 *    Used with ICCARM and AARM.
 *    (c) Copyright IAR Systems 2006
 *    File name   : drv_glcd.c
 *    Description : Graphic LCD driver
 *    History :
 *    1. Date        : December 2, 2006
 *       Author      : Stanimir Bonev
 *       Description : Create
 *    $Revision: #1 $
#include "drv_glcd.h"
#include "stdarg.h"
#include <assert.h>
/* delay definition */
#define GLCD_DLY_10US                        800     // 10us
#define GLCD_RESET_DLY                       500     // 5ms
#define GLCD_BOOSTER_ON_DLY                1200     // 120 ms
static const GLCD_CmdCtrl_t GLCD_Cmd_Iss0[GLCD_CMD_NUMB] =
// (ISS=0)
// NOP - No Operation
  {0x00, GLCD_WRITE, 0, 0},
// SLPIN - Sleep in & booster off
  {0x10, GLCD_WRITE, 0, 0},
// SLPOUT - Sleep out & booster on
  {0x11, GLCD_WRITE, 0, 0},
// PTLOUT (NORON) - Partial off (Normal)
  {0x13, GLCD_WRITE, 0, 0},
// INVOFF - Display inversion off (normal)
  {0x20, GLCD_WRITE, 0, 0},
// INVON - Display inversion on
  {0x21, GLCD_WRITE, 0, 0},
// DISPOFF - Display off
  {0x28, GLCD_WRITE, 0, 0},
// DISPON - Display on
  {0x29, GLCD_WRITE, 0, 0},
// CASET - Column address set
// X_ADR start: 0h <= XS <= 83h
// X_ADR end: 0h <= XS <= 83h
  {0x2A, GLCD_WRITE, 0, 2},
// RASET - Row address set
// Y_ADR start: 0h <= YS <= 83h
// Y_ADR end: 0h <= YS <= 83h
  {0x2B, GLCD_WRITE, 0, 2},
// RAMWR - Memory write
  {0x2C, GLCD_WRITE, 0, (Int32U)-1},
// RGBSET - Color set for 256 color display
  {0x2D, GLCD_WRITE, 0, 20},
// VSCSAD - Scroll start address of RAM
// SSA = 0, 1, 2, … , 131
  {0x37, GLCD_WRITE, 0, 1},
// IDMOFF - Idle mode off
  {0x38, GLCD_WRITE, 0, 0},
// IDMON - Idle mode on
  {0x39, GLCD_WRITE, 0, 0},
// RDID1 - Interface pixel format
  {0xDA, GLCD_READ,  0, 1},
// RDID2 - Interface pixel format
  {0xDB, GLCD_READ,  0, 1},
// RDID3 - Interface pixel format
  {0xDC, GLCD_READ,  0, 1},
// FRMSEL - External oscillator select
// Frame frequency in Temp range A
// Frame frequency in Temp range B
// Frame frequency in Temp range C
// Frame frequency in Temp range D
  {0xB4, GLCD_WRITE, 0, 4},
// FRM8SEL - External oscillator select
  {0xB5, GLCD_WRITE, 0, 4},
// TMPRNG - External oscillator select
// Temp range A
// Temp range B
// Temp range C
// Temp range D
  {0xB6, GLCD_WRITE, 0, 4},
// TMPHIS - Temp range set
  {0xB8, GLCD_WRITE, 0, 1},
// TMPREAD - Temperature read back
  {0xB7, GLCD_READ,  0, 1},
// EPWRIN - EEPROM write start
  {0xD1, GLCD_WRITE, 0, 0},
// EPWROUT - EEPROM write end
  {0xD0, GLCD_WRITE, 0, 0},
// RDEV - Read internal contrast (EV_IN)
  {0xD4, GLCD_WRITE, 0, 1},
// RDRR - Read internal resistor ratio (RR_IN)
  {0xD5, GLCD_READ,  0, 1},
// Adapted commands
// PTIN - adapted command (PTLAR + PTIN)
// SCRLAR - Scroll area set (2-line unit)
// TFA = 0,1,2, … , 132
// VSA = 0,1,2, … , 132
// BFA = 0,1,2, … , 132
  {0x33, GLCD_WRITE, 0, 3},
// DATCTR - adapted command (MADCTR + COLMOD)
// SETCON - Write contrast 0 - 127
  {0x25, GLCD_WRITE, 0, 1},
// Commands applicable only when ISS=1
// OSCON
  {GLCD_INV_CMD, GLCD_WRITE, 0, 0},
// OSCOFF
// RMWIN
// RMWOUT
// VOLUP
// VOLDOWN
// ASCSET
// DISCTR
// PWRCTR
// VOLCTR
// Commands applicable only when ISS=0
// CLKINT - Internal oscillator select
  {0xB0, GLCD_WRITE, 0, 0},
// CLKEXT - External oscillator select
  {0xB1, GLCD_WRITE, 0, 0},
// RDDST - Read Display Status
  {0x09, GLCD_READ,  1, 4},
// SWRESET - Software reset
  {0x01, GLCD_WRITE, 0, 0},
// RDDID - Read Display ID
  {0x04, GLCD_READ,  1, 3},
// PTLAR - Partial start/end address set
// Start address (0,1,2, …, 131)
// End address (0,1,2, …, 131)
  {0x30, GLCD_WRITE, 0, 2},
// PTLON - Partial mode on
  {0x12, GLCD_WRITE, 0, 0},
// MADCTR - Tearing effect mode set & on
  {0x36, GLCD_WRITE, 0, 1},
// COLMOD - Interface pixel format
// Interface format
  {0x3A, GLCD_WRITE, 0, 1},
// APOFF - All pixel off (only for test purpose)
  {0x22, GLCD_WRITE, 0, 0},
// APON - All pixel on (only for test purpose)
  {0x23, GLCD_WRITE, 0, 0},
// BSTROFF - Booster off (only for test purpose)
  {0x02, GLCD_WRITE, 0, 0},
// BSTRON - Booster on (only for test purpose)
  {0x03, GLCD_WRITE, 0, 0},
static const GLCD_CmdCtrl_t GLCD_Cmd_Iss1[GLCD_CMD_NUMB] =
// (ISS=1)
  {0x25, GLCD_WRITE, 0, 0},
  {0x95, GLCD_WRITE, 0, 0},
  {0x94, GLCD_WRITE, 0, 0},
  {0xA9, GLCD_WRITE, 0, 0},
  {0xA6, GLCD_WRITE, 0, 0},
  {0xA7, GLCD_WRITE, 0, 0},
  {0xAE, GLCD_WRITE, 0, 0},
  {0xAF, GLCD_WRITE, 0, 0},
  {0x15, GLCD_WRITE, 0, 2},
  {0x75, GLCD_WRITE, 0, 2},
  {0x5C, GLCD_WRITE, 0, (Int32U)-1},
  {0xCE, GLCD_WRITE, 0, 20},
  {0xAB, GLCD_WRITE, 0, 1},
// Temp range A
// Temp range B
// Temp range C
// Temp range D
// TMPHIS - Temp hysteresis range set
  {0xCD, GLCD_WRITE, 0, 0},
  {0xCC, GLCD_WRITE, 0, 0},
  {0x7C, GLCD_WRITE, 0, 1},
  {0x7D, GLCD_READ,  0, 1},
// Adapted commands
// PTIN - Partial area set & on
// Partial start line address
// PSL7-0 Partial start line address
// PEL7-0 Partial end line address
  {0xA8, GLCD_WRITE, 0, 2},
// SCRLAR(ASCSET) - Scroll area set (2-line unit) Mode-0
// SSL7-0 - Scroll start line
// SEL7-0 - Scroll end line
// SFL7-0 - Scroll specified line
// SMD2-0 - Area scroll mode
  {0xAA, GLCD_WRITE, 0, 4},
// MV MX MY	 		- Row/column address control
// MRGB					- RGB
// GS2 GS1 GS0	- Gray-scale setup
  {0xBC, GLCD_WRITE, 0, 3},
  {0x00, GLCD_WRITE, 0, 1},
// OSCON - Oscillator on
// OSCOFF - Oscillator off
  {0xD2, GLCD_WRITE, 0, 0},
// RMWIN - Read & modify write on
  {0xE0, GLCD_WRITE, 0, 0},
// RMWOUT - Read & modify write off
  {0xEE, GLCD_WRITE, 0, 0},
// VOLUP - EV increment
  {0xD6, GLCD_WRITE, 0, 0},
// VOLDOWN - EV decrement
  {0xD7, GLCD_WRITE, 0, 0},
// ASCSET - Scroll area set
// SMD1-0 - Area scroll mode
// DISCTR - Display control
// P1
// P2
// P3
  {0xCA, GLCD_WRITE, 0, 3},
// PWRCTR - Power control set
// P13-P10
  {0x20, GLCD_WRITE, 0, 1},
// VOLCTR
  {0x81, GLCD_WRITE, 0, 2},
  {GLCD_INV_CMD, GLCD_READ,  0, 0},
// Interface format
static GLCD_ISS_t Glcd_Iss;
static Boolean OddPixel = FALSE;
static Int32U PixelHold = 0;
static pFontType_t pCurrFont = NULL;
static LdcPixel_t TextColour;
static LdcPixel_t TextBackgndColour;
static Int32U TextX_Pos = 0;
static Int32U TextY_Pos = 0;
static Int32U XL_Win = DEF_X_LEFT;
static Int32U YU_Win = DEF_Y_UP;
static Int32U XR_Win = DEF_X_RIGHT;
static Int32U YD_Win = DEF_Y_DOWN;
static Int32U TabSize = TEXT_DEF_TAB_SIZE;
 * Function Name: GLCD_SendCmd
 * Parameters: GLCD_SendCmd Cmd, pInt8U pData, Int32U Size
 * Return: GLCD_Status_t
 * Description: Send command to the Graphic LCD
GLCD_Status_t GLCD_SendCmd (GLCD_Cmd_t Cmd, pInt8U pData, Int32U Size)
static Boolean Write2_DRAM = FALSE; // write to DRAM mode
static Int32U ResRatio;             // Hold resistor ratio init by VOLCTR
                                    // and used by SETCON adapted command
// Pointer to current set of commands
pGLCD_CmdCtrl_t pGLCD_CmdCtrl = (pGLCD_CmdCtrl_t)(((Glcd_Iss==GLCD_ISS_0)?
                                GLCD_Cmd_Iss0:GLCD_Cmd_Iss1) + Cmd);
pDATCTR_Data_t pDATCTR_Data;
Int8U ColourSch;
pASCSET_Data_t pASCSET_Data;
MADCTR_Data_t DataMode = {0};
Int32U Contrast;
  if(Write2_DRAM)
    // Select LCD
    GLCD_SPI_ChipSelect(1);
    if(Cmd != RAMWR)
      if(PixelHold & WAITED_PIXEL)
        // Flush pixel
        GLCD_SPI_TranserByte(PixelHold);
      // Release CS
      GLCD_SPI_ChipSelect(0);
    else
      // pixels collection
      Int32U Pixel;
      while(Size > 1)
        Pixel  =  *pData++;
        Pixel |= (*pData++)<<8;
        PixelHold |= WAITED_PIXEL;
        if(!OddPixel)
          // Get even pixel
          PixelHold |= PIXEL_CONV(Pixel,0);
        else
          // Apply odd pixel
          PixelHold |= PIXEL_CONV(Pixel,1);
          // and send together both pixels
          GLCD_SPI_SendBlock((pInt8U)&PixelHold,3);
          PixelHold = 0;
        // update the even/odd flag
        OddPixel ^= 1;
        // update the counter of the remaining bytes
        Size -= 2;
      // Release CS
      return(GLCD_OK);
	// sanitary check of command
	if(pGLCD_CmdCtrl->Cmd == GLCD_INV_CMD)
		return(GLCD_UNSUPPORTED);
	// Implement adapted commands
	if(Glcd_Iss==GLCD_ISS_0)
		switch(Cmd)
		case PTIN:
			// PTLAR + PTIN
			GLCD_SendCmd(PTLAR,pData,0);
			GLCD_SendCmd(PTLON,NULL,0);
			return(GLCD_OK);
		case DATCTR:
      pDATCTR_Data = (pDATCTR_Data_t)pData;
			// MADCTR + COLMOD
			// Data reconstruction
      DataMode.MY = pDATCTR_Data->MY;
			DataMode.MX = pDATCTR_Data->MX;
			DataMode.MV = pDATCTR_Data->MV;
			DataMode.ML = pDATCTR_Data->ML;
			DataMode.RGB = !pDATCTR_Data->RGB;
			GLCD_SendCmd(MADCTR,(pInt8U)&DataMode,0);
      // 4K colors Type A
			ColourSch = 3;			
			return(GLCD_SendCmd(COLMOD,&ColourSch,0));
	else
    switch(Cmd)
    case SCRLAR:
			pASCSET_Data = (pASCSET_Data_t)pData;
			pASCSET_Data->Smd = 0;	// Center screen scroll mode
			GLCD_SendCmd(ASCSET,pData,0);
			return(GLCD_OK);
    case DATCTR:
      pDATCTR_Data->ML  = 0;
			pDATCTR_Data->MX = !pDATCTR_Data->MX;
      // 4K colors Type A
      pDATCTR_Data->GS  = 2;
      break;
    case SETCON:
      Contrast = *pData | (ResRatio << 8);
      return(GLCD_SendCmd(VOLCTR,(pInt8U)&Contrast,0));
    case VOLCTR:
      ResRatio = *(pData+1);
      break;
  if(pGLCD_CmdCtrl->Param != (Int32U)-1)
    // Command with fixed size of parameters
    Size = pGLCD_CmdCtrl->Param;
  // Select LCD
  GLCD_SPI_TranserByte(pGLCD_CmdCtrl->Cmd);
  if(Cmd == RAMWR)
    // enter in write to DRAM mode
    OddPixel = FALSE;
    PixelHold = 0;
    Write2_DRAM = TRUE;
    return(GLCD_SendCmd(RAMWR,pData,Size));
  // Send/Receive parameters
  if(pGLCD_CmdCtrl->Dir == GLCD_READ)
    if(pGLCD_CmdCtrl->Pulse)
      if(Size)
        *pData++ = GLCD_SPI_TranserByte(0xFFFF);
        --Size;
    GLCD_SPI_SetWordWidth(8);
    GLCD_SPI_ReceiveBlock(pData,Size);
  else
    GLCD_SPI_SendBlock(pData,Size);
  // Release CS
    GLCD_SPI_SetWordWidth(9);
  return(GLCD_OK);
 * Function Name: GLCD_PowerUpInit
 * Parameters: pInt8U pInitData
 *         GLCD_OK - init pass
 *         GLCD_ID_ERROR - unsupported driver type
 * Description: Power-up initialization of Graphic LCD
GLCD_Status_t GLCD_PowerUpInit (pInt8U pInitData)
Int32U Data;
Int32U i;
  // Init SPI and IO
  // Init low level
  GLCD_SPI_Init(GLCD_DEF_CLOCK,GLCD_DEF_WIDTH);
  GLCD_LLInit();
  GLCD_Backlight(BACKLIGHT_ON);
  // H/W Reset
  // Rest L > 10us H
  GLCD_SetReset(0);
  for(volatile Int32U i = GLCD_DLY_10US; i ; --i);
  GLCD_SetReset(1);
  // Wait 5 ms
  DelayResolution100us(GLCD_RESET_DLY);
  // Identify LCD and command interpreter
  Glcd_Iss = GLCD_ISS_0;
  GLCD_SendCmd(RDDID,(pInt8U)&Data,0);
  if(((Data        & 0xFF) != GLCD_MANF_ID) ||
     (((Data >> 16)& 0xFF) != GLCD_MOD_ID))
  	// Iss = 1 don't support RDDID command
  	Glcd_Iss = GLCD_ISS_1;
  // Power Supply Set
  if(Glcd_Iss == GLCD_ISS_1)
    // Support only 4K colors
    assert(GLCD_DEF_DPL_ML == 0);
	  //  DISCTR (Display Control)
	  //	 - F1/F2 switching period set
	  //	 - Line inversion set
	  Data = 0 | (0x20UL << 8) | (0x11UL << 16);
	  GLCD_SendCmd(DISCTR,(pInt8U)&Data,0);
	  //  OSCON (Oscillator ON)
	  GLCD_SendCmd(OSCON,NULL,0);
    // Set contrast
    Data = 38 | (0x0UL << 8);
    GLCD_SendCmd(VOLCTR,(pInt8U)&Data,0);
  else
    // Set contrast
    Data = 0x3B;
    GLCD_SendCmd(SETCON,(pInt8U)&Data,0);
  // SLPOUT (Sleep mode OFF & OSC/Booster On)
  GLCD_SendCmd(SLPOUT,NULL,0); // Sleep out
  if(Glcd_Iss == GLCD_ISS_0)
    GLCD_SendCmd(BSTRON,NULL,0); // Booster voltage on
  // Display Environment Set
  // Display inversion setting
  GLCD_SendCmd(GLCD_DEF_DPL_INV?INVON:INVOFF,NULL,0);
  // Display color scheme setting
  GLCD_SendCmd(GLCD_DEF_DPL_8_COLOR?IDMON:IDMOFF,NULL,0);
  // Display partial setting
  if(GLCD_DEF_DPL_PARTIAL_MODE)
    GLCD_SendCmd(PTLOUT,NULL,0);
  else
#if GLCD_DEF_DPL_PARTIAL_MODE > 0
#error "PARTIAL_MODE not supported yet"
#endif // GLCD_DEF_DPL_PARTIAL_MODE > 0
  // Memory Data Access Control
  Data = 0;
  pDATCTR_Data = (pDATCTR_Data_t)&Data;
  pDATCTR_Data->RGB = GLCD_DEF_DPL_RGB_ORD; // BGR / RGB order
  pDATCTR_Data->MY = GLCD_DEF_DPL_MY; 			// no mirror Y
  pDATCTR_Data->MX = GLCD_DEF_DPL_MX; 			// no mirror X
  pDATCTR_Data->MV = GLCD_DEF_DPL_V; 				// vertical RAM write in Y/X direction
  pDATCTR_Data->ML = GLCD_DEF_DPL_ML; 			// line address order (bottom to top) / (top to bottom)
  // support only 4k type A colored scheme
  GLCD_SendCmd(DATCTR,(pInt8U)&Data,0);
  // Display Data Write & Display On
  // COLUMN ADDRESS SET and PAGE ADDRESS SET
  Data = 0 | ((GLCD_HORIZONTAL_SIZE - 1)<<8);
  GLCD_SendCmd(RASET,(pInt8U)&Data,0);
  GLCD_SendCmd(CASET,(pInt8U)&Data,0);
  // Init display memory
  if(pInitData == NULL)
    Data = DEF_BACKGND_COLOUR;
    for(i = 0; i < (GLCD_HORIZONTAL_SIZE * GLCD_VERTICAL_SIZE); ++i)
		Data = 0xFFFFFFFF >> (i & 0x1F);
      LCD_WRITE_PIXEL(Data);
    LCD_FLUSH_PIXELS();
  else
    GLCD_SendCmd(RAMWR,pInitData,GLCD_HORIZONTAL_SIZE * GLCD_VERTICAL_SIZE * 2);
    // PWRCTR
    Data = 0x1F;
    GLCD_SendCmd(PWRCTR,(pInt8U)&Data,0);
  // Wait for more than 120ms after power control command
	DelayResolution100us(GLCD_BOOSTER_ON_DLY);
  GLCD_SendCmd(GLCD_DISPLAY_STATE?DISPON:DISPOFF,NULL,0);
  return(GLCD_OK);
void GLCD_UpdateMemory(pInt8U pInitData)
	Int32U Data;
	Int32U i;
    LCD_FLUSH_PIXELS();
  else
    // PWRCTR
    Data = 0x1F;
 * Function Name: GLCD_SetFont
 * Parameters: pFontType_t pFont, LdcPixel_t Color
 *              LdcPixel_t BackgndColor
 * Return: none
 * Description: Set current font, font color and background color
void GLCD_SetFont(pFontType_t pFont, LdcPixel_t Color, LdcPixel_t BackgndColor)
  pCurrFont = pFont;
  TextColour = Color;
  TextBackgndColour = BackgndColor;
 * Function Name: GLCD_SetWindow
 * Parameters: Int32U X_Left, Int32U Y_Up,
 *             Int32U X_Right, Int32U Y_Down
 * Return: none
 * Description: Set draw window XY coordinate in pixels
void GLCD_SetWindow(Int32U X_Left, Int32U Y_Up,
                    Int32U X_Right, Int32U Y_Down)
  assert(X_Right < GLCD_HORIZONTAL_SIZE);
  assert(Y_Down < GLCD_VERTICAL_SIZE);
  assert(X_Left < X_Right);
  assert(Y_Up < Y_Down);
  XL_Win = X_Left;
  YU_Win = Y_Up;
  XR_Win = X_Right;
  YD_Win = Y_Down;
 * Function Name: GLCD_TextSetPos
 * Parameters: Int32U X_UpLeft, Int32U Y_UpLeft,
 *             Int32U X_DownLeft, Int32U Y_DownLeft
 * Return: none
 * Description: Set text X,Y coordinate in characters
void GLCD_TextSetPos(Int32U X, Int32U Y)
  TextX_Pos = X;
  TextY_Pos = Y;
 * Function Name: GLCD_TextSetTabSize
 * Parameters: Int32U Size
 * Return: none
 * Description: Set text tab size in characters
void GLCD_TextSetTabSize(Int32U Size)
  TabSize = Size;
 * Function Name: GLCD_TextCalcWindow
 * Parameters: pInt32U pXL, pInt32U pXR,
 *             pInt32U pYU, pInt32U pYD,
 *             pInt32U pH_Size, pInt32U pV_Size
 * Return: Boolean
 *          FALSE - out of window coordinate aren't valid
 *          TRUE  - the returned coordinate are valid
 * Description: Calculate character window
static
Boolean GLCD_TextCalcWindow (pInt32U pXL, pInt32U pXR,
                             pInt32U pH_Size, pInt32U pV_Size)
  *pH_Size = pCurrFont->H_Size;
  *pV_Size = pCurrFont->V_Size;
  *pXL = XL_Win + (TextX_Pos*pCurrFont->H_Size);
  if(*pXL > XR_Win)
    return(FALSE);
  *pYU = YU_Win + (TextY_Pos*pCurrFont->V_Size);
  if(*pYU > YD_Win)
    return(FALSE);
  *pXR   = XL_Win + ((TextX_Pos+1)*pCurrFont->H_Size) - 1;
  if(*pXR > XR_Win)
  	*pH_Size -= *pXR - XR_Win;
    *pXR = XR_Win;
  *pYD = YU_Win + ((TextY_Pos+1)*pCurrFont->V_Size) - 1;
  if(*pYD > YD_Win)
    *pV_Size -= *pYD - YD_Win;
    *pYD = YD_Win;
  return(TRUE);
 * Function Name: GLCD_putchar
 * Parameters: int c
 * Return: none
 * Description: Put char function
int GLCD_putchar (int c)
pInt8U pSrc;
Int32U H_Line;
Int32U xl,xr,yu,yd,Temp,V_Size, H_Size, SrcInc = 1;
Int32U WhiteSpaceNumb;
  if(pCurrFont == NULL)
    return(EOF);
  H_Line = (pCurrFont->H_Size / 8) + ((pCurrFont->H_Size % 8)?1:0);
  switch(c)
  case '\n':  // go to start of next line (NewLine)
    ++TextY_Pos;
    break;
  case '\r':  // go to start of this line (Carriage Return)
  	// clear from current position to end of line
  	while(GLCD_TextCalcWindow(&xl,&xr,&yu,&yd,&H_Size,&V_Size))
      LCD_SET_WINDOW(xl,xr,yu,yd);
	    for(Int32U i = 0; i < V_Size; ++i)
	      for(Int32U j = 0; j < H_Size; ++j)
	        LCD_WRITE_PIXEL(TextBackgndColour);
  		++TextX_Pos;
    TextX_Pos = 0;
    break;
  case '\b': // go back one position (BackSpace)
    if(TextX_Pos)
      --TextX_Pos;
      // del current position
	  	if(GLCD_TextCalcWindow(&xl,&xr,&yu,&yd,&H_Size,&V_Size))
    break;
  case '\t':  // go to next Horizontal Tab stop
  	WhiteSpaceNumb = TabSize - (TextX_Pos%TabSize);
  	for(Int32U k = 0; k < WhiteSpaceNumb; ++k)
		    ++TextX_Pos;
	  	else
	  		break;
    break;
  case '\f':  // go to top of page (Form Feed)
  	// clear entire window
  	H_Size = XR_Win - XL_Win;
  	V_Size = YD_Win - YU_Win;
    // set character window X left, Y right
    LCD_SET_WINDOW(XL_Win,XR_Win,YU_Win,YD_Win);
    // Fill window with background font color
    for(Int32U i = 0; i <= V_Size; ++i)
      for(Int32U j = 0; j <= H_Size; ++j)
  	TextX_Pos = TextY_Pos = 0;
    break;
  case '\a':  // signal an alert (BELl)
    TEXT_BEL1_FUNC();
    break;
  default:
    // Calculate the current character base address from stream
    // and the character position
    if((c <  pCurrFont->CharacterOffset) &&
    	 (c >= pCurrFont->CharactersNuber))
   		c = 0;
    else
    	c -= pCurrFont->CharacterOffset;
    pSrc = pCurrFont->pFontStream + (H_Line * pCurrFont->V_Size * c);
    // Calculate character window and fit it in the text window
	    // Send char data
        SrcInc = H_Line;
	        Temp = (*pSrc & (1UL << (j&0x7)))?TextColour:TextBackgndColour;
	        LCD_WRITE_PIXEL(Temp);
	        if((j&0x7) == 7)
	          ++pSrc;
            --SrcInc;
        // next line of character
	      pSrc += SrcInc;
    ++TextX_Pos;
  LCD_FLUSH_PIXELS();
  return(c);
 * Function Name: GLCD_print
 * Parameters: int c
 * Return: none
void GLCD_print (const char *fmt,...)
va_list ap;
char s[MAX_GLCD_STR_SIZE];
char *p_char = s;
  va_start(ap, fmt);
  vsprintf(s, fmt,ap);
  va_end(ap);
  while(0 != *p_char)
    if(-1 == GLCD_putchar(*p_char++))
      break;
