(module DD-PAK_TO263_DualDiode_ThermalVias_RevA_31May2013 (layer F.Cu)
  (at 0 0)
  (descr "DD-PAK, TO263, Dual Diode, Thermal Vias,")
  (tags "DD-PAK, TO263, Dual Diode, Thermal Vias,")
  (path DD-PAK_TO263_Single_RevA_06Sep2012)
  (attr smd)
  (fp_text reference D (at -0.05 -9.85) (layer F.SilkS)
    (effects (font (size 1.27 1.27) (thickness 0.254)))
  (fp_text value DD-PAK_TO263_DualDiode_ThermalVias_RevA_31May2013 (at 0.50038 9.75106) (layer F.SilkS) hide
  (fp_line (start -5.5 -8.25) (end 5.5 -8.25) (layer F.Mask) (width 0.45))
  (fp_line (start 5.5 -8.25) (end 5.5 -4.25) (layer F.Mask) (width 0.45))
  (fp_line (start 5.5 -4.25) (end -5.5 -4.25) (layer F.Mask) (width 0.45))
  (fp_line (start -5.5 -4.25) (end -5.5 -8.25) (layer F.Mask) (width 0.45))
  (fp_circle (center 4 -4.75) (end 4.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 3 -4.75) (end 3.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 5 -4.75) (end 5.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -2 -4.75) (end -1.9 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -3 -4.75) (end -2.9 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -5 -4.75) (end -4.9 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -4 -4.75) (end -3.9 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 0 -4.75) (end 0.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -1 -4.75) (end -0.9 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 1 -4.75) (end 1.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 2 -7.75) (end 2.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 1 -7.75) (end 1.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 3 -7.75) (end 3.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 4 -7.75) (end 4.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 1 -6.75) (end 1.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 0 -6.75) (end 0.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -2 -6.75) (end -1.9 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -1 -6.75) (end -0.9 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 4 -5.75) (end 4.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 3 -5.75) (end 3.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 5 -5.75) (end 5.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 2 -4.75) (end 2.1 -4.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -2 -5.75) (end -1.9 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -3 -5.75) (end -2.9 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -5 -5.75) (end -4.9 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -4 -5.75) (end -3.9 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 3 -6.75) (end 3.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 2 -6.75) (end 2.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 4 -6.75) (end 4.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 5 -6.75) (end 5.1 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 2 -5.75) (end 2.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 1 -5.75) (end 1.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -1 -5.75) (end -0.9 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 0 -5.75) (end 0.1 -5.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -5 -6.75) (end -4.9 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 5 -7.75) (end 5.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -4 -6.75) (end -3.9 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -3 -6.75) (end -2.9 -6.75) (layer F.Mask) (width 0.215))
  (fp_circle (center 0 -7.75) (end 0.1 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -1 -7.75) (end -0.9 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -3 -7.75) (end -2.9 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -2 -7.75) (end -1.9 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -4 -7.75) (end -3.9 -7.75) (layer F.Mask) (width 0.215))
  (fp_circle (center -5 -7.75) (end -4.9 -7.75) (layer F.Mask) (width 0.215))
  (fp_line (start -5.25 -5.25) (end 5.25 -5.25) (layer F.Mask) (width 0.45))
  (fp_line (start -5.25 -5.25) (end 5.25 -5.25) (layer F.Paste) (width 0.45))
  (fp_line (start -5.25 -6.25) (end 5.25 -6.25) (layer F.Mask) (width 0.45))
  (fp_line (start -5.25 -6.25) (end 5.25 -6.25) (layer F.Paste) (width 0.45))
  (fp_line (start -5.25 -7.25) (end 5.25 -7.25) (layer F.Mask) (width 0.45))
  (fp_line (start -5.25 -7.25) (end 5.25 -7.25) (layer F.Paste) (width 0.45))
  (fp_line (start 4.5 -8.05) (end 4.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start 4.5 -8.05) (end 4.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start 3.5 -8.05) (end 3.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start 3.5 -8.05) (end 3.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start 2.5 -8.05) (end 2.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start 2.5 -8.05) (end 2.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start 1.5 -8.05) (end 1.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start 1.5 -8.05) (end 1.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start 0.5 -8.05) (end 0.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start 0.5 -8.05) (end 0.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -0.5 -8.05) (end -0.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start -0.5 -8.05) (end -0.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -1.5 -8.05) (end -1.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start -1.5 -8.05) (end -1.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -2.5 -8.05) (end -2.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start -2.5 -8.05) (end -2.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -3.5 -8.05) (end -3.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start -3.5 -8.05) (end -3.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -4.5 -8.05) (end -4.5 -4.5) (layer F.Mask) (width 0.45))
  (fp_line (start -4.5 -8.05) (end -4.5 -4.5) (layer F.Paste) (width 0.45))
  (fp_line (start -2.49936 -3.50012) (end 0 -3.50012) (layer F.SilkS) (width 0.3048))
  (fp_line (start -4.0005 -1.00076) (end -1.00076 -1.00076) (layer F.SilkS) (width 0.3048))
  (fp_line (start -2.5019 -2.49936) (end -4.0005 -1.00076) (layer F.SilkS) (width 0.3048))
  (fp_line (start -1.00076 -1.00076) (end -2.5019 -2.49936) (layer F.SilkS) (width 0.3048))
  (fp_line (start -4.0005 -2.49936) (end -1.00076 -2.49936) (layer F.SilkS) (width 0.3048))
  (fp_line (start -2.5019 -2.49936) (end -2.5019 -3.50012) (layer F.SilkS) (width 0.3048))
  (fp_line (start -2.5019 -1.00076) (end -2.5019 0) (layer F.SilkS) (width 0.3048))
  (fp_line (start 2.49936 -1.00076) (end 2.49936 0) (layer F.SilkS) (width 0.3048))
  (fp_line (start 2.49936 -2.49936) (end 2.49936 -3.50012) (layer F.SilkS) (width 0.3048))
  (fp_line (start 2.49936 -3.50012) (end 0 -3.50012) (layer F.SilkS) (width 0.3048))
  (fp_line (start 0 -3.50012) (end 0 -4.0005) (layer F.SilkS) (width 0.3048))
  (fp_line (start 1.00076 -2.49936) (end 4.0005 -2.49936) (layer F.SilkS) (width 0.3048))
  (fp_line (start 4.0005 -1.00076) (end 2.49936 -2.49936) (layer F.SilkS) (width 0.3048))
  (fp_line (start 2.49936 -2.49936) (end 1.00076 -1.00076) (layer F.SilkS) (width 0.3048))
  (fp_line (start 1.00076 -1.00076) (end 4.0005 -1.00076) (layer F.SilkS) (width 0.3048))
  (fp_line (start 4.0005 1.99898) (end 5.99948 1.99898) (layer F.SilkS) (width 0.3048))
  (fp_line (start 5.99948 1.99898) (end 5.99948 -7.00024) (layer F.SilkS) (width 0.3048))
  (fp_line (start -5.99948 -7.00024) (end -5.99948 1.99898) (layer F.SilkS) (width 0.3048))
  (fp_line (start -5.99948 1.99898) (end -4.0005 1.99898) (layer F.SilkS) (width 0.3048))
  (pad 2 thru_hole rect (at -5 -7.75) (size 1 1) (drill 0.4)
    (layers *.Cu B.Mask)
  (pad 2 thru_hole rect (at -4 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -4 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -5 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -3 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -2 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -2 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -3 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 1 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 2 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 2 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 1 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -1 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 0 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 0 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -1 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 3 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 3 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 4 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 5 -6.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 5 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 4 -7.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 4 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 5 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 5 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 4 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 3 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 3 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -1 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 0 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 0 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -1 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 1 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 2 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 2 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at 1 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -3 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -2 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -2 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -3 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -5 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -4 -4.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -4 -5.75) (size 1 1) (drill 0.4)
  (pad 2 thru_hole rect (at -5 -5.75) (size 1 1) (drill 0.4)
  (pad 1 smd rect (at -2.54 4.43992) (size 1.09982 7.0104)
    (layers F.Cu F.Paste F.Mask)
  (pad 3 smd rect (at 2.54 4.43992) (size 1.09982 7.0104)
  (pad ~ smd oval (at 0 -1.99898) (size 5.00126 1.99898)
    (layers F.Adhes)
  (model DD-PAK_TO263AB_Faktor03937_RevA_06Sep2012.wrl
    (at (xyz 0 0.075 0))
    (scale (xyz 0.3937 0.3937 0.3937))
    (rotate (xyz 0 0 0))
