 * uart_test.c
 *  Created on: 10.09.2012
 *      Author: Gromph
#include <stdio.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "eddy/General.h"
#include "eddy/RS232.h"
#include <util/delay.h>
void flash (uint8_t farbe)
	DDRB|=(0b00001111);	//PORTB 0-3 als Ausgang
	PORTB|=15;			//LED's aus durch high setzen
	PORTB &= ~(farbe);  //LED an durch Low
	_delay_ms(200);
	PORTB|=farbe;
	_delay_ms(200);
** Baud Rate für die Serielle Schnittstelle
#define BAUD_RATE		9600
** Where the byte via UART Interrupt will be saved
** Use 'volatile', otherwise, data is lost
volatile uint8_t	UART_Byte;
volatile uint8_t	UART_Byte_Status;
** Define a stream for the printf function, using the UART
FILE uart_str = FDEV_SETUP_STREAM(RS232_putchar, NULL, _FDEV_SETUP_RW);
 Function: RS232_Init
 Purpose: Initialise the RS232 serial link
 Input Parameter: None
 Return Value: None
void RS232_Init (void)
** Enable TXEN and RXEN in register UCSRB
	UCSR0B |= (1 << TXEN0);
	UCSR0B |= (1 << RXEN0);
** Set transmission type, Asynchron 8N1
	UCSR0C |= (1 << UMSEL00)|(3<<UCSZ00);
** Set baud rate
    UBRR0H = (uint8_t) ((F_CPU / (BAUD_RATE * 16L) - 1)>>8);
    UBRR0L = (uint8_t) (F_CPU / (BAUD_RATE * 16L) - 1);
** Open a channel for printf
	stdout = &uart_str;
//	fdevopen (RS232_putchar, NULL);
** Set the UART CMD bytes
	UART_Byte = 0;
	UART_Byte_Status = 0;
 Function: RS232_putchar
 Purpose: Initialise function "printf "
 Input Parameter: char buffer
 Return Value:
 	Value = 0
int RS232_putchar (char c, FILE *stream)
** Check on NEWLINE
	if (c == '\n')
		RS232_putchar ('\r', stream);
** Wait until previous character is sent
	loop_until_bit_is_set(UCSR0A, UDRE0);
** Send character to UART
	UDR0 = c;
	return 0;
 Function: RS232_PutByte
 Purpose: Send to the UART a data byte
 Input Parameter: the byte
 Return Value: None
 	Value = 0
void RS232_PutByte (uint8_t Byte)
	while (!(UCSR0A & (1<<UDRE0)));
** Send byte to UART
	UDR0 = Byte;
	return;
 Function: RS232_Put_uint16
 Purpose: Send a two byte word (uin16_t) to the UART, LSB first
 Input Parameter: Address of uint16_t
 Return Value: None
void RS232_Put_uint16 (uint16_t *Word)
	uint8_t 	i;
	uint8_t		*py;
	py = (uint8_t*) Word;
	for (i=0;i<2;i++)
		RS232_PutByte (*py++);
	return;
 Function: RS232_Put_uint32
 Purpose: Send a four byte word (uin32_t) to the UART, LSB first
 Input Parameter:  Address of uint32_t
 Return Value: None
void RS232_Put_uint32 (uint32_t *DWord)
	uint8_t 	i;
	uint8_t		*py;
	py = (uint8_t*) DWord;
	for (i=0;i<4;i++)
	return;
 Function: RS232_GetByte
 Purpose: Get from the UART a byte
 Return Value: The UART byte
uint8_t RS232_GetByte (void)
** Wait until byte is available
	while (!(UCSR0A &(1<<RXC0)));
** Get and return the byte from UART
	return UDR0;
int main (void)
	uint8_t tmp;
	uint16_t tmp1;
	while (1)
		tmp = 202;
		tmp1 = 403;
		printf ("tmp = %d\n", tmp);
		RS232_Put_uint16 (tmp1);
		flash(1);
