10:41:04 29.07.12 Start program V2.0.12725-64 (Linux) 10:41:04 Use INI file: /opt/EleLa/EleLa.ini 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadInteger 10:41:04 F: -ReadInteger 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadString 10:41:04 F: -ReadString 10:41:04 F: ReadInteger 10:41:04 F: -ReadInteger 10:41:04 F: ReadInteger 10:41:04 F: -ReadInteger 10:41:04 Parameter [DB] Protocol=sqlite-3 10:41:04 Parameter [DB] Database=/opt/EleLa/EleLa.sq3 10:41:04 Parameter [Programm] VorlageDir=/opt/EleLa/Vorlage/ 10:41:04 Parameter [Programm] TempDir=/opt/EleLa/Temp/ 10:41:04 Parameter [Programm] QueryCancel=1 10:41:04 Parameter [Bauteil] DefHandbuchDir=/opt/EleLa/Handbuch 10:41:04 Parameter [Projekt] DefHandbuchDir=/opt/EleLa/Projekt 10:41:04 Parameter [Linux] ComboItemHeight=9 10:41:04 Parameter [Linux] FontHeight=11 10:41:04 Parameter [Debug] Mode=2 10:41:04 F: CreateTables 10:41:04 F: DBBeforeConnect 10:41:04 F: -DBBeforeConnect 10:41:04 Error on Test Database. 10:41:05 F: spProjektDetClick 10:41:05 F: -spProjektDetClick 10:41:05 F: spPPosDetClick 10:41:05 F: -spPPosDetClick 10:41:05 F: spHist1DetClick 10:41:05 F: -spHist1DetClick 10:41:05 F: spHistDetClick 10:41:05 F: -spHistDetClick 10:41:05 F: spBestellDetClick 10:41:05 F: -spBestellDetClick 10:41:05 F: spAdrBankDetClick 10:41:05 F: -spAdrBankDetClick 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: TBildList.Create 10:41:05 F: -TBildList.Create 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: CreatePopup 10:41:05 F: -CreatePopup 10:41:05 F: -CreateTables 10:41:05 F: TBildList.OnParentResize.BildBauteil 10:41:05 F: -TBildList.OnParentResize.BildBauteil 10:41:05 F: FormShow 10:41:05 F: -FormShow 10:41:05 F: ApplicationActivate 10:41:05 F: -ApplicationActivate 10:41:05 F: FormActivate 10:41:05 F: -FormActivate 10:41:05 F: tmrBackgroundTimer 10:41:05 Connect database... 10:41:06 F: DBBeforeConnect 10:41:06 F: -DBBeforeConnect 10:41:06 Error: Cannot open database! SQL Error: library routine called out of sequence (DB-Connect) 10:41:06 F: pgMainChanging 10:41:06 F: -pgMainChanging 10:41:06 F: pgMainChanging 10:41:06 F: -pgMainChanging 10:41:06 F: -tmrBackgroundTimer 10:41:06 F: tmrBackgroundTimer 10:41:06 Connect database... 10:41:06 F: DBBeforeConnect 10:41:06 F: -DBBeforeConnect 10:41:06 Error: Cannot open database! SQL Error: library routine called out of sequence (DB-Connect) 10:41:06 F: -tmrBackgroundTimer 10:41:21 F: tmrBackgroundTimer 10:41:21 Connect database... 10:41:21 F: DBBeforeConnect 10:41:21 F: -DBBeforeConnect 10:41:21 Error: Cannot open database! SQL Error: library routine called out of sequence (DB-Connect) 10:41:21 F: -tmrBackgroundTimer 10:41:22 F: ApplicationActivate 10:41:22 F: -ApplicationActivate 10:41:36 F: tmrBackgroundTimer 10:41:36 Connect database... 10:41:36 F: DBBeforeConnect 10:41:36 F: -DBBeforeConnect 10:41:36 Error: Cannot open database! SQL Error: library routine called out of sequence (DB-Connect) 10:41:36 F: -tmrBackgroundTimer 10:41:38 F: ApplicationActivate 10:41:38 F: -ApplicationActivate 10:41:44 F: mnDebugLogCopyAllClick
