(setq load-path (cons (expand-file-name "D:/Local_Progs/Emacs/vhdl-mode-3.33.12") load-path))
;;; VHDL mode
(autoload 'vhdl-mode "vhdl-mode" "VHDL Mode" t)
(setq auto-mode-alist (cons '("\\.vhd?\\'" . vhdl-mode) auto-mode-alist))
(custom-set-variables
  ;; custom-set-variables was added by Custom -- don't edit or cut/paste it!
  ;; Your init file should contain only one such instance.
 '(confirm-kill-emacs (quote y-or-n-p))
 '(vc-command-messages t)
 '(vc-default-init-version "0.1")
 '(vc-delete-logbuf-window nil)
 '(vc-diff-switches (quote ("")))
 '(vc-handled-backends (quote (RCS CVS SCCS)))
 '(vc-initial-comment t)
 '(vc-static-header-alist (quote (("\\.vhd$" . "--Version as set by Emacs: %s") ("\\.c$" . "
#ifndef lint
static char vcid[] = \"%s\";
#endif /* lint */
 '(version-control t)
 '(vhdl-clock-edge-condition (quote function))
 '(vhdl-compiler-alist (quote (("Cadence Leapfrog" "cv" "-work \\1 -file" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "leapfrog" ("duluth: \\*E,[0-9]+ (\\(.+\\),\\([0-9]+\\)):" 1 2 0) ("" 0) ("\\1/entity" "\\2/\\1" "\\1/configuration" "\\1/package" "\\1/body" downcase)) ("Cadence NC" "ncvhdl" "-work \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "ncvhdl" ("ncvhdl_p: \\*E,\\w+ (\\(.+\\),\\([0-9]+\\)|\\([0-9]+\\)):" 1 2 3) ("" 0) ("\\1/entity/pc.db" "\\2/\\1/pc.db" "\\1/configuration/pc.db" "\\1/package/pc.db" "\\1/body/pc.db" downcase)) ("Ikos" "analyze" "-l \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "ikos" ("E L\\([0-9]+\\)/C\\([0-9]+\\):" 0 1 2) ("^analyze +\\(.+ +\\)*\\(.+\\)$" 2) nil) ("ModelSim" "vcom" "-93 -work \\1" "make" "-f \\1" nil "vlib \\1; vmap \\2 \\1" "D:/FPGA_projects/Kamera_1/FPGA/scripts/" "work/" "D:/FPGA_projects/Kamera_1/FPGA/scripts/Makefile" "modelsim" ("\\(ERROR\\|WARNING\\|\\*\\* Error\\|\\*\\* Warning\\)[^:]*: \\(.+\\)(\\([0-9]+\\)):" 2 3 0) ("" 0) ("\\1/_primary.dat" "\\2/\\1.dat" "\\1/_primary.dat" "\\1/_primary.dat" "\\1/body.dat" downcase)) ("LEDA ProVHDL" "provhdl" "-w \\1 -f" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "provhdl" ("\\([^ 	
]+\\):\\([0-9]+\\): " 1 2 0) ("" 0) ("ENTI/\\1.vif" "ARCH/\\1-\\2.vif" "CONF/\\1.vif" "PACK/\\1.vif" "BODY/BODY-\\1.vif" upcase)) ("QuickHDL" "qvhcom" "-work \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "quickhdl" ("\\(ERROR\\|WARNING\\)[^:]*: \\(.+\\)(\\([0-9]+\\)):" 2 3 0) ("" 0) ("\\1/_primary.dat" "\\2/\\1.dat" "\\1/_primary.dat" "\\1/_primary.dat" "\\1/body.dat" downcase)) ("Savant" "scram" "-publish-cc -design-library-name \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work._savant_lib/" "Makefile" "savant" ("\\([^ 	
]+\\):\\([0-9]+\\): " 1 2 0) ("" 0) ("\\1_entity.vhdl" "\\2_secondary_units._savant_lib/\\2_\\1.vhdl" "\\1_config.vhdl" "\\1_package.vhdl" "\\1_secondary_units._savant_lib/\\1_package_body.vhdl" downcase)) ("Simili" "vhdlp" "-work \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "simili" ("\\(Error\\|Warning\\): \\w+: \\(.+\\): (line \\([0-9]+\\)): " 2 3 0) ("" 0) ("\\1/prim.var" "\\2/_\\1.var" "\\1/prim.var" "\\1/prim.var" "\\1/_body.var" downcase)) ("Speedwave" "analyze" "-libfile vsslib.ini -src" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "speedwave" ("^ *ERROR[[0-9]+]::File \\(.+\\) Line \\([0-9]+\\):" 1 2 0) ("" 0) nil) ("Synopsys" "vhdlan" "-nc -work \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "synopsys" ("\\*\\*Error: vhdlan,[0-9]+ \\(.+\\)(\\([0-9]+\\)):" 1 2 0) ("" 0) ("\\1.sim" "\\2__\\1.sim" "\\1.sim" "\\1.sim" "\\1__.sim" upcase)) ("Synopsys Design Compiler" "vhdlan" "-nc -spc -work \\1" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "synopsys_dc" ("\\*\\*Error: vhdlan,[0-9]+ \\(.+\\)(\\([0-9]+\\)):" 1 2 0) ("" 0) ("\\1.syn" "\\2__\\1.syn" "\\1.syn" "\\1.syn" "\\1__.syn" upcase)) ("Synplify" "n/a" "n/a" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "synplify" ("@[EWN]:\"\\(.+\\)\":\\([0-9]+\\):\\([0-9]+\\):" 1 2 3) ("" 0) nil) ("Vantage" "analyze" "-libfile vsslib.ini -src" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "vantage" ("\\*\\*Error: LINE \\([0-9]+\\) \\*\\*\\*" 0 1 0) ("^ *Compiling \"\\(.+\\)\" " 1) nil) ("VeriBest" "vc" "vhdl" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "veribest" ("^ +\\([0-9]+\\): +[^ ]" 0 1 0) ("" 0) nil) ("Viewlogic" "analyze" "-libfile vsslib.ini -src" "make" "-f \\1" nil "mkdir \\1" "./" "work/" "Makefile" "viewlogic" ("\\*\\*Error: LINE \\([0-9]+\\) \\*\\*\\*" 0 1 0) ("^ *Compiling \"\\(.+\\)\" " 1) nil))))
 '(vhdl-end-comment-column 100)
 '(vhdl-highlight-special-words t)
 '(vhdl-optional-labels (quote none))
 '(vhdl-standard (quote (93 nil)))
 '(vhdl-underscore-is-part-of-word nil)
 '(vhdl-upper-case-enum-values t)
 '(vhdl-upper-case-keywords t))
(custom-set-faces
  ;; custom-set-faces was added by Custom -- don't edit or cut/paste it!
 '(font-lock-comment-face ((((class color) (background light)) (:foreground "ForestGreen"))))
 '(font-lock-type-face ((((class color) (background light)) (:foreground "firebrick"))))
 '(vhdl-font-lock-type-face ((((class color) (background light)) (:foreground "firebrick")))))
