(module Capacitor7x2.5RM5 (layer F.Cu)
  (at 0 0)
  (descr "Capacitor 7mm x 2,5mm RM 5mm")
  (tags "Capacitor Kondensator")
  (path /4C583B33)
  (fp_text reference C1 (at -1.79832 -2.90068) (layer F.SilkS)
    (effects (font (size 1.524 1.524) (thickness 0.3048)))
  (fp_text value 470nF/RM5 (at 1.27 3.81) (layer F.SilkS) hide
  (fp_line (start 6.35 1.27) (end 6.35 -1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start 6.35 -1.27) (end -1.27 -1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start -1.27 -1.27) (end -1.27 1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start -1.27 1.27) (end 6.35 1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.7512 21.1) (end 3.7512 21.1) (layer F.SilkS) (width 0.3048))
  (fp_line (start -2.8401 24.529) (end -5.7611 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start -12.3651 24.529) (end -8.5551 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start -11.6031 23.64) (end -8.8091 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.8401 23.64) (end -5.5071 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start -12.3651 17.671) (end -8.5551 17.671) (layer F.SilkS) (width 0.381))
  (fp_line (start -11.6031 18.56) (end -8.8091 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.8401 17.671) (end -5.7611 17.671) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.8401 18.56) (end -5.5071 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 17.671) (end 6.76364 17.671) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 18.56) (end 6.50964 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 23.64) (end 6.50964 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 24.529) (end 6.76364 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start 13.36764 24.529) (end 9.55764 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start 12.47864 23.64) (end 9.81164 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start 13.36764 17.671) (end 9.55764 17.671) (layer F.SilkS) (width 0.381))
  (fp_line (start 12.47864 18.56) (end 9.81164 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start 13.36764 17.671) (end 13.36764 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 24.529) (end 3.71564 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 17.671) (end 3.71564 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start -12.36764 17.671) (end -12.36764 24.529) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.84264 24.529) (end -2.84264 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.84264 17.671) (end -2.84264 18.687) (layer F.SilkS) (width 0.381))
  (fp_line (start 6.215 23.64) (end -5.469 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start -5.342 18.56) (end 6.215 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.84264 21.1) (end -2.84264 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start -11.60564 18.56) (end -11.60564 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.84264 23.64) (end -2.84264 21.1) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 21.1) (end 3.71564 18.56) (layer F.SilkS) (width 0.381))
  (fp_line (start 12.4761 18.56) (end 12.4761 23.64) (layer F.SilkS) (width 0.381))
  (fp_line (start 3.71564 23.64) (end 3.71564 21.1) (layer F.SilkS) (width 0.381))
  (pad 1 thru_hole circle (at 0 0) (size 1.50114 1.50114) (drill 0.8001)
    (layers *.Cu *.Mask F.SilkS)
  (pad 2 thru_hole circle (at 5.08 0) (size 1.50114 1.50114) (drill 0.8001)
 (pad 2 thru_hole circle (at 5.62064 21.1) (size 2.3495 2.3495) (drill 1.34874)
  (pad 2 thru_hole circle (at 10.70064 21.1) (size 2.3495 2.3495) (drill 1.34874)
  (pad 1 thru_hole circle (at -4.6181 21.1) (size 2.3495 2.3495) (drill 1.34874)
  (pad 1 thru_hole circle (at -9.6981 21.1) (size 2.3495 2.3495) (drill 1.34874)
  (pad 2 thru_hole circle (at 8.16064 18.56) (size 2.3495 2.3495) (drill 1.34874)
  (pad 2 thru_hole circle (at 8.16064 23.64) (size 2.3495 2.3495) (drill 1.34874)
  (pad 1 thru_hole circle (at -7.1581 18.56) (size 2.3495 2.3495) (drill 1.34874)
  (pad 1 thru_hole circle (at -7.1581 23.64) (size 2.3495 2.3495) (drill 1.34874)
