################################################################################################### xorg.conf ################################################################################################### Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules" FontPath "/usr/share/fonts/X11/misc" FontPath "/usr/share/fonts/X11/100dpi/:unscaled" FontPath "/usr/share/fonts/X11/75dpi/:unscaled" FontPath "/usr/share/fonts/X11/Type1" FontPath "/usr/share/fonts/X11/100dpi" FontPath "/usr/share/fonts/X11/75dpi" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "built-ins" EndSection Section "Module" Load "dri2" Load "dbe" Load "record" Load "dri" Load "glx" Load "extmod" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5 6 7" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "Monitor Model" EndSection Section "Device" Identifier "gma500_gfx" Driver "fbdev" # Driver "modesetting" Option "SWCursor" "ON" BusID "PCI:0:2:0" EndSection Section "Screen" Identifier "Screen0" Device "gma500_gfx" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 16 EndSubSection SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection ################################################################################################### logfile mit fbdev: ################################################################################################### [ 80998.433] X.Org X Server 1.12.4 Release Date: 2012-08-27 [ 80998.433] X Protocol Version 11, Revision 0 [ 80998.433] Build Operating System: Linux 2.6.32-5-686-bigmem i686 Debian [ 80998.433] Current Operating System: Linux hserver 3.2.0-4-686-pae #1 SMP Debian 3.2.46-1 i686 [ 80998.433] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=906ec526-39df-44f4-a507-a8eb12bd7aca ro quiet [ 80998.433] Build Date: 17 April 2013 11:13:16AM [ 80998.433] xorg-server 2:1.12.4-6 (Julien Cristau ) [ 80998.433] Current version of pixman: 0.26.0 [ 80998.433] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 80998.433] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 80998.434] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 3 21:29:38 2013 [ 80998.434] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 80998.434] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 80998.435] (==) ServerLayout "X.org Configured" [ 80998.435] (**) |-->Screen "Screen0" (0) [ 80998.435] (**) | |-->Monitor "Monitor0" [ 80998.435] (**) | |-->Device "gma500_gfx" [ 80998.435] (**) |-->Input Device "Mouse0" [ 80998.435] (**) |-->Input Device "Keyboard0" [ 80998.435] (==) Automatically adding devices [ 80998.436] (==) Automatically enabling devices [ 80998.436] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. [ 80998.436] Entry deleted from font path. [ 80998.436] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 80998.436] Entry deleted from font path. [ 80998.436] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. [ 80998.436] Entry deleted from font path. [ 80998.436] (**) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins, /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 80998.436] (**) ModulePath set to "/usr/lib/xorg/modules" [ 80998.436] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 80998.436] (WW) Disabling Mouse0 [ 80998.436] (WW) Disabling Keyboard0 [ 80998.436] (II) Loader magic: 0xb777a5a0 [ 80998.436] (II) Module ABI versions: [ 80998.436] X.Org ANSI C Emulation: 0.4 [ 80998.436] X.Org Video Driver: 12.1 [ 80998.436] X.Org XInput driver : 16.0 [ 80998.436] X.Org Server Extension : 6.0 [ 80998.438] (--) PCI:*(0:0:2:0) 8086:0be2:1849:0be2 rev 11, Mem @ 0xdfc00000/1048576, I/O @ 0x0000f100/8 [ 80998.438] (II) Open ACPI successful (/var/run/acpid.socket) [ 80998.438] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) "glx" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) "record" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) "dri" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file. [ 80998.438] (II) LoadModule: "dri2" [ 80998.439] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so [ 80998.439] (II) Module dri2: vendor="X.Org Foundation" [ 80998.439] compiled for 1.12.4, module version = 1.2.0 [ 80998.439] ABI class: X.Org Server Extension, version 6.0 [ 80998.439] (II) Loading extension DRI2 [ 80998.439] (II) LoadModule: "dbe" [ 80998.439] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so [ 80998.440] (II) Module dbe: vendor="X.Org Foundation" [ 80998.440] compiled for 1.12.4, module version = 1.0.0 [ 80998.440] Module class: X.Org Server Extension [ 80998.440] ABI class: X.Org Server Extension, version 6.0 [ 80998.440] (II) Loading extension DOUBLE-BUFFER [ 80998.440] (II) LoadModule: "record" [ 80998.440] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so [ 80998.440] (II) Module record: vendor="X.Org Foundation" [ 80998.440] compiled for 1.12.4, module version = 1.13.0 [ 80998.441] Module class: X.Org Server Extension [ 80998.441] ABI class: X.Org Server Extension, version 6.0 [ 80998.441] (II) Loading extension RECORD [ 80998.441] (II) LoadModule: "dri" [ 80998.441] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so [ 80998.441] (II) Module dri: vendor="X.Org Foundation" [ 80998.441] compiled for 1.12.4, module version = 1.0.0 [ 80998.441] ABI class: X.Org Server Extension, version 6.0 [ 80998.441] (II) Loading extension XFree86-DRI [ 80998.441] (II) LoadModule: "glx" [ 80998.441] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 80998.442] (II) Module glx: vendor="X.Org Foundation" [ 80998.442] compiled for 1.12.4, module version = 1.0.0 [ 80998.442] ABI class: X.Org Server Extension, version 6.0 [ 80998.442] (==) AIGLX enabled [ 80998.442] (II) Loading extension GLX [ 80998.442] (II) LoadModule: "extmod" [ 80998.442] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so [ 80998.443] (II) Module extmod: vendor="X.Org Foundation" [ 80998.443] compiled for 1.12.4, module version = 1.0.0 [ 80998.443] Module class: X.Org Server Extension [ 80998.443] ABI class: X.Org Server Extension, version 6.0 [ 80998.443] (II) Loading extension SELinux [ 80998.443] (II) Loading extension MIT-SCREEN-SAVER [ 80998.443] (II) Loading extension XFree86-VidModeExtension [ 80998.443] (II) Loading extension XFree86-DGA [ 80998.443] (II) Loading extension DPMS [ 80998.443] (II) Loading extension XVideo [ 80998.443] (II) Loading extension XVideo-MotionCompensation [ 80998.443] (II) Loading extension X-Resource [ 80998.443] (II) LoadModule: "fbdev" [ 80998.444] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 80998.444] (II) Module fbdev: vendor="X.Org Foundation" [ 80998.444] compiled for 1.12.1, module version = 0.4.2 [ 80998.444] ABI class: X.Org Video Driver, version 12.0 [ 80998.444] (II) FBDEV: driver for framebuffer: fbdev [ 80998.444] (++) using VT number 9 [ 80998.454] (II) Loading sub module "fbdevhw" [ 80998.454] (II) LoadModule: "fbdevhw" [ 80998.454] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 80998.455] (II) Module fbdevhw: vendor="X.Org Foundation" [ 80998.455] compiled for 1.12.4, module version = 0.0.2 [ 80998.455] ABI class: X.Org Video Driver, version 12.1 [ 80998.455] (**) FBDEV(0): claimed PCI slot 0@0:2:0 [ 80998.455] (II) FBDEV(0): using default device [ 80998.455] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32 [ 80998.455] (==) FBDEV(0): RGB weight 888 [ 80998.455] (==) FBDEV(0): Default visual is TrueColor [ 80998.455] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0) [ 80998.455] (II) FBDEV(0): hardware: psbfb (video memory: 7352kB) [ 80998.455] (II) FBDEV(0): checking modes against framebuffer device... [ 80998.455] (II) FBDEV(0): checking modes against monitor... [ 80998.455] (--) FBDEV(0): Virtual size is 1024x768 (pitch 1024) [ 80998.455] (**) FBDEV(0): Built-in mode "current" [ 80998.455] (==) FBDEV(0): DPI set to (96, 96) [ 80998.456] (II) Loading sub module "fb" [ 80998.456] (II) LoadModule: "fb" [ 80998.456] (II) Loading /usr/lib/xorg/modules/libfb.so [ 80998.456] (II) Module fb: vendor="X.Org Foundation" [ 80998.456] compiled for 1.12.4, module version = 1.0.0 [ 80998.456] ABI class: X.Org ANSI C Emulation, version 0.4 [ 80998.456] (**) FBDEV(0): using shadow framebuffer [ 80998.456] (II) Loading sub module "shadow" [ 80998.456] (II) LoadModule: "shadow" [ 80998.457] (II) Loading /usr/lib/xorg/modules/libshadow.so [ 80998.457] (II) Module shadow: vendor="X.Org Foundation" [ 80998.457] compiled for 1.12.4, module version = 1.1.0 [ 80998.457] ABI class: X.Org ANSI C Emulation, version 0.4 [ 80998.457] (==) Depth 24 pixmap format is 32 bpp [ 80998.458] (==) FBDEV(0): Backing store disabled [ 80998.459] (==) FBDEV(0): DPMS enabled [ 80998.459] (==) RandR enabled [ 80998.459] (II) Initializing built-in extension Generic Event Extension [ 80998.459] (II) Initializing built-in extension SHAPE [ 80998.459] (II) Initializing built-in extension MIT-SHM [ 80998.459] (II) Initializing built-in extension XInputExtension [ 80998.459] (II) Initializing built-in extension XTEST [ 80998.459] (II) Initializing built-in extension BIG-REQUESTS [ 80998.459] (II) Initializing built-in extension SYNC [ 80998.459] (II) Initializing built-in extension XKEYBOARD [ 80998.459] (II) Initializing built-in extension XC-MISC [ 80998.459] (II) Initializing built-in extension SECURITY [ 80998.459] (II) Initializing built-in extension XINERAMA [ 80998.459] (II) Initializing built-in extension XFIXES [ 80998.459] (II) Initializing built-in extension RENDER [ 80998.459] (II) Initializing built-in extension RANDR [ 80998.459] (II) Initializing built-in extension COMPOSITE [ 80998.459] (II) Initializing built-in extension DAMAGE [ 80998.462] (II) SELinux: Disabled on system [ 80998.482] (II) AIGLX: Screen 0 is not DRI2 capable [ 80998.482] (II) AIGLX: Screen 0 is not DRI capable [ 80998.493] (II) AIGLX: Loaded and initialized swrast [ 80998.493] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 80998.645] (II) config/udev: Adding input device Power Button (/dev/input/event6) [ 80998.645] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 80998.645] (II) LoadModule: "evdev" [ 80998.646] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so [ 80998.646] (II) Module evdev: vendor="X.Org Foundation" [ 80998.646] compiled for 1.12.1, module version = 2.7.0 [ 80998.646] Module class: X.Org XInput Driver [ 80998.646] ABI class: X.Org XInput driver, version 16.0 [ 80998.646] (II) Using input driver 'evdev' for 'Power Button' [ 80998.646] (**) Power Button: always reports core events [ 80998.646] (**) evdev: Power Button: Device: "/dev/input/event6" [ 80998.646] (--) evdev: Power Button: Vendor 0 Product 0x1 [ 80998.647] (--) evdev: Power Button: Found keys [ 80998.647] (II) evdev: Power Button: Configuring as keyboard [ 80998.647] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event6" [ 80998.647] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6) [ 80998.647] (**) Option "xkb_rules" "evdev" [ 80998.647] (**) Option "xkb_model" "pc105" [ 80998.647] (**) Option "xkb_layout" "de" [ 80998.703] (II) config/udev: Adding input device Power Button (/dev/input/event4) [ 80998.704] (**) Power Button: Applying InputClass "evdev keyboard catchall" [ 80998.704] (II) Using input driver 'evdev' for 'Power Button' [ 80998.704] (**) Power Button: always reports core events [ 80998.704] (**) evdev: Power Button: Device: "/dev/input/event4" [ 80998.704] (--) evdev: Power Button: Vendor 0 Product 0x1 [ 80998.704] (--) evdev: Power Button: Found keys [ 80998.704] (II) evdev: Power Button: Configuring as keyboard [ 80998.704] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4/event4" [ 80998.704] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7) [ 80998.704] (**) Option "xkb_rules" "evdev" [ 80998.704] (**) Option "xkb_model" "pc105" [ 80998.704] (**) Option "xkb_layout" "de" [ 80998.706] (II) config/udev: Adding input device Sleep Button (/dev/input/event5) [ 80998.706] (**) Sleep Button: Applying InputClass "evdev keyboard catchall" [ 80998.706] (II) Using input driver 'evdev' for 'Sleep Button' [ 80998.706] (**) Sleep Button: always reports core events [ 80998.706] (**) evdev: Sleep Button: Device: "/dev/input/event5" [ 80998.706] (--) evdev: Sleep Button: Vendor 0 Product 0x3 [ 80998.706] (--) evdev: Sleep Button: Found keys [ 80998.706] (II) evdev: Sleep Button: Configuring as keyboard [ 80998.706] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5/event5" [ 80998.706] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8) [ 80998.706] (**) Option "xkb_rules" "evdev" [ 80998.706] (**) Option "xkb_model" "pc105" [ 80998.706] (**) Option "xkb_layout" "de" [ 80998.708] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event9) [ 80998.708] (II) No input driver specified, ignoring this device. [ 80998.708] (II) This device may have been added with another device file. [ 80998.709] (II) config/udev: Adding input device HDA Intel HDMI/DP,pcm=3 (/dev/input/event10) [ 80998.709] (II) No input driver specified, ignoring this device. [ 80998.709] (II) This device may have been added with another device file. [ 80998.709] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event11) [ 80998.709] (II) No input driver specified, ignoring this device. [ 80998.709] (II) This device may have been added with another device file. [ 80998.711] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:4024 (/dev/input/event1) [ 80998.711] (**) Logitech Unifying Device. Wireless PID:4024: Applying InputClass "evdev pointer catchall" [ 80998.711] (**) Logitech Unifying Device. Wireless PID:4024: Applying InputClass "evdev keyboard catchall" [ 80998.711] (II) Using input driver 'evdev' for 'Logitech Unifying Device. Wireless PID:4024' [ 80998.711] (**) Logitech Unifying Device. Wireless PID:4024: always reports core events [ 80998.711] (**) evdev: Logitech Unifying Device. Wireless PID:4024: Device: "/dev/input/event1" [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Vendor 0x46d Product 0xc52b [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found 20 mouse buttons [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found scroll wheel(s) [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found relative axes [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found x and y relative axes [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found absolute axes [ 80998.711] (II) evdev: Logitech Unifying Device. Wireless PID:4024: Forcing absolute x/y axes to exist. [ 80998.711] (--) evdev: Logitech Unifying Device. Wireless PID:4024: Found keys [ 80998.711] (II) evdev: Logitech Unifying Device. Wireless PID:4024: Configuring as mouse [ 80998.711] (II) evdev: Logitech Unifying Device. Wireless PID:4024: Configuring as keyboard [ 80998.711] (II) evdev: Logitech Unifying Device. Wireless PID:4024: Adding scrollwheel support [ 80998.711] (**) evdev: Logitech Unifying Device. Wireless PID:4024: YAxisMapping: buttons 4 and 5 [ 80998.712] (**) evdev: Logitech Unifying Device. Wireless PID:4024: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200 [ 80998.712] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb4/4-2/4-2:1.2/0003:046D:C52B.000F/input/input14/event1" [ 80998.712] (II) XINPUT: Adding extended input device "Logitech Unifying Device. Wireless PID:4024" (type: KEYBOARD, id 9) [ 80998.712] (**) Option "xkb_rules" "evdev" [ 80998.712] (**) Option "xkb_model" "pc105" [ 80998.712] (**) Option "xkb_layout" "de" [ 80998.712] (II) evdev: Logitech Unifying Device. Wireless PID:4024: initialized for relative axes. [ 80998.713] (WW) evdev: Logitech Unifying Device. Wireless PID:4024: ignoring absolute axes. [ 80998.713] (**) Logitech Unifying Device. Wireless PID:4024: (accel) keeping acceleration scheme 1 [ 80998.713] (**) Logitech Unifying Device. Wireless PID:4024: (accel) acceleration profile 0 [ 80998.713] (**) Logitech Unifying Device. Wireless PID:4024: (accel) acceleration factor: 2.000 [ 80998.713] (**) Logitech Unifying Device. Wireless PID:4024: (accel) acceleration threshold: 4 [ 80998.714] (II) config/udev: Adding input device Logitech Unifying Device. Wireless PID:4024 (/dev/input/mouse0) [ 80998.714] (II) No input driver specified, ignoring this device. [ 80998.714] (II) This device may have been added with another device file. [ 80998.715] (II) config/udev: Adding input device Afatech DVB-T 2 (/dev/input/event0) [ 80998.715] (**) Afatech DVB-T 2: Applying InputClass "evdev keyboard catchall" [ 80998.715] (II) Using input driver 'evdev' for 'Afatech DVB-T 2' [ 80998.715] (**) Afatech DVB-T 2: always reports core events [ 80998.715] (**) evdev: Afatech DVB-T 2: Device: "/dev/input/event0" [ 80998.715] (--) evdev: Afatech DVB-T 2: Vendor 0x15a4 Product 0x9016 [ 80998.715] (--) evdev: Afatech DVB-T 2: Found keys [ 80998.715] (II) evdev: Afatech DVB-T 2: Configuring as keyboard [ 80998.715] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb1/1-2/1-2:1.1/input/input0/event0" [ 80998.716] (II) XINPUT: Adding extended input device "Afatech DVB-T 2" (type: KEYBOARD, id 10) [ 80998.716] (**) Option "xkb_rules" "evdev" [ 80998.716] (**) Option "xkb_model" "pc105" [ 80998.716] (**) Option "xkb_layout" "de" [ 80998.717] (II) config/udev: Adding input device IR-receiver inside an USB DVB receiver (/dev/input/event8) [ 80998.717] (**) IR-receiver inside an USB DVB receiver: Applying InputClass "evdev keyboard catchall" [ 80998.717] (II) Using input driver 'evdev' for 'IR-receiver inside an USB DVB receiver' [ 80998.717] (**) IR-receiver inside an USB DVB receiver: always reports core events [ 80998.717] (**) evdev: IR-receiver inside an USB DVB receiver: Device: "/dev/input/event8" [ 80998.718] (--) evdev: IR-receiver inside an USB DVB receiver: Vendor 0x15a4 Product 0x9016 [ 80998.718] (--) evdev: IR-receiver inside an USB DVB receiver: Found keys [ 80998.718] (II) evdev: IR-receiver inside an USB DVB receiver: Configuring as keyboard [ 80998.718] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.7/usb1/1-2/rc/rc0/input8/event8" [ 80998.718] (II) XINPUT: Adding extended input device "IR-receiver inside an USB DVB receiver" (type: KEYBOARD, id 11) [ 80998.718] (**) Option "xkb_rules" "evdev" [ 80998.718] (**) Option "xkb_model" "pc105" [ 80998.718] (**) Option "xkb_layout" "de" [ 80998.719] (II) config/udev: Adding input device PC Speaker (/dev/input/event7) [ 80998.719] (II) No input driver specified, ignoring this device. [ 80998.719] (II) This device may have been added with another device file. ################################################################################################### logfile mit modesetting: ################################################################################################### [ 81088.246] X.Org X Server 1.12.4 Release Date: 2012-08-27 [ 81088.246] X Protocol Version 11, Revision 0 [ 81088.246] Build Operating System: Linux 2.6.32-5-686-bigmem i686 Debian [ 81088.246] Current Operating System: Linux hserver 3.2.0-4-686-pae #1 SMP Debian 3.2.46-1 i686 [ 81088.246] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=906ec526-39df-44f4-a507-a8eb12bd7aca ro quiet [ 81088.247] Build Date: 17 April 2013 11:13:16AM [ 81088.247] xorg-server 2:1.12.4-6 (Julien Cristau ) [ 81088.247] Current version of pixman: 0.26.0 [ 81088.247] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 81088.247] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 81088.247] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 3 21:31:07 2013 [ 81088.247] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 81088.247] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 81088.248] (==) ServerLayout "X.org Configured" [ 81088.248] (**) |-->Screen "Screen0" (0) [ 81088.248] (**) | |-->Monitor "Monitor0" [ 81088.249] (**) | |-->Device "gma500_gfx" [ 81088.249] (**) |-->Input Device "Mouse0" [ 81088.249] (**) |-->Input Device "Keyboard0" [ 81088.249] (==) Automatically adding devices [ 81088.249] (==) Automatically enabling devices [ 81088.249] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. [ 81088.249] Entry deleted from font path. [ 81088.249] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 81088.249] Entry deleted from font path. [ 81088.249] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. [ 81088.249] Entry deleted from font path. [ 81088.249] (**) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins, /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins [ 81088.249] (**) ModulePath set to "/usr/lib/xorg/modules" [ 81088.250] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled. [ 81088.250] (WW) Disabling Mouse0 [ 81088.250] (WW) Disabling Keyboard0 [ 81088.250] (II) Loader magic: 0xb77255a0 [ 81088.250] (II) Module ABI versions: [ 81088.250] X.Org ANSI C Emulation: 0.4 [ 81088.250] X.Org Video Driver: 12.1 [ 81088.250] X.Org XInput driver : 16.0 [ 81088.250] X.Org Server Extension : 6.0 [ 81088.251] (--) PCI:*(0:0:2:0) 8086:0be2:1849:0be2 rev 11, Mem @ 0xdfc00000/1048576, I/O @ 0x0000f100/8 [ 81088.251] (II) Open ACPI successful (/var/run/acpid.socket) [ 81088.251] (II) "extmod" will be loaded. This was enabled by default and also specified in the config file. [ 81088.251] (II) "dbe" will be loaded. This was enabled by default and also specified in the config file. [ 81088.251] (II) "glx" will be loaded. This was enabled by default and also specified in the config file. [ 81088.251] (II) "record" will be loaded. This was enabled by default and also specified in the config file. [ 81088.251] (II) "dri" will be loaded. This was enabled by default and also specified in the config file. [ 81088.252] (II) "dri2" will be loaded. This was enabled by default and also specified in the config file. [ 81088.252] (II) LoadModule: "dri2" [ 81088.252] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so [ 81088.253] (II) Module dri2: vendor="X.Org Foundation" [ 81088.253] compiled for 1.12.4, module version = 1.2.0 [ 81088.253] ABI class: X.Org Server Extension, version 6.0 [ 81088.253] (II) Loading extension DRI2 [ 81088.253] (II) LoadModule: "dbe" [ 81088.253] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so [ 81088.253] (II) Module dbe: vendor="X.Org Foundation" [ 81088.253] compiled for 1.12.4, module version = 1.0.0 [ 81088.253] Module class: X.Org Server Extension [ 81088.253] ABI class: X.Org Server Extension, version 6.0 [ 81088.253] (II) Loading extension DOUBLE-BUFFER [ 81088.253] (II) LoadModule: "record" [ 81088.254] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so [ 81088.254] (II) Module record: vendor="X.Org Foundation" [ 81088.254] compiled for 1.12.4, module version = 1.13.0 [ 81088.254] Module class: X.Org Server Extension [ 81088.254] ABI class: X.Org Server Extension, version 6.0 [ 81088.254] (II) Loading extension RECORD [ 81088.254] (II) LoadModule: "dri" [ 81088.254] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so [ 81088.254] (II) Module dri: vendor="X.Org Foundation" [ 81088.254] compiled for 1.12.4, module version = 1.0.0 [ 81088.254] ABI class: X.Org Server Extension, version 6.0 [ 81088.255] (II) Loading extension XFree86-DRI [ 81088.255] (II) LoadModule: "glx" [ 81088.255] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 81088.255] (II) Module glx: vendor="X.Org Foundation" [ 81088.255] compiled for 1.12.4, module version = 1.0.0 [ 81088.255] ABI class: X.Org Server Extension, version 6.0 [ 81088.255] (==) AIGLX enabled [ 81088.255] (II) Loading extension GLX [ 81088.255] (II) LoadModule: "extmod" [ 81088.256] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so [ 81088.256] (II) Module extmod: vendor="X.Org Foundation" [ 81088.256] compiled for 1.12.4, module version = 1.0.0 [ 81088.256] Module class: X.Org Server Extension [ 81088.256] ABI class: X.Org Server Extension, version 6.0 [ 81088.256] (II) Loading extension SELinux [ 81088.256] (II) Loading extension MIT-SCREEN-SAVER [ 81088.256] (II) Loading extension XFree86-VidModeExtension [ 81088.257] (II) Loading extension XFree86-DGA [ 81088.257] (II) Loading extension DPMS [ 81088.257] (II) Loading extension XVideo [ 81088.257] (II) Loading extension XVideo-MotionCompensation [ 81088.257] (II) Loading extension X-Resource [ 81088.257] (II) LoadModule: "modesetting" [ 81088.257] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 81088.258] (II) Module modesetting: vendor="X.Org Foundation" [ 81088.258] compiled for 1.12.1.902, module version = 0.3.0 [ 81088.258] Module class: X.Org Video Driver [ 81088.258] ABI class: X.Org Video Driver, version 12.0 [ 81088.258] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 81088.258] (++) using VT number 7 [ 81088.268] (WW) Falling back to old probe method for modesetting [ 81088.268] (II) UnloadModule: "modesetting" [ 81088.268] (EE) Screen(s) found, but none have a usable configuration. [ 81088.268] Fatal server error: [ 81088.268] no screens found [ 81088.268] Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 81088.268] Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 81088.268] [ 81088.277] Server terminated with error (1). Closing log file.
