//   MSP430xG46x Demo - USCI_A0, 115200 UART Echo ISR, DCO SMCLK, LPM3
//   Description: Echo a received character, RX ISR used. Normal mode is LPM3.
//   Automatic clock activation for SMCLK through the USCI is demonstrated.
//   USCI_A0 RX interrupt triggers TX Echo.
//   Baud rate divider with 1048576hz = 1048576/115200 = ~9.1 (009h|01h)
//   ACLK = LFXT1 = 32768Hz, MCLK = SMCLK = default DCO = 32 x ACLK = 1048576Hz
//   //* An external watch crystal between XIN & XOUT is required for ACLK *//	
//                MSP430xG461x
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P4.6/UCA0TXD|------------>
//            |                 | 115200 - 8N1
//            |     P4.7/UCA0RXD|<------------
//   A. Dannenberg/ M. Mitchell
//   Texas Instruments Inc.
//   October 2006
//   Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include  "msp430xG46x.h"
void main(void)
 volatile unsigned int i;
  WDTCTL = WDTPW+WDTHOLD;                   // Stop WDT
  FLL_CTL0 |= XCAP14PF;                     // Configure load caps
  do
  IFG1 &= ~OFIFG;                           // Clear OSCFault flag
  for (i = 0x47FF; i > 0; i--);             // Time for flag to set
  while ((IFG1 & OFIFG));                   // OSCFault flag still set?
  P4SEL |= 0x0C0;                           // P4.7,6 = USCI_A0 RXD/TXD
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 0x09;                           // 1MHz 115200
  UCA0BR1 = 0x00;                           // 1MHz 115200
  UCA0MCTL = 0x02;                          // Modulation
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM4, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
  UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character
