# Makefile to compile and link the UARTlibrary and test program
# based on
# WinAVR Sample makefile written by Eric B. Weddington, Jrg Wunsch, et al.
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make coff = Convert ELF to AVR COFF (for use with AVR Studio 3.x or VMLAB).
# make extcoff = Convert ELF to AVR Extended COFF (for use with AVR Studio
#                4.07 or greater).
# make program = Download the hex file to the device, using avrdude.  Please
#                customize the avrdude settings below first!
# make filename.s = Just compile filename.c into the assembler code only
# To rebuild project do "make clean" then "make all".
# MCU clock frequency
XTAL_CPU = 8000000UL
# MCU name
MCU = attiny84
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Optimization level, can be [0, 1, 2, 3, s]. 0 turns off optimization.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
# Target file name (without extension).
TARGET = main
# List C source files here. (C dependencies are automatically generated.)
SRC = twi.c uart.c $(TARGET).c
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
EXTRAINCDIRS =
# Optional compiler flags.
#  -g:        generate debugging information (for GDB, or for COFF conversion)
#  -O*:       optimization level
#  -f...:     tuning, see gcc manual and avr-libc documentation
#  -Wall...:  warning level
#  -Wa,...:   tell GCC to pass this to the assembler.
#    -ahlms:  create assembler listing
CFLAGS = -g -O$(OPT) \
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums \
-Wall -Wstrict-prototypes \
-fno-split-wide-types \
-fno-inline-small-functions \
-fno-move-loop-invariants \
-fno-tree-loop-optimize \
-Wl,--relax \
-ffreestanding \
-Wa,-adhlns=$(<:.c=.lst) \
$(patsubst %,-I%,$(EXTRAINCDIRS))
# Set a "language standard" compiler flag.
#   Unremark just one line below to set the language standard to use.
#   gnu99 = C99 + GNU extensions. See GCC manual for more information.
#CFLAGS += -std=c89
#CFLAGS += -std=gnu89
#CFLAGS += -std=c99
CFLAGS += -std=gnu99 -fgnu89-inline
#Pass the MCU clock frequency to flags
CFLAGS += -DXTAL_CPU=$(XTAL_CPU) -DF_CPU=$(XTAL_CPU)
# Optional assembler flags.
#  -ahlms:    create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs
ASFLAGS += -DXTAL_CPU=$(XTAL_CPU)
# Optional linker flags.
#  -Wl,...:   tell GCC to pass this to linker.
#  -Map:      create map file
#  --cref:    add cross reference to  map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
# Additional libraries
# Minimalistic printf version
#LDFLAGS += -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires -lm below)
#LDFLAGS += -Wl,-u,vfprintf -lprintf_flt
# -lm = math library
LDFLAGS += -lm
# Programming support using avrdude. Settings and variables.
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
AVRDUDE_FLAGS_LPT = -i 5 -p $(MCU) -P /dev/parport0 -c stk200 -y
AVRDUDE_FLAGS_SERCON = -p $(MCU) -P /dev/ttyS0 -c ponyser -y
# Uncomment the following if you want avrdude's erase cycle counter.
# Note that this counter needs to be initialized first using -Yn,
# see avrdude manual.
#AVRDUDE_ERASE += -y
# Uncomment the following if you do /not/ wish a verification to be
# performed after programming the device.
#AVRDUDE_FLAGS += -V
# Increase verbosity level.  Please use this when submitting bug
# reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
# to submit bug reports.
#AVRDUDE_FLAGS += -v -v
# Define directories, if needed.
DIRAVR = c:/winavr
DIRAVRBIN = $(DIRAVR)/bin
DIRAVRUTILS = $(DIRAVR)/utils/bin
DIRINC = .
DIRLIB = $(DIRAVR)/avr/lib
# Define programs and commands.
SHELL = sh
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
SIZEX = avr-sizex
AVRDUDE = avrdude
REMOVE = rm -f
COPY = cp
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
#ELFSIZEX = $(SIZEX) --long --flash=16384 --sram=1024 --eeprom=512 $(TARGET).elf
# free flash size: 16384 - 2048 bytes for bootloader
ELFSIZEX = $(SIZEX) --long --flash=8192 --sram=512 --eeprom=512 $(TARGET).elf
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_SIZEX = Percentage of space used on the AVR device $(MCU):
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
# Define all object files.
OBJ = $(ASRC:.S=.o) $(SRC:.c=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(SRC:.c=.lst)
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore $(TARGET).elf $(TARGET).hex $(TARGET).eep \
	$(TARGET).lss $(TARGET).sym sizeafter finished end
# Eye candy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
	@echo
	@echo $(MSG_BEGIN)
finished:
	@echo $(MSG_ERRORS_NONE)
end:
	@echo $(MSG_END)
	@echo
# Display size of file.
sizebefore:
	@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); $(ELFSIZEX); echo; fi
sizeafter:
	@if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); $(ELFSIZEX); echo; fi
# Display compiler version information.
gccversion :
	@$(CC) --version
# Convert ELF to COFF for use in debugging / simulating in
# AVR Studio or VMLAB.
COFFCONVERT=$(OBJCOPY) --debugging \
	--change-section-address .data-0x800000 \
	--change-section-address .bss-0x800000 \
	--change-section-address .noinit-0x800000 \
	--change-section-address .eeprom-0x810000
coff: $(TARGET).elf
	@echo
	@echo $(MSG_COFF) $(TARGET).cof
	$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
	@echo
	@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
	$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Program the device.
#program: usb_program_flash
sercon_program_flash: $(TARGET).hex
	$(AVRDUDE) $(AVRDUDE_FLAGS_SERCON) $(AVRDUDE_WRITE_FLASH)
sercon_read_fuses:
	$(AVRDUDE) $(AVRDUDE_FLAGS_SERCON) -v
sercon_write_fuses:
	$(AVRDUDE) $(AVRDUDE_FLAGS_SERCON) -U lfuse:w:0xC2:m -U hfuse:w:0xD4:m
lpt_program_flash: $(TARGET).hex
	$(AVRDUDE) $(AVRDUDE_FLAGS_LPT) $(AVRDUDE_WRITE_FLASH)
lpt_read_fuses:
	$(AVRDUDE) $(AVRDUDE_FLAGS_LPT) -v
lpt_write_fuses:
	$(AVRDUDE) $(AVRDUDE_FLAGS_LPT) -U lfuse:w:0xC2:m -U hfuse:w:0xD4:m
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
	@echo
	@echo $(MSG_FLASH) $@
	$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
	@echo
	@echo $(MSG_EEPROM) $@
	-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
	--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
%.lss: %.elf
	@echo
	@echo $(MSG_EXTENDED_LISTING) $@
	$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
	@echo
	@echo $(MSG_SYMBOL_TABLE) $@
	avr-nm -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
	@echo
	@echo $(MSG_LINKING) $@
	$(CC) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
%.o : %.c
	@echo
	@echo $(MSG_COMPILING) $<
	$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
	$(CC) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
%.o : %.S
	@echo
	@echo $(MSG_ASSEMBLING) $<
	$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
	@echo
	@echo $(MSG_CLEANING)
	$(REMOVE) $(TARGET).hex
	$(REMOVE) $(TARGET).eep
	$(REMOVE) $(TARGET).obj
	$(REMOVE) $(TARGET).cof
	$(REMOVE) $(TARGET).elf
	$(REMOVE) $(TARGET).map
	$(REMOVE) $(TARGET).a90
	$(REMOVE) $(TARGET).sym
	$(REMOVE) $(TARGET).lnk
	$(REMOVE) $(TARGET).lss
	$(REMOVE) $(OBJ)
	$(REMOVE) $(LST)
	$(REMOVE) $(SRC:.c=.s)
	$(REMOVE) $(SRC:.c=.d)
# Automatically generate C source code dependencies.
# (Code originally taken from the GNU make user manual and modified
# (See README.txt Credits).)
# Note that this will work with sh (bash) and sed that is shipped with WinAVR
# (see the SHELL variable defined above).
# This may not work with other shells or other seds.
%.d: %.c
	set -e; $(CC) -MM $(ALL_CFLAGS) $< \
	| sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > $@; \
	[ -s $@ ] || rm -f $@
# Remove the '-' if you want to see the dependency files generated.
-include $(SRC:.c=.d)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion coff extcoff \
	clean clean_list program open
open:
	scite $(SRC:.c=.c)&
