Version 4 SHEET 1 1236 1188 WIRE -112 80 -176 80 WIRE -16 80 -48 80 WIRE 112 80 64 80 WIRE 128 80 112 80 WIRE 208 80 192 80 WIRE 272 80 208 80 WIRE 368 80 336 80 WIRE 496 80 448 80 WIRE 592 80 496 80 WIRE 688 80 656 80 WIRE 816 80 768 80 WIRE -176 208 -176 80 WIRE -128 208 -176 208 WIRE 112 208 112 80 WIRE 112 208 -48 208 WIRE 208 208 208 80 WIRE 240 208 208 208 WIRE 496 208 496 80 WIRE 496 208 320 208 WIRE -176 352 -176 208 WIRE -32 352 -176 352 WIRE 0 352 -32 352 WIRE 128 352 64 352 WIRE 272 352 208 352 WIRE 384 352 352 352 WIRE 496 352 496 208 WIRE 496 352 384 352 WIRE -176 400 -176 352 WIRE 496 400 496 352 WIRE -32 448 -32 352 WIRE 144 448 -32 448 WIRE 384 448 384 352 WIRE 384 448 208 448 WIRE -176 512 -176 464 WIRE 496 512 496 464 FLAG -176 512 0 FLAG 496 512 0 FLAG 816 80 out SYMBOL Digital\\and -80 0 R0 WINDOW 3 -51 0 Invisible 2 SYMATTR Value Vhigh=3V SYMATTR InstName A1 SYMATTR Value2 Vlow=0V SYMATTR SpiceLine trise=1n td=1n SYMBOL cap 64 336 R90 WINDOW 0 -1 30 VBottom 2 WINDOW 3 38 33 VTop 2 SYMATTR InstName C1 SYMATTR Value 1.9fF SYMBOL ind 224 336 R90 WINDOW 0 5 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName L1 SYMATTR Value 16mH IC=100u SYMATTR SpiceLine Rpar=1e20 SYMBOL res 368 336 R90 WINDOW 0 0 64 VBottom 2 WINDOW 3 36 65 VTop 2 SYMATTR InstName R1 SYMATTR Value 33 SYMBOL cap 208 432 R90 WINDOW 0 -5 29 VBottom 2 WINDOW 3 35 33 VTop 2 SYMATTR InstName C2 SYMATTR Value 1.1pF SYMBOL cap -192 464 M180 WINDOW 0 44 44 Left 2 WINDOW 3 38 15 Left 2 SYMATTR InstName C3 SYMATTR Value 30p SYMBOL cap 480 464 M180 WINDOW 0 51 38 Left 2 WINDOW 3 42 15 Left 2 SYMATTR InstName C4 SYMATTR Value 30p SYMBOL Digital\\and 304 0 R0 WINDOW 3 -30 -2 Invisible 2 SYMATTR Value Vhigh=3V SYMATTR InstName A2 SYMATTR Value2 Vlow=0V SYMATTR SpiceLine trise=1n td=1n SYMBOL cap 128 96 R270 WINDOW 0 32 32 VTop 2 WINDOW 3 0 32 VBottom 2 SYMATTR InstName C5 SYMATTR Value 1n SYMBOL res -32 192 R90 WINDOW 0 -6 61 VBottom 2 WINDOW 3 35 55 VTop 2 SYMATTR InstName R2 SYMATTR Value 1k SYMBOL res 336 192 R90 WINDOW 0 -10 66 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R3 SYMATTR Value 1k SYMBOL res 352 96 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R6 SYMATTR Value 50 SYMBOL Digital\\and 624 0 R0 WINDOW 3 -30 -2 Invisible 2 SYMATTR Value Vhigh=3V SYMATTR InstName A3 SYMATTR Value2 Vlow=0V SYMATTR SpiceLine trise=1n td=1n SYMBOL res 672 96 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R4 SYMATTR Value 50 SYMBOL res -32 96 R270 WINDOW 0 32 56 VTop 2 WINDOW 3 0 56 VBottom 2 SYMATTR InstName R5 SYMATTR Value 50 TEXT -192 -104 Left 2 !.tran 0 1000u 0 .1n uic TEXT -192 -224 Left 2 ;Set "Rp=1e20" in the inductor to avoid damping by the default value of Rp.\nSet "trise=1n td=1n" in the inverter.\nSet "IC=100u" in the inductor to get a quick start.\nUse .tran with "uic". RECTANGLE Normal 416 496 -64 304 2 RECTANGLE Normal 80 128 -144 0 2 RECTANGLE Normal 464 128 240 0 2 RECTANGLE Normal 784 128 560 0 2
