// include the library code: #include #include #include #include #include //#include //#include #include #define CONFIG_START 32 #define CMD_ZEIT 1 #define CMD_PMP 2 #define CMD_SAN 3 #define CMD_START_IMP 4 #define CMD_STOP_IMP 5 #define CMD_END 6 const byte ROWS = 4; //four rows const byte COLS = 3; //tree columns //define the cymbols on the buttons of the keypads char hexaKeys[ROWS][COLS] = { {'p','u','m'}, {'l','e','r'}, {'b','d','#'}, {'1','2','3'} }; //# Own Chars //# ================================== uint8_t arrow_up[8] = {0x4,0xE,0x15,0x4,0x4,0x4,0x0}; uint8_t arrow_down[8] = {0x0,0x4,0x4,0x4,0x15,0xE,0x4}; byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad byte colPins[COLS] = {6, 7, 8}; //connect to the column pinouts of the keypad LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 boolean sysStatus = false; // Programme Declaration boolean pUpload = false; struct StoreStruct{ float impPause; float impDauer; } storage = { 0, 0 }; // Programm declaration ############################################ struct structCMD{ int Befehl; int param1; int param2; } cmdP = { 0, 0 ,0 }; structCMD CMD[30]; int anzCMD = 0; int iAktProg = 0; int prog_run = 0; boolean p_imp_status = false; boolean state_imp = false; int p_imp_dauer, p_imp_pause; int adrProgMem = sizeof(storage)+1; String tmpString = ""; int i=0; char strA[15][15]; String p1,p2 = ""; // ################################################################## // Menüdeclaration Menu top("Root"); LCDMenu2 Root(top, lcd , 4, 20, 0, 1); Menu Item1("Jobs"); Menu Item11("Job 01"); //Menu Item12("Job 02"); //Menu Item13("Job 03"); //Menu Item14("Job 04"); //Menu Item15("Job 05"); Menu Item2("Einstellungen"); Menu Item21("Impulse"); Menu Item211("Pause"); Menu Item212("IMP-Dauer"); Menu Item22("Uhr"); Menu Item23("Auto-Aus"); Menu mnuProg[20]; uint8_t usedMnu = 0; boolean tmpFF = false; String strPumpe = "PMP"; String strSanosil = "SAN"; String strPneumatik = "IMP"; String aktMenu = "main"; int menuPos = 0; int mAnzMain = 3; int mAnzSetup = 3; // ISR Declaration long pMillis = 0; long intervall_imp = 0; long p_pMillis = 0; long p_intervall_imp = 0; //initialize an instance of class NewKeypad Keypad keypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS); // Register const int pumpe = 9; const int injektor = 10; const int v_pneumatik = 12; const int v_leer = 11; const int startposX = 5; void setup() { Serial.begin(9600); loadData(); // setup Relais pinMode(pumpe, OUTPUT); pinMode(injektor, OUTPUT); pinMode(v_pneumatik, OUTPUT); pinMode(v_leer, OUTPUT); warten(500); lcd.init(); // initialize the lcd //lcd.backlight(); lcd.createChar(0, arrow_up); lcd.createChar(1, arrow_down); menuinit(); keypad.addEventListener(keypadEvent); //add an event listener for this keypad } //## Menu Init void menuinit() { top.addChild(Item1); Item1.addChild(Item11); //Item1.addChild(Item12); //Item1.addChild(Item13); //Item1.addChild(Item14); //Item1.addChild(Item15); top.addChild(Item2); Item2.addChild(Item21); Item21.addChild(Item211); Item21.addChild(Item212); Item2.addChild(Item22); Item2.addChild(Item23); } void p_pulse(int ps, int dauer){ digitalWrite(v_pneumatik, HIGH); aktStatus(); warten(dauer); digitalWrite(v_pneumatik, LOW); aktStatus(); warten(ps); } void menu(){ lcd.clear(); Root.display(); } // Aktualisiert de Status in der linken Spalte void aktStatus(){ lcd.setCursor(0,0); if(digitalRead(pumpe)==HIGH) {lcd.print(strPumpe);} else {lcd.print(" ");}; lcd.setCursor(0,1); if(digitalRead(injektor)==HIGH) {lcd.print(strSanosil);} else {lcd.print(" ");}; lcd.setCursor(0,2); if(digitalRead(v_pneumatik)==HIGH) {lcd.print(strPneumatik);} else {lcd.print(" ");}; } Menu* allocateMenu() { if( usedMnu >= 20 ) return NULL; return &mnuProg[usedMnu++]; } void mnuAddCMD(char *n) { Menu* newMenu = allocateMenu(); if( newMenu == NULL ) { // da ist wohl was schief gelaufen Serial.println("newMenu = NULL"); return; } newMenu->name = n; Item11.addChild(*newMenu); } void FtoChar( float f, char* chr) { int vk = (int)f; int nk = abs((f - (int)f) * 100); //if(vk==NULL) vk = 0; char cVK[5], cNK[5]; itoa(vk, cVK, 10); itoa(nk, cNK, 10); strcpy(chr, cVK); strcat(chr, "."); strcat(chr, cNK); } void loadProg() { // Befehl Anzahl aus dem EEprom laden int adrIP = adrProgMem; *((int*)&anzCMD) = EEPROM.read(adrIP); adrIP++; for (int iP=0; iP 0) prog_isr(); if (state_imp) {pmp_isr();}; check_serial(); } void check_serial() { char letra; String progName = ""; while(Serial.available() > 0) { // get incoming byte: letra = Serial.read(); tmpString += String(letra); // CMD ende if (letra == 59) { tmpString = tmpString.trim(); Serial.println(tmpString); //Serial.println("#" + tmpString + "#"); if (tmpString.substring(0,5) == "pname") { pUpload = true; progName = tmpString.substring(6,(tmpString.length() - 7)); } if (tmpString.substring(0,3) == "end") { addPZeile(CMD_END,i); pUpload = false; pUploaded(); } String tmpCMD = tmpString.substring(0, tmpString.indexOf("(")); if (tmpCMD == "zeit") { addPZeile(CMD_ZEIT,i); } else if (tmpCMD == "pmp") { addPZeile(CMD_PMP,i); } else if (tmpCMD == "san") { addPZeile(CMD_SAN,i); } else if (tmpCMD == "imp") { addPZeile(CMD_START_IMP,i); } else if (tmpCMD == "stop_imp") { addPZeile(CMD_STOP_IMP,i); } int ka, kz, k = 0; ka = tmpString.indexOf("("); k = tmpString.indexOf(","); kz = tmpString.indexOf(")"); p1 = ""; p2 = ""; if (ka > 0 & kz > 0) { if((tmpString.substring(ka + 1, kz)).length() > 0) { if (k > 0) { p1 = tmpString.substring(ka + 1, k); p2 = tmpString.substring(k + 1, kz); } else { p1 = tmpString.substring(ka + 1, kz); } if (p1=="an") p1="1"; else if(p1=="aus") p1="0"; if (p2=="an") p2="1"; else if(p2=="aus") p2="0"; CMD[i].param1 = p1.toInt(); CMD[i].param2 = p2.toInt(); } } i++; tmpString=""; } } } void addPZeile(int bef, int ind) { CMD[ind].Befehl = bef; anzCMD++; } void pUploaded() { int adrIP = adrProgMem; EEPROM.write(adrIP, *((int*)&anzCMD)); adrIP++; for (int iP=0; iP anzCMD) { prog_run = 0; Serial.println("BEendet"); } // ZeitBefehl abgelaufen if (millis() - p_pMillis > p_intervall_imp) { // aktuelle Zeit abspeichern p_pMillis = millis(); prog_run ++; Root.goDown(); } } void pmp_isr() { byte value = digitalRead(v_pneumatik); if (value == LOW) { if(p_imp_status) intervall_imp = p_imp_pause; else intervall_imp = (storage.impPause * 1000); } else { if(p_imp_status) intervall_imp = p_imp_dauer; else intervall_imp = (storage.impDauer * 1000); } if (millis() - pMillis > intervall_imp) { pMillis = millis(); // aktuelle Zeit abspeichern // LED Zustand wecheln. if (value == LOW) value = HIGH; else value = LOW; // Wert auf den Ausgang schreiben digitalWrite(v_pneumatik, value); aktStatus(); } } void warten(long zeit) { long aWert = millis(); while(millis() < (aWert + zeit)) { char key = keypad.getKey(); } } void prog_null() { state_imp = false; p_imp_status = false; prog_run = 0; iAktProg = 0; anzCMD = 0; usedMnu = 0; mnuProg[] = NULL; } //take care of some special events void keypadEvent(KeypadEvent key){ int mAnz; if (aktMenu == "main") { mAnz = mAnzMain; } else if(aktMenu == "Setup") { mAnz = mAnzSetup; }; switch (keypad.getState()){ case PRESSED: switch (key){ case 'p': if(sysStatus) {ausschalten();} else{einschalten();}; break; case 'u': if(tmpFF) { if (Root.curfuncname == "Pause") { storage.impPause = storage.impPause + 0.1; aktPause(); } else if (Root.curfuncname == "IMP-Dauer") { storage.impDauer = storage.impDauer + 0.1; aktDauer(); }; } else { Root.goUp(); aktStatus(); }; break; case 'd': if(tmpFF) { if (Root.curfuncname == "Pause") { storage.impPause = storage.impPause - 0.1; aktPause(); } else if (Root.curfuncname == "IMP-Dauer") { storage.impDauer = storage.impDauer - 0.1; aktDauer(); }; } else { Root.goDown(); aktStatus(); }; break; case 'm': prog_null(); Root.goMenu(top); aktStatus(); break; case '1': if(digitalRead(pumpe) == HIGH) {digitalWrite(pumpe, LOW);} else{digitalWrite(pumpe, HIGH);}; aktStatus(); break; case '2': if(digitalRead(injektor) == HIGH) {digitalWrite(injektor, LOW);} else{digitalWrite(injektor, HIGH);}; aktStatus(); break; case '3': if(state_imp) { state_imp=false; digitalWrite(v_pneumatik, LOW); aktStatus(); } else{ state_imp=true; }; break; case 'b': if(iAktProg > 0) { prog_null(); } tmpFF = false; Root.goBack(); aktStatus(); break; case 'e': if(iAktProg > 0) { start_prog(); } else { Root.goEnter(); funccheck(1); } aktStatus(); break; } break; case RELEASED: switch (key){ case '*': break; } break; case HOLD: switch (key){ case '*': break; } break; } }
