12:17:33 --------- 12:17:33 13.08.12 Start program V2.0.12811-64 (Linux) 12:17:33 Use INI file: /opt/EleLa/EleLa.ini 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadInteger 12:17:33 F: -ReadInteger 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: KorrectPath: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_1: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_2: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_3: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_4: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_5: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_6: /opt/EleLa/EleLa.sq3 12:17:33 Fx: KorrectPath_7: /opt/EleLa/EleLa.sq3 12:17:33 F: -KorrectPath_7: /opt/EleLa/EleLa.sq3 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: KorrectPath: ./Handbuch 12:17:33 Fx: KorrectPath_1: ./Handbuch 12:17:33 Fx: KorrectPath_2: /opt/EleLa/Handbuch 12:17:33 Fx: KorrectPath_3: /opt/EleLa/Handbuch 12:17:33 Fx: KorrectPath_4: /opt/EleLa/Handbuch 12:17:33 Fx: KorrectPath_5: /opt/EleLa/Handbuch 12:17:33 Fx: KorrectPath_6: /opt/EleLa/Handbuch 12:17:33 Fx: KorrectPath_7: /opt/EleLa/Handbuch 12:17:33 F: -KorrectPath_7: /opt/EleLa/Handbuch 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: KorrectPath: ./Projekt 12:17:33 Fx: KorrectPath_1: ./Projekt 12:17:33 Fx: KorrectPath_2: /opt/EleLa/Projekt 12:17:33 Fx: KorrectPath_3: /opt/EleLa/Projekt 12:17:33 Fx: KorrectPath_4: /opt/EleLa/Projekt 12:17:33 Fx: KorrectPath_5: /opt/EleLa/Projekt 12:17:33 Fx: KorrectPath_6: /opt/EleLa/Projekt 12:17:33 Fx: KorrectPath_7: /opt/EleLa/Projekt 12:17:33 F: -KorrectPath_7: /opt/EleLa/Projekt 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadString 12:17:33 F: -ReadString 12:17:33 F: ReadInteger 12:17:33 F: -ReadInteger 12:17:33 F: ReadInteger 12:17:33 F: -ReadInteger 12:17:33 Parameter [DB] Protocol=sqlite-3 12:17:33 Parameter [DB] Database=/opt/EleLa/EleLa.sq3 12:17:33 Parameter [Programm] VorlageDir=/opt/EleLa/Vorlage/ 12:17:33 Parameter [Programm] TempDir=/opt/EleLa/Temp/ 12:17:33 Parameter [Programm] QueryCancel=1 12:17:33 Parameter [Bauteil] DefHandbuchDir=/opt/EleLa/Handbuch 12:17:33 Parameter [Projekt] DefHandbuchDir=/opt/EleLa/Projekt 12:17:33 Parameter [Linux] ComboItemHeight=9 12:17:33 Parameter [Linux] FontHeight=11 12:17:33 Parameter [Debug] Mode=2 12:17:33 F: CreateTables 12:17:33 F: DBBeforeConnect 12:17:33 Use LibraryLocation: libsqlite3.so.0 12:17:33 DB.LibraryLocation: libsqlite3.so.0 .Protocol: sqlite-3 .Database: /opt/EleLa/EleLa.sq3 12:17:33 F: -DBBeforeConnect 12:17:33 F: DBAfterConnect 12:17:33 F: -DBAfterConnect 12:17:33 F: qryBeforeOpen 12:17:33 SELECT tbl_name FROM (SELECT * FROM sqlite_master UNION ALL SELECT * FROM sqlite_temp_master) WHERE tbl_name LIKE :Like1 AND type!='meta' ORDER BY type DESC, name 12:17:33 F: -qryBeforeOpen 12:17:33 F: -CreateTables 12:17:33 F: spProjektDetClick 12:17:33 F: -spProjektDetClick 12:17:33 F: spPPosDetClick 12:17:33 F: -spPPosDetClick 12:17:33 F: spHist1DetClick 12:17:33 F: -spHist1DetClick 12:17:33 F: spHistDetClick 12:17:33 F: -spHistDetClick 12:17:33 F: spBestellDetClick 12:17:33 F: -spBestellDetClick 12:17:33 F: spAdrBankDetClick 12:17:33 F: -spAdrBankDetClick 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: TBildList.Create 12:17:33 F: -TBildList.Create 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: CreatePopup 12:17:33 F: -CreatePopup 12:17:33 F: -FormCreate 12:17:33 F: TBildList.OnParentResize.BildBauteil 12:17:33 F: -TBildList.OnParentResize.BildBauteil 12:17:33 F: FormShow 12:17:33 F: -FormShow 12:17:33 F: ApplicationActivate 12:17:33 F: -ApplicationActivate 12:17:33 F: FormActivate 12:17:33 F: -FormActivate 12:17:34 F: tmrBackgroundTimer 12:17:34 Connect database... 12:17:35 F: DBBeforeConnect 12:17:35 DB.LibraryLocation: libsqlite3.so.0 .Protocol: sqlite-3 .Database: /opt/EleLa/EleLa.sq3 12:17:35 F: -DBBeforeConnect 12:17:35 F: DBAfterConnect 12:17:35 F: -DBAfterConnect 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ValText FROM param WHERE ParNr=1 12:17:35 F: -qryBeforeOpen 12:17:35 Database Version: V2.0.12729 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ValText FROM param WHERE ParNr=5 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ValInt FROM param WHERE ParNr=12 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ValText FROM param WHERE ParNr=14 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM adr WHERE ID_ID IS NULL OR ID_ID=0 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: dsAdrDataChange 12:17:35 F: TBildList.SetFotoID.BildAdr 128 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildAdr 128 0 0 0 0 0 12:17:35 F: -dsAdrDataChange 12:17:35 F: qAdrAfterOpen 12:17:35 F: RefreshAdr 12:17:35 F: Fillcbo.cboAdr.adr 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Lieferant=1 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: -Fillcbo.cboAdr.adr 12:17:35 F: Fillcbo.cboAdrLG.adr 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Hersteller=1 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: -Fillcbo.cboAdrLG.adr 12:17:35 F: Fillcbo.cboPAdr.adr 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Projekt=1 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: -Fillcbo.cboPAdr.adr 12:17:35 F: cboPKAdrSelect 12:17:35 F: -cboPKAdrSelect 12:17:35 F: cboH1AdrSelect 12:17:35 F: -cboH1AdrSelect 12:17:35 F: cboHAdrSelect 12:17:35 F: -cboHAdrSelect 12:17:35 F: -RefreshAdr 12:17:35 F: -qAdrAfterOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM gehause ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdCaseSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdCaseSelectEditor 12:17:35 F: grdCaseSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdCaseSelectEditor 12:17:35 F: dsGehauseDataChange 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE l.Gehause_ID = 43 ORDER BY Bezeichnung, LBez 12:17:35 F: -qryBeforeOpen 12:17:35 F: TBildList.SetFotoID.BildCase 143 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildCase 143 0 0 0 0 0 12:17:35 F: -dsGehauseDataChange 12:17:35 F: qGehauseAfterOpen 12:17:35 F: Fillcbo.cboCase.gehause 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, Bezeichnung FROM gehause ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: -Fillcbo.cboCase.gehause 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT Typ FROM gehause ORDER BY Typ 12:17:35 F: -qryBeforeOpen 12:17:35 F: -qGehauseAfterOpen 12:17:35 F: FillcboCaseLib 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT Library FROM gehause WHERE NOT(Library IS NULL) ORDER BY Library 12:17:35 F: -qryBeforeOpen 12:17:35 F: -FillcboCaseLib 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM kiste ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID FROM bauteillager WHERE Kiste_ID = 1 LIMIT 1 OFFSET 0 12:17:35 F: -qryBeforeOpen 12:17:35 F: dsKisteDataChange 12:17:35 F: TBildList.SetFotoID.BildKiste 112 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildKiste 112 0 0 0 0 0 12:17:35 F: TBildList.SetPosBauteil 12:17:35 F: -TBildList.SetPosBauteil 12:17:35 F: -dsKisteDataChange 12:17:35 F: qKisteAfterOpen 12:17:35 F: Fillcbo.cboKiste.kiste 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, Bezeichnung FROM kiste ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: -Fillcbo.cboKiste.kiste 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID FROM bauteillager WHERE Kiste_ID = 1 LIMIT 1 OFFSET 0 12:17:35 F: -qryBeforeOpen 12:17:35 F: dsKisteDataChange 12:17:35 F: -dsKisteDataChange 12:17:35 F: -qKisteAfterOpen 12:17:35 F: TypTreeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM tree_typ ORDER BY ID, ID_ID 12:17:35 F: -qryBeforeOpen 12:17:35 F: dsTypDataChange 12:17:35 F: TBildList.SetFotoID.BildTyp 229 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildTyp 229 0 0 0 0 0 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, c.Bezeichnung AS Gehause, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung, l.EPreis, l.Haltbar, l.BWare, l.RoHS, l.Kennz, l.Gewicht, l.Barcode, l.SMD FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE b.tree_typ_ID = 1 ORDER BY Bezeichnung, LBez, Gehause 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT c.Bezeichnung AS Bezeichnung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) WHERE b.tree_typ_ID = 1 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: panTypCaseResize 12:17:35 F: -panTypCaseResize 12:17:35 F: chkTypCaseItemClick 12:17:35 F: -chkTypCaseItemClick 12:17:35 F: -dsTypDataChange 12:17:35 F: qTypAfterOpen 12:17:35 F: -qTypAfterOpen 12:17:35 F: dsTypDataChange 12:17:35 F: TBildList.SetFotoID.BildTyp 246 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildTyp 246 0 0 0 0 0 12:17:35 F: qryBeforeClose_qTypB 12:17:35 F: -qryBeforeClose_qTypB 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, c.Bezeichnung AS Gehause, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung, l.EPreis, l.Haltbar, l.BWare, l.RoHS, l.Kennz, l.Gewicht, l.Barcode, l.SMD FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE b.tree_typ_ID = 14 ORDER BY Bezeichnung, LBez, Gehause 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT c.Bezeichnung AS Bezeichnung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) WHERE b.tree_typ_ID = 14 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: panTypCaseResize 12:17:35 F: -panTypCaseResize 12:17:35 F: chkTypCaseItemClick 12:17:35 F: -chkTypCaseItemClick 12:17:35 F: -dsTypDataChange 12:17:35 F: dsTypDataChange 12:17:35 F: TBildList.SetFotoID.BildTyp 242 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildTyp 242 0 0 0 0 0 12:17:35 F: qryBeforeClose_qTypB 12:17:35 F: -qryBeforeClose_qTypB 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, c.Bezeichnung AS Gehause, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung, l.EPreis, l.Haltbar, l.BWare, l.RoHS, l.Kennz, l.Gewicht, l.Barcode, l.SMD FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE b.tree_typ_ID = 134 ORDER BY Bezeichnung, LBez, Gehause 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT c.Bezeichnung AS Bezeichnung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) WHERE b.tree_typ_ID = 134 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: panTypCaseResize 12:17:35 F: -panTypCaseResize 12:17:35 F: chkTypCaseItemClick 12:17:35 F: -chkTypCaseItemClick 12:17:35 F: -dsTypDataChange 12:17:35 F: dsTypDataChange 12:17:35 F: TBildList.SetFotoID.BildTyp 247 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildTyp 247 0 0 0 0 0 12:17:35 F: qryBeforeClose_qTypB 12:17:35 F: -qryBeforeClose_qTypB 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, c.Bezeichnung AS Gehause, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung, l.EPreis, l.Haltbar, l.BWare, l.RoHS, l.Kennz, l.Gewicht, l.Barcode, l.SMD FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE b.tree_typ_ID = 124 ORDER BY Bezeichnung, LBez, Gehause 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT c.Bezeichnung AS Bezeichnung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) WHERE b.tree_typ_ID = 124 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: panTypCaseResize 12:17:35 F: -panTypCaseResize 12:17:35 F: chkTypCaseItemClick 12:17:35 F: -chkTypCaseItemClick 12:17:35 F: -dsTypDataChange 12:17:35 F: -TypTreeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM bauteil ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: grdBeschreibungSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBeschreibungSelectEditor 12:17:35 F: TBildList.SetFotoID.BildBauteil 0 0 1 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildBauteil 0 0 1 0 0 0 12:17:35 F: dsBauteilDataChange 12:17:35 F: -dsBauteilDataChange 12:17:35 F: qBauteilAfterOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM bauteillager ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdBLagerSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBLagerSelectEditor 12:17:35 F: grdBLagerSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: -grdBLagerSelectEditor 12:17:35 F: dsBLagerDataChange 12:17:35 F: TBildList.SetFotoID.BildCaseBauteil 0 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildCaseBauteil 0 0 0 0 0 0 12:17:35 F: -dsBLagerDataChange 12:17:35 F: qBLagerAfterOpen 12:17:35 F: CalcBLagerSumMenge 12:17:35 F: qryBeforeOpen 12:17:35 SELECT SUM(Menge) FROM bauteillager WHERE Bauteil_ID=180 12:17:35 F: -qryBeforeOpen 12:17:35 F: -CalcBLagerSumMenge 12:17:35 F: -qBLagerAfterOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.*, l.ArtikelNr, l.ArtikelNr2 FROM bauteiladr b LEFT JOIN bauteillager l ON (l.ID=b.Bauteillager_ID) 12:17:35 F: -qryBeforeOpen 12:17:35 F: grdBAdrSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: CopyObject 12:17:35 F: -CopyObject 12:17:35 F: -grdBAdrSelectEditor 12:17:35 F: grdBAdrSelectEditor 12:17:35 F: grdSelectEditor 12:17:35 F: -grdSelectEditor 12:17:35 F: CopyObject 12:17:35 F: -CopyObject 12:17:35 F: -grdBAdrSelectEditor 12:17:35 F: dsBAdrDataChange 12:17:35 F: TBildList.SetFotoID.BildBauteilAdr 0 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildBauteilAdr 0 0 0 0 0 0 12:17:35 F: -dsBAdrDataChange 12:17:35 F: qBAdrAfterOpen 12:17:35 F: -qBAdrAfterOpen 12:17:35 F: -qBauteilAfterOpen 12:17:35 F: FillcboBLagerLib 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT Library FROM bauteil WHERE NOT(Library IS NULL) ORDER BY Library 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT Library FROM bauteillager WHERE NOT(Library IS NULL) ORDER BY Library 12:17:35 F: -qryBeforeOpen 12:17:35 F: -FillcboBLagerLib 12:17:35 Database connected. 12:17:35 F: tmrSetFocus.edSchnellsuche 12:17:35 F: -tmrSetFocus.edSchnellsuche 12:17:35 Fx: tmrBackgroundTimer1 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM param WHERE ParNr=2 12:17:35 F: -qryBeforeOpen 12:17:35 Fx: tmrBackgroundTimer2 12:17:35 Fx: tmrBackgroundTimer5 12:17:35 F: -tmrBackgroundTimer5 12:17:35 F: TBildList.OnTimer.BildAdr False 128 0 0 0 0 0 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, ID_ID FROM foto WHERE ID=128 OR ID_ID=128 ORDER BY ID 12:17:35 F: -qryBeforeOpen 12:17:35 F: TBildDetail.Create 12:17:35 F: -TBildDetail.Create 12:17:35 F: TBildDetail.SetHint 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.SetHint 12:17:35 AddBild 1: 1 12:17:35 F: TBildDetail.SetInUse True 12:17:35 F: -TBildDetail.SetInUse True 12:17:35 F: TBildList.OnParentResize.BildAdr 12:17:35 F: TBildDetail.SetVisible False 12:17:35 F: -TBildDetail.SetVisible False 12:17:35 F: TBildDetail.SetVisible True 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM foto WHERE ID=128 12:17:35 F: -qryBeforeOpen 12:17:35 Load ID: 128 12:17:35 Load Size: 3121 / W: 90 12:17:35 F: TBildDetail.Resize 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.Resize 12:17:35 F: -TBildDetail.SetVisible True 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildList.OnParentResize.BildAdr 12:17:35 F: -TBildList.OnTimer.BildAdr False 128 0 0 0 0 0 12:17:35 F: TBildList.OnTimer.BildCase False 143 0 0 0 0 0 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, ID_ID FROM foto WHERE ID=143 OR ID_ID=143 ORDER BY ID 12:17:35 F: -qryBeforeOpen 12:17:35 F: TBildDetail.Create 12:17:35 F: -TBildDetail.Create 12:17:35 F: TBildDetail.SetHint 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.SetHint 12:17:35 AddBild 1: 1 12:17:35 F: TBildDetail.SetInUse True 12:17:35 F: -TBildDetail.SetInUse True 12:17:35 F: TBildList.OnParentResize.BildCase 12:17:35 F: TBildDetail.SetVisible False 12:17:35 F: -TBildDetail.SetVisible False 12:17:35 F: TBildDetail.SetVisible True 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM foto WHERE ID=143 12:17:35 F: -qryBeforeOpen 12:17:35 Load ID: 143 12:17:35 Load Size: 3531 / W: 90 12:17:35 F: TBildDetail.Resize 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.Resize 12:17:35 F: -TBildDetail.SetVisible True 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildList.OnParentResize.BildCase 12:17:35 F: -TBildList.OnTimer.BildCase False 143 0 0 0 0 0 12:17:35 F: tvTypClick 12:17:35 F: dsTypDataChange 12:17:35 F: TBildList.SetFotoID.BildTyp 214 0 0 0 0 0 12:17:35 F: -TBildList.SetFotoID.BildTyp 214 0 0 0 0 0 12:17:35 F: qryBeforeClose_qTypB 12:17:35 F: -qryBeforeClose_qTypB 12:17:35 F: qryBeforeOpen 12:17:35 SELECT b.ID AS ID, l.ID AS LID, b.Bezeichnung AS Bezeichnung, b.Beschreibung, l.Bezeichnung AS LBez, l.Menge, c.Bezeichnung AS Gehause, k.Bezeichnung AS Kiste, l.LagerNr, l.Bemerkung, l.EPreis, l.Haltbar, l.BWare, l.RoHS, l.Kennz, l.Gewicht, l.Barcode, l.SMD FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) WHERE b.tree_typ_ID = 59 ORDER BY Bezeichnung, LBez, Gehause 12:17:35 F: -qryBeforeOpen 12:17:35 F: qryBeforeOpen 12:17:35 SELECT DISTINCT c.Bezeichnung AS Bezeichnung FROM bauteil b LEFT JOIN bauteillager l ON (b.ID = l.Bauteil_ID) LEFT JOIN gehause c ON (c.ID = l.Gehause_ID) WHERE b.tree_typ_ID = 59 ORDER BY Bezeichnung 12:17:35 F: -qryBeforeOpen 12:17:35 F: panTypCaseResize 12:17:35 F: -panTypCaseResize 12:17:35 F: chkTypCaseItemClick 12:17:35 F: -chkTypCaseItemClick 12:17:35 F: -dsTypDataChange 12:17:35 F: -tvTypClick 12:17:35 F: TBildList.OnTimer.BildKiste False 112 0 0 0 0 0 12:17:35 F: qryBeforeOpen 12:17:35 SELECT ID, ID_ID FROM foto WHERE ID=112 OR ID_ID=112 ORDER BY ID 12:17:35 F: -qryBeforeOpen 12:17:35 F: TBildDetail.Create 12:17:35 F: -TBildDetail.Create 12:17:35 F: TBildDetail.SetHint 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.SetHint 12:17:35 AddBild 1: 1 12:17:35 F: TBildDetail.SetInUse True 12:17:35 F: -TBildDetail.SetInUse True 12:17:35 F: TBildList.OnParentResize.BildKiste 12:17:35 F: TBildDetail.SetVisible False 12:17:35 F: -TBildDetail.SetVisible False 12:17:35 F: TBildDetail.SetVisible True 12:17:35 F: qryBeforeOpen 12:17:35 SELECT * FROM foto WHERE ID=112 12:17:35 F: -qryBeforeOpen 12:17:35 Load ID: 112 12:17:35 Load Size: 3002 / W: 90 12:17:35 F: TBildDetail.Resize 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.Resize 12:17:35 F: -TBildDetail.SetVisible True 12:17:35 F: TBildDetail.ResizeImgHint 12:17:35 F: -TBildDetail.ResizeImgHint 12:17:35 F: -TBildList.OnParentResize.BildKiste 12:17:35 F: -TBildList.OnTimer.BildKiste False 112 0 0 0 0 0 12:17:36 F: TBildList.OnTimer.BildBauteil False 0 0 1 0 0 0 12:17:36 F: qryBeforeOpen 12:17:36 SELECT Foto_ID FROM tree_typ WHERE ID=1 12:17:36 F: -qryBeforeOpen 12:17:36 F: qryBeforeOpen 12:17:36 SELECT ID, ID_ID FROM foto WHERE ID=229 OR ID_ID=229 ORDER BY ID 12:17:36 F: -qryBeforeOpen 12:17:36 F: TBildDetail.Create 12:17:36 F: -TBildDetail.Create 12:17:36 F: TBildDetail.SetHint 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.SetHint 12:17:36 AddBild 1: 1 12:17:36 F: TBildDetail.SetInUse True 12:17:36 F: -TBildDetail.SetInUse True 12:17:36 F: TBildList.OnParentResize.BildBauteil 12:17:36 F: TBildDetail.SetVisible False 12:17:36 F: -TBildDetail.SetVisible False 12:17:36 F: TBildDetail.SetVisible True 12:17:36 F: qryBeforeOpen 12:17:36 SELECT * FROM foto WHERE ID=229 12:17:36 F: -qryBeforeOpen 12:17:36 Load ID: 229 12:17:36 Load Size: 5200 / W: 90 12:17:36 F: TBildDetail.Resize 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.Resize 12:17:36 F: -TBildDetail.SetVisible True 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildList.OnParentResize.BildBauteil 12:17:36 F: -TBildList.OnTimer.BildBauteil False 0 0 1 0 0 0 12:17:36 F: TBildList.OnTimer.BildCaseBauteil False 0 0 0 0 0 0 12:17:36 F: -TBildList.OnTimer.BildCaseBauteil False 0 0 0 0 0 0 12:17:36 F: TBildList.OnTimer.BildBauteilAdr False 0 0 0 0 0 0 12:17:36 F: -TBildList.OnTimer.BildBauteilAdr False 0 0 0 0 0 0 12:17:36 F: TBildList.OnTimer.BildTyp False 214 0 0 0 0 0 12:17:36 F: qryBeforeOpen 12:17:36 SELECT ID, ID_ID FROM foto WHERE ID=214 OR ID_ID=214 ORDER BY ID 12:17:36 F: -qryBeforeOpen 12:17:36 F: TBildDetail.Create 12:17:36 F: -TBildDetail.Create 12:17:36 F: TBildDetail.SetHint 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.SetHint 12:17:36 AddBild 1: 1 12:17:36 F: TBildDetail.SetInUse True 12:17:36 F: -TBildDetail.SetInUse True 12:17:36 F: TBildList.OnParentResize.BildTyp 12:17:36 F: TBildDetail.SetVisible False 12:17:36 F: -TBildDetail.SetVisible False 12:17:36 F: TBildDetail.SetVisible True 12:17:36 F: qryBeforeOpen 12:17:36 SELECT * FROM foto WHERE ID=214 12:17:36 F: -qryBeforeOpen 12:17:36 Load ID: 214 12:17:36 Load Size: 1724 / W: 90 12:17:36 F: TBildDetail.Resize 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.Resize 12:17:36 F: -TBildDetail.SetVisible True 12:17:36 F: TBildDetail.ResizeImgHint 12:17:36 F: -TBildDetail.ResizeImgHint 12:17:36 F: -TBildList.OnParentResize.BildTyp 12:17:36 F: -TBildList.OnTimer.BildTyp False 214 0 0 0 0 0 12:17:36 F: tmrFocusOnTimer 12:17:36 Fx: tmrFocusOnTimer: edSchnellsuche 12:17:36 F: -tmrFocusOnTimer: edSchnellsuche 12:17:37 F: pgMainChanging 12:17:37 F: -pgMainChanging 12:17:37 F: TBildList.OnParentResize.BildProjekt 12:17:37 F: -TBildList.OnParentResize.BildProjekt 12:17:37 F: pgMainChange 12:17:37 Fx: pgMainChange3 12:17:37 F: qryBeforeOpen 12:17:37 SELECT p.*, l.ArtikelNr, l.ArtikelNr2 FROM projekt p LEFT JOIN bauteillager l ON (l.ID=p.Bauteillager_ID) ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: grdBeschreibungSelectEditor 12:17:37 F: grdSelectEditor 12:17:37 F: -grdSelectEditor 12:17:37 F: -grdBeschreibungSelectEditor 12:17:37 F: grdBeschreibungSelectEditor 12:17:37 F: grdSelectEditor 12:17:37 F: -grdSelectEditor 12:17:37 F: -grdBeschreibungSelectEditor 12:17:37 F: SetspPDeleteEnable 12:17:37 F: -SetspPDeleteEnable 12:17:37 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:37 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:37 F: qProjektAfterOpen 12:17:37 F: SetspPDeleteEnable 12:17:37 F: -SetspPDeleteEnable 12:17:37 F: Fillcbo.cboBestellProjekt.projekt 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboBestellProjekt.projekt 12:17:37 F: Fillcbo.cboProjekt.projekt 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboProjekt.projekt 12:17:37 F: qPPosDoOpen 12:17:37 F: qryBeforeOpen 12:17:37 SELECT DISTINCT Variante FROM projektpos WHERE Projekt_ID=0 12:17:37 F: -qryBeforeOpen 12:17:37 F: -qPPosDoOpen 12:17:37 F: DoOpenHist1 12:17:37 F: -DoOpenHist1 12:17:37 F: ProjektTreeRefresh 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM projekt WHERE ID_ID=0 OR ID_ID IS NULL ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -ProjektTreeRefresh 12:17:37 F: -qProjektAfterOpen 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM bauteil ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: RefreshAdr 12:17:37 F: Fillcbo.cboAdr.adr 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Lieferant=1 ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboAdr.adr 12:17:37 F: Fillcbo.cboAdrLG.adr 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Hersteller=1 ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboAdrLG.adr 12:17:37 F: Fillcbo.cboPAdr.adr 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung , Gesperrt FROM adr WHERE (ID_ID IS NULL OR ID_ID=0) AND Projekt=1 ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboPAdr.adr 12:17:37 F: cboPKAdrSelect 12:17:37 F: -cboPKAdrSelect 12:17:37 F: cboH1AdrSelect 12:17:37 F: -cboH1AdrSelect 12:17:37 F: cboHAdrSelect 12:17:37 F: -cboHAdrSelect 12:17:37 F: -RefreshAdr 12:17:37 F: dsPPosDataChange 12:17:37 F: TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:37 F: -TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:37 F: TBildList.SetPosBauteil 12:17:37 F: -TBildList.SetPosBauteil 12:17:37 F: -dsPPosDataChange 12:17:37 F: dsPKostDataChange 12:17:37 F: cboPKAdrSelect 12:17:37 F: -cboPKAdrSelect 12:17:37 F: TBildList.SetFotoID.BildKost 0 0 0 0 0 0 12:17:37 F: -TBildList.SetFotoID.BildKost 0 0 0 0 0 0 12:17:37 F: -dsPKostDataChange 12:17:37 F: dsPKostPosDataChange 12:17:37 F: TBildList.SetFotoID.BildKostPos 0 0 0 0 0 0 12:17:37 F: -TBildList.SetFotoID.BildKostPos 0 0 0 0 0 0 12:17:37 F: -dsPKostPosDataChange 12:17:37 F: -pgMainChange3 12:17:37 F: tvProjektChange 12:17:37 F: CheckPostProjekt 12:17:37 F: -CheckPostProjekt 12:17:37 F: qryBeforeClose_qProjekt 12:17:37 F: -qryBeforeClose_qProjekt 12:17:37 F: qProjektAfterClose 12:17:37 F: -qProjektAfterClose 12:17:37 F: qryBeforeOpen 12:17:37 SELECT p.*, l.ArtikelNr, l.ArtikelNr2 FROM projekt p LEFT JOIN bauteillager l ON (l.ID=p.Bauteillager_ID) ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: grdBeschreibungSelectEditor 12:17:37 F: grdSelectEditor 12:17:37 F: -grdSelectEditor 12:17:37 F: -grdBeschreibungSelectEditor 12:17:37 F: grdBeschreibungSelectEditor 12:17:37 F: grdSelectEditor 12:17:37 F: -grdSelectEditor 12:17:37 F: -grdBeschreibungSelectEditor 12:17:37 F: SetspPDeleteEnable 12:17:37 F: -SetspPDeleteEnable 12:17:37 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:37 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:37 F: qProjektAfterOpen 12:17:37 F: SetspPDeleteEnable 12:17:37 F: -SetspPDeleteEnable 12:17:37 F: Fillcbo.cboBestellProjekt.projekt 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboBestellProjekt.projekt 12:17:37 F: Fillcbo.cboProjekt.projekt 12:17:37 F: qryBeforeOpen 12:17:37 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:37 F: -qryBeforeOpen 12:17:37 F: -Fillcbo.cboProjekt.projekt 12:17:37 F: qPPosDoOpen 12:17:37 F: qryBeforeOpen 12:17:37 SELECT DISTINCT Variante FROM projektpos WHERE Projekt_ID=0 12:17:37 F: -qryBeforeOpen 12:17:37 F: -qPPosDoOpen 12:17:37 F: DoOpenHist1 12:17:37 F: -DoOpenHist1 12:17:37 F: -qProjektAfterOpen 12:17:37 F: -tvProjektChange 12:17:37 F: TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:37 F: -TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:37 F: TBildList.OnTimer.BildKost False 0 0 0 0 0 0 12:17:37 F: -TBildList.OnTimer.BildKost False 0 0 0 0 0 0 12:17:37 F: TBildList.OnTimer.BildKostPos False 0 0 0 0 0 0 12:17:37 F: -TBildList.OnTimer.BildKostPos False 0 0 0 0 0 0 12:17:37 F: TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:37 F: -TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:39 F: EditMouseDown 12:17:39 F: -EditMouseDown 12:17:40 F: FormKeyDown 12:17:40 F: -FormKeyDown 12:17:40 F: qProjektNewRecord 12:17:40 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:40 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:40 F: -qProjektNewRecord 12:17:40 F: grdBeschreibungSelectEditor 12:17:40 F: grdSelectEditor 12:17:40 F: -grdSelectEditor 12:17:40 F: -grdBeschreibungSelectEditor 12:17:40 F: SetspPDeleteEnable 12:17:40 F: -SetspPDeleteEnable 12:17:40 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:40 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:40 F: qProjektAfterEdit 12:17:40 F: -qProjektAfterEdit 12:17:40 F: FormKeyPress 12:17:40 F: -FormKeyPress 12:17:40 F: FormKeyDown 12:17:40 F: -FormKeyDown 12:17:40 F: FormKeyPress 12:17:40 F: -FormKeyPress 12:17:40 F: TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:40 F: -TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:40 F: FormKeyDown 12:17:40 F: -FormKeyDown 12:17:40 F: FormKeyPress 12:17:40 F: -FormKeyPress 12:17:40 F: FormKeyDown 12:17:40 F: -FormKeyDown 12:17:40 F: FormKeyPress 12:17:40 F: -FormKeyPress 12:17:41 F: tmrBackgroundTimer 12:17:41 Fx: tmrBackgroundTimer1 12:17:41 F: qryBeforeOpen 12:17:41 SELECT * FROM param WHERE ParNr=2 12:17:41 F: -qryBeforeOpen 12:17:41 Fx: tmrBackgroundTimer2 12:17:41 Fx: tmrBackgroundTimer5 12:17:41 F: -tmrBackgroundTimer5 12:17:41 F: FormKeyDown 12:17:41 F: -FormKeyDown 12:17:41 F: FormKeyPress 12:17:41 F: -FormKeyPress 12:17:42 F: FormKeyDown 12:17:42 F: -FormKeyDown 12:17:42 F: FormKeyPress 12:17:42 F: -FormKeyPress 12:17:42 F: FormKeyDown 12:17:42 F: -FormKeyDown 12:17:42 F: FormKeyPress 12:17:42 F: -FormKeyPress 12:17:43 F: SetspPDeleteEnable 12:17:43 F: -SetspPDeleteEnable 12:17:43 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:43 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:43 F: TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:43 F: -TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:43 F: ApplicationActivate 12:17:43 F: -ApplicationActivate 12:17:44 F: FindQuery 12:17:44 F: -FindQuery 12:17:44 F: spSaveClick_qProjekt 12:17:44 F: qProjektBeforePost 12:17:44 F: qryBeforePost 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -qryBeforePost 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID FROM projekt WHERE Bezeichnung = :Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -qProjektBeforePost 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: dsProjektDataChange 12:17:44 F: qPPosDoOpen 12:17:44 F: qryBeforeOpen 12:17:44 SELECT p.*, k.Bezeichnung AS Kiste, l.LagerNr, l.Menge AS LMenge, l.ArtikelNr AS LArtikelNr, l.ArtikelNr2 AS LArtikelNr2, l.Barcode AS LBarcode, l.Art AS LArt, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager l ON (l.ID = p.BauteilLager_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) LEFT JOIN gehause g ON (g.ID = l.Gehause_ID) WHERE Projekt_ID=1 ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdPPosSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPPosSelectEditor 12:17:44 F: grdPPosSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPPosSelectEditor 12:17:44 F: dsPPosDataChange 12:17:44 F: TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:44 F: TBildList.SetPosBauteil 12:17:44 F: -TBildList.SetPosBauteil 12:17:44 F: -dsPPosDataChange 12:17:44 F: qPPosAfterOpen 12:17:44 F: -qPPosAfterOpen 12:17:44 F: CalcProjektPosSumme 12:17:44 F: qryBeforeOpen 12:17:44 SELECT SUM(GPreis), SUM(Menge) FROM projektpos WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -CalcProjektPosSumme 12:17:44 F: qryBeforeOpen 12:17:44 SELECT DISTINCT Variante FROM projektpos WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -qPPosDoOpen 12:17:44 F: DoOpenHist1 12:17:44 F: qryBeforeOpen 12:17:44 SELECT * FROM historie WHERE Projekt_ID=1 ORDER BY Datum DESC 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdHist1SelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: CopyObject 12:17:44 F: -CopyObject 12:17:44 F: -grdHist1SelectEditor 12:17:44 F: grdHist1SelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: CopyObject 12:17:44 F: -CopyObject 12:17:44 F: -grdHist1SelectEditor 12:17:44 F: dsHist1DataChange 12:17:44 F: TBildList.SetFotoID.BildHist1 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildHist1 0 0 0 0 0 0 12:17:44 F: cboH1AdrSelect 12:17:44 F: -cboH1AdrSelect 12:17:44 F: -dsHist1DataChange 12:17:44 F: qHist1AfterOpen 12:17:44 F: CalcHist1Summe 12:17:44 F: qryBeforeOpen 12:17:44 SELECT SUM(Aufwand) FROM historie WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -CalcHist1Summe 12:17:44 F: -qHist1AfterOpen 12:17:44 F: -DoOpenHist1 12:17:44 F: DoOpenKosten 12:17:44 F: qryBeforeOpen 12:17:44 SELECT * FROM kosten WHERE Projekt_ID=1 ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdPKostUebSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPKostUebSelectEditor 12:17:44 F: dsPKostDataChange 12:17:44 F: cboPKAdrSelect 12:17:44 F: -cboPKAdrSelect 12:17:44 F: TBildList.SetFotoID.BildKost 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildKost 0 0 0 0 0 0 12:17:44 F: -dsPKostDataChange 12:17:44 F: qPKostAfterOpen 12:17:44 F: qryBeforeOpen 12:17:44 SELECT p.*, l.ArtikelNr As LArtikelNr, l.ArtikelNr2 As LArtikelNr2, l.Barcode AS LBarcode, l.Art AS LArt FROM kostenpos p LEFT JOIN bauteillager l ON (l.ID=p.Bauteillager_ID) ORDER BY Nr, Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdPKostDetSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPKostDetSelectEditor 12:17:44 F: dsPKostPosDataChange 12:17:44 F: TBildList.SetFotoID.BildKostPos 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildKostPos 0 0 0 0 0 0 12:17:44 F: -dsPKostPosDataChange 12:17:44 F: qPKostPosAfterOpen 12:17:44 F: -qPKostPosAfterOpen 12:17:44 F: -qPKostAfterOpen 12:17:44 F: Fillcbo.cboH1Kost.kosten 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM kosten WHERE Projekt_ID=1 ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -Fillcbo.cboH1Kost.kosten 12:17:44 F: FillcboHistPPos 12:17:44 F: qryBeforeOpen 12:17:44 SELECT p.ID AS ID, p.Bezeichnung AS PBez, b.ArtikelNr AS BArt, p.Symbol, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager b ON (b.ID=p.Bauteillager_ID) LEFT JOIN gehause g ON (g.ID=b.Gehause_ID) WHERE Projekt_ID=1 ORDER BY PBez, BArt, Symbol, GBez 12:17:44 F: -qryBeforeOpen 12:17:44 F: -FillcboHistPPos 12:17:44 F: -DoOpenKosten 12:17:44 F: -dsProjektDataChange 12:17:44 F: qProjektAfterPost 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: Fillcbo.cboBestellProjekt.projekt 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -Fillcbo.cboBestellProjekt.projekt 12:17:44 F: ProjektTreeRefresh 12:17:44 F: tvProjektChanging 12:17:44 F: -tvProjektChanging 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM projekt WHERE ID_ID=0 OR ID_ID IS NULL ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM projekt WHERE ID_ID=1 ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -ProjektTreeRefresh 12:17:44 F: -qProjektAfterPost 12:17:44 F: -spSaveClick_qProjekt 12:17:44 F: TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:44 F: TBildList.OnTimer.BildHist1 False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildHist1 False 0 0 0 0 0 0 12:17:44 F: TBildList.OnTimer.BildKost False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildKost False 0 0 0 0 0 0 12:17:44 F: tvProjektChange 12:17:44 F: CheckPostProjekt 12:17:44 F: -CheckPostProjekt 12:17:44 F: qryBeforeClose_qProjekt 12:17:44 F: -qryBeforeClose_qProjekt 12:17:44 F: qProjektAfterClose 12:17:44 F: qPPosBeforeClose 12:17:44 F: qryBeforeClose_qPPos 12:17:44 F: -qryBeforeClose_qPPos 12:17:44 F: -qPPosBeforeClose 12:17:44 F: qPPosAfterClose 12:17:44 F: -qPPosAfterClose 12:17:44 F: -qProjektAfterClose 12:17:44 F: qryBeforeOpen 12:17:44 SELECT p.*, l.ArtikelNr, l.ArtikelNr2 FROM projekt p LEFT JOIN bauteillager l ON (l.ID=p.Bauteillager_ID) ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: qProjektAfterOpen 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: Fillcbo.cboBestellProjekt.projekt 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -Fillcbo.cboBestellProjekt.projekt 12:17:44 F: Fillcbo.cboProjekt.projekt 12:17:44 F: qryBeforeOpen 12:17:44 SELECT ID, Bezeichnung FROM projekt ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: -Fillcbo.cboProjekt.projekt 12:17:44 F: qryBeforeClose_qHist1 12:17:44 F: -qryBeforeClose_qHist1 12:17:44 F: qHist1AfterClose 12:17:44 F: -qHist1AfterClose 12:17:44 F: qPPosDoOpen 12:17:44 F: qryBeforeOpen 12:17:44 SELECT p.*, k.Bezeichnung AS Kiste, l.LagerNr, l.Menge AS LMenge, l.ArtikelNr AS LArtikelNr, l.ArtikelNr2 AS LArtikelNr2, l.Barcode AS LBarcode, l.Art AS LArt, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager l ON (l.ID = p.BauteilLager_ID) LEFT JOIN kiste k ON (k.ID = l.Kiste_ID) LEFT JOIN gehause g ON (g.ID = l.Gehause_ID) WHERE Projekt_ID=1 ORDER BY Bezeichnung 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdPPosSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPPosSelectEditor 12:17:44 F: grdPPosSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdPPosSelectEditor 12:17:44 F: dsPPosDataChange 12:17:44 F: TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:44 F: TBildList.SetPosBauteil 12:17:44 F: -TBildList.SetPosBauteil 12:17:44 F: -dsPPosDataChange 12:17:44 F: qPPosAfterOpen 12:17:44 F: -qPPosAfterOpen 12:17:44 F: CalcProjektPosSumme 12:17:44 F: qryBeforeOpen 12:17:44 SELECT SUM(GPreis), SUM(Menge) FROM projektpos WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -CalcProjektPosSumme 12:17:44 F: qryBeforeOpen 12:17:44 SELECT DISTINCT Variante FROM projektpos WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -qPPosDoOpen 12:17:44 F: DoOpenHist1 12:17:44 F: qryBeforeOpen 12:17:44 SELECT * FROM historie WHERE Projekt_ID=1 ORDER BY Datum DESC 12:17:44 F: -qryBeforeOpen 12:17:44 F: grdHist1SelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: CopyObject 12:17:44 F: -CopyObject 12:17:44 F: -grdHist1SelectEditor 12:17:44 F: grdHist1SelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: CopyObject 12:17:44 F: -CopyObject 12:17:44 F: -grdHist1SelectEditor 12:17:44 F: dsHist1DataChange 12:17:44 F: TBildList.SetFotoID.BildHist1 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildHist1 0 0 0 0 0 0 12:17:44 F: cboH1AdrSelect 12:17:44 F: -cboH1AdrSelect 12:17:44 F: -dsHist1DataChange 12:17:44 F: qHist1AfterOpen 12:17:44 F: CalcHist1Summe 12:17:44 F: qryBeforeOpen 12:17:44 SELECT SUM(Aufwand) FROM historie WHERE Projekt_ID=1 12:17:44 F: -qryBeforeOpen 12:17:44 F: -CalcHist1Summe 12:17:44 F: -qHist1AfterOpen 12:17:44 F: -DoOpenHist1 12:17:44 F: -qProjektAfterOpen 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: grdBeschreibungSelectEditor 12:17:44 F: grdSelectEditor 12:17:44 F: -grdSelectEditor 12:17:44 F: -grdBeschreibungSelectEditor 12:17:44 F: SetspPDeleteEnable 12:17:44 F: -SetspPDeleteEnable 12:17:44 F: TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -TBildList.SetFotoID.BildProjekt 0 0 0 0 0 0 12:17:44 F: -tvProjektChange 12:17:44 F: TBildList.OnTimer.BildKostPos False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildKostPos False 0 0 0 0 0 0 12:17:44 F: TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:44 F: TBildList.OnTimer.BildHist1 False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildHist1 False 0 0 0 0 0 0 12:17:44 F: TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:44 F: -TBildList.OnTimer.BildProjekt False 0 0 0 0 0 0 12:17:46 F: pgMainChanging 12:17:46 F: -pgMainChanging 12:17:46 F: TBildList.OnParentResize.BildProjektPos 12:17:46 F: -TBildList.OnParentResize.BildProjektPos 12:17:46 F: pgProjektChange 12:17:46 F: -pgProjektChange 12:17:47 F: tmrBackgroundTimer 12:17:47 Fx: tmrBackgroundTimer1 12:17:47 F: qryBeforeOpen 12:17:47 SELECT * FROM param WHERE ParNr=2 12:17:47 F: -qryBeforeOpen 12:17:47 Fx: tmrBackgroundTimer2 12:17:47 Fx: tmrBackgroundTimer5 12:17:47 F: -tmrBackgroundTimer5 12:17:49 F: spPPExpClick 12:17:49 F: popPPExpPopup 12:17:49 F: -popPPExpPopup 12:17:51 F: ApplicationActivate 12:17:51 F: -ApplicationActivate 12:17:53 F: tmrBackgroundTimer 12:17:53 Fx: tmrBackgroundTimer1 12:17:53 F: qryBeforeOpen 12:17:53 SELECT * FROM param WHERE ParNr=2 12:17:53 F: -qryBeforeOpen 12:17:53 Fx: tmrBackgroundTimer2 12:17:53 Fx: tmrBackgroundTimer5 12:17:53 F: -tmrBackgroundTimer5 12:17:57 F: mnPopImportTargetClick 12:17:57 F: qPPosNewRecord 12:17:57 F: -qPPosNewRecord 12:17:57 F: qPPosAfterEdit 12:17:57 F: -qPPosAfterEdit 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: qryBeforePost 12:17:57 F: -qryBeforePost 12:17:57 F: qPPosBeforePost 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: -qPPosBeforePost 12:17:57 F: qPPosAfterPost 12:17:57 F: CalcProjektPosSumme 12:17:57 F: qryBeforeOpen 12:17:57 SELECT SUM(GPreis), SUM(Menge) FROM projektpos WHERE Projekt_ID=1 12:17:57 F: -qryBeforeOpen 12:17:57 F: -CalcProjektPosSumme 12:17:57 F: FillcboHistPPos 12:17:57 F: qryBeforeOpen 12:17:57 SELECT p.ID AS ID, p.Bezeichnung AS PBez, b.ArtikelNr AS BArt, p.Symbol, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager b ON (b.ID=p.Bauteillager_ID) LEFT JOIN gehause g ON (g.ID=b.Gehause_ID) WHERE Projekt_ID=1 ORDER BY PBez, BArt, Symbol, GBez 12:17:57 F: -qryBeforeOpen 12:17:57 F: -FillcboHistPPos 12:17:57 F: -qPPosAfterPost 12:17:57 F: qPPosNewRecord 12:17:57 F: -qPPosNewRecord 12:17:57 F: qPPosAfterEdit 12:17:57 F: -qPPosAfterEdit 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: qryBeforePost 12:17:57 F: -qryBeforePost 12:17:57 F: qPPosBeforePost 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: -qPPosBeforePost 12:17:57 F: qPPosAfterPost 12:17:57 F: CalcProjektPosSumme 12:17:57 F: qryBeforeOpen 12:17:57 SELECT SUM(GPreis), SUM(Menge) FROM projektpos WHERE Projekt_ID=1 12:17:57 F: -qryBeforeOpen 12:17:57 F: -CalcProjektPosSumme 12:17:57 F: FillcboHistPPos 12:17:57 F: qryBeforeOpen 12:17:57 SELECT p.ID AS ID, p.Bezeichnung AS PBez, b.ArtikelNr AS BArt, p.Symbol, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager b ON (b.ID=p.Bauteillager_ID) LEFT JOIN gehause g ON (g.ID=b.Gehause_ID) WHERE Projekt_ID=1 ORDER BY PBez, BArt, Symbol, GBez 12:17:57 F: -qryBeforeOpen 12:17:57 F: -FillcboHistPPos 12:17:57 F: -qPPosAfterPost 12:17:57 F: qPPosNewRecord 12:17:57 F: -qPPosNewRecord 12:17:57 F: qPPosAfterEdit 12:17:57 F: -qPPosAfterEdit 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: qryBeforePost 12:17:57 F: -qryBeforePost 12:17:57 F: qPPosBeforePost 12:17:57 F: qPPosPreisChange 12:17:57 F: -qPPosPreisChange 12:17:57 F: -qPPosBeforePost 12:17:57 F: qPPosAfterPost 12:17:57 F: CalcProjektPosSumme 12:17:57 F: qryBeforeOpen 12:17:57 SELECT SUM(GPreis), SUM(Menge) FROM projektpos WHERE Projekt_ID=1 12:17:57 F: -qryBeforeOpen 12:17:57 F: -CalcProjektPosSumme 12:17:57 F: FillcboHistPPos 12:17:57 F: qryBeforeOpen 12:17:57 SELECT p.ID AS ID, p.Bezeichnung AS PBez, b.ArtikelNr AS BArt, p.Symbol, g.Bezeichnung AS GBez FROM projektpos p LEFT JOIN bauteillager b ON (b.ID=p.Bauteillager_ID) LEFT JOIN gehause g ON (g.ID=b.Gehause_ID) WHERE Projekt_ID=1 ORDER BY PBez, BArt, Symbol, GBez 12:17:57 F: -qryBeforeOpen 12:17:57 F: -FillcboHistPPos 12:17:57 F: -qPPosAfterPost 12:17:57 F: dsPPosDataChange 12:17:57 F: TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:57 F: -TBildList.SetFotoID.BildProjektPos 0 0 0 0 0 0 12:17:57 F: TBildList.SetPosBauteil 12:17:57 F: -TBildList.SetPosBauteil 12:17:57 F: -dsPPosDataChange 12:17:57 F: -mnPopImportTargetClick 12:17:57 F: ApplicationActivate 12:17:57 F: -ApplicationActivate 12:17:57 F: TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:57 F: -TBildList.OnTimer.BildProjektPos False 0 0 0 0 0 0 12:17:57 F: -spPPExpClick 12:17:59 F: tmrBackgroundTimer 12:17:59 Fx: tmrBackgroundTimer1 12:17:59 F: qryBeforeOpen 12:17:59 SELECT * FROM param WHERE ParNr=2 12:17:59 F: -qryBeforeOpen 12:17:59 Fx: tmrBackgroundTimer2 12:17:59 Fx: tmrBackgroundTimer5 12:17:59 F: -tmrBackgroundTimer5 12:18:04 F: ApplicationActivate 12:18:04 F: -ApplicationActivate 12:18:04 F: FormDestroy 12:18:05 F: TBildList.Destroy.BildBauteil 12:18:05 F: TBildDetail.SetInUse False 12:18:05 F: -TBildDetail.SetInUse False 12:18:05 F: -TBildList.Destroy.BildBauteil 12:18:05 F: TBildList.Destroy.BildCase 12:18:05 F: TBildDetail.SetInUse False 12:18:05 F: -TBildDetail.SetInUse False 12:18:05 F: -TBildList.Destroy.BildCase 12:18:05 F: TBildList.Destroy.BildKiste 12:18:05 F: TBildDetail.SetInUse False 12:18:05 F: -TBildDetail.SetInUse False 12:18:05 F: -TBildList.Destroy.BildKiste 12:18:05 F: TBildList.Destroy.BildAdr 12:18:05 F: TBildDetail.SetInUse False 12:18:05 F: -TBildDetail.SetInUse False 12:18:05 F: -TBildList.Destroy.BildAdr 12:18:05 F: TBildList.Destroy.BildAdrKontakt 12:18:05 F: -TBildList.Destroy.BildAdrKontakt 12:18:05 F: TBildList.Destroy.BildProjekt 12:18:05 F: -TBildList.Destroy.BildProjekt 12:18:05 F: TBildList.Destroy.BildProjektPos 12:18:05 F: -TBildList.Destroy.BildProjektPos 12:18:05 F: TBildList.Destroy.BildKost 12:18:05 F: -TBildList.Destroy.BildKost 12:18:05 F: TBildList.Destroy.BildKostPos 12:18:05 F: -TBildList.Destroy.BildKostPos 12:18:05 F: TBildList.Destroy.BildHist1 12:18:05 F: -TBildList.Destroy.BildHist1 12:18:05 F: TBildList.Destroy.BildHist 12:18:05 F: -TBildList.Destroy.BildHist 12:18:05 F: TBildList.Destroy.BildWissen 12:18:05 F: -TBildList.Destroy.BildWissen 12:18:05 F: TBildList.Destroy.BildTyp 12:18:05 F: TBildDetail.SetInUse False 12:18:05 F: -TBildDetail.SetInUse False 12:18:05 F: -TBildList.Destroy.BildTyp 12:18:05 F: TBildList.Destroy.BildMP3 12:18:05 F: -TBildList.Destroy.BildMP3 12:18:05 F: TBildList.Destroy.BildCaseBauteil 12:18:05 F: -TBildList.Destroy.BildCaseBauteil 12:18:05 F: TBildList.Destroy.BildBauteilAdr 12:18:05 F: -TBildList.Destroy.BildBauteilAdr 12:18:05 F: TBildList.Destroy.BildBestellung 12:18:05 F: -TBildList.Destroy.BildBestellung 12:18:05 F: TBildList.Destroy.BildCaseExp 12:18:05 F: -TBildList.Destroy.BildCaseExp 12:18:05 F: -FormDestroy 12:18:05 F: tvProjektChanging
