Index: openocd-0.5.0/tcl/interface/estick.cfg
--- openocd-0.5.0/tcl/interface/estick.cfg	(revision 0)
+++ openocd-0.5.0/tcl/interface/estick.cfg	(revision 13)
@@ -0,0 +1,9 @@
+# eStick
+# http://code.google.com/p/estick-jtag/
+interface estick
+adapter_khz 66
Index: openocd-0.5.0/configure.in
--- openocd-0.5.0/configure.in	(revision 11)
+++ openocd-0.5.0/configure.in	(working copy)
@@ -462,6 +462,10 @@
   AS_HELP_STRING([--enable-jlink], [Enable building support for the Segger J-Link JTAG Programmer]),
   [build_jlink=$enableval], [build_jlink=no])
+AC_ARG_ENABLE(estick,
+  AS_HELP_STRING([--enable-estick], [Enable building support for the estick JTAG Programmer]),
+  [build_estick=$enableval], [build_estick=no])
 AC_ARG_ENABLE(vsllink,
   AS_HELP_STRING([--enable-vsllink], [Enable building support for the Versaloon-Link JTAG Programmer]),
   [build_vsllink=$enableval], [build_vsllink=no])
@@ -723,6 +727,12 @@
   AC_DEFINE(BUILD_JLINK, 0, [0 if you don't want the J-Link JTAG driver.])
 fi
+if test $build_estick = yes; then
+  AC_DEFINE(BUILD_ESTICK, 1, [1 if you want the estick JTAG driver.])
+else
+  AC_DEFINE(BUILD_ESTICK, 0, [0 if you don't want the estick JTAG driver.])
+fi
 if test $build_vsllink = yes; then
   AC_DEFINE(BUILD_VSLLINK, 1, [1 if you want the Versaloon-Link JTAG driver.])
 else
@@ -1073,6 +1083,7 @@
 AM_CONDITIONAL(USBPROG, test $build_usbprog = yes)
 AM_CONDITIONAL(OOCD_TRACE, test $build_oocd_trace = yes)
 AM_CONDITIONAL(JLINK, test $build_jlink = yes)
+AM_CONDITIONAL(ESTICK, test $build_estick = yes)
 AM_CONDITIONAL(VSLLINK, test $build_vsllink = yes)
 AM_CONDITIONAL(RLINK, test $build_rlink = yes)
 AM_CONDITIONAL(ULINK, test $build_ulink = yes)
Index: openocd-0.5.0/src/jtag/interfaces.c
--- openocd-0.5.0/src/jtag/interfaces.c	(revision 11)
+++ openocd-0.5.0/src/jtag/interfaces.c	(working copy)
@@ -94,6 +94,9 @@
 #if BUILD_ARMJTAGEW == 1
 extern struct jtag_interface armjtagew_interface;
 #endif
+#if BUILD_ESTICK == 1
+extern struct jtag_interface estick_interface;
+#endif
 #if BUILD_BUSPIRATE == 1
 extern struct jtag_interface buspirate_interface;
 #endif
@@ -160,6 +163,9 @@
 		&armjtagew_interface,
 #endif
+    &estick_interface,
+#endif
		&buspirate_interface,
 #endif
Index: openocd-0.5.0/src/jtag/drivers/estick.c
--- openocd-0.5.0/src/jtag/drivers/estick.c	(revision 0)
+++ openocd-0.5.0/src/jtag/drivers/estick.c	(revision 13)
@@ -0,0 +1,854 @@
+ *   Copyright (C) 2009 by Cahya Wirawan <cahya@gmx.at>                    *
+ *   Based on opendous driver by Vladimir Fonov                            *
+ *   Copyright (C) 2009 by Vladimir Fonov <vladimir.fonov@gmai.com>        *
+ *   Based on J-link driver by  Juergen Stuber                             *
+ *   Copyright (C) 2007 by Juergen Stuber <juergen@jstuber.net>            *
+ *   based on Dominic Rath's and Benedikt Sauter's usbprog.c               *
+ *   Copyright (C) 2008 by Spencer Oliver                                  *
+ *   spen@spen-soft.co.uk                                                  *
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+ *   This program is distributed in the hope that it will be useful,       *
+ *   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
+ *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
+ *   GNU General Public License for more details.                          *
+ *   You should have received a copy of the GNU General Public License     *
+ *   along with this program; if not, write to the                         *
+ *   Free Software Foundation, Inc.,                                       *
+ *   59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.             *
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <jtag/interface.h>
+#include <jtag/commands.h>
+#include "usb_common.h"
+#include <string.h>
+#include <sys/timeb.h>
+#include <time.h>
+#define VID 0x1781
+#define PID 0xC0C0
+#define ESTICK_WRITE_ENDPOINT   0x02
+#define ESTICK_READ_ENDPOINT    0x81
+static unsigned int estick_hw_jtag_version = 1;
+#define ESTICK_USB_TIMEOUT      1000
+#define ESTICK_USB_BUFFER_SIZE  360
+#define ESTICK_IN_BUFFER_SIZE   (ESTICK_USB_BUFFER_SIZE)
+#define ESTICK_OUT_BUFFER_SIZE  (ESTICK_USB_BUFFER_SIZE)
+/* Global USB buffers */
+static uint8_t usb_in_buffer[ESTICK_IN_BUFFER_SIZE];
+static uint8_t usb_out_buffer[ESTICK_OUT_BUFFER_SIZE];
+/* Constants for ESTICK command */
+#define ESTICK_MAX_SPEED 				66
+#define ESTICK_MAX_TAP_TRANSMIT 350  //even number is easier to handle
+#define ESTICK_MAX_INPUT_DATA   (ESTICK_MAX_TAP_TRANSMIT*4)
+#define ESTICK_TAP_BUFFER_SIZE 65536
+#define MAX_PENDING_SCAN_RESULTS (ESTICK_MAX_INPUT_DATA)
+//JTAG usb commans
+#define JTAG_CMD_TAP_OUTPUT     0x0
+#define JTAG_CMD_SET_TRST       0x1
+#define JTAG_CMD_SET_SRST       0x2
+#define JTAG_CMD_READ_INPUT     0x3
+#define JTAG_CMD_TAP_OUTPUT_EMU 0x4
+#define JTAG_CMD_SET_DELAY      0x5
+#define JTAG_CMD_SET_SRST_TRST  0x6
+/* External interface functions */
+static int estick_execute_queue(void);
+static int estick_speed(int speed);
+static int estick_speed_div(int speed, int *khz);
+static int estick_khz(int khz, int *jtag_speed);
+static int estick_init(void);
+static int estick_quit(void);
+/* Queue command functions */
+static void estick_end_state(tap_state_t state);
+static void estick_state_move(void);
+static void estick_path_move(int num_states, tap_state_t *path);
+static void estick_runtest(int num_cycles);
+static void estick_scan(int ir_scan, enum scan_type type, uint8_t *buffer, int scan_size, struct scan_command *command);
+static void estick_reset(int trst, int srst);
+static void estick_simple_command(uint8_t command,uint8_t _data);
+static int estick_get_status(void);
+/* eStick tap buffer functions */
+static void estick_tap_init(void);
+static int  estick_tap_execute(void);
+static void estick_tap_ensure_space(int scans, int bits);
+static void estick_tap_append_step(int tms, int tdi);
+static void estick_tap_append_scan(int length, uint8_t *buffer, struct scan_command *command);
+/* estick lowlevel functions */
+struct estick_jtag
+	struct usb_dev_handle* usb_handle;
+static struct estick_jtag *estick_usb_open(void);
+static void estick_usb_close(struct estick_jtag *estick_jtag);
+static int estick_usb_message(struct estick_jtag *estick_jtag, int out_length, int in_length);
+static int estick_usb_write(struct estick_jtag *estick_jtag, int out_length);
+static int estick_usb_read(struct estick_jtag *estick_jtag);
+//static int estick_usb_read_emu_result(struct estick_jtag *estick_jtag);
+/* helper functions */
+int estick_get_version_info(void);
+#ifdef _DEBUG_USB_COMMS_
+char time_str[50];
+static void estick_debug_buffer(uint8_t *buffer, int length);
+char *estick_get_time(char *);
+#endif
+static struct estick_jtag* estick_jtag_handle;
+/* External interface implementation */
+COMMAND_HANDLER(estick_handle_estick_info_command)
+	if (estick_get_version_info() == ERROR_OK)
+		/* attempt to get status */
+		estick_get_status();
+	return ERROR_OK;
+COMMAND_HANDLER(estick_handle_estick_hw_jtag_command)
+	switch (CMD_ARGC) {
+	case 0:
+		command_print(CMD_CTX, "estick hw jtag  %i", estick_hw_jtag_version);
+		break;
+	case 1: {
+		int request_version = atoi(CMD_ARGV[0]);
+		switch (request_version) {
+		case 2: case 3:
+			estick_hw_jtag_version = request_version;
+			break;
+		default:
+			return ERROR_COMMAND_SYNTAX_ERROR;
+		break;
+	default:
+	return ERROR_OK;
+static const struct command_registration estick_command_handlers[] = {
+		.name = "estick_info",
+		.handler = &estick_handle_estick_info_command,
+		.mode = COMMAND_EXEC,
+		.help = "show estick info",
+		.name = "estick_hw_jtag",
+		.handler = &estick_handle_estick_hw_jtag_command,
+		.help = "access eStick HW JTAG command version",
+		.usage = "[2|3]",
+	COMMAND_REGISTRATION_DONE
+struct jtag_interface estick_interface =
+	.name = "estick",
+	.commands = estick_command_handlers,
+	.execute_queue = estick_execute_queue,
+	.speed = estick_speed,
+	.speed_div = estick_speed_div,
+	.khz = estick_khz,
+	.init = estick_init,
+	.quit = estick_quit,
+	struct jtag_command *cmd = jtag_command_queue;
+	int scan_size;
+	enum scan_type type;
+	uint8_t *buffer;
+	while (cmd != NULL)
+		switch (cmd->type)
+			case JTAG_RUNTEST:
+				DEBUG_JTAG_IO( "runtest %i cycles, end in %i", cmd->cmd.runtest->num_cycles, \
+					cmd->cmd.runtest->end_state);
+				if (cmd->cmd.runtest->end_state != -1)
+					estick_end_state(cmd->cmd.runtest->end_state);
+				estick_runtest(cmd->cmd.runtest->num_cycles);
+				break;
+			case JTAG_TLR_RESET:
+				DEBUG_JTAG_IO("statemove end in %i", cmd->cmd.statemove->end_state);
+				estick_end_state(cmd->cmd.statemove->end_state);
+				estick_state_move();
+				break;
+			case JTAG_PATHMOVE:
+				DEBUG_JTAG_IO("pathmove: %i states, end in %i", \
+					cmd->cmd.pathmove->num_states, \
+					cmd->cmd.pathmove->path[cmd->cmd.pathmove->num_states - 1]);
+				estick_path_move(cmd->cmd.pathmove->num_states, cmd->cmd.pathmove->path);
+				break;
+			case JTAG_SCAN:
+				DEBUG_JTAG_IO("scan end in %i", cmd->cmd.scan->end_state);
+				if (cmd->cmd.scan->end_state != -1)
+					estick_end_state(cmd->cmd.scan->end_state);
+				scan_size = jtag_build_buffer(cmd->cmd.scan, &buffer);
+				DEBUG_JTAG_IO("scan input, length = %d", scan_size);
+				estick_debug_buffer(buffer, (scan_size + 7) / 8);
+#endif
+				type = jtag_scan_type(cmd->cmd.scan);
+				estick_scan(cmd->cmd.scan->ir_scan, type, buffer, scan_size, cmd->cmd.scan);
+				break;
+			case JTAG_RESET:
+				DEBUG_JTAG_IO("reset trst: %i srst %i", cmd->cmd.reset->trst, cmd->cmd.reset->srst);
+				estick_tap_execute();
+				if (cmd->cmd.reset->trst == 1)
+					tap_set_state(TAP_RESET);
+				estick_reset(cmd->cmd.reset->trst, cmd->cmd.reset->srst);
+				break;
+			case JTAG_SLEEP:
+				DEBUG_JTAG_IO("sleep %i", cmd->cmd.sleep->us);
+				jtag_sleep(cmd->cmd.sleep->us);
+				break;
+			default:
+				LOG_ERROR("BUG: unknown JTAG command type encountered");
+				exit(-1);
+		cmd = cmd->next;
+	return estick_tap_execute();
+/* Sets speed in kHz. */
+	if (speed <= ESTICK_MAX_SPEED)
+    //one day...
+    return ERROR_OK;
+	else
+		LOG_INFO("Requested speed %dkHz exceeds maximum of %dkHz, ignored", speed, ESTICK_MAX_SPEED);
+	return ERROR_OK;
+static int estick_speed_div(int speed, int* khz)
+	*khz = speed;
+	return ERROR_OK;
+	*jtag_speed = khz;
+  //TODO: convert this into delay value for estick
+	return ERROR_OK;
+	int check_cnt;
+	estick_jtag_handle = estick_usb_open();
+	if (estick_jtag_handle == 0)
+		LOG_ERROR("Cannot find eStick Interface! Please check connection and permissions.");
+		return ERROR_JTAG_INIT_FAILED;
+  //reset the board
+  //usb_control_msg(estick_jtag_handle, (REQDIR_DEVICETOHOST | REQTYPE_VENDOR | REQTYPE_STANDARD), 1, 0, 0, &dummy, 1, ESTICK_USB_TIMEOUT);
+	check_cnt = 0;
+	while (check_cnt < 3)
+			break;
+		check_cnt++;
+	LOG_INFO("eStick JTAG Interface ready");
+	estick_reset(0, 0);
+	estick_tap_init();
+	//estick_simple_command ( JTAG_CMD_SET_DELAY, 255);
+	return ERROR_OK;
+	estick_usb_close(estick_jtag_handle);
+	return ERROR_OK;
+/* Queue command implementations */
+void estick_end_state(tap_state_t state)
+	if (tap_is_state_stable(state))
+		tap_set_end_state(state);
+	else
+		LOG_ERROR("BUG: %i is not a valid end state", state);
+		exit(-1);
+/* Goes to the end state. */
+void estick_state_move(void)
+	int i;
+	int tms = 0;
+	uint8_t tms_scan = tap_get_tms_path(tap_get_state(), tap_get_end_state());
+	uint8_t tms_scan_bits = tap_get_tms_path_len(tap_get_state(), tap_get_end_state());
+	for (i = 0; i < tms_scan_bits; i++)
+		tms = (tms_scan >> i) & 1;
+		estick_tap_append_step(tms, 0);
+	tap_set_state(tap_get_end_state());
+void estick_path_move(int num_states, tap_state_t *path)
+	int i;
+	for (i = 0; i < num_states; i++)
+		if (path[i] == tap_state_transition(tap_get_state(), false))
+			estick_tap_append_step(0, 0);
+		else if (path[i] == tap_state_transition(tap_get_state(), true))
+			estick_tap_append_step(1, 0);
+		else
+			LOG_ERROR("BUG: %s -> %s isn't a valid TAP transition", tap_state_name(tap_get_state()), tap_state_name(path[i]));
+			exit(-1);
+		tap_set_state(path[i]);
+	tap_set_end_state(tap_get_state());
+void estick_runtest(int num_cycles)
+	int i;
+	tap_state_t saved_end_state = tap_get_end_state();
+	/* only do a state_move when we're not already in IDLE */
+	if (tap_get_state() != TAP_IDLE)
+		estick_end_state(TAP_IDLE);
+	/* execute num_cycles */
+	for (i = 0; i < num_cycles; i++)
+	/* finish in end_state */
+	estick_end_state(saved_end_state);
+	if (tap_get_state() != tap_get_end_state())
+void estick_scan(int ir_scan, enum scan_type type, uint8_t *buffer, int scan_size, struct scan_command *command)
+	tap_state_t saved_end_state;
+	estick_tap_ensure_space(1, scan_size + 8);
+	saved_end_state = tap_get_end_state();
+	/* Move to appropriate scan state */
+	estick_end_state(ir_scan ? TAP_IRSHIFT : TAP_DRSHIFT);
+	/* Scan */
+	estick_tap_append_scan(scan_size, buffer, command);
+	/* We are in Exit1, go to Pause */
+	tap_set_state(ir_scan ? TAP_IRPAUSE : TAP_DRPAUSE);
+void estick_reset(int trst, int srst)
+    LOG_DEBUG("trst: %i, srst: %i", trst, srst);
+    /* Signals are active low */
+    if (srst == 0)
+        estick_simple_command ( JTAG_CMD_SET_SRST,1);
+    else if (srst == 1)
+        estick_simple_command ( JTAG_CMD_SET_SRST,0);
+    if (trst == 0)
+        estick_simple_command ( JTAG_CMD_SET_TRST,1);
+    else if (trst == 1)
+        estick_simple_command ( JTAG_CMD_SET_TRST,0);
+		srst=srst?0:1;
+		trst=trst?0:2;
+		estick_simple_command ( JTAG_CMD_SET_SRST_TRST,srst|trst );
+void estick_simple_command(uint8_t command,uint8_t _data)
+	int result;
+	DEBUG_JTAG_IO("0x%02x 0x%02x", command,_data);
+	usb_out_buffer[0] = (uint16_t) 2;
+	usb_out_buffer[2] = command;
+	usb_out_buffer[3] = _data;
+	result = estick_usb_message(estick_jtag_handle, 4, 1);
+	if (result != 1)
+		LOG_ERROR("Estick command 0x%02x failed (%d)", command, result);
+int estick_get_status(void)
+	estick_simple_command(EMU_CMD_GET_STATE);
+	result = estick_usb_read(estick_jtag_handle);
+	if (result == 8)
+		int vref = usb_in_buffer[0] + (usb_in_buffer[1] << 8);
+		LOG_INFO("Vref = %d.%d TCK = %d TDI = %d TDO = %d TMS = %d SRST = %d TRST = %d\n", \
+			vref / 1000, vref % 1000, \
+			usb_in_buffer[2], usb_in_buffer[3], usb_in_buffer[4], \
+			usb_in_buffer[5], usb_in_buffer[6], usb_in_buffer[7]);
+		if (vref < 1500)
+			LOG_ERROR("Vref too low. Check Target Power\n");
+	else
+		LOG_ERROR("J-Link command EMU_CMD_GET_STATE failed (%d)\n", result);
+	return ERROR_OK;
+  return ERROR_OK;
+/* Estick tap functions */
+static int tap_length;
+static uint8_t tms_buffer[ESTICK_TAP_BUFFER_SIZE];
+static uint8_t tdo_buffer[ESTICK_TAP_BUFFER_SIZE];
+struct pending_scan_result {
+	int first;	/* First bit position in tdo_buffer to read */
+	int length; /* Number of bits to read */
+	struct scan_command *command; /* Corresponding scan command */
+	uint8_t *buffer;
+static int pending_scan_results_length;
+static struct pending_scan_result pending_scan_results_buffer[MAX_PENDING_SCAN_RESULTS];
+static int last_tms;
+void estick_tap_init(void)
+	tap_length = 0;
+	pending_scan_results_length = 0;
+void estick_tap_ensure_space(int scans, int bits)
+	int available_scans = MAX_PENDING_SCAN_RESULTS - pending_scan_results_length;
+	if (scans > available_scans )
+void estick_tap_append_step(int tms, int tdi)
+	last_tms = tms;
+	unsigned char _tms=tms?1:0;
+	unsigned char _tdi=tdi?1:0;
+	int index =  tap_length/4;
+	int bits  = (tap_length%4)*2;
+	if (tap_length < ESTICK_TAP_BUFFER_SIZE)
+	    if(!bits)
+					tms_buffer[index]=0;
+      tms_buffer[index]  |= (_tdi<<bits)|(_tms<<(bits+1)) ;
+	    tap_length++;
+	else
+		LOG_ERROR("estick_tap_append_step, overflow");
+void estick_tap_append_scan(int length, uint8_t *buffer, struct scan_command *command)
+  DEBUG_JTAG_IO("append scan, length = %d", length);
+	struct pending_scan_result *pending_scan_result = &pending_scan_results_buffer[pending_scan_results_length];
+	int i;
+	pending_scan_result->first = tap_length;
+	pending_scan_result->length = length;
+	pending_scan_result->command = command;
+	pending_scan_result->buffer = buffer;
+	for (i = 0; i < length; i++)
+		estick_tap_append_step((i < length-1 ? 0 : 1), (buffer[i/8] >> (i%8)) & 1);
+	pending_scan_results_length++;
+/* Pad and send a tap sequence to the device, and receive the answer.
+ * For the purpose of padding we assume that we are in idle or pause state. */
+int estick_tap_execute(void)
+	int byte_length,byte_length_out;
+	int i,j;
+	int result;
+	int output_counter;
+	if (tap_length > 0)
+	    //memset(tdo_buffer,0,ESTICK_TAP_BUFFER_SIZE);
+	    //LOG_INFO("ESTICK tap execute %d",tap_length);
+	    byte_length =     (tap_length+3)/4;
+	    byte_length_out = (tap_length+7)/8;
+	    LOG_DEBUG("eStick is sending %d bytes", byte_length);
+#endif
+	    output_counter=0;
+	    for (j = 0, i = 0; j <  byte_length;)
+				 int recieve;
+				 int transmit=byte_length-j;
+				 if(transmit>ESTICK_MAX_TAP_TRANSMIT)
+						 transmit=ESTICK_MAX_TAP_TRANSMIT;
+						 recieve=(ESTICK_MAX_TAP_TRANSMIT)/2;
+						 usb_out_buffer[2]=JTAG_CMD_TAP_OUTPUT;
+				 }  else {
+						 usb_out_buffer[2]=JTAG_CMD_TAP_OUTPUT | ((tap_length%4)<<4);
+						 recieve=(transmit+1)/2;
+				 *(uint16_t *)&usb_out_buffer[0]=transmit+1;
+				 memmove(usb_out_buffer+3,tms_buffer+j,transmit);
+				 result = estick_usb_message(estick_jtag_handle, 3 + transmit, recieve);
+				 if(result!=recieve)
+						 LOG_ERROR("estick_tap_execute, wrong result %d, expected %d", result, recieve);
+						 return ERROR_JTAG_QUEUE_FAILED;
+				 memmove(tdo_buffer+i,usb_in_buffer,recieve);
+         i+=recieve;
+				 j+=transmit;
+    result=byte_length_out;
+    LOG_DEBUG("eStick tap result %d",result);
+    estick_debug_buffer(tdo_buffer,result);
+#endif
+    //LOG_INFO("eStick tap execute %d",tap_length);
+    for (i = 0; i < pending_scan_results_length; i++)
+      struct pending_scan_result *pending_scan_result = &pending_scan_results_buffer[i];
+      uint8_t *buffer = pending_scan_result->buffer;
+      int length = pending_scan_result->length;
+      int first = pending_scan_result->first;
+      struct scan_command *command = pending_scan_result->command;
+      /* Copy to buffer */
+      buf_set_buf(tdo_buffer, first, buffer, 0, length);
+      DEBUG_JTAG_IO("pending scan result, length = %d", length);
+      //estick_debug_buffer(buffer, byte_length_out);
+#endif
+      if (jtag_read_buffer(buffer, command) != ERROR_OK)
+      if (pending_scan_result->buffer != NULL)
+        free(pending_scan_result->buffer);
+	return ERROR_OK;
+/* Estick USB low-level functions */
+struct estick_jtag* estick_usb_open()
+	usb_set_debug(10);
+	usb_init();
+	const uint16_t vids[] = { VID, 0 };
+	const uint16_t pids[] = { PID, 0 };
+	struct usb_dev_handle *dev;
+	if (jtag_usb_open(vids, pids, &dev) != ERROR_OK)
+		return NULL;
+	struct estick_jtag *tmp = malloc(sizeof(struct estick_jtag));
+	tmp->usb_handle = dev;
+	usb_set_configuration(dev, 1);
+	usb_claim_interface(dev, 0);
+	usb_set_altinterface(dev, 0);
+	return tmp;
+void estick_usb_close(struct estick_jtag *estick_jtag)
+	usb_close(estick_jtag->usb_handle);
+	free(estick_jtag);
+/* Send a message and receive the reply. */
+int estick_usb_message(struct estick_jtag *estick_jtag, int out_length, int in_length)
+	int result;
+	result = estick_usb_write(estick_jtag, out_length);
+	if (result == out_length)
+		result = estick_usb_read(estick_jtag);
+    if (result == in_length)
+      return result;
+		else
+			LOG_ERROR("usb_bulk_read failed (requested=%d, result=%d)", in_length, result);
+			return -1;
+	else
+		LOG_ERROR("usb_bulk_write failed (requested=%d, result=%d)", out_length, result);
+		return -1;
+/* Write data from out_buffer to USB. */
+int estick_usb_write(struct estick_jtag *estick_jtag, int out_length)
+	int result;
+	if (out_length > ESTICK_OUT_BUFFER_SIZE)
+		LOG_ERROR("estick_jtag_write illegal out_length=%d (max=%d)", out_length, ESTICK_OUT_BUFFER_SIZE);
+		return -1;
+	LOG_DEBUG("%s: USB write begin", estick_get_time(time_str));
+#endif
+	result = usb_bulk_write(estick_jtag->usb_handle, ESTICK_WRITE_ENDPOINT, \
+		(char *)usb_out_buffer, out_length, ESTICK_USB_TIMEOUT);
+	LOG_DEBUG("%s: USB write end: %d bytes", estick_get_time(time_str), result);
+#endif
+	DEBUG_JTAG_IO("estick_usb_write, out_length = %d, result = %d", out_length, result);
+	//estick_debug_buffer(usb_out_buffer, out_length);
+#endif
+	return result;
+/* Read data from USB into in_buffer. */
+int estick_usb_read(struct estick_jtag *estick_jtag)
+	LOG_DEBUG("%s: USB read begin", estick_get_time(time_str));
+#endif
+	int result = usb_bulk_read(estick_jtag->usb_handle, ESTICK_READ_ENDPOINT,
+		(char *)usb_in_buffer, ESTICK_IN_BUFFER_SIZE, ESTICK_USB_TIMEOUT);
+	LOG_DEBUG("%s: USB read end: %d bytes", estick_get_time(time_str), result);
+#endif
+	DEBUG_JTAG_IO("estick_usb_read, result = %d", result);
+	//estick_debug_buffer(usb_in_buffer, result);
+#endif
+	return result;
+//#ifdef _DEBUG_USB_COMMS_
+#define BYTES_PER_LINE  16
+void estick_debug_buffer(uint8_t *buffer, int length)
+	char line[81];
+	char s[4];
+	int i;
+	int j;
+	for (i = 0; i < length; i += BYTES_PER_LINE)
+		snprintf(line, 5, "%04x", i);
+		for (j = i; j < i + BYTES_PER_LINE && j < length; j++)
+			snprintf(s, 4, " %02x", buffer[j]);
+			strcat(line, s);
+		LOG_DEBUG("%s", line);
+char *estick_get_time(char *str)
+	struct timeb timebuffer;
+    char *timeline;
+	ftime( &timebuffer );
+	timeline = ctime( & ( timebuffer.time ) );
+	snprintf(str, 49, "%.8s.%hu", &timeline[11], timebuffer.millitm);
+	return str;
+//#endif
Index: openocd-0.5.0/src/jtag/drivers/Makefile.am
--- openocd-0.5.0/src/jtag/drivers/Makefile.am	(revision 11)
+++ openocd-0.5.0/src/jtag/drivers/Makefile.am	(working copy)
@@ -72,6 +72,9 @@
 if ARMJTAGEW
 DRIVERFILES += arm-jtag-ew.c
 endif
+if ESTICK
+DRIVERFILES += estick.c
+endif
 if BUSPIRATE
 DRIVERFILES += buspirate.c
 endif
Index: openocd-0.5.0/src/Makefile.am
--- openocd-0.5.0/src/Makefile.am	(revision 11)
+++ openocd-0.5.0/src/Makefile.am	(working copy)
@@ -92,12 +92,16 @@
 if VSLLINK
 LIBUSB = -lusb
 else
+if ESTICK
+LIBUSB = -lusb
+else
 LIBUSB =
 endif
 endif
 endif
 endif
 endif
+endif
 libopenocd_la_LIBADD = \
 	$(top_builddir)/src/xsvf/libxsvf.la \
