U-Boot 2011.09-00000-gf54ce7f-dirty (Dec 20 2011 - 12:36:29) DRAM: 128 MiB NAND: NAND device: Manufacturer ID: 0xad, Chip ID: 0x76 (Hynix NAND 64MiB 3,3V 8-bit) 64 MiB Bad block table at page 1120, version 0x01 Bad block table at page 1152, version 0x01 In: serial Out: serial Err: serial Net: natsemi: EEPROM contents: d008 0400 0b34 00f3 0000 0000 0000 8b80 7d98 156f 0000 aa7a natsemi: MAC-Address: 0:17:31:FB:DE:2A dp83815#0 Welcome to the pollinux board v1.1 Hit any key to stop autoboot: 0 Loading from nand0, offset 0x94000 Image Name: MIPS Created: 2011-12-19 19:20:07 UTC Image Type: MIPS Linux Kernel Image (gzip compressed) Data Size: 2153323 Bytes = 2.1 MiB Load Address: 80060000 Entry Point: 8039f0c0 ## Booting kernel from Legacy Image at 82000000 ... Image Name: MIPS Created: 2011-12-19 19:20:07 UTC Image Type: MIPS Linux Kernel Image (gzip compressed) Data Size: 2153323 Bytes = 2.1 MiB Load Address: 80060000 Entry Point: 8039f0c0 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Starting kernel ... Linux version 3.1.0.3PNX8550+ (root@macian) (gcc version 4.4.5 (Debian 4.4.5-8) ) #5 Mon Dec 19 20:16:03 CET 2011 CPU revision is: 00061200 (Philips PR4450) Determined physical RAM map: memory: 08000000 @ 00000000 (usable) Initrd not found or empty - disabling initrd Zone PFN ranges: Normal 0x00000000 -> 0x00008000 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x00008000 completed setup_arch() Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512 Kernel command line: console=ttyS1,38400n8 stb810_display=pal nomainapp=1 root=/ dev/sda1 rw ip=192.168.20.160 root=/dev/sda1 rw ip=192.168.20.160 PID hash table entries: 512 (order: -1, 2048 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Primary instruction cache 16kB, VIPT, 2-way, linesize 32 bytes. Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes Memory: 124712k/131072k available (3365k kernel code, 6360k reserved, 1100k data , 236k init, 0k highmem) NR_IRQS:128 mips_hpt_frequency: 250714278 pnx_clocksource.rating: 200 cpj: 1002857 pnx8xxx_clockevent.mult: 1076809625 pnx8xxx_clockevent.shift: 32 pnx8xxx_clockevent.min_delta_ns: 3063 pnx8xxx_clockevent.max_delta_ns: 8565462100 clockevent 250714278 1076809625 32 registered called pnx8xxx_set_mode(1) called pnx8xxx_set_mode(3) console [ttyS1] enabled imba is 0 Calibrating delay loop... 248.06 BogoMIPS (lpj=496128) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 0 NET: Registered protocol family 16 bio: create slab at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb pci 0000:00:08.0: BAR 6: assigned [mem 0x12000000-0x1207ffff pref] pci 0000:00:0a.0: BAR 6: assigned [mem 0x12080000-0x1208ffff pref] pci 0000:00:09.0: BAR 0: assigned [mem 0x12090000-0x12090fff] pci 0000:00:09.0: BAR 0: set to [mem 0x12090000-0x12090fff] (PCI address [0x1209 0000-0x12090fff]) pci 0000:00:09.1: BAR 0: assigned [mem 0x12091000-0x12091fff] pci 0000:00:09.1: BAR 0: set to [mem 0x12091000-0x12091fff] (PCI address [0x1209 1000-0x12091fff]) pci 0000:00:0a.0: BAR 1: assigned [mem 0x12092000-0x12092fff] pci 0000:00:0a.0: BAR 1: set to [mem 0x12092000-0x12092fff] (PCI address [0x1209 2000-0x12092fff]) pci 0000:00:08.0: BAR 5: assigned [mem 0x12093000-0x120931ff] pci 0000:00:08.0: BAR 5: set to [mem 0x12093000-0x120931ff] (PCI address [0x1209 3000-0x120931ff]) pci 0000:00:09.2: BAR 0: assigned [mem 0x12093200-0x120932ff] pci 0000:00:09.2: BAR 0: set to [mem 0x12093200-0x120932ff] (PCI address [0x1209 3200-0x120932ff]) pci 0000:00:0a.0: BAR 0: assigned [io 0x1c001000-0x1c0010ff] pci 0000:00:0a.0: BAR 0: set to [io 0x1c001000-0x1c0010ff] (PCI address [0x1c00 1000-0x1c0010ff]) pci 0000:00:08.0: BAR 4: assigned [io 0x1c001400-0x1c00140f] pci 0000:00:08.0: BAR 4: set to [io 0x1c001400-0x1c00140f] (PCI address [0x1c00 1400-0x1c00140f]) pci 0000:00:08.0: BAR 0: assigned [io 0x1c001410-0x1c001417] pci 0000:00:08.0: BAR 0: set to [io 0x1c001410-0x1c001417] (PCI address [0x1c00 1410-0x1c001417]) pci 0000:00:08.0: BAR 2: assigned [io 0x1c001418-0x1c00141f] pci 0000:00:08.0: BAR 2: set to [io 0x1c001418-0x1c00141f] (PCI address [0x1c00 1418-0x1c00141f]) pci 0000:00:08.0: BAR 1: assigned [io 0x1c001420-0x1c001423] pci 0000:00:08.0: BAR 1: set to [io 0x1c001420-0x1c001423] (PCI address [0x1c00 1420-0x1c001423]) pci 0000:00:08.0: BAR 3: assigned [io 0x1c001424-0x1c001427] pci 0000:00:08.0: BAR 3: set to [io 0x1c001424-0x1c001427] (PCI address [0x1c00 1424-0x1c001427]) Switching to clocksource pnx8xxx NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. msgmni has been set to 243 Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) io scheduler noop registered io scheduler deadline registered (default) Serial: PNX8XXX driver pnx8xxx-uart: ttyS0 at MMIO 0xbbe4a000 (irq = 27) is a PNX8XXX pnx8xxx-uart: ttyS1 at MMIO 0xbbe4b000 (irq = 28) is a PNX8XXX brd: module loaded loop: module loaded sata_sil 0000:00:08.0: Applying R_ERR on DMA activate FIS errata fix scsi0 : sata_sil scsi1 : sata_sil ata1: SATA max UDMA/100 mmio m512@0x12093000 tf 0x12093080 irq 55 ata2: SATA max UDMA/100 mmio m512@0x12093000 tf 0x120930c0 irq 55 natsemi dp8381x driver, version 2.1, Sept 11, 2006 originally by Donald Becker 2.4.x kernel port by Jeff Garzik, Tjeerd Mulder PCI: Enabling device 0000:00:0a.0 (0006 -> 0007) natsemi eth0: NatSemi DP8381[56] at 0x12092000 (0000:00:0a.0), 00:17:31:fb:de:2a , IRQ 55, port TP. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ehci_hcd 0000:00:09.2: EHCI Host Controller ehci_hcd 0000:00:09.2: new USB bus registered, assigned bus number 1 ehci_hcd 0000:00:09.2: irq 55, io mem 0x12093200 ehci_hcd 0000:00:09.2: USB 2.0 started, EHCI 0.95 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: EHCI Host Controller usb usb1: Manufacturer: Linux 3.1.0.3PNX8550+ ehci_hcd usb usb1: SerialNumber: 0000:00:09.2 hub 1-0:1.0: USB hub found hub 1-0:1.0: 4 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver pnx8550-ohci pnx8550-ohci: PNX8550 OHCI pnx8550-ohci pnx8550-ohci: new USB bus registered, assigned bus number 2 pnx8550-ohci pnx8550-ohci: irq 13, io mem 0x1be48000 usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb2: Product: PNX8550 OHCI usb usb2: Manufacturer: Linux 3.1.0.3PNX8550+ ohci_hcd usb usb2: SerialNumber: pnx8550 hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected ohci_hcd 0000:00:09.0: OHCI Host Controller ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 3 ohci_hcd 0000:00:09.0: irq 55, io mem 0x12090000 usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb3: Product: OHCI Host Controller usb usb3: Manufacturer: Linux 3.1.0.3PNX8550+ ohci_hcd usb usb3: SerialNumber: 0000:00:09.0 hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected ohci_hcd 0000:00:09.1: OHCI Host Controller ohci_hcd 0000:00:09.1: new USB bus registered, assigned bus number 4 ohci_hcd 0000:00:09.1: irq 55, io mem 0x12091000 ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310) ata1.00: ATA-8: SAMSUNG HD502HJ, 1AJ10001, max UDMA/133 ata1.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 0/32) ata1.00: configured for UDMA/100 scsi 0:0:0:0: Direct-Access ATA SAMSUNG HD502HJ 1AJ1 PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb4: Product: OHCI Host Controller usb usb4: Manufacturer: Linux 3.1.0.3PNX8550+ ohci_hcd usb usb4: SerialNumber: 0000:00:09.1 hub 4-0:1.0: USB hub found hub 4-0:1.0: 2 ports detected usbcore: registered new interface driver uas Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver ums-datafab usbcore: registered new interface driver ums-freecom usbcore: registered new interface driver ums-jumpshot usbcore: registered new interface driver ums-sddr09 usbcore: registered new interface driver ums-sddr55 usbcore: registered new interface driver ums-usbat i2c /dev entries driver usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP cubic registered NET: Registered protocol family 17 sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA kmemleak: Kernel memory leak detector initialized drivers/rtc/hctosys.c: unable to open rtc device (rtc0) eth0: DSPCFG accepted after 0 usec. eth0: link up. eth0: Setting full-duplex based on negotiated link capability. sda: sda1 sda2 sda3 sd 0:0:0:0: [sda] Attached SCSI disk kmemleak: Automatic memory scanning thread started IP-Config: Guessing netmask 255.255.255.0 IP-Config: Complete: device=eth0, addr=192.168.20.160, mask=255.255.255.0, gw=255.255.255.255, host=192.168.20.160, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath= ata2: SATA link down (SStatus 0 SControl 310) kjournald starting. Commit interval 5 seconds EXT3-fs (sda1): using internal journal EXT3-fs (sda1): recovery complete EXT3-fs (sda1): mounted filesystem with ordered data mode VFS: Mounted root (ext3 filesystem) on device 8:1. Freeing unused kernel memory: 236k freed Algorithmics/MIPS FPU Emulator v1.5 Creating device nodes...done Set log level... Setting up /tmp... done Starting logging daemons...done Setting up network...done Mounting config fs... cat: /proc/mtd: No such file or directory mount: Mounting /dev/ on /profile failed: No such device cat: /proc/mtd: No such file or directory mount: Mounting /dev/ on /config failed: No such device du: /config/debug/: No such file or directory done Starting command server... - done Setting up timezone... cp: /usr/share/zoneinfo/Etc/UTC: No such file or director y done Setting up network services...Setup network interface eth0... done Bring up main interface... - done Loading luddite (256M_NOIP)... lud-corelud_core: version magic '2.6.21.3PNX8550 mod_unload MIPS32_R1 32BIT ' should be '3.1.0.3PNX8550+ mod_unload MIPS32_R1 32B IT ' insmod: cannot insert `/usr/lib/luddite/lud-core.ko': Invalid module format (-1) : Exec format error lud-pnx8550lud_pnx8550: version magic '2.6.21.3PNX8550 mod_unload MIPS32_R1 32B IT ' should be '3.1.0.3PNX8550+ mod_unload MIPS32_R1 32BIT ' insmod: cannot insert `/usr/lib/luddite/lud-pnx8550.ko': Invalid module format ( -1): Exec format error phStbDspInfomodprobe: could not parse modules.dep done Loading pre-TM modules... fusionmodprobe: could not parse modules.dep mmiomodprobe: could not parse modules.dep i2c3203modprobe: could not parse modules.dep i2c0105modprobe: could not parse modules.dep tda1004xmodprobe: could not parse modules.dep tda10021modprobe: could not parse modules.dep tda10048modprobe: could not parse modules.dep stv0297modprobe: could not parse modules.dep demuxmodprobe: could not parse modules.dep dvbmodprobe: could not parse modules.dep ak470modprobe: could not parse modules.dep saa8510modprobe: could not parse modules.dep tda9983 output_mode: PAL-RGBmodprobe: could not parse modules.dep denc21modprobe: could not parse modules.dep phStbRpcmodprobe: could not parse modules.dep phStbDPmodprobe: could not parse modules.dep phStbRTCmodprobe: could not parse modules.dep phStbGpiomodprobe: could not parse modules.dep phStbAudiomodprobe: could not parse modules.dep sndmodprobe: could not parse modules.dep modprobe: could not parse modules.dep phStbDrawmodprobe: could not parse modules.dep done Populating /dev using udev: cat: /dev/gpio10: No such file or directory cat: /dev/gpio15: No such file or directory cat: /dev/gpio5: No such file or directory RESTORE GPIO12 done Starting Trimedia 0 ...Cannot open luddite device - Error = -1 open tmdev: No such file or directory done Starting TriMedia 1 ...Cannot open luddite device - Error = -1 open tmdev: No such file or directory done Loading post-TM modules...modprobe: could not parse modules.dep modprobe: could not parse modules.dep modprobe: could not parse modules.dep modprobe: could not parse modules.dep done Starting network servers...telnetd - done Starting autofs...usb samba - done Starting DSP file services...
