; *         ATMEL Microcontroller Software Support 
; * Copyright (c) 2008, Atmel Corporation
; * All rights reserved.
; * Redistribution and use in source and binary forms, with or without
; * modification, are permitted provided that the following conditions are met:
; * - Redistributions of source code must retain the above copyright notice,
; * this list of conditions and the disclaimer below.
; * Atmel's name may not be used to endorse or promote products derived from
; * this software without specific prior written permission.
; * DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR
; * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
; * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
; * DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT,
; * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
; * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
; * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
; * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
; * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
; * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
;     KEIL startup file for AT91SAM7X microcontrollers.
;          Definitions
; Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
ARM_MODE_USR        EQU     0x10
ARM_MODE_FIQ        EQU     0x11
ARM_MODE_IRQ        EQU     0x12
ARM_MODE_SVC        EQU     0x13
ARM_MODE_ABT        EQU     0x17
ARM_MODE_UND        EQU     0x1B
ARM_MODE_SYS        EQU     0x1F
I_BIT               EQU     0x80            ; when I bit is set, IRQ is disabled
F_BIT               EQU     0x40            ; when F bit is set, FIQ is disabled
AT91C_BASE_AIC      EQU     0xFFFFF000
AIC_IVR             EQU     0x100
AIC_EOICR           EQU     0x130
UND_Stack_Size      EQU     0x00000000
SVC_Stack_Size      EQU     0x00000400
ABT_Stack_Size      EQU     0x00000000
FIQ_Stack_Size      EQU     0x00000000
IRQ_Stack_Size      EQU     0x00000080
USR_Stack_Size      EQU     0x00000400
        PRESERVE8
; Area Definition and Entry Point
; Startup Code must be linked first at Address at which it expects to run.
        AREA    VECTOR, CODE
        ARM
; Exception Vectors
Vectors         
				LDR     pc,=resetHandler 
undefVector  
			    b   	undefVector             ; Undefined instruction
swiVector
        		b       swiVector               ; Software interrupt
prefetchAbortVector
        		b       prefetchAbortVector     ; Prefetch abort
dataAbortVector
        		b       dataAbortVector         ; Data abort
reservedVector
        		b       reservedVector          ; Reserved for future use
irqVector
        b       irqHandler              ; Interrupt
fiqVector
                                        ; Fast interrupt
; Handles a fast interrupt request by branching to the address defined in the
; AIC.
fiqHandler
        b       fiqHandler
; Handles incoming interrupt requests by branching to the corresponding
; handler, as defined in the AIC. Supports interrupt nesting.
irqHandler
        ;  Save interrupt context on the stack to allow nesting */
        SUB     lr, lr, #4
        STMFD   sp!, {lr}
        MRS     lr, SPSR
        STMFD   sp!, {r0,r1,lr}
        ; Write in the IVR to support Protect Mode */
        LDR     lr, =AT91C_BASE_AIC
        LDR     r0, [r14, #AIC_IVR]
        STR     lr, [r14, #AIC_IVR]
        ; Branch to interrupt handler in Supervisor mode */
        MSR     CPSR_c, #ARM_MODE_SVC
        STMFD   sp!, {r1-r4, r12, lr}
        MOV     lr, pc
        BX      r0
        LDMIA   sp!, {r1-r4, r12, lr}
        MSR     CPSR_c, #ARM_MODE_IRQ :OR: I_BIT
        ; Acknowledge interrupt */
        STR     lr, [r14, #AIC_EOICR]
        ; Restore interrupt context and branch back to calling code
        LDMIA   sp!, {r0,r1,lr}
        MSR     SPSR_cxsf, lr
        LDMIA   sp!, {pc}^
; After a reset, execution starts here, the mode is ARM, supervisor
; with interrupts disabled.
; Initializes the chip and branches to the main() function.
   		AREA  cstartup, CODE
   		ENTRY        ; Entry point for the application
; Reset Handler
        EXPORT  resetHandler
        IMPORT	|Image$$Fixed_region$$Limit|
        IMPORT  |Image$$Relocate_region$$Base|
        IMPORT  |Image$$Relocate_region$$ZI$$Base|
        IMPORT  |Image$$Relocate_region$$ZI$$Limit|
        IMPORT  |Image$$ARM_LIB_STACK$$Base|
        IMPORT  |Image$$ARM_LIB_STACK$$ZI$$Limit|
		; Perform low-level initialization of the chip using LowLevelInit()
		IMPORT  LowLevelInit
resetHandler   
        ; Set pc to actual code location (i.e. not in remap zone)
	    LDR     pc, =label
label	    
		; Set up temporary stack (Top of the SRAM)
		LDR     r0, = |Image$$ARM_LIB_STACK$$ZI$$Limit|
        MOV     sp, r0
		; Call Low level init
	    LDR     r0, =LowLevelInit
        MOV     lr, pc
        BX      r0
;Initialize the Relocate_region segment 
		LDR 	r0, = |Image$$Fixed_region$$Limit|
		LDR 	r1, = |Image$$Relocate_region$$Base|
		LDR 	r3, = |Image$$Relocate_region$$ZI$$Base|
	    CMP     r0, r1                 
     	BEQ     %1
        ; Copy init data
0       CMP     r1, r3         
        LDRCC   r2, [r0], #4   
        STRCC   r2, [r1], #4
        BCC     %0
1       LDR     r1, =|Image$$Relocate_region$$ZI$$Limit|
        MOV     r2, #0
2       CMP     r3, r1                  
        STRCC   r2, [r3], #4
        BCC     %2
; Setup Stack for each mode
        LDR     R0, = |Image$$ARM_LIB_STACK$$ZI$$Limit|
;  Enter IRQ Mode and set its Stack Pointer
        MSR     CPSR_c, #ARM_MODE_IRQ:OR:I_BIT:OR:F_BIT
        MOV     SP, R0
        SUB     R4, SP, #IRQ_Stack_Size
; Supervisor mode (interrupts enabled) 
        MSR     CPSR_c, #ARM_MODE_SVC :OR: F_BIT
        MOV     SP, R4   
; Enter the C code
        IMPORT  __main
        LDR     R0, =__main
        BX      R0
loop4
        B       loop4
       END
