(define-abbrev-table 'idl-mode-abbrev-table '(
(define-abbrev-table 'text-mode--abbrev-table '(
    ("LIM" "Local Improvement Movement" nil 0)
(define-abbrev-table 'c++-mode-abbrev-table '(
    ("switch10" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch10 0)
    ("ifpp" "#if" abbrev-korrekt-ifpp 1)
    ("ifepp" "#if" abbrev-korrekt-ifepp 1)
    ("ifdef" "#ifdef" abbrev-korrekt-ifdef 1)
    ("ifdefe" "#ifdef" abbrev-korrekt-ifdefelse 1)
    ("ifndef" "#ifndef" abbrev-korrekt-ifndef 1)
    ("print" "printf( \"\\n\" )" abbrev-korrekt-printf 0)
    ("ifdeb" "#ifndef NDEBUG" abbrev-korrekt-ifdeb 1)
    ("forever" "for(;;)
} // for(;;)" abbrev-korrekt-forever 0)
    ("if" "if( )
}" abbrev-korrekt-if 9)
    ("templ" "template<typename T>" nil 0)
    ("try" "try
catch( std::exception &Fehler )
std::cerr << \"Fehler: <\"
 << Fehler.what()
 << \"> in \"
 << __PRETTY_FUNCTION__
<< \"\\n\";
//throw( Fehler );
catch( ... )
std::cerr << \"unbekannter Fehler in \"
 << \"\\n\";
//throw;
}" abbrev-korrekt-try 0)
    ("scan" "scanf( \"%\", & )" abbrev-korrekt-scanf 0)
    ("cout" "std::cout << \"\" << << std::endl;" abbrev-korrekt-cout 0)
    ("cerr" "std::cerr << \"\" << << std::endl;" abbrev-korrekt-cout 0)
    ("log" "log << \"\" << << std::endl;" abbrev-korrekt-cout 0)
    ("dlog" "#ifndef NDEBUG
#endif" abbrev-korrekt-dlog 0)
    ("cin" "std::cin >>;" abbrev-korrekt-cin 0)
 ("whil" "while( )
  }"  abbrev-korrekt-while 1)
    ("main" "// Time-stamp: \"abc\"
//#include <cstdlib>
//#include <cstddef>
//#include <cstdio>
//#include <cstring>
//#include <stdexcept>
#include <iostream>
//#include <iomanip>    // setw(), setfill() etc.
//#include <fstream>
//#include <sstream>    // string streams
//#include <string>
//#include <algorithm>
//#include <utility>
//#include <map>  // map<> und multimap<>
//#include <set>  // set<> und multiset<>
//#include <list>
//#include <vector>
//#include <deque>
//#include <>
//#include <>
//#include <>
//#include <>
// Ausnahmen für Fehler:
#define DERIVEEXCEPTION( NAME, BASENAME, TEXT )                         \\
  class NAME : public BASENAME                                          \\
    public:                                                             \\
      NAME( const std::string &_what = #NAME )                          \\
        : BASENAME( std::string( TEXT ) + std::string( \"\\n\" ) + _what ) \\
int main( int nargs, char **args )
  return 0;
} // main( int nargs, char **args )" nil 1)
    ("dlprint" "#ifdef DEBUG
lgprintf( LogHandle, \"\\n\" )
#endif // DEBUG" nil 9)
    ("sstream" "std::stringstream" nil 0)
    ("isstream" "std::istringstream" nil 0)
    ("osstream" "std::ostringstream" nil 0)
    ("ifstream" "std::ifstream" nil 0)
    ("ofstream" "std::ofstream" nil 0)
    ("s" "std::string" nil 0)
    ("vec" "std::vector<  >" abbrev-korrekt-backeins 0)
    ("map" "std::map<  >" abbrev-korrekt-backeins 0)
    ("mmap" "std::multimap<  >" abbrev-korrekt-backeins 0)
    ("set" "std::set<  >" abbrev-korrekt-backeins 0)
    ("mset" "std::multiset<  >" abbrev-korrekt-backeins 0)
    ("list" "std::list<  >" abbrev-korrekt-backeins 0)
    ("sscan" "sscanf( puffer, \"%\", & )" abbrev-korrekt-scanf 0)
    ("lprint" "lgprintf( \"\\n\" )" abbrev-korrekt-printf 0)
    ("switch9" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch9 0)
    ("def" "#define" nil 1)
    ("switch8" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch8 0)
    ("class" "class
}; // class " abbrev-korrekt-class 0)
    ("switch7" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch7 0)
    ("fprints" "fprintf( stderr, \"\\n\" )" abbrev-korrekt-printf 0)
    ("switch6" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch6 0)
    ("switch5" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch5 0)
    ("do" "do
  while( );" abbrev-korrekt-do 0)
    ("else" "else" c-electric-continued-statement 0)
    ("switch4" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch4 0)
    ("switch3" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch3 0)
    ("switch" "  switch( )
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch4 3)
    ("switch2" "  switch( )
      case :
        break;
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch2 0)
    ("switch1" "  switch( )
      case :
        break;
    default :
      break;
    }" abbrev-korrekt-switch1 0)
    ("dfprint" "#ifdef DEBUG
#endif // DEBUG" nil 0)
    ("sprint" "sprintf( puffer, \"\" )" abbrev-korrekt-printf 0)
    ("aprint" "ads_printf( \"\\n\" )" abbrev-korrekt-printf 0)
    ("catch" "catch" c-electric-continued-statement 0)
    ("myinc" "#include \".h\"
" abbrev-korrekt-include 0)
    ("snprint" "snprintf( puffer, sizeof(puffer), \"\" )" abbrev-korrekt-printf 0)
    ("fprint" "fprintf( , \"\\n\" )" abbrev-korrekt-printf 0)
    ("for" "for(; ;  )
}" abbrev-korrekt-for 0)
    ("fscan" "fscanf( f, \"%\", & )" abbrev-korrekt-scanf 0)
    ("inc" "#include <>
" abbrev-korrekt-backzwei 0)
(define-abbrev-table 'c-mode-abbrev-table '(
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    ("ifdeb" "#ifdef DEBUG
#else /* nicht DEBUG */
#endif /* DEBUG */" abbrev-korrekt-ifdeb 1)
fprintf( stderr, \"\",  );
#endif" abbrev-korrekt-dprint 0)
    ("forever" "for(;;)
    ("if" "if( )
 ("whil" "while( )
    ("main" "/* Time-stamp: \"abc\"
#include <stdlib.h>
#include <stddef.h>
#include <stdio.h>
#include <string.h>
  return 0;
} /* main( int nargs, char **args ) */" nil 0)
    ("lprint" "lgprintf( LogHandle, \"\\n\" )" abbrev-korrekt-printf 0)
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
    ("do" "do
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
      case :
        break;
    default :
      break;
      case :
        break;
    default :
      break;
#endif /* DEBUG */" nil 0)
    ("for" "for(; ;  )
    ("inc" "#include <.h>
(define-abbrev-table 'java-mode-abbrev-table '(
    ("if" "if( )
    ("cout" "System.out.println(" nil 0)
 ("while" "while( )
// javac klassenname.JAVA && java klassenname
import java.util.*;
public class klassenname
    public static void main( String args[] )
        System.out.println( );
} // public class klassenname
" abbrev-java-korrekt-main 1)
    ("finally" "finally" c-electric-continued-statement 0)
    ("for" "for(; ;  )
(define-abbrev-table 'objc-mode-abbrev-table '(
    ("while" "while" c-electric-continued-statement 0)
(define-abbrev-table 'latex-mode-abbrev-table '(
    ("bzw" "beziehungsweise" nil 0)
    ("bzgl" "bezüglich" nil 0)
    ("zb" "zum Beispiel" nil 0)
    ("bspw" "beispielsweise" nil 0)
    ("usw" "und so weiter" nil 0)
    ("ggf" "gegebenenfalls" nil 0)
    ("zzgl" "zuzüglich" nil 0)
    ("idr" "in der Regel" nil 0)
    ("foot" "{\\footnotesize}" abbrev-korrekt-latex-foot 0)
    ("script" "{\\scriptsize}" abbrev-korrekt-latex-script 0)
    ("item" "\\item" nil 0)
    ("bf" "{\\bf}" abbrev-korrekt-latex-em 0)
    ("Huge" "{\\Huge}" abbrev-korrekt-latex-huge 0)
    ("bibi" "{\\bibitem}" abbrev-korrekt-latex-bibi 0)
    ("bibitem" "\\bibitem[]{} % [Bezeichnung im Text]{label}
{:\\\\ % Verfasser
{\\em \\\\ % Titel
\\/}\\\\ % Untertitel
\\\\ % Verlag, Jahr
ISBN % ggf.ISBN
}" nil 1)
    ("doc" "%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
% Time-stamp: \"a\"
% Copyright:
% (C) 2002 AnyWare
% Klaus Wachtler
% Breidingstr. 17
% 29614 Soltau
% Tel. (49)-5191-70 2 71
% Fax: (49)-5191-70 2 72
% eMail AnyWare@Wachtler.de
% Geschichte:
% Datum:     Name: Vers. Aenderung:
%  kw    0.1   Basisversion
% Zukunft:
% Benoetigt:
% dvips
% c2tex
%%%% entweder Needstexformat..., documentclass... mit den             %
%%%% usepackage... (neues LaTeX)                                      %
\\NeedsTeXFormat{LaTeX2e}                                             %
\\documentclass[12pt,a4paper,twoside,titlepage]{article}              %
\\usepackage{a4,german,makeidx,graphicx}                              %
%\\usepackage{helvet}                                                  %
\\usepackage[ansinew]{inputenc}                                       %
\\usepackage{epsf,colordvi}                                           %
\\usepackage{html}					              %
\\usepackage{htmllist}			         		      %
\\usepackage{marvosym}
\\usepackage{fancyhdr}					      %
%%%% oder documentstyle... und input{psbox} (alt, fuer tex2rtf)       %
%\\documentstyle[12pt,german,inputenc,texhelp]{book}                   %
%\\input{psbox}                                                        %
%\\inputencoding{ansinew}                                              %
\\parindent0pt
\\parskip5mm
%\\textheight25cm
%\\textwidth10cm
%\\topmargin0cm
%\\leftmargin0cm
%\\evensidemargin0cm
%\\oddsidemargin0cm
%\\input{version.tex}
\\makeindex
%\\renewcommand\\familydefault{\\sfdefault}
\\begin{document}
%\\pagestyle{myheadings}
%\\pagestyle{headings}
\\pagestyle{fancy}
\\newsavebox{\\logo}
\\savebox{\\logo}{\\makebox{\\raisebox{-1em}{\\parbox[t]{2cm}{\\includegraphics[width=3cm]{anywbutn.eps}}}}}
\\renewcommand{\\sectionmark}[1]{\\markboth{{\\sl \\thesection\\ #1}}{}}
\\renewcommand{\\subsectionmark}[1]{\\markright{{\\sl \\thesubsection\\ #1}}}
\\renewcommand{\\headrulewidth}{0.15pt}
\\addtolength{\\headheight}{5mm}
\\fancyhead{}
\\fancyhead[LE,RO]{\\thepage}
\\fancyhead[CE]{\\leftmark}
\\fancyhead[CO]{\\rightmark}
\\fancyhead[RE]{\\usebox{\\logo}}
\\fancyhead[LO]{\\usebox{\\logo}}
\\newcommand{\\CC}{C\\nolinebreak\\hspace{-.05em}\\raisebox{.4ex}{\\tiny\\bf +}\\nolinebreak\\hspace{-.10em}\\raisebox{.4ex}{\\tiny\\bf +}}
\\author{Klaus Wachtler}
\\date{\\today}
\\title{Titel...\\\\[5mm]
%includegraphics[width=4cm]{anywbutn.ps}\\\\[3mm]
%Version \\version
\\maketitle
\\clearpage
\\tableofcontents
\\clearpage
\\section{Einleitung}
%\\addcontentsline{toc}{chapter}{Literatur}
%\\begin{thebibliography}{STROU78945dddddd}
%\\bibitem[man make]{lit-man-make} % Label fuer \\cite{...}
%{Dennis Morse\\index{Dennis Morse}\\index{Morse, Dennis}, Roland McGrath\\index{Roland McGrath}\\index{McGrath, Roland}:\\\\ % Verfasser
%{\\em make - GNU make utility to maintain groups of programs\\\\ % Titel
%{\\tt{}man 1L make}\\/}\\\\ % Untertitel
%{\\em Linux man pages, 1989-2000 by the Free Software Foundation\\index{Free Software Foundation},
%Inc.\\/, {\\tt http://www.fsf.org}}\\\\ % Verlag/Ort, Jahr
%\\bibitem[info make]{lit-info-make} % Label fuer \\cite{...}
%{Free Software Foundation:\\\\
%{\\tt{}info make}\\/}\\\\ % Untertitel
%\\bibitem[man bash]{lit-man-bash} % Label fuer \\cite{...}
%{Brian Fox\\index{Brian Fox}\\index{Fox, Brian}, Chet Ramey\\index{Chet Ramey}\\index{Ramey, Chet}:\\\\ % Verfasser
%{\\em bash - GNU\\index{GNU} Bourne-Again SHel\\\\ % Titel
%{\\tt{}man 1 bash}\\/}\\\\ % Untertitel
%{\\em Linux man pages, 1989-1999 by the Free Software Foundation\\index{Free Software Foundation},
%{\\em Brian Fox, Free Software Foundation, {\\tt bfox@gnu.ai.MIT.Edu}\\/}\\\\
%{\\em Chet Ramey, Case Western Reserve University, {\\tt chet@ins.CWRU.Edu}\\/}\\\\ % Verlag, Jahr
%\\bibitem[info bash]{lit-info-bash} % Label fuer \\cite{...}
%{Brian Fox\\index{Fox, Brian}, Chet Ramey\\index{Ramey, Chet}:\\\\ % Verfasser
%{\\em bash - GNU\\index{GNU} Bourne-Again SHell\\\\ % Titel
%info bash\\/}\\\\ % Untertitel
%\\bibitem[Herold: Shell]{lit-herold-shells} % Label fuer \\cite{...}
%{Helmut Herold\\index{Helmut Herold}\\index{Herold, Helmut}:\\\\ % Verfasser
%{\\em Linux - Unix Shells\\\\ % Titel
%Bourne-Shell\\index{Bourne-Shell}, Korn-Shell\\index{Korn-Shell},
%C-Shell\\index{C-Shell}, bash\\index{bash}, tcsh\\index{tcsh}\\/}\\\\ % Untertitel
%3. Auflage\\\\
%Addison Wesley, 1999\\\\ % Verlag, Jahr
%ISBN 3-8273-1511-5% ggf.ISBN
%\\bibitem[LaTeX2html]{lit-latextotohtml} % Label fuer \\cite{...}
%{Nikos Drakos\\index{Nikos Drakos}\\index{Drakos, Nikos}:\\\\ % Verfasser
%{\\em The \\latextotohtml\\index{\\sortby+LaTeX2html+\\latextotohtml}{} Translator\\\\ % Titel
%(Onlinehilfe zu \\latextotohtml{}\\index{\\sortby-LaTeX2html-\\latextotohtml{}} Version 96.1)\\/}\\\\ % Untertitel
%CTAN\\index{CTAN} (Comprehensive \\TeX{} archive\\index{Comprehensive \\TeX{} archive}), z.B.\\ {\\tt ftp.shsu.edu}, {\\tt ftp.dante.de} % Verlag, Jahr
%\\bibitem[v.Helden,Dunkel: Inf2]{lit-jvh-inf-ii}
%{Josef v.\\ Helden\\index{Josef v.\\ Helden}\\index{\\sortby-Helden, Josef-v.\\ Helden, Josef}, Jürgen Dunkel\\index{Jürgen Dunkel}\\index{Dunkel Jürgen}:}\\\\
%{\\em Informatik 2\\\\
%Vorlesungsskript Sommersemester 2000\\/}\\\\
%FH Hannover, FB Informatik
%\\bibitem[Knuth 1]{knuth1}{Donald E.\\ Knuth:\\\\
%{\\em The Art of Computer Programming\\/}\\\\
%{\\em Vol. 1: Fundamental Algorithms\\/}\\\\
%2. Auflage\\\\
%Addison-Wesley, 1973\\\\
%ISBN 0-201-03809-9
%\\bibitem[Knuth 2]{knuth2}{Donald E.\\ Knuth:\\\\
%{\\em Vol. 2: Seminumerical Algorithms\\/}\\\\
%2. Auflage\\\\
%Addison-Wesley, 1971\\\\
%ISBN 0-201-03822-6
%\\bibitem[Knuth 3]{knuth3}{Donald E.\\ Knuth:\\\\
%{\\em Vol. 3: Sorting and Searching\\/}\\\\
%2. Auflage\\\\
%ISBN 0-201-03803-X
%\\bibitem[Knuth Sel.]{knuthsel}{Donald E.\\ Knuth:\\\\
%{\\em Selected Papers on Computer Science\\/}\\\\
%Center for the Study of language and Information (CSLI Publications), Leland Stanford Junior University 1996\\\\
%ISBN 1-881526-91-7 (paperback)\\\\
%ISBN 1-881526-92-5 (hardback)\\\\
%%{\\em Kein Lehrbuch, aber sehr interessant zu lesen\\/}
%\\bibitem[Ziegenbalg]{ziegenbalg} % Label fuer \\cite{...}
%{Jochen Ziegenbalg:\\\\ % Verfasser
%{\\em Algorithmen\\\\ % Titel
%Von Hammurapi bis Gödel\\/}\\\\ % Untertitel
%Spektrum Akademischer Verlag, 1996\\\\ % Verlag, Jahr
%ISBN 3-8274-0114-3% ggf.ISBN
%%{\\em Recht interessant zu lesen, weil neben der nüchternen
%%Beschreibung auch ein paar Geschichten erzählt werden.\\/}
%\\bibitem[Sedgewick C]{lit-sedgewick-c-dt}{Robert Sedgewick:\\\\ % Verfasser
%{\\em Algorithmen in C\\/}\\\\ % Untertitel
%Addison Wesley 1992\\\\
%ISBN 3-89319-376-6
%%{\\em Gutes Lehr- und Referenzbuch für einen relativ weiten Bereich (Suchen,
%%Sortieren, Zeichenfolgen, etwas Geometrie, etwas Numerik)\\/}
%\\bibitem[Sedgewick C (eng.)]{lit-sedgewick-c-en}{Robert Sedgewick:\\\\ % Verfasser
%{\\em Algorithms in C\\/}\\\\ % Untertitel
%Addison Wesley 1990\\\\
%ISBN 0-201-51425-7
%%{\\em Originaltext der deutschen Übersetzung \\cite{lit-sedgewick-c-dt}\\/}
%\\bibitem[Strou II]{lit-stro2}{Bjarne Stroustrup:\\\\
%{\\em Die C++ Programmiersprache\\/}\\\\
%2. Auflage\\\\
%Addison-Wesley, 1992
%\\bibitem[Strou IV]{lit-stro4}{Bjarne Stroustrup:\\\\
%4. Auflage\\\\
%Addison-Wesley, 1999   % TODO: Datum strou4
%\\bibitem[Cline: C++ FAQs]{lit-cppfaq}{Marshall Cline, Greg Lomow, Mike Girou:\\\\
%{\\em C++ FAQs\\/}\\\\
%2nd Edition\\\\
%Addison-Wesley,  1999\\\\
%{\\em Eine Sammlung vieler kleinerer Aspekte zu C++, CORBA und COM\\/}
%\\bibitem[Josuttis: Stdbib.]{lit-josuttis-standardbibliothek}{Nicolai Josuttis::\\\\
%{\\em Die C++-Standardbibliothek\\/}\\\\
%Eine detaillierte Einführung in die vollständige ANSI/ISO-Schnittstelle\\\\
%1. Auflage\\\\
%ISBN 3-8273-1023-7\\\\
%Addison-Wesley,  1996
%\\bibitem[RRZN]{lit-rrzn}{{\\em Die Programmiersprache C++ für C-Programmierer\\\\
%RRZN-Klassifikationsschlüssel SPR.C 2\\/}\\\\
%3. Auflage\\\\
%Revision B
%Regionales Rechenzentrum für Niedersachsen/Universität Hannover\\\\
%Juni 1993
%\\bibitem[KW:0 ist false]{lit-cbuch}{Klaus Wachtler:\\\\
%{\\em 0 ist false, alles andere true}\\\\
%Selbstverlag Klaus Wachtler\\\\
%Breidingstraße 17\\\\
%29614 Soltau\\\\
%\\htmladdnormallink{http://www.wachtler.de}{http://www.wachtler.de}\\\\
%August 2001
%\\bibitem[ct 9/94 Hartinger]{lit-ct-syntaxpuzzle}{Roland Hartinger:\\\\
%{\\em Syntax-Puzzle\\\\
%Die jüngsten C++-Erweiterungen\\/}\\\\
%c't 9/1994, S. 184\\\\
%Korrektur in c't 10/1994, S. 12\\\\
%{\\em Kurzabriß der neueren Sprachelemente (außer templates):\\\\
%Ausnahmebehandlung, RTTI, Namensräume (name spaces)\\/}
%\\bibitem[ct 9/94 Hueskes]{lit-ct-hueskes}{Ralf Hüskes:\\\\
%{\\em Geduldsspiel\\\\
%Der kommende C++-Standard\\/}\\\\
%c't 9/1994, S. 180\\\\
%{\\em Zur Standardisierung von C++, Interview mit Bjarne Stroustrup\\/}
%\\bibitem[ct 11/94 Langner]{lit-ct-langner}{Angelika Langner:\\\\
%{\\em Instantware\\\\
%Die neuen Standardklassen für C++\\/}\\\\
%c't 11/1994, S. 272\\\\
%\\bibitem[c't 5/89 Bayerbäume]{lit-ct-bayerbaeume}{:\\\\ % Verfasser
%{\\em Bayer-Bäume\\\\ % Titel
%-\\/}\\\\ % Untertitel
%c't 5/89, S. 178\\\\ % Verlag, Jahr
%\\bibitem[c't 6/89 Winkler/M.]{lit-ct-starke-typen}{Eckart Winkler,
%Dirk Meiners:\\\\ % Verfasser
%{\\em Starke Typen\\\\ % Titel
%Funktions- und Prozedurtypen in modernen Programmiersprachen\\/}\\\\ % Untertitel
%c't 6/89, S. 174\\\\ % Verlag, Jahr
%%{\\em Kurze und verständliche Beschreibung der Übergabe von Funktionen
%%und Prozeduren als Parameter in C, Turbo-Pascal, und Modula-2\\/}
%\\bibitem[c't 6/89 Berchtold]{lit-ct-evolution-im-computer}{Stefan Berchtold:\\\\ % Verfasser
%{\\em Evolution im Computer\\\\ % Titel
%Optimierung mit genetischen Algorithmen\\/}\\\\ % Untertitel
%c't 6/89, S. 130\\\\ % Verlag, Jahr
%%{\\em Übersichtliche Beschreibung des Konzepts der genetischen
%%Algorithmen, mit einem Beispiel in Pascal (Entwickeln einer
%%Spielstrategie für das Spiel {\\em Nimm\\/})\\/}
%\\bibitem[Eckel: TIC++ 1]{lit-tica1}{Bruce Eckel:\\\\
%{\\em Thinking in C++\\\\
%Volume 1\\/}\\\\
%\\htmladdnormallink{http://www.mindview.net/Books/DownloadSites}{http://www.mindview.net/Books/DownloadSites}
%\\bibitem[Eckel: TIC++ 2]{lit-tica2}{Bruce Eckel:\\\\
%Volume 2\\/}\\\\
%\\bibitem[Eckel: TIJ]{lit-tij}{Bruce Eckel:\\\\
%{\\em Thinking in Java}\\\\
%\\bibitem[KW-C++]{lit-kw-cpp} % Label fuer \\cite{...}
%{Klaus Wachtler:\\\\ % Verfasser
%{\\em Ein Überblick über die Programmierung mit  C++}\\\\ % Untertitel
%Selbstverlag, 2002\\\\ % Verlag, Jahr
%\\bibitem[KW-DLL]{lit-kw-dll} % Label fuer \\cite{...}
%{\\em Dynamische Bibliotheken unter Windows und Linux\\/}\\\\
%Selbstverlag 2002\\\\ % Verlag, Jahr
%% [3] N. Wirth, Compilerbau, 4. Auflage, Stuttgart 1986
%% GNU Coding Standards:
%% http://www.gnu.org/prep/standards_toc.html
%\\bibitem[Muellges/R.]{lit-muellges-reutter}{G. Engeln-Müllges\\index{Engeln-Müllges, Gisela}, F. Reutter\\index{Reutter, Fritz}:\\\\
%{\\em Numerische Mathematik\\/}\\\\
%Bibliographisches Institut Mannheim\\\\
%ISBN 3-411-01688-4 \\\\ % ggf.ISBN
%%{\\em Sehr praxisgerechte Darstellung der wichtigsten numerischen
%%Verfahren aus der Technik (Fehleranalyse, Lösen von Gleichungen,
%%numerische Lösung von linearen und nichtlinearen Gleichungssystemen\\index{Gleichungssystem},
%%Approximation\\index{Approximation}, Interpolation\\index{Interpolation}, numerisches Integrieren\\index{Integrieren},
%%Anfangswertprobleme\\index{Anfangswertprobleme}).
%%Als Ergänzung ist eine Formelsammlung \\cite{lit-muellges-reutter-fs-f77} erhältlich.\\/}
%\\bibitem[Muellges/R./F77]{lit-muellges-reutter-fs-f77}{G. Engeln-Müllges\\index{Engeln-Müllges, Gisela}, F. Reutter\\index{Reutter, Fritz}:\\\\
%{\\em Formelsammlung zur Numerischen Mathematik mit Standard-FORTRAN~77-Programmen\\/}\\\\
%ISBN 3-411-03125-5 \\\\ % ggf.ISBN
%%{\\em \\index{Formelsammlung}Formelsammlung zum Nachschlagen als Ergänzung zu
%%\\cite{lit-muellges-reutter};  enthält alle Verfahren in Fortran\\index{Fortran}~77
%%formuliert. Analoge Ausgaben sind mit BASIC\\index{BASIC}, Pascal\\index{Pascal} und C\\index{C} erhältlich.\\/}
%\\bibitem[Solomon: Inside NT]{lit-solomon-inside-nt}{David A.\\ Solomon:\\\\ % Verfasser
%{\\em Inside Windows NT\\\\
%The Official Guide to the Architecture and Internals of Microsoft's
%Premier Operating System\\/}\\\\ % Untertitel
%Second Edition
%Microsoft Press 1998\\\\ % Verlag, Jahr
%ISBN 1-57231-677-2 % ggf.ISBN
%\\bibitem[Solomon: Inside NT]{lit-solomon-inside-nt-dt} % Label fuer \\cite{...}
%{David A.\\ Solomon:\\\\ % Verfasser
%{\\em Inside Windows NT\\\\ % Titel
%Der offizielle Führer zur Architektur von Windows NT 4.0\\/}\\\\ % Untertitel
%ISBN 3-86063-435-6% ggf.ISBN
%\\bibitem[Solomon: Inside 2000 dt.]{lit-solomon-inside-zweitausend}{David A.\\ Solomon, Mark Russinovich:\\\\ % Verfasser
%{\\em Inside Microsoft Windows 2000\\\\ % Titel
%Der offizielle Leitfaden zur Architektur der Betriebssystemplattform
%Windows 2000\\/}\\\\ % Untertitel
%3. Auflage\\\\
%Microsoft Press \\\\ % Verlag, Jahr
%ISBN 3-86063-630-8
%\\bibitem[Richter: Experten]{lit-richter-experten} % Label fuer \\cite{...}
%{Jeffrey Richter:\\\\ % Verfasser
%{\\em Microsoft Windows Programmierung für Experten\\\\ % Titel
%Profiwissen zur Programmierung von Anwendungen für Windows 98 und
%Microsoft Press 2000\\\\ % Verlag, Jahr
%ISBN 86063-615-4% ggf.ISBN
%\\bibitem[Sheldon: NT Sec.]{lit-sheldon-nt-security} % Label fuer \\cite{...}
%{Tom Sheldon:\\\\ % Verfasser
%{\\em Windows NT Security\\\\ % Titel
%Everything You Need to Protect Your Network\\/}\\\\ % Untertitel
%McGraw-Hill 1997\\\\ % Verlag, Jahr
%ISBN 0-07-882240-8% ggf.ISBN
%\\bibitem[Bähring-Mikrorechner]{lit-baerhing-mikrorechner}
%{Helmut Bähring u.a.:\\\\ % Verfasser
%{\\em Mikrorechner-Systeme\\\\
%Mikroprozessoren, Speicher, Peripherie\\/}\\\\
%Springer-Verlag 1994\\\\
%ISBN 3-540-58362-9
%\\bibitem[Krieg d.\\ Codes]{lit-krieg-der-codes} % Label fuer \\cite{...}
%{G.\\ P.\\ Zachary:\\\\ % Verfasser
%{\\em Der Krieg der Codes\\\\ % Titel
%Wie Microsoft ein neues Betriebssystem entwickelt.\\/}\\\\ % Untertitel
%1996\\\\
%ISBN 345511038X% ggf.ISBN
%\\bibitem[MSDN]{lit-msdn}
%{Microsoft:\\\\ % Verfasser
%{\\em MS Developer Network}\\\\
%(Online-Dokumentation zu Developer Studio)
%\\bibitem[Stev.:Adv.Prg.Unix]{lit-stevens-advanced-unix} % Label fuer \\cite{...}
%{W. Richard Stevens:\\\\ % Verfasser
%{\\em Advanced Programming in the Unix Environment\\/}\\\\ % Untertitel
%Addison Wesley 1993\\\\ % Verlag, Jahr
%ISBN 0-201-56317-7% ggf.ISBN
%\\bibitem[Stevens:Sockets]{lit-stevens-sockets} % Label fuer \\cite{...}
%{\\em Unix Network Programming\\\\ % Titel
%Vol. 1: Networking APIs: Sockets and XTI\\/}\\\\ % Untertitel
%Prentice Hall 1997\\\\ % Verlag, Jahr
%ISBN 0-13-490012-X% ggf.ISBN
%\\bibitem[Stevens:IPC]{lit-stevens-ipc} % Label fuer \\cite{...}
%Vol. 2: Interprocess Communications\\/}\\\\ % Untertitel
%Second Edition\\\\
%Prentice Hall 1998\\\\ % Verlag, Jahr
%ISBN ISBN 0-13-081081-9 % ggf.ISBN
%\\bibitem[Rago: Netw.Prog.]{citeRagoUNIXSVNetworkProgramming} % Label fuer \\cite{...}
%{Stephen A.\\ Rago:\\\\ % Verfasser
%{\\em UNIX System V Network Programming\\/}\\\\ % Untertitel
%Addison Wesley, 1993\\\\ % Verlag, Jahr
%ISBN 0-201-56318-5% ggf.ISBN
%%{\\em Dieses Buch hat im Vorspann eine sehr übersichtliche und gut
%%verständliche Einführung in die Programmierung unter Unix; daher auch
%%sehr interessant, wenn man gar nichts mit Netzwerkprogrammierung zu
%%tun hat!
%%Für Netzwerkprogrammierung selbst ist es eher uninteressant, weil der
%%Stoff nur unter System V R4 benutzbar ist (die
%%ganzen \\verb+t_+\\ldots-Funktionen
%%gemäß X/Open Transport Interface XTI).
%%Hier ist \\meinrefsiehe{Unix Network
%%Programming Vol. 1}{lit-stevens-sockets} geeigneter.\\/}
%\\bibitem[Riepe: Erbstücke]{lit-ix-riepe-erbstuecke} % Label fuer \\cite{...}
%{Michael Riepe:\\\\ % Verfasser
%{\\em Erbstücke\\\\ % Titel
%Umgang mit Shellvariablen\\/}\\\\ % Untertitel
%Heise Verlag iX August 2002\\\\ % Verlag, Jahr
%ISSN 0935-9680 % ggf.ISBN
%\\bibitem[Riepe: Kreuz und quer]{lit-ix-riepe-kreuz-und-quer} % Label fuer \\cite{...}
%{\\em Kreuz und quer\\\\ % Titel
%Ein- und Ausgabeumlenkung in der Shell\\/}\\\\ % Untertitel
%Heise Verlag iX Oktober 2002\\\\ % Verlag, Jahr
%%\\htmladdnormallink{http://www.codeguru.com/}{http://www.codeguru.com/}
%\\end{thebibliography}
\\end{document}
" abbrev-korrekt-latex-doc 0)
    ("Large" "{\\Large}" abbrev-korrekt-latex-large 0)
    ("sec" "\\section{}" abbrev-korrekt-latex-sec 0)
    ("tt" "{\\tt}" abbrev-korrekt-latex-em 0)
    ("gf" "\"`\"'" abbrev-korrekt-latex-gfuss 1)
    ("huge" "{\\huge}" abbrev-korrekt-latex-huge 0)
    ("ssec" "\\subsection{}" abbrev-korrekt-latex-sec 0)
    ("em" "{\\em\\/}" abbrev-korrekt-latex-em 7)
    ("large" "{\\large}" abbrev-korrekt-latex-large 0)
    ("sssec" "\\subsubsection{}" abbrev-korrekt-latex-sec 0)
    ("sf" "{\\sf}" abbrev-korrekt-latex-em 0)
    ("mrs" "\\meinrefsiehe" nil 0)
    ("verb" "\\verb" nil 5)
    ("LARGE" "{\\LARGE}" abbrev-korrekt-latex-large 0)
(define-abbrev-table 'lisp-mode-abbrev-table '(
(define-abbrev-table 'fundamental-mode-abbrev-table '(
(define-abbrev-table 'global-abbrev-table '(
