[root obj-avr]# ../configure --target=avr --prefix=/usr/local/avr --disable-nls loading cache ./config.cache checking host system type... i386-pc-nto-qnx6.2.1 checking target system type... avr-unknown-none checking build system type... i386-pc-nto-qnx6.2.1 checking for a BSD compatible install... ../install-sh -c *** This configuration is not supported in the following subdirectories: target-libiberty (Any other directories should still work fine.) *** removing intl/Makefile to force reconfigure *** removing libiberty/Makefile to force reconfigure *** removing opcodes/Makefile to force reconfigure *** removing bfd/Makefile to force reconfigure *** removing binutils/Makefile to force reconfigure *** removing gas/Makefile to force reconfigure *** removing ld/Makefile to force reconfigure *** removing etc/Makefile to force reconfigure checking for i386-pc-nto-qnx6.2.1-ar... no checking for ar... (cached) ar checking for i386-pc-nto-qnx6.2.1-as... no checking for as... (cached) as checking for i386-pc-nto-qnx6.2.1-dlltool... no checking for dlltool... (cached) dlltool checking for i386-pc-nto-qnx6.2.1-ld... (cached) /usr/bin/ntox86-ld checking for i386-pc-nto-qnx6.2.1-nm... no checking for nm... (cached) nm checking for i386-pc-nto-qnx6.2.1-ranlib... no checking for ranlib... (cached) ranlib checking for i386-pc-nto-qnx6.2.1-windres... no checking for windres... (cached) windres checking for i386-pc-nto-qnx6.2.1-objcopy... no checking for objcopy... (cached) objcopy checking for i386-pc-nto-qnx6.2.1-objdump... no checking for objdump... (cached) objdump checking for avr-ar... no checking for avr-as... no checking for avr-dlltool... no checking for avr-ld... no checking for avr-nm... no checking for avr-ranlib... no checking for avr-windres... no checking whether to enable maintainer-specific portions of Makefiles... no creating ./config.status creating Makefile [root obj-avr]# ./configure --target=avr --prefix=/usr/local/avr --disable-nls /bin/sh: ./configure: not found [root obj-avr]#
