INC HL
instr do_fetch_H, op_INC, do_store_H ;24 ;INC H
instr do_fetch_H, op_DEC, do_store_H ;25 ;DEC H
instr do_fetch_DIR8, op_nop, do_store_H ;26 nn ;LD H,n
instr do_fetch_A, op_DA, do_store_A ;27 ;DAA
instr do_fetch_nop, op_INV, do_store_nop ;28 oo ;JR Z,o
instr do_fetch_HL, op_ADDHL, do_store_HL ;29 ;ADD HL,HL
instr do_fetch_DIR16, op_RMEM16, do_store_HL ;2A nn nn ;LD HL,(nn)
instr do_fetch_HL, op_DEC16, do_store_HL ;2B ;DEC HL
instr do_fetch_L, op_INC, do_store_L ;2C ;INC L
instr do_fetch_L, op_DEC, do_store_L ;2D ;DEC L
instr do_fetch_DIR8, op_nop, do_store_L ;2E nn ;LD L,n
instr do_fetch_nop, op_CPL, do_store_nop ;2F ;CPL
instr do_fetch_nop, op_INV, do_store_nop ;30 oo ;JR NC,o
instr do_fetch_DIR16, op_nop, do_store_SP ;31 nn nn ;LD SP,nn
instr do_fetch_DIR16, op_nop, do_store_AM ;32 nn nn ;LD (nn),A
instr do_fetch_SP, op_INC16, do_store_SP ;33 ;INC SP
instr do_fetch_MHL, op_INC, do_store_MHL ;34 ;INC (HL)
instr do_fetch_MHL, op_DEC, do_store_MHL ;35 ;DEC (HL)
instr do_fetch_DIR8, op_nop, do_store_MHL ;36 nn ;LD (HL),n
instr do_fetch_nop, op_SCF, do_store_nop ;37 ;SCF
instr do_fetch_nop, op_INV, do_store_nop ;38 oo ;JR C,o
instr do_fetch_SP, op_ADDHL, do_store_HL ;39 ;ADD HL,SP
instr do_fetch_DIR16, op_RMEM8, do_store_A ;3A nn nn ;LD A,(nn)
instr do_fetch_SP, op_DEC16, do_store_SP ;3B ;DEC SP
instr do_fetch_nop, op_INCA, do_store_nop ;3C ;INC A
instr do_fetch_nop, op_DECA, do_store_nop ;3D ;DEC A
instr do_fetch_DIR8, op_nop, do_store_A ;3E nn ;LD A,n
instr do_fetch_nop, op_CCF, do_store_nop ;3F ;CCF (Complement Carry Flag, gvd)
instr do_fetch_B, op_nop, do_store_B ;40 ;LD B,B
instr do_fetch_C, op_nop, do_store_B ;41 ;LD B,C
instr do_fetch_D, op_nop, do_store_B ;42 ;LD B,D
instr do_fetch_E, op_nop, do_store_B ;43 ;LD B,E
instr do_fetch_H, op_nop, do_store_B ;44 ;LD B,H
instr do_fetch_L, op_nop, do_store_B ;45 ;LD B,L
instr do_fetch_MHL, op_nop, do_store_B ;46 ;LD B,(HL)
instr do_fetch_A, op_nop, do_store_B ;47 ;LD B,A
instr do_fetch_B, op_nop, do_store_C ;48 ;LD C,B
instr do_fetch_C, op_nop, do_store_C ;49 ;LD C,C
instr do_fetch_D, op_nop, do_store_C ;4A ;LD C,D
instr do_fetch_E, op_nop, do_store_C ;4B ;LD C,E
instr do_fetch_H, op_nop, do_store_C ;4C ;LD C,H
instr do_fetch_L, op_nop, do_store_C ;4D ;LD C,L
instr do_fetch_MHL, op_nop, do_store_C ;4E ;LD C,(HL)
instr do_fetch_A, op_nop, do_store_C ;4F ;LD C,A
instr do_fetch_B, op_nop, do_store_D ;50 ;LD D,B
instr do_fetch_C, op_nop, do_store_D ;51 ;LD D,C
instr do_fetch_D, op_nop, do_store_D ;52 ;LD D,D
instr do_fetch_E, op_nop, do_store_D ;53 ;LD D,E
instr do_fetch_H, op_nop, do_store_D ;54 ;LD D,H
instr do_fetch_L, op_nop, do_store_D ;55 ;LD D,L
instr do_fetch_MHL, op_nop, do_store_D ;56 ;LD D,(HL)
instr do_fetch_A, op_nop, do_store_D ;57 ;LD D,A
instr do_fetch_B, op_nop, do_store_E ;58 ;LD E,B
instr do_fetch_C, op_nop, do_store_E ;59 ;LD E,C
instr do_fetch_D, op_nop, do_store_E ;5A ;LD E,D
instr do_fetch_E, op_nop, do_store_E ;5B ;LD E,E
instr do_fetch_H, op_nop, do_store_E ;5C ;LD E,H
instr do_fetch_L, op_nop, do_store_E ;5D ;LD E,L
instr do_fetch_MHL, op_nop, do_store_E ;5E ;LD E,(HL)
instr do_fetch_A, op_nop, do_store_E ;5F ;LD E,A
instr do_fetch_B, op_nop, do_store_H ;60 ;LD H,B
instr do_fetch_C, op_nop, do_store_H ;61 ;LD H,C
instr do_fetch_D, op_nop, do_store_H ;62 ;LD H,D
instr do_fetch_E, op_nop, do_store_H ;63 ;LD H,E
instr do_fetch_H, op_nop, do_store_H ;64 ;LD H,H
instr do_fetch_L, op_nop, do_store_H ;65 ;LD H,L
instr do_fetch_MHL, op_nop, do_store_H ;66 ;LD H,(HL)
instr do_fetch_A, op_nop, do_store_H ;67 ;LD H,A
instr do_fetch_B, op_nop, do_store_L ;68 ;LD L,B
instr do_fetch_C, op_nop, do_store_L ;69 ;LD L,C
instr do_fetch_D, op_nop, do_store_L ;6A ;LD L,D
instr do_fetch_E, op_nop, do_store_L ;6B ;LD L,E
instr do_fetch_H, op_nop, do_store_L ;6C ;LD L,H
instr do_fetch_L, op_nop, do_store_L ;6D ;LD L,L
instr do_fetch_MHL, op_nop, do_store_L ;6E ;LD L,(HL)
instr do_fetch_A, op_nop, do_store_L ;6F ;LD L,A
instr do_fetch_B, op_nop, do_store_MHL ;70 ;LD (HL),B
instr do_fetch_C, op_nop, do_store_MHL ;71 ;LD (HL),C
instr do_fetch_D, op_nop, do_store_MHL ;72 ;LD (HL),D
instr do_fetch_E, op_nop, do_store_MHL ;73 ;LD (HL),E
instr do_fetch_H, op_nop, do_store_MHL ;74 ;LD (HL),H
instr do_fetch_L, op_nop, do_store_MHL ;75 ;LD (HL),L
instr do_fetch_nop, op_INV, do_store_nop ;76 ;HALT
instr do_fetch_A, op_nop, do_store_MHL ;77 ;LD (HL),A
instr do_fetch_B, op_nop, do_store_A ;78 ;LD A,B
instr do_fetch_C, op_nop, do_store_A ;79 ;LD A,C
instr do_fetch_D, op_nop, do_store_A ;7A ;LD A,D
instr do_fetch_E, op_nop, do_store_A ;7B ;LD A,E
instr do_fetch_H, op_nop, do_store_A ;7C ;LD A,H
instr do_fetch_L, op_nop, do_store_A ;7D ;LD A,L
instr do_fetch_MHL, op_nop, do_store_A ;7E ;LD A,(HL)
instr do_fetch_A, op_nop, do_store_A ;7F ;LD A,A
instr do_fetch_B, op_ADDA, do_store_nop ;80 ;ADD A,B
instr do_fetch_C, op_ADDA, do_store_nop ;81 ;ADD A,C
instr do_fetch_D, op_ADDA, do_store_nop ;82 ;ADD A,D
instr do_fetch_E, op_ADDA, do_store_nop ;83 ;ADD A,E
instr do_fetch_H, op_ADDA, do_store_nop ;84 ;ADD A,H
instr do_fetch_L, op_ADDA, do_store_nop ;85 ;ADD A,L
instr do_fetch_MHL, op_ADDA, do_store_nop ;86 ;ADD A,(HL)
instr do_fetch_A, op_ADDA, do_store_nop ;87 ;ADD A,A
instr do_fetch_B, op_ADCA, do_store_nop ;88 ;ADC A,B
instr do_fetch_C, op_ADCA, do_store_nop ;89 ;ADC A,C
instr do_fetch_D, op_ADCA, do_store_nop ;8A ;ADC A,D
instr do_fetch_E, op_ADCA, do_store_nop ;8B ;ADC A,E
instr do_fetch_H, op_ADCA, do_store_nop ;8C ;ADC A,H
instr do_fetch_L, op_ADCA, do_store_nop ;8D ;ADC A,L
instr do_fetch_MHL, op_ADCA, do_store_nop ;8E ;ADC A,(HL)
instr do_fetch_A, op_ADCA, do_store_nop ;8F ;ADC A,A
instr do_fetch_B, op_SUBFA, do_store_nop ;90 ;SUB A,B
instr do_fetch_C, op_SUBFA, do_store_nop ;91 ;SUB A,C
instr do_fetch_D, op_SUBFA, do_store_nop ;92 ;SUB A,D
instr do_fetch_E, op_SUBFA, do_store_nop ;93 ;SUB A,E
instr do_fetch_H, op_SUBFA, do_store_nop ;94 ;SUB A,H
instr do_fetch_L, op_SUBFA, do_store_nop ;95 ;SUB A,L
instr do_fetch_MHL, op_SUBFA, do_store_nop ;96 ;SUB A,(HL)
instr do_fetch_A, op_SUBFA, do_store_nop ;97 ;SUB A,A
instr do_fetch_B, op_SBCFA, do_store_nop ;98 ;SBC A,B
instr do_fetch_C, op_SBCFA, do_store_nop ;99 ;SBC A,C
instr do_fetch_D, op_SBCFA, do_store_nop ;9A ;SBC A,D
instr do_fetch_E, op_SBCFA, do_store_nop ;9B ;SBC A,E
instr do_fetch_H, op_SBCFA, do_store_nop ;9C ;SBC A,H
instr do_fetch_L, op_SBCFA, do_store_nop ;9D ;SBC A,L
instr do_fetch_MHL, op_SBCFA, do_store_nop ;9E ;SBC A,(HL)
instr do_fetch_A, op_SBCFA, do_store_nop ;9F ;SBC A,A
instr do_fetch_B, op_ANDA, do_store_nop ;A0 ;AND A,B
instr do_fetch_C, op_ANDA, do_store_nop ;A1 ;AND A,C
instr do_fetch_D, op_ANDA, do_store_nop ;A2 ;AND A,D
instr do_fetch_E, op_ANDA, do_store_nop ;A3 ;AND A,E
instr do_fetch_H, op_ANDA, do_store_nop ;A4 ;AND A,H
instr do_fetch_L, op_ANDA, do_store_nop ;A5 ;AND A,L
instr do_fetch_MHL, op_ANDA, do_store_nop ;A6 ;AND A,(HL)
instr do_fetch_A, op_ANDA, do_store_nop ;A7 ;AND A,A
instr do_fetch_B, op_XORA, do_store_nop ;A8 ;XOR A,B
instr do_fetch_C, op_XORA, do_store_nop ;A9 ;XOR A,C
instr do_fetch_D, op_XORA, do_store_nop ;AA ;XOR A,D
instr do_fetch_E, op_XORA, do_store_nop ;AB ;XOR A,E
instr do_fetch_H, op_XORA, do_store_nop ;AC ;XOR A,H
instr do_fetch_L, op_XORA, do_store_nop ;AD ;XOR A,L
instr do_fetch_MHL, op_XORA, do_store_nop ;AE ;XOR A,(HL)
instr do_fetch_A, op_XORA, do_store_nop ;AF ;XOR A,A
instr do_fetch_B, op_ORA, do_store_nop ;B0 ;OR A,B
instr do_fetch_C, op_ORA, do_store_nop ;B1 ;OR A,C
instr do_fetch_D, op_ORA, do_store_nop ;B2 ;OR A,D
instr do_fetch_E, op_ORA, do_store_nop ;B3 ;OR A,E
instr do_fetch_H, op_ORA, do_store_nop ;B4 ;OR A,H
instr do_fetch_L, op_ORA, do_store_nop ;B5 ;OR A,L
instr do_fetch_MHL, op_ORA, do_store_nop ;B6 ;OR A,(HL)
instr do_fetch_A, op_ORA, do_store_nop ;B7 ;OR A,A
instr do_fetch_B, op_CPFA, do_store_nop ;B8 ;CP A,B
instr do_fetch_C, op_CPFA, do_store_nop ;B9 ;CP A,C
instr do_fetch_D, op_CPFA, do_store_nop ;BA ;CP A,D
instr do_fetch_E, op_CPFA, do_store_nop ;BB ;CP A,E
instr do_fetch_H, op_CPFA, do_store_nop ;BC ;CP A,H
instr do_fetch_L, op_CPFA, do_store_nop ;BD ;CP A,L
instr do_fetch_MHL, op_CPFA, do_store_nop ;BE ;CP A,(HL)
instr do_fetch_A, op_CPFA, do_store_nop ;BF ;CP A,A
instr do_fetch_nop, op_IFNZ, do_store_RET ;C0 ;RET NZ
instr do_fetch_nop, op_POP16, do_store_BC ;C1 ;POP BC
instr do_fetch_DIR16, op_IFNZ, do_store_PC ;C2 nn nn ;JP NZ,nn
instr do_fetch_DIR16, op_nop, do_store_PC ;C3 nn nn ;JP nn
instr do_fetch_DIR16, op_IFNZ, do_store_CALL ;C4 nn nn ;CALL NZ,nn
instr do_fetch_BC, op_PUSH16, do_store_nop ;C5 ;PUSH BC
instr do_fetch_DIR8, op_ADDA, do_store_nop ;C6 nn ;ADD A,n
instr do_fetch_RST, op_nop, do_store_CALL ;C7 ;RST 0
instr do_fetch_nop, op_IFZ, do_store_RET ;C8 ;RET Z
instr do_fetch_nop, op_nop, do_store_RET ;C9 ;RET
instr do_fetch_DIR16, op_IFZ, do_store_PC ;CA nn nn ;JP Z,nn
instr do_fetch_nop, op_INV, do_store_nop ;CB ;(Z80 specific)
instr do_fetch_DIR16, op_IFZ, do_store_CALL ;CC nn nn ;CALL Z,nn
instr do_fetch_DIR16, op_nop, do_store_CALL ;CD nn nn ;CALL nn
instr do_fetch_DIR8, op_ADCA, do_store_nop ;CE nn ;ADC A,n
instr do_fetch_RST, op_nop, do_store_CALL ;CF ;RST 8H
instr do_fetch_nop, op_IFNC, do_store_RET ;D0 ;RET NC
instr do_fetch_nop, op_POP16, do_store_DE ;D1 ;POP DE
instr do_fetch_DIR16, op_IFNC, do_store_PC ;D2 nn nn ;JP NC,nn
instr do_fetch_DIR8, op_OUTA, do_store_nop ;D3 nn ;OUT (n),A
instr do_fetch_DIR16, op_IFNC, do_store_CALL ;D4 nn nn ;CALL NC,nn
instr do_fetch_DE, op_PUSH16, do_store_nop ;D5 ;PUSH DE
instr do_fetch_DIR8, op_SUBFA, do_store_nop ;D6 nn ;SUB n
instr do_fetch_RST, op_nop, do_store_CALL ;D7 ;RST 10H
instr do_fetch_nop, op_IFC, do_store_RET ;D8 ;RET C
instr do_fetch_nop, op_nop, do_store_nop ;D9 ;EXX
instr do_fetch_DIR16, op_IFC, do_store_PC ;DA nn nn ;JP C,nn
instr do_fetch_DIR8, op_IN, do_store_A ;DB nn ;IN A,(n)
instr do_fetch_DIR16, op_IFC, do_store_CALL ;DC nn nn ;CALL C,nn
instr do_fetch_nop, op_INV, do_store_nop ;DD ;(Z80 specific)
instr do_fetch_DIR8, op_SBCFA, do_store_nop ;DE nn ;SBC A,n
instr do_fetch_RST, op_nop, do_store_CALL ;DF ;RST 18H
instr do_fetch_nop, op_IFPO, do_store_RET ;E0 ;RET PO
instr do_fetch_nop, op_POP16, do_store_HL ;E1 ;POP HL
instr do_fetch_DIR16, op_IFPO, do_store_PC ;E2 nn nn ;JP PO,nn
instr do_fetch_MSP, op_EXHL, do_store_MSP ;E3 ;EX (SP),HL
instr do_fetch_DIR16, op_IFPO, do_store_CALL ;E4 nn nn ;CALL PO,nn
instr do_fetch_HL, op_PUSH16, do_store_nop ;E5 ;PUSH HL
instr do_fetch_DIR8, op_ANDA, do_store_nop ;E6 nn ;AND n
instr do_fetch_RST, op_nop, do_store_CALL ;E7 ;RST 20H
instr do_fetch_nop, op_IFPE, do_store_RET ;E8 ;RET PE
instr do_fetch_HL, op_nop, do_store_PC ;E9 ;JP HL
instr do_fetch_DIR16, op_IFPE, do_store_PC ;EA nn nn ;JP PE,nn
instr do_fetch_DE, op_EXHL, do_store_DE ;EB ;EX DE,HL
instr do_fetch_DIR16, op_IFPE, do_store_CALL ;EC nn nn ;CALL PE,nn
instr do_fetch_nop, op_INV, do_store_nop ;ED ;(Z80 specific)
instr do_fetch_DIR8, op_XORA, do_store_nop ;EE nn ;XOR n
instr do_fetch_RST, op_nop, do_store_CALL ;EF ;RST 28H
instr do_fetch_nop, op_IFP, do_store_RET ;F0 ;RET P
instr do_fetch_nop, op_POP16, do_store_AF ;F1 ;POP AF
instr do_fetch_DIR16, op_IFP, do_store_PC ;F2 nn nn ;JP P,nn
instr do_fetch_nop, op_DI, do_store_nop ;F3 ;DI
instr do_fetch_DIR16, op_IFP, do_store_CALL ;F4 nn nn ;CALL P,nn
instr do_fetch_AF, op_PUSH16, do_store_nop ;F5 ;PUSH AF
instr do_fetch_DIR8, op_ORA, do_store_nop ;F6 nn ;OR n
instr do_fetch_RST, op_nop, do_store_CALL ;F7 ;RST 30H
instr do_fetch_nop, op_IFM, do_store_RET ;F8 ;RET M
instr do_fetch_HL, op_nop, do_store_SP ;F9 ;LD SP,HL
instr do_fetch_DIR16, op_IFM, do_store_PC ;FA nn nn ;JP M,nn
instr do_fetch_nop, op_EI, do_store_nop ;FB ;EI
instr do_fetch_DIR16, op_IFM, do_store_CALL ;FC nn nn ;CALL M,nn
instr do_fetch_nop, op_INV, do_store_nop ;FD ;(Z80 specific)
instr do_fetch_DIR8, op_CPFA, do_store_nop ;FE nn ;CP n
instr do_fetch_RST, op_nop, do_store_CALL ;FF ;RST 38H
; Lookup table, stolen from z80ex, Z80 emulation library.
; http://z80ex.sourceforge.net/
; The S, Z, 5 and 3 bits and the parity of the lookup value
.org opcjmp + 256
sz53p_tab:
.db 0x44,0x00,0x00,0x04,0x00,0x04,0x04,0x00
.db 0x08,0x0c,0x0c,0x08,0x0c,0x08,0x08,0x0c
.db 0x00,0x04,0x04,0x00,0x04,0x00,0x00,0x04
.db 0x0c,0x08,0x08,0x0c,0x08,0x0c,0x0c,0x08
.db 0x20,0x24,0x24,0x20,0x24,0x20,0x20,0x24
.db 0x2c,0x28,0x28,0x2c,0x28,0x2c,0x2c,0x28
.db 0x24,0x20,0x20,0x24,0x20,0x24,0x24,0x20
.db 0x28,0x2c,0x2c,0x28,0x2c,0x28,0x28,0x2c
.db 0x04,0x00,0x00,0x04,0x00,0x04,0x04,0x00
.db 0x80,0x84,0x84,0x80,0x84,0x80,0x80,0x84
.db 0x8c,0x88,0x88,0x8c,0x88,0x8c,0x8c,0x88
.db 0x84,0x80,0x80,0x84,0x80,0x84,0x84,0x80
.db 0x88,0x8c,0x8c,0x88,0x8c,0x88,0x88,0x8c
.db 0xa4,0xa0,0xa0,0xa4,0xa0,0xa4,0xa4,0xa0
.db 0xa8,0xac,0xac,0xa8,0xac,0xa8,0xa8,0xac
.db 0xa0,0xa4,0xa4,0xa0,0xa4,0xa0,0xa0,0xa4
.db 0xac,0xa8,0xa8,0xac,0xa8,0xac,0xac,0xa8
; vim:set ts=8 noet nowrap
