//*				LCD_driver.c: Interface for Nokia LCD
//*	Edit History
//*		<MLS>	= Mark Sproul msproul -at- jove.rutgers.edu
//*	Apr  2,	2010	<MLS> I received my Color LCD Shield sku: LCD-09363 from sparkfun
//*	Apr  2,	2010	<MLS> The code was written for WinAVR, I modified it to compile under Arduino
//*	Apr  3,	2010	<MLS> Changed LCDSetPixel to make it "RIGHT" side up
//*	Apr  3,	2010	<MLS> Made LCDSetPixel public
//*	Apr  3,	2010	<MLS> Working on MEGA, pin defs in nokia_tester.h
//*	Apr  4,	2010	<MLS> Removed delays from LCDCommand & LCDCommand, increased speed by 75%
#include "LCD_driver.h"
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#ifdef _USE_ARDUINO_FOR_NOKIEA_
	#include	"WProgram.h"
#endif
//Usage: LCDClear(black);
//Inputs: char color: 8-bit color to be sent to the screen.
//Outputs: None
//Description: This function will clear the screen with "color" by writing the
//				color to each location in the RAM of the LCD.
void LCDClear(int color)
unsigned int i;
	#ifdef EPSON
		LCDCommand(PASET);
		LCDData(0);
		LCDData(131);
		LCDCommand(CASET);
		LCDData(0);
		LCDData(131);
		LCDCommand(RAMWR);
	#endif
	#ifdef	PHILLIPS
		LCDCommand(PASETP);
		LCDData(0);
		LCDData(131);
		LCDCommand(CASETP);
		LCDData(0);
		LCDData(131);
		LCDCommand(RAMWRP);
	#endif
	for (i=0; i < (131*131)/2; i++)
		LCDData((color >> 4) & 0x00FF);
		LCDData(((color & 0x0F) << 4) | (color >> 8));
		LCDData(color & 0x0FF);		// nop(EPSON)
//	x_offset = 0;
//	y_offset = 0;
void	delay_us(int microSecs)
	delayMicroseconds(microSecs);
void	delay_ms(int millisecs)
//	delay(millisecs);
//	delayMicroseconds(millisecs * 1000);
//Usage: LCDCommand(RAMWR);
//Inputs: char data - character command to be sent to the LCD
//Outputs: None
void LCDCommand(unsigned char data)
char jj;
	cbi(LCD_PORT_CS, CS);		// enable chip, p0.20 goes low
	//delay_us(1);
	cbi(LCD_PORT_DIO, DIO);		// output low on data out (9th bit low = command), p0.19
	//delay_us(1);
	cbi(LCD_PORT_SCK, SCK);		// send clock pulse
	delay_us(1);
	sbi(LCD_PORT_SCK, SCK);
	//delay_us(1);
	for (jj = 0; jj < 8; jj++)
		if ((data & 0x80) == 0x80)
			sbi(LCD_PORT_DIO, DIO);
		else
		//delay_us(1);
	//+	delay_us(1);
		data <<= 1;
	sbi(LCD_PORT_CS, CS);			// disable
//Usage: LCDData(RAMWR);
//Inputs: char data - character data to be sent to the LCD
//Outputs: None
void LCDData(unsigned char data)
char j;
	//delay_us(1);
	sbi(LCD_PORT_DIO, DIO);			// output high on data out (9th bit high = data), p0.19
	//delay_us(1);
//+	delay_us(1);
	sbi(LCD_PORT_SCK, SCK);			// send clock pulse
	//delay_us(1);
	for (j = 0; j < 8; j++)
		else
		//delay_us(1);
//+		delay_us(1);
		data <<= 1;
	LCD_PORT_CS	|=	(1<<CS);		// disable
//Usage: LCDInit();
//Inputs: None
//Outputs: None
//Description:  Initializes the LCD regardless of if the controlller is an EPSON or PHILLIPS.
void LCDInit(void)
	delay_ms(200);
	cbi(LCD_PORT_SCK, SCK);			//output_low (SPI_CLK);//output_low (SPI_DO);
	delay_us(10);
	sbi(LCD_PORT_CS, CS);			//output_high (LCD_CS);
	delay_us(10);
	cbi(LCD_PORT_RES, LCD_RES);		//output_low (LCD_RESET);
	delay_ms(200);
	sbi(LCD_PORT_RES, LCD_RES);		//output_high (LCD_RESET);
	delay_ms(200);
	delay_us(10);
	LCDCommand(DISCTL);		// display control(EPSON)
	LCDData(0x0C);			// 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
	LCDData(0x20);
	//LCDData(0x02);
	LCDData(0x00);
	LCDData(0x01);
	LCDCommand(COMSCN);		// common scanning direction(EPSON)
	LCDData(0x01);
	LCDCommand(OSCON);		// internal oscialltor ON(EPSON)
	LCDCommand(SLPOUT);		// sleep out(EPSON)
	LCDCommand(P_SLEEPOUT);	//sleep out(PHILLIPS)
	LCDCommand(PWRCTR);		// power ctrl(EPSON)
	LCDData(0x0F);			//everything on, no external reference resistors
	LCDCommand(P_BSTRON);	//Booset On(PHILLIPS)
	LCDCommand(DISINV);		// invert display mode(EPSON)
	LCDCommand(P_INVON);	// invert display mode(PHILLIPS)
	LCDCommand(DATCTL);		// data control(EPSON)
	LCDData(0x03);			// correct for normal sin7
	LCDData(0x00);			// normal RGB arrangement
	//LCDData(0x01);		// 8-bit Grayscale
	LCDData(0x02);			// 16-bit Grayscale Type A
	LCDCommand(P_MADCTL);	//Memory Access Control(PHILLIPS)
	LCDData(0xC8);
	LCDCommand(P_COLMOD);	// Set Color Mode(PHILLIPS)
	LCDData(0x02);
	LCDCommand(VOLCTR);		// electronic volume, this is the contrast/brightness(EPSON)
	//LCDData(0x18);		// volume (contrast) setting - fine tuning, original
	LCDData(0x24);			// volume (contrast) setting - fine tuning, original
	LCDData(0x03);			// internal resistor ratio - coarse adjustment
	LCDCommand(P_SETCON);	// Set Contrast(PHILLIPS)
	LCDData(0x30);
	LCDCommand(NOP);		// nop(EPSON)
	LCDCommand(P_NOP);		// nop(PHILLIPS)
	delay_ms(200);
	LCDCommand(DISON);		// display on(EPSON)
	LCDCommand(P_DISPON);	// display on(PHILLIPS)
//Usage: LCDSetPixel(white, 0, 0);
//Inputs: unsigned char color - desired color of the pixel
//			unsigned char x - Page address of pixel to be colored
//			unsigned char y - column address of pixel to be colored
//Outputs: None
//Description: Sets the starting page(row) and column (x & y) coordinates in ram,
//				then writes the colour to display memory.	The ending x & y are left
//				maxed out so one can continue sending colour data bytes to the 'open'
//				RAMWR command to fill further memory.	issuing any red command
//				finishes RAMWR.
//**NOTE** Because this function is static, it is essentially a "private" function
//		and can only be used within this file!
void LCDSetPixel(int color, unsigned char x, unsigned char y)
	y	=	(COL_HEIGHT - 1) - y;
        x       =       (ROW_LENGTH - 1) - x;
	#ifdef EPSON
		LCDCommand(PASET);	// page start/end ram
		LCDData(x);
		LCDData(ENDPAGE);
		LCDCommand(CASET);	// column start/end ram
		LCDData(y);
		LCDData(ENDCOL);
		LCDCommand(RAMWR);	// write
		LCDData((color>>4)&0x00FF);
		LCDData(((color&0x0F)<<4)|(color>>8));
		LCDData(color&0x0FF);		// nop(EPSON)
		//LCDData(color);
		//LCDData(NOP);
		//LCDData(NOP);
	#endif
	#ifdef	PHILLIPS
		LCDCommand(PASETP);	// page start/end ram
		LCDData(x);
		LCDData(ENDPAGE);
		LCDCommand(CASETP);	// column start/end ram
		LCDData(y);
		LCDData(ENDCOL);
		LCDCommand(RAMWRP);	// write
		LCDData((unsigned char)((color>>4)&0x00FF));
		LCDData((unsigned char)(((color&0x0F)<<4)|0x00));
	#endif
void ioinit(void)
  	//*	setup the switches for input
	pinMode(kSwitch1_PIN, INPUT);
	pinMode(kSwitch2_PIN, INPUT);
	pinMode(kSwitch3_PIN, INPUT);
	//*	set the pull up resisters
	digitalWrite(kSwitch1_PIN, HIGH);
	digitalWrite(kSwitch2_PIN, HIGH);
	digitalWrite(kSwitch3_PIN, HIGH);
	//*	do the LCD control lines
	pinMode(CS_PIN,			OUTPUT);
	pinMode(DIO_PIN,		OUTPUT);
	pinMode(SCK_PIN,		OUTPUT);
	pinMode(LCD_RES_PIN,	OUTPUT);
#else
	DDRB	=	((1<<CS)|(1<<DIO)|(1<<SCK)|(1<<LCD_RES));	//Set the control pins as outputs
	// USART Baud rate: 115200 (With 16 MHz Clock)
	UBRR0H	=	(MYUBRR >> 8) & 0x7F;	//Make sure highest bit(URSEL) is 0 indicating we are writing to UBRRH
	UBRR0L	=	MYUBRR;
	UCSR0A	=	(1<<U2X0);					//Double the UART Speed
	UCSR0B	=	(1<<RXEN0)|(1<<TXEN0);		//Enable Rx and Tx in UART
	UCSR0C	=	(1<<UCSZ00)|(1<<UCSZ01);		//8-Bit Characters
//	stdout	=	&mystdout; //Required for printf init
	cli();
	// Arduino D3-5 are button pins
	// This is PD3-5
	DDRD	=	0x00;
	PORTD	=	0xFF;
	// Init timer 2
	//Set Prescaler to 8. (Timer Frequency set to 16Mhz)
	//Used for delay routines
	TCCR2B	=	(1<<CS20); 	//Divde clock by 1 for 16 Mhz Timer 2 Frequency
#endif
//***                        Set line                                  ***
void LCDSetLine(int x0, int y0, int x1, int y1, int color) {
int dy = y1 - y0;// Difference between y0 and y1
int dx = x1 - x0;// Difference between x0 and x1
int stepx, stepy;
if (dy < 0) { dy = -dy; stepy = -1; } else { stepy = 1; }
if (dx < 0) { dx = -dx; stepx = -1; } else { stepx = 1; }
dy <<= 1;// dy is now 2*dy
dx <<= 1;// dx is now 2*dx
LCDSetPixel(color, x0, y0);
if (dx > dy) {
int fraction = dy - (dx >> 1);
while (x0 != x1) {
if (fraction >= 0) {
y0 += stepy;
fraction -= dx;
x0 += stepx;
fraction += dy;
} else {
int fraction = dx - (dy >> 1);
while (y0 != y1) {
x0 += stepx;
fraction -= dy;
y0 += stepy;
fraction += dx;
//***                   Set rectangle                                  ***
void LCDSetRect(int x0, int y0, int x1, int y1, unsigned char fill, int color) {
// check if the rectangle is to be filled
if (fill == 1) {
int xDiff;
if(x0 > x1){ //Find the difference between the x vars
  xDiff = x0 - x1;
}else{
  xDiff = x1 - x0;
while(xDiff > 0){
LCDSetLine(x0, y0, x0, y1, color);
if(x0 > x1){
  x0--;
}else{
  x0++;
xDiff--;
} else {
// best way to draw an unfilled rectangle is to draw four lines
LCDSetLine(x0, y0, x1, y0, color);
LCDSetLine(x0, y1, x1, y1, color);
LCDSetLine(x1, y0, x1, y1, color);
//LCDPutChar.c
//Draws an ASCII character at the specified (x,y) address and color
//Inputs:
//c      = character to be displayed
//x      = row address (0 .. 131)
//y      = column address (0 .. 131)
//size   = font pitch (SMALL, MEDIUM, LARGE)
//fcolor = 12-bit foreground color value
//bcolor = 12-bit background color value
//Returns: nothing
// Author: James P Lynch, August 30, 2007
// Edited by Peter Davenport on August 23, 2010
//For more information on how this code does it's thing look at this
//"http://www.sparkfun.com/tutorial/Nokia%206100%20LCD%20Display%20Driver.pdf"
void LCDPutChar(char c, int x, int y, int fColor, int bColor) {
	y	=	(COL_HEIGHT - 1) - y; // make display "right" side up
	x	=	(ROW_LENGTH - 2) - x;
extern const unsigned char FONT8x16[97][16];
int             i,j;
unsigned int    nCols;
unsigned int    nRows;
unsigned int    nBytes;
unsigned char   PixelRow;
unsigned char   Mask;
unsigned int    Word0;
unsigned int    Word1;
unsigned char   *pFont;
unsigned char   *pChar;
// get pointer to the beginning of the selected font table
pFont = (unsigned char *)FONT8x16;
// get the nColumns, nRows and nBytes
nCols = *pFont;
nRows = *(pFont + 1);
nBytes = *(pFont + 2);
// get pointer to the last byte of the desired character
pChar = pFont + (nBytes * (c - 0x1F)) + nBytes - 1;
// Row address set (command 0x2B)
LCDCommand(PASET);
LCDData(x);
LCDData(x + nRows - 1);
// Column address set (command 0x2A)
LCDCommand(CASET);
LCDData(y);
LCDData(y + nCols - 1);
// WRITE MEMORY
LCDCommand(RAMWR);
// loop on each row, working backwards from the bottom to the top
for (i = nRows - 1; i >= 0; i--) {
  // copy pixel row from font table and then decrement row
  PixelRow = *pChar++;
  // loop on each pixel in the row (left to right)
  // Note: we do two pixels each loop
  Mask = 0x80;
  for (j = 0; j < nCols; j += 2) {
    // if pixel bit set, use foreground color; else use the background color
    // now get the pixel color for two successive pixels
    if ((PixelRow & Mask) == 0)
    Word0 = bColor;
    else
    Word0 = fColor;
    Mask = Mask >> 1;
    Word1 = bColor;
    else
    Word1 = fColor;
    Mask = Mask >> 1;
    // use this information to output three data bytes
    LCDData((Word0 >> 4) & 0xFF);
    LCDData(((Word0 & 0xF) << 4) | ((Word1 >> 8) & 0xF));
    LCDData(Word1 & 0xFF);
// terminate the Write Memory command
LCDCommand(NOP);
//LCDPutStr.c
//Draws a null-terminates character string at the specified (x,y) address and color
// Inputs: pString = pointer to character string to be displayed
// x = row address (0 .. 131)
// y = column address (0 .. 131)
// Size = font pitch (SMALL, MEDIUM, LARGE)
// fColor = 12-bit foreground color value rrrrggggbbbb
// bColor = 12-bit background color value rrrrggggbbbb
// Returns: nothing
// Notes: Here's an example to display "Hello World!" at address (20,20)
// LCDPutChar("Hello World!", 20, 20, WHITE, BLACK);
void LCDPutStr(char *pString, int x, int y, int fColor, int bColor) {
  x = x + 16;
  y = y + 8;
  // loop until null-terminator is seen
  while (*pString != 0x00) {
    // draw the character
    LCDPutChar(*pString++, x, y, fColor, bColor);
    // advance the y position
    y = y + 8;
    // bail out if y exceeds 131
    if (y > 131) break;
const unsigned char FONT8x16[97][16] = {
0x08,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x18,0x3C,0x3C,0x3C,0x18,0x18,0x18,0x00,0x18,0x18,0x00,0x00,0x00,0x00,
0x00,0x63,0x63,0x63,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x36,0x36,0x7F,0x36,0x36,0x36,0x7F,0x36,0x36,0x00,0x00,0x00,0x00,
0x0C,0x0C,0x3E,0x63,0x61,0x60,0x3E,0x03,0x03,0x43,0x63,0x3E,0x0C,0x0C,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x61,0x63,0x06,0x0C,0x18,0x33,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x1C,0x36,0x36,0x1C,0x3B,0x6E,0x66,0x66,0x3B,0x00,0x00,0x00,0x00,
0x00,0x30,0x30,0x30,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0C,0x18,0x18,0x30,0x30,0x30,0x30,0x18,0x18,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x18,0x0C,0x0C,0x06,0x06,0x06,0x06,0x0C,0x0C,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x42,0x66,0x3C,0xFF,0x3C,0x66,0x42,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x18,0x18,0x18,0xFF,0x18,0x18,0x18,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x18,0x30,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x01,0x03,0x07,0x0E,0x1C,0x38,0x70,0xE0,0xC0,0x80,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x63,0x6B,0x6B,0x63,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x0C,0x1C,0x3C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x3F,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x03,0x06,0x0C,0x18,0x30,0x61,0x63,0x7F,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x03,0x03,0x1E,0x03,0x03,0x03,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x0E,0x1E,0x36,0x66,0x66,0x7F,0x06,0x06,0x0F,0x00,0x00,0x00,0x00,
0x00,0x00,0x7F,0x60,0x60,0x60,0x7E,0x03,0x03,0x63,0x73,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x1C,0x30,0x60,0x60,0x7E,0x63,0x63,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x7F,0x63,0x03,0x06,0x06,0x0C,0x0C,0x18,0x18,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x63,0x3E,0x63,0x63,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x63,0x63,0x3F,0x03,0x03,0x06,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x18,0x18,0x18,0x30,0x00,0x00,
0x00,0x00,0x00,0x06,0x0C,0x18,0x30,0x60,0x30,0x18,0x0C,0x06,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x60,0x30,0x18,0x0C,0x06,0x0C,0x18,0x30,0x60,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x06,0x0C,0x0C,0x0C,0x00,0x0C,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x6F,0x6B,0x6B,0x6E,0x60,0x60,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x08,0x1C,0x36,0x63,0x63,0x63,0x7F,0x63,0x63,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x7E,0x33,0x33,0x33,0x3E,0x33,0x33,0x33,0x33,0x7E,0x00,0x00,0x00,0x00,
0x00,0x00,0x1E,0x33,0x61,0x60,0x60,0x60,0x60,0x61,0x33,0x1E,0x00,0x00,0x00,0x00,
0x00,0x00,0x7C,0x36,0x33,0x33,0x33,0x33,0x33,0x33,0x36,0x7C,0x00,0x00,0x00,0x00,
0x00,0x00,0x7F,0x33,0x31,0x34,0x3C,0x34,0x30,0x31,0x33,0x7F,0x00,0x00,0x00,0x00,
0x00,0x00,0x7F,0x33,0x31,0x34,0x3C,0x34,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,
0x00,0x00,0x1E,0x33,0x61,0x60,0x60,0x6F,0x63,0x63,0x37,0x1D,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x63,0x63,0x63,0x7F,0x63,0x63,0x63,0x63,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x3C,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x0F,0x06,0x06,0x06,0x06,0x06,0x06,0x66,0x66,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x73,0x33,0x36,0x36,0x3C,0x36,0x36,0x33,0x33,0x73,0x00,0x00,0x00,0x00,
0x00,0x00,0x78,0x30,0x30,0x30,0x30,0x30,0x30,0x31,0x33,0x7F,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x77,0x7F,0x6B,0x63,0x63,0x63,0x63,0x63,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x63,0x73,0x7B,0x7F,0x6F,0x67,0x63,0x63,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x1C,0x36,0x63,0x63,0x63,0x63,0x63,0x63,0x36,0x1C,0x00,0x00,0x00,0x00,
0x00,0x00,0x7E,0x33,0x33,0x33,0x3E,0x30,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x63,0x63,0x63,0x63,0x6B,0x6F,0x3E,0x06,0x07,0x00,0x00,
0x00,0x00,0x7E,0x33,0x33,0x33,0x3E,0x36,0x36,0x33,0x33,0x73,0x00,0x00,0x00,0x00,
0x00,0x00,0x3E,0x63,0x63,0x30,0x1C,0x06,0x03,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0xFF,0xDB,0x99,0x18,0x18,0x18,0x18,0x18,0x18,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x63,0x63,0x63,0x63,0x63,0x63,0x36,0x1C,0x08,0x00,0x00,0x00,0x00,
0x00,0x00,0x63,0x63,0x63,0x63,0x63,0x6B,0x6B,0x7F,0x36,0x36,0x00,0x00,0x00,0x00,
0x00,0x00,0xC3,0xC3,0x66,0x3C,0x18,0x18,0x3C,0x66,0xC3,0xC3,0x00,0x00,0x00,0x00,
0x00,0x00,0xC3,0xC3,0xC3,0x66,0x3C,0x18,0x18,0x18,0x18,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x7F,0x63,0x43,0x06,0x0C,0x18,0x30,0x61,0x63,0x7F,0x00,0x00,0x00,0x00,
0x00,0x00,0x3C,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x3C,0x00,0x00,0x00,0x00,
0x00,0x00,0x80,0xC0,0xE0,0x70,0x38,0x1C,0x0E,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
0x00,0x00,0x3C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x3C,0x00,0x00,0x00,0x00,
0x08,0x1C,0x36,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
0x18,0x18,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3C,0x46,0x06,0x3E,0x66,0x66,0x3B,0x00,0x00,0x00,0x00,
0x00,0x00,0x70,0x30,0x30,0x3C,0x36,0x33,0x33,0x33,0x33,0x6E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3E,0x63,0x60,0x60,0x60,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x0E,0x06,0x06,0x1E,0x36,0x66,0x66,0x66,0x66,0x3B,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3E,0x63,0x63,0x7E,0x60,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x1C,0x36,0x32,0x30,0x7C,0x30,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3B,0x66,0x66,0x66,0x66,0x3E,0x06,0x66,0x3C,0x00,0x00,
0x00,0x00,0x70,0x30,0x30,0x36,0x3B,0x33,0x33,0x33,0x33,0x73,0x00,0x00,0x00,0x00,
0x00,0x00,0x0C,0x0C,0x00,0x1C,0x0C,0x0C,0x0C,0x0C,0x0C,0x1E,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x06,0x00,0x0E,0x06,0x06,0x06,0x06,0x06,0x66,0x66,0x3C,0x00,0x00,
0x00,0x00,0x70,0x30,0x30,0x33,0x33,0x36,0x3C,0x36,0x33,0x73,0x00,0x00,0x00,0x00,
0x00,0x00,0x1C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x1E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x6E,0x7F,0x6B,0x6B,0x6B,0x6B,0x6B,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x6E,0x33,0x33,0x33,0x33,0x33,0x33,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3E,0x63,0x63,0x63,0x63,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x6E,0x33,0x33,0x33,0x33,0x3E,0x30,0x30,0x78,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3B,0x66,0x66,0x66,0x66,0x3E,0x06,0x06,0x0F,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x6E,0x3B,0x33,0x30,0x30,0x30,0x78,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x3E,0x63,0x38,0x0E,0x03,0x63,0x3E,0x00,0x00,0x00,0x00,
0x00,0x00,0x08,0x18,0x18,0x7E,0x18,0x18,0x18,0x18,0x1B,0x0E,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x66,0x66,0x66,0x66,0x66,0x66,0x3B,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x63,0x63,0x36,0x36,0x1C,0x1C,0x08,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x63,0x63,0x63,0x6B,0x6B,0x7F,0x36,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x63,0x36,0x1C,0x1C,0x1C,0x36,0x63,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x63,0x63,0x63,0x63,0x63,0x3F,0x03,0x06,0x3C,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x7F,0x66,0x0C,0x18,0x30,0x63,0x7F,0x00,0x00,0x00,0x00,
0x00,0x00,0x0E,0x18,0x18,0x18,0x70,0x18,0x18,0x18,0x18,0x0E,0x00,0x00,0x00,0x00,
0x00,0x00,0x18,0x18,0x18,0x18,0x18,0x00,0x18,0x18,0x18,0x18,0x18,0x00,0x00,0x00,
0x00,0x00,0x70,0x18,0x18,0x18,0x0E,0x18,0x18,0x18,0x18,0x70,0x00,0x00,0x00,0x00,
0x00,0x00,0x3B,0x6E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void LCDContrast(char setting) {
     LCDData(setting);        // volume (contrast) setting - course adjustment,  -- original was 24
//     LCDData(0x03);            // internal resistor ratio - coarse adjustment
//     LCDData(0x30);
//LCDDrawCircle
//Draws a full circle, half a circle, or a quarter of a circle
// Inputs:
// xCenter the x for the center of the circle
// yCenter the y for the center of the circle
// radius the radius for the circle
// color the color of the circle
// circleType the type of circle see LCD_driver.h for types of circles
//  This routine can be used to draw a complete circle, half circle or a quarter of a circle
// Returns: Nothing
// I found the original code at http://www.arduino.cc/playground/Code/GLCDks0108 and modified it for
// this library
void LCDDrawCircle (int xCenter, int yCenter, int radius, int color, int circleType)
       int tSwitch, x1 = 0, y1 = radius;
       int Width = 2*radius, Height=Width;
       tSwitch = 3 - 2 * radius;
       while (x1 <= y1) {
         if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENEAST||circleType == OPENSOUTHEAST) {
           LCDSetPixel(color,xCenter+radius - x1, yCenter+radius - y1);
           LCDSetPixel(color,xCenter+radius - y1, yCenter+radius - x1);
         if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENEAST||circleType == OPENNORTHEAST) {
           LCDSetPixel(color,xCenter+Width-radius + x1, yCenter+radius - y1);
           LCDSetPixel(color,xCenter+Width-radius + y1, yCenter+radius - x1);
         if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENWEST||circleType == OPENNORTHWEST) {
           LCDSetPixel(color,xCenter+Width-radius + x1, yCenter+Height-radius + y1);
           LCDSetPixel(color,xCenter+Width-radius + y1, yCenter+Height-radius + x1);
         if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENWEST||circleType == OPENSOUTHWEST) {
           LCDSetPixel(color,xCenter+radius - x1, yCenter+Height-radius + y1);
           LCDSetPixel(color,xCenter+radius - y1, yCenter+Height-radius + x1);
         if (tSwitch < 0) {
               tSwitch += (4 * x1 + 6);
         } else {
               tSwitch += (4 * (x1 - y1) + 10);
             y1--;
         x1++;
