* $Date: 19. May 2012
* $Revision: V1.0.0
* Project: CMSIS DSP Library
* Title: arm_atan2_f32.c
* Description: Fast atan2 calculation for floating-point values.
* Target Processor: Cortex-M4/Cortex-M3/Cortex-M0
#include "arm_math.h"
#define TABLE_SIZE_64 64
* @ingroup groupFastMath
* @defgroup atan2 arc tangent
* Computes the trigonometric atan2 function using a combination of table lookup
* and cubic interpolation.
* atan2(y, x) = atan( y / x )
* The lookup table only contains values for angles [0 pi/4],
* other values are calculated case sensitive depending on magnitude proportion
* and negativeness.
* The implementation is based on table lookup using 64 values together with cubic interpolation.
* The steps used are:
* -# Calculation of the nearest integer table index
* -# Fetch the four table values a, b, c, and d
* -# Compute the fractional portion (fract) of the table index.
* -# Calculation of wa, wb, wc, wd
* -# The final result equals a*wa + b*wb + c*wc + d*wd
* where
* a=Table[index-1]; * b=Table[index+0]; * c=Table[index+1]; * d=Table[index+2]; ** and *
* wa=-(1/6)*fract.^3 + (1/2)*fract.^2 - (1/3)*fract; * wb=(1/2)*fract.^3 - fract.^2 - (1/2)*fract + 1; * wc=-(1/2)*fract.^3+(1/2)*fract.^2+fract; * wd=(1/6)*fract.^3 - (1/6)*fract; **/ /** * @addtogroup atan2 * @{ */ /* pi value is 3.14159265358979 */ static const float32_t atanTable[68] = { -0.015623728620477f, 0.000000000000000f, // = 0 for in = 0.0 0.015623728620477f, 0.031239833430268f, 0.046840712915970f, 0.062418809995957f, 0.077966633831542f, 0.093476781158590f, 0.108941956989866f, 0.124354994546761f, 0.139708874289164f, 0.154996741923941f, 0.170211925285474f, 0.185347949995695f, 0.200398553825879f, 0.215357699697738f, 0.230219587276844f, 0.244978663126864f, 0.259629629408258f, 0.274167451119659f, 0.288587361894077f, 0.302884868374971f, 0.317055753209147f, 0.331096076704132f, 0.345002177207105f, 0.358770670270572f, 0.372398446676754f, 0.385882669398074f, 0.399220769575253f, 0.412410441597387f, 0.425449637370042f, 0.438336559857958f, 0.451069655988523f, 0.463647609000806f, 0.476069330322761f, 0.488333951056406f, 0.500440813147294f, 0.512389460310738f, 0.524179628782913f, 0.535811237960464f, 0.547284380987437f, 0.558599315343562f, 0.569756453482978f, 0.580756353567670f, 0.591599710335111f, 0.602287346134964f, 0.612820202165241f, 0.623199329934066f, 0.633425882969145f, 0.643501108793284f, 0.653426341180762f, 0.663202992706093f, 0.672832547593763f, 0.682316554874748f, 0.691656621853200f, 0.700854407884450f, 0.709911618463525f, 0.718829999621625f, 0.727611332626511f, 0.736257428981428f, 0.744770125716075f, 0.753151280962194f, 0.761402769805578f, 0.769526480405658f, 0.777524310373348f, 0.785398163397448f, // = pi/4 for in = 1.0 0.793149946109655f, 0.800781565178043f }; /** * @brief Fast approximation to the trigonometric atan2 function for floating-point data. * @param[in] x input value, y input value. * @return atan2(y, x) = atan(y/x) as radians. */ float32_t arm_atan2_f32(float32_t y, float32_t x) { float32_t atan2Val, fract, in; /* Temporary variables for input, output */ uint32_t index; /* Index variable */ uint32_t tableSize = (uint32_t) TABLE_SIZE_64; /* Initialise tablesize */ float32_t wa, wb, wc, wd; /* Cubic interpolation coefficients */ float32_t a, b, c, d; /* Four nearest output values */ float32_t *tablePtr; /* Pointer to table */ uint8_t flags = 0; /* flags providing information about input values: Bit0 = 1 if |x| < |y| Bit1 = 1 if x < 0 Bit2 = 1 if y < 0 */ /* calculate magnitude of input values */ if (x < 0.0f) { x = -x; flags |= 0x02; } if (y < 0.0f) { y = -y; flags |= 0x04; } /* calculate in value for LUT [0 1] */ if (x < y) { in = x / y; flags |= 0x01; } else /* x >= y */ { if (x > 0.0f) in = y / x; else /* both are 0.0 */ in = 0.0; /* prevent division by 0 */ } /* Calculation of index of the table */ index = (uint32_t) (tableSize * in); /* fractional value calculation */ fract = ((float32_t) tableSize * in) - (float32_t) index; /* Initialise table pointer */ tablePtr = (float32_t *) & atanTable[index]; /* Read four nearest values of output value from the sin table */ a = *tablePtr++; b = *tablePtr++; c = *tablePtr++; d = *tablePtr++; /* Cubic interpolation process */ wa = -(((0.166666667f) * (fract * (fract * fract))) + ((0.3333333333333f) * fract)) + ((0.5f) * (fract * fract)); wb = (((0.5f) * (fract * (fract * fract))) - ((fract * fract) + ((0.5f) * fract))) + 1.0f; wc = (-((0.5f) * (fract * (fract * fract))) + ((0.5f) * (fract * fract))) + fract; wd = ((0.166666667f) * (fract * (fract * fract))) - ((0.166666667f) * fract); /* Calculate atan2 value */ atan2Val = ((a * wa) + (b * wb)) + ((c * wc) + (d * wd)); /* exchanged input values? */ if (flags & 0x01) /* output = pi/2 - output */ atan2Val = 1.5707963267949f - atan2Val; /* negative x input? Quadrant 2 or 3 */ if (flags & 0x02) atan2Val = 3.14159265358979f - atan2Val; /* negative y input? Quadrant 3 or 4 */ if (flags & 0x04) atan2Val = - atan2Val; /* Return the output value */ return (atan2Val); } /** * @} end of atan2 group */
