# Automatically-generated file. Do not edit!
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS := 
PROJ := 
O_SRCS := 
C_SRCS := 
S_SRCS := 
S_UPPER_SRCS := 
OBJ_SRCS := 
ASM_SRCS := 
PREPROCESSING_SRCS := 
OBJS := 
OBJS_AS_ARGS := 
C_DEPS := 
C_DEPS_AS_ARGS := 
EXECUTABLES := 
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=$$$AVR_APP_PATH$$$
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:=
# Every subdirectory with source files must be described here
SUBDIRS := 
# Add inputs and outputs from these tool invocations to the build variables 
C_SRCS +=  \
../lcd-routines.c \
../Transistortester.c
PREPROCESSING_SRCS +=  \
../CombineToLong.S \
../ReadADC.S \
../swuart.S \
../wait1000ms.S
ASM_SRCS += 
OBJS +=  \
CombineToLong.o \
lcd-routines.o \
ReadADC.o \
swuart.o \
Transistortester.o \
wait1000ms.o
OBJS_AS_ARGS +=  \
CombineToLong.o \
lcd-routines.o \
ReadADC.o \
swuart.o \
wait1000ms.o
C_DEPS +=  \
lcd-routines.d \
Transistortester.d
C_DEPS_AS_ARGS +=  \
lcd-routines.d \
Transistortester.d
OUTPUT_FILE_PATH +=Transistortester.elf
OUTPUT_FILE_PATH_AS_ARGS +=Transistortester.elf
# AVR32/GNU C Compiler
./%.o: .././%.c
	@echo Building file: $<
	@echo Invoking: AVR/GNU C Compiler : (AVR_8_bit_GNU_Toolchain_3.4.0_663) 4.6.2
	$(QUOTE)C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-gcc.exe$(QUOTE) -funsigned-char -funsigned-bitfields -Os -fpack-struct -fshort-enums -g2 -Wall -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"  -mmcu=atmega168   -o"$@" "$<" 
	@echo Finished building: $<
# AVR32/GNU Preprocessing Assembler
# AVR32/GNU Assembler
./CombineToLong.o: .././CombineToLong.s
	@echo Invoking: AVR32/GNU Assembler : (AVR_8_bit_GNU_Toolchain_3.4.0_663) 4.6.2
	$(QUOTE)C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-gcc.exe$(QUOTE) -Wa,-gdwarf2 -x assembler-with-cpp -c -Wa,-g  -mmcu=atmega168   -o"$@" "$<"
./ReadADC.o: .././ReadADC.s
./swuart.o: .././swuart.s
./wait1000ms.o: .././wait1000ms.s
./%.o: .././%.s
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP)
	@echo Building target: $@
	@echo Invoking: AVR/GNU Linker : (AVR_8_bit_GNU_Toolchain_3.4.0_663) 4.6.2
	$(QUOTE)C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="Transistortester.map" -Wl,--start-group -Wl,-lm -Wl,-lm  -Wl,--end-group  -mmcu=atmega168  
	@echo Finished building target: $@
	"C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature  "Transistortester.elf" "Transistortester.hex"
	"C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "Transistortester.elf" "Transistortester.eep" || exit 0
	"C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-objdump.exe" -h -S "Transistortester.elf" > "Transistortester.lss"
	"C:\Program Files (x86)\Atmel\Atmel Studio 6.0\extensions\Atmel\AVRGCC\3.4.0.65\AVRToolchain\bin\avr-size.exe" "Transistortester.elf"
# Other Targets
clean:
	-$(RM) $(OBJS_AS_ARGS)$(C_DEPS_AS_ARGS) $(EXECUTABLES) 
	rm -rf "Transistortester.elf" "Transistortester.a" "Transistortester.hex" "Transistortester.lss" "Transistortester.eep" "Transistortester.map"
