Version 4 SHEET 1 1788 1012 WIRE -96 -320 -304 -320 WIRE -64 -320 -96 -320 WIRE -304 -256 -304 -320 WIRE -64 -240 -64 -320 WIRE 32 -240 -64 -240 WIRE 32 -144 -64 -144 WIRE -304 -96 -304 -176 WIRE -64 -96 -64 -144 WIRE 16 48 -16 48 WIRE 128 48 96 48 WIRE 160 48 128 48 WIRE 272 48 240 48 WIRE -224 144 -304 144 WIRE -160 144 -224 144 WIRE -16 144 -16 48 WIRE -16 144 -80 144 WIRE 16 144 -16 144 WIRE 128 144 128 48 WIRE 128 144 96 144 WIRE 160 144 128 144 WIRE 272 144 272 48 WIRE 272 144 240 144 WIRE 352 144 272 144 WIRE 512 144 352 144 WIRE 688 144 512 144 WIRE 352 176 352 144 WIRE 688 176 688 144 WIRE -304 192 -304 144 WIRE 512 192 512 144 WIRE -304 304 -304 272 WIRE 352 304 352 256 WIRE 512 304 512 256 WIRE 512 304 352 304 WIRE 688 304 688 256 WIRE 688 304 512 304 WIRE 352 320 352 304 FLAG -64 -96 0 FLAG -304 -96 0 FLAG -304 304 0 FLAG 352 320 0 FLAG -96 -320 z FLAG -224 144 z1 SYMBOL EL_SPEAKER 80 -192 R0 SYMATTR Value SP100 SYMATTR InstName U1 SYMBOL cap 496 192 R0 SYMATTR InstName C1 SYMATTR Value {250µ/0.95} SYMBOL res -176 160 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R0 SYMATTR Value 5.7 SYMBOL ind 336 160 R0 SYMATTR InstName L1 SYMATTR Value {28m*0.95} SYMBOL res 672 160 R0 SYMATTR InstName R1 SYMATTR Value 56.4 SYMBOL ind 144 160 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName L3 SYMATTR Value {l3} SYMBOL res 144 64 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R3 SYMATTR Value {r3} SYMBOL ind 0 160 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 5 56 VBottom 2 SYMATTR InstName L2 SYMATTR Value {l2} SYMBOL res 0 64 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R2 SYMATTR Value {r2} SYMBOL current -304 -176 M180 WINDOW 0 24 80 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I1 SYMATTR Value AC 1 SYMBOL current -304 272 M180 WINDOW 0 24 80 Left 2 WINDOW 3 24 0 Left 2 SYMATTR InstName I2 SYMATTR Value AC 1 TEXT -328 -392 Left 2 !.ac dec 100 10 20k TEXT -32 -176 Left 2 ;Z TEXT -328 -504 Left 2 ;Using a Z(freq) table\n \n(All in blue text is just comment) TEXT 40 -312 Left 2 ;Z(freq) TEXT -56 -392 Left 2 !.inc SP100.txt TEXT 64 208 Left 2 ;Skin Effekt TEXT -328 -552 Left 4 ;Equivalent Speaker Circuit TEXT 248 -536 Left 2 !.param r2opt=2.6\n.param l2opt=255u\n.param r3opt=30\n.param l3opt=48u\n.param r2={r2opt}\n.param l2={l2opt}\n.param r3={r3opt}\n.param l3={l3opt} TEXT 512 -496 Left 2 !.MEASURE AC cost INTEG abs(abs(V(z1)/V(z))-1)/freq TEXT 504 -408 Left 3 ;Manual Optimization Procedure TEXT 520 -536 Left 3 ;Cost function TEXT 504 -368 Left 2 ;L1, C1 for center frequency\nR0 at f=10Hz\nR1 for mimmum cost function\n*facor, /factor of L1, C1 for minimum cost function\nR2, L2 for mimmum cost function\nR3, L3 for mimmum cost function LINE Normal 8 -208 -56 -208 LINE Normal -8 -224 8 -208 LINE Normal -8 -224 -8 -224 LINE Normal 8 -208 -8 -224 LINE Normal -8 -192 8 -208 LINE Normal -8 -192 -8 -192 RECTANGLE Normal 784 352 -176 -32 2 RECTANGLE Normal 288 224 -32 0 2 RECTANGLE Normal 1104 -464 496 -560 2
