library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; entity Counter4Bits is port ( Clock : in STD_LOGIC; Reset : in STD_LOGIC; Enable : in STD_LOGIC; Cnt : out STD_LOGIC_VECTOR(3 downto 0) ); end Counter4Bits; architecture Counter4Bits_arch of Counter4Bits is signal counter : STD_LOGIC_VECTOR(3 downto 0); begin process (Clock,Reset,Enable,Counter) begin if (Reset = '1') then counter <= (others => '0'); elsif (rising_edge(Clock)) then if (Enable = '1') then counter <= counter + 1; end if; --if (counter >= "1001") then -- counter <= (others => '0'); --end if; end if; end process; Cnt <= counter; end Counter4Bits_arch;
